03-Layer 2 - LAN Switching Configuration Guide
HomeSupportRoutersSR8800 SeriesConfigure & DeployConfiguration GuidesH3C SR8800 Configuration Guide-Release3347-6W10303-Layer 2 - LAN Switching Configuration Guide
03-Spanning Tree Configuration
03-Spanning Tree Configuration 568.57 KB
As a Layer 2 management protocol, the Spanning Tree Protocol (STP) eliminates Layer 2 loops by selectively blocking redundant links in a network, and in the mean time, allows for link redundancy.
STP evolves as the network grows. The later versions of STP are the Rapid Spanning Tree Protocol (RSTP) and the Multiple Spanning Tree Protocol (MSTP).
STP
STP was developed based on the 802.1d standard of IEEE to eliminate loops at the data link layer in a local area network (LAN). Routers running this protocol detect loops in the network by exchanging information with one another and eliminate loops by selectively blocking certain ports to prune the loop structure into a loop-free tree structure. This avoids proliferation and infinite cycling of packets that would occur in a loop network and prevents decreased performance of network devices caused by duplicate packets received.
In the narrow sense, STP refers to IEEE 802.1d STP. In the broad sense, STP refers to the IEEE 802.1d STP and various enhanced spanning tree protocols derived from that protocol.
STP protocol packets
STP uses bridge protocol data units (BPDUs), also known as configuration messages, as its protocol packets.
STP-enabled network devices exchange BPDUs to establish a spanning tree. BPDUs contain sufficient information for the network devices to complete spanning tree calculation.
In STP, BPDUs have the following types:
·           Configuration BPDUsUsed for calculating a spanning tree and maintaining the spanning tree topology.
·           Topology change notification (TCN) BPDUsUsed for notifying the involved routers of network topology changes, if any.
A configuration BPDU contains the following information for network devices to complete spanning tree calculation.
·           Root bridge ID—Comprises the priority and MAC address of the root bridge.
·           Root path costCost of the path to the root bridge.
·           Designated bridge ID—Comprises the priority and MAC address of the designated bridge.
·           Designated port ID—Comprises the port priority and global port number.
·           Message ageTimes that the configuration BPDU has been forwarded on the network.
·           Max ageMaximum age of the configuration BPDU.
·           Hello time—Transmission interval of the configuration BPDU.
·           Forward delayDelay before a port transitions to the forwarding state.
Basic concepts in STP
Root bridge
A tree network must have a root bridge.
There is only one root bridge in the entire network. The root bridge is not fixed, but can change along with changes of the network topology.
Upon initialization of a network, each router generates and sends out configuration BPDUs periodically with itself as the root bridge. After network convergence, only the root bridge generates and sends out configuration BPDUs at a certain interval, and the other routers forward the BPDUs.
Root port
On a non-root bridge, the port nearest to the root bridge is the root port. The root port communicates with the root bridge. Each non-root bridge has only one root port. The root bridge has no root port.
Designated bridge and designated port
Table 1 Description of designated bridges and designated ports
Classification
Designated bridge
Designated port
For a router
A router directly connected with the local router and responsible for forwarding BPDUs to the local router
The port through which the designated bridge forwards BPDUs to this router
For a LAN
The router responsible for forwarding BPDUs to this LAN segment
The port through which the designated bridge forwards BPDUs to this LAN segment
As shown in Figure 1, Device B and Device C are directly connected to a LAN. If Device A forwards BPDUs to Device B through port A1, the designated bridge for Device B is Device A, and the designated port of Device B is port A1 on Device A. If Device B forwards BPDUs to the LAN, the designated bridge for the LAN is Device B, and the designated port for the LAN is port B2 on Device B.
Figure 1 A schematic diagram of designated bridges and designated ports
Path cost
Path cost is a reference value used for link selection in STP. By calculating path costs, STP selects relatively robust links and blocks redundant links, and finally prunes the network into a loop-free tree.
Calculation process of the STP algorithm
The STP algorithm uses the following calculation process:
1.      Initial state
Upon initialization of a router, each port generates a BPDU with the router as the root bridge, in which the root path cost is 0, designated bridge ID is the device ID, and the designated port is the port itself.
2.      Selection of the root bridge
Initially, each STP-enabled router on the network assumes itself to be the root bridge, with the root bridge ID being its own device ID. By exchanging configuration BPDUs, the routers compare their root bridge IDs to elect the router with the smallest root bridge ID as the root bridge.
3.      Selection of the root port and designated ports on a non-root router
Table 2 describes the process of selecting the root port and designated ports.
Table 2 Selection of the root port and designated ports
Step
1
A non-root-bridge router regards the port on which it received the optimum configuration BPDU as the root port. Table 3 describes how the optimum configuration BPDU is selected.
2
Based on the configuration BPDU and the path cost of the root port, the router calculates a designated port configuration BPDU for each of the rest ports.
·       The root bridge ID is replaced with that of the configuration BPDU of the root port.
·       The root path cost is replaced with that of the configuration BPDU of the root port plus the path cost of the root port.
·       The designated bridge ID is replaced with the ID of this router.
·       The designated port ID is replaced with the ID of this port.
3
The router compares the calculated configuration BPDU with the configuration BPDU on the port whose port role is to be determined:
·       If the calculated configuration BPDU is superior, the router considers this port as the designated port, replaces the configuration BPDU on the port with the calculated configuration BPDU, and periodically sends out the calculated configuration BPDU.
·       If the configuration BPDU on the port is superior, the router blocks this port without updating its configuration BPDU. The blocked port can receive BPDUs, but cannot send BPDUs or forward data traffic.
When the network topology is stable, only the root port and designated ports forward user traffic, while other ports are all in the blocked state to receive BPDUs but not forward BPDUs or user traffic.
Table 3 Selection of the optimum configuration BPDU
Step
Actions
1
Upon receiving a configuration BPDU on a port, the router compares the priority of the received configuration BPDU with that of the configuration BPDU generated by the port, and:
·       If the former priority is lower, the router discards the received configuration BPDU and does not process the configuration BPDU of this port.
·       If the former priority is higher, the router replaces the content of the configuration BPDU generated by the port with the content of the received configuration BPDU.
2
The router compares the configuration BPDUs of all the ports and chooses the optimum configuration BPDU.
The following are the principles of configuration BPDU comparison:
·       The configuration BPDU that has the lowest root bridge ID has the highest priority.
·       If all configuration BPDUs have the same root bridge ID, their root path costs are compared. For example, the root path cost in a configuration BPDU plus the path cost of a receiving port is S. The configuration BPDU with the smallest S value has the highest priority.
·       If all configuration BPDUs have the same ports value, their designated bridge IDs, designated port IDs, and the IDs of the receiving ports are compared in sequence. The configuration BPDU containing a smaller ID wins out.
A tree-shape topology forms when the root bridge, root ports, and designated ports are selected.
The following describes with an example how the STP algorithm works.
Figure 2 The STP algorithm
As shown in Figure 2, the priority values of Device A, Device B, and Device C are 0, 1, and 2, and the path costs of links among the three devices are 5, 10, and 4 respectively.
4.      Initial state of each device
Table 4 Initial state of each device
Device
Port name
Configuration BPDU on the port
Device A
Port A1
{0, 0, 0, Port A1}
Port A2
{0, 0, 0, Port A2}
Device B
Port B1
{1, 0, 1, Port B1}
Port B2
{1, 0, 1, Port B2}
Device C
Port C1
{2, 0, 2, Port C1}
Port C2
{2, 0, 2, Port C2}
In Table 4, each configuration BPDU contains the following fields: root bridge ID, root path cost, designated bridge ID, and designated port ID.
5.      Comparison process and result on each device
Table 5 Comparison process and result on each device
Device
Comparison process
Configuration BPDU on ports after comparison
Device A
·       Port A1 receives the configuration BPDU of Port B1 {1, 0, 1, Port B1}, finds that its existing configuration BPDU {0, 0, 0, Port A1} is superior to the received configuration BPDU, and discards the received one.
