09-MPLS Command Reference
HomeSupportSwitchesH3C S12500 Switch SeriesReference GuidesCommand ReferencesH3C S12500 Command References-Release1828P04-6W18209-MPLS Command Reference
03-VPLS Commands
03-VPLS Commands 235.49 KB
The term "router" in this document refers to both routers and Layer 3 switches.
car
car { inbound | outbound } name car-name
undo car { inbound | outbound }
View
Service instance view
Default level
2: System level
inbound: Applies a global CAR action in the inbound direction.
outbound: Applies a global CAR action in the outbound direction.
name car-name: Specifies a global CAR action by name, a string of 1 to 31 characters.
Use car to apply a global CAR action in the inbound or outbound traffic on an attachment circuit (AC).
Use undo car to restore the default.
By default, no global CAR action is applied to an AC.
# Apply global CAR action car1 to inbound traffic and car2 to outbound traffic for service instance 200 on the interface GigabitEthernet 3/0/1.
[Sysname] interface GigabitEthernet 3/0/1
[Sysname-GigabitEthernet3/0/1] service-instance 200
[Sysname-GigabitEthernet3/0/1-srv200] car inbound name car1
[Sysname-GigabitEthernet3/0/1-srv200] car outbound name car2
description
View
VSI view
Default level
2: System level
text: Description for a VPLS instance, a string of 1 to 80 characters.
Use description to set a description for a VPLS instance.
Use undo description to remove the configuration.
By default, no description is set for a VPLS instance.
# Set the description of VPLS instance aaa to Aaa_Technologies_Co._Ltd..
[Sysname] vsi aaa
[Sysname-vsi-aaa] description Aaa_Technologies_Co._Ltd.
display bgp vpls
display bgp vpls { all | group [ group-name ] | peer [ [ ip-address ] verbose ] | route-distinguisher route-distinguisher [ site-id site-id [ label-offset label-offset ] ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Specifies all VPLS information in the BGP routing table.
group group-name: Specifies a peer group by its name, a string of 1 to 47 characters.
ip-address: IP address of the peer.
verbose: Displays detailed information.
route-distinguisher route-distinguisher: Specifies the route distinguisher (RD), a string of 3 to 21 characters in the format of nn:nn or IP_address:nn.
site-id site-id: Specifies the site in the VPLS instance by its ID.
label-offset label-offset: Specifies the label offset value in the range of 0 to 65535.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display bgp vpls to display the VPLS information in a BGP routing table.
# Display all VPLS information in the BGP routing table.
<Sysname> display bgp vpls all
 BGP Local Router ID : 2.2.2.9, Local AS number : 100
 Origin codes:i - IGP, e - EGP, ? - incomplete
 BGP.VPLS: 1 destination
 **Route Distinguisher: 100:1
 SITE ID    LB Offset    LB Size    LB Base    Nexthop    LocPref
 1          0            10         131346     3.3.3.9    100
BGP Local Router ID
Router ID of the local BGP router.
Local AS number
Number of the local AS.
Origin codes
Route origin codes. Valid values include:
·     i - IGP—Learned from within the AS.
·     e - EGP—Learned through EGP.
·     ? - incomplete—Learned in any other way.
BGP.VPLS
Number of BGP VPLS.
SITE ID
ID of a site in the VPLS instance.
LB Offset
Label offset value.
LB Size
Size of the label block.
LB Base
Initial label of the label block.
LocPref
Local preference.
# Display detailed information about VPLS peer 3.3.3.9 in the BGP routing table.
<Sysname> display bgp vpls peer 3.3.3.9 verbose
         Peer: 3.3.3.9   Local: 2.2.2.9
         Type: IBGP link
         BGP version 4, remote router ID 3.3.3.9
         BGP current state: Established, Up for 01h06m42s
         BGP last state: OpenConfirm
         Port:  Local - 1040      Remote - 179
         Configured: Active Hold Time: 180 sec   Keep Alive Time:60 sec
         Received  : Active Hold Time: 180 sec
         Negotiated: Active Hold Time: 180 sec   Keep Alive Time:60 sec
         Peer optional capabilities:
         Peer support bgp multi-protocol extended
         Peer support bgp route refresh capability
         Graceful Restart Capability: received
             Restart Timer Value of Peer: 150 seconds
             Forwarding State preserved by Peer for following Address families:
                 IPv4 Unicast
                 VPLS
         Address family IPv4 Unicast: advertised and received
         Address family VPLS: advertised and received
 Received: Total 26 messages, Update messages 2
 Sent: Total 28 messages, Update messages 2
 Threshold: 75%
 Minimum time between advertisement runs is 15 seconds
 Optional capabilities:
 Connect-interface has been configured
 Peer Preferred Value: 0
  BFD: Enabled
 Routing policy configured:
Peer
Local
IP address of the local router.
BGP type.
BGP version 4
BGP version information.
remote router ID
IP address of the remote router.
BGP current state
Current status of the BGP session.
BGP current event
Current event of the BGP session.
BGP last state
State that the BGP session was in before transitioning to the current status.
Port
Local and remote port numbers of the BGP session.
Configured
Settings of the local timers.
Received
Received active hold interval.
Negotiated
Negotiated timer settings.
Optional peer capabilities. In this example, the peer supports BGP multicast protocol extension and route refresh.
Information about Graceful Restart (GR) capability, including the peer restart timer and the address families for which forwarding state is preserved.
IPv4 unicast address family capability.
Address family VPLS
VPLS address family.
Received
Counts of received messages, including the total number of received messages and the number of received update messages.
Sent
Counts of sent messages, including the total number of sent messages and the number of sent update messages.
Maximum number of routes allowed.
Threshold
Threshold value. When the number of routes reaches the maximum number of routes allowed multiplied by this threshold value, an alarm is issued.
Minimum time between advertisement runs is XX seconds
Minimum advertising interval.
Optional capabilities. In this example, route refresh capability is enabled, and the directly connected interface is configured.
Peer preference value.
BFD
Whether BFD is enabled for the peer.
Routing policy configured for the peer.
# Display the VPLS information for RD 100:1 in the BGP routing table.
<Sysname> display bgp vpls route-distinguisher 100:1
 BGP Local Router ID : 2.2.2.9, Local AS Number : 100
 8          0            10         524624     3.3.3.9    100
BGP Local Router ID
Local AS Number
Origin codes
BGP.VPLS
Number of BGP VPLS.
SITE ID
LB Offset
Label offset value.
LB Size
LB Base
Nexthop
Address of the next hop.
LocPref
Local preference.
# Display the VPLS information for specified RD, CE number, and label offset in the BGP routing table.
<Sysname> display bgp vpls route-distinguisher 100:1 site-id 4 label-offset 0
 BGP Local router ID : 2.2.2.9, local AS number : 100
 *Nexthop : 3.3.3.9    ,  Locpref      : 100
 Metric   : 133        ,  Flag         : 0x85
 LB Base  : 132096     ,  LB NewBase   : 0
 LB Size  : 10         ,  Label Offset : 0
 MTU      :0           ,  Encap Type   :Unknown or Reserved
 Path Attribute : RefCount : 1, MED 133: , AS Path : 200
The following table gives the description on the fields of the display bgp vpls route-distinguisher site-id label-offset command.
