02-MPLS TE Commands | 421.97 KB |
MPLS TE configuration commands
display isis traffic-eng advertisements
display isis traffic-eng network·
display isis traffic-eng statistics
display isis traffic-eng sub-tlvs
display mpls rsvp-te established
display mpls rsvp-te psb-content
display mpls rsvp-te reservation
display mpls rsvp-te rsb-content
display mpls rsvp-te statistics
display mpls te link-administration admission-control
display mpls te link-administration bandwidth-allocation
display mpls te protection tunnel
display mpls te tunnel statistics
display mpls te tunnel-interface
display ospf traffic-adjustment
enable traffic-adjustment advertise
mpls rsvp-te blockade-multiplier
mpls rsvp-te timer graceful-restart recovery
mpls rsvp-te timer graceful-restart restart
mpls rsvp-te timer retransmission
mpls te bandwidth change thresholds
mpls te cspf timer failed-link
mpls te failure-action teardown
mpls te fast-reroute bypass-tunnel
mpls te link administrative group·
mpls te reoptimization (tunnel interface view)
mpls te reoptimization (user view)
mpls te timer link-management periodic-flooding
add hop
add hop ip-address1 [ include [ loose | strict ] | exclude ] { after | before } ip-address2
View
Explicit path view
Default level
2: System level
ip-address1: IP address or Router ID of the node to be inserted, in dotted decimal notation.
include: Includes the specified IP address ip-address1 in the explicit path.
loose: Specifies the inserted node as a loose node, which means that the inserted node and its previous hop can be connected indirectly.
strict: Specifies the inserted node as a strict node, which means that the inserted node and its previous hop must be connected directly.
exclude: Excludes the node identified by the ip-address1 argument from the explicit path. Excluded addresses are not considered in path calculation.
after: Inserts the node ip-address1 after the reference node ip-address2.
before: Inserts the node ip-address1 before the reference node ip-address2.
ip-address2: IP address of the reference node, in dotted decimal notation.
Use add hop to insert a node to the explicit path, and configure the node’s attributes (include or exclude, strict or loose).
· If you specify neither include nor exclude, the include keyword is used by default.
· If you specify neither loose nor strict, the strict keyword is used by default.
# Specify the switch to not consider 3.3.29.3 as the next hop of 3.3.10.5 during path calculation for the explicit path path1.
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] add hop 3.3.29.3 exclude after 3.3.10.5
delete hop
delete hop ip-address
View
Explicit path view
Default level
2: System level
ip-address: IP address of a node along the explicit path.
Use delete hop to remove a specific node from the explicit path.
# Remove the node identified by 10.0.0.1 from the explicit path path1.
[Sysname-explicit-path-path1] delete hop 10.0.0.1
display explicit-path
display explicit-path [ path-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
path-name: Specifies a path name, a string of 1 to 31 characters.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display explicit-path to display information about an explicit path.
If no path name is specified, this command displays information about all explicit paths.
# Display information about all explicit paths.
<Sysname> display explicit-path
Path Name : ErHop-Path1 Path Status : Enabled
1 1.1.1.10 Strict Include
2 2.1.1.10 Strict Include
3 1.1.1.20 Strict Include
4 2.1.1.20 Strict Include
5 2.1.1.30 Strict Include
6 1.1.1.30 Strict Include
7 9.4.4.4 Strict Include
Path Name : ErHop-Path2 Path Status : Enabled
3 1.1.1.40 Strict Include
4 2.1.1.40 Strict Include
5 1.1.1.50 Strict Include
6 2.1.1.40 Strict Include
7 2.1.1.30 Strict Include
8 1.1.1.30 Strict Include
9 9.4.4.4 Strict Include
Path Name |
Explicit path name. |
Path Status |
Explicit path status. |
display isis traffic-eng advertisements [ [ level-1 | level-1-2 | level-2 ] | [ lsp-id lsp-id | local ] ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
level-1: Displays the TE information for IS-IS Level-1 routers.
level-1-2: Displays the TE information for IS-IS Level-1-2 routers.
level-2: Displays the TE information for IS-IS Level-2 routers.
lsp-id lsp-id: Displays the IS-IS TE information advertised by the specified link state packet (LSP). For more information about IS-IS LSP, see Layer 3—IP Routing Configuration Guide.
local: Displays local TE information.
process-id: Specifies an IS-IS process ID in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the IS-IS TE information for the specified VPN. The vpn-instance-name argument specifies an MPLS L3VPN by its instance name, a case-sensitive string of 1 to 31 characters. To display the IS-IS TE information for the public network, do not specify this option.
Use display isis traffic-eng advertisements to display the latest TE information advertised by IS-IS.
If no IS-IS level is specified, this command displays the TE information for IS-IS Level-1-2 routers.
# Display the latest TE information advertised by IS-IS.
<Sysname> display isis traffic-eng advertisements
TE information for ISIS(1)
Level-1 Link State Database
LSPID LSP Seq Num LSP Checksum LSP Holdtime ATT/P/OL
0000.0000.0001.00-00* 0x00000001 0x3f57 534 0/0/0
NLPID : IPV4
AREA ADDR : 00.0005
INTF ADDR : 10.1.1.1
INTF ADDR : 1.1.1.9
INTF ADDR : 30.1.1.1
Level-2 Link State Database
0000.0000.0001.00-00* 0x0000001c 0xf1ec 687 0/0/0
NLPID : IPV4
AREA ADDR : 00.0005
INTF ADDR : 1.1.1.9
Router ID : 1.1.1.9
+NBR : 0000.0000.0002.02 COST: 10
Admin Group: 0x00000000
Interface IP Address: 10.1.1.1
Physical BW : 0 Bytes/sec
Reservable BW: 0 Bytes/sec
Unreserved BW for Class Type 0:
BW Unresrv[0]: 0 Bytes/sec BW Unresrv[1]: 0 Bytes/sec
BW Unresrv[2]: 0 Bytes/sec BW Unresrv[3]: 0 Bytes/sec
BW Unresrv[4]: 0 Bytes/sec BW Unresrv[5]: 0 Bytes/sec
BW Unresrv[6]: 0 Bytes/sec BW Unresrv[7]: 0 Bytes/sec
Unreserved BW for Class Type 1:
TE Cost : 10
Bandwidth Constraint Model: Russian Doll
Bandwidth Constraints:
BC[0] : 0 Bytes/sec BC[1] : 0 Bytes/sec
+NBR : 0000.0000.0004.00 COST: 10
Interface IP Address: 30.1.1.1
Peer IP Address : 30.1.1.2
TE Cost : 10
LSPID |
LSP ID. |
LSP Seq Num |
LSP sequence number. |
ATT/P/OL |
· ATT—Attach bit. · P—Partition bit. · OL—Overload bit. |
NLPID |
Network protocol type. |
AREA ADDR |
IS-IS area address. |
INTF ADDR |
Interface address. |
+NBR |
Neighbor. |
Admin Group |
Link administrative group attribute. |
Physical BW |
Physical bandwidth. |
Reservable BW |
Reservable bandwidth. |
BW Unresrv[0]-[7] |
Available subpool bandwidths at eight levels. |
BC[0] |
Global pool. |
BC[1] |
Subpool. |
LOM[0] LOM[1] |
Local overbooking multiplier. The bracketed number indicates the level of bandwidth. |
display isis traffic-eng link
display isis traffic-eng link [ [ level-1 | level-1-2 | level-2 ] | verbose ] * [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
verbose: Displays details.
process-id: IS-IS process ID in the range of 1 to 65535.
vpn-instance vpn-instance-name: Displays the IS-IS TE link information for the specified VPN.. The vpn-instance-name argument specifies an MPLS L3VPN by its instance name, a case-sensitive string of 1 to 31 characters. To display the IS-IS TE link information for the public network, do not specify this option.
Use display isis traffic-eng link to display IS-IS TE link information.
If no IS-IS level is specified, this command displays TE link information for IS-IS Level-1-2 routers.
# Display IS-IS TE link information.
<Sysname> display isis traffic-eng link
Level-2 Link Information
0000.0000.0001.00-->0000.0000.0001.01 Type: MULACC LinkID: 10.1.1.1
0000.0000.0002.00-->0000.0000.0003.00 Type: P2P LinkID: 3.3.3.9
0000.0000.0002.00-->0000.0000.0001.01 Type: MULACC LinkID: 10.1.1.1
0000.0000.0003.00-->0000.0000.0002.00 Type: P2P LinkID: 2.2.2.9
0000.0000.0003.00-->0000.0000.0004.01 Type: MULACC LinkID: 30.1.1.2
0000.0000.0004.00-->0000.0000.0004.01 Type: MULACC LinkID: 30.1.1.2
Total Number of TE Links in Level-2 Area: 6, Num Active: 6
Type |
Type of the link. |
LinkID |
ID of the link. |
Total Number of TE Links in Level-2 Area |
Total number of TE links in the Level-2 area. |
Num Active |
Number of active TE links. |
display isis traffic-eng network [ level-1 | level-1-2 | level-2 ] [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Displays the IS-IS TE network information for the specified VPN. The vpn-instance-name argument specifies an MPLS L3VPN by its instance name, a case-sensitive string of 1 to 31 characters. To display the IS-IS TE network information for the public network, do not specify this option.
Use display isis traffic-eng network to display the IS-IS TE network information.
If no IS-IS level is specified, this command displays information about TE networks in the IS-IS Level-1-2 area.
# Display information about IS-IS TE networks.
<Sysname> display isis traffic-eng network
Level-1 Network Information
DIS Router ID : 89.1.1.1 DIS's Ip Address : 86.1.1.1
Status In CSPF : ACTIVE Attached Router Count : 2
List of Attached Routers
RouterId : 89.1.1.1 Nbr : 1111.1111.1111.00
Link State : 1
RouterId : 89.2.2.2 Nbr : 1111.1111.1113.00
Link State : 1
Total Number of TE Networks in Level-1 Area: 1, Num Active: 1
Level-2 Network Information
Link State : 1
Link State : 1
Total Number of TE Networks in Level-2 Area: 1, Num Active: 1
DIS's Ip Address |
IP address of the DR router. |
Status In CSPF |
CSPF state. |
Attached Router Count |
Number of attached routers. |
List of Attached Routers |
List of attached routers. |
RouterId |
Router ID. |
Nbr |
Neighbors. |
Level-2 Network Information |
Level-2 network information. |
display isis traffic-eng statistics [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Displays the IS-IS TE statistics for the specified VPN. The vpn-instance-name argument specifies an MPLS L3VPN by its instance name, a case-sensitive string of 1 to 31 characters. To display the IS-IS TE statistics for the public network, do not specify this option.
Use display isis traffic-eng statistics to display IS-IS TE statistics.
If no IS-IS level is specified, this command displays TE statistics for Level-1-2 IS-IS.
# Display IS-IS TE statistics.
<Sysname> display isis traffic-eng statistics
TE Statistics Information
IS-IS System Type : Level-1-2
IS-IS Cost Style Status : Wide
IS-IS Level-1 Traffic Engineering Status : Disabled
IS-IS Level-2 Traffic Engineering Status : Enabled
IS-IS Router ID : 1.1.1.9
Table 5 Command output
IS-IS System Type |
System type. |
IS-IS Cost Style Status |
Cost type of the router. |
IS-IS Level-1 Traffic Engineering Status |
TE state of Level-1 router. |
IS-IS Level-2 Traffic Engineering Status |
TE state of Level-2 router. |
display isis traffic-eng sub-tlvs [ process-id | vpn-instance vpn-instance-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Displays the IS-IS sub-TLVs for TE in the specified VPN. The vpn-instance-name argument specifies an MPLS L3VPN by its VPN instance name, a case-sensitive string of 1 to 31 characters. To display TE sub-TLV information for the public network, do not specify this option.
Use display isis traffic-eng sub-tlvs to display information about IS-IS sub-TLVs for TE.
If no IS-IS level is specified, this command displays Level-1-2 IS-IS sub-TLVs for TE.
Related commands: te-set-subtlv.
# Display IS-IS sub-TLV information for TE.
<Sysname> display isis traffic-eng sub-tlvs
IS-IS(1) SubTlv Information
Unreserved sub-pool bandwidth sub-tlv value : 251
Bandwidth constraint sub-tlv value : 252
LO multiplier sub-tlv value : 253
Table 6 Command output
Unreserved sub-pool bandwidth sub-tlv value |
Sub-TLV of unreserved subpool bandwidth. |
Bandwidth constraint sub-tlv value |
Bandwidth constraint sub-TLV. |
LO multiplier sub-tlv value |
LOM sub-TLV. |
display mpls lsp bfd te
display mpls lsp bfd [ te tunnel tunnel-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
tunnel tunnel-number: Displays the BFD information for the specified MPLS TE tunnel. tunnel-number is the tunnel interface number.
Use display mpls lsp bfd te to display BFD information for MPLS TE tunnels.
# Display BFD information for the MPLS TE tunnel using tunnel interface Tunnel1.
<Sysname> display mpls lsp bfd te Tunnel 1
MPLS BFD Session(s) Information
FEC : Tunnel1 Type : TE Tunnel
Local Discr : 3 Remote Discr : 3
Tunnel ID : 0xd2009 NextHop : ----
Session State : Up Source IP : 1.1.1.1
Session Role : Active
Total Session Num: 1
Table 7 Command output
Type |
Type of the tunnel detected by BFD, which can be LSP or TE Tunnel. |
Local Discr |
Local discriminator of the BFD session. |
Remote Discr |
Remote discriminator of the BFD session. |
Session State |
Status of the BFD session, which can be Init (initializing), Up, or Down. |
Source IP |
IP address of the active end (ingress LSR) of the BFD session. |
Session Role |
Role of the LSR in the BFD session, Active or Passive. |
display mpls rsvp-te [ interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ] ]
View
Default level
1: Monitor level
interface: Displays RSVP-TE configuration for interfaces.
interface-type interface-number: Specifies an interface for which RSVP-TE configuration is displayed.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 80 characters.
Use display mpls rsvp-te to display RSVP-TE configuration.
If the interface keyword is not specified, this command displays global RSVP-TE configuration.
If no interface is specified through the interface-type interface-number argument, this command displays RSVP-TE configuration for all RSVP-TE enabled interfaces.
