05-Layer 3 - IP Services Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10305-Layer 3 - IP Services Command Reference
13-Tunneling Commands
13-Tunneling Commands 141.02 KB
default
default
View
Tunnel interface view
Default level
2: System level
None
Use the default command to restore the default settings for the tunnel interface.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. You can use the display this command in interface view to check for these commands, and perform their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure that you are fully aware of the impacts of this command when you perform it on a live network.
# Restore the default settings of interface tunnel 10.
[Sysname] interface tunnel 10
[Sysname-Tunnel10] default
This command will restore the default settings. Continue? [Y/N]:y
description
View
Default level
2: System level
text: Description of an interface, a string of 1 to 80 characters.
Use the description command to configure a description for the current interface.
Use the undo description command to restore the default.
By default, the description of a tunnel interface is Tunnelnumber Interface, for example, Tunnel1 Interface.
Related commands: display interface tunnel.
# Configure the description of interface Tunnel 1 as tunnel1.
[Sysname-Tunnel1] description tunnel1
destination
destination ip-address
undo destination
View
Default level
2: System level
ip-address: Tunnel destination IPv4 address.
Use the command destination to specify the destination address for the tunnel interface.
Use the undo destination command to remove the configured tunnel destination address.
By default, no tunnel destination address is configured.
Note that:
The tunnel destination address is the address of the peer interface receiving packets and must be configured as the source address of the peer tunnel interface.
Related commands: display interface tunnel, display ipv6 interface tunnel, interface tunnel, and source.
# Configure interface GigabitEthernet 2/1/1 (193.101.1.1) of Sysname 1 and interface GigabitEthernet 2/1/1 (192.100.1.1) of Sysname 2 as the source and destination interfaces of a tunnel between the two routers, respectively.
<Sysname1> system-view
[Sysname1] interface Tunnel 1
[Sysname1-Tunnel1] source 193.101.1.1
[Sysname1-Tunnel1] destination 192.100.1.1
<Sysname2> system-view
[Sysname2] interface Tunnel 2
[Sysname2-Tunnel2] source 192.100.1.1
[Sysname2-Tunnel2] destination 193.101.1.1
display interface [ tunnel ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface tunnel number [ brief ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
number: Number of a tunnel interface. With this argument, the command displays information about the specified tunnel interface.
down: Displays information about interfaces in the DOWN state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display interface tunnel command to display information about a tunnel interface, such as source address, destination address, and tunnel mode.
·           If you do not specify the tunnel keyword, this command displays information about all interfaces on the device.
·           If you specify the tunnel keyword without the number argument, this command displays information about all existing tunnel interfaces.
Related commands: destination, interface tunnel, source, and tunnel-protocol.
# Display detailed information about interface Tunnel 0.
<Sysname> display interface tunnel 0
Tunnel0 current state: UP
The Maximum Transmit Unit is 1476
Internet Address is 10.1.2.1/24 Primary
Encapsulation is TUNNEL, service-loopback-group ID not set
Tunnel source 192.13.2.1, destination 192.13.2.2
Tunnel bandwidth 64 (kbps)
Tunnel protocol/transport GRE/IP
    GRE key disabled
    Checksumming of GRE packets disabled
Last clearing of counters:  Never
    Last 300 seconds input:  0 bytes/sec, 0 packets/sec
    Last 300 seconds output:  0 bytes/sec, 0 packets/sec
    361 packets input,  9953388 bytes
    0 input error
    361 packets output,  30324 bytes
    0 output error
Table 1 Output description
Physical state of the tunnel interface, which can be:
·       DOWN (Administratively)—Indicates that the interface is administratively down; that is, the interface is shut down with the shutdown command.
·       DOWN—Indicates that the interface is administratively up but its physical state is down.
·       UP—Indicates that both the administrative and physical states of the interface are up.
Link layer state of the tunnel interface, which can be:
·       DOWN—Indicates that the protocol state of the interface is down.
·       UP—Indicates that the protocol state of the interface is up.
Descriptive information of a tunnel interface.
Maximum transmit unit allowed on the tunnel interface.
Internet Address
IP address of the tunnel interface.
If no IP address is assigned to the interface, "Internet protocol processing: disabled" will be displayed, which means that packets cannot be processed.
"Primary" indicates the primary IP address of the interface; "Sub" indicates a secondary IP address of the interface.
The encapsulation protocol is tunnel.
ID of the service loopback group referenced by the tunnel.
If service loopback group is not supported or not specified, "service-loopback-group ID not set" will be displayed.
Tunnel source
Tunnel source address.
destination
Tunnel destination address.
Tunnel bandwidth
Bandwidth of the tunnel interface.