BGP Local router ID
local AS number
Origin codes
*Nexthop
Locpref
Local preference.
Metric
Cost value.
Flag
Current status of the label:
0x0001 (BGP_VPLS_LB_NOT_SENTTO_VPLS)
0x0002 (BGP_VPLS_LB_SENTTO_VPLS)
0x0004 (BGP_VPLS_LB_SELECTED)
0x0008 (BGP_VPLS_LB_ASBR_TNLDOWN)
0x0010 (BGP_VPLS_LB_FROM_RR_IBGP)
0x0020 (BGP_VPLS_LB_FROM_RR_EBGP)
0x0040 (BGP_VPLS_LB_FROM_IBGP)
0x0080 (BGP_VPLS_LB_FROM_EBGP)
0x0085 (BGP_VPLS_LB_NOT_SENTTO_VPLS | BGP_VPLS_LB_SELECTED | BGP_VPLS_LB_FROM_EBGP)
LB Offset
Label offset value.
LB Size
LB Base
LB NewBase
New label block.
RefCount
Label reference count.
MED
Cost value.
AS Path
AS path of the route.
MTU
Maximum transmission unit at Layer 2.
Encap Type
Encapsulation type.
display l2vpn fast-switch-group
display l2vpn fast-switch-group [ group-index ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
group-index: Fast switching group index in the range of 0 to 4095.
Use display l2vpn fast-switch-group to display information about one or all fast switching groups.
The switch does not support this command.
# Display information about all fast switching groups.
<Sysname> display l2vpn fast-switch-group
Fast group index       :0
Peer router ID         :20.0.0.1
Backup-peer router ID  :20.0.0.2
In used peer router ID :20.0.0.1
Reference counter      :1
Fast group index       :1
Peer router ID         :30.0.0.1
Backup-peer router ID  :30.0.0.2
In used peer router ID  :30.0.0.1
Table 5 Command output
Fast group index
Index of the fast switching group.
Peer router ID
Address of the VPLS instance peer.
Address of the backup peer.
Address of the peer that is in use.
Reference counter
Number of times that the group has been referenced.
display mac-address vsi
display mac-address vsi [ vsi-name ] [ blackhole | dynamic | static ] [ count ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vsi-name: Name of the VPLS instance, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed.
blackhole: Black hole MAC forwarding entries.
dynamic: Dynamic MAC forwarding entries.
static: Static MAC forwarding entries.
count: Number of MAC forwarding entries.
Use display mac-address vsi to display the MAC address table information for a specific VPLS instance or all VPLS instances.
Related commands: vsi; mac-address (Layer 2—LAN Switching Command Reference).
The switch does not support black hole MAC forwarding entries (blackhole) and static MAC forwarding entries (static). If you specify the blackhole and static keywords, no information is output for them.
# Display information about the MAC address table.
<Sysname> display mac-address vsi
MAC ADDR         STATE            VSI ID   PEER IP           AGING TIME
 0000-0000-000a  dynamic          1        Vlan 300          AGING
 0000-0000-0009  dynamic          1        LinkId 1          AGING
--- 2 mac address(es) found  ---
# Display the total number of entries in the MAC address table.
<Sysname> display mac-address vsi count
Table 6 Command output
MAC ADDR
MAC address.
STATE
Status of the MAC address.
MACTYPE
MAC address type of the VPLS instance.
Vsilndex
VSI index.
LINK ID
Link ID.
VSI ID
ID of the VPLS instance.
PEER IP
IP address of the peer in the VPLS instance. For a device on the private network side, it is the ID of the VLAN to which the switch belongs. For a device on the public network side, it is the PW ID.
AGING TIME
Whether the MAC address of the VPLS instance get aged, AGING or NOAGED.
XX mac address(es) found
Total number of MAC addresses in the MAC address table of the VPLS instance.
display mpls l2vpn fib ac vpls
In standalone mode:
display mpls l2vpn fib ac vpls [ vsi vsi-name | interface interface-type interface-number [ service-instance service-instanceid ] ] [ slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display mpls l2vpn fib ac vpls [ vsi vsi-name | interface interface-type interface-number [ service-instance service-instanceid ] ] [ chassis chassis-number slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vsi vsi-name: Specifies the VPLS instance name, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed.
interface interface-type interface-number: Specifies the interface connecting a CE by its type and number.
service-instance service-instanceid: Specifies a service instance. service-instanceid is the service instance ID in the range of 1 to 4094.
verbose: Displays the detailed information.
slot slot-number: Displays the AC information on a card. slot-number represents the number of the slot that holds the card. Use this option when your switch is operating in standalone (the default) mode.
chassis chassis-number slot slot-number: Displays the AC entries of a card on an IRF member switch. The chassis-number argument represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. You can display the chassis number and slot number with the display device command. Use this option when your switch is operating in IRF mode.
Use display mpls l2vpn fib ac vpls to display the AC entry information for one or all VPLS instances.
When you use this command, note these guidelines:
·     If you specify an interface but do not specify a service instance, the command displays the AC entries of the VPLS connection created on the Layer 3 interface.
·     If you specify both an interface and a service instance, the command displays the AC entries of the VPLS connection created for the service instance on the Layer 2 interface.
·     If you do not specify any parameter, the command displays the AC entries of all VPLS connections.
# Display the AC entry information for all VPLS instances.
<Sysname> display mpls l2vpn fib ac vpls
Total VSI Entry:1          Total AC Entry:1
In Interface     ServID  VSIName              VSIIndex LinkID
GE3/1/1          1000    vsi1                 1        1
Table 7 Command output
Total VSI Entry
Total number of VSI entries, which is displayed only when you display all VPLS AC entries.
Total AC Entry
Total number of VPLS AC entries, which is displayed only when you display all VPLS AC entries.
In Interface
Incoming interface, the interface bound to an L2VPN.
ServID
Service instance ID.
VSIName
VPLS instance name.
VSIIndex
VPLS instance index.
LinkID
Link ID of an AC in the VPLS instance.
# Display the detailed AC entry information for all VPLS instances.
<Sysname> display mpls l2vpn fib ac vpls verbose
Total VSI Entry:2           Total AC Entry:2
  VSI Name: aaa                             VSI Index: 0
  **In Interface        : GE3/0/1
    Service Instance ID : 1
    Link ID             : 9
    Access Mode         : Vlan
    CE Type             : Independent
    AC Encapsulation    : s-vid 300 c-vid 400 to 500 600 700
    Hub Spoke Type      : ----
    GR Count            : 0
  VSI Name: bbb                             VSI Index: 1
    Service Instance ID : 2
    Link ID             : 9
    Access Mode         : Vlan
    AC Encapsulation    : s-vid 4011 4012 to 4050
    GR Count            : 0
Table 8 Command output
Total VSI Entry
Total AC Entry
VSI Name
Name of the VPLS instance.
VSI Index
Index of the VPLS instance.
In Interface
Link ID
Access Mode
Access mode at the AC side.
CE Type
Interface encapsulation type at the AC side, which can be PortVlan or Independent.
AC Encapsulation
Encapsulation VLAN information at the AC side.
