05-Layer 3 - IP Services Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10305-Layer 3 - IP Services Command Reference
09-IPv6 Basics Commands
09-IPv6 Basics Commands 253 KB
display ipv6 fib
display ipv6 fib [ vpn-instance vpn-instance-name ] [ acl6 acl6-number | ipv6-prefix ipv6-prefix-name ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Displays the IPv6 FIB entries of the specified MPLS L3VPN. The vpn-instance-name argument is a case sensitive string of 1 to 31 characters. Without this option specified, the display ipv6 fib command displays the IPv6 FIB entries of the public network.
acl6 acl6-number: Displays the IPv6 FIB entries permitted by a specified ACL. The ACL number is in the range of 2000 to 2999. If the specified ACL does not exist, all IPv6 FIB entries are displayed.
ipv6-prefix ipv6-prefix-name: Displays the IPv6 FIB entries matching a specified prefix list. The ipv6-prefix-name argument is a case-sensitive string of 1 to 19 characters. If the specified prefix list does not exist, all IPv6 FIB entries are displayed.
slot slot-number: Displays the IPv6 FIB entries of the specified card.
ipv6-address: Displays the IPv6 FIB entries containing the specified destination IPv6 address.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display ipv6 fib command to display IPv6 FIB entries. If no argument is specified, all IPv6 FIB entries will be displayed.
The router looks up a matching IPv6 FIB entry for forwarding an IPv6 packet.
# Display all IPv6 FIB entries.
<Sysname> display ipv6 fib
FIB Table:
 Total number of Routes : 1
 Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
Destination:    ::1                                     PrefixLength : 128
NextHop     :    ::1                                      Flag           : HU
Label       :    NULL                                     Token          : 0
Interface  :    InLoopBack0
Table 1 Output description
Total number of routes in the FIB
Destination
Destination address
PrefixLength
Prefix length of the destination address
NextHop
Next hop
Flag
Route flag:
·       U—Usable route
·       G—Gateway route
·       H—Host route
·       B—Black hole route
·       D—Dynamic route
·       S—Static route
Label
Label
Token
LSP index number
Outgoing interface
display ipv6 fib ipv6-address
display ipv6 fib [ vpn-instance vpn-instance-name ] ipv6-address [ prefix-length ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Displays the IPv6 FIB entries for a specified MPLS L3VPN. The vpn-instance-name argument is case sensitive string of 1 to 31 characters. Without this option specified, the display ipv6 fib ipv6-address command displays IPv6 FIB entries on the public network and all private networks.
ipv6-address: Destination IPv6 address.
prefix-length: Prefix length of the destination IPv6 address, in the range of 0 to 128.
Use the display ipv6 fib ipv6-address command to display the IPv6 FIB entry of the specified destination IPv6 address.
Note that:
·           Without the prefix-length argument specified, this command displays the matching IPv6 FIB entry with the longest prefix.
·           With the prefix-length argument specified, this command displays the IPv6 FIB entry exactly matching the specified destination IPv6 address and prefix length.
# Display the matching IPv6 FIB entry with the longest prefix.
<Sysname> display ipv6 fib ::1
FIB Table:
Flag:
Table 2 Output description
Destination
Destination address
PrefixLength
NextHop
Next hop
Flag
Route flag:
·       U—Usable route
·       G—Gateway route
·       H—Host route
·       D—Dynamic route
·       S—Static route
Label
Label
Token
LSP index number
Outgoing interface
display ipv6 interface
display ipv6 interface [ interface-type [ interface-number ] ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
interface-type: Interface type.
interface-number: Interface number.
verbose: Displays the detailed IPv6 information of an interface.
Use the display ipv6 interface command to display the IPv6 information of an interface.
If interface-type interface-number is not specified, the IPv6 information of all interfaces is displayed; if only interface-type is specified, the IPv6 information of the interfaces of the specified type is displayed; if interface-type interface-number is specified, the IPv6 information of the specified interface is displayed. If the verbose keyword is also specified, the detailed IPv6 information of the interface is displayed.
If you have configured the time slots of a CE1 or CT1 interface as an ISDN PRI group using the pri-set command, then executing the display ipv6 interface command only displays the time slot used by the control channel (D channel), instead of the ones used by the user channels (B channels). For more information about CE1 and CT1 interfaces, see Interface Configuration Guide.
# Display the IPv6 information of GigabitEthernet 1/1/2.
<Sysname> display ipv6 interface GigabitEthernet 1/1/2
*down: administratively down
(s): spoofing
Interface                                Physical   Protocol   IPv6 Address
GigabitEthernet1/1/2                      up         down      Unassigned
Table 3 Output description
*down
The interface is down, that is, the interface is closed by using the shutdown command.
(s)
Spoofing attribute of the interface, that is, the link protocol state of the interface is up, but the link does not exist; or the link is established on demand, instead of being permanent.
Name of the interface.
Physical
Physical state of the interface.
Protocol
Link protocol state of the interface.
IPv6 Address
IPv6 address of the interface. Only the first of configured IPv6 addresses is displayed. (If no address is configured for the interface, “Unassigned” will be displayed.)
# Display the IPv6 information of all interfaces for which IPv6 addresses can be configured.
(s): spoofing
GigabitEthernet2/1/2                       down       down     Unassigned
GigabitEthernet2/1/3                       down       down     Unassigned
GigabitEthernet2/1/4                       down       down     Unassigned
GigabitEthernet2/1/6                       down       down     Unassigned
GigabitEthernet2/1/7                       down       down     Unassigned
GigabitEthernet2/1/7.20                    down       down     Unassigned
GigabitEthernet2/1/8                       down       down     Unassigned
GigabitEthernet2/1/9                       down       down     Unassigned
GigabitEthernet2/1/10                      down       down     Unassigned
M-Ethernet0/0/0                             up        down     Unassigned
Table 4 Output description
*down
(s) : spoofing
Spoofing attribute of the interface, that is, the link protocol state of the interface is up, but the link does not exist, or the link is established on demand, instead of being permanent.
Physical
Physical state of the interface:
·       *downIndicates that the VLAN interface is administratively down; In other words, the interface has been shut down by using the shutdown command.
·       down—Indicates that the VLAN interface is administratively up but its physical state is down; that is, no port in the VLAN is up, which may be caused by a connection or link failure.
·       upIndicates that the administrative and physical states of the VLAN interface are both up.
Protocol
Link layer protocol state of the interface:
·       downIndicates that the network layer protocol state of the VLAN interface is down, generally because no IP address is configured.