Tunnel mode and transport protocol, which can be:
·       GRE/IP—GRE over IPv4 tunnel mode
·       IP/IP—IPv4 over IPv4 tunnel mode
·       IPv6/IP—IPv6 over IPv4 manual tunnel mode
·       IPv6/IP 6to4—IPv6 over IPv4 6to4 tunnel mode
·       IPv6/IP auto-tunnel—Automatic IPv6 over IPv4 tunnel mode
·       IPv6/IP ISATAP—IPv6 over IPv4 ISATAP tunnel mode
·       CR_LSP—MPLS TE tunnel mode
GRE key disabled
No key is configured for the GRE tunnel interface.
Disables the GRE packet checksum function.
Last time of clearing of counters.
Average input rate in the last 300 seconds in bytes/sec or packets/sec.
Average output rate in the last 300 seconds in bytes/sec or packets/sec.
packets input
Total number of input packets.
input error
Number of error packets among all input packets.
packets output
Total number of output packets.
output error
Number of error packets in all output packets.
# Display brief information about interface Tunnel 0.
<Sysname> display interface tunnel 0 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Tun0                 UP   UP       1.1.1.1
# Display brief information about interface Tunnel 1 in the DOWN state.
<Sysname> display interface tunnel brief down
Tun1                 DOWN Not connected
Table 2 Output description
Brief information about Layer 3 interfaces.
Link status:
·       ADM—The interface has been administratively shut down. To recover its physical state, perform the undo shutdown command.
·       Stby—The interface is a backup interface. To see the primary interface, use the display standby state command (see High Availability Command Reference).
(s) indicates that the network layer protocol state is UP, but the link is not available because it is an on-demand link or not present at all.
Abbreviated interface name.
Link
Physical link state of the interface:
·       UP—The link is up.
·       DOWN—The link is down.
·       ADM—The link has been administratively shut down. To bring it up, perform the undo shutdown command.
Protocol
Protocol state:
·       DOWN—The protocol is disabled.
·       UP—The protocol is enabled.
Main IP
Primary IP address of the interface.
Description of the interface.
Cause
Cause of a DOWN physical link. If the port has been shut down with the shutdown command, this field displays Administratively. To bring up the interface, use the undo shutdown command.
display ipv6 interface tunnel [ number ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
number: Tunnel interface number. If no interface number is specified, IPv6 information about all tunnel interfaces will be displayed.
verbose: Displays detailed IPv6 information and IPv6 packet statistics of a tunnel interface. If this keyword is not specified, brief IPv6 information of a tunnel interface is displayed.
Use the display ipv6 interface tunnel command to display IPv6 information of a tunnel interface.
# Display detailed IPv6 information and IPv6 packet statistics of interface Tunnel 0.
<Sysname> display ipv6 interface tunnel 0 verbose
Tunnel0 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::202:201
  Global unicast address(es):
    3000:101:101::1, subnet is 3000::/64
  Joined group address(es):
    FF02::1:FF02:201
    FF02::1:FF00:1
    FF02::1:FF00:0
    FF02::2
    FF02::1
  MTU is 1480 bytes
IPv6 Packet statistics:
  InReceives:                    45
  InTooShorts:                   0
  InTruncatedPkts:               0
  InHopLimitExceeds:             0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    45
  OutRequests:                   45
  OutForwDatagrams:              0
  InNoRoutes:                    0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   0
  InMcastNotMembers:             0
  OutMcastPkts:                  0
  InAddrErrors:                  0
Table 3 Output description
Physical state of the tunnel interface:
·       Administratively DOWN—Indicates that the interface is administratively down; that is, the interface is shut down with the shutdown command.
Link layer state of the tunnel interface:
IPv6 is enabled
IPv6 packet forwarding state of the tunnel interface. IPv6 packet forwarding is automatically enabled after an IPv6 address is assigned to the interface. IPv6 is enabled on the tunnel interface in this example.
link-local address
Link-local address of a tunnel interface.
Aggregatable global unicast address of a tunnel interface.
Multicast address of a tunnel interface.
MTU is 1480 bytes
Size of the MTU in a tunnel. The MTU in this example is 1480 bytes.
ND reachable time
Neighbor reachable time.
Interval for retransmitting a neighbor discovery request message.
Hosts use the stateless autoconfiguration mode to acquire IPv6 addresses.
InReceives
Number of all IPv6 packets received on the tunnel interface, including error packets.
InTooShorts
Number of IPv6 packets that are too short in length received on the tunnel interface, such as a packet with a length less than 40 bytes.
InTruncatedPkts
Number of IPv6 packets received on the tunnel interface, with a length less than that specified in the packet header.
InHopLimitExceeds
Number of IPv6 packets that exceeded the hop limit received on the tunnel interface.
InBadHeaders
Number of IPv6 packets with wrong basic headers received on the tunnel interface.
InBadOptions
Number of IPv6 packets with wrong extension headers received on the tunnel interface.