# Display global RSVP-TE configuration.
<Sysname> display mpls rsvp-te
LSR ID: 4.4.4.4
Resv Confirmation Request: DISABLE
RSVP Hello Extension: ENABLE
Hello interval: 3 sec Max Hello misses: 3
Path and Resv message refresh interval: 30 sec
Path and Resv message refresh retries count: 3
Blockade Multiplier: 4
Graceful Restart: ENABLE
Restart Time: 200 sec Recovery Time: 150 sec
Table 8 Command output
LSR ID |
Label switched Router ID, in the format of X.X.X.X. |
Resv Confirmation Request |
Reserved confirmation request. |
RSVP Hello Extension |
State of the hello mechanism: enabled or disabled. |
Hello Interval |
Hello interval, in seconds. |
Max Hello misses |
Maximum number of consecutive hello losses before a neighbor is considered dead. |
Path and Resv message refresh interval |
Path and reservation message refresh interval, in seconds. |
Path and Resv message refresh retries count |
Number of Path and Resv message retransmissions. |
Blockade Multiplier |
Blockade multiplier. |
Graceful Restart |
State of GR: enabled or disabled. |
Restart Time |
GR restart interval in seconds. |
Recovery Time |
GR recovery interval in seconds. |
# Display the RSVP-TE configuration on interface VLAN-interface 1000.
<Sysname> display mpls rsvp-te interface Vlan-interface 1000
Interface Vlan-interface 1000
Interface state: UP BFD feature: ENABLE
Total-BW: 80 Used-BW: 20
Hello configured: NO Num of Neighbors: 1
SRefresh feature: ENABLE SRefresh Interval: 30sec
Authentication: DISABLE Reliability configured: NO
Retransmit Interval: 500msec Increment Value: 1
Table 9 Command output
Interface Vlan-interface 1000 |
RSVP-TE enabled interface. |
Interface state |
Physical interface state. |
BFD feature |
State of BFD: enabled or disabled. |
Total-BW |
Total bandwidth (in kbps). |
Used-BW |
Used bandwidth (in kbps). |
Hello configured |
Num of Neighbors |
Number of neighbors connected to the interface. |
Srefresh feature |
State of the summary refresh function: enabled or disabled. |
Srefresh interval |
Summary refresh interval (in seconds). |
Authentication |
State of authentication: enabled or disabled. |
Reliability |
Whether the reliability feature is configured: yes or no. |
Retransmit interval |
Initial retransmission interval (in milliseconds). |
Increment value |
Increment value delta which governs the speed at which the interface increases the retransmission interval. Assume the retransmission interval is Rf seconds. If the interface does not receive an ACK message for a packet within this interval, it retransmits the packet after (1 + Increment value) × Rf seconds. |
display mpls rsvp-te established [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the RSVP-TE tunnel information for all interfaces.
Use display mpls rsvp-te established to display information about RSVP-TE tunnels.
# Display RSVP-TE tunnel information for interface VLAN-interface 1000.
<Sysname> display mpls rsvp-te established interface Vlan-interface 1000
Token Bucket Rate: 0.00 Peak Data Rate: 0.00
Tunnel Dest: 2.2.2.2 Ingress LSR ID: 3.3.3.3
Local LSP ID: 4 Session Tunnel ID: 4
Next Hop Addr: 80.4.1.1
Upstream Label: 1024 Downstream Label: 3
Table 10 Command output
Token Bucket rate |
Token bucket rate, a traffic parameter. |
Peak Data Rate |
Peak rate, a traffic parameter. |
Tunnel Dest |
Tunnel destination, in the format of X.X.X.X. |
Ingress LSR ID |
Ingress LSR ID, in the format of X.X.X.X. |
Next Hop Addr |
Next hop address, in the format of X.X.X.X. |
display mpls rsvp-te peer
display mpls rsvp-te peer [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display mpls rsvp-te peer to display information about RSVP-TE neighbors on the specified or all interfaces.
# Display information about RSVP-TE neighbors on all interfaces.
<Sysname> display mpls rsvp-te peer
Interface Vlan-interface1000
Neighbor Addr: 80.4.1.1
SrcInstance: 841 NbrSrcInstance: 928
PSB Count: 0 RSB Count: 1
Hello Type Sent: ACK Neighbor Hello Extension: ENABLE
SRefresh Enable: NO Reliability Enable: YES
Graceful Restart State: Ready
Interface Vlan-interface1001
Neighbor Addr: 80.2.1.1
SrcInstance: 832 NbrSrcInstance: 920
PSB Count: 1 RSB Count: 0
Hello Type Sent: REQ Neighbor Hello Extension: ENABLE
Graceful Restart State: Not Ready
Restart Time: --- Recovery Time: ---
Table 11 Command output
Interface Vlan-interface1000 |
Neighbor Addr: |
Neighbor address, in the format of X.X.X.X. |
SrcInstance |
Instance of source Message ID. |
NbrSrcInstance |
Instance of neighbor Message ID. |
PSB Count |
Number of path state blocks. |
RSB Count |
Number of reservation state blocks. |
Hello Type Sent |
Type of hellos sent to the neighbor: REQ, ACK, or NONE. |
Neighbor Hello Extension |
State of hello extension: enabled or disabled. This field is displayed only when hello extension is enabled on the interface. |
SRefresh Enable |
State of summary refresh: YES for enabled and NO for disabled. |
Reliability Enable |
State of the reliability function: YES for enabled and NO for disabled. |
Graceful Restart State |
Neighbor's GR status: Not Ready, Ready, Restart, or Recovery. Displayed as --- when not supported by the switch. |
Restart Time |
Recovery Time |
display mpls rsvp-te psb-content ingress-lsr-id lspid tunnel-id egress-lsr-id [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ingress-lsr-id: Ingress LSR ID.
lspid: Local LSR ID in the range of 1 to 65535.
tunnel-id: Tunnel ID in the range of 0 to 65535.
egress-lsr-id: Egress LSR ID.
Use display mpls rsvp-te psb-content to display information about RSVP-TE PSB.
# Display PSB information.
<Sysname> display mpls rsvp-te psb-content 19.19.19.19 1 0 29.29.29.29
The PSB Content:
Tunnel Dest: 29.29.29.29 Session Tunnel ID: 0
Tunnel ExtID: 19.19.19.19
Ingress LSR ID: 19.19.19.19 Local LSP ID: 1
Previous Hop : 101.101.101.1 Next Hop : -----
Incoming / Outgoing Interface: Vlan-interface1000 / -----
InLabel : 3 OutLabel : NULL
Reverse InLabel : null Reverse OutLabel : 1024
Send Message ID : 1 Recv Message ID : 0
Session Attribute-
SetupPrio: 7 HoldPrio: 7
SessionFlag: SE Style desired
ERO Information-
L-Type ERO-IPAddr ERO-PrefixLen
ERHOP_STRICT 101.101.101.2 32
RRO Information-
RRO-CType: IPV4 RRO-IPAddress: 101.101.101.1 RRO-IPPrefixLen: 32
SenderTspec Information-
Token bucket rate: 0.00
Token bucket size: 0.00
Peak data rate: 0.00
Minimum policed unit: 0
Maximum packet size: 4294967295
Path Message arrive on Vlan-interface1000 from PHOP 101.101.101.1
Resource Reservation OK
Graceful Restart State: Stale
Bandwidth Constraint Mode: IETF DS-TE RDM
Table 12 Command output
Tunnel Dest |
Session Tunnel ID |
Session tunnel ID. |
Tunnel ExtID |
Tunnel extension ID, in the format of X.X.X.X. |
Ingress LSR ID |
Local LSP ID |
Local LSP ID. |
Next Hop |
Previous Hop |
Previous hop address, in the format of X.X.X.X. |
In Label |
Incoming label. |
Out Label |
Outgoing label. |
Reverse InLabel |
Incoming label of the reverse LSP. |
Reverse OutLabel |
Outgoing label of the reverse LSP. |
Send message ID |
Instance of sent Message ID. |
Resv Message ID |
Instance of received Message ID. |
Setup Prio |
Session setup priority. |
HoldPrio |
Session hold priority. |
Session Flag |
Session flag (local protection policy, label, SE style). |
ERO Information |
Information about explicit routes. |
L-Type |
Explicit routing type: strict or loose. |
ERO-IPAddress |
IP address for an explicit route. |
ERO-Prefix Len |
Prefix length for an explicit route. |
RRO Information |
Information about route recording. |
RRO-C Type |
Type of route recording. |
RRO-IP Address |
IP address of recorded route in the format of X.X.X.X. |
RRO-IPPrefixLen |
IP prefix length of recorded route. |
Sender Tspec Information |
Information about sender's service specifications. |
Token Bucket rate |
Token bucket rate (in kbps), a traffic parameter. |
Token Bucket size |
Token bucket size, a traffic parameter. |
Peak Data Rate |
Peak data rate (in kbps), a traffic parameter. |
Maximum packet size |
Maximum packet size, a traffic parameter. |
Minimum policed unit |
Minimum policed unit, a traffic parameter. |
Path message |
Path message sent from the interface to the next hop at X.X.X.X. |
Resource |
Available when the RSVP flag is configured. |
State of GR: stale or normal. Displayed as --- when not supported by the switch. |
Bandwidth Constraint Mode |
Bandwidth constraints model carried in the path message: · IETF DS-TE RDM. · IETF DS-TE MAM. · Prestandard DS-TE RDM. |
display mpls rsvp-te request
display mpls rsvp-te request [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display mpls rsvp-te request to display information about RSVP-TE requests on the specified or all interfaces.
# Display information about RSVP-TE requests on all interfaces.
<Sysname> display mpls rsvp-te request
Interface Vlan-interface1000:
NextHopAddr: 80.4.1.1
SessionFlag: SE Style desired.
Token bucket rate: 0.00 Token bucket size: 1000.00
Out Interface: Vlan-interface1001
Table 13 Command output
RSVP-TE enabled Ethernet interface. |
Tunnel Dest |
Tunnel destination, in the format of X.X.X.X |
Ingress LSR ID |
Ingress LSR ID, in the format of X.X.X.X |
Next Hop Address |
Next hop address, in the format of X.X.X.X |
SessionFlag |
Reservation style. |
Token Bucket rate |
Token Bucket Size |
Out Interface |
Output interface. |
display mpls rsvp-te reservation [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display mpls rsvp-te reservation to display information about RSVP-TE reservations on the specified interface or all interfaces.
# Display information about RSVP-TE reservations on interface VLAN-interface 1000.
<Sysname> display mpls rsvp-te reservation interface Vlan-interface 1000
Tunnel Dest: 29.29.29.29 Ingress LSR ID: 19.19.19.19
LSP ID: 1 Tunnel ID: 1
Upstream Label: -----
Token bucket rate: 0.00 Token bucket size: 0.00
# Display information about RSVP-TE reservations on all interfaces.
Interface: Outgoing-Interface at the Egress
Tunnel Dest: 19.19.19.19 Ingress LSR ID: 29.29.29.29
Upstream Label: 3
Table 14 Command output
Tunnel Dest |
Ingress LSR ID |
Token Bucket rate |
Token Bucket Size |
display mpls rsvp-te rsb-content ingress-lsr-id Ispid tunnel-id egress-lsr-id nexthop-address [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
lspid: Local LSP ID in the range of 1 to 65535.
nexthop-address: Next hop address.
Use display mpls rsvp-te rsb-content to display information about RSVP-TE reservation state blocks (RSBs).
# Display information about RSVP-TE RSBs.
<Sysname> display mpls rsvp-te rsb-content 19.19.19.19 1 0 29.29.29.29 101.101.101.2
The RSB Content:
Next Hop: 101.101.101.2 Reservation Style: SE Style
Reservation Incoming Interface: Vlan-interface1000
Reservation Interface: Vlan-interface1000
Message ID : 2
Filter Spec Information-
The filter number: 1
Ingress LSR ID: 19.19.19.19 Local LSP ID: 1 OutLabel: 3
RRO Information-
RRO-Flag is
RRO-CType: IPV4 RRO-IPAddress: 101.101.101.2 RRO-IPPrefixLen: 32
FlowSpec Information-
Token bucket rate: 2500.00
Maximum packet size: 0
Bandwidth guarantees: 0.00
Delay guarantees: 0
Qos Service is Controlled
Resv Message arrive on Vlan-interface1000 from NHOP 101.101.101.2
Table 15 Command output
Tunnel Dest |
Tunnel Ext ID |
Tunnel extension (ingress LSR ID), in the format of X.X.X.X. |
Next Hop |
Reservation Style |
Reservation style: SE or FF. |
Reservation Interface |
Reservation interface name. |
Reserve Incoming Interface |
Incoming interface where the Resv message was received. |
Message ID |
Message ID of the Refresh Reduction message. |
Filter Spec Information |
Filter specifications. |
The filter number |
Number of filters. |
Ingress LSR ID |
Out Label |
Outgoing label. |
RRO Information |
RRO-C Type |
RRO-IP Address |
RRO-IPPrefixLen |
Flow Spec information |
Flow specifications. |
Token Bucket rate |
Token Bucket size |
Peak Data Rate |
Bandwidth guarantees |
Guaranteed bandwidth, a reservation specifications parameter. |
Delay guarantees |
Delay guarantee, a reservation specifications parameter. |
QOS service |
QoS guarantee/control. |
Resv Message |
Reservation message received on a particular interface from next hop (X.X.X.X). |
display mpls rsvp-te sender
display mpls rsvp-te sender [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display mpls rsvp-te sender to display RSVP-TE sender message information.
# Display RSVP-TE sender message information on interface VLAN-interface 1000.
<Sysname> display mpls rsvp-te sender interface Vlan-interface 1000
LSP ID: 1 Session Tunnel ID: 1
Session Name: Tunnel1
Previous Hop Address: 101.101.101.1
Token bucket rate: 0.0 Token bucket size: 0.00
# Display RSVP-TE sender message information on all interfaces.
LSP ID: 1 Session Tunnel ID: 0
Previous Hop Address: 101.101.101.2
Interface: Incoming-Interface at the Ingress
Session Name: Tunnel2
Previous Hop Address: 19.19.19.19
Table 16 Command output
Tunnel Dest |
Ingress LSR ID |
Previous Hop Address |
Token Bucket rate |
Token Bucket Size |
display mpls rsvp-te statistics { global | interface [ interface-type interface-number ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
global: Display global RSVP-TE information.
interface: Displays statistics about RSVP-TE for a specific interface or, if no interface is specified, all interfaces.
interface-type interface-number: Specifies an interface for which statistics about RSVP-TE is displayed.
Use display mpls rsvp-te statistics to display statistics about RSVP-TE.
# Display global RSVP-TE statistics.
<Sysname> display mpls rsvp-te statistics global
LSR ID: 1.1.1.1
PSB Count: 1 RSB Count: 1
RFSB Count: 0 TCSB Count: 1
LSP Count: 1
Total Statistics Information:
PSB CleanupTimeOutCounter: 0 RSB CleanupTimeOutCounter: 0
SendPacketCounter: 55 RecPacketCounter: 54
SendPathCounter: 5 RecPathCounter: 0
SendResvCounter: 0 RecResvCounter: 4
SendResvConfCounter: 0 RecResvConfCounter: 0
SendHelloCounter: 2 RecHelloCounter: 48
SendAckCounter: 48 RecAckCounter: 2
SendPathErrCounter: 0 RecPathErrCounter: 0
SendResvErrCounter: 0 RecResvErrCounter: 0
SendPathTearCounter: 0 RecPathTearCounter: 0
SendResvTearCounter: 0 RecResvTearCounter: 0
SendSrefreshCounter: 0 RecSrefreshCounter: 0
SendAckMsgCounter: 0 RecAckMsgCounter: 0
SendErrMsgCounter: 0 RecErrMsgCounter: 0
RecReqFaultCounter: 0 BindFrrFaultCounter: 0
# Display RSVP-TE statistics for interface VLAN-interface 1000.
<Sysname> display mpls rsvp-te statistics interface Vlan-interface1000
Vlan-interface1000:
SendPacketCounter: 69 RecPacketCounter: 68
SendPathCounter: 6 RecPathCounter: 0
SendResvCounter: 0 RecResvCounter: 5
SendHelloCounter: 2 RecHelloCounter: 61
SendAckCounter: 61 RecAckCounter: 2
Table 17 Command output
PSB Count |
Number of PSBs. |
RSB Count |
Number of RSBs. |
RFSB Count |
Number of RFSBs. |
TCSB Count |
Number of TCSBs. |
LSP Count |
Number of LSPs. |
PSB CleanupTimeOutCounter |
Number of PSB timeouts. |
RSB CleanupTimeOutCounter |
Number of RSB timeouts. |
SendPacketCounter |
Number of transmitted packets. |
RecPacketCounter |
Number of received packets. |
SendPathCounter |
Number of transmitted Path messages. |
RecPathCounter |
Number of received Path messages. |
SendResvCounter |
Number of transmitted Resv messages. |
RecResvCounter |
Number of received Resv messages. |
SendResvConfCounter |
Number of transmitted ResvConf messages. |
RecResvConfCounter |
Number of received ResvConf messages. |
SendHelloCounter |
Number of transmitted Hello messages. |
RecHelloCounter |
Number of received Hello messages. |
SendAckCounter |
Number of transmitted Ack messages. |
RecAckCounter |
Number of received Ack messages. |
SendPathErrCounter |
Number of transmitted PathErr messages. |
RecPathErrCounter |
Number of received PathErr messages. |
SendResvErrCounter |
Number of transmitted ResvErr messages. |
RecResvErrCounter |
Number of received ResvErr messages. |
SendPathTearCounter |
Number of transmitted PathTear messages. |
RecPathTearCounter |
Number of received PathTear messages. |
SendResvTearCounter |
Number of transmitted ResvTear messages. |
RecResvTearCounter |
Number of received ResvTear messages. |
SendSrefreshCounter |
Number of transmitted Srefresh messages. |
RecSrefreshCounter |
Number of received Srefresh messages. |
SendAckMsgCounter |
Number of transmitted AckMsg messages. |
RecAckMsgCounter |
Number of received AckMsg messages. |
SendErrMsgCounter |
Number of transmitted errors. |
RecErrMsgCounter |
Number of received errors. |
RecReqFaultCounter |
Number of request failures. |
BindFrrFaultCounter |
Number of primary-to-bypass tunnel binding failures in the FRR process. |
display mpls static-cr-lsp
display mpls static-cr-lsp [ lsp-name lsp-name ] [ { include | exclude } ip-address prefix-length ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
lsp-name lsp-name: Label switched path name containing 1 to 15 characters.
include: Displays only CR-LSPs with the destination IP address specified by the ip-address prefix-length arguments.
exclude: Displays only CR-LSPs with destination IP addresses other than the one specified by the ip-address prefix-length arguments.
ip-address: IP address of the FEC.
prefix-length: IP address prefix length in the range of 0 to 32.
verbose: Displays detailed information.