GR Count
Number of times that GR occurs.
display mpls l2vpn fib pw vpls
In standalone mode:
display mpls l2vpn fib pw vpls [ vsi vsi-name [ link link-id ] ] [ slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
In IRF mode:
display mpls l2vpn fib pw vpls [ vsi vsi-name [ link link-id ] ] [ chassis chassis-number slot slot-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vsi vsi-name: Specifies the VPLS instance name, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed. The specified VPLS instance must have existed.
link link-id: Specifies a PW in the VPLS instance by its link ID. The specified PW must have existed.
slot slot-number: Displays the PW information on a card. The slot-number argument represents the number of the slot that holds the card. Use this option when your switch is operating in standalone (the default) mode.
chassis chassis-number slot slot-number: Displays the PW entries of a card on an IRF member switch. The chassis-number represents the ID of the IRF member switch, and the slot-number argument represents the number of the slot that holds the card. You can display the chassis number and slot number with the display device command. Use this option when your switch is operating in IRF mode.
Use display mpls l2vpn fib pw vpls to display the PW entry information for one or all VPLS instances.
# Display the PW entry information for all VPLS instance.
<Sysname> display mpls l2vpn fib pw vpls
Total VSI Entry:1          Total PW Entry:1
VSI Name   VSI Index  Link ID InVCLabel OutVCLabel TunnelID
vsi1       1          1       1000      1002       0x878ad000
Table 9 Command output
Total VSI Entry
Total number of VSI entries, which is displayed only when you display all VPLS PW entries.
Total PW Entry
Total number of VPLS PW entries, which is displayed only when you display all VPLS PW entries.
VSI Name
VPLS instance name.
VSI Index
Link ID
Link ID of a PW in the VPLS instance.
InVCLabel
Incoming VC label.
OutVCLabel
Outgoing VC label.
TunnelID
Public tunnel ID.
# Display the detailed PW entry information for all VPLS instances.
<Sysname> display mpls l2vpn fib pw vpls verbose
  VSI Name : vsi1                    VSI Index: 0
  **Link ID             : 1
    In Interface        : GE3/1/1
    In VC Label         : 1000
    Out VC Label        : 1002
    Encapsulation Type  : Ethernet
    Hub Spoke Type      : Hub
    MTU                 : 1500
    Role                : Main
    State               : Active
    Dual Link ID        : 2
    Fast Switch Group ID: 1
    Tunnel ID           : 0x878ad000(Done)
                          GrCount:1
    Tunnel ID           : 0x878ad001(Waiting)
                          GrCount:1
Table 10 Command output
Total VSI Entry
Total PW Entry
VSI Name
VPLS instance name.
VSI Index
Link ID
In Interface
In VC Label
Incoming VC label.
Out VC Label
Outgoing VC label.
MTU
Maximum transmission unit.
Role
PW role, which can be Main, Backup, or Normal.
PW state, active or standby.
Dual Link ID
Link ID of the other PW, which is displayed when main and backup PWs exist in the VPLS instance.
PW group ID.
Tunnel ID
Public tunnel ID and entry state (Done or Waiting)
GrCount: Number of times that GR occurs.
display pw-class
display pw-class [ pw-class-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
pw-class-name: Name of a PW class, a case-insensitive string of 1 to 19 characters.
Use display pw-class to display information about one or all PW classes.
If no PW class is specified, the command displays information about all PW classes.
If you specify a PW class, the command output includes an additional field to show the number of times the PW class has been referenced.
# Display information about all PW classes.
<Sysname> display pw-class
Total 3 PW-class(es)
PW-class name     Transport mode   Tunnel policy
1234              Ethernet         abc
1025              VLAN             abc
1026              VLAN             -
# Display information about the PW class named 1234.
<Sysname> display pw-class 1234
PW-class name         Transport mode  Tunnel policy       Reference count
1234                  Ethernet        abc                 0
Table 11 Command output
Tunnel policy
Name of the tunneling policy used by the PW class. If no tunneling policy is specified for the PW class, this field displays a hyphen (-).
Reference count
Number of times that the PW class are referenced.
display service-instance interface
display service-instance interface interface-type interface-number [ service-instance service-instance-id ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type interface-number: Specifies an interface by it type and number.
service-instance service-instance-id: Specifies a service instance configured on the specified interface. service-instance-id is in the range of 1 to 4094. If you do not specify any service instance, the command displays information about all service instances configured on the specified interface.
Use display service-instance interface to display information about one or all service instances configured on an interface.
# Display information about all service instances configured on GigabitEthernet 3/0/3.
<Sysname> display service-instance interface GigabitEthernet 3/0/3
 Service instance     : 1000
 Encapsulation        : s-vid 100
 MTU                  : 1500
 Access-mode          : VLAN
 Service type         : VPLS
 Service instance     : 1002
 Encapsulation        : s-vid 103
 MTU                  : 1500
 Access-mode          : VLAN
 Service type         : VPLS
Table 12 Command output
Encapsulation
Packet matching rule.
Service Type
Service type associated with the service instance. The service type can be VPLS or VPWS, and is displayed as – when the service instance is not associated with L2VPN.
display vpls connection
display vpls connection [ bgp | ldp | vsi vsi-name ] [ block | down | up ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
bgp: Specifies all Kompella VPLS connections.
ldp: Specifies all Martini VPLS connections.
vsi vsi-name: Specifies a VPLS instance by its name, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed.
block: Specifies VPLS connections that are blocked. A PW in the block state is not used for the moment.
down: Specifies VPLS connections that are down.
up: Specifies VPLS connections that are up.
Use display vpls connection to display information about VPLS connections.
Related commands: vsi.
# Display information about VPLS connections of VPLS instance aaa.
<Sysname> display vpls connection vsi aaa
Total 1 connection(s),
connection(s): 1 up, 0 block, 0 down, 1 ldp, 0 bgp
VSI Name: aaa                           Signaling: ldp
VsiID   VsiType   PeerAddr   InLabel   OutLabel   LinkID   VCState
500     vlan      1.1.1.9    1024      1024       1        up
Table 13 Command output
VSI Name
Signaling
Type of the PW signaling protocol used by the VPLS instance.
VsiID
VsiType
Access type of the VPLS instance.
PeerAddr
Address of the peer in the VPLS instance.
InLabel
Incoming label of the VPLS instance.
OutLabel
Outgoing label of the VPLS instance.
LinkID
ID of the PW in the VPLS instance.
VCState
Status of the VC.
# Display detailed information about VPLS connections of VPLS instance aaa.
<Sysname> display vpls connection vsi aaa verbose
  **Remote Vsi ID        : 500
    VC State             : up
    Encapsulation        : vlan
    Group ID             : 0
    MTU                  : 1500
    Peer Ip Address      : 1.1.1.9
    PW Type              : label
    Local VC Label       : 1024
    Remote VC Label      : 1024
    Link ID              : 1
    Tunnel Policy        : --
    Tunnel ID            : 0x3703ae
    Local VCCV CC Type   : CW, RA
    Local VCCV CV Type   : LSPV
    Remote VCCV CC Type  : CW, RA
    Remote VCCV CV Type  : LSPV
Table 14 Command output
VSI Name
Signaling
Remote Vsi ID
VC State
Status of the virtual circuit.
Encapsulation
Encapsulation type of the VPLS instance.
MTU
Maximum transmission unit of the VPLS instance.
Peer Ip Address
IP address of the peer of the VPLS instance.
PW Type
PW type:
·     label—NPW, the PW with a PE.