ReasmReqds
Number of IPv6 fragments received on the tunnel interface.
ReasmOKs
Number of IPv6 datagrams reassembled on the tunnel interface.
InFragDrops
Number of wrong IPv6 fragments discarded on the tunnel interface.
InFragTimeouts
Number of IPv6 fragments discarded on the interface because they had stayed in the cache longer than the specified time.
OutFragFails
Number of IPv6 Packets that failed to be fragmented on the outbound tunnel interface.
InUnknownProtos
Number of IPv6 packets received on the tunnel interface, with an unknown or unsupported protocol type.
InDelivers
Number of IPv6 packets delivered to the upper-layer IPv6 protocols (such as ICMPv6, TCP, or UDP) from the tunnel interface.
OutRequests
Number of local IPv6 packets from the upper-layer IPv6 protocols.
OutForwDatagrams
Number of IPv6 packets forwarded by the outbound tunnel interface.
InNoRoutes
Number of IPv6 packets discarded on the interface because no matching route is found.
InTooBigErrors
Number of IPv6 packets discarded on the interface due to exceeding the MTU value.
OutFragOKs
Number of packets that are successfully fragmented on the outbound interface.
OutFragCreates
Number of fragments on the outbound interface.
InMcastPkts
Number of IPv6 multicast packets received on the interface.
InMcastNotMembers
Number of IPv6 multicast packets discarded on the interface because the interface does not belong to the corresponding multicast groups.
OutMcastPkts
Number of IPv6 multicast packets sent on the interface.
InAddrErrors
Number of IPv6 packets discarded on the interface due to illegal destination addresses.
InDiscards
Number of IPv6 packets received but then discarded on the interface due to resource problems rather than packet content errors
OutDiscards
Number of IPv6 packets sent on the interface but then discarded due to resource problems rather than packet content errors.
# Display brief IPv6 information of interface Tunnel 0.
*down: administratively down
(s): spoofing
Interface                                Physical   Protocol   IPv6 Address
Tunnel0                                up         up       3000::1
Table 4 Output description
*down
The tunnel interface is in administrative down state, meaning the interface is shut down using the shutdown command.
(s)
Spoofing feature of the tunnel interface. That is, although the link-layer protocol state of the interface is up, no such link exists, or the link is not a permanent one and can only be established as needed.
Name of the tunnel interface.
Physical
·       *down—Indicates that the interface is administratively down; that is, the interface is shut down with the shutdown command.
·       down—Indicates that the interface is administratively up but its physical state is down.
·       up—Indicates that both the administrative and physical states of the interface are up.
Protocol
Link-layer protocol state of the tunnel interface:
·       down—Indicates that the protocol state of the interface is down.
·       up—Indicates that the protocol state of the interface is up.
IPv6 Address
IPv6 address of the tunnel interface. Only the first configured IPv6 address is displayed. (If no IPv6 address is configured, Unassigned is displayed.)
interface tunnel
undo interface tunnel number
View
Default level
2: System level
number: Tunnel interface number, in the range of 0 to 1023. The number of tunnels that can be created is restricted to the total number of interfaces and the memory.
Use the interface tunnel command to create a tunnel interface and enter tunnel interface view.
Use the undo interface tunnel command to remove a specified tunnel interface.
By default, there is no tunnel interface on the router.
·           Use the interface tunnel command to enter interface view of a specified tunnel. If the tunnel interface is not created, you must create it before entering its view.
·           A tunnel interface number has only local significance, and therefore, the same interface number or different interface numbers can be set at both ends of a tunnel.
Related commands: destination, display interface tunnel, display ipv6 interface tunnel, source, and tunnel-protocol.
# Create interface Tunnel 3 and enter tunnel interface view.
[Sysname] interface Tunnel 3
[Sysname-Tunnel3]
mtu (tunnel interface view)
mtu mtu-size
undo mtu
View
Default level
2: System level
mtu-size: MTU for IPv4 packets on the interface, in bytes, in the range of 46 to 10240.
Use the mtu command to set the MTU for IPv4 packets on an interface.
Use the undo mtu command to restore the default.
The default MTU for IPv4 packets on an interface is 1500 bytes.
# Set the MTU for IPv4 packets on Tunnel 3 to 10000 bytes.
[Sysname] interface tunnel 3
[Sysname-Tunnel3] mtu 10000
reset counters interface
reset counters interface [ tunnel [ number ] ]
View
Default level
2: System level
number: Tunnel interface number, in the range of 0 to 1023. The number of tunnels that can be created depends on the total number of interfaces and interface memory.
Use the reset counters interface command to clear the statistics of tunnel interfaces.
Before sampling network traffic within a specific period of time on an interface, you need to clear the existing statistics.
·           If neither the tunnel keyword nor interface number is specified, this command clears the statistics of all interfaces.