·       upIndicates that the network layer protocol state of the VLAN interface is up.
IPv6 Address
display ipv6 neighbors
display ipv6 neighbors { { ipv6-address | all | dynamic | static } [ slot slot-number ] | interface interface-type interface-number | vlan vlan-id } [ verbose ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
ipv6-address: IPv6 address whose neighbor information is to be displayed.
all: Displays information of all neighbors, including neighbors acquired dynamically and configured statically on the public network and all private networks.
dynamic: Displays information of all neighbors acquired dynamically.
static: Displays information of all neighbors configured statically.
slot slot-number: Displays the neighbor information of the specified card.
interface interface-type interface-number: Displays information of the neighbors of a specified interface.
vlan vlan-id: Displays information of the neighbors of a specified VLAN whose ID ranges from 1 to 4094.
verbose: Displays the detailed information of neighbors.
Use the display ipv6 neighbors command to display neighbor information.
You can use the reset ipv6 neighbors command to clear specific IPv6 neighbor information.
Related commands: ipv6 neighbor and reset ipv6 neighbors.
# Display all neighbor information.
<Sysname> display ipv6 neighbors all
                Type: S-Static    D-Dynamic
IPv6 Address              Link-layer       VID  Interface     State  T   Age
FE80::200:5EFF:FE32:B800  0000-5e32-b800   N/A  GE2/1/6       REACH  S   -
# Display the detailed information of all neighbors.
<Sysname> display ipv6 neighbors all verbose
IPv6 Address     : FE80::223:89FF:FEE1:E330
Link-layer       : 0023-89e1-e330      VID : N/A    Interface   : GE3/1/8
State            : REACH               Type: D      Age         : 0
Vpn-instance     : [No Vrf]
Table 5 Output description
IPv6 Address
IPv6 address of a neighbor.
Link-layer
Link layer address (MAC address of a neighbor).
VID
VLAN to which the interface connected with a neighbor belongs.
Interface connected with a neighbor.
State of a neighbor, including:
·       INCMPThe address is being resolved. The link layer address of the neighbor is unknown.
·       REACHThe neighbor is reachable.
·       STALEThe reachability of the neighbor is unknown. The router will not verify the reachability any longer unless data is sent to the neighbor.
·       DELAYThe reachability of the neighbor is unknown. The router sends an NS message after a delay.
·       PROBEThe reachability of the neighbor is unknown. The router sends an NS message to verify the reachability of the neighbor.
Type of neighbor information, including static configuration and dynamic acquisition.
Age
For a static entry, a hyphen “-“ is displayed. For a dynamic entry, the reachable time (in seconds) elapsed is displayed, and if it is never reachable, “#” is displayed (for a neighbor acquired dynamically).
VPN-instance
Name of a VPN. [No Vrf] indicates no VPN is configured.
display ipv6 neighbors count
display ipv6 neighbors { { all | dynamic | static } [ slot slot-number ] | interface interface-type interface-number | vlan vlan-id } count [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
all: Displays the total number of all neighbor entries, including neighbor entries acquired dynamically and configured statically.
dynamic: Displays the total number of all neighbor entries acquired dynamically.
static: Displays the total number of neighbor entries configured statically.
slot slot-number: Displays the total number of neighbor entries of the specified card.
interface interface-type interface-number: Displays the total number of neighbor entries of a specified interface.
vlan vlan-id: Displays the total number of neighbor entries of a specified VLAN whose ID ranges from 1 to 4094.
Use the display ipv6 neighbors count command to display the total number of neighbor entries satisfying the specified condition.
# Display the total number of neighbor entries acquired dynamically.
<Sysname> display ipv6 neighbors dynamic count
Total dynamic entry(ies):  2
display ipv6 neighbors vpn-instance
display ipv6 neighbors vpn-instance vpn-instance-name [ count ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance-name: Specifies the MPLS L3 VPN for which neighbor entries are to be displayed. The vpn-instance-name argument is a case sensitive string of 1 to 31 characters.
count: Displays the total number of neighbor entries in the specified VPN.
Use the display ipv6 neighbors vpn-instance command to display the neighbor information for the specified VPN.
# Display the neighbor information for the VPN vpn1.
<Sysname> display ipv6 neighbors vpn-instance vpn1
FE80::200:5EFF:FE32:B800  0000-5e32-b800   N/A  GE3/1/1        REACH  S   -
Table 6 Output description
IPv6 Address
Link-layer
Link layer address (MAC address) of a neighbor.
VID
State of a neighbor, which can be:
·       STALEThe reachability of the neighbor is unknown. The device will not verify the reachability any longer unless data is sent to the neighbor.
·       DELAYThe reachability of the neighbor is unknown. The device sends an NS message after a delay.
·       PROBEThe reachability of the neighbor is unknown. The device sends an NS message to verify the reachability of the neighbor.
T
Type of neighbor information, which can be static (represented by S) or dynamic (represented by D).
Age
For a static entry, a hyphen (-) is displayed. For a dynamic entry, the time (in seconds) elapsed since it became reachable is displayed, and if it is never reachable, a number sign (#) is displayed.
display ipv6 pathmtu
display ipv6 pathmtu [ vpn-instance vpn-instance-name ] { ipv6-address | all | dynamic | static } [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
vpn-instance vpn-instance-name: Displays the IPv6 PMTU information for the specified MPLS L3VPN. The vpn-instance-name argument is a case sensitive string of 1 to 31 characters. Without this option specified, the display ipv6 pathmtu command displays the IPv6 PMTU information for the public network.
ipv6-address: IPv6 address whose PMTU information is to be displayed.
all: Displays all PMTU information on the public network.
dynamic: Displays all dynamic PMTU information.
static: Displays all static PMTU information.
Use the display ipv6 pathmtu command to display the PMTU information of IPv6 addresses.
# Display all PMTU information.
<Sysname> display ipv6 pathmtu all
IPv6 Destination Address    ZoneID  PathMTU     Age     Type
 fe80::12                   0       1300            40      Dynamic
 2222::3                    0       1280            -       Static
Table 7 Output description
ZoneID
ID of address zone, currently invalid.
PathMTU
PMTU of an IPv6 address.
Age
Time for a PMTU to live. For a static PMTU, a hyphen “-“ is displayed.