·     MEHVPLS—UPW, the PW with a UPE.
Link ID
Local VCCV CC Type
Virtual Circuit Connectivity Verification (VCCV) control channel (CC) types supported on the local peer:
·     CW—Control word.
·     RA—Router alert (RA) label.
VCCV is technology like ping. It is used to check the connectivity of L2VPN PWs.
Local VCCV CV Type
VCCV connectivity verification (CV) types supported on the local peer. Only LSPV is supported, indicating that MPLS LSP ping is used to check the PW connectivity.
Remote VCCV CC Type
VCCV control channel types supported on the remote peer.
Remote VCCV CV Type
VCCV connectivity verification types supported on the remote peer.
You can use VCCV to verify the connectivity of a PW only if the two peers support at least one identical CC type and one identical CV type.
display vsi
display vsi [ vsi-name ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display vsi to display information about a specific VPLS instance or all VPLS instances.
# Display information about VPLS instance aaa.
<Sysname> display vsi aaa
Vsi                             Mem    PW   Mac       Encap     Mtu   Vsi
Name                            Disc   Type Learn     Type      Value State
aaa                             static ldp  unqualify vlan      1500  up
Table 15 Command output
Vsi Name
Name of the VSI.
Mem Disc
Peer discovery mechanism of the VSI:
·     static—The peer must be configured manually.
·     auto—The peer automatic discovery mechanism is used.
PW Type
PW signaling protocol, ldp or bgp.
Mac Learn
MAC address learning type, unqualify or qualify.
Encap Type
PW encapsulation type, vlan, ethernet, or bgp-vpls.
Mtu Value
Vsi State
Status of the VSI, up or down.
# Display detailed configuration information about VPLS instance aaa, which uses LDP as the PW signaling protocol.
<Sysname> display vsi aaa verbose
***VSI Name                  : aaa
    VSI Index                : 0
    VSI Description          : 1
    PW Signaling             : ldp
    Member Discovery Style   : static
    PW MAC Learn Style       : unqualify
    Encapsulation Type       : vlan
    MTU                      : 1500
    Bandwidth                : 102400 kbps
    BroadcastRestrain        : 5%
    Multicast Restrain       : 50%
    Unknown Unicast Restrain : 10%
    MacTabLimit              : 128
    Drop Unknown             : enabled
    MacLearnEnable           : enable
    Hub-spoke                : unspecified
    P2P                      : unspecified
    Wait to Restore Time     : 10(Min)
    VSI State                : down
    VSI ID                   : 100
   *Peer Router ID           : 2.2.2.2
    VC Label                 : 1024
    Session                  : up
    Service                  : QoS
    Inbound CAR name         : car1
    Inbound CAR ID           : 1
    Outbound CAR name        : car1
    Outbound CAR ID          : 1
    Interface Name           : GigabitEthernet3/0/3
    State                    : down
    Service instance ID      : 100
   *Peer Ip Address          : 2.2.2.2
    PW State                 : up
    Remote VC Label          : 1027
    PW Type                  : label
    Tunnel ID                : 0xd2008
    Remote VCCV CC Type      : RA
# Display detailed configuration information about VPLS instance bbb, which uses BGP as the PW signaling protocol.
<Sysname> display vsi bbb verbose
***VSI Name                  : bbb
    VSI Index                : 1
    PW Signaling             : bgp
    Member Discovery Style   : auto
    MTU                      : 1500
    MacTabLimit              : 128
    Drop Unknown             : disabled
    Wait to Restore Time     : Invalid
    VSI State                : down
    BGP RD                   : 111:1
    SiteID/Range/Offset      : 100/10/0
    Import vpn target        : 111:1
    Export vpn target        : 111:1
    Local Label Block        : 8192/10/0
    Interface Name           : GigabitEthernet3/0/4
    State                    : down
    Service instance ID      : 200
Table 16 Command output
VSI Name
VSI Index
VSI Description
Description of the VPLS instance.
PW Signaling
Type of the PW signaling protocol used by the VPLS instance, which can be ldp or bgp.
Peer discovery mechanism of the VPLS instance:
·     static—The peer must be specified manually.
PW MAC Learn Style
Encapsulation Type
IntfIndex
Index of the interface.
MTU
Bandwidth
Bandwidth threshold of the VPLS instance.
BroadcastRestrain
Broadcast suppression ratio of the VPLS instance.
Multicast Restrain
Multicast suppression ratio of the VPLS instance.
Unknown unicast suppression ratio of the VPLS instance.
MacTabLimit
Maximum number of MAC addresses for a VPLS instance.
Drop Unknown
Whether to drop packets with unknown source MAC addresses when the VPLS instance has learned the maximum number of MAC addresses allowed.
·     enabled—Drops packets with unknown source MAC addresses.
·     disabled—Forwards packets with unknown source MAC addresses.
MacLearnEnable
Whether MAC address learning is enabled.
Hub-spoke
Whether Hub-Spoke capability is enabled when the peer discovery mechanism is static.
P2P
Whether P2P capability is enabled when the peer discovery mechanism is static.
PW switchback delay time, in minutes. A value of invalid means that the switchback function is disabled.
VSI State
Status of the VPLS instance, down or up.
Local VCCV CC Type
Virtual Circuit Connectivity Verification (VCCV) control channel types supported on the local peer:
·     CW—Control word.
VCCV is a technology like ping. It is used to check the connectivity of L2VPN PWs.
Local VCCV CV Type
VCCV connectivity verification types supported on the local peer. Only LSPV is supported, indicating that MPLS LSP ping is used to check the PW connectivity.
VSI ID
Peer Router ID
ID of the peer.
VC Label
Label of the VC.
Session
Status of the session.
Service
Enabled services:
·     Statistics—The statistics collection service.
·     QoS—The PW traffic policing service.
Inbound CAR name
Name of the CAR action applied in the inbound direction. If no CAR action is specified, this field does not appear.
Inbound CAR ID
ID of the CAR action applied in the inbound direction. If no CAR action is specified, this field does not appear.
Outbound CAR name
Name of the CAR action applied in the outbound direction. If no CAR action is specified, this field does not appear.
Outbound CAR ID
ID of the CAR action applied in the outbound direction. If no CAR action is specified, this field does not appear.
Fast Switch Group Index
BGP RD
BGP router distinguisher.
SiteID/Range/Offset
Site ID/site range/CE offset of a site in the VPLS instance.
Import vpn target
Incoming routing information from the destination VPN extended community.
Export vpn target
Outgoing routing information to the destination VPN extended community.
Interface Name
Name of the Layer 2 Ethernet interface where the service instance associated with the VPLS instance resides.
Status of the Layer 2 Ethernet interface where the service instance associated with the VPLS instance resides.
Service instance ID
ID of the service instance associated with the VPLS instance.
PW Type
PW type:
Remote VCCV CC Type
Remote VCCV CV Type
display vsi remote
display vsi remote { bgp | ldp } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
bgp: Displays information about remote VPLS connections using the signaling protocol of BGP.
ldp: Displays information about remote VPLS connections using the signaling protocol of LDP.
Use display vsi remote to display information about remote VPLS connections using a specific signaling protocol.