·       Port A2 receives the configuration BPDU of Port C1 {2, 0, 2, Port C1}, finds that its existing configuration BPDU {0, 0, 0, Port A2} is superior to the received configuration BPDU, and discards the received one.
·       Device A finds that it is both the root bridge and designated bridge in the configuration BPDUs of all its ports, and considers itself as the root bridge. It does not change the configuration BPDU of any port and starts to periodically send out configuration BPDUs.
·       Port A1: {0, 0, 0, Port A1}
·       Port A2: {0, 0, 0, Port A2}
Device B
·       Port B1 receives the configuration BPDU of Port A1 {0, 0, 0, Port A1}, finds that the received configuration BPDU is superior to its existing configuration BPDU {1, 0, 1, Port B1}, and updates its configuration BPDU.
·       Port B2 receives the configuration BPDU of Port C2 {2, 0, 2, Port C2}, finds that its existing configuration BPDU {1, 0, 1, Port B2} is superior to the received configuration BPDU, and discards the received one.
·       Port B1: {0, 0, 0, Port A1}
·       Port B2: {1, 0, 1, Port B2}
·       Device B compares the configuration BPDUs of all its ports, decides that the configuration BPDU of Port B1 is the optimum, and selects Port B1 as the root port with the configuration BPDU unchanged.
·       Based on the configuration BPDU and path cost of the root port, Device B calculates a designated port configuration BPDU for Port B2 {0, 5, 1, Port B2}, and compares it with the existing configuration BPDU of Port B2 {1, 0, 1, Port B2}. Device B finds that the calculated one is superior, decides that Port B2 is the designated port, replaces the configuration BPDU on Port B2 with the calculated one, and periodically sends out the calculated configuration BPDU.
·       Root port (Port B1): {0, 0, 0, Port A1}
·       Designated port (Port B2): {0, 5, 1, Port B2}
Device C
·       Port C1 receives the configuration BPDU of Port A2 {0, 0, 0, Port A2}, finds that the received configuration BPDU is superior to its existing configuration BPDU {2, 0, 2, Port C1}, and updates its configuration BPDU.
·       Port C2 receives the original configuration BPDU of Port B2 {1, 0, 1, Port B2}, finds that the received configuration BPDU is superior to the existing configuration BPDU {2, 0, 2, Port C2}, and updates its configuration BPDU.
·       Port C1: {0, 0, 0, Port A2}
·       Port C2: {1, 0, 1, Port B2}
·       Device C compares the configuration BPDUs of all its ports, decides that the configuration BPDU of Port C1 is the optimum, and selects Port C1 as the root port with the configuration BPDU unchanged.
·       Based on the configuration BPDU and path cost of the root port, Device C calculates the configuration BPDU of Port C2 {0, 10, 2, Port C2}, and compares it with the existing configuration BPDU of Port C2 {1, 0, 1, Port B2}. Device C finds that the calculated configuration BPDU is superior to the existing one, selects Port C2 as the designated port, and replaces the configuration BPDU of Port C2 with the calculated one.
·       Root port (Port C1): {0, 0, 0, Port A2}
·       Designated port (Port C2): {0, 10, 2, Port C2}
·       Port C2 receives the updated configuration BPDU of Port B2 {0, 5, 1, Port B2}, finds that the received configuration BPDU is superior to its existing configuration BPDU {0, 10, 2, Port C2}, and updates its configuration BPDU.
·       Port C1 receives a periodic configuration BPDU {0, 0, 0, Port A2} from Port A2, finds that it is the same as the existing configuration BPDU, and discards the received one.
·       Port C2: {0, 5, 1, Port B2}
·       Device C finds that the root path cost of Port C1 (10) (root path cost of the received configuration BPDU (0) plus path cost of Port C1 (10)) is larger than that of Port C2 (9) (root path cost of the received configuration BPDU (5) plus path cost of Port C2 (4)), decides that the configuration BPDU of Port C2 is the optimum, and selects Port C2 as the root port with the configuration BPDU unchanged.
·       Based on the configuration BPDU and path cost of the root port, Device C calculates a designated port configuration BPDU for Port C1 {0, 9, 2, Port C1} and compares it with the existing configuration BPDU of Port C1 {0, 0, 0, Port A2}. Device C finds that the existing configuration BPDU is superior to the calculated one and blocks Port C1 with the configuration BPDU unchanged. Then Port C1 does not forward data until a spanning tree calculation process is triggered by a new event, for example, the link between Device B and Device C is down.
·       Blocked port (Port C1): {0, 0, 0, Port A2}
·       Root port (Port C2): {0, 5, 1, Port B2}
In Table 5, each configuration BPDU contains the following fields: root bridge ID, root path cost, designated bridge ID, and designated port ID.
After the comparison processes described in Table 5, a spanning tree with Device A as the root bridge is established, and the topology is shown in Figure 3.
Figure 3 Topology of the final calculated spanning tree
The spanning tree calculation process in this example is only simplified process.
The configuration BPDU forwarding mechanism of STP
The configuration BPDUs of STP are forwarded following these guidelines:
·           Upon network initiation, every router regards itself as the root bridge, generates configuration BPDUs with itself as the root, and sends the configuration BPDUs at a regular hello interval.
·           If it is the root port that received a configuration BPDU and the received configuration BPDU is superior to the configuration BPDU of the port, the router increases the message age carried in the configuration BPDU following a certain rule and starts a timer to time the configuration BPDU while sending out this configuration BPDU through the designated port.
·           If the configuration BPDU received on a designated port has a lower priority than the configuration BPDU of the local port, the port immediately sends out its own configuration BPDU in response.
·           If a path becomes faulty, the root port on this path no longer receives new configuration BPDUs and the old configuration BPDUs will be discarded due to timeout. The router generates a configuration BPDU with itself as the root and sends out the BPDUs and TCN BPDUs. This triggers a new spanning tree calculation process to establish a new path to restore the network connectivity.
However, the newly calculated configuration BPDU cannot be propagated throughout the network immediately, so the old root ports and designated ports that have not detected the topology change continue forwarding data along the old path. If the new root ports and designated ports begin to forward data as soon as they are elected, a temporary loop may occur.
STP timers
STP calculation involves the following timers: forward delay, hello time, and max age.
·           Forward delay
Forward delay is the delay time for state transition.
A path failure can cause spanning tree re-calculation to adapt the spanning tree structure to the change. However, the resulting new configuration BPDU cannot propagate throughout the network immediately. If the newly elected root ports and designated ports start to forward data right away, a temporary loop is likely to occur.
For this reason, as a mechanism for state transition in STP, the newly elected root ports or designated ports require twice the forward delay time before transiting to the forwarding state to make sure that the new configuration BPDU has propagated throughout the network.
·           Hello time
The router sends hello packets at the hello time interval to the neighboring routers to make sure that the paths are fault-free.
·           Max age
The router uses the max age to determine whether a stored configuration BPDU has expired and discards it if the max age is exceeded.
RSTP
Developed based on the 802.1w standard of IEEE, RSTP is an optimized version of STP. It achieves rapid network convergence by allowing a newly elected root port or designated port to enter the forwarding state much quicker under certain conditions than in STP.
A newly elected RSTP root port rapidly enters the forwarding state if the old root port on the router has stopped forwarding data and the upstream designated port has started forwarding data.
A newly elected RSTP designated port rapidly enters the forwarding state if it is an edge port (which directly connects to a user terminal rather than to another router or a shared LAN segment) or it connects to a point-to-point link (to another router). Edge ports directly enter the forwarding state. Connecting to a point-to-point link, a designated port enters the forwarding state immediately after the router receives a handshake response from the directly connected router.
MSTP
STP and RSTP limitations
STP does not support rapid state transition of ports. A newly elected port must wait twice the forward delay time before transiting to the forwarding state, even if it connects to a point-to-point link or is an edge port.
Although RSTP supports rapid network convergence, it has the same drawback as STP—All bridges within a LAN share the same spanning tree, so redundant links cannot be blocked based on VLAN, and the packets of all VLANs are forwarded along the same spanning tree.
