02-Interface Configuration Guide
HomeSupportRoutersSR8800 SeriesConfigure & DeployConfiguration GuidesH3C SR8800 Configuration Guide-Release3347-6W10302-Interface Configuration Guide
06-Loopback and Null Interface Configuration
06-Loopback and Null Interface Configuration 95.5 KB
Loopback interface
Introduction
A loopback interface is a software-only virtual interface. It delivers the following benefits.
·           The physical layer state and link layer protocols of a loopback interface are always up unless the loopback interface is manually shut down.
·           You must assign a loopback interface an IP address with an all-F mask to save the IP address resources. When you assign an IPv4 address whose mask is not 32-bit, the system automatically changes the mask into a 32-bit mask. When you assign an IPv6 address whose mask is not 128-bit, the system automatically changes the mask into a 128-bit mask.
·           You can enable routing protocols on a loopback interface, and a loopback interface can send and receive routing protocol packets.
Because of the benefits mentioned above, loopback interfaces are widely used in the following scenarios
·           You can configure a loopback interface address as the source address of the IP packets that the device generates. Because loopback interface addresses are stable unicast addresses, they are usually used as device identifications. Therefore, when you configure a rule on an authentication or security server to permit or deny packets generated by a device, you can simplify the rule by configuring it to permit or deny packets carrying the loopback interface address identifying the device. Note that, when you use a loopback interface address as the source address of IP packets, make sure that the route from the loopback interface to the peer is reachable by performing routing configuration. All data packets sent to the loopback interface are considered as packets sent to the device itself, so the device does not forward these packets.
·           Because a loopback interface is always up unless you manually shut it down, it can be used in dynamic routing protocols. For example, if no router ID is configured for a dynamic routing protocol, the highest loopback interface IP address is selected as the router ID. In BGP, to avoid BGP sessions being interrupted by physical port failure, you can use a loopback interface as the source interface of BGP packets.
Configuring a loopback interface
To configure a loopback interface:
Step
Remarks
1.     Enter system view.
N/A
2.     Create a Loopback interface and enter loopback interface view.
interface loopback interface-number
The loopback interface number ranges from 0 to 1023.
3.     Set a description for the loopback interface.
Optional.
By default, the description of an interface is the interface name followed by the “Interface” string.
4.     Shut down the loopback interface.
shutdown
Optional.
A loopback interface is up once created.
5.     Restore the default settings.
default
Optional.
CAUTION
CAUTION:
Parameters such as IP addresses can be configured on loopback interfaces. For more information, see Layer 3IP Services Configuration Guide.
Null interface
Introduction
A null interface is a completely software-based logical interface, and is always up. However, you cannot use it to forward data packets or configure an IP address or link layer protocol on it. With a null interface specified as the next hop of a static route to a specific network segment, any packets routed to the network segment are dropped. The null interface provides a simpler way to filter packets than ACL. You can filter uninteresting traffic by transmitting it to a null interface instead of applying an ACL.
For example, by executing the ip route-static 92.101.0.0 255.255.0.0 null 0 command (which configures a static route leading to null interface 0), you can have all the packets destined for the network segment 92.101.0.0/16 discarded.
Currently, only one null interface, interface Null 0, is supported on your router. You cannot remove or create a null interface.
Configuring interface Null 0
To configure interface Null 0:
Step
Remarks
6.     Enter system view.
N/A
7.     Enter null interface view.
interface null 0
Interface Null 0 is the default null interface on a router. It can neither be created nor removed.
8.     Set a description for the null interface.
Optional.
9.     Restore the default settings.
default
Optional.
Displaying and maintaining loopback and null interfaces
Remarks
Display information about loopback interfaces.
display interface [ loopback ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface loopback interface-number [ brief ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Display information about the null interface.
display interface [ null ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface null 0 [ brief ] [ | { begin | exclude | include } regular-expression ]
Clear the statistics on a loopback interface or the null interface.
reset counters interface [ interface-type [ interface-number ] ]
Available in user view