· begin: Displays the first line that matches the specified regular expression and all lines that follow.
· exclude: Displays all lines that do not match the specified regular expression.
· include: Displays all lines that match the specified regular expression.
· regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use display mpls static-cr-lsp to display information about static CR-LSPs.
# Display brief information about all static CR-LSPs.
<Sysname> display mpls static-cr-lsp
total statics-cr-lsp : 1
Name FEC I/O Label I/O If State
Tunnel1 3.3.3.9/32 NULL/100 -/Vlan1000 Down
Table 18 Command output
Name |
Static CR-LSP name. |
FEC |
FEC destination address and mask. |
I/O Label |
Incoming/outgoing label. |
I/O If |
Incoming/outgoing interface. |
State |
Current state of the CR-LSP. |
# Display detailed information about all static CR-LSPs.
<Sysname> display mpls static-cr-lsp verbose
No : 1
LSP-Name : Tunnel1
LSR-Type : Ingress
FEC : 3.3.3.3/32
In-Label : NULL
Out-Label : 20
In-Interface : -
Out-Interface : Vlan-interface1000
NextHop : 2.1.1.2
Lsp Status : Up
Table 19 Command output
LSP-Name |
LSR-Type |
Role of the LSR in the LSP: ingress, transit, or egress. |
FEC |
FEC destination address and the destination address mask. |
In-Label |
Incoming label. |
Out-Label |
Outgoing label. |
In-Interface |
Incoming interface. |
Out-Interface |
Outgoing interface. |
NextHop |
Next hop address. |
Lsp Status |
Status of the LSP. |
display mpls te cspf tedb
display mpls te cspf tedb { all | area area-id | interface ip-address | network-lsa | node [ mpls-lsr-id ] } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
area-id: Area ID. For OSPF, it is in the range of 0 to 4294967295. For IS-IS, it is in the range of 1 or 2.
ip-address: IP address of an interface.
network-lsa: Displays traffic engineering database (TEDB) information in network LSAs.
node: Displays the TEDB information on nodes. If no node is specified, this command displays the TEDB information on all nodes.
mpls-lsr-id: Specifies a node by its MPLS LSR ID.
Use display mpls te cspf tedb to display information about CSPF-based TEDB by specified criteria.
# Display TEDB information in network LSAs.
<Sysname> display mpls te cspf tedb network-lsa
Maximum Network LSA Supported: 500
Current Total Network LSA Number: 7
Id DR MPLS LSR-Id DR-Address IGP Process-Id Area Neighbor
1 8.1.1.2 3.0.0.2 OSPF 100 0 1.1.1.1
2.1.1.1
8.1.1.2
2 2.1.1.1 3.0.0.3 OSPF 100 0 2.1.1.1
3.1.1.1
2.1.1.2
3 3.1.1.2 3.0.0.4 OSPF 100 0 3.1.1.1
4.1.1.1
3.1.1.2
4 4.1.1.2 3.0.0.5 OSPF 100 0 4.1.1.1
5.1.1.1
4.1.1.2
5 5.1.1.2 3.0.0.6 OSPF 100 0 5.1.1.1
6.1.1.1
5.1.1.2
6 6.1.1.2 3.0.0.9 OSPF 100 0 6.1.1.1
7.1.1.1
6.1.1.2
7 7.1.1.1 12.0.0.7 OSPF 100 0 3.1.1.1
7.1.1.1
7.1.1.2
Table 20 Command output
ID |
Number. |
DR MPLS LSR-Id |
MPLS LSR ID of the designated router (DR), in dotted decimal notation. |
DR-Address |
Interface address of the DR. |
IGP |
Interior gateway protocol: OSPF or IS-IS. |
Process-Id |
IGP process ID. |
Area |
Area to which the router belongs. |
Neighbor |
Neighbor router ID. |
# Display all TEDB information.
<Sysname> display mpls te cspf tedb all
Maximum Node Supported: 1000 Maximum Link Supported: 4000
Current Total Node Number: 3 Current Total Link Number: 44
Id MPLS LSR-Id IGP Process-Id Area Link-Count
1 1.1.1.1 OSPF 100 1001,1002,1003 20
1004,1005,1006
1007,1008,1009
1010,1,2
13,14,15
16,17,18
19,20
2 2.1.1.1 ISIS 100 Level-0,1 20
3 3.1.1.1 OSPF 100 0 4
Table 21 Command output
ID |
Number. |
MPLS LSR-Id |
MPLS LSR ID, in dotted decimal notation. |
IGP |
Process-Id |
IGP process ID. |
Area |
Link-count |
Total number of connected links belonging to a particular IGP protocol process. |
# Display the TEDB information for IGP area 1.
<Sysname> display mpls te cspf tedb area 1
Router Node Information for Area 1:
1 2.2.2.2 OSPF 100 1 1
2 3.3.3.3 OSPF 100 1 1
3 2.2.2.2 ISIS 100 Level-1 1
4 3.3.3.3 ISIS 100 Level-1 1
Network LSA Information for Area 1:
1 3.3.3.3 20.1.1.2 OSPF 100 1 2.2.2.2
3.3.3.3
2 3.3.3.3 20.1.1.2 ISIS 100 Level-1 3.3.3.3
2.2.2.2
Table 22 Command output
Id |
Number. |
MPLS LSR-Id |
IGP |
Process-Id |
IGP process ID. |
Area |
Link-Count |
DR MPLS LSR-Id |
MPLS LSR ID of the DR. |
DR-Address |
Neighbor |
MPLS LSR ID of the neighbor. |
# Display the TEDB information for all nodes in prestandard DS-TE mode.
<Sysname> display mpls te cspf tedb node
MPLS LSR-Id: 1.1.1.1
IGP Type: OSPF Process Id: 100
MPLS-TE Link Count: 1
Link[1] :
Interface IP Address: 2.0.0.33, 2.0.0.35, 2.0.0.36,
Neighbor IP Address: 2.0.0.2, 2.0.0.42, 2.0.0.43,
2.0.0.44, 2.0.0.45, 2.0.0.46,
2.0.0.47, 2.0.0.32,
Neighbor MPLS LSR-Id : 1.1.1.2
IGP Area: 1
Link Type: point-to-point Link Status: Inactive
IGP Metric: 100 TE Metric: 100 Color: 0xff
Maximum Reservable Bandwidth: 0 (kbps)
Bandwidth Constraint Mode: Prestandard DS-TE RDM
BC[0] : 0 (kbps)
BC[1] : 0 (kbps)
Unreserved Bandwidth for each TE Class:
[0] : 0 (kbps), [1] : 0 (kbps)
[2] : 0 (kbps), [3] : 0 (kbps)
[4] : 0 (kbps), [5] : 0 (kbps)
[6] : 0 (kbps), [7] : 0 (kbps)
[8] : 0 (kbps), [9] : 0 (kbps)
[10]: 0 (kbps), [11]: 0 (kbps)
[12]: 0 (kbps), [13]: 0 (kbps)
[14]: 0 (kbps), [15]: 0 (kbps)
IGP Type: ISIS Process Id: 100
MPLS-TE Link Count: 2
Link[1] :
2.0.0.47, 2.0.0.32, 2.0.0.33
Neighbor MPLS LSR-Id: 1.1.1.2
IGP Area: Level-0
Link Type: point-to-point Link Status: Active
IGP Metric: 10 TE Metric: 10 Color: 0x11
Maximum Bandwidth: 100 (kbps)
BC[0] : 0 (kbps)
BC[1] : 0 (kbps)
Table 23 Command output
MPLS LSR-Id |
MPLS LSR ID of node, in dotted decimal notation. |
Process Id |
IGP process ID. |
MPLS-TE Link Count |
Number of MPLS TE links. |
Link[1] |
Information about the first link. |
DR Address |
IP address of the DR. |
IGP Metric |
IGP metric of link. |
TE Metric |
TE metric of link. |
Color |
Link administrative attribute. |
Maximum Bandwidth |
Maximum bandwidth of the link. |
Maximum Reservable Bandwidth |
Maximum reservable bandwidth of link. |
Bandwidth constrains model. |
Unreserved Bandwidth for each TE Class |
Reservable bandwidth for each TE class. |
# Display TEDB information for a specific interface address in IETF DS TE RDM mode.
<Sysname> display mpls te cspf tedb interface 20.1.1.1
MPLS LSR-Id: 2.2.2.2
Link[1] :
Interface IP Address: 20.1.1.1
DR Address: 20.1.1.2
IGP Area: Level-1
Link Type: multi-access Link Status: Active
IGP Metric: 10 TE Metric: 0 Color: 0x0
Maximum Bandwidth: 0 (kbps)
BC[0] : 0 (kbps)
BC[1] : 0 (kbps)
BC[2] : 0 (kbps)
BC[3] : 0 (kbps)
MPLS LSR-Id |
Process Id |
IGP process ID. |
Link[1] |
Interface IP Address |
Interface IP address. |
DR Address |
IGP Metric |
TE Metric |
Color |
Maximum Bandwidth |
Maximum reservable bandwidth of the link. |
Bandwidth constraints model. |
display mpls te link-administration admission-control [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface interface-type interface-number: Specifies an interface by its type and a number.
Use display mpls te link-administration admission-control to display information about CR-LSPs carried on the link of a specific interface or links of all interfaces if no interface is specified.
# Display information about the CR-LSPs carried on the links of all interfaces.
<Sysname> display mpls te link-administration admission-control
LspID In/Out IF S/H Prio CT BW(kbps)
1.1.1.9:1024 ---/Vlan1000 7/7 0 0
1.1.1.9:2048 ---/Vlan1001 7/7 0 0
Table 25 Command output
LspID |
ID of an LSP carried on a link. |
In/Out IF |
Incoming/Outgoing interface. |
S/H Prio |
Setup and holding priorities of CR-LSP. |
CT |
Service class type. |
BW(kbps) |
Bandwidth (in kbps) |
display mpls te link-administration bandwidth-allocation [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display mpls te link-administration bandwidth-allocation to display bandwidth allocation on the specified or all MPLS TE enabled interfaces.
# Display bandwidth allocation on the MPLS TE enabled interface in prestandard mode.
<Sysname> display mpls te link-administration bandwidth-allocation
Link ID: Vlan-interface1000
Max Link Bandwidth : 0 kbits/sec
Max Reservable Bandwidth of Prestandard RDM : 0 kbits/sec
Max Reservable Bandwidth of IETF RDM : 0 kbits/sec
Max Reservable Bandwidth of IETF MAM : 0 kbits/sec
Downstream LSP Count : 0
UpStream LSP Count : 0
Downstream Bandwidth : 0 kbits/sec
Upstream Bandwidth : 0 kbits/sec
IPUpdown Link Status : UP
PhysicalUpdown Link Status : UP
BC Prestandard RDM(kbps) IETF Mode RDM(kbps) IETF Mode MAM(kbps)
0 0 0 0
1 0 0 0
2 0 0 0
3 0 0 0
TE CLASS CLASS TYPE PRIORITY BW RESERVED(kbps) BW AVAILABLE(kbps)
0 0 0 0 0
1 0 1 0 0
2 0 2 0 0
3 0 3 0 0
4 0 4 0 0
5 0 5 0 0
6 0 6 0 0
7 0 7 0 0
8 1 0 0 0
9 1 1 0 0
10 1 2 0 0
11 1 3 0 0
12 1 4 0 0
13 1 5 0 0
14 1 6 0 0
15 1 7 0 0
Table 26 Command output
Downstream LSP Count |
Number of downstream LSPs. |
UpStream LSP Count |
Number of upstream LSPs. |
IPUpdown Link Status |
IP layer link status. |
PhysicalUpdown Link Status |
Physical layer link status. |
BC |
Bandwidth constraint number. |
Prestandard RDM |
Bandwidth constraints in prestandard RDM mode, in kbps. |
IETF Mode RDM |
Bandwidth constraints in IETF RDM mode, in kbps. |
IETF Mode MAM |
TE CLASS |
TE class. |
CLASS TYPE |
BW RESERVED |
Bandwidth reserved for the TE class, in kbps. |
BW AVAILABLE |
Bandwidth available for the TE class, in kbps. |
display mpls te protection tunnel { tunnel-id | all } [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
tunnel-id: ID of a main tunnel.
all: Displays information about all protection groups.
verbose: Displays the detailed information.
Use display mpls te protection tunnel to display information about the specified tunnel and its protection tunnel.
