整本手册
本章节下载 (1.02 MB)
H3C S5560-EI系列以太网交换机日志信息参考
Copyright © 2015-2018 新华三技术有限公司 版权所有,保留一切权利。 非经本公司书面许可,任何单位和个人不得擅自摘抄、复制本文档内容的部分或全部, 并不得以任何形式传播。本文档中的信息可能变动,恕不另行通知。 |
3.4 PFILTER_GLB_IPV4_DACT_NO_RES
3.5 PFILTER_GLB_IPV4_DACT_UNK_ERR
3.6 PFILTER_GLB_IPV6_DACT_NO_RES
3.7 PFILTER_GLB_IPV6_DACT_UNK_ERR
3.8 PFILTER_GLB_MAC_DACT_NO_RES
3.9 PFILTER_GLB_MAC_DACT_UNK_ERR
3.13 PFILTER_IF_IPV4_DACT_NO_RES
3.14 PFILTER_IF_IPV4_DACT_UNK_ERR
3.15 PFILTER_IF_IPV6_DACT_NO_RES
3.16 PFILTER_IF_IPV6_DACT_UNK_ERR
3.17 PFILTER_IF_MAC_DACT_NO_RES
3.18 PFILTER_IF_MAC_DACT_UNK_ERR
3.24 PFILTER_VLAN_IPV4_DACT_NO_RES
3.25 PFILTER_VLAN_IPV4_DACT_UNK_ERR
3.26 PFILTER_VLAN_IPV6_DACT_NO_RES
3.27 PFILTER_VLAN_IPV6_DACT_UNK_ERR
3.28 PFILTER_VLAN_MAC_DACT_NO_RES
3.29 PFILTER_VLAN_MAC_DACT_UNK_ERR
5.5 ARP_ACTIVE_ACK_NOREQUESTED_REPLY
10.11 FAN_DIRECTION_NOT_PREFERRED
12.1 DLDP_AUTHENTICATION_FAILED
13.1 ETHOAM_CONNECTION_FAIL_DOWN
13.2 ETHOAM_CONNECTION_FAIL_TIMEOUT
13.3 ETHOAM_CONNECTION_FAIL_UNSATISF
13.4 ETHOAM_CONNECTION_SUCCEED
13.8 ETHOAM_ENTER_LOOPBACK_CTRLLED
13.9 ETHOAM_ENTER_LOOPBACK_CTRLLING
13.11 ETHOAM_LOCAL_ERROR_FRAME
13.12 ETHOAM_LOCAL_ERROR_FRAME_PERIOD
13.13 ETHOAM_LOCAL_ERROR_FRAME_SECOND
13.16 ETHOAM_LOOPBACK_EXIT_ERROR_STATU
13.17 ETHOAM_LOOPBACK_NO_RESOURCE
13.18 ETHOAM_LOOPBACK_NOT_SUPPORT
13.19 ETHOAM_QUIT_LOOPBACK_CTRLLED
13.20 ETHOAM_QUIT_LOOPBACK_CTRLLING
13.22 ETHOAM_REMOTE_DYING_GASP
13.23 ETHOAM_REMOTE_ERROR_FRAME
13.24 ETHOAM_REMOTE_ERROR_FRAME_PERIOD
13.25 ETHOAM_REMOTE_ERROR_FRAME_SECOND
13.26 ETHOAM_REMOTE_ERROR_SYMBOL
13.28 ETHOAM_REMOTE_FAILURE_RECOVER
13.29 ETHOAM_REMOTE_LINK_FAULT
13.30 ETHOAM_NO_ENOUGH_RESOURCE
13.31 ETHOAM_NOT_CONNECTION_TIMEOUT
15.2 EVIISIS_LICENSE_UNAVAILABLE
15.4 EVIISIS_LICENSE_EXPIRED_TIME
16.1 FCOE_INTERFACE_NOTSUPPORT_FCOE
16.3 FCOE_LICENSE_EXPIRED_EXIT
16.4 FCOE_LICENSE_EXPIRED_TIME
17.1 FCLINK_FDISC_REJECT_NORESOURCE
17.2 FCLINK_FLOGI_REJECT_NORESOURCE
19.1 FCOE_FIPS_HARD_RESOURCE_NOENOUGH
19.2 FCOE_FIPS_HARD_RESOURCE_RESTORE
22.6 HTTPD_REACH_CONNECT_LIMIT
26.1 IRDP_EXCEED_ADVADDR_LIMIT
28.1 L2VPN_HARD_RESOURCE_NOENOUGH
28.2 L2VPN_HARD_RESOURCE_RESTORE
29.3 LAGG_INACTIVE_CONFIGURATION
29.5 LAGG_INACTIVE_HARDWAREVALUE
29.6 LAGG_INACTIVE_LOWER_LIMIT
29.9 LAGG_INACTIVE_RESOURCE_INSUFICIE
29.11 LAGG_INACTIVE_UPPER_LIMIT
31.3 LLDP_LESS_THAN_NEIGHBOR_LIMIT
