05-Layer 3 - IP Services Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10305-Layer 3 - IP Services Command Reference
10-DHCPv6 Commands
10-DHCPv6 Commands 72.72 KB
DHCPv6 configuration commands
display ipv6 dhcp duid
display ipv6 dhcp duid [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display ipv6 dhcp duid command to display the DUID of the local router.
# Display the DUID of the device.
<Sysname> display ipv6 dhcp duid
The DUID of this device: 0003-0001-00e0-fc00-5552
display ipv6 dhcp relay server-address
display ipv6 dhcp relay server-address { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays all DHCPv6 server address information.
interface interface-type interface-number: Displays DHCPv6 server address information of the specified interface.
Use the display ipv6 dhcp relay server-address command to display information about DHCPv6 server addresses specified on the DHCPv6 relay agent.
# Display all the DHCPv6 server address information.
<Sysname> display ipv6 dhcp relay server-address all
Interface: GE3/1/1
Server address(es)                             Output Interface
1::1
FF02::1:2                                      GE3/1/3
Interface: GE3/1/2
1::1
FF02::1:2                                      GE3/1/3
# Display DHCPv6 server address information of interface GigabitEthernet 3/1/1.
<Sysname> display ipv6 dhcp relay server-address GigabitEthernet 3/1/1
Interface: GE3/1/1
1::1
FF02::1:2                                      GE3/1/3
Table 1 Output description
Interface that serves as the DHCPv6 relay agent
Server address(es)
DHCPv6 server address(es) specified on the interface
Output Interface
Outgoing interface of DHCPv6 packets
display ipv6 dhcp relay statistics
display ipv6 dhcp relay statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display ipv6 dhcp relay statistics command to display packet statistics on the DHCPv6 relay agent.
Related commands: reset ipv6 dhcp relay statistics.
# Display packet statistics on the DHCPv6 relay agent.
<Sysname> display ipv6 dhcp relay statistics
Packets dropped               :  4
    Error                     :  4
    Excess of rate limit      :  0
Packets received              :  14
    SOLICIT                   :  0
    REQUEST                   :  0
    CONFIRM                   :  0
    RENEW                     :  0
    REBIND                    :  0
    RELEASE                   :  0
    DECLINE                   :  0
    INFORMATION-REQUEST       :  7
    RELAY-FORWARD             :  0
    RELAY-REPLY               :  7
Packets sent                  :  14
    ADVERTISE                 :  0
    RECONFIGURE               :  0
    REPLY                     :  7
    RELAY-FORWARD             :  7
    RELAY-REPLY               :  0
Table 2 Output description
Packets dropped
Number of discarded packets
Error
Number of discarded error packets
Number of packets discarded due to excess of rate limit
Packets received
Number of received packets
SOLICIT
Number of received solicit packets
REQUEST
Number of received request packets
CONFIRM
Number of received confirm packets
RENEW
Number of received renew packets
REBIND
Number of received rebind packets
RELEASE
Number of received release packets
DECLINE
Number of received decline packets
INFORMATION-REQUEST
Number of received information request packets
RELAY-FORWARD
Number of received relay-forward packets
RELAY-REPLY
Number of received relay-reply packets
Packets sent
Number of sent packets
ADVERTISE
Number of sent advertise packets
RECONFIGURE
Number of sent reconfigure packets
REPLY
Number of sent reply packets
RELAY-FORWARD
Number of sent Relay-forward packets
RELAY-REPLY
Number of sent Relay-reply packets
ipv6 dhcp relay server-address ipv6-address [ interface interface-type interface-number ]
undo ipv6 dhcp relay server-address ipv6-address [ interface interface-type interface-number ]
View
Interface view
Default level
2: System level
ipv6-address: IPv6 address of the DHCPv6 server.
interface interface-type interface-number: Specifies an outgoing interface for DHCPv6 packets.
Use the ipv6 dhcp relay server-address command to enable DHCPv6 relay agent on the interface and specify a DHCPv6 server.
Use the undo ipv6 dhcp relay server-address command to remove the DHCPv6 server from the interface.
By default, DHCPv6 relay agent is disabled and no DHCPv6 server is specified on the interface.
Upon receiving a request from a DHCPv6 client, the interface that operates as a DHCPv6 relay agent encapsulates the request into a Relay-forward message and forwards the message to the specified DHCPv6 server, which then assigns an IPv6 address and other configuration parameters to the DHCPv6 client.
Note that:
·           Executing the ipv6 dhcp relay server-address command repeatedly can specify multiple DHCPv6 servers, and up to eight DHCP servers can be specifed for an interface. After receiving requests from DHCPv6 clients, the DHCPv6 relay agent forwards the reqests to all the specified DHCPv6 servers.
·           If the DHCPv6 server address is a link-local address or link-scoped multicast address on the local link, you need to specify an outgoing interface; otherwise, DHCPv6 packets may fail to be forwarded to the DHCPv6 server.
·           Removing all the specified DHCPv6 server addresses from an interface with the undo ipv6 dhcp relay server-address command disables DHCPv6 relay agent on the interface.
Related commands: display ipv6 dhcp relay server-address.
# Enable DHCPv6 relay agent on GigabitEthernet 3/1/1, and specify the DHCPv6 server address as 2001:1::3.
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] ipv6 dhcp relay server-address 2001:1::3
View
Default level
1: Monitor level
None
Use the reset ipv6 dhcp relay statistics command to clear packets statistics on the DHCPv6 relay agent.
After this command is executed, the packets statistics is displayed as 0 when you use the display ipv6 dhcp relay statistics command.
Related commands: display ipv6 dhcp relay statistics.
# Clear packet statistics on the DHCPv6 relay agent.
<Sysname> reset ipv6 dhcp relay statistics