# Display information about tunnel 100 and its protection tunnel.
<Sysname> display mpls te protection tunnel 100
Work-tunnel id Protect-tunnel id Switch-Result
100 101 work-tunnel
# Display detailed information about tunnel 100 and its protection tunnel.
<Sysname> display mpls te protection tunnel 100 verbose
Work-tunnel id : 100
Protect-tunnel id : 101
Switch result : work-tunnel
Work-tunnel defect state : No-defect
Protect-tunnel defect state : No-defect
Holdoff : 5000ms
WTR : 150s
Mode : revertive
Holdoff timer : not start
WTR timer : not start
The current switch command : --
Table 27 Command output
Work-tunnel id |
Main tunnel's ID. |
Protect-tunnel id |
Protection tunnel's ID. |
Switch result |
Tunnel in use, which can be work-tunnel or protect-tunnel. |
Work-tunnel defect state |
State of the main tunnel: · No-defect—The main tunnel is normal. · In-defect—The main tunnel is failed. |
Protect-tunnel defect state |
State of the protection tunnel: · No-defect—The protection tunnel is normal. · In-defect—The protection tunnel is failed. |
Holdoff |
Switching delay time, time to wait before switching to the backup tunnel. |
WTR |
Reverting delay time, time to wait before switching back to the main tunnel. |
Mode |
Reverting mode, which can be revertive or non-revertive. |
The current switch command |
Executed external switching command. |
display mpls te tunnel [ destination dest-addr ] [ lsp-id lsr-id lsp-id ] [ lsr-role { all | egress | ingress | remote | transit } ] [ name name ] [ { incoming-interface | outgoing-interface | interface } interface-type interface-number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
destination address: Specifies a destination IP address to display only the tunnels with the specified destination IP address.
lsr-id: LSR ID of the ingress node, in dotted decimal notation.
lsp-id: LSP ID in the range of 1 to 65535.
lsr-role: Displays tunnels by LSR role (ingress, transit, egress, or remote).
all: Displays all tunnels.
egress: Displays tunnels created taking the current device as the egress.
ingress: Displays tunnels created taking the current device as the ingress .
remote: Displays tunnels created taking the current device as the egress or a transit node.
transit: Displays tunnels created taking the current device as a transit node.
name name: Displays the tunnel with a particular name. This could be a string of 1 to 63 characters configured as interface description or the interface name if no interface description is configured. The tunnel name should be signaled to all hops.
incoming-interface: Displays all tunnels that use the interface identified by the interface-type interface-number arguments as the incoming interface.
outgoing-interface: Displays all tunnels that use the interface identified by the interface-type interface-number arguments as the outgoing interface.
interface: Displays all tunnels that use the interface identified by the interface-type interface-number arguments as the incoming or outgoing interface.
Use display mpls te tunnel to display information about MPLS TE tunnels.
# Display information about MPLS TE tunnels. (The output might vary by signaling protocol.)
<Sysname> display mpls te tunnel
LSP-Id Destination In/Out-If Name
1.1.1.9:1024 3.3.3.9 -/Vlan10 Tunnel1
1.1.1.9:2048 3.3.3.9 -/Vlan11 Tunnel1
Table 28 Command output
LSP-ID |
LSP ID of tunnel. |
Destination |
Destination router ID. |
In/Out-IF |
Name |
Tunnel name configured on the ingress node. |
# Display detailed information about MPLS TE tunnels.
<Sysname> display mpls te tunnel verbose
No : 1
LSP-Id : *1.1.1.9:23
Tunnel-Name : Tunnel2
Destination : 1.1.1.9
In-Interface : Vlan1
Out-Interface : -
Tunnel BW : 0 kbps
Class Type : CT0
Ingress LSR-Id : *1.1.1.9
Egress LSR-Id : 1.1.1.9
Setup-Priority : 7
Hold-Priority : 7
Sign-Protocol : RSVP TE
Resv Style : FF
IncludeAnyAff : 0x0
ExcludeAllAff : 0x0
IncludeAllAff : 0x0
Created Time : 2011/01/28 09:59:49
No : 2
LSP-Id : 1.1.1.9:23
Destination : 2.2.2.9
In-Interface : -
Out-Interface : Vlan1
Tunnel BW : 0 kbps
Class Type : CT0
Ingress LSR-Id : 1.1.1.9
Egress LSR-Id : 2.2.2.9
Setup-Priority : 7
Hold-Priority : 7
Resv Style : FF
IncludeAnyAff : 0x0
ExcludeAllAff : 0x0
IncludeAllAff : 0x0
Table 29 Command output
No |
Number. |
LSP-Id |
LSP ID of tunnel. |
Tunnel-Name |
Destination |
In-Interface |
Out-Interface |
Tunnel BW |
Tunnel bandwidth. |
Class Type |
Ingress LSR-Id |
Ingress LSR ID. |
Egress LSR-Id |
Egress LSR-ID. |
Setup-Priority |
Setup priority of link. |
Hold-Priority |
Holding priority of link. |
Sign-Protocol |
Signaling protocol. |
Resv Style |
IncludeAnyAff |
Any affinity properties that must be included. |
ExcludeAllAff |
Link properties that are excluded. |
IncludeAllAff |
All link affinity properties that must be included. |
Created Time |
Time when the tunnel was created. |
display mpls te tunnel path
display mpls te tunnel path [ lsp-id lsr-id lsp-id | tunnel-name tunnel-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
lsr-id: Ingress LSR ID, in dotted decimal notation.
tunnel-name tunnel-name: Tunnel name, a string of 1 to 63 characters.
Use display mpls te tunnel path to display the path or paths that the specified or all MPLS TE tunnels traverse on this node.
# Display the paths that all MPLS TE tunnels traverse.
<Sysname> display mpls te tunnel path
Tunnel Interface Name : Tunnel1
Lsp ID : 1.1.1.9:10
Hop information:
Hop 0: 192.1.1.1;
Hop 1: 12.1.1.2;
Hop 2: 10.202.2.2.
Table 30 Command output
Tunnel Interface Name |
Tunnel interface name. |
Lsp ID |
LSP ID. |
Hop 0 |
Hop 0 on the path. |
Hop 1 |
Hop 1 on the path. |
Hop 2 |
Hop 2 on the path. |
display mpls te tunnel statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display mpls te tunnel statistics to display statistics about MPLS TE tunnels.
# Display statistics about MPLS TE tunnels.
<Sysname> display mpls te tunnel statistics
Ingress: 0 Tunnels, 0 Tunnels Up, 0 CRLSPs Up
0 Modified, 0 In-Progress, 0 Failed
Transit: 0 Up
Egress : 0 Up
Table 31 Command output
Ingress |
This device is the tunnel ingress. |
Transit |
This device is a transit node on the tunnel. |
Egress |
This device is the tunnel egress. |
Modified |
Number of CR-LSP tunnels that use this device as the ingress and are in modified state. |
In-Progress |
Number of CR-LSP tunnels that use this device as the ingress and are in in-progress state. |
Failed |
Number of CR-LSP tunnels that use this device as the ingress and are in failed state. |
display mpls te tunnel-interface [ tunnel number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
tunnel number: Displays information about a tunnel interface.
Use display mpls te tunnel-interface to display information about MPLS TE tunnel interfaces on this node.
# Display information about MPLS TE tunnel interfaces on this node.
<Sysname> display mpls te tunnel-interface
Tunnel Name : Tunnel1
Tunnel Desc : Tunnel1 Interface
Tunnel State Desc : CR-LSP is Up
Tunnel Attributes :
LSP ID : 1.1.1.9:1
Session ID : 10
Admin State : UP Oper State : UP
Ingress LSR ID : 1.1.1.9 Egress LSR ID: 2.2.2.9
Signaling Prot : RSVP Resv Style : FF
Tunnel mode : Co-routed, active
Class Type : CT0 Tunnel BW : 2000 kbps
Reserved BW : 2000 kbps
Setup Priority : 7 Hold Priority: 7
Affinity Prop/Mask : 0/0
Explicit Path Name : -
Tie-Breaking Policy : None
Metric Type : None
Record Route : Disabled Record Label : Disabled
FRR Flag : Disabled BackUpBW Flag: Not Supported
BackUpBW Type : - BackUpBW : -
Route Pinning : Disabled
Retry Limit : 10 Retry Interval: 10
Reopt : Disabled Reopt Freq : -
Back Up Type : None
Back Up LSPID : -
Auto BW : Disabled Auto BW Freq : -
Min BW : - Max BW : -
Current Collected BW: -
Interfaces Protected: -
VPN Bind Type : NONE
VPN Bind Value : -
Car Policy : Disabled
Tunnel Group : Secondary
Primary Tunnel : 120
Backup Tunnel : -
Group Status : -
Table 32 Command output
Tunnel Desc |
Tunnel description. |
Tunnel State Desc |
Tunnel state description. |
Admin State |
Administrative state. |
Oper State |
Operation state. |
Signaling Prot |
Resv Style |
Class Type |
Tunnel BW |
Tunnel bandwidth. |
Reserved BW |
Reserved bandwidth. |
Setup Priority |
Setup priority of LSP. |
Hold Priority |
Hold priority of LSP. |
Affinity Prop/Mask |
Affinity attribute and mask. |
Tie-Breaking Policy |
Path selection policy. |
Record Route |
State of the route recording function. |
Record Label |
State of the label recording function. |
FRR Flag |
Fast reroute (FRR) flag. |
BackUpBW Flag |
Backup bandwidth flag. |
BackUpBW Type |
Backup bandwidth type. |
BackUpBW |
Backup bandwidth. |
Route Pinning |
Route pinning function. |
Retry Limit |
Maximum number of setup retries. |
Retry Interval |
Retry interval. |
Reopt |
State of the reoptimization function. |
Reopt Freq |
Reoptimization interval. |
Back Up Type |
Backup path type. |
Back Up LSPID |
Backup LSP ID. |
Auto BW |
State of the automatic bandwidth adjustment function. |
Auto BW Freq |
Automatic bandwidth adjustment interval. |
Min BW |
Lower limit for automatic bandwidth adjustment. |
Max BW |
Upper limit for automatic bandwidth adjustment . |
Current Collected BW |
Bandwidth information collected. |
Interfaces Protected |
FRR protected interfaces. |
VPN Bind Type |
Type of the binding, VPN or ACL. |
VPN Bind Value |
Value of the binding, the VPN instance name or ACL number. |
Car Policy |
Whether CAR policy is enabled. |
Tunnel Group |
Whether the tunnel is the primary tunnel or backup tunnel in the group. |
Primary Tunnel |
Tunnel ID of the corresponding primary tunnel. Displayed as - for a primary tunnel. |
Backup Tunnel |
Tunnel ID of the corresponding backup tunnel. Displayed as - for a backup tunnel. |
Group Status |
Status of the group. Displayed as - if no protection group is configured. |
display ospf mpls-te
display ospf [ process-id ] mpls-te [ area area-id ] [ self-originated ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
process-id: OSPF process ID in the range of 1 to 65535. If a process is specified, only the TE LSAs of this process are displayed; if no process is specified, the TE LSAs of all processes are displayed.
area area-id: Displays the TE LSAs of a specific OSPF area. The area-id argument takes an integer in the range of 0 to 4294967295 or the form of IPv4 address.
self-originated: Displays self originated TE LSAs.
Use display ospf mpls-te to display TE LSAs in the link state database (LSDB).
# Display all TE LSAs in the LSDB.
<Sysname> display ospf mpls-te
OSPF Process 100 with Router ID 10.0.0.1
Area ID:
Traffic Engineering LSA’s of the database
LSA []
LSA Type : Opq-Area
Opaque Type : 1
Opaque ID :
Advertising Router ID : xxx.xxx.xxx.xxx
LSA Age :
Length :
LSA Options :
LS Seq Number :
CheckSum :
Link Type :Point to Point / Point to Multi Point /MultiAccess
Link ID :
Local Interface Address : xxx.xxx.xxx.xxx
Remote Interface Address : xxx.xxx.xxx.xxx
TE Metric :
Maximum Bandwidth : bytes/sec
Maximum Reservable BW : bytes/sec
Admin Group :
Unreserved BW [ 0] = 0 bytes/sec
Unreserved BW [ 1] = 0 bytes/sec
Unreserved BW [ 2] = 0 bytes/sec
Unreserved BW [ 3] = 0 bytes/sec
Unreserved BW [ 4] = 0 bytes/sec
Unreserved BW [ 5] = 0 bytes/sec
Unreserved BW [ 6] = 0 bytes/sec
Unreserved BW [ 7] = 0 bytes/sec
Unreserved BW [ 8] = 0 bytes/sec
Unreserved BW [ 9] = 0 bytes/sec
Unreserved BW [10] = 0 bytes/sec
Unreserved BW [11] = 0 bytes/sec
Unreserved BW [12] = 0 bytes/sec
Unreserved BW [13] = 0 bytes/sec
Unreserved BW [14] = 0 bytes/sec
Unreserved BW [15] = 0 bytes/sec
BC [ 0] = bytes/sec
BC [ 1] = bytes/sec
Table 33 Command output
Area ID |
TE enabled OSPF area ID. |
LSA Type |
LSA type which must be Opd-Area, carried in the Opaque LSA header. |
Opaque Type |
1 for TE, carried in the header of Opaque LSA. |
Opaque ID |
Opaque ID, carried in the header of Opaque LSA. |
Advertising Router ID |
Router ID of the node where the LSA was generated. |
LSA age |
LSA age, carried in the header of Opaque LSA. |
Length |
LSA length, carried in the header of Opaque LSA. |
LSA Options |
LSA options, carried in the header of Opaque LSA. |
LS Seq Number |
LSA sequence number, carried in the header of Opaque LSA. |
Checksum |
LSA checksum, carried in the header of Opaque LSA. |
Link Type |
Link type: point to point, point to multipoint, or multiAccess. |
Admin Group |
Administrative group attribute. |
Unreserved BW [0] to [15] |
Available bandwidths of the 16 TE classes. |
Bandwidth Constraints |
Bandwidth constraints (only significant for DS-TE LSAs) |
BC 0–1 |
Two types of bandwidth constraints (only significant for DS-TE LSAs): BC0 and BC1. |
display ospf [ process-id ] traffic-adjustment [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use display ospf traffic-adjustment to display the settings of tunnel traffic adjustment (IGP shortcut and forwarding adjacency) for a specific OSPF process or for all OSPF processes.
# Display the settings of tunnel traffic adjustment for all OSPF processes.
<Sysname> display ospf traffic-adjustment
OSPF Process 100 with Router ID 100.0.0.1
Traffic adjustment
Interface: 100.0.0.1 (Tunnel1)
Type: Forwarding Adjacency State: Up
Neighbor ID: 100.0.0.2 Cost: 100
Configuration:
Neighbor Ip Address: 100.0.0.2
Cost : -10
Cost Type : Relative
Hold time : 10s
Table 34 Command output
Tunnel interface address and name. |
Type |
Approach to automatic route advertisement: IGP shortcut or forwarding adjacency. |
Neighbor ID |
Remote neighbor ID. |
State |
State: up or down. |
display tunnel-info
display tunnel-info { tunnel-id | all | statistics } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
tunnel-id: Specifies a tunnel ID in the range of 1 to FFFFFFFE. If a tunnel is specified, only information about this tunnel will be displayed.
all: Display information about all tunnels.
statistics: Displays statistics about tunnels.
Use display tunnel-info to display information about tunnels.
# Display information about all tunnels.
<Sysname> display tunnel-info all
Tunnel ID Type Destination
0x1100002 lsp 2.2.2.2
# Display statistics about tunnels.
<Sysname> display tunnel-info statistics
Tunnel Allocation Method : GLOBAL
Avail Tunnel ID Value : 65535
Total Tunnel ID Allocated : 1
LSP : 1
GRE : 0
CRLSP : 0
LOCAL IFNET : 0
MPLS LOCAL IFNET : 0
Table 35 Command output
Tunnel Allocation Method |
The way that tunnels are allocated. |
Avail Tunnel ID Value |
Available tunnel ID. |
Total Tunnel ID Allocated |
Total number of tunnel IDs that have been allocated. |
LSP |
Number of LSP tunnels. |
GRE |
Number of GRE tunnels. |
CRLSP |
Number of CR-LSP tunnels. |
LOCAL IFNET |
Number of CE-side interfaces in MPLS L2VPN. |
MPLS LOCAL IFNET |
Number of outgoing interfaces in CCC remote mode in MPLS L2VPN. |
undo enable traffic-adjustment
View
OSPF view
Default level
2: System level
None
Use enable traffic-adjustment to enable IGP shortcut.