Indicates the PMTU is dynamically negotiated or statically configured.
display ipv6 socket
display ipv6 socket [ socktype socket-type ] [ task-id socket-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
socktype socket-type: Displays the socket information of this type. The socket type is in the range of 1 to 3. The value “1” represents a TCP socket, “2” a UDP socket, and “3” a raw IP socket.
task-id: Displays the socket information of the task. The task ID is in the range of 1 to 100.
socket-id: Displays the information of the socket. The socket ID is in the range of 0 to 3072.
slot slot-number: Displays the socket information of the specified card.
Use the display ipv6 socket command to display socket information.
With no parameter specified, this command displays the information about all the sockets; with only the socket type specified, the command displays the information about sockets of the specified type; with the socket type, task ID and socket ID specified, the command displays the information about the specified socket.
# Display the information of all sockets.
<Sysname> display ipv6 socket
SOCK_STREAM:
Task = VTYD(14), socketid = 4, Proto = 6,
LA = ::->22, FA = ::->0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_REUSEPORT SO_SENDVPNID,
socket state = SS_PRIV SS_ASYNC
Task = VTYD(14), socketid = 3, Proto = 6,
LA = ::->23, FA = ::->0,
SOCK_DGRAM:
Task = AGNT(51), socketid = 2, Proto = 17,
LA = ::->161, FA = ::->0,
sndbuf = 9216, rcvbuf = 42080, sb_cc = 0, rb_cc = 0,
socket option = SO_REUSEPORT,
socket state = SS_PRIV SS_NBIO SS_ASYNC
Task = TRAP(52), socketid = 2, Proto = 17,
LA = ::->1024, FA = ::->0,
socket option =,
SOCK_RAW:
Task = ROUT(86), socketid = 5, Proto = 89,
LA = ::, FA = ::,
sndbuf = 262144, rcvbuf = 262144, sb_cc = 0, rb_cc = 0,
socket option = SO_REUSEADDR,
Table 8 Output description
SOCK_STREAM
TCP socket.
SOCK_DGRAM
UDP socket.
SOCK_RAW
Raw IP socket.
Task name and ID of the created socket.
socketid
ID assigned by the kernel to the created socket.
Proto
Protocol ID, for example, 6 indicates TCP and 17 indicates UDP.
LA
Local address and local port number.
FA
Remote address and remote port number.
sndbuf
Size of the send buffer.
rcvbuf
Size of the receive buffer.
sb_cc
Number of bytes sent by the send buffer.
rb_cc
Number of bytes received by the receive buffer.
socket option
Socket option set by the application, which can be:
·       SO_ACCEPTCONNDetects connection request at the server end.
·       SO_REUSEADDRAllows for reuse of a local address.
·       SO_REUSEPORTAllows for reuse of a local port.
·       SO_SENDVPNIDEnables sending of the VPN ID.
socket state
State of the socket.
display ipv6 statistics
display ipv6 statistics [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
slot slot-number: Display IPv6 and ICMPv6 packet statistics of the specified card.
Use the display ipv6 statistics command to display statistics of IPv6 packets and ICMPv6 packets.
You can use the reset ipv6 statistics command to clear all IPv6 and ICMPv6 packet statistics.
# Display the statistics of IPv6 packets and ICMPv6 packets.
<Sysname> display ipv6 statistics
IPv6 Protocol:
    Sent packets:
      Total:      0
        Local sent out:       0            forwarded:           0
        raw packets:          0            discarded:           0
        routing failed:       0            fragments:           0
        fragments failed:     0
    Received packets:
      Total:      0
        local host:           0            hopcount exceeded:   0
        format error:         0            option error:         0
        protocol error:       0            fragments:            0
        reassembled:          0            reassembly failed:   0
        reassembly timeout:   0
  ICMPv6 protocol:
    Sent packets:
      Total:      0
        unreached:           0             too big:              0
        hopcount exceeded:   0             reassembly timeout: 0
        parameter problem:   0
        echo request:        0             echo replied:         0
        neighbor solicit:    0             neighbor advert:     0
        router solicit:      0             router advert:        0
        redirected:          0
      Send failed:
        ratelimited:         0             other errors:         0
    Received packets:
      Total:      0
        checksum error:      0             too short:            0
        bad code:            0
        parameter problem:   0             unknown error type:   0
        redirected:          0              router renumbering:   0
        unknown info type:   0
      Deliver failed:
        bad length:          0             ratelimited:          0
Table 9 Output description
IPv6 Protocol:
Statistics of IPv6 packets
Sent packets
Statistics of sent IPv6 packets, including:
·       TotalTotal number of packets sent and forwarded locally
·       Local sent out—Number of packets sent locally
·       forwarded—Number of forwarded packets
·       raw packets—Number of packets sent via raw socket
·       discarded—Number of discarded packets
·       routing failed—Number of packets failing to be routed
·       fragments—Number of sent fragment packets
·       fragments failed—Number of fragments failing to be sent
Received packets
Statistics of received IPv6 packets, including:
·       TotalTotal number of received packets
·       local host—Number of packets received locally
·       hopcount exceeded—Number of packets exceeding the hop limit
·       format error—Number of packets in an incorrect format
·       option error—Number of packets with incorrect options
·       protocol error—Number of packets with incorrect protocol
·       fragments—Number of received fragment packets
·       reassembled—Number of reassembled packets
·       reassembly failed—Number of packets failing to be reassembled
·       reassembly timeout—Number of packets whose reassembly times out
ICMPv6 protocol:
Statistics of ICMPv6 packets
Sent packets
Statistics of sent ICMPv6 packets, including:
·       TotalTotal number of sent packets
·       unreached—Number of packets whose destination is unreachable
·       too big—Number of too large packets
·       reassembly timeout—Number of packets whose fragmentation and reassembly times out
·       parameter problem—Number of packets with parameter errors
·       echo request—Number of request packets
·       echo replied—Number of response packets
·       neighbor solicit—Number of neighbor solicitation packets
·       neighbor advert—Number of neighbor advertisement packets
·       router solicit—Number of router solicit packets
·       router advert—Number of router advertisement packets
·       redirected—Number of redirected packets
·       Send failedNumber of packets failed to be sent
·       ratelimited—Number of packets failing to be sent because of rate limitation
·       other errors—Number of packets with other errors
Received packets
Statistics of received ICMPv6 packets, including:
·       checksum error—Number of packets with checksum errors
·       too short—Number of too small packets
·       bad code—Number of packets with error codes
·       unknown error type—Number of packets with unknown errors
·       neighbor solicit—Number of neighbor solicitation messages
·       router solicit—Number of router solicitation packets
·       router renumberingNumber of renumbered packets
·       unknown info type—Number of unknown type of packets
·       Deliver failedNumber of packets failed to be delivered
·       bad length—Number of packets with a incorrect size
·       ratelimited—Number of packets failing to be received because of rate limitation
display tcp ipv6 statistics
display tcp ipv6 statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display tcp ipv6 statistics command to display IPv6 TCP connection statistics.