MSTP features
Developed based on IEEE 802.1s, MSTP overcomes the limitations of STP and RSTP. In addition to the support for rapid network convergence, it allows data flows of different VLANs to be forwarded along separate paths, providing a better load sharing mechanism for redundant links.
MSTP includes the following features:
·           MSTP supports mapping VLANs to spanning tree instances by means of a VLAN-to-instance mapping table. MSTP can reduce communication overheads and resource usage by mapping multiple VLANs to one instance.
·           MSTP divides a switched network into multiple regions, each containing multiple spanning trees that are independent of one another.
·           MSTP prunes a loop network into a loop-free tree, avoiding proliferation and endless cycling of packets in a loop network. In addition, it provides multiple redundant paths for data forwarding, supporting load balancing of VLAN data.
·           MSTP is compatible with STP and RSTP.
MSTP basic concepts
Figure 4 shows a switched network that comprises four MST regions, each MST region comprising four MSTP devices. Figure 5 shows the networking topology of MST region 3. This section describes some basic concepts of MSTP.
Figure 4 Basic concepts in MSTP
Figure 5 Network diagram and topology of MST region 3
MST region
A multiple spanning tree region (MST region) consists of multiple routers in a switched network and the network segments among them. All these routers have the following characteristics:
·           A spanning tree protocol enabled
·           Same region name
·           Same VLAN-to-instance mapping configuration
·           Same MSTP revision level
·           Physically linked together
Multiple MST regions can exist in a switched network. You can assign multiple routers to the same MST region. In Figure 4, the switched network comprises four MST regions, MST region 1 through MST region 4, and all routers in each MST region have the same MST region configuration.
MSTI
MSTP can generate multiple spanning trees in an MST region, and each spanning tree is independent of another and maps to specific VLANs. Each spanning tree is referred to as a multiple spanning tree instance (MSTI).
In Figure 5, MST region 3 comprises three MSTIs, MSTI 1, MSTI 2, and MSTI 0.
As an attribute of an MST region, the VLAN-to-instance mapping table describes the mapping relationships between VLANs and MSTIs.
In Figure 5, the VLAN-to-instance mapping table of MST region 3 is: VLAN 1 to MSTI 1, VLAN 2 and VLAN 3 to MSTI 2, and other VLANs to MSTI 0. MSTP achieves load balancing by means of the VLAN-to-instance mapping table.
CST
The common spanning tree (CST) is a single spanning tree that connects all MST regions in a switched network. If you regard each MST region as a router, the CST is a spanning tree calculated by these routers through STP or RSTP.
The blue lines in Figure 4 represent the CST.
IST
An internal spanning tree (IST) is a spanning tree that runs in an MST region. It is also called MSTI 0, a special MSTI to which all VLANs are mapped by default.
In Figure 4, MSTI 0 is the IST in MST region 3.
CIST
The common and internal spanning tree (CIST) is a single spanning tree that connects all routers in a switched network. It consists of the ISTs in all MST regions and the CST.
In Figure 4, the ISTs (MSTI 0) in all MST regions plus the inter-region CST constitute the CIST of the entire network.
Regional root
The root bridge of the IST or an MSTI within an MST region is the regional root of the IST or MSTI. Based on the topology, different spanning trees in an MST region may have different regional roots.
For example, in MST region 3 in Figure 5, the regional root of MSTI 1 is Device B, the regional root of MSTI 2 is Device C, and the regional root of MSTI 0 (also known as the IST) is Device A.
Common root bridge
The common root bridge is the root bridge of the CIST.
In Figure 4, for example, the common root bridge is a router in MST region 1.
Port roles
A port can play different roles in different MSTIs. As shown in Figure 6, an MST region comprises Device A, Device B, Device C, and Device D. Port A1 and port A2 of Device A connect to the common root bridge. Port B2 and Port B3 of Device B form a loop. Port C3 and Port C4 of Device C connect to other MST regions. Port D3 of Device D directly connects to a host.
Figure 6 Port roles
MSTP calculation involves these port roles:
·           Root port—Forwards data for a non-root bridge to the root bridge. The root bridge does not have any root port.
·           Designated port—Forwards data to the downstream network segment or router.
·           Alternate port—The backup port for a root port or master port. When the root port or master port is blocked, the alternate port takes over.
·           Backup port—The backup port of a designated port. When the designated port is invalid, the backup port becomes the new designated port. When a loop occurs due to the interconnection of two ports of the same router running a spanning tree protocol, the router blocks either of the two ports, and the blocked port is the backup port.
·           Edge port—An edge port does not connect to any network device or network segment, but directly connects to a user host.
·           Master port—A port on the shortest path from the local MST region to the common root bridge. The master port is not always located on the regional root. It is a root port on the IST or CIST and still a master port on the other MSTIs.
·           Boundary port—Connects an MST region to another MST region or to an STP/RSTP-running router. In MSTP calculation, a boundary port’s role on an MSTI is consistent with its role on the CIST. But that is not true with master ports. A master port on MSTIs is a root port on the CIST.
Port states
In MSTP, a port may be in one of the following states:
·           Forwarding—the port receives and sends BPDUs, learns MAC addresses, and forwards user traffic.
·           Learning—the port receives and sends BPDUs, learns MAC addresses, but does not forward user traffic. Learning is an intermediate port state.
·           Discarding—the port receives and sends BPDUs, but does not learn MAC addresses or forwards user traffic.
When in different MSTIs, a port can be in different states.
A port state is not exclusively associated with a port role. Table 6 lists the port state(s) supported by each port role ("√" indicates that the port supports this state, and "—" indicates that the port does not support this state).
Table 6 Port states supported by different port roles
Port role (right)
Root port/master port
Designated port
Alternate port
Backup port
Port state (below)
Forwarding
Learning
Discarding
How MSTP works
MSTP divides an entire Layer 2 network into multiple MST regions, which are interconnected by a calculated CST. Inside an MST region, multiple spanning trees are calculated, each being an MSTI. Among these MSTIs, MSTI 0 is the IST. Similar to STP, MSTP uses configuration BPDUs to calculate spanning trees. The only difference between the two protocols is that an MSTP BPDU carries the MSTP configuration on the router from which this BPDU is sent.
CIST calculation
The calculation of a CIST tree is also the process of configuration BPDU comparison. During this process, the router with the highest priority is elected as the root bridge of the CIST. MSTP generates an IST within each MST region through calculation, and, at the same time, MSTP regards each MST region as a single router and generates a CST among these MST regions through calculation. The CST and ISTs constitute the CIST of the entire network.
MSTI calculation
Within an MST region, MSTP generates different MSTIs for different VLANs based on the VLAN-to-instance mappings. MSTP performs a separate calculation process, which is similar to spanning tree calculation in STP, for each spanning tree. For more information, see “Calculation process of the STP algorithm.”
In MSTP, a VLAN packet is forwarded along the following paths:
·           Within an MST region, the packet is forwarded along the corresponding MSTI.
·           Between two MST regions, the packet is forwarded along the CST.
Implementation of MSTP on routers
MSTP is compatible with STP and RSTP. STP and RSTP protocol packets can be recognized by routers running MSTP and used for spanning tree calculation.
In addition to basic MSTP functions, the following functions are provided for ease of management:
·           Root bridge hold
·           Root bridge backup
·           Root guard
·           BPDU guard
·           Loop guard
·           TC-BPDU guard
·           BPDU drop
·           Support for hot swapping of interface cards and active/standby changeover.
Protocols and standards
The spanning tree protocols are documented in the following standards:
·           IEEE 802.1d: Media Access Control (MAC) Bridges
·           IEEE 802.1w: Part 3: Media Access Control (MAC) Bridges—Amendment 2: Rapid Reconfiguration
·           IEEE 802.1s: Virtual Bridged Local Area Networks—Amendment 3: Multiple Spanning Trees
Spanning tree configuration task list
Before configuring a spanning tree, you must determine the spanning tree protocol to be used (STP, RSTP, or MSTP) and plan the device roles (the root bridge or leaf node).