Use undo enable traffic-adjustment to disable IGP shortcut.
By default, IGP shortcut is disabled.
IGP shortcut allows OSPF to include static LSP tunnels in SPF calculation and advertise them to OSPF neighbors.
# Enable IGP shortcut when the IGP protocol is OSPF.
[Sysname] ospf 100
[Sysname-ospf-100] enable traffic-adjustment
undo enable traffic-adjustment advertise
View
OSPF view
Default level
2: System level
None
Use enable traffic-adjustment advertise to enable forwarding adjacency.
Use undo enable traffic-adjustment advertise to disable forwarding adjacency.
By default, forwarding adjacency is disabled.
Forwarding adjacency allows OSPF to include static LSP tunnels in SPF calculation and flooding.
# Enable forwarding adjacency when the IGP protocol is OSPF.
[Sysname] ospf 100
[Sysname-ospf-100] enable traffic-adjustment advertise
explicit-path
explicit-path path-name [ disable | enable ]
undo explicit-path path-name
View
Default level
2: System level
path-name: Name of an explicit path for a tunnel, a string of 1 to 31 characters.
disable: Disables explicit routing.
enable: Enables explicit routing.
Use explicit-path to create an explicit path and enter its view.
Use undo explicit-path to remove an explicit path.
# Create an explicit path named path1 and enter its view.
list hop
list hop [ ip-address ]
View
Explicit path view
Default level
2: System level
ip-address: Specifies the IP address of a node on the explicit path. If no IP address is specified, this command displays information about all the nodes on the explicit path.
Use list hop to display information about a node or all nodes on the explicit path.
# Display information about all nodes on an MPLS TE explicit path.
[Sysname-explicit-path-path1] list hop
Path Name : path1 Path Status : Enabled
1 1.1.1.9 Strict Include
2 2.2.2.9 Strict Exclude
modify hop
modify hop ip-address1 ip-address2 [ include [ loose | strict ] | exclude ]
View
Explicit path view
Default level
2: System level
ip-address1 ip-address2: Substitutes the IP address specified by the ip-address2 argument for the IP address specified by the ip-address1 argument in the explicit path. The specified IP addresses could be link IP addresses or router IDs of nodes.
include: Includes the node ip-address2 on the explicit path.
loose: Specifies the node ip-address2 as a loose node, which means that ip-address2 and its previous hop can be connected indirectly.
strict: Specifies the node ip-address2 as a strict node, which means that ip-address2 and its previous hop must be connected directly.
exclude: Excludes the node ip-address2 from path calculations for the explicit path.
Use modify hop to change a node on the explicit path, including the node’s IP address and other attributes (include or exclude, strict or loose).
· If you specify neither include nor exclude, the include keyword is used by default.
· If you specify neither loose nor strict, the strict keyword is used by default.
# Replace IP address 10.0.0.125 with IP address 10.0.0.200 for the explicit path path1 and exclude this new IP address from path calculations.
[Sysname] explicit-path path1
[Sysname-explicit-path-path1] modify hop 10.0.0.125 10.0.0.200 exclude
mpls rsvp-te
mpls rsvp-te
undo mpls rsvp-te
View
MPLS view, interface view
Default level
2: System level
None
Use mpls rsvp-te to enable RSVP-TE.
Use undo mpls rsvp-te to disable RSVP-TE.
By default, RSVP-TE is disabled.
You must enable RSVP-TE before you can configure other RSVP-TE features.
Before enabling RSVP-TE in MPLS view on a node, enable MPLS in system view and MPLS TE in MPLS view.
Before enabling RSVP-TE in interface view, enable MPLS and MPLS TE in interface view.
Disabling RSVP-TE in MPLS view disables RSVP-TE on interfaces.
# Enable RSVP-TE on current node.
[Sysname] mpls
[Sysname-mpls] mpls te
[Sysname-mpls] mpls rsvp-te
# Enable RSVP-TE on VLAN-interface 1.
[Sysname-Vlan-interface1] mpls
[Sysname-Vlan-interface1] mpls te
[Sysname-Vlan-interface1] mpls rsvp-te
mpls rsvp-te authentication
mpls rsvp-te authentication { cipher | plain } auth-key
undo mpls rsvp-te authentication
View
Interface view
Default level
2: System level
cipher: Specifies a ciphertext key. This key will be displayed in cipher text.
plain: Specifies a plaintext key. This key will be displayed in cipher text.
auth-key: Specifies the key string. This argument is case sensitive. If the cipher keyword is specified, it must be a ciphertext string of 8 to 53 characters. If the plain keyword is specified, it is a plaintext string of 8 to 16 characters.
Use mpls rsvp-te authentication to enable RSVP authentication on the interface.
Use undo mpls rsvp-te authentication to disable RSVP authentication on the interface.
By default, RSVP authentication is disabled.
The RSVP messages sent out of the interface convey a message authentication digest created using the hash algorithm and the configured authentication key. This authentication key is also used by the interface to authenticate received RSVP messages. For the two interfaces at the two ends of a link to exchange RSVP messages, they must share the same authentication key.
This hop-by-hop authentication of RSVP prevents fake resource reservation requests from occupying network resources.
# Enable RSVP authentication on VLAN-interface 1, and configure a plaintext the authentication key of userkey1.
[Sysname-Vlan-interface1] mpls rsvp-te authentication plain userkey1
mpls rsvp-te bfd enable
undo mpls rsvp-te bfd enable
View
Interface view
Default level
2: System level
None
Use mpls rsvp-te bfd enable on an RSVP-TE enabled interface to enable BFD for link detection.
Use undo mpls rsvp-te bfd enable to disable BFD on an RSVP-TE enabled interface.
By default, BFD for link detection is not enabled on an RSVP-TE enabled interface.
Before enabling BFD for link detection on an interface, make sure that the interface is enabled with RSVP-TE.
# Enable BFD link detection on RSVP-TE enabled interface VLAN-interface 100.
[Sysname-Vlan-interface100] mpls rsvp-te bfd enable
mpls rsvp-te blockade-multiplier
mpls rsvp-te blockade-multiplier number
undo mpls rsvp-te blockade-multiplier
View
MPLS view
Default level
2: System level
number: Blockade multiplier in the range of 3 to 255.
Use mpls rsvp-te blockade-multiplier to configure the blockade multiplier, which determines the timeout time of blockade state.
Use undo mpls rsvp-te blockade-multiplier to restore the default.
The default blockade multiplier is 4.
Sometimes, although a reservation request does not pass admission control on some node, you might want to store the resource reservation state for it while allowing other requests to use the resources reserved for the request. In this case, the node transits to the blockade state and a blockade state block (BSB) is created on each downstream node. When the number of non-refreshing times exceeds the blockade multiplier, the blockade state is removed. The blockade state timeout time is blockade multiplier × refresh-time. The refresh time is the refresh interval of the path/reservation messages.
Enable RSVP-TE before configuring this command.
Related commands: mpls rsvp-te timer refresh.
# Set the blockade multiplier to 5.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te blockade-multiplier 5
mpls rsvp-te graceful-restart
undo mpls rsvp-te graceful-restart
View
MPLS view
Default level
2: System level
None
Use mpls rsvp-te graceful-restart to enable the GR capability for MPLS RSVP-TE.
Use undo mpls rsvp-te graceful-restart to disable MPLS RSVP-TE GR.
By default, GR capability is disabled for MPLS RSVP-TE.
Enable RSVP-TE hello extension before enabling RSVP-TE GR.
# Enable MPLS RSVP-TE GR.
[Sysname] mpls lsr-id 1.1.1.1
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te hello
[Sysname-mpls] mpls rsvp-te graceful-restart
mpls rsvp-te hello
mpls rsvp-te hello
undo mpls rsvp-te hello
View
Default level
2: System level
None
Use mpls rsvp-te hello to enable RSVP hello extension.
Use undo mpls rsvp-te hello to disable RSVP hello extension.
By default, RSVP hello extension is disabled.
RSVP-TE uses the hello extension mechanism to check the reachability of an RSVP neighbor.
Before you enable RSVP hello extension in interface view, enable RSVP-TE in interface view and RSVP hello extension in MPLS view.
# Enable RSVP hello extension in MPLS view.
[Sysname] mpls
# Enable RSVP hello extension on VLAN-interface 1.
[Sysname-Vlan-interface1] mpls rsvp-te hello
mpls rsvp-te hello-lost
mpls rsvp-te hello-lost times
undo mpls rsvp-te hello-lost
View
MPLS view
Default level
2: System level
times: Maximum number of consecutive hello losses before an RSVP neighbor is considered dead, in the range of 3 to 10.
Use mpls rsvp-te hello-lost to configure the maximum number of consecutive hello losses before an RSVP neighbor is considered dead.
Use undo mpls rsvp-te hello-lost to restore the default.
By default, the RSVP node considers an RSVP neighbor to be dead if no response is received after sending three consecutive hellos.
An RSVP node detects whether its RSVP neighbor is still alive by sending hellos regularly. If no response is received after the number of consecutive hellos reaches the specified limit, the RSVP node considers its RSVP neighbor as dead. The failure is handled the same as a link layer communication failure.
Before configuring this command, enable RSVP-TE and RSVP hello extension in MPLS view.
Related commands: mpls rsvp-te timer hello.
# Set the maximum number of consecutive hello losses allowed on a node to 5.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te hello-lost 5
mpls rsvp-te keep-multiplier
mpls rsvp-te keep-multiplier number
undo mpls rsvp-te keep-multiplier
View
MPLS view
Default level
2: System level
number: Keep multiplier in the range of 3 to 255.
Use mpls rsvp-te keep-multiplier to configure the keep multiplier, which determines the timeout time of the path state block (PSB) and reservation state block (RSB).
Use undo mpls rsvp-te keep-multiplier to restore default.
The default keep multiplier is 3.
The PSB and RSB timeout time is (keep-multiplier + 0.5) × 1.5 × refresh-time.
Before you configure the keep multiplier, enable RSVP-TE.
# Set the keep multiplier for PSB and RSB to 5.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te keep-multiplier 5
mpls rsvp-te reliability
undo mpls rsvp-te reliability
View
Interface view
Default level
2: System level
None
Use mpls rsvp-te reliability to enable the RSVP reliability mechanism.
Use undo mpls rsvp-te reliability to disable the RSVP reliability mechanism.
By default, the RSVP reliability mechanism is disabled.
With RSVP reliability enabled, the switch adds objects Message_ID and Message_ID_ACK into the outgoing RSVP messages. The objects will be used for RSVP message acknowledgment to improve reliability.
# Enable the RSVP reliability mechanism on VLAN-interface 1.
[Sysname-Vlan-interface1] mpls rsvp-te reliability
mpls rsvp-te resvconfirm
undo mpls rsvp-te resvconfirm
View
MPLS view
Default level
2: System level
None
Use mpls rsvp-te resvconfirm to enable reservation confirmation on the current node.
Use undo mpls rsvp-te resvconfirm to disable reservation confirmation.
By default, resource reservation confirmation is disabled.
When the reservation confirmation mechanism is enabled on a node, a Resv message sent by the node carries an object that requires reservation confirmation. The node that receives the Resv message must send back a ResvConf message to confirm the reservation.
# Enable reservation confirmation on your device.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te resvconfirm
mpls rsvp-te srefresh
undo mpls rsvp-te srefresh
View
Interface view
Default level
2: System level
None
Use mpls rsvp-te srefresh to enable summary refresh.
Use undo mpls rsvp-te srefresh to restore the default.
By default, summary refresh is disabled.
Summary refresh (Srefresh) messages refresh path state and reservation state. Enabling summary refresh disables conventional time-driven state refresh.
# Enable summary refresh on VLAN-interface 1.
[Sysname-Vlan-interface1] mpls rsvp-te srefresh
mpls rsvp-te timer graceful-restart recovery
mpls rsvp-te timer graceful-restart recovery recovery-time
undo mpls rsvp-te timer graceful-restart recovery
View
MPLS view
Default level
2: System level
recovery-time: RSVP-TE GR recovery interval in seconds, in the range of 60 to 300.
Use mpls rsvp-te timer graceful-restart recovery to set the RSVP-TE GR recovery interval.
Use undo mpls rsvp-te timer graceful-restart recovery to restore the default.
By default, the RSVP-TE GR recovery interval is 300 seconds.
Before using this command, enable the GR capability for MPLS RSVP-TE.
# Set the RSVP-TE GR recovery interval to 100 seconds.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer graceful-restart recovery 100
mpls rsvp-te timer graceful-restart restart
mpls rsvp-te timer graceful-restart restart restart-time
undo mpls rsvp-te timer graceful-restart restart
View
MPLS view
Default level
2: System level
restart-time: RSVP-TE GR restart interval in seconds, in the range of 60 to 300.
Use mpls rsvp-te timer graceful-restart restart to set the RSVP-TE GR restart interval.
Use undo mpls rsvp-te timer graceful-restart restart to restore the default.
By default, the RSVP-TE GR restart interval is 120 seconds.
Before using this command, be sure to enable the GR capability for MPLS RSVP-TE.
# Set the RSVP-TE GR restart interval to 200 seconds.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer graceful-restart restart 200
mpls rsvp-te timer hello timevalue
undo mpls rsvp-te timer hello
View
MPLS view
Default level
2: System level
timevalue: Hello interval in the range of 1 to 60 seconds.
Use mpls rsvp-te timer hello to configure the hello interval.
Use undo mpls rsvp-te timer hello to restore the default.
The default hello interval is three seconds.
Before configuring this command, enable the hello mechanism in MPLS view.
Related commands: mpls rsvp-te hello and mpls rsvp-te hello-lost.
# Set the hello interval to 5 seconds.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer hello 5
mpls rsvp-te timer refresh timevalue
undo mpls rsvp-te timer refresh
View
MPLS view
Default level
2: System level
timevalue: Refresh interval in the range of 10 to 65535 seconds.
Use mpls rsvp-te timer refresh to configure the path/reservation state refresh interval.
Use undo mpls rsvp-te timer refresh to restore the default.
The default path/reservation state refresh interval is 30 seconds.
Related commands: mpls rsvp-te keep-multiplier.
# Set the path/reservation state refresh interval to 60 seconds.
[Sysname] mpls
[Sysname-mpls] mpls rsvp-te timer refresh 60
mpls rsvp-te timer retransmission
mpls rsvp-te timer retransmission { increment-value [ increment-value ] | retransmit-value [ retrans-timer-value ] } *
undo mpls rsvp-te timer retransmission
View
Interface view
Default level
2: System level
increment-value increment-value: Increment value delta in the range of 1 to 10. The default is 1.
retransmit-value retrans-timer-value: Initial retransmission interval in the range of 500 to 3000 milliseconds. The default is 500 milliseconds.
Use mpls rsvp-te timer retransmission to enable RSVP message retransmission.
Use undo mpls rsvp-te timer retransmission to restore the default.
By default, RSVP message retransmission is disabled.
If a node sends a message carrying the Message_ID object, and the ACK_Desired flag in the object is set, the node expects a response that carries the Message_ID_ACK object during the initial retransmission interval (Rf). If the node does not receive the response within the Rf interval, it resends the message and sets the retransmission interval to (1+Delta) × Rf. The node repeats such retransmissions until it receives the corresponding response within the retransmission time or the number of retransmission attempts reaches the limit.
The initial value of the retransmission time is specified by retrans-timer-value, and the delta value is specified by increment-value in this command.