You can use the reset tcp ipv6 statistics command to clear statistics of all IPv6 TCP packets.
# Display the statistics of IPv6 TCP connections.
<Sysname> display tcp ipv6 statistics
Received packets:
     Total: 0
     packets in sequence: 0 (0 bytes)
     window probe packets: 0, window update packets: 0
     checksum error: 0, offset error: 0, short error: 0
     duplicate packets: 0 (0 bytes), partially duplicate packets: 0 (0 bytes)
     out-of-order packets: 0 (0 bytes)
     packets with data after window: 0 (0 bytes)
     packets after close: 0
     ACK packets: 0 (0 bytes)
     duplicate ACK packets: 0, too much ACK packets: 0
Sent packets:
     Total: 0
     urgent packets: 0
     control packets: 0 (including 0 RST)
     data packets: 0 (0 bytes) data packets retransmitted: 0 (0 bytes)
     ACK only packets: 0 (0 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections: 0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
Table 10 Output description
Received packets
Statistics of received packets, including:
·       packets in sequenceNumber of packets received in sequence
·       window probe packetsNumber of window probe packets
·       window update packets—Number of window size update packets
·       offset error—Number of packets with offset errors
·       short error—Number of packets whose total length is less than specified by the packet header
·       duplicate packets—Number of duplicate packets
·       partially duplicate packets—Number of partially duplicate packets
·       out-of-order packets—Number of out-of-order packets
·       packets with data after window—Number of packets exceeding the size of the receiving window
·       packets after close—Number of packets received after the connection is closed
·       ACK packets—Number of ACK packets
·       duplicate ACK packets—Number of duplicate ACK packets
·       too much ACK packets—Number of excessive ACK packets
Sent packets
Statistics of sent packets, including:
·       urgent packets—Number of packets containing an urgent indicator
·       control packets—Number of control packets
·       window probe packets—Number of window probe packets
·       window update packets—Number of window update packets
·       data packets—Number of data packets
·       data packets retransmitted—Number of retransmitted packets
·       ACK only packets—Number of ACK packets
Number of packets whose retransmission times out
Number of connections dropped because of retransmission timeout
Keepalive timeout
Number of keepalive timeouts
keepalive probe
Number of keepalive probes
Keepalive timeout, so connections disconnected
Number of connections dropped because of keepalive response timeout
Number of initiated connections
Number of accepted connections
Number of established connections
Closed connections
Number of closed connections
dropped
Number of dropped connections (after SYN is received from the peer)
initiated dropped
Number of initiated but dropped connections (before SYN is received from the peer)
Number of packets that fail the MD5 authentication and are thus dropped
Number of packets that pass the MD5 authentication
display tcp ipv6 status
display tcp ipv6 status [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display tcp ipv6 command to display the IPv6 TCP connection status, including the IPv6 TCP control block address, local and peer IPv6 addresses, and status of the IPv6 TCP connection.
# Display the IPv6 TCP connection status.
<Sysname> display tcp ipv6 status
*: TCP6 MD5 Connection
TCP6CB   Local Address             Foreign Address           State
045d8074 ::->21                    ::->0                       Listening
Table 11 Output description
The asterisk indicates that the TCP6 connection is secured by MD5 encryption
TCP6CB
IPv6 address of the TCP control block (hexadecimal)
Local Address
Local IPv6 address
Foreign Address
Remote IPv6 address
·       Closed
·       Listening
·       Syn_Sent
·       Syn_Rcvd
·       Established
·       Close_Wait
·       Fin_Wait1
·       Closing
·       Last_Ack
·       Fin_Wait2
·       Time_Wait
display udp ipv6 statistics
display udp ipv6 statistics [ | { begin | exclude | include } regular-expression ]
View
Default level
1: Monitor level
Use the display udp ipv6 statistics command to display statistics of IPv6 UDP packets.
You can use the reset udp ipv6 statistics command to clear the statistics of all IPv6 UDP packets.
# Display statistics information of IPv6 UDP packets.
<Sysname> display udp ipv6 statistics
Received packets:
     Total: 0
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     unicast(no socket on port): 0
     broadcast/multicast(no socket on port): 0
     not delivered, input socket full: 0
     input packets missing pcb cache: 0
Sent packets:
     Total: 0
Table 12 Output description
Total
Total number of received/sent packets
checksum error
Total number of packets with a checksum error
shorter than header
Total number of IPv6 UDP packets whose total length is less than specified by the packet header
Total number of packets whose data length exceeds that specified by the packet header
Total number of unicast packets without any socket received on a port
Total number of broadcast/multicast packets without any socket received on a port
Number of packets not handled because of the receive buffer being full
input packet missing pcb cache
Number of packets failing to match the protocol control block (PCB) cache
ipv6
ipv6
undo ipv6
View
Default level
2: System level
None
Use the ipv6 command to enable the IPv6 packet forwarding function.
Use the undo ipv6 command to disable the IPv6 packet forwarding function.
By default, the IPv6 packet forwarding function is disabled.
# Enable the IPv6 packet forwarding function.
[Sysname] ipv6
ipv6 address
ipv6 address { ipv6-address prefix-length | ipv6-address | prefix-length }
undo ipv6 address [ ipv6-address prefix-length | ipv6-address | prefix-length ]
View
Interface view
Default level
2: System level
ipv6-address: IPv6 address.
prefix-length: Prefix length of an IPv6 address, in the range of 1 to 128.
Use the ipv6 address command to configure an IPv6 global unicast address for an interface.
Use the undo ipv6 address command to remove the IPv6 address from the interface.
By default, no global unicast address is configured for an interface.
Note that except the link-local address automatically obtained and the one generated through stateless autoconfiguration, all IPv6 addresses will be removed from the interface if you carry out the undo ipv6 address command without any parameter specified.
CAUTION
CAUTION:
If you configure an IPv6 address for an interface associated with a VPN instance, fewer VPNs can be configured for the router.