Complete the following tasks to configure STP:
Remarks
Configuring the root bridge
Setting the spanning tree mode
Required
Configure the router to work in STP-compatible mode.
Configuring the root bridge or a secondary root bridge
Optional
Configuring the device priority
Optional
Configuring the network diameter of a switched network
Optional
Configuring spanning tree timers
Optional
Configuring the timeout factor
Optional
Configuring the maximum port rate
Optional
Configuring the mode a port uses to recognize/send MSTP packets
Optional
Enabling the spanning tree feature
Required
Configuring the leaf nodes
Required
Optional
Optional
Optional
Configuring path costs of ports
Optional
Configuring the port priority
Optional
Optional
Required
Configuring the VLAN Ignore feature
Optional
Configuring protection functions
Optional
Complete the following tasks to configure RSTP:
Remarks
Required
Configure the router to work in RSTP mode.
Optional
Optional
Optional
Optional
Optional
Optional
Configuring edge ports
Optional
Configuring the port link type
Optional
Optional
Required
Required
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Required
Performing mCheck
Optional
Optional
Optional
Complete the following tasks to configure MSTP:
Remarks
Optional
By default, the router works in MSTP mode.
Configuring an MST region
Required
Optional
Optional
Configuring the maximum hops of an MST region
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Required
Optional
Required
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Optional
Required
Performing mCheck
Optional
Optional
Configuring Digest Snooping
Optional
Configuring No Agreement Check
Optional
Optional
·       If GVRP and a spanning tree protocol are enabled on a router at the same time, GVRP packets are forwarded along the CIST. To advertise a certain VLAN within the network through GVRP, make sure that this VLAN is mapped to the CIST when you configure the VLAN-to-instance mapping table. For more information about GVRP, see the chapter “Configuring GVRP.”
·       The spanning tree configurations are mutually exclusive with any of the following functions on a port: service loopback, RRPP, Smart Link, and BPDU tunnel.
·       The spanning tree configurations made in system view take effect globally. Configurations made in Ethernet interface view take effect on the current interface only. Configurations made in port group view take effect on all member ports in the port group. Configurations made in Layer 2 aggregate interface view take effect only on the aggregate interface. Configurations made on an aggregation member port can take effect only after the port is removed from the aggregation group.
·       After you enable a spanning tree protocol on a Layer 2 aggregate interface, the system performs spanning tree calculation on the Layer 2 aggregate interface but not on the aggregation member ports. The spanning tree protocol enable state and forwarding state of each selected member port is consistent with those of the corresponding Layer 2 aggregate interface.
·       Though the member ports of an aggregation group do not participate in spanning tree calculation, the ports still reserve its spanning tree configurations for participating spanning tree calculation after leaving the aggregation group.
Configuring the spanning tree
The spanning tree modes include:
·           STP-compatible modeThe router sends out STP BPDUs through all ports.
·           RSTP modeThe router sends out RSTP BPDUs through all ports, and ports that connect to STP devices automatically transitions to the STP-compatible mode.
·           MSTP modeThe router sends out MSTP BPDUs through all ports, and ports that connect to STP devices automatically transitions to the STP-compatible mode.
To set the spanning tree mode:
Step
Remarks
1.     Enter system view.
N/A
2.     Set the spanning tree mode.
stp mode { stp | rstp | mstp }
The default setting is MSTP mode.
To configure an MST region:
Step
Remarks
3.     Enter system view.
N/A
4.     Enter MST region view.
stp region-configuration
N/A
5.     Configure the MST region name.
region-name name
Optional.
The MST region name is the MAC address by default.
6.     Configure the VLAN-to-instance mapping table.
·       instance instance-id vlan vlan-list
·       vlan-mapping modulo modulo
Optional.
Use either command.
All VLANs in an MST region are mapped to the CIST (or MSTI 0) by default.
7.     Configure the MSTP revision level of the MST region.
revision-level level
Optional.
The default setting is 0.
8.     Display the MST region configurations that are not activated yet.
check region-configuration
Optional.
9.     Activate MST region configuration manually.
active region-configuration
N/A
10.   Display the activated configuration information of the MST region.
display stp region-configuration [ | { begin | exclude | include } regular-expression ]
Optional.
Available in any view
·       Two or more spanning tree devices belong to the same MST region only if they are configured to have the same format selector (0 by default, not configurable), MST region name, MST region revision level, and the same VLAN-to-instance mapping entries in the MST region, and they are interconnected via a physical link.
·       The configuration of MST region–related parameters, especially the VLAN-to-instance mapping table, will result in a new spanning tree calculation. To reduce the possibility of topology instability, the MST region configuration takes effect only after you activate it by using the active region-configuration command, or enable a spanning tree protocol by using the stp enable command in the case that the spanning tree protocol is disabled.
The root bridge of a spanning tree is determined through spanning tree calculation. Alternatively, you can specify the router as the root bridge or a secondary root bridge.
A router has independent roles in different spanning trees. It can act as the root bridge in one spanning tree and as a secondary root bridge in another. However, a router cannot be the root bridge and a secondary root bridge in the same spanning tree.
A spanning tree can have one root bridge only. If two or more routers are selected as the root bridge in a spanning tree at the same time, the router with the lowest MAC address wins out.
When the root bridge of an instance fails or is shut down, the secondary root bridge (if you have specified one) can take over the role of the primary root bridge. However, if you specify a new primary root bridge for the instance then, the secondary root bridge will not become the root bridge. If you have specified multiple secondary root bridges for an instance, when the root bridge fails, the secondary root bridge with the lowest MAC address is selected as the new root bridge.
Configuring the current router as the root bridge of a specific spanning tree
To configure the current router as the root bridge of a specific spanning tree:
Step
Remarks
N/A
2.     Configure the current router as the root bridge.
·       In STP/RSTP mode:
stp root primary
·       In MSTP mode:
stp [ instance instance-id ] root primary
Use one of the commands.
By default, a router does not function as the root bridge.
Configuring the current router as a secondary root bridge of a specific spanning tree
To configure the current router as a secondary root bridge of a specific spanning tree:
Step
Remarks
N/A
2.     Configure the current router as a secondary root bridge.
·       In STP/RSTP mode:
stp root secondary
·       In MSTP mode:
stp [ instance instance-id ] root secondary
By default, a router does not function as a secondary root bridge.
·       You can specify one root bridge for each spanning tree, regardless of the device priority settings. Once you specify a router as the root bridge or a secondary root bridge, you cannot change its priority.
·       You can configure the current router as the root bridge by setting the device priority to 0. For the device priority configuration, see “Configuring the device priority.”
Device priorities participate in spanning tree calculation. The priority of a router determines whether the router can be elected as the root bridge of a spanning tree. A lower value indicates a higher priority. By setting the priority of a router to a low value, you can specify the router as the root bridge of the spanning tree. A spanning tree router can have different priorities in different MSTIs.
To configure the priority of a router in a specified MSTI:
Step
Remarks
N/A
2.     Configure the priority of the current router.
·       In STP/RSTP mode:
stp priority priority
·       In MSTP mode:
stp [ instance instance-id ] priority priority
The default setting is 32768.
CAUTION
CAUTION:
·       After configuring a router as the root bridge or a secondary root bridge, you cannot change the priority of the router.
·       During root bridge selection, if all routers in a spanning tree have the same priority, the one with the lowest MAC address will be selected as the root bridge of the spanning tree.
By setting the maximum hops of an MST region, you can restrict the region size. The maximum hops configured on the regional root bridge will be used as the maximum hops of the MST region.
The regional root bridge always sends a configuration BPDU with a hop count set to the maximum value. When a router receives this configuration BPDU, it decrements the hop count by 1 and uses the new hop count in the BPDUs it propagates. When the hop count of a BPDU reaches 0, it is discarded by the router that received it. Routers beyond the reach of the maximum hop can no longer take part in spanning tree calculation, and the size of the MST region is confined.
Make this configuration on the root bridge only. All the routers other than the root bridge in the MST region use the maximum hop value set for the root bridge.