# Enable RSVP message retransmission on VLAN-interface 1, setting the increment value delta to 2 and the initial retransmission interval to 1000 milliseconds.
[Sysname-Vlan-interface1] mpls rsvp-te timer retransmission increment-value 2 retransmit-value 1000
mpls te
mpls te
undo mpls te
View
Default level
2: System level
None
Use mpls te to enable MPLS TE.
Use undo mpls te to disable MPLS TE.
By default, MPLS TE is disabled.
When performed in MPLS view, the mpls te command enables MPLS TE globally and its undo form disables MPLS TE and removes all CR-LSPs.
When performed in interface view, the mpls te command enables MPLS TE on an interface and its undo form disables MPLS TE and removes all CR-LSPs on the interface.
Enable MPLS TE globally before you enable MPLS TE on an interface.
CAUTION: After changing the MTU of an interface where MPLS TE is enabled, perform the shutdown command and then the undo shutdown command to refresh the TE tunnels on it. |
# Enable MPLS TE globally in MPLS view.
[Sysname] mpls lsr-id 1.1.1.9
[Sysname] mpls
# Enable MPLS TE on VLAN-interface 1.
mpls te affinity property
mpls te affinity property properties [ mask mask-value ]
undo mpls te affinity property
View
Tunnel interface view
Default level
2: System level
properties: Link properties affinity attribute of the tunnel, a 32-bit integer in the range of 0x0 to 0xFFFFFFFF. Each affinity bit represents a property with a value of 1 or 0.
mask-value: 32-bit mask comprising 0s and 1s, in the range of 0x0 to 0xFFFFFFFF. This mask is used when ANDing the link affinity attribute with the link administrative group attribute. The affinity bits corresponding to the 1s in the mask are "do care" bits which must be considered; those corresponding to the 0s in the mask are "don't care" bits.
Use mpls te affinity property to configure the link affinity attribute of the tunnel.
Use undo mpls te affinity property to restore the default.
The default affinity attribute of the tunnel is 0x00000000 and the mask is 0x00000000.
The affinity attribute of an MPLS TE tunnel identifies the properties of the links that the tunnel can use.
Related commands: mpls te link administrative group.
# Configure the link affinity attribute of tunnel 1.
[Sysname] interface tunnel 1
[Sysname-Tunnel1] mpls te affinity property 101 mask 303
mpls te backup
mpls te backup { hot-standby | ordinary }
undo mpls te backup
View
Default level
2: System level
hot-standby: Sets the tunnel backup mode to hot backup. In this mode, a backup CR-LSP is established immediately after the primary CR-LSP is established. When the primary CR-LSP fails, MPLS TE immediately switches services to the backup CR-LSP.
ordinary: Sets the tunnel backup mode to ordinary backup. In this mode, a backup CR-LSP is established only when the primary CR-LSP fails.
Use mpls te backup to enable specified backup mode for the current tunnel.
Use undo mpls te backup to restore the default.
By default, tunnel backup is disabled.
NOTE: · With backup enabled, the record route flag is automatically set to record reroute regardless of whether the mpls te record-route command is configured. · The mpls te backup command cannot be used together with these commands: mpls te reoptimization, and mpls te resv-style ff. |
# Enable hot backup for Tunnel1.
[Sysname-Tunnel1] mpls te backup hot-standby
mpls te backup bandwidth
mpls te backup bandwidth { bandwidth | { ct0 | ct1 | ct2 | ct3 } { bandwidth | un-limited } }
undo mpls te backup bandwidth
View
Default level
2: System level
bandwidth: Total bandwidth that the bypass tunnel can protect, in the range of 1 to 32000000 kbps.
ct0: Indicates that only the LSPs of CT 0 can use the bypass tunnel.
ct1: Indicates that only the LSPs of CT 1 can use the bypass tunnel.
ct2: Indicates that only the LSPs of CT 2 can use the bypass tunnel.
ct3: Indicates that only the LSPs of CT 3 can use the bypass tunnel.
un-limited: Puts on limit on total protected bandwidth.
Use mpls te backup bandwidth to configure the total bandwidth and type of LSP that the bypass tunnel can protect.
Use undo mpls te backup bandwidth to remove the configuration.
By default, bypass tunnels do not protect bandwidth.
If no CT is specified, all LSPs can use the bypass tunnel.
The bandwidth value specified with this command is used for only calculating and determining the bandwidth protection relationship. No bandwidth will be reserved in the bypass tunnel.
The specified bandwidth value must be less than the actual bandwidth of the bypass tunnel. Otherwise, the bypass tunnel might be overwhelmed after FRR switchover, causing the protected tunnel to be torn down.
# Configure Tunnel1 to provide protection for LSPs of CT 0 without constraining the bandwidth to be protected. Configure Tunnel2 to provide protection for LSPs of CT 1 and protect up to 1000 kbps bandwidth.
[Sysname] interface Tunnel 1
[Sysname-Tunnel1] mpls te backup bandwidth ct0 un-limited
[Sysname-Tunnel1] quit
[Sysname] interface tunnel 2
[Sysname-Tunnel2] mpls te backup bandwidth ct1 1000
mpls te bandwidth change thresholds
mpls te bandwidth change thresholds { down | up } percent
undo mpls te bandwidth change thresholds { down | up }
View
Interface view
Default level
2: System level
down: Sets the threshold in percentages for IGP to flood when the bandwidth is decreasing. When the percentage of available bandwidth decrease exceeds the threshold, the change is flooded and the traffic engineering database (TEDB) is updated.
up: Sets the IGP flooding threshold in percentages that applies when the bandwidth is increasing. When the percentage of available bandwidth increase exceeds the threshold, the change is flooded and the TEDB is updated.
percent: IGP flooding threshold in percentages, in the range of 0 to 100.
Use mpls te bandwidth change thresholds to set the IGP flooding thresholds that apply when bandwidth resources are increasing and decreasing.
Use undo mpls te bandwidth change thresholds to restore the default.
The default IGP flooding thresholds in both up and down directions are 10.
# On VLAN-interface 1 configure IGP to flood when the percentage of available bandwidth decrease reaches 100%.
[Sysname-Vlan-interface1] mpls te bandwidth change thresholds down 100
mpls te bfd enable
mpls te bfd enable [ discriminator local local-id remote remote-id ]
undo mpls te bfd enable
View
Default level
2: System level
discriminator: Specifies the discriminator values of the BFD session.
local local-id: Specifies the local discriminator value of the BFD session, in the range of 1 to 512.
remote remote-id: Specifies the remote discriminator value of the BFD session, in the range of 1 to 4294967295.
Use mpls te bfd enable to configure BFD to check the connectivity of the MPLS TE tunnel.
Use undo mpls te bfd enable to disable BFD for the MPLS TE tunnel of a TE tunnel interface.
By default, BFD is not configured for MPLS TE tunnels.
Enable LSP verification by using the mpls lspv command first before executing the mpls te bfd enable command. For details of the mpls lspv command, see "Basic MPLS commands."
BFD session parameters are those configured on the TE tunnel interface. The source address of the BFD session is the MPLS LSR ID. Before enabling BFD for an MPLS TE tunnel, make sure that a route is available on the peer device to the MPLS LSR ID. You can also configure the BFD session parameters on the tunnel interface as needed. For information about BFD parameter configuration, see High Availability Configuration Guide.
# Enable BFD for the MPLS TE tunnel on tunnel interface Tunnel1.
[Sysname-Tunnel1] mpls te bfd enable
mpls te commit
mpls te commit
View
Default level
2: System level
None
Use mpls te commit to submit current MPLS TE tunnel configuration.
The MPLS TE tunnel configuration you made can take effect only after you perform this command.
# Configure an MPLS TE tunnel and submit the configuration.
[Sysname-Tunnel1] tunnel-protocol mpls te
[Sysname-Tunnel1] destination 2.2.2.9
[Sysname-Tunnel1] mpls te commit
mpls te cspf
mpls te cspf
undo mpls te cspf
View
MPLS view
Default level
2: System level
None
Use mpls te cspf to enable CSPF.
Use undo mpls te cspf to disable CSPF.
By default, CSPF is disabled.
Before enabling CSPF, enable MPLS TE in MPLS view.
CSPF provides a method to path selection in MPLS domains. You must enable CSPF to establish an MPLS TE tunnel through dynamic signaling.
You must enable CSPF before configuring other CSPF related functions.
# Enable CSPF on the current node.
[Sysname] mpls
[Sysname-mpls] mpls te cspf
mpls te cspf timer failed-link
mpls te cspf timer failed-link timer-interval
undo mpls te cspf timer failed-link
View
MPLS view
Default level
2: System level
timer-interval: Value of the failed link timer, in the range of 0 to 300 seconds. The default is 10 seconds.
Use mpls te cspf timer failed-link to configure the failed link timer.
Use undo mpls te cspf timer failed-link to restore the default.
By default, the failed link timer is 10 seconds.
The failed link timer starts once a link goes down. If the IGP removes or modifies the link before the timer expires, CSPF updates information about the link in TEDB and stops the timer. If the IGP does not remove or modify the link before the timer expires, the state of the link in TEDB will change to up.
Related commands: mpls te cspf.
# Set the failed link timer to 50 seconds.
[Sysname] mpls
[Sysname-mpls] mpls te cspf timer failed-link 50
mpls te failure-action teardown
undo mpls te failure-action teardown
View
Default level
2: System level
None
Use mpls te failure-action teardown to enable the capability of tearing down a failed RSVP TE tunnel and then re-establishing it.
Use undo mpls te failure-action teardown to disable the capability.
By default, this capability is disabled.
With this capability configured, after BFD or periodic LSP tracert detects a failure of an RSVP-TE tunnel, if RSVP does not re-establish the RSVP-TE tunnel within a specific period of time, MPLS TE will remove the tunnel and re-establish it.
# On tunnel interface Tunnel1, enable the capability of tearing down a failed MPLS TE tunnel and then re-establishing the tunnel.
[Sysname-Tunnel1] mpls te failure-action teardown
mpls te fast-reroute
undo mpls te fast-reroute
View
Default level
2: System level
None
Use mpls te fast-reroute to enable fast reroute (FRR).
Use undo mpls te fast-reroute to disable FRR.
By default, FRR is disabled.
After FRR is enabled, the record route flag is automatically set to record reroute with label, whether the mpls te record-route label command is configured or not.
Disable FRR before configuring the mpls te record-route command or its undo form.
NOTE: Fast reroute cannot be used together with the mpls te resv-style ff command. |
# Enable FRR for MPLS TE tunnel interface Tunnel1, so the MPLS TE tunnel uses an available bypass tunnel in case the protected link or node that it traverses fails.
[Sysname-Tunnel1] mpls te fast-reroute
mpls te fast-reroute bypass-tunnel
mpls te fast-reroute bypass-tunnel tunnel tunnel-number
undo mpls te fast-reroute bypass-tunnel tunnel tunnel-number
View
Interface view
Default level
2: System level
tunnel tunnel-number: Specifies a bypass tunnel by its tunnel number.
Use mpls te fast-reroute bypass-tunnel to specify a bypass tunnel for the protected interface.
Use undo mpls te fast-reroute bypass-tunnel to remove the specified bypass tunnel.
You can specify multiple bypass tunnels for the protected interface. A maximum of three bypass tunnels can be specified for a protected interface.
When specifying a bypass tunnel, consider the following:
· The state of the tunnel must be up.
· The protected interface is not the outgoing interface in the route entries for the LSP of the bypass tunnel.
NOTE: A bypass tunnel cannot be used for services like VPN. |
# Use tunnel interface Tunnel1 as the bypass tunnel to protect the link connected to VLAN-interface 1.
[Sysname-Vlan-interface1] mpls te fast-reroute bypass-tunnel tunnel 1
mpls te igp advertise
mpls te igp advertise [ hold-time value ]
undo mpls te igp advertise
View
Default level
2: System level
hold-time value: Sets the delay that IGP waits to notify IGP neighbors of the down event of the TE tunnel. It is in the range of 0 to 4294967295 milliseconds. The default is 0 milliseconds.
Use mpls te igp advertise to enable IGP to advertise the MPLS TE tunnel as a link to IGP neighbors.
Use undo mpls te igp advertise to remove the configuration.
By default, IGP does not advertise MPLS TE tunnels to IGP neighbors.
NOTE: The mpls te igp advertise command cannot be used together with the mpls te igp shortcut command. |
# Set the hold time to 10000 milliseconds.
[Sysname-Tunnel1] mpls te igp advertise hold-time 10000
mpls te igp metric
mpls te igp metric { absolute value | relative value }
undo mpls te igp metric
View
Default level
2: System level
absolute value: Assigns an absolute metric to the TE tunnel for path calculation. The value argument takes an integer in the range of 1 to 65535. This value is directly used for path calculation.
relative value: Assigns a relative metric to the TE tunnel for path calculation. The value argument takes an integer in the range of –10 to +10. The default is 0. The cost of the corresponding IGP path must be added to this relative metric before it can be used for path calculation.
Use mpls te igp metric to assign a metric to the MPLS TE tunnel.
Use undo mpls te igp metric to restore the default.
By default, TE tunnels take their IGP metrics.
You can configure a metric, either absolute or relative, for a tunnel to be used as an IGP shortcut or a forwarding adjacency. If it is absolute, the metric is directly used for path calculation. If it is relative, the cost of the corresponding IGP path must be added to the metric for path calculation.
# Assign TE tunnel Tunnel1 a relative metric of –1 for path calculation in IGP shortcut or forwarding adjacency mechanism.
[Sysname-Tunnel1] mpls te igp metric relative -1
mpls te igp shortcut [ isis | ospf ]
undo mpls te igp shortcut
View
Default level
2: System level
isis: Sets the IGP protocol to IS-IS.
ospf: Sets the IGP protocol to OSPF.
Use mpls te igp shortcut to enable IS-IS or OSPF to consider the MPLS TE tunnel in its enhanced SPF calculation when the tunnel is up. If no IGP protocol is specified, the command applies to both OSPF and IS-IS.
Use undo mpls te igp shortcut to restore the default.
By default, IGP does not consider MPLS TE tunnels in its enhanced SPF calculation.
NOTE: The mpls te igp shortcut command cannot be used together with the mpls te igp advertise command. |
# Enable OSPF and IS-IS to consider TE tunnel Tunnel1 in enhanced SPF calculation when the tunnel is up.
[Sysname-Tunnel1] mpls te igp shortcut
mpls te link administrative group value
undo mpls te link administrative group
View
Interface view
Default level
2: System level
value: Link administrative group attribute, in the range of 0x00000000 to 0xFFFFFFFF. It is a set of 32 link properties. Each bit represents a property with a value of 0 or 1. By ANDing the administrative group attribute bits with the corresponding link affinity attribute bits of an MPLS TE tunnel, MPLS TE identifies the properties of the links that the MPLS TE tunnel can use.
Use mpls te link administrative group to configure the link administrative group attribute.
Use undo mpls te link administrative group to restore the default.
The default link administrative group attribute is 0x00000000.
The interface properties are propagated globally and are used for path selection at the tunnel ingress.
Related commands: mpls te affinity property.
# Assign VLAN-interface 1 the link administrative group attribute of 0x00000101.
[Sysname-Vlan-interface1] mpls te link administrative group 101
mpls te loop-detection
undo mpls te loop-detection
View
Default level
2: System level
None
Use mpls te loop-detection to configure the node to perform loop detection when setting up the MPLS TE tunnel.
Use undo mpls te loop-detection to disable loop detection.
By default, a node does not perform loop detection when setting up a tunnel.