# Set the global IPv6 unicast address of GigabitEthernet 3/1/1 to 2001::1/64.
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] ipv6 address 2001::1/64
ipv6 address anycast
ipv6 address ipv6-address | prefix-length anycast
undo ipv6 address ipv6-address | prefix-length anycast
View
Interface view
Default Level
2: System level
ipv6-address/prefix-length: Specifies an IPv6 anycast address and its prefix length. The prefix length ranges 1 to 128.
Use the ipv6 address anycast command to configure an IPv6 anycast address for an interface.
Use the undo ipv6 address anycast command to remove the IPv6 anycast address from the interface.
By default, no IPv6 anycast address is configured for an interface.
# Set the IPv6 anycast address of GigabitEthernet 3/1/1 to 2001::1 with prefix length 64.
[Sysname-GigabitEthernet3/1/1] ipv6 address 2001::1/64 anycast
ipv6 address auto link-local
undo ipv6 address auto link-local
View
Interface view
Default level
2: System level
None
Use the ipv6 address auto link-local command to automatically generate a link-local address for an interface.
Use the undo ipv6 address auto link-local command to remove the automatically generated link-local address for the interface.
By default, no link-local address is configured on an interface, and a link-local address will be automatically generated after a global IPv6 unicast address is configured for the interface.
Note that:
·           After an IPv6 aggregatable global unicast address is configured for an interface, a link-local address is generated automatically. The automatically generated link-local address is the same as the one generated by using the ipv6 address auto link-local command.
·           The undo ipv6 address auto link-local command can only remove the link-local addresses generated through the ipv6 address auto link-local command. After the undo ipv6 address auto link-local command is used on an interface that has an IPv6 global unicast address configured, the interface still has a link-local address. If the interface has no IPv6 global unicast address configured, it will have no link-local address.
·           Manual assignment takes precedence over automatic generation. That is, if you first adopt automatic generation and then manual assignment, the manually assigned link-local address will overwrite the automatically generated one. If you first adopt manual assignment and then automatic generation, the automatically generated link-local address will not take effect and the link-local address of an interface is still the manually assigned one. If you delete the manually assigned address, the automatically generated link-local address is validated. For manually assignment of an IPv6 link-local address, see ipv6 address link-local.”
# Configure GigabitEthernet 3/1/1 to automatically generate a link-local address.
[Sysname-GigabitEthernet3/1/1] ipv6 address auto link-local
ipv6 address eui-64
ipv6 address ipv6-address | prefix-length eui-64
undo ipv6 address ipv6-address | prefix-length eui-64
View
Interface view
Default level
2: System level
ipv6-address | prefix-length: IPv6 address and IPv6 prefix. The ipv6-address and prefix-length arguments jointly specify the prefix of an IPv6 address in the EUI-64 format.
Use the ipv6 address eui-64 command to configure a global unicast address in the EUI-64 format for an interface.
Use the undo ipv6 address eui-64 command to remove the configured global unicast address in the EUI-64 format for the interface.
By default, no EUI-64 IPv6 address is configured for an interface.
An EUI-64 IPv6 address is generated based on the specified prefix and the automatically generated interface identifier and can be displayed by using the display ipv6 interface command.
The prefix length of an address in EUI-64 format cannot exceed 64.
# Configure an IPv6 address in the EUI-64 format for GigabitEthernet 3/1/1. The prefix length of the address is the same as that of 2001::1/64, and the interface ID is generated based on the MAC address of the router.
[Sysname-GigabitEthernet3/1/1] ipv6 address 2001::1/64 eui-64
undo ipv6 address ipv6-address link-local
View
Interface view
Default level
2: System level
ipv6-address: IPv6 link-local address. The first ten bits of an address must be 1111111010 (binary), that is, the first group of hexadecimals in the address must be FE80 to FEBF.
Use the ipv6 address link-local command to configure a link-local address manually for a specified interface. Use the undo ipv6 address link-local command to remove the configured link-local address for an interface.
Note that:
Manual assignment takes precedence over automatic generation. That is, if you first adopt automatic generation and then manual assignment, the manually assigned link-local address will overwrite the automatically generated one. If you first adopt manual assignment and then automatic generation, the automatically generated link-local address will not take effect and the link-local address of an interface is still the manually assigned one. If you delete the manually assigned address, the automatically generated link-local address is validated. For automatic generation of an IPv6 link-local address, see the ipv6 address auto link-local command.
# Configure a link-local address for GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ipv6 address fe80::1 link-local
ipv6 fib-loadbalance-type hash-based
undo ipv6 fib-loadbalance-type hash-based
View
Default level
2: System level
None
Use the ipv6 fib-loadbalance-type hash-based command to specify the load sharing mode based on the HASH algorithm for packet forwarding.
Use the undo ipv6 fib-loadbalance-type hash-based command to restore the load sharing mode to the default.
By default, the load sharing based on polling is adopted. ECMP routes are used in turn to forward packets.
# Specify the load sharing mode based on the HASH algorithm for packet forwarding.
[Sysname] ipv6 fib-loadbalance-type hash-based
ipv6 hoplimit-expires enable
undo ipv6 hoplimit-expires
View
Default level
2: System level
None
Use the ipv6 hoplimit-expires enable command to enable the sending of ICMPv6 time exceeded packets.
Use the undo ipv6 hoplimit-expires command to disable the sending of ICMPv6 time exceeded packets.
By default, the sending of ICMPv6 time exceeded packets is enabled.
Note that:
After you disable the sending of ICMPv6 time exceeded packets, the router will not send time-to-live count exceeded packets, but will still send fragment reassembly time exceeded packets.
# Disable the sending of ICMPv6 time exceeded packets.
[Sysname] undo ipv6 hoplimit-expires
ipv6 icmp-error
ipv6 icmp-error { bucket bucket-size | ratelimit interval } *
undo ipv6 icmp-error
View
Default level
2: System level
bucket bucket-size: Number of tokens in a token bucket, in the range of 1 to 200.
ratelimit interval: Update period of the token bucket in milliseconds, in the range of 0 to 2,147,483,647. The update period “0” indicates that the number of ICMPv6 error packets sent is not restricted.
Use the ipv6 icmp-error command to configure the size and update period of a token bucket.
Use the undo ipv6 icmp-error command to restore the defaults.
By default, the size is 10 and the update period is 100 milliseconds. That is, at most 10 ICMPv6 error packets can be sent within these 100 milliseconds.