# Display information about remote VPLS connections using LDP.
<Sysname> display vsi remote ldp
Vsi        Peer            VC       Group   Vsi                MTU     Vsi
ID         RouterID        Label    ID      Type               Value   Index
500        60.1.1.1        524688   0       vlan               1500    0
Table 17 Command output
Vsi ID
Peer Router ID
ID of the peer.
VC Label
Label of the VC.
Group ID
ID of the group.
Vsi Type
MTU Value
Vsi Index
dual-npe revertive
dual-npe revertive [ wtr-time wtr-time ]
undo dual-npe revertive [ wtr-time ]
View
VSI LDP view
Default level
2: System level
wtr-time wtr-time: Specifies the switchback delay time, or the wait-to-restore time. After the primary PW comes back, the system waits for a period of time dictated by the switchback delay time before switching data from the secondary PW back to the primary PW. The wtr-time argument is in the range of 1 to 720, in minutes. The default is 30 minutes.
Use dual-npe revertive to enable the switchback function and set the switchback delay time.
Use undo dual-npe revertive wtr-time to restore the default switchback delay time.
Use undo dual-npe revertive to disable the switchback function.
By default, the switchback function is disabled.
# Create a VPLS instance named vpna that uses the peer discovery mechanism of manual configuration and set the switchback delay time to 1 minute.
[Sysname] vsi vpna static
[Sysname-vsi-vpna] pwsignal ldp
[Sysname-vsi-vpna-ldp] dual-npe revertive wtr-time 1
encapsulation (service instance view)
encapsulation { s-vid vlan-id [ only-tagged ] | port-based | tagged | untagged }
undo encapsulation
View
Default level
2: System level
s-vid vlan-id: Specifies the outer VLAN ID. VLAN ID is in the range of 1 to 4094.
only-tagged: Matches only tagged packets. If the specified VLAN ID is the default VLAN of the port and the only-tagged keyword is not specified, the service instance matches untagged packets as well as packets carrying the current port's default VLAN ID.
port-based: Matches packets by port.
untagged: Matches untagged packets.
Use encapsulation to configure a packet matching rule for the current service instance.
Use undo encapsulation to remove the packet matching rule of the current service instance.
By default, no packet matching rule is configured for a service instance.
If you configure this command for a service instance for multiple times, only the last configuration will take effect.
On a port, if you have configured a rule to match packets carrying the port's PVID tag in a service instance without specifying the only-tagged keyword, and to match untagged packets in another service instance, untagged packets will be matched in the service instance where this command was configured first. H3C recommends that you also specify the only-tagged keyword to match packets carrying specific VLAN tags. Otherwise, untagged packets might be matched to a different service instance than the one you expected.
Specify different VLAN IDs for different service instances on the same Layer 2 Ethernet interface.
# Configure service instance 100 to match VLAN 100.
[Sysname] interface GigabitEthernet 3/0/3
[Sysname-GigabitEthernet3/0/3] service-instance 100
[Sysname-GigabitEthernet3/0/3-srv100] encapsulation s-vid 100
encapsulation (VSI view)
encapsulation { bgp-vpls | ethernet | vlan }
View
VSI view
Default level
2: System level
bgp-vpls: Specifies the PW encapsulation type of the current BGP VPLS instance as the standard encapsulation type defined in RFC 4761, which corresponds to the PW encapsulation type of Ethernet.
ethernet: Specify the PW encapsulation type of the current VPLS instance as Ethernet.
vlan: Specifies the PW encapsulation type of the current VPLS instance as VLAN.
Use encapsulation to specify the PW encapsulation type for a VPLS instance.
By default, the PW encapsulation type of a VPLS instance is VLAN.
# Set the VPLS instance encapsulation type to Ethernet.
[Sysname] vsi aaa
[Sysname-vsi-aaa] encapsulation ethernet
l2 binding vsi
l2 binding vsi vsi-name [ access-mode { ethernet | vlan } | { hub | spoke } ] *
undo l2 binding vsi vsi-name
View
Interface view
Default level
2: System level
access-mode: Specifies the access mode of the VPLS instance, which can be ethernet or vlan. When the interface bound with the VPLS instance is a routing interface, the default access mode is Ethernet. When interface bound with the VPLS instance is a routing subinterface, the default access mode is VLAN.
ethernet: Specifies the access mode of Ethernet.
vlan: Specifies the access mode of VLAN.
hub: Specifies that the attached CE is the hub-CE.
spoke: Specifies that the attached CE is a spoke-CE. This is the default when the hub-spoke feature is enabled for the instance.
Use l2 binding vsi to bind a VPLS instance on an interface.
Use undo l2 binding vsi to remove the binding.
When the hub-spoke feature is enabled for a VPLS instance (the hub-spoke keyword included in the vsi static command), you can also specify whether the attached CE is a spoke site or the hub site.
IMPORTANT:
·     With the l2 binding vsi command configured on an interface, services bound to the interface are considered the internal VPN services of the VPLS instance.
·     After a Layer 3 interface is bound with a VPLS instance, its Layer 3 subinterfaces cannot be bound with an L2VPN or VPLS instance. After a Layer 3 subinterface is bound with a VPLS instance, the corresponding Layer 3 interface cannot be bound with an L2VPN or VPLS instance.
Related commands: peer and vsi.
# Bind VPLS instance aaa on GigabitEthernet 3/0/1.
[Sysname-GigabitEthernet3/0/1] port link-mode route
[Sysname-GigabitEthernet3/0/1] l2 binding vsi aaa
mac-learning
mac-learning { enable | disable }
View
VSI view
Default level
2: System level
enable: Enables MAC address learning for the VPLS instance.
disable: Disables MAC address learning for the VPLS instance.
Use mac-learning to enable or disable MAC address learning for a VPLS instance.
With MAC address learning disabled for a VPLS instance, the system does not learn source MAC addresses from the packets received from the VPLS instance.
By default, MAC address learning is enabled.
# Enables MAC address learning for VPLS instance aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mac-learning enable
mac-table limit
mac-table limit mac-limit-number
undo mac-table limit
View
VSI view
Default level
2: System level
mac-limit-number: Maximum number of MAC addresses that the switch can learn for the VPLS instance. The value range depends on the system working mode. For more information, see Fundamentals Configuration Guide.
Use mac-table limit to specify the maximum number of MAC addresses that the switch can learn for the VPLS instance.
Use undo mac-table limit to restore the default.
By default, the maximum number depends on the system working mode. For more information, see Fundamentals Configuration Guide.
Once the number of MAC addresses learned for a VPLS instance reaches this limit, the switch does not learn source MAC addresses any more but broadcasts the received packet in the VPLS instance.
# Set the maximum number of MAC addresses that the switch can learn for VPLS instance aaa to 1024.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mac-table limit 1024
mac-withdraw null-ip-address-tlv
undo mac-withdraw null-ip-address-tlv
View
PW class view
Default level
2: System level
None
Use mac-withdraw null-ip-address-tlv to configure the signaling protocol to carry an empty IP address list TLV in MAC address withdraw messages.
Use undo mac-withdraw null-ip-address-tlv to configure the signaling protocol to not carry an empty IP address list TLV in MAC address withdraw messages.
By default, a MAC address withdraw message carries an empty IP address list TLV.