# Configure the node to perform loop detection when setting up TE tunnel Tunnel1.
[Sysname-Tunnel1] mpls te loop-detection
mpls te metric
mpls te metric value
undo mpls te metric
View
Interface view
Default level
2: System level
value: TE metric of the link, in the range of 0 to 4294967295.
Use mpls te metric to assign a TE metric to the link.
Use undo mpls te metric to restore the default.
By default, the link uses its IGP metric as its TE metric.
Related commands: mpls te path metric-type.
# Assign a TE metric of 20 to the link on VLAN-interface 1.
[Sysname-Vlan-interface1] mpls te metric 20
mpls te path
mpls te path { dynamic | explicit-path path-name } preference value
undo mpls te path { dynamic | explicit-path path-name }
View
Default level
2: System level
dynamic: Uses the path that is dynamically calculated.
explicit-path path-name: Uses an existing explicit path. The pathname argument is a case-insensitive string of 1 to 31 characters.
preference value: Specifies the preference of the path. The value argument is in the range of 1 to 10. A smaller value represents a higher preference.
Use mpls te path to specify a path for the tunnel to use and set the preference of the path.
Use undo mpls te path to remove a path used by the tunnel.
By default, a tunnel uses the dynamically calculated path.
Up to 10 paths can be specified for an MPLS TE tunnel.
The paths for a tunnel to use must have different preferences.
A path with the highest preference is preferred for CSPF calculation.
# Configure interface Tunnel1 to use the explicit path path1 and the dynamically calculated path, setting the preferences of the paths to 1 and 2, respectively.
[Sysname-Tunnel1] mpls te path explicit-path path1 preference 1
[Sysname-Tunnel1] mpls te path dynamic preference 2
mpls te path metric-type { igp | te }
undo mpls te path metric-type
View
MPLS view, tunnel interface view
Default level
2: System level
igp: Uses the IGP metric for tunnel path calculation.
te: Uses the TE metric for tunnel path calculation.
Use mpls te path metric-type in MPLS view to specify the link metric type for tunnel path calculation when a metric type was not explicitly configured for a tunnel.
Use mpls te path metric-type in tunnel interface view to specify the link metric type to be used for path calculation of the current tunnel.
Use undo mpls te path metric-type to restore the default. This undo form is only available in tunnel interface view.
In MPLS view, TE metrics of links are used in path calculation for TE tunnels by default.
In tunnel interface view, no link metric type is specified for path calculation by default.
NOTE: A tunnel prefers the link metric type specified in the tunnel interface view. If no link metric type is specified in tunnel interface view, the configuration in MPLS view is used. |
Related commands: mpls te metric.
In MPLS view:
# Configure TE tunnels that were not explicitly specified with a metric type to use the IGP metric for path calculation.
[Sysname] mpls
[Sysname-mpls] mpls te path metric-type igp
In tunnel interface view:
# Configure Tunnel1 to use the IGP metric for path calculation.
[Sysname-Tunnel1] mpls te path metric-type igp
mpls te periodic-tracert
mpls te periodic-tracert [ -a source-ip | -exp exp-value | -h ttl-value | -m wait-time | -t time-out | -u retry-attempt ] *
undo mpls te periodic-tracert
View
Default level
2: System level
-a source-ip: Specifies the source IP address of MPLS Echo Request messages. By default, the MPLS LSR ID is used as the source address of MPLS Echo Request messages.
-exp exp-value: Specifies the EXP value of the label. exp-value is in the range of 0 to 7 and defaults to 0.
-h ttl-value: Specifies the TTL value to be carried by an MPLS Echo Request message. ttl-number is in the range of 1 to 255 and defaults to 30.
-m wait-time: Specifies the interval for performing LSP tracert. wait-time is in the range of 15 to 120 and defaults to 60, in minutes.
-t time-out: Specifies the timeout time for waiting for the response of an MPLS Echo Request message. time-out is in the range of 0 to 65535 and defaults to 2000, in milliseconds.
-u retry-attempt: Specifies the maximum number of times that MPLS Echo Request messages can be sent if no response is received. retry-attempt is in the range of 1 to 9 and defaults to 3.
Use mpls te periodic-tracert to enable periodic LSP tracert for the MPLS TE tunnels on a tunnel interface.
Use undo mpls te periodic-tracert to disable periodic LSP tracert for MPLS TE tunnels on a tunnel interface.
By default, periodic LSP tracert is disabled for MPLS TE tunnels.
The periodic LSP tracert function for an MPLS TE tunnel is for locating faults of the MPLS TE tunnel periodically. It detects the consistency of the forwarding and control plane and records detection results into logs. You can know whether an MPLS TE tunnel has failed by checking the logs.
If you configure BFD as well as periodical tracert for an MPLS TE tunnel, once the tracert function detects a data plane failure or an inconsistency between the data plane and control plane, the existing BFD session is deleted and a new BFD session is then re-established based on the control plane.
Enable LSP verification by using the mpls lspv command before executing the mpls te periodic-tracert command.
# Enable periodic LSP tracert for the MPLS TE tunnels on tunnel interface Tunnel1.
[Sysname-Tunnel1] mpls te periodic-tracert
mpls te priority
mpls te priority setup-priority [ hold-priority ]
undo mpls te priority
View
Default level
2: System level
setup-priority: Setup priority of the tunnel, in the range of 0 to 7. A lower numerical number represents a higher priority.
hold-priority: Holding priority of the tunnel, in the range of 0 to 7. A lower numerical number represents a higher priority. If not configured, it is the same as the setup priority.
Use mpls te priority to assign a setup priority and holding priority to the MPLS TE tunnel.
Use undo mpls te priority to restore the default.
By default, both setup and holding priorities of TE tunnels are 7.
To avoid flapping caused by improper preemptions between TE tunnels, the setup priority of an MPLS TE tunnel should not be set higher than its holding priority.
# Set the setup and holding priorities to 1 for Tunnel1.
[Sysname-Tunnel1] mpls te priority 1
mpls te protection tunnel tunnel-id [ holdoff holdoff-time | mode { non-revertive | revertive [ wtr wtr-time ] } ] *
undo mpls te protection tunnel
View
Default level
2: System level
tunnel-id: ID of the tunnel to be specified as the protection tunnel.
holdoff holdoff-time: Specifies the switching delay time. After detecting that the main tunnel fails, the switch will not switch data to the protection tunnel immediately but wait for a period of time (the holdoff time). If the protection tunnel keeps in no-defect state during this period of time, the switch will switch data to the protection tunnel. The holdoff-time is the holdoff time factor in the range of 0 to 20, and the default is to 0. Holdoff time = holdoff time factor × 500 milliseconds. Therefore, the maximum holdoff time is 10 seconds.
mode: Specifies the reverting mode, non-revertive or revertive. The default reverting mode is revertive.
non-revertive: Specifies the non-revertive mode, where data will not be switched back from the protection tunnel to the main tunnel even if the main tunnel recovers.
revertive: Specifies the revertive mode, where data will be switched back from the protection tunnel to the main tunnel when the main tunnel recovers.
wtr wtr-time: Specifies the reverting delay time, or, the time to wait before switching back to the main tunnel. wtr-time is the WTR time factor, which is in the range of 0 to 60 and defaults to 24. WTR time = WTR time factor × 30 seconds. Therefore, the default WTR time is 12 minutes.
Use mpls te protection tunnel to configure a protection tunnel for the main tunnel. The main tunnel and its protection tunnel (also called "backup tunnel") form a tunnel protection group.
Use undo mpls te protection tunnel to remove the protection tunnel of a main tunnel.
By default, no protection tunnel is configured for the main tunnel.
Before configuring the mpls te protection tunnel command, execute the tunnel-protocol mpls te command in tunnel interface view.
The configured protection tunnel takes effect only after you execute the mpls te commit command in the tunnel interface view.
Because the bypass tunnel configured in TE FRR cannot be applied in VPN applications, do not configure a protection tunnel for the bypass tunnel of TE FRR.
# Configure a protection tunnel for tunnel 1.
[Sysname-Tunnel1] mpls te protection tunnel 102 holdoff 20 mode revertive
wtr 30
mpls te protect-switch
mpls te protect-switch { clear | force | lock | manual }
View
Default level
2: System level
clear: Clears all configured switching actions.
force: Forces data to travel on the backup LSP.
lock: Always uses the main LSP to transfer data.
manual: Switches data from the main LSP to the backup LSP.
Use mpls te protect-switch to configure a switching action for a tunnel.
By default, no switching action is configured.
The following shows the priority of the externally configured switching actions and the signal fail switching, in the descending order:
· Clear
· Lockout of protection
· Signal fail of the backup LSP
· Forced switch
· Signal fail of the main LSP
· Signal clear
· Manual switch
# Specify to always use the main LSP to transfer data.
[Sysname-Tunnel1] mpls te protect-switch lock
mpls te record-route [ label ]
undo mpls te record-route
View
Default level
2: System level
label: Includes the record of labels in the route record.
Use mpls te record-route to enable route recording or label recording for the tunnel.
Use undo mpls te record-route to restore the default.
By default, a tunnel does not support route recording or label recording.
# Enable route recording on MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls te record-route
mpls te reoptimization (tunnel interface view)
mpls te reoptimization [ frequency seconds ]
undo mpls te reoptimization
View
Default level
2: System level
frequency seconds: Specifies reoptimization frequency in the range of 1 to 604800 seconds. The default is 3600 seconds, or 1 hour.
Use mpls te reoptimization to enable reoptimization on the tunnel.
Use undo mpls te reoptimization to disable reoptimization on the tunnel.
Reoptimization is disabled by default.
NOTE: The reoptimization function cannot be used together with these commands: mpls te route-pinning, mpls te backup, and mpls te resv-style ff. |
# Enable reoptimization, setting the reoptimization (automatic rerouting) frequency to 43200 seconds (12 hours).
[Sysname-Tunnel1] mpls te reoptimization frequency 43200
mpls te reoptimization (user view)
View
Default level
2: System level
None
Use mpls te reoptimization to start reoptimizing all reoptimization-enabled TE tunnels.
# Start reoptimizing all reoptimization-enabled TE tunnels.
<Sysname> mpls te reoptimization
mpls te resv-style
mpls te resv-style { ff | se }
undo mpls te resv-style
View
Default level
2: System level
ff: Sets the resource reservation style to fixed filter (FF).
se: Sets the resource reservation style to shared explicit (SE).
Use mpls te resv-style to set the resource reservation style for the MPLS TE tunnel.
Use undo mpls te resv-style to restore the default.
The default resource reservation style is SE.
You can configure FF and SE only when the signaling protocol is set to RSVP-TE.
# Adopt the FF reservation style when setting up the CR-LSP tunnel.
[Sysname-Tunnel1] mpls te resv-style ff
mpls te retry
mpls te retry times
undo mpls te retry
View
Default level
2: System level
times: Number of tunnel setup retries, in the range of 10 to 4294967295.
Use mpls te retry to configure the maximum number of tunnel setup retries.
Use undo mpls te retry to restore the default.
The default maximum number of tunnel setup retries is 10.
You can configure the system to attempt setting up a tunnel multiple times until it is established successfully or until the number of attempts reaches the upper limit.
Related commands: mpls te timer retry.
# Set the maximum number of tunnel setup retries to 20.
[Sysname-Tunnel1] mpls te retry 20
undo mpls te route-pinning
View
Default level
2: System level
None
Use mpls te route-pinning to enable route pinning.
Use undo mpls te route-pinning to restore the default.
By default, route pinning is disabled.
NOTE: The mpls te route-pinning command cannot be used together with the mpls te reoptimization command. |
# Enable route pinning.
[Sysname-Tunnel1] mpls te route-pinning
mpls te signal-protocol
mpls te signal-protocol { rsvp-te | static }
View
Default level
2: System level
rsvp-te: Sets the signaling protocol for MPLS TE tunnel establishment to RSVP-TE.
static: Sets up the tunnel using a static CR-LSP.
Use mpls te signal-protocol to configure the signaling protocol for MPLS TE tunnel establishment.
The default signaling protocol for MPLS TE tunnel establishment is RSVP-TE.
CAUTION: To use RSVP-TE as the signaling protocol for setting up the MPLS TE tunnel, you must enable both MPLS TE and RSVP-TE on the interface for the tunnel to use. |
# Adopt RSVP-TE as the signaling protocol for establishing the MPLS TE tunnel Tunnel1.
[Sysname-Tunnel1] mpls te signal-protocol rsvp-te
mpls te tie-breaking
mpls te tie-breaking { least-fill | most-fill | random }
undo mpls te tie-breaking
View
Default level
2: System level
least-fill: Selects a path with the least bandwidth usage ratio (the used bandwidth to the maximum reservable link bandwidth).
most-fill: Selects a path with the most bandwidth usage ratio (the used bandwidth to the maximum reserved bandwidth).
random: Selects a path randomly.
Use mpls te tie-breaking to specify a tie breaker that a tunnel uses to select a path when multiple paths with the same metric are present.
Use undo mpls te tie-breaking to restore the default.
In MPLS view, the default tie breaker is random. In tunnel interface view, no tie breaker is specified by default.
NOTE: · A tunnel prefers the tie breaker specified in the tunnel interface view. If no tie breaker is specified in tunnel interface view, the tunnel uses the tie breaker specified in MPLS view to select a path. · The IETF DS-TE supports only random path selection. |
# Configure tunnels to use the paths with the least bandwidth usage ratio.
[Sysname] mpls
[Sysname-mpls] mpls te tie-breaking least-fill
# Configure tunnel interface Tunnel1 to use the path with the least bandwidth usage ratio.
[Sysname-Tunnel1] mpls te tie-breaking least-fill
mpls te timer fast-reroute
mpls te timer fast-reroute [ seconds ]
undo mpls te timer fast-reroute
View
MPLS view
Default level
2: System level
seconds: FRR polling timer setting for the point of local repair (PLR) to poll available bypass tunnels for the best one. It is in the range of 0 to 604800 seconds, with 0 disabling the PLR to poll available bypass tunnels regularly for the best one. The default is 300 seconds or 5 minutes.
Use mpls te timer fast-reroute to set the FRR polling timer.
Use undo mpls te timer fast-reroute to restore the default setting.
The default FRR polling timer is 300 seconds.
# Set the FRR polling timer to 120 seconds or 2 minutes.
[Sysname] mpls
[Sysname-mpls] mpls te timer fast-reroute 120
mpls te timer link-management periodic-flooding
mpls te timer link-management periodic-flooding interval
undo mpls te timer link-management periodic-flooding
View
MPLS view
Default level
2: System level
interval: Interval for advertising bandwidth, in the range of 0 to 3600, in seconds.
Use mpls te timer link-management periodic-flooding to configure the interval for advertising updated bandwidth.
Use undo mpls te timer link-management periodic-flooding to restore the default.
By default, the bandwidth advertisement interval is 180 seconds.
The interval specified by this command is that at which the system will periodically advertise interface bandwidth if the bandwidth changes are within the specified threshold. Setting the interval to 0 means to disable the bandwidth advertisement function. The minimal valid interval is 30 seconds. If you set the interval to a value less than 30, the system will take 30 seconds as the interval. If you change the interval before the current interval elapses, the new setting will take effect. For example, if you set the interval to 30 seconds, and then, within 30 seconds, set the interval to 3600 seconds, the interval of 3600 seconds will take effect.
# Set the bandwidth advertising interval to 100 seconds.
[Sysname] mpls
[Sysname- mpls] mpls te timer link-management periodic-flooding 100
mpls te timer retry
mpls te timer retry seconds
undo mpls te timer retry
View
Default level
2: System level
seconds: Interval for re-establishing the tunnel, in the range of 1 to 4294967295 seconds.