# Set the capacity of the token bucket to 50 and the update period to 100 milliseconds.
[Sysname] ipv6 icmp-error bucket 50 ratelimit 100
undo ipv6 icmpv6 multicast-echo-reply
View
Default level
2: System level
None
Use the ipv6 icmpv6 multicast-echo-reply enable command to enable sending of multicast echo replies.
Use the undo ipv6 icmpv6 multicast-echo-reply command to disable sending of multicast echo replies.
By default, the router is disabled from sending multicast echo replies.
# Enable sending of multicast echo replies.
[Sysname] ipv6 icmpv6 multicast-echo-reply enable
ipv6 mtu
ipv6 mtu mtu-size
undo ipv6 mtu
View
Interface view
Default level
2: System level
mtu-size: Size of the maximum transmission units (MTUs) of an interface in bytes. The value range depends on the interface type.
Use the ipv6 mtu command to set the MTU of IPv6 packets sent over an interface.
Use the undo ipv6 mtu command to restore the default MTU.
By default, the MTU of IPv6 packets sent over an interface is 1500 bytes.
# Set the MTU of IPv6 packets over GigabitEthernet 3/1/1 to 1280 bytes.
[Sysname-GigabitEthernet3/1/1] ipv6 mtu 1280
undo ipv6 nd autoconfig managed-address-flag
View
Interface view
Default level
2: System level
None
Use the ipv6 nd autoconfig managed-address-flag command to set the managed address configuration (M) flag to 1 so that the host can acquire an IPv6 address through stateful autoconfiguration (for example, DHCP server).
Use the undo ipv6 nd autoconfig managed-address-flag command to restore the default.
By default, the M flag is set to 0 so that the host can acquire an IPv6 address through stateless autoconfiguration.
# Configure the host to acquire an IPv6 address through stateful autoconfiguration.
[Sysname-GigabitEthernet3/1/1] ipv6 nd autoconfig managed-address-flag
ipv6 nd autoconfig other-flag
undo ipv6 nd autoconfig other-flag
View
Interface view
Default level
2: System level
None
Use the ipv6 nd autoconfig other-flag command to set the other stateful configuration flag (O) flag to 1 so that the host can acquire information other than IPv6 address through stateful autoconfiguration (for example, DHCP server).
Use the undo ipv6 nd autoconfig other-flag command to restore the default.
By default, the O flag is set to 0 so that the host can acquire other information through stateless autoconfiguration.
# Configure the host to acquire information other than IPv6 address through stateless autoconfiguration.
[Sysname-igabitEthernet3/1/1] undo ipv6 nd autoconfig other-flag
ipv6 nd dad attempts
ipv6 nd dad attempts value
undo ipv6 nd dad attempts
View
Interface view
Default level
2: System level
value: Number of attempts to send an NS message for DAD, in the range of 0 to 600. The default value is “1”. When it is set to 0, the DAD is disabled.
Use the ipv6 nd dad attempts command to configure the number of attempts to send an NS message for DAD.
Use the undo ipv6 nd dad attempts command to restore the default.
By default, the number of attempts to send an NS message for DAD is 1.
Related commands: display ipv6 interface.
# Set the number of attempts to send an NS message for DAD to 20.
[Sysname-GigabitEthernet3/1/1] ipv6 nd dad attempts 20
ipv6 nd hop-limit
ipv6 nd hop-limit value
undo ipv6 nd hop-limit
View
Default level
2: System level
value: Number of hops, in the range of 0 to 255. When it is set to 0, the Cur Hop Limit field in RA messages sent by the router is 0. That is, the number of hops is determined by the host itself, but not specified by the router.
Use the ipv6 nd hop-limit command to configure the hop limit advertised by the router.
Use the undo ipv6 nd hop-limit command to restore the default hop limit.
By default, the hop limit advertised by the router is 64.
# Set the hop limit advertised by the router to 100.
[Sysname] ipv6 nd hop-limit 100
ipv6 nd ns retrans-timer
undo ipv6 nd ns retrans-timer
View
Interface view
Default level
2: System level
value: Interval for sending NS messages in milliseconds, in the range of 1,000 to 4,294,967,295.
Use the ipv6 nd ns retrans-timer command to set the interval for sending NS messages. The local interface sends NS messages at intervals of this value. Furthermore, the Retrans Timer field in RA messages sent by the local interface is equal to this value.
Use the undo ipv6 nd ns retrans-timer command to restore the default interval.
By default, the local interface sends NS messages at an interval of 1000 milliseconds and the Retrans Timer field in the RA messages is 0, so that the interval for retransmitting an NS message is determined by the receiving device.
# Specify GigabitEthernet 3/1/1 to send NS messages at 10000 millisecond intervals.
[Sysname-GigabitEthernet3/1/1] ipv6 nd ns retrans-timer 10000
ipv6 nd nud reachable-time
ipv6 nd nud reachable-time value
undo ipv6 nd nud reachable-time
View
Interface view
Default level
2: System level
value: Neighbor reachable time in milliseconds, in the range of 1 to 3,600,000.
Use the ipv6 nd nud reachable-time command to configure the neighbor reachable time on an interface. This time value serves as not only the neighbor reachable time on the local interface, but also the value of the Reachable Time field in RA messages sent by the local interface.
Use the undo ipv6 nd nud reachable-time command to restore the default.
By default, the neighbor reachable time on the local interface is 30,000 milliseconds and the Reachable Time field in RA messages is 0.
# Set the neighbor reachable time on GigabitEthernet 3/1/1 to 10,000 milliseconds.
[Sysname-GigabitEthernet3/1/1] ipv6 nd nud reachable-time 10000
ipv6 nd ra halt
ipv6 nd ra halt
undo ipv6 nd ra halt
View
Interface view
Default level
2: System level
None
Use the ipv6 nd ra halt command to enable RA message suppression.
Use the undo ipv6 nd ra halt command to disable the RA message suppression.
By default, RA messages are suppressed.
# Suppress RA messages on GigabitEthernet 2/1/2.
[Sysname] interface GigabitEthernet2/1/2
[Sysname-GigabitEthernet2/1/2] ipv6 nd ra halt
ipv6 nd ra interval
ipv6 nd ra interval max-interval-value min-interval-value
undo ipv6 nd ra interval
View
Interface view
Default level
2: System level
max-interval-value: Maximum interval for advertising RA messages in seconds, in the range of 4 to 1800.
min-interval-value: Minimum interval for advertising RA messages in seconds, in the range of 3 to 1,350.
Use the ipv6 nd ra interval command to set the maximum and minimum interval for advertising RA messages. The router advertises RA messages at intervals of a random value between the maximum interval and the minimum interval.