Use the mac-withdraw null-ip-address-tlv command or its undo form on your device to make sure the two end devices of a PW have the same implementation on whether a MAC address withdraw message will carry an empty IP address list TLV. Otherwise, when a primary/backup PW switchover occurs, the local device cannot receive the MAC address withdraw message from the peer device.
For more information about the Address List TLV, see "Address Withdraw Message" in RFC 5036.
# Configure the signaling protocol to not carry an empty IP address list TLV in MAC address withdraw messages.
[Sysname] pw-class pw100
[Sysname-pw-pw100] undo mac-withdraw null-ip-address-tlv
mtu (VSI view)
mtu mtu
undo mtu
View
VSI view
Default level
2: System level
mtu: Maximum transmission unit (MTU) for the VPLS instance, in the range of 328 to 8192. The default is 1500.
Use mtu to set the MTU of a VPLS instance.
The MTU of a VPLS instance is a global attribute and is also the MTU of the PW. In Martini VPLS, the MTUs of VPLS instances of peer PEs must be identical. In Kompella VPLS, the MTUs of VPLS instances of peer PEs can be different.
# Set the MTU of VPLS instance aaa to 1400.
[Sysname] vsi aaa
[Sysname-vsi-aaa] mtu 1400
peer (VSI LDP view)
peer ip-address [ { hub | spoke } | pw-class class-name | [ pw-id pw-id ] [ upe | backup-peer ip-address [ backup-pw-id pw-id ] ] ] *
undo peer ip-address
View
VSI LDP view
Default level
2: System level
ip-address: IP address of the remote VPLS peer PE.
hub: Specifies the peer PE as the hub.
spoke: Specifies the peer PE as a spoke. This is the default when the hub-spoke feature is enabled for the instance.
pw-class class-name: References a PW class. class-name represents the template name, a case-insensitive string of 1 to 19 characters.
pw-id pw-id: ID of the PW to the VPLS peer PE, in the range of 1 to 4294967295. The default is VSI ID.
upe: Specifies that the peer PE is a UPE in the H-VPLS model.
backup-peer ip-address: Specifies the IP address of the backup NPE. If you specify this parameter, you create a primary NPE and a backup NPE on the UPE.
backup-pw-id pw-id: Specifies the ID of the PW to the backup NPE. The pw-id argument is in the range of 1 to 4294967295, and the default is the VSI ID.
Use peer to create a peer PE for a VPLS instance.
Use undo peer to remove a peer PE.
With the hub-spoke feature for a VPLS instance, you can specify the connection mode of the peer PE as hub or spoke.
Related commands: vsi and vsi-id.
# Create a peer PE, which is of the UPE type, with the IP address of 4.4.4.4 and the PW ID of 200.
[Sysname] vsi aaa
[Sysname-vsi-aaa] pwsignal ldp
[Sysname-vsi-aaa-ldp] peer 4.4.4.4 pw-id 200 upe
# Create a primary peer PE 1.1.1.1 and a backup peer PE 2.2.2.2, and set the PW ID to the primary peer to 300 and that to the backup peer to 400.
[Sysname] vsi aaa
[Sysname-vsi-aaa-ldp] peer 1.1.1.1 pw-id 300 backup-peer 2.2.2.2 backup-pw-id 400
ping lsp pw (for VPLS)
ping lsp [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -s packet-size | -t time-out | -v ] * pw ip-address pw-id pw-id
View
Default level
0: Visit level
-a source-ip: Specifies the source IP address of the Echo Request messages to be sent.
-c count: Specifies the number of request messages to be sent. The count argument is in the range of 1 to 4294967295 and defaults to 5.
-exp exp-value: Specifies the EXP value for the Echo Request messages. The exp-value argument is in the range of 0 to 7 and defaults to 0.
-h ttl-value: Specifies the TTL value for the Echo Request messages. The ttl-value argument is in the range of 1 to 255 and defaults to 255.
-m wait-time: Specifies the interval for sending Echo Request messages. The wait-time argument is in the range of 1 to 10000 and defaults to 200, in milliseconds.
-r reply-mode: Specifies the reply mode of the receiver in response to an Echo Request message. The reply-mode argument can be 1 or 2, where 1 means "Do not respond" and 2 means "Respond using a UDP packet". The default is 2.
-s packet-size: Specifies the payload length of the Echo Request message. The packet-size argument is in the range of 65 to 8100 and defaults to 100, in bytes.
-t time-out: Specifies the timeout interval for waiting for the response to an echo request message. The time-out argument is in the range of 0 to 65535 and defaults to 2000, in milliseconds.
-v: Displays detailed response information.
pw ip-address: Specifies the IP address of the peer PE.
pw-id pw-id: Specifies the ID of the PW to the peer PE. The pw-id argument is in the range of 1 to 4294967295.
Use ping lsp pw to check the connectivity of a Martini PW.
# Check the connectivity of the PW to peer PE 3.3.3.9 that uses the PW ID of 301.
<Sysname> ping lsp pw 3.3.3.9 pw-id 301
LSP Ping FEC: FEC 128 PSEUDOWIRE (NEW) 3.3.3.9 301 : 100  data bytes, press CTRL_C to break
    Reply from 100.1.2.1: bytes=100 Sequence=0 time = 31 ms
    Reply from 100.1.2.1: bytes=100 Sequence=1 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=2 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=3 time = 62 ms
    Reply from 100.1.2.1: bytes=100 Sequence=4 time = 62 ms
  --- FEC: FEC 128 PSEUDOWIRE (NEW) 3.3.3.9 301 ping statistics ---
    5 packet(s) transmitted
    5 packet(s) received
    0.00% packet loss
    round-trip min/avg/max = 31/55/62 ms
pw-class
pw-class pw-class-name
undo pw-class pw-class-name
View
Default level
2: System level
pw-class-name: Name of the PW class, a case-insensitive string of 1 to 19 characters.
Use pw-class to create a PW class and enter PW class view.
Use undo pw-class to delete an existing PW class.
By default, no PW class is created.
# Create PW class pw100 and enter its view.
[Sysname-pw-pw100]
pwsignal
pwsignal { bgp | ldp }
View
VSI view
Default level
2: System level
bgp: Specifies to use BGP signaling (Kompella mode).
ldp: Specifies to use LDP signaling (Martini mode).
Use pwsignal to specify the PW signaling protocol for VPLS to use, and enter VSI LDP view (Martini mode) or VSI BGP view (Kompella mode).
# Specify that VPLS instance aaa uses the connection mode of Martini and enter VSI LDP view.
[Sysname] vsi aaa
pw-tunnel-policy
pw-tunnel-policy policy-name
undo pw-tunnel-policy
View
PW class view
Default level
2: System level
policy-name: Name of the tunneling policy, a case-insensitive string of 1 to 19 characters.
Use pw-tunnel-policy to specify the tunneling policy for the PW class.
Use undo pw-tunnel-policy to restore the default.
By default, the tunneling policy specified by the tnl-policy command in VSI view is used.
If you specify a non-existent tunneling policy in the pw-tunnel-policy command, the tunneling policy specified by the tnl-policy command in VSI view will be used. For information about configuring a tunneling policy, see MPLS Configuration Guide.
Related commands: tnl-policy and tunnel-policy.
