05-Layer 3 - IP Services Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10305-Layer 3 - IP Services Command Reference
14-GRE Commands
14-GRE Commands 56.51 KB
GRE configuration commands
tunnel-protocol gre
tunnel-protocol gre
undo tunnel-protocol
View
Tunnel interface view
Default level
2: System level
None
Use the tunnel-protocol gre command to set the GRE tunnel mode.
Use the undo tunnel-protocol to restore the default.
By default, the GRE tunnel mode is GRE over IPv4.
Select a tunnel mode according to the network topology and application. Both ends of a tunnel must be configured with the same tunnel mode. Otherwise, packet delivery will fail.
Related commands: interface tunnel.
# On router Sysname1, set the tunnel mode to GRE for the tunnel between Sysname1 and Sysname2.
<Sysname1> system-view
[Sysname1] interface tunnel 1
[Sysname1-Tunnel1] tunnel-protocol gre
# On router Sysname2, set the tunnel mode to GRE for the tunnel between Sysname1 and Sysname2.
<Sysname2> system-view
[Sysname2] interface tunnel 2
[Sysname2-Tunnel2] tunnel-protocol gre