Use the undo ipv6 nd ra interval command to restore the default.
By default, the maximum interval between RA messages is 600 seconds, and the minimum interval is 200 seconds.
Note the following:
·           The minimum interval should be three-fourths of the maximum interval or less.
·           The maximum interval for sending RA messages should be less than or equal to the router lifetime in RA messages.
# Set the maximum interval for advertising RA messages to 1,000 seconds and the minimum interval to 700 seconds.
[Sysname-GigabitEthernet3/1/1] ipv6 nd ra interval 1000 700
ipv6 nd ra no-advlinkmtu
undo ipv6 nd ra no-advlinkmtu
View
Interface view
Default level
2: System level
None
Use the ipv6 nd ra no-advlinkmtu command to turn off the MTU option in RA messages.
Use the undo ipv6 nd ra no-advlinkmtu command to restore the default.
By default, RA messages contain the MTU option.
# Turn off the MTU option in RA messages on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] ipv6 nd ra no-advlinkmtu
ipv6 nd ra prefix
ipv6 nd ra prefix { ipv6-prefix prefix-length | ipv6-prefix | prefix-length } valid-lifetime preferred-lifetime [ no-autoconfig | off-link ] *
undo ipv6 nd ra prefix { ipv6-prefix | ipv6-prefix | prefix-length }
View
Interface view
Default level
2: System level
ipv6-prefix: IPv6 address prefix.
prefix-length: Prefix length of an IPv6 address.
valid-lifetime: Valid lifetime of a prefix in seconds, in the range of 0 to 4,294,967,295.
preferred-lifetime: Preferred lifetime of a prefix used for stateless autoconfiguration in seconds, in the range of 0 to 4,294,967,295.
no-autoconfig: Specifies a prefix not to be used for stateless autoconfiguration. If this keyword is not provided, the prefix is used for stateless autoconfiguration.
off-link: Specifies the address with the prefix not to be directly reachable on the link. If this keyword is not provided, the address with the prefix is directly reachable on the link.
Use the ipv6 nd ra prefix command to configure the prefix information in RA messages.
Use the undo ipv6 nd ra prefix command to remove the prefix information from RA messages.
By default, no prefix information is configured in RA messages and the IPv6 address of the interface sending RA messages is used as the prefix information with valid lifetime 2592000 seconds (that is, 30 days) and preferred lifetime 604800 seconds (that is, 7 days).
# Configure the prefix information for RA messages on GigabitEthernet 3/1/1.
[Sysname] interface GigabitEthernet3/1/1
[Sysname-GigabitEthernet3/1/1] ipv6 nd ra prefix 2001:10::100/64 100 10
ipv6 nd ra router-lifetime
ipv6 nd ra router-lifetime value
undo ipv6 nd ra router-lifetime
View
Interface view
Default level
2: System level
value: Router lifetime in seconds, in the range of 0 to 9,000. When it is set to 0, the router does not serve as the default router.
Use the ipv6 nd ra router-lifetime command to configure the router lifetime in RA messages.
Use the undo ipv6 nd ra router-lifetime command to restore the default configuration.
By default, the router lifetime in RA messages is 1,800 seconds.
Note that the router lifetime in RA messages should be greater than or equal to the advertising interval.
# Set the router lifetime in RA messages on GigabitEthernet 3/1/1 to 1,000 seconds.
[Sysname-GigabitEthernet3/1/1] ipv6 nd ra router-lifetime 1000
ipv6 neighbor
ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number } [ vpn-instance vpn-instance-name ]
undo ipv6 neighbor ipv6-address interface-type interface-number
undo ipv6 neighbor ipv6-address mac-address { vlan-id port-type port-number | interface interface-type interface-number } [ vpn-instance vpn-instance-name ]
View
Default level
2: System level
ipv6-address: IPv6 address in a static neighbor entry.
mac-address: Link layer address in a static neighbor entry (48 bits long, in the format of H-H-H).
vlan-id: VLAN ID in a static neighbor entry, in the range of 1 to 4094.
port-type port-number: Type and number of  a Layer 2 port in a static neighbor entry.
interface interface-type interface-number: Type and number of a Layer 3 interface in a static neighbor entry.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN that the static neighbor entry belongs to. The vpn-instance-name argument is a case sensitive string of 1 to 31 characters. If the static neighbor entry is for the public network, do not specify this option.
Use the ipv6 neighbor command to configure a static neighbor entry.
Use the undo ipv6 neighbor command to remove a static neighbor entry.
You can use a Layer 3 VLAN interface or a Layer 2 port in the VLAN to configure a static neighbor entry.
·           If the first method is used, the neighbor entry is in the INCMP state. After the device obtains the corresponding Layer 2 port information, the neighbor entry will go into the REACH state.
·           If the second method is used, the corresponding VLAN interface must exist and the port specified by port-type port-number must belong to the VLAN specified by vlan-id. After the static neighbor entry is configured, the device will relate the VLAN interface with the IPv6 address to identify the static neighbor entry uniquely and the entry will be in the REACH state.
To remove a static neighbor entry, you only need to specify the corresponding VLAN interface and the neighbor address.
Related commands: display ipv6 neighbors.
# Configure a static neighbor entry for Layer 3 interface GigabitEthernet 3/1/1.
[Sysname] ipv6 neighbor 2000::1 fe-e0-89 interface GigabitEthernet 3/1/1
ipv6 neighbor stale-aging
undo ipv6 neighbor stale-aging
View
Default level
2: System level
aging-time: Age timer for ND entries in stale state, ranging from 1 to 24 hours.
Use the ipv6 neighbor stale-aging command to set the age timer for ND entries in stale state.
Use the undo ipv6 neighbor stale-aging command to restore the default.
By default, the age timer for ND entries in stale state is four hours.
# Set the age timer for ND entries in stale state to two hours.
[Sysname] ipv6 neighbor stale-aging 2
ipv6 neighbors max-learning-num
ipv6 neighbors max-learning-num number
undo ipv6 neighbors max-learning-num
View
Interface view
Default level
2: System level
number: Maximum number of neighbors that can be dynamically learned by the interface, ranging from 1 to 16381 in hybrid system working mode, and from 1 to 65533 in SPE or SPC system working mode. For more information about the system working modes, see Fundamentals Configuration Guide.
Use the ipv6 neighbors max-learning-num command to configure the maximum number of neighbors that can be dynamically learned on a specified interface.