# Specify tunneling policy tp100 for PW class pw100.
[Sysname-pw-pw100] pw-tunnel-policy tp100
reset bgp vpls
reset bgp vpls { as-number | ip-address | all | external | internal }
View
Default level
2: System level
as-number: Resets VPLS BGP connections to peers in a specific AS. as-number is in the range of 1 to 4294967295.
ip-address: Resets the VPLS BGP connection to a specific peer.
all: Resets all VPLS BGP connections.
external: Resets VPLS EBGP session.
internal: Resets VPLS IBGP session.
Use reset bgp vpls to reset a specific VPLS BGP connection or all VPLS BGP connections.
# Reset all VPLS BGP connections.
<Sysname> reset bgp vpls all
reset mac-address vsi
reset mac-address vsi [ vsi-name ]
View
Default level
1: Monitor level
vsi-name: Name of a VPLS instance, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed.
Use reset mac-address vsi to clear the MAC address table of a specific VPLS instance or all VPLS instances.
# Clear the MAC address table of VPLS instance aaa.
<Sysname>reset mac-address vsi aaa
reset service-instance statistics
reset service-instance statistics [ interface interface-type interface-number [ service-instance instance-id [ inbound | outbound ] ] ]
View
Default level
1: Monitor level
interface interface-type interface-number: Clears the traffic statistics for the specified service instance or all service instances on the specified interface. The interface-type interface-number arguments specify an interface by its type and number.
service-instance instance-id: Clears the traffic statistics for the specified service instance on the interface. The instance-id argument represents the ID of a service instance, in the range of 1 to 4094.
inbound: Clears inbound traffic statistics.
outbound: Clears outbound traffic statistics.
Use reset service-instance statistics to clear the traffic statistics for one or all service instances on an interface.
# Clear the traffic statistics of service instance 200 on the interface GigabitEthernet 3/0/1.
<Sysname> reset service-instance statistics interface GigabitEthernet 3/0/1 service-instance 200
route-distinguisher (VSI BGP view)
View
VSI BGP view
Default level
2: System level
route-distinguisher: Route distinguisher (RD), a string of 3 to 21 characters in the format of nn:nn or IP_address:nn.
An RD can be one of these formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number, where the AS number must be equal to or greater than 65536. For example, 65536:1.
Use route-distinguisher to configure an RD for a VPLS instance.
Different VPLS instances on a PE must have different RDs, but a VPLS instance can have the same RD or different RDs on different PEs.
·     RD has no default value. You must configure an RD for a VPLS instance to make the instance take effect.
·     To change the RD of a VPLS instance, you must remove the VPLS instance and then reconfigure the VPLS instance and RD.
# Set the RD to 111:1.
[Sysname] vsi aaa
[Sysname-vsi-aaa] pwsignal bgp
[Sysname-vsi-aaa-bgp] route-distinguisher 111:1
service-instance
undo service-instance service-instance-id
View
Layer 2 Ethernet interface view, aggregate interface view
Default level
2: System level
service-instance-id: Service instance ID for uniquely identifying a service instance on a Layer 2 Ethernet interface. It is in the range of 1 to 4094.
Use service-instance to create a service instance and enter service instance view.
Use undo service-instance to delete an existing service instance.
By default, no service instance is created.
The service instances created on different Layer 2 Ethernet interfaces can have the same service instance ID.
# On Layer 2 interface GigabitEthernet 3/0/3, create service instance 100 and enter its view.
shutdown (VSI view)
shutdown
View
VSI view
Default level
2: System level
None
Use shutdown to shut down the VPLS service of a VPLS instance.
Use undo shutdown to restart the VPLS service of a VPLS instance.
By default, the VPLS service of a VPLS instance is started.
When a VPLS instance is disabled, the system does not handle any service of the VPLS instance.
# Shut down the VPLS service of VPLS instance aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa] shutdown
site
site site-id [ range site-range ] [ default-offset { 0 | 1 } ]
undo site site-id
View
VSI BGP view
Default level
2: System level
site-id: ID of a site of the VPLS instance.
range site-range: Specifies the site range on a PE. The site-range argument is the total number of sites of a VPLS instance. The default is 10.
default-offset { 0 | 1 }: Default initial CE offset. It can be 0 or 1 and defaults to 0.
Use site to create sites for a VPLS instance.
Use undo site to remove sites of a VPLS instance.
Sites of a VPLS instance use natural numbers as the site IDs. In a VPN, each site ID must be unique.
For a VPLS instance, you are not allowed to execute the site command repeatedly.
# Create sites for VPLS instance aaa and set the site range to 20.
[Sysname] vsi aaa
[Sysname-vsi-aaa-bgp] site 1 range 20
tnl-policy
tnl-policy tunnel-policy-name
undo tnl-policy
View
VSI view
Default level
2: System level
tunnel-policy-name: Name of the tunneling policy for the VPLS instance, a string of 1 to 19 characters without any blank space.
Use tnl-policy to specify a tunneling policy for a VPLS instance.
Use undo tnl-policy to remove the configuration.
By default, no tunneling policy is specified for a VPLS instance and the default tunneling policy is used. The default tunneling policy selects only one tunnel (no load balancing) in this order: LSP tunnel, CR-LSP tunnel.
If you specify a tunneling policy name but the tunneling policy is not configured, the default tunneling policy is used. For information about configuring a tunneling policy, see MPLS Configuration Guide.
Related commands: tunnel-policy.
# Specify that VPLS instance aaa uses the tunneling policy of policy1.
[Sysname] vsi aaa
[Sysname-vsi-aaa] tnl-policy policy1
trans-mode
trans-mode { ethernet | vlan }
undo trans-mode
View
PW class view
Default level
2: System Level
ethernet: Specifies the PW transport mode as Ethernet mode.
vlan: Specifies the PW transport mode as VLAN mode.
Use trans-mode to specify the PW transport mode.
Use undo trans-mode to restore the default.
By default, the PW transport mode is VLAN.
In Ethernet mode, P-Tag is not transferred on the PW. For a packet from a CE, if it contains the service delimiter, the PE removes the service delimiter and adds a PW label and a tunnel label into the packet before forwarding the packet. Otherwise, the PE adds a PW label and a tunnel label into the packet and then forwards the packet. For a packet to be sent downstream, whether the PE adds the service delimiter into the packet depends on your configuration. However, rewriting and removing of existing tags are not allowed.
In VLAN mode, packets transmitted over the PW must carry a P-Tag. For a packet from a CE, if it contains the service delimiter, the PE keeps the P-Tag unchanged or changes the P-tag to the VLAN tag expected by the peer PE or to a null tag (the tag value is 0), and then adds a PW label and a tunnel label into the packet before sending the packet out. If the packet contains no service delimiter, the PE adds the VLAN tag expected by the peer PE or a null tag, and then a PW label and a tunnel label into the packet before sending the packet out. For a packet to be sent downstream, the PE rewrites, removes, or retains the service delimiter depending on your configuration.
# Configure the PW transport mode as Ethernet.
[Sysname-pw-pw100] trans-mode ethernet
vpls-family
vpls-family
View
BGP view
Default level
2: System level
None
Use vpls-family to enter VPLS address family view.