To configure the maximum number of hops of an MST region:
Step
Remarks
N/A
2.     Configure the maximum hops of the MST region.
stp max-hops hops
The default setting is 20.
Any two terminal devices in a switched network are interconnected through a specific path composed of a series of devices. The network diameter is the number of devices on the path composed of the most devices. The network diameter is a parameter that indicates the network size. A bigger network diameter indicates a larger network size.
To configure the network diameter of a switched network:
Step
Remarks
N/A
2.     Configure the network diameter of the switched network.
stp bridge-diameter diameter
The default setting is 7.
·       Based on the network diameter you configured, the system automatically sets an optimal hello time, forward delay, and max age for the router.
·       Each MST region is considered as a router and the configured network diameter is effective only for the CIST (or the common root bridge), but not for MSTIs.
The following timers are used for spanning tree calculation:
·           Forward delay
It is the delay time for port state transition. To prevent temporary loops on a network, the spanning tree sets an intermediate port state, the learning state, before it transitions from the discarding state to the forwarding state, and requires that the port transitions its state after a forward delay timer to make sure that the state transition of the local port keeps synchronized with the peer.
·           Hello time
The router detects whether a link failure has occurred with the hello time interval. The spanning tree sends out a configuration BPDU every hello time interval. If the router receives no configuration BPDUs within the hello time interval, it recalculates the spanning tree.
·           Max age
In the CIST of an MSTP network, the router determines whether a configuration BPDU received by a port has expires based on the max age timer. If yes, a new spanning tree calculation process starts. The max age timer is ineffective for MSTIs.
To prevent network instability, make sure that the timer settings meet the following formulas:
·           2 × (forward delay – 1 second) ¦ max age
·           Max age ¦ 2 × (hello time + 1 second)
H3C does not recommend you to manually set the spanning tree timers. Instead, you can specify the network diameter and let spanning tree protocols automatically calculate the timers based on the network diameter. If the network diameter uses the default value, the timers also use their default values.
Configure the timers on the root bridge only, and the timer settings on the root bridge apply to all the routers on the entire switched network.
To configure the spanning tree timers:
Step
Remarks
N/A
2.     Configure the forward delay timer.
stp timer forward-delay time
Optional.
The default setting is 1500 centiseconds.
3.     Configure the hello timer.
stp timer hello time
Optional.
The default setting is 200 centiseconds.
4.     Configure the max age timer.
stp timer max-age time
Optional.
The default setting is 2000 centiseconds.
·       The length of the forward delay timer is related to the network diameter of the switched network. The larger the network diameter is, the longer the forward delay time should be. If the forward delay timer is too short, temporary redundant paths may be introduced. If the forward delay timer is too long, it may take a long time for the network to converge. H3C recommends you to use the default setting.
·       An appropriate hello time setting enables the router to timely detect link failures on the network without using excessive network resources. If the hello time is too long, the router will consider packet loss as a link failure and trigger a new spanning tree calculation process. If the hello time is too short, the router will frequently send the same configuration BPDUs, which add the router burden and waste network resources. H3C recommends you to use the default setting.
·       If the max age timer is too short, the router will frequently launch spanning tree calculation and may consider network congestion as a link failure. If the max age timer is too long, the router may fail to timely detect link failures and launch spanning tree calculation, reducing the auto-sensing capability of the network. H3C recommends you to use the default setting.
The timeout factor is a parameter used to decide the timeout time, as shown in the following formula: Timeout time = timeout factor × 3 × hello time.
After the network topology is stabilized, each non-root-bridge router forwards configuration BPDUs to the downstream routers at the interval of hello time to check whether any link is faulty. If a router does not receive a BPDU from the upstream router within nine times the hello time, it assumes that the upstream router has failed and starts a new spanning tree calculation process.
Sometimes a router may fail to receive a BPDU from the upstream router because the upstream router is busy. If a spanning tree calculation occurs, the calculation can fail and also waste the network resources. In a stable network, you can prevent undesired spanning tree calculations by setting the timeout factor to 5, 6, or 7.
To configure the timeout factor:
Step
Remarks
N/A
2.     Configure the timeout factor of the router.
stp timer-factor factor
The default setting is 3.
The maximum rate of a port refers to the maximum number of BPDUs the port can send within each hello time. The maximum rate of a port is related to the physical status of the port and the network structure.
To configure the maximum rate of a port or a group of ports:
Step
Remarks
N/A
2.     Enter interface view or port group view.
·       Enter Ethernet interface view or Layer 2 aggregate interface view:
·       Enter port group view:
port-group manual port-group-name
3.     Configure the maximum rate of the ports.
stp transmit-limit limit
The default setting is 10.
The higher the maximum port rate is, the more BPDUs will be sent within each hello time, and the more system resources will be used. By setting an appropriate maximum port rate, you can limit the rate at which the port sends BPDUs and prevent spanning tree protocols from using excessive network resources when the network becomes instable. H3C recommends you to use the default setting.
If a port directly connects to a user terminal rather than another router or a shared LAN segment, this port is regarded as an edge port. When a network topology change occurs, an edge port will not cause a temporary loop. Because a router does not know whether a port is directly connected to a terminal, you need to manually configure the port to be an edge port. After that, this port can transition rapidly from the blocked state to the forwarding state without delay.
To specify a port or a group of ports as edge port or ports:
Step
Remarks
N/A
3.     Configure the current ports as edge ports.
stp edged-port enable
By default, all ports are non-edge ports.
·       With BPDU guard disabled, when a port set as an edge port receives a BPDU from another port, it will become a non-edge port again. To restore the edge port, re-enable it.
·       If a port directly connects to a user terminal, configure it as an edge port and enable BPDU guard for it. This enables the port to transition to the forwarding state fast while ensuring network security.
·       Among loop guard, root guard and edge port settings, only one function (whichever is configured the earliest) can take effect on a port at the same time.
Path cost is a parameter related to the rate of a port. On a spanning tree device, a port can have different path costs in different MSTIs. Setting appropriate path costs allows VLAN traffic flows to be forwarded along different physical links, achieving VLAN-based load balancing.
The router can automatically calculate the default path cost; alternatively, you can also configure the path cost for ports.
Specifying a standard that the router uses when calculating the default path cost
You can specify a standard for the router to use in automatic calculation for the default path cost. The router supports the following standards:
·           dot1d-1998—The router calculates the default path cost for ports based on IEEE 802.1d-1998.
·           dot1t—The router calculates the default path cost for ports based on IEEE 802.1t.
·           legacy—The router calculates the default path cost for ports based on a private standard.
To specify a standard for the router to use when calculating the default path cost:
Step
Remarks
N/A
2.     Specify a standard for the router to use when calculating the default path costs of its ports.
stp pathcost-standard { dot1d-1998 | dot1t | legacy }
Optional.
The default setting is legacy.
CAUTION
CAUTION:
If you change the standard that the router uses in calculating the default path costs, you restore the path costs to the default.
Table 7 shows the mappings between the link speed and the path cost.
Table 7 Mappings between the link speed and the path cost
Link speed
Port type
Path cost
IEEE 802.1d-1998
IEEE 802.1t
Private standard
0
N/A
65535
200,000,000
200,000
10 Mbps
Single Port
100
2,000,000
2,000
Aggregate interface containing 2 selected ports
1,000,000
1,800
Aggregate interface containing 3 selected ports
666,666
1,600
Aggregate interface containing 4 selected ports
500,000
1,400
100 Mbps
Single Port
19
200,000
200
100,000
180
66,666
160
50,000
140
1000 Mbps
Single Port
4
20,000
20
10,000
18
6666
16
5000
14
10 Gbps
Single Port
2
2000
2
1000
1
666
1
500
1
When calculating path cost for an aggregate interface, IEEE 802.1t takes into account the number of selected ports in its aggregation group, but IEEE 802.1d-1998 does not. The calculation formula of IEEE 802.1t is: Path Cost = 200,000,000/link speed (in 100 kbps), where link speed is the sum of the link speed values of the selected ports in the aggregation group.