Use the undo ipv6 neighbors max-learning-num command to restore the default.
By default, up to 16381 neighbors can be learned on an interface in hybrid system working mode, and up to 65533 neighbors can be learned on an interface in SPE or SPC system working mode.
# Set the maximum number of neighbors that can be dynamically learned on GigabitEthernet 3/1/1 to 10.
[Sysname-GigabitEthernet3/1/1] ipv6 neighbors max-learning-num 10
ipv6 pathmtu
ipv6 pathmtu [ vpn-instance vpn-instance-name ] ipv6-address [ value ]
undo ipv6 pathmtu [ vpn-instance vpn-instance-name ] ipv6-address
View
Default level
2: System level
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN that the PMTU belongs to. The vpn-instance-name argument is a case sensitive string of 1 to 31 characters. If the PMTU is for the public network, do not specify this option.
ipv6-address: Specified IPv6 address.
value: PMTU of a specified IPv6 address in bytes, in the range of 1280 to 10240.
Use the ipv6 pathmtu command to configure a static PMTU for a specified IPv6 address.
Use the undo ipv6 pathmtu command to remove the PMTU configuration for a specified IPv6 address.
By default, no static PMTU is configured.
# Configure a static PMTU for a specified IPv6 address.
[Sysname] ipv6 pathmtu fe80::12 1300
ipv6 pathmtu age
ipv6 pathmtu age age-time
undo ipv6 pathmtu age
View
Default level
2: System level
age-time: Aging time for PMTU in minutes, in the range of 10 to 100.
Use the ipv6 pathmtu age command to configure the aging time for a dynamic PMTU.
Use the undo ipv6 pathmtu age command to restore the default.
By default, the aging time is 10 minutes.
Note that the aging time is invalid for a static PMTU.
Related commands: display ipv6 pathmtu.
# Set the aging time for a dynamic PMTU to 40 minutes.
[Sysname] ipv6 pathmtu age 40
ipv6 unreachables enable
undo ipv6 unreachables
View
Default level
2: System level
None
Use the ipv6 unreachables enable command to enable sending of ICMPv6 destination unreachable packets.
Use the undo ipv6 unreachables command to disable sending of ICMPv6 destination unreachable packets.
By default, sending of ICMPv6 destination unreachable packets is disabled.
# Enable sending of ICMPv6 destination unreachable packets.
[Sysname] ipv6 unreachables enable
View
Default level
2: System level
all: Clears the static and dynamic neighbor information on all interfaces.
dynamic: Clears the dynamic neighbor information on all interfaces.
interface interface-type interface-number: Clears dynamic neighbor information on a specified interface.
slot slot-number: Clears the dynamic neighbor information on a specified card.
static: Clears the static neighbor information on all interfaces.
Use the reset ipv6 neighbors command to clear IPv6 neighbor information.
You can use the display ipv6 neighbors command to display the current IPv6 neighbor information.
# Clear neighbor information on all interfaces.
<Sysname> reset ipv6 neighbors all
# Clear all neighbor information on GigabitEthernet 3/1/4.
<Sysname> reset ipv6 neighbors interface GigabitEthernet 3/1/4
reset ipv6 pathmtu
reset ipv6 pathmtu { all | static | dynamic }
View
Default level
2: System level
all: Clears all PMTUs.
static: Clears all static PMTUs.
dynamic: Clears all dynamic PMTUs.
Use the reset ipv6 pathmtu the command to clear the PMTU information.
# Clear all PMTUs.
<Sysname> reset ipv6 pathmtu all
View
Default level
2: System level
slot slot number: Clears the IPv6 and ICMPv6 packets statistics of the specified card.
Use the reset ipv6 statistics command to clear the statistics of IPv6 packets and ICMPv6 packets.
You can use the display ipv6 statistics command to display the statistics of IPv6 and ICMPv6 packets.
# Clear the statistics of IPv6 packets and ICMPv6 packets.
<Sysname> reset ipv6 statistics
View
Default level
2: System level
None
Use the reset tcp ipv6 statistics command to clear the statistics of all IPv6 TCP connections.
You can use the display tcp ipv6 statistics command to display the statistics of IPv6 TCP connections.
# Clear the statistics of all IPv6 TCP connections.
<Sysname> reset tcp ipv6 statistics
View
Default level
2: System level
None
Use the reset udp ipv6 statistics command to clear the statistics of all IPv6 UDP packets.
You can use the display udp ipv6 statistics command to display the statistics of IPv6 UDP packets.
# Clear the statistics of all IPv6 UDP packets.
<Sysname> reset udp ipv6 statistics
tcp ipv6 timer fin-timeout
tcp ipv6 timer fin-timeout wait-time
undo tcp ipv6 timer fin-timeout
View
Default level
2: System level
wait-time: Length of the finwait timer for IPv6 TCP connections in seconds, in the range of 76 to 3,600.
Use the tcp ipv6 timer fin-timeout command to set the finwait timer for IPv6 TCP connections.
Use the undo tcp ipv6 timer fin-timeout command to restore the default finwait timer length.
By default, the length of the finwait timer is 675 seconds.
# Set the finwait timer length of IPv6 TCP connections to 800 seconds.
[Sysname] tcp ipv6 timer fin-timeout 800
tcp ipv6 timer syn-timeout
tcp ipv6 timer syn-timeout wait-time
undo tcp ipv6 timer syn-timeout
View
Default level
2: System level
wait-time: Length of the synwait timer for IPv6 TCP connections in seconds, in the range of 2 to 600.
Use the tcp ipv6 timer syn-timeout command to set the synwait timer for IPv6 TCP connections
Use the undo tcp ipv6 timer syn-timeout command to restore the default synwait timer length.
By default, the length of the synwait timer of IPv6 TCP connections is 75 seconds.
# Set the synwait timer length of IPv6 TCP connections to 100 seconds.
[Sysname] tcp ipv6 timer syn-timeout 100
tcp ipv6 window
tcp ipv6 window size
undo tcp ipv6 window
View
Default level
2: System level
size: Size of the IPv6 TCP sending/receiving buffer in KB (kilobyte), in the range of 1 to 32.
Use the tcp ipv6 window command to set the size of the IPv6 TCP sending/receiving buffer.
Use the undo tcp ipv6 window command to restore the default.
By default, the size of the IPv6 TCP sending/receiving buffer is 8 KB.
# Set the size of the IPv6 TCP sending/receiving buffer to 4 KB.
[Sysname] tcp ipv6 window 4