# Enter VPLS address family view.
[Sysname] bgp 100
[Sysname-bgp] vpls-family
[Sysname-bgp-af-vpls]
vpn-target (VSI BGP view)
vpn-target vpn-target &<1-16> [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { all | vpn-target &<1-16> } [ both | export-extcommunity | import-extcommunity ]
View
VSI BGP view
Default level
2: System level
vpn-target&<1-16>: Adds VPN target extended community attributes to the import VPN target extended community attribute list (Import Target) or export VPN target extended community attribute list (Export Target). &<1-16> means that you can add up to 16 VPN targets..
A VPN target attribute can be a string of 3 to 21 characters in one the following formats:
·     16-bit AS number:32-bit user-defined number, such as 101:3.
·     32-bit IP address:16-bit user-defined number, such as 192.168.122.15:1.
both: Uses the specified VPN targets as both import targets and export targets. The both keyword is also used when you do not specify any of both, export-extcommunity, and import-extcommunity.
export-extcommunity: Uses the specified VPN targets as export targets.
import-extcommunity: Uses the specified VPN targets as import targets.
all: Removes all VPN targets.
Use vpn-target to configure one or more VPN targets for a VPLS instance.
Use undo vpn-target to remove the specified or all VPN targets of a VPLS instance.
By default, no VPN targets are configured and you must configure VPN targets when creating a VPLS instance.
# Configure VPN targets for the VPLS instance aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa-bgp] vpn-target 100:1
[Sysname-vsi-aaa-bgp] vpn-target 1:1 2:2 export-extcommunity
[Sysname-vsi-aaa-bgp] vpn-target 1.2.3.4:11 12:12 import-extcommunity
vsi
vsi vsi-name [ { auto | static [ hub-spoke | p2p ] } | minm i-sid i-sid [ pxp ] ] *
undo vsi vsi-name
View
Default level
2: System level
vsi-name: Name of the VSI instance, a case-insensitive string of 1 to 31 characters. Hyphens (-) are not allowed.
auto: Configures the peer discovery mechanism as dynamic. This corresponds to BGP mode.
static: Configures the peer discovery mechanism as static. This corresponds to LDP mode.
hub-spoke: Enables the hub-spoke capability for the VSI whose peer discovery mechanism is static.
p2p: Enables the P2P (PW to PW) capability for the VSI whose peer discovery mechanism is static. The P2P feature is used to associate two PWs to set up a multi-hop PW.
minm: Enables the MAC-in-MAC function for the VSI.
i-sid i-sid: Specifies an I-SID for the VSI enabled with MAC-in-MAC. The value range for the i-sid argument is 1 to 16777215.
pxp: Learns only the backbone source MAC address of the packet that arrives first. You cannot specify this keyword when you create a VSI that supports VPLS and MAC-in-MAC dual-stack.
Use vsi to create a VSI and enter VSI view. If the specified VSI already exits, you enter the VSI view directly.
Use undo vsi to remove a VSI.
VSI instances include two categories:
·     VPLS instance—A VSI created by using the vsi command with the auto or static keyword. A VPLS instance discovers a peer PE automatically or statically, and establishes a VPLS PW to the peer PE.
·     MAC-in-MAC instance—A VSI created by using the vsi command with the minm keyword. Such a VSI supports the MAC-in-MAC function.
If you specify the pxp keyword, when a BEB receives a broadcast or an unknown unicast from the customer side, the BEB encapsulates the frame with the broadcast MAC address, and it broadcasts the frame in the backbone.
If you do not specify the pxp keyword, when a BEB receives a broadcast or an unknown unicast from the customer side, the BEB encapsulates the frame with the learned backbone source MAC address being the backbone destination MAC address, and it unicasts the frame.
To enter the view of an existing VSI, use the vsi vsi-name command without specifying any other parameters.
To create a VSI, you must specify a globally unique name for it, and specify the peer discovery mechanism (by specifying the auto or static keyword) or enable MAC-in-MAC (by specifying the minm keyword). If you specify the peer discovery mechanism as static, you can also enable hub-spoke or P2P for the VPLS instance as needed.
When creating a VSI, you can specify the peer discovery mechanism and then enable MAC-in-MAC for the VSI. Such a VSI then supports VPLS and MAC-in-MAC dual-stack.
Before creating a VSI that supports VPLS and MAC-in-MAC dual-stack, you need to enable L2VPN and MPLS L2VPN through the l2vpn command and the mpls l2vpn command. Before creating a VSI that supports only MAC-in-MAC, you just need to enable L2VPN through the l2vpn command.
Related commands: display vsi, mpls l2vpn, and l2vpn.
# Create VPLS instance aaa, and specify the peer discovery mechanism as static.
[Sysname] vsi aaa static
[Sysname-vsi-aaa]
# Create VPLS instance bbb, specify the peer discovery mechanism as static, and enable P2P capability for the VPLS instance.
[Sysname] vsi bbb static p2p
[Sysname-vsi-bbb]
# Create a VSI that supports VPLS and MAC-in-MAC dual-stack, specifying its name as dualstack, peer discovery mechanism as static, and I-SID as 500.
[Sysname] vsi dualstack static minm i-sid 500
[Sysname-vsi-dualstack]
vsi-id
vsi-id vsi-id
View
VSI LDP view
Default level
2: System level
vsi-id: ID for the VPLS instance, in the range of 1 to 4294967295.
Use vsi-id to specify the ID of a VPLS instance.
On PEs in the same VPN, be sure to specify the same VSI ID for the VPLS instances that correspond to the VPN.
# Set the VSI ID of VPLS instance aaa to 100.
[Sysname] vsi aaa
[Sysname-vsi-aaa-ldp] vsi-id 100
xconnect vsi
xconnect vsi vsi-name [ access-mode { ethernet | vlan } | { hub | spoke } ] *
undo xconnect vsi
View
Default level
2: System level
access-mode: Specifies the access mode of the service instance as Ethernet or VLAN. The default access mode is VLAN.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
hub: Specifies the access mode of the VPLS instance as hub.
spoke: Specifies the access mode of the VPLS instance as spoke, which is also the default when the VPLS instance is enabled with the hub-spoke capability.
Use xconnect vsi to associate a VPLS instance with the service instance on a specific interface.
Use undo xconnect vsi to remove the association.
By default, a service instance is not associated with any VPLS instance.
The access mode of a service instance can be VLAN or Ethernet:
·     VLAN access—The Ethernet header of a packet sent from a CE to a PE or from a PE to a CE includes a VLAN tag that is added in the header as a service delimiter for the service provider network to identify the user. The tag is called a P-Tag.
·     Ethernet access—The Ethernet header of a packet sent from a CE to a PE or from a PE to a CE does not contain any service delimiter. If the header contains a VLAN tag, it is the internal VLAN tag of the user and means nothing to the PE. Such an internal VLAN tag of a user is called a U-Tag.
You further specify the access mode as hub or spoke only when the VPLS instance is enabled with the hub-spoke capability. The default access mode spoke.
For VPLS, signaling advertisement uses the MTU of the VPLS instance.
The xconnect vsi command is available for service instances with the ID in the range of 1 to 4094.
Related commands: service-instance.
# Associate service instance 200 of GigabitEthernet 3/0/3 with VPLS instance vsi200 and specify the matching external VLAN tag as 200.
[Sysname-GigabitEthernet3/0/3] service-instance 200
[Sysname-GigabitEthernet3/0/3-srv200] encapsulation s-vid 200
[Sysname-GigabitEthernet3/0/3-srv200] xconnect vsi vsi200 hub