To configure the path cost of ports:
Step
Remarks
N/A
3.     Configure the path cost of the ports.
·       In STP/RSTP mode:
stp cost cost
·       In MSTP mode:
stp [ instance instance-id ] cost cost
By default, the system automatically calculates the path cost of each port.
When the path cost of a port changes, the system re-calculates the role of the port and initiates a state transition.
Configuration example
# In MSTP mode, specify the router to calculate the default path costs of its ports by using IEEE 802.1d-1998, and set the path cost of GigabitEthernet 3/1/3 to 200 on MSTI 2.
[Sysname] stp pathcost-standard dot1d-1998
[Sysname] interface gigabitethernet 3/1/3
[Sysname-GigabitEthernet3/1/3] stp instance 2 cost 200
The priority of a port is an important factor in determining whether the port can be elected as the root port of a router. If all other conditions are the same, the port with the highest priority will be elected as the root port.
On a spanning tree router, a port can have different priorities and play different roles in different spanning trees, so that data of different VLANs can be propagated along different physical paths, implementing per-VLAN load balancing. You can set port priority values based on the actual networking requirements.
To configure the priority of a port or a group of ports:
Step
Remarks
N/A
3.     Configure the port priority.
·       In STP/RSTP mode:
stp port priority priority
·       In MSTP mode:
stp [ instance instance-id ] port priority priority
The default setting is 128.
If the port priority changes, the system re-calculates the port role and initiate a state transition.
A point-to-point link directly connects two devices. If two root ports or designated ports are connected over a point-to-point link, they can rapidly transition to the forwarding state after a proposal-agreement handshake process.
To configure the link type of a port or a group of ports:
Step
Remarks
N/A
3.     Configure the port link type.
stp point-to-point { auto | force-false | force-true }
By default, the link type is auto where the port automatically detects the link type.
·       You can configure the link type as point-to-point for a Layer 2 aggregate interface or a port that works in full duplex mode. H3C recommends you to use the default setting and let the router to automatically detect the port link type.
·       The stp point-to-point force-false or stp point-to-point force-true command configured on a port in MSTP mode is effective for all MSTIs.
·       If the physical link to which the port connects is not a point-to-point link but you set it to be one, the configuration may bring a temporary loop.
A port can receive/send MSTP packets in the following formats:
·           dot1s802.1s-compliant standard format
·           legacyCompatible format
By default, the packet format recognition mode of a port is auto. The port automatically distinguishes the two MSTP packet formats, and determines the format of packets it will send based on the recognized format.
You can configure the MSTP packet format on a port. When working in MSTP mode after the configuration, the port sends and receives only MSTP packets of the format you have configured to communicate with routers that send packets of the same format.
To configure the MSTP packet format to be supported on a port or a group of ports:
Step
Remarks
N/A
3.     Configure the mode the port uses to recognize/send MSTP packets.
stp compliance { auto | dot1s | legacy }
The default setting is auto.
·       MSTP provides the MSTP packet format incompatibility guard function. In MSTP mode, if a port is configured to recognize/send MSTP packets in a mode other than auto, and receives a packet in a format different from the specified type, the port will become a designated port and remain in the discarding state to prevent the occurrence of a loop.
·       MSTP provides the MSTP packet format frequent change guard function. If a port receives MSTP packets of different formats frequently, the MSTP packet format configuration contains errors. If the port is working in MSTP mode, it will be shut down for protection. The closed ports can be reactivated after a detection interval. For more information about the detection interval, see Fundamentals Configuration Guide.
You must enable the spanning tree feature for the router before any other spanning tree related configurations can take effect.
To enable the spanning tree feature:
Step
Remarks
N/A
2.     Enable the spanning tree feature globally.
stp enable
By default, the spanning tree feature is disabled.
3.     Enter interface view or port group view.
interface
interface-type interface-number
port-group manual
port-group-name
Use either command.
4.     Enable the spanning tree feature for the port or group of ports.
stp enable
Optional.
By default, the spanning tree feature is enabled for all ports.
You can disable the spanning tree feature for certain ports with the undo stp enable command to exclude them from spanning tree calculation and save CPU resources of the router. However, use this command with caution because the ports with the spanning tree feature disabled will keep forwarding data traffic and discard STP BPDUs, and loops can occur.
Performing mCheck
If a port on a router running MSTP or RSTP connects to an STP router, this port will automatically transition to the STP-compatible mode. However, it cannot automatically transition back to the original mode when:
·           The STP router is shut down or removed.
·           The STP router transitions to the MSTP or RSTP mode.
To forcibly transition the port to operate in the original mode, you can perform an mCheck operation.
You can perform mCheck on a port through the following two approaches, which lead to the same result.
Performing mCheck globally
To perform global mCheck:
Step
2.     Perform mCheck.
stp mcheck
Performing mCheck in interface view
To perform mCheck in interface view:
Step
2.     Enter Ethernet interface view or Layer 2 aggregate interface view.
3.     Perform mCheck.
stp mcheck
An mCheck operation takes effect on a router that operates in MSTP or RSTP mode.
Traffic of a VLAN on a complex network may be blocked by the spanning tree.
Figure 7 VLAN connectivity blocked by MSTP
As shown in Figure 7:
·           Port A1 on Device A allows the traffic of VLAN 1 to pass through, and Port A2 allows the traffic of VLAN 2 to pass through.
·           Port B1 on Device B allows the traffic of VLAN 1 to pass through, and Port B2 allows the traffic of VLAN 2 to pass through.
·           Device A and Device B run a spanning tree protocol. Device A is the root bridge, and Port A1 and Port A2 are designated ports. On Device B, Port B1 is the root port, and port B2 is the blocked port. Traffic of VLAN 2 is blocked.
·           Enabling the VLAN Ignore feature for a VLAN can make ports of the VLAN forward packets normally rather than comply with the spanning tree calculation result.
To configure VLAN Ignore:
Step
Remarks
N/A
2.     Enable VLAN Ignore for the specified VLANs.
stp ignored vlan vlan-list
By default, VLAN Ignore is disabled.
3.     Display VLAN Ignore-enabled VLANs.
display stp ignored-vlan [ | { begin | exclude | include } regular-expression ]
Optional.
VLAN Ignore configuration example
1.      Network requirements
As shown in Figure 8:
¡  Device A and Device B are directly connected.
¡  GigabitEthernet 3/1/1 on Device A and GigabitEthernet 3/1/1 on Device B allow the traffic of VLAN 1 to pass through. GigabitEthernet 3/1/2 on Device A and GigabitEthernet 3/1/2 on Device B allow the traffic of VLAN 2 to pass through.
¡  Device A is the root bridge, and Device A and Device B both run a spanning tree protocol. GigabitEthernet 3/1/2 on Device B is blocked, causing traffic of VLAN 2 to be blocked.
Configure VLAN Ignore to keep GigabitEthernet 3/1/2 of Device B in the forwarding state.
Figure 8 Network diagram
2.      Configuration procedure
# Enable VLAN Ignore for VLAN 2 on Device B.
[DeviceB] stp ignored vlan 2
# Display the VLAN Ignore-enabled VLAN.
[DeviceB] display stp ignored-vlan
 STP-Ignored VLAN: 2
As defined in IEEE 802.1s, interconnected devices are in the same region only when the MST region-related configurations (region name, revision level, VLAN-to-instance mappings) on them are identical. A spanning tree device identifies devices in the same MST region by checking the configuration ID in BPDU packets. The configuration ID includes the region name, revision level, configuration digest that is in 16-byte length and is the result calculated via the HMAC-MD5 algorithm based on VLAN-to-instance mappings.
Spanning tree implementations vary with vendors, and the configuration digests calculated using private keys is different. As a result, devices of different vendors in the same MST region cannot communicate with each other.
To enable communication between an H3C router and a third-party device, enable the Digest Snooping feature on the port connecting the H3C router to the third-party device in the same MST region.
Before enabling Digest Snooping, make sure that associated devices of different vendors are connected and run spanning tree protocols.
