05-Layer 3 - IP Services Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10305-Layer 3 - IP Services Command Reference
08-UDP Helper Commands
08-UDP Helper Commands 66.43 KB
display udp-helper server
display udp-helper server [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
View
Default level
2: System level
interface interface-type interface-number: Displays information of forwarded UDP packets on the specified interface.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
Use the display udp-helper server command to display the information of forwarded UDP packets on the specified interface or all interfaces.
If interface-type interface-number is not specified, this command displays the information of forwarded UDP packets on all interfaces.
# Display the information of forwarded UDP packets on the interface GigabitEthernet 3/1/1.
<Sysname> display udp-helper server interface GigabitEthernet 3/1/1
 Interface name         Server address      Packets sent
 GigabitEthernet3/1/1           192.1.1.2           0
The information above shows that the IP address of the destination server corresponding to the interface GigabitEthernet 3/1/1 is 192.1.1.2 and that no packets are forwarded to the destination server.
reset udp-helper packet
View
Default level
2: System level
None
Use the reset udp-helper packet command to clear the statistics of UDP packets forwarded.
Related commands: display udp-helper server.
# Clear the statistics of the forwarded UDP packets.
<Sysname> reset udp-helper packet
udp-helper enable
udp-helper enable
undo udp-helper enable
View
Default level
2: System level
None
Use the udp-helper enable command to enable UDP Helper. The router enabled with UDP Helper serves as a relay agent that converts UDP broadcast packets into unicast packets and forwards them to a specified destination server.
Use the undo udp-helper enable command to disable UDP Helper.
By default, UDP Helper is disabled.
# Enable UDP Helper
[Sysname] udp-helper enable
udp-helper port
undo udp-helper port { port-number | dns | netbios-ds | netbios-ns | tacacs | tftp | time }
View
Default level
2: System level
port-number: UDP port number with which packets need to be forwarded, in the range of 1 to 65535 (except 67 and 68).
dns: Forwards DNS data packets. The corresponding UDP port number is 53.
netbios-ds: Forwards NetBIOS data packets. The corresponding UDP port number is 138.
netbios-ns: Forwards NetBIOS name service data packets. The corresponding UDP port number is 137.
tacacs: Forwards terminal access controller access control system (TACACS) data packet. The corresponding UDP port number is 49.
tftp: Forwards TFTP data packets. The corresponding UDP port number is 69.
time: Forwards time service data packets. The corresponding UDP port number is 37.
Use the udp-helper port command to enable the forwarding of packets with the specified UDP port number.
Use the undo udp-helper port command to remove the configured UDP port numbers.
By default, no UDP port number is specified.
Note that:
·           You can configure up to 256 UDP ports on a router.
·           The specified UDP port numbers will all be removed if UDP Helper is disabled.
# Forward broadcast packets with the UDP destination port number 100.
[Sysname] udp-helper port 100
udp-helper server
udp-helper server ip-address
undo udp-helper server [ ip-address ]
View
Interface view
Default level
2: System level
ip-address: IP address of the destination server, in dotted decimal notation.
Use the udp-helper server command to specify the destination server which UDP packets need to be forwarded to.
Use the undo udp-helper server command to remove the destination server.
No destination server is configured by default.
Note that:
·           You can configure up to 20 destination servers on an interface.
·           You will remove all the destination servers on an interface if you carry out the undo udp-helper server command without the ip-address argument.
# Specify the IP address of the destination server as 192.1.1.2 on the interface GigabitEthernet 3/1/1.
[Sysname] interface GigabitEthernet 3/1/1
[Sysname-GigabitEthernet3/1/1] udp-helper server 192.1.1.2