·           If only the tunnel keyword is specified, this command clears the statistics of all tunnel interfaces.
·           If both the tunnel keyword and interface number are specified, this command clears the statistics of the specified tunnel interface.
# Clear the statistics of Tunnel 3.
<Sysname> reset counters interface tunnel 3
shutdown
shutdown
View
Default level
2: System level
None
Use the shutdown command to shut down a tunnel interface.
Use the undo shutdown command to bring up a tunnel interface.
By default, a tunnel interface is in the up state.
# Shut down interface Tunnel 1.
[Sysname-Tunnel1] shutdown
source
source { ip-address | interface-type interface-number }
undo source
View
Default level
2: System level
ip-address: Tunnel source IPv4 address.
interface-type interface-number: Specifies an interface.
interface-type interface-number: Specifies an interface. The interface types include Ethernet, serial, ATM, tunnel, and loopback.
Use the source command to specify the source address for the tunnel interface.
Use the undo source command to remove the configured tunnel source address.
By default, no tunnel source address is configured.
The tunnel source address is the address of the interface sending packets and should be configured as the destination address of the peer tunnel interface.
Related commands: destination, display interface tunnel, display ipv6 interface tunnel, and interface tunnel.
# Set the tunnel source address to 192.100.1.1 (or VLAN-interface 10) on interface Tunnel 5.
[Sysname] interface tunnel 5
[Sysname-Tunnel5] source 192.100.1.1
tunnel bandwidth
tunnel bandwidth bandwidth-value
undo tunnel bandwidth
View
Default level
2: System level
bandwidth-value: Bandwidth value of the tunnel interface in kbps, in the range of 1 to 10000000.
Use the tunnel bandwidth command to set the bandiwith value of the tunnel interface.
Use the undo tunnel bandwidth command to restore the default.
By default, the bandwidth of the tunnel interface is 64 kbps.
The tunnel interface bandwidth set with the tunnel bandwidth command is for dynamical routing protocols to calculate the cost of a tunnel path, rather than changes the bandwidth of the tunnel interface. Refer to the bandwidth of the output interface of the packet when you set the bandwidth of the tunnel interface.
# Configure the bandwidth of Tunnel 0 as 100 kbps.
[Sysname] interface tunnel 0
[Sysname-Tunnel0] tunnel bandwidth 100
tunnel discard ipv4-compatible-packet
undo tunnel discard ipv4-compatible-packet
View
Default level
2: System level
None
Use the tunnel discard ipv4-compatible-packet command to enable dropping of IPv6 packets using IPv4-compatible IPv6 addresses.
Use the undo tunnel discard ipv4-compatible-packet command to restore the default.
By default, IPv6 packets using IPv4-compatible IPv6 addresses are not dropped.
The tunnel discard ipv4-compatible-packet command enables the device to check the source and destination IPv6 addresses of the de-encapsulated IPv6 packets from the tunnel and discard packets that use a source or destination IPv4-compatible IPv6 address.
# Enable dropping of IPv6 packets using IPv4-compatible IPv6 addresses.
[Sysname] tunnel discard ipv4-compatible-packet
tunnel-protocol
tunnel-protocol { ipv4-ipv4 | gre | ipv6-ipv4 [ 6to4 | auto-tunnel | isatap ] | mpls te }
undo tunnel-protocol
View
Default level
2: System level
ipv4-ipv4: Sets the tunnel to an IPv4 over IPv4 tunnel.
gre: Specifies the GRE over IPv4 tunnel mode.
ipv6-ipv4: Sets the tunnel to an IPv6 over IPv4 tunnel.
ipv6-ipv4 6to4: Sets the tunnel to IPv6 over IPv4 6to4 tunnel.
ipv6-ipv4 auto-tunnel: Sets the tunnel to an automatic IPv4 compatible IPv6 tunnel.
ipv6-ipv4 isatap: Sets the tunnel to an IPv6 over IPv4 ISATAP tunnel.
mpls te: Sets the tunnel to an MPLS TE tunnel.
Use the tunnel-protocol command to configure the tunnel type.
Use the undo tunnel-protocol to restore the default.
By default, the tunnel is a GRE tunnel.
Note that:
·           A proper tunnel type can be selected for packet encapsulation according to the network topology and application. The same tunnel type must be configured at both ends of the tunnel. Otherwise, packet delivery will fail.
·           Only one automatic tunnel can be configured at the same tunnel source.
For more information about MPLS TE tunnels, see MPLS TE Configuration Guide.
The router does not support IPv4 over IPv4 tunnels when working in hybrid or SPC mode. For more information about the system working modes, see Fundamentals Configuration Guide.
# Specify the tunnel type as GRE tunnel for a tunnel interface.
[Sysname] interface tunnel 4
[Sysname-Tunnel4] tunnel-protocol gre