Configuring the Digest Snooping feature
You can enable Digest Snooping only on the H3C router that is connected to a third-party device that uses its private key to calculate the configuration digest.
To configure Digest Snooping:
Step
Remarks
N/A
interface
port-group manual
port-group-name
Use either command.
3.     Enable Digest Snooping on the interface or port group.
stp config-digest-snooping
By default, Digest Snooping is disabled on a port.
4.     Return to system view.
N/A
5.     Enable global Digest Snooping.
By default, Digest Snooping is disabled globally.
CAUTION
CAUTION:
·       With the Digest Snooping feature enabled, comparison of configuration digest is not needed for in-the-same-region check, so the VLAN-to-instance mappings must be the same on associated ports.
·       With global Digest Snooping enabled, modification of VLAN-to-instance mappings and removing of the current region configuration using the undo stp region-configuration command are not allowed. You can only modify the region name and revision level.
·       You must enable Digest Snooping both globally and on associated ports to make it take effect. To make the configuration effective on all configured ports and while reducing impact on the network, enable Digest Snooping on all associated ports first and then globally.
·       To prevent loops, do not enable Digest Snooping on MST region edge ports.
·       H3C recommends you to enable Digest Snooping first and then the spanning tree feature. To avoid traffic interruption, do not configure Digest Snooping when the network works well.
Digest Snooping configuration example
As shown in Figure 9, Device A and Device B connect to Device C, which is a third-party device. All these devices are in the same region.
Enable Digest Snooping on Device A’s and Device B’s ports that connect to Device C, so that the three devices can communicate with one another.
Figure 9 Network diagram
# Enable Digest Snooping on GigabitEthernet 3/1/1 of Device A and enable global Digest Snooping on Device A.
[DeviceA] interface gigabitethernet 3/1/1
[DeviceA-GigabitEthernet3/1/1] stp config-digest-snooping
[DeviceA-GigabitEthernet3/1/1] quit
[DeviceA] stp config-digest-snooping
# Enable Digest Snooping on GigabitEthernet 3/1/1 of Device B and enable global Digest Snooping on Device B.
[DeviceB] interface gigabitethernet 3/1/1
[DeviceB-GigabitEthernet3/1/1] stp config-digest-snooping
[DeviceB-GigabitEthernet3/1/1] quit
[DeviceB] stp config-digest-snooping
In RSTP and MSTP, the following types of messages are used for rapid state transition on designated ports:
·           ProposalSent by designated ports to request rapid transition
·           AgreementUsed to acknowledge rapid transition requests
Both RSTP and MSTP devices can perform rapid transition on a designated port only when the port receives an agreement packet from the downstream device. RSTP and MSTP devices have the following differences:
·           For MSTP, the downstream device’s root port sends an agreement packet only after it receives an agreement packet from the upstream device.
·           For RSTP, the down stream device sends an agreement packet regardless of whether an agreement packet from the upstream device is received.
Figure 10 shows the rapid state transition mechanism on MSTP designated ports.
Figure 10 Rapid state transition of an MSTP designated port
Figure 11 shows rapid state transition of an RSTP designated port.
Figure 11 Rapid state transition of an RSTP designated port
If the upstream device is a third-party device, the rapid state transition implementation may be limited. For example, when the upstream device uses a rapid transition mechanism similar to that of RSTP, and the downstream device adopts MSTP and does not work in RSTP mode, the root port on the downstream device receives no agreement packet from the upstream device and sends no agreement packets to the upstream device. As a result, the designated port of the upstream device fails to transit rapidly and can only change to the forwarding state after a period twice the Forward Delay.
You can enable the No Agreement Check feature on the downstream device’s port to enable the designated port of the upstream device to transit its state rapidly.
Configuration Prerequisites
Before you configure the No Agreement Check function, complete the following tasks:
·           Connect a router to a third-party upstream router supporting spanning tree protocols via a point-to-point link.
·           Configure the same region name, revision level and VLAN-to-instance mappings on the two routers, assigning them to the same region.
Configuring the No Agreement Check function
To make the No Agreement Check feature take effect, enable it on the root port.
To configure No Agreement Check:
Step
Remarks
N/A
interface
port-group manual
port-group-name
Use either command.
3.     Enable No Agreement Check.
stp no-agreement-check
By default, No Agreement Check is disabled.
No Agreement Check configuration example
As shown in Figure 12:
¡  Device A connects to Device B, a third-party device that has a different spanning tree implementation. Both devices are in the same region.
¡  Device B is the regional root bridge, and Device A is the downstream device.
Figure 12 Network diagram
# Enable No Agreement Check on GigabitEthernet 3/1/1 of Device A.
[DeviceA-GigabitEthernet3/1/1] stp no-agreement-check
A spanning tree device supports the following protection functions:
·           BPDU guard
·           Root guard
·           Loop guard
·           TC-BPDU guard
Configuration prerequisites
The spanning tree feature has been correctly configured on the router.
Enabling BPDU guard
For access layer devices, the access ports can directly connect to the user terminals (such as PCs) or file servers. The access ports are configured as edge ports to allow rapid transition. When these ports receive configuration BPDUs, the system will automatically set these ports as non-edge ports and start a new spanning tree calculation process. This will cause a change of network topology. Under normal conditions, these ports should not receive configuration BPDUs. However, if someone forges configuration BPDUs maliciously to attack the devices, the network will become instable.
The spanning tree protocol provides the BPDU guard function to protect the system against such attacks. With the BPDU guard function enabled on the routers, when edge ports receive configuration BPDUs, the system will close these ports and notify the NMS that these ports have been closed by the spanning tree protocol. The closed ports will be re-activated by the router after a detection interval. For more information about this detection interval, see Fundamentals Configuration Guide.
Make this configuration on a router with edge ports configured.
To enable BPDU guard:
Step
Remarks
N/A
2.     Enable the BPDU guard function for the router.
stp bpdu-protection
By default, BPDU guard is disabled.
BPDU guard does not take effect on loopback test-enabled ports. For more information about loopback testing, see Interface Configuration Guide.
Enabling root guard
H3C recommends you to enable root guard.
The root bridge and secondary root bridge of a spanning tree should be located in the same MST region. Especially for the CIST, the root bridge and secondary root bridge are put in a high-bandwidth core region during network design. However, due to possible configuration errors or malicious attacks in the network, the legal root bridge may receive a configuration BPDU with a higher priority. The current legal root bridge will be superseded by another router, causing an undesired change of the network topology. As a result, the traffic that should go over high-speed links is switched to low-speed links, resulting in network congestion.
To prevent this situation from happening, MSTP provides the root guard function. If the root guard function is enabled on a port of a root bridge, this port will keep playing the role of designated port on all MSTIs. Once this port receives a configuration BPDU with a higher priority from an MSTI, it immediately sets that port to the listening state in the MSTI, without forwarding the packet (this is equivalent to disconnecting the link connected with this port in the MSTI). If the port receives no BPDUs with a higher priority within twice the forwarding delay, it will revert to its original state.
Make this configuration on a designated port.
To enable root guard:
Step
Remarks
N/A
interface
port-group manual
port-group-name
Use either command.
3.     Enable the root guard function for the port(s).
stp root-protection
By default, root guard is disabled.
Enabling loop guard
By keeping receiving BPDUs from the upstream device, a router can maintain the state of the root port and blocked ports. However, due to link congestion or unidirectional link failures, these ports may fail to receive BPDUs from the upstream devices. The router will reselect the port roles: Those ports in forwarding state that failed to receive upstream BPDUs will become designated ports, and the blocked ports will transition to the forwarding state, resulting in loops in the switched network. The loop guard function can suppress the occurrence of such loops.
The initial state of a loop guard-enabled port is discarding in every MSTI. When the port receives BPDUs, its state transitions normally. Otherwise, it stays in the discarding state to prevent temporary loops.
Make this configuration on the root port and alternate ports of a router.
To enable loop guard:
Step
Remarks
N/A
Use either command.
3.     Enable the loop guard function for the ports.
stp loop-protection
By default, loop guard is disabled.