Use mpls te timer retry to configure the interval for re-establishing the tunnel.
Use undo mpls te timer retry to restore the default.
The default interval for re-establishing a tunnel is 2 seconds.
Related commands: mpls te retry.
# Set the interval for re-establishing Tunnel1 to 20 seconds.
[Sysname-Tunnel1] mpls te timer retry 20
mpls te tunnel-id
mpls te tunnel-id tunnel-id
View
Default level
2: System level
tunnel-id: Tunnel ID.
Use mpls te tunnel-id to configure the tunnel ID.
Configure the tunnel ID before issuing the mpls te commit command for the first time. Otherwise, the tunnel cannot be created.
NOTE: Once configured, a tunnel ID cannot be removed. To change a tunnel ID, remove the tunnel and then reconfigure the tunnel, giving it a new tunnel ID. |
# Configure the tunnel ID as 100.
[Sysname-Tunnel1] mpls te tunnel-id 100
mpls te vpn-binding
mpls te vpn-binding { acl acl-number | vpn-instance vpn-instance-name }
undo mpls te vpn-binding
View
Default level
2: System level
acl acl-number: Configures the MPLS TE tunnel to forward only VPN traffic that matches the specified ACL. The ACL number is in the range of 3000 to 3999.
vpn-instance vpn-instance-name: Configures the MPLS TE tunnel to forward only traffic of the specified VPN. The vpn-instance-name argument specifies an MPLS L3VPN by its instance name, a case-sensitive string of 1 to 31 characters.
Use mpls te vpn-binding to define the traffic to be forwarded along the MPLS TE tunnel. You can specify the tunnel to forward only the VPN traffic that matches the specified ACL or forward only the traffic of the specified VPN.
Use undo mpls te vpn-binding to restore the default.
By default, no restriction is defined about what traffic can travel down a TE tunnel.
The switch selects a TE tunnel for forwarding VPN traffic in this order: the TE tunnel specified with an ACL, the TE tunnel specified with a VPN instance, the TE tunnel with no restriction on traffic to be forwarded. The switch does not perform load sharing over different types of TE tunnels.
# Configure tunnel interface Tunnel1 to forward only traffic of the VPN vpn1.
[Sysname-Tunnel1] mpls te vpn-binding vpn-instance vpn1
# Configure tunnel interface Tunnel1 to forward only the VPN traffic that matches ACL 3001.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule 0 permit ip vpn-instance vpn1
[Sysname-acl-adv-3001] quit
[Sysname-Tunnel1] mpls te vpn-binding acl 3001
mpls-te
mpls-te enable
undo mpls-te
View
OSPF area view
Default level
2: System level
enable: Enables the MPLS TE capability in the OSPF area.
Use mpls-te to enable the MPLS TE capability in the current OSPF area.
Use undo mpls-te to disable the MPLS TE capability in the current OSPF area.
By default, the MPLS TE capability is disabled in OSPF areas.
For an OSPF area to support the MPLS TE capability, its OSPF process must be available with the opaque LSA capability.
Related commands: opaque-capability.
# Enable the MPLS TE capability in OSPF area 1.
[Sysname] ospf 100
[Sysname-ospf-100] area 1
[Sysname-ospf-100-area-0.0.0.1] mpls-te enable
next hop
next hop ip-address [ include [ loose | strict ] | exclude ]
View
Explicit path view
Default level
2: System level
ip-address: Defines a node by its link IP address or router ID in dotted decimal notation. In the strict routing method, this IP address must be a link IP address. In the loose routing method, this IP address can be either a link IP address or a router ID.
include: Includes the specified IP address on the explicit path.
loose: Specifies the node as a loose node, which means that the ip-address and its previous hop can be connected indirectly.
strict: Specifies the node as a strict node, which means that the ip-address and its previous hop must be directly connected.
exclude: Excludes the specified IP address from the explicit path.
Use next hop to define a node on the explicit path. By performing this command multiple times, you can define all nodes that the explicit path must traverse in sequence.
Related commands: delete hop.
# Specify the switch to not consider the IP address 10.0.0.125 in path calculation for the explicit path path1.
[Sysname-explicit-path-path1] next hop 10.0.0.125 exclude
opaque-capability
opaque-capability enable
undo opaque-capability
View
OSPF view
Default level
2: System level
enable: Enables the opaque LSA capability.
Use opaque-capability to enable the opaque LSA capability for the OSPF process to generate and receive from its neighbors Opaque LSAs.
Use undo opaque-capability to restore the default.
By default, the opaque LSA capability of OSPF is disabled.
# Enable the opaque LSA capability of OSPF.
[Sysname] ospf 100
[Sysname-ospf-100] opaque-capability enable
ping lsp te
ping lsp [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -s packet-size | -t time-out | -v ] * te interface-type interface-number
View
Default level
0: Visit level
-a source-ip: Specifies the source IP address of the Echo Request messages to be sent.
-c count: Specifies the number of Echo Request messages to be sent. The count argument is in the range of 1 to 4294967295 and defaults to 5.
-exp exp-value: Specifies the EXP value for the Echo Request messages. The exp-value argument is in the range of 0 to 7 and defaults to 0.
-h ttl-value: Specifies the TTL value for the Echo Request messages. The ttl-value argument is in the range of 1 to 255 and defaults to 255.
-m wait-time: Specifies the interval for sending Echo Request messages. The wait-time argument is in the range of 1 to 10000 and defaults to 200, in milliseconds.
-r reply-mode: Specifies the reply mode of the receiver in response to an Echo Request message. The reply-mode argument can be 1, 2, or 5. 1 means "Do not respond," 2 means "Respond using a UDP packet," and 5 means "Respond using the reverse CR-LSP of the bidirectional MPLS TE tunnel." The default is 2.
-s packet-size: Specifies the payload length of the Echo Request messages. The packet-size argument is in the range of 65 to 8100 and defaults to 100, in bytes.
-t time-out: Specifies the timeout interval for waiting for the response to an echo request message. The time-out argument is in the range of 0 to 65535 and defaults to 2000, in milliseconds.
-v: Displays detailed response information.
te interface-type interface-number: Specifies a tunnel interface.
Use ping lsp te to check MPLS TE tunnel connectivity.
# Use the ping function to check the connectivity of the MPLS TE tunnel Tunnel1.
<Sysname> ping lsp te tunnel 1
LSP Ping FEC: TE TUNNEL IPV4 SESSION QUERY Tunnel1 : 100 data bytes, press CTRL_C to break
Reply from 100.1.2.1: bytes=100 Sequence=0 time = 31 ms
Reply from 100.1.2.1: bytes=100 Sequence=1 time = 62 ms
Reply from 100.1.2.1: bytes=100 Sequence=2 time = 62 ms
Reply from 100.1.2.1: bytes=100 Sequence=3 time = 62 ms
Reply from 100.1.2.1: bytes=100 Sequence=4 time = 62 ms
--- FEC: TE TUNNEL IPV4 SESSION QUERY Tunnel1 ping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 31/55/62 ms
reset mpls rsvp-te statistics
reset mpls rsvp-te statistics { global | interface [ interface-type interface-number ]
View
Default level
1: Monitor level
global: Clears statistics about global RSVP-TE.
interface: Clears statistics about RSVP-TE for all interfaces.
interface interface-type interface-number: Specifies an interface by its type and number. If an interface is specified, the command clears the statistics about RSVP-TE for the interface.
Use reset mpls rsvp-te statistics to clear statistics about RSVP-TE.
# Clear statistics about global RSVP-TE.
<Sysname> reset mpls rsvp-te statistics global
static-cr-lsp egress
static-cr-lsp egress tunnel-name incoming-interface interface-type interface-number in-label in-label-value [ bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth-value ]
undo static-cr-lsp egress tunnel-name
View
Default level
2: System level
tunnel-name: Tunnel name, a case-sensitive string of 1 to 15 characters.
incoming-interface interface-type interface-number: Specifies the incoming interface.
in-label in-label-value: Specifies the incoming label, which can be a value of 0, 3, or 16 through 1023.
bandwidth: Specifies the class type (CT) for static CR-LSP traffic. By default, static CR-LSP traffic belongs to CT 0.
ct0: Specifies CT 0 for static CR-LSP traffic.
ct1: Specifies CT 1 for static CR-LSP traffic.
ct2: Specifies CT 2 for static CR-LSP traffic.
ct3: Specifies CT 3 for static CR-LSP traffic.
bandwidth-value: Bandwidth required by static CR-LSP traffic, in the range of 1 to 32000000, in kbps.
Use static-cr-lsp egress to configure a static CR-LSP on the egress node.
Use undo static-cr-lsp egress to remove the static CR-LSP.
In prestandard DS-TE mode, the configuration of CT 2 or CT 3 is invalid, and thus the tunnel cannot be established. CT 2 and CT 3 are valid in only IETF DS-TE mode.
Related commands: mpls te tunnel-id.
# Configure a static CR-LSP on the egress node, setting its name to tunnel1, incoming interface to VLAN-interface 1000, and incoming label to 233.
[Sysname] static-cr-lsp egress tunnel1 incoming-interface Vlan-interface1000 in-label 233
static-cr-lsp ingress
static-cr-lsp ingress tunnel-name destination dest-addr nexthop next-hop-addr out-label out-label-value [ bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth-value ]
undo static-cr-lsp ingress tunnel-name
View
Default level
2: System level
tunnel-name: Tunnel name, a case-sensitive string of 1 to 15 characters. It must be an exact reference to a tunnel interface created by the interface tunnel command. For example, if you create a tunnel interface with the interface tunnel 1 command, the tunnel name referenced here must be Tunnel1.
destination dest-addr: Specifies the IP address of the tunnel destination.
nexthop next-hop-addr: Specifies the next hop address.
out-label out-label-value: Specifies the outgoing label, which can be a value of 0, 3, or 16 through 1023.
bandwidth-value: Bandwidth required by the static CR-LSP, in the range of 1 to 32000000 kbps.
Use static-cr-lsp ingress to configure a static CR-LSP at the ingress node.
Use undo static-cr-lsp ingress to remove the static CR-LSP.
CT 2 and CT 3 can be used in only IETF DS-TE mode. In prestandard DS-TE mode, the configuration of CT 2 or CT 3 is invalid, and thus the tunnel cannot be established.
NOTE: The next hop address cannot be a local public address when configuring the static CR-LSP on the ingress or a transit node. |
# Configure a static CR-LSP on the ingress node, setting its name to Tunnel1, destination IP address to 202.25.38.1, destination address mask length to 24, next hop IP address to 202.55.25.33, outgoing label to 237, CT of traffic to CT 0, and required bandwidth to 20 kbps.
[Sysname] static-cr-lsp ingress Tunnel1 destination 202.25.38.1 nexthop 202.55.25.33 out-label 237 bandwidth ct0 20
static-cr-lsp transit
static-cr-lsp transit tunnel-name incoming-interface interface-type interface-number in-label in-label-value nexthop next-hop-addr out-label out-label-value [ bandwidth [ ct0 | ct1 | ct2 | ct3 ] bandwidth-value ]
undo static-cr-lsp transit tunnel-name
View
Default level
2: System level
incoming-interface interface-type interface-number: Specifies an incoming interface for the static CR-LSP.
in-label in-label-value: Specifies the incoming label in the range of 16 to 1023.
Use static-cr-lsp transit to configure a static CR-LSP on a transit node.
Use undo static-cr-lsp transit to remove the static CR-LSP.
# Configure a static CR-LSP on the transit node, setting its name to tunnel1, incoming interface to VLAN-interface 1000, incoming label to 123, next hop IP address to 202.55.25.33, outgoing label to 253, CT of traffic to CT 0, and required bandwidth to 20 kbps.
[Sysname] static-cr-lsp transit tunnel1 incoming-interface Vlan-interface 1000 in-label 123 nexthop 202.55.25.33 out-label 253 bandwidth ct0 20
te-set-subtlv
te-set-subtlv { bw-constraint value | lo-multiplier value | unreserved-bw-sub-pool value } *
undo te-set-subtlv { bw-constraint | lo-multiplier | unreserved-bw-sub-pool } *
View
IS-IS view
Default level
2: System level
bw-constraint value: Sets the bandwidth constraint sub-TLV. value is the sub-TLV value in the range of 19 to 254.
lo-multiplier value: Sets the sub-TLV of local overbooking multiplier (LOM). value is the sub-TLV value in the range of 19 to 254.
unreserved-bw-sub-pool value: Sets the sub-TLV of unreserved subpool bandwidth. value is the sub-TLV value in the range of 19 to 254.
Use te-set-subtlv to configure the sub-TLVs carrying the DS-TE parameters. Because no standard is available for these sub-TLVs, you need to configure them manually for interoperability with other vendors' devices.
Use undo te-set-subtlv to restore the default.
By default, the bandwidth constraint sub-TLV is 252, the sub-TLV of LOM is 253, and the sub-TLV of unreserved subpool bandwidth is 251.
Related commands: display isis traffic-eng sub-tlvs.
# Configure sub-TLVs for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] te-set-subtlv bw-constraint 200 lo-multiplier 201 unreserved-bw-sub-pool 202
tracert lsp te
tracert lsp [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode |-t time-out ] * te interface-type interface-number
View
Default level
0: Visit level
-a source-ip: Specifies the source IP address of the Echo Request messages.
-h ttl-value: Specifies the TTL value for the Echo Request messages. The ttl-value argument is in the range of 1 to 255 and defaults to 30.
-r reply-mode: Specifies the reply mode of the receiver in response to an Echo Request message. The reply-mode argument can be 1 or 2, where 1 means "Do not respond" and 2 means "Respond using a UDP packet". The default is 2.
Use tracert lsp te to locate errors of MPLS TE tunnels.
# Tracert the MPLS TE tunnel of tunnel interface Tunnel 1.
<Sysname> tracert lsp te tunnel 1
LSP Trace Route FEC: TE TUNNEL IPV4 SESSION QUERY Tunnel1 , press CTRL_C to break.
TTL Replier Time Type Downstream
0 Ingress 10.4.5.1/[1025]
1 10.4.5.1 1 Transit 100.3.4.1/[1024]
2 100.3.4.1 63 Transit 100.1.2.1/[3]
3 100.1.2.1 129 Egress
Table 36 Command output
Replier |
Address of the LSR that replies to the request. |
Time |
Time when the reply was received, in milliseconds. |
Type |
Role of the LSR in the LSP, Ingress, Transit, or Egress. |
Downstream |
Address of the downstream LSR and the outgoing label. |
traffic-eng
traffic-eng [ level-1 | level-1-2 | level-2 ]
undo traffic-eng [ level-1 | level-1-2 | level-2 ]
View
IS-IS view
Default level
2: System level
level-1: Enables Level-1 IS-IS TE.
level-1-2: Enables Level-1-2 IS-IS TE.
level-2: Enables Level-2 IS-IS TE.
NOTE: If no level is specified, IS-IS TE applies to Level-1-2. |
Use traffic-eng to enable IS-IS TE.
Use undo traffic-eng to restore the default.
By default, IS-IS TE is disabled.
In order to enable IS-IS TE, you must use the cost-style command to configure the cost style of the IS-IS packet to wide, compatible or wide-compatible. For more information about the cost-style command, see Layer 3—IP Routing Command Reference.
# Enable TE for Level-2 IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] cost-style compatible
[Sysname-isis-1] traffic-eng level-2
