04-Layer 2 - WAN Command Reference
HomeSupportRoutersSR8800 SeriesReference GuidesCommand ReferencesH3C SR8800 Command Reference-Release3347-6W10304-Layer 2 - WAN Command Reference
00-Preface
00-Preface 91.17 KB
Preface
The H3C SR8800 documentation set includes 13 command references, which describe the commands and command syntax options available for the H3C SR8800 10G Core Routers.
The Layer 2—WAN Command Reference describes WAN configuration commands, including configuration commands for ATM, PPP, HDLC, and frame relay.
This preface includes:
·           Audience
·           Conventions
·           About the H3C SR8800 documentation set
·           Obtaining documentation
·           Technical support
·           Documentation feedback
Audience
·           Network planners
·           Field technical support and servicing engineers
·           Network administrators working with the SR8800
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your router.
The H3C SR8800 documentation set includes:
Category
Documents
Purposes
Product description and specifications
Marketing brochures
Describe product specifications and benefits.
Technology white papers
Provide an in-depth description of software features and technologies.
Card datasheets
Describe card specifications, features, and standards.
Hardware specifications and installation
Compliance and safety manual
Provides regulatory information and the safety instructions that must be followed during installation.
Installation guide
Provides a complete guide to hardware installation and hardware specifications.
H3C N68 Cabinet Installation and Remodel Introduction
Guides you through installing and remodeling H3C N68 cabinets.
H3C Pluggable SFP [SFP+][XFP] Transceiver Modules Installation Guide
Guides you through installing SFP/SFP+/XFP transceiver modules.
H3C High-End Network Products Hot-Swappable Module Manual
Describes the hot-swappable modules available for the H3C high-end network products, their external views, and specifications.
Software configuration
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Operations and maintenance
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
We appreciate your comments.