·       Do not enable loop guard on a port connecting user terminals. Otherwise, the port will stay in the discarding state in all MSTIs because it cannot receive BPDUs.
Enabling TC-BPDU guard
When receiving topology change (TC) BPDUs (the BPDUs used to notify topology changes), a router flushes its forwarding address entries. If someone forges TC-BPDUs to attack the router, the router will receive a large number of TC-BPDUs within a short time and be busy with forwarding address entry flushing. This affects network stability.
With the TC-BPDU guard function, you can set the maximum number of immediate forwarding address entry flushes that the router can perform every a certain period of time (10 seconds). For TC-BPDUs received in excess of the limit, the router performs forwarding address entry flush when the time period expires. This prevents frequent flushing of forwarding address entries.
To enable TC-BPDU guard:
Step
Remarks
N/A
2.     Enable the TC-BPDU guard function.
stp tc-protection enable
Optional.
By default, TC-BPDU guard is enabled.
3.     Configure the maximum number of forwarding address entry flushes that the router can perform every 10 seconds.
stp tc-protection threshold number
Optional.
The default setting is 6.
H3C does not recommend you disable this feature.
Displaying and maintaining the spanning tree
Remarks
Display information about ports blocked by spanning tree protection functions.
display stp abnormal-port [ | { begin | exclude | include } regular-expression ]
Display BPDU statistics on ports.
display stp bpdu-statistics [ interface interface-type interface-number [ instance instance-id ] ] [ | { begin | exclude | include } regular-expression ]
Display information about ports shut down by spanning tree protection functions.
display stp down-port [ | { begin | exclude | include } regular-expression ]
Display the historical information of port role calculation for the specified MSTI or all MSTIs.
display stp [ instance instance-id  ] history [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the statistics of TC/TCN BPDUs sent and received by all ports in the specified MSTI or all MSTIs.
display stp [ instance instance-id ] tc [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display the spanning tree status and statistics.
display stp [ instance instance-id ] [ interface interface-list | slot slot-number ] [ brief ] [ | { begin | exclude | include } regular-expression ]
Display the MST region configuration information that has taken effect.
Display the root bridge information of all MSTIs.
display stp root [ | { begin | exclude | include } regular-expression ]
Display the list of VLANs with VLAN Ignore enabled.
Clear the spanning tree statistics.
reset stp [ interface interface-list ]
Available in user view
MSTP configuration example
As shown in Figure 13, all devices on the network are in the same MST region, Device A and Device B work at the distribution layer, and Device C and Device D work at the access layer.
Configure MSTP so that packets of different VLANs are forwarded along different spanning trees: Packets of VLAN 10 are forwarded along MSTI 1, those of VLAN 30 are forwarded along MSTI 3, those of VLAN 40 are forwarded along MSTI 4, and those of VLAN 20 are forwarded along MSTI 0.
VLAN 10 and VLAN 30 are terminated on the distribution layer devices, and VLAN 40 is terminated on the access layer devices, so the root bridges of MSTI 1 and MSTI 3 are Device A and Device B respectively, and the root bridge of MSTI 4 is Device C.
Figure 13 Network diagram
1.      Configure VLANs and VLAN member ports. (Details not shown)
Create VLAN 10, VLAN 20, and VLAN 30 on Device A and Device B respectively, VLAN 10, VLAN 20, and VLAN 40 on Device C, and VLAN 20, VLAN 30, and VLAN 40 on Device D. Configure the ports on these devices as trunk ports and assign them to related VLANs.
2.      Configure Device A:
# Enter MST region view, configure the MST region name as example, map VLAN 10, VLAN 30, and VLAN 40 to MSTI 1, MSTI 3, and MSTI 4 respectively, and configure the revision level of the MST region as 0.
[DeviceA] stp region-configuration
[DeviceA-mst-region] region-name example
[DeviceA-mst-region] instance 1 vlan 10
[DeviceA-mst-region] instance 3 vlan 30
[DeviceA-mst-region] instance 4 vlan 40
[DeviceA-mst-region] revision-level 0
# Activate MST region configuration.
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
# Specify the current device as the root bridge of MSTI 1.
[DeviceA] stp instance 1 root primary
# Enable the spanning tree feature globally.
[DeviceA] stp enable
3.      Configure Device B:
[DeviceB] stp region-configuration
[DeviceB-mst-region] region-name example
[DeviceB-mst-region] instance 1 vlan 10
[DeviceB-mst-region] instance 3 vlan 30
[DeviceB-mst-region] instance 4 vlan 40
[DeviceB-mst-region] revision-level 0
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
# Specify the current device as the root bridge of MSTI 3.
[DeviceB] stp instance 3 root primary
[DeviceB] stp enable
4.      Configure Device C:
<DeviceC> system-view
[DeviceC-mst-region] region-name example
[DeviceC-mst-region] instance 1 vlan 10
[DeviceC-mst-region] instance 3 vlan 30
[DeviceC-mst-region] instance 4 vlan 40
[DeviceC-mst-region] revision-level 0
[DeviceC-mst-region] quit
# Specify the current device as the root bridge of MSTI 4.
[DeviceC] stp instance 4 root primary
[DeviceC] stp enable
5.      Configure Device D:
<DeviceD> system-view
[DeviceD-mst-region] region-name example
[DeviceD-mst-region] instance 1 vlan 10
[DeviceD-mst-region] instance 3 vlan 30
[DeviceD-mst-region] instance 4 vlan 40
[DeviceD-mst-region] revision-level 0
[DeviceD-mst-region] quit
[DeviceD] stp enable
6.      Verify the configurations:
You can use the display stp brief command to display brief spanning tree information on each device after the network is stable.
# Display brief spanning tree information on Device A.
[DeviceA] display stp brief
 MSTID      Port                         Role  STP State     Protection
   0        GigabitEthernet4/1/1         ALTE  DISCARDING    NONE
   0        GigabitEthernet4/1/2         DESI  FORWARDING    NONE
   0        GigabitEthernet4/1/3         ROOT  FORWARDING    NONE
   1        GigabitEthernet4/1/1         DESI  FORWARDING    NONE
   1        GigabitEthernet4/1/3         DESI  FORWARDING    NONE
   3        GigabitEthernet4/1/2         DESI  FORWARDING    NONE
   3        GigabitEthernet4/1/3         ROOT  FORWARDING    NONE
# Display brief spanning tree information on Device B.
[DeviceB] display stp brief
   0        GigabitEthernet4/1/1         DESI  FORWARDING    NONE
   0        GigabitEthernet4/1/3         DESI  FORWARDING    NONE
   1        GigabitEthernet4/1/2         DESI  FORWARDING    NONE
   1        GigabitEthernet4/1/3         ROOT  FORWARDING    NONE
   3        GigabitEthernet4/1/1         DESI  FORWARDING    NONE
   3        GigabitEthernet4/1/3         DESI  FORWARDING    NONE
# Display brief spanning tree information on Device C.
[DeviceC] display stp brief
   0        GigabitEthernet4/1/2         ROOT  FORWARDING    NONE
   1        GigabitEthernet4/1/1         ROOT  FORWARDING    NONE
   1        GigabitEthernet4/1/2         ALTE  DISCARDING    NONE
   4        GigabitEthernet4/1/3         DESI  FORWARDING    NONE
# Display brief spanning tree information on Device D.
[DeviceD] display stp brief
   0        GigabitEthernet4/1/1         ROOT  FORWARDING    NONE
   0        GigabitEthernet4/1/2         ALTE  DISCARDING    NONE
   0        GigabitEthernet4/1/3         ALTE  DISCARDING    NONE
   3        GigabitEthernet4/1/1         ROOT  FORWARDING    NONE
   3        GigabitEthernet4/1/2         ALTE  DISCARDING    NONE
   4        GigabitEthernet4/1/3         ROOT  FORWARDING    NONE
Based on the output, you can draw the MSTI mapped to each VLAN, as shown in Figure 14.
Figure 14 MSTIs mapped to different VLANs