31.5 LLDP_REACH_NEIGHBOR_LIMIT
35.7 LS_PWD_CHGPWD_FOR_AGEDOUT
35.9 LS_PWD_CHGPWD_FOR_COMPOSITION
35.10 LS_PWD_CHGPWD_FOR_FIRSTLOGIN
35.11 LS_PWD_CHGPWD_FOR_LENGTH
35.12 LS_PWD_FAILED2WRITEPASS2FILE
41.1 MGROUP_APPLY_SAMPLER_FAIL
41.2 MGROUP_RESTORE_CPUCFG_FAIL
41.3 MGROUP_RESTORE_IFCFG_FAIL
42.1 MPLS_HARD_RESOURCE_NOENOUGH
42.2 MPLS_HARD_RESOURCE_RESTORE
44.1 MTLK_UPLINK_STATUS_CHANGE
56.1 PORTSEC_PORTMODE_NOT_EFFECTIVE
56.2 PORTSEC_NTK_NOT_EFFECTIVE
59.2 QOS_POLICY_APPLYCOPP_CBFAIL
59.3 QOS_POLICY_APPLYCOPP_FAIL
59.4 QOS_POLICY_APPLYGLOBAL_CBFAIL
59.5 QOS_POLICY_APPLYGLOBAL_FAIL
59.6 QOS_POLICY_APPLYIF_CBFAIL
59.8 QOS_POLICY_APPLYVLAN_CBFAIL
59.9 QOS_POLICY_APPLYVLAN_FAIL
59.10 QOS_NOT_ENOUGH_BANDWIDTH
69.6 SNMP_AUTHENTICATION_FAILURE
70.2 SSHS_AUTH_EXCEED_RETRY_TIMES
70.11 SSHS_REACH_SESSION_LIMIT
75.1 TELNETD_REACH_SESSION_LIMIT
76.3 TRILL_INTF ENTERED_SUSPENDED
76.4 TRILL_INTF EXITED_SUSPENDED
76.5 TRILL_LICENSE_UNAVAILABLE
76.6 TRILL_LICENSE_UNAVAILABLE
76.7 TRILL_LICENSE_UNAVAILABLE
76.9 TRILL_LICENSE_EXPIRED_TIME
77.3 VLAN_VLANTRANSPARENT_FAILED
日志信息包含日志的参数介绍、产生原因、处理建议等,为用户进行系统诊断和维护提供参考。
除了S5560-EI特有的日志信息外,本文还包含S5560-EI Release1109版本基于的Comware V7平台版本的日志信息,其中的部分日志信息本产品可能并不支持,请以设备的实际情况为准。
本文假设您已具备数据通信技术知识,并熟悉H3C网络产品。
缺省情况下,日志采用RFC3164定义的格式:
<Int_16>TIMESTAMP HOSTNAME %%vendorMODULE/severity/MNEMONIC:locationAttributes; description
表1-1 日志字段说明
<Int_16> |
优先级标识符,仅存在于输出方向为日志主机的日志信息。优先级的计算公式为:facility*8+level · facility表示工具名称,由info-center loghost命令设置,主要用于在日志主机端标志不同的日志来源,查找、过滤对应日志源的日志 · level表示日志信息的等级,具体含义请参见表1-2 |
TIMESTAMP |
时间戳记录了日志信息产生的时间,方便用户查看和定位系统事件。用户可以自定义时间显示格式 |
HOSTNAME |
生成该日志信息的设备的名称或IP地址 |
%%vendor |
厂家标志,%%10 表示本字段表示本日志信息由H3C设备生成 本字段只有在日志信息发往日志主机时才会存在 |
MODULE |
生成该日志信息的功能模块的名称 |
severity |
日志信息的等级,具体说明请参见表1-2 |
MNEMONIC |
助记符,本字段为该日志信息的概述,是一个不超过32个字符的字符串 |
locationAttributes |
定位信息,为该日志信息的产生者。本字段的具体内容可能为: · 单板槽位号(分布式设备—独立运行模式) · IRF(Intelligent Resilient Framework,智能弹性架构)的成员设备编号(集中式IRF设备) · IRF的成员设备编号和单板槽位号(分布式设备—IRF模式) · 日志发送者的源IP 本字段是可选字段,格式如下: -attribute1=x-attribute2=y…-attributeN=z 日志位置信息和日志描述之间用分号和空格“; ”分隔 |
description |
该日志的具体内容,包含事件或错误发生的详细信息 对于本字段中的可变参数域,本文使用表1-3定义的方式表示 |
日志信息按严重性可划分为如表1-2所示的八个等级,各等级的严重性依照数值从0~7依次降低。
级别 |
严重程度 |
0 |
Emergency |
表示设备不可用的信息,如系统授权已到期 |
1 |
Alert |
表示设备出现重大故障,需要立刻做出反应的信息,如流量超出接口上限 |
2 |
Critical |
表示严重信息,如设备温度已经超过预警值,设备电源、风扇出现故障等 |
3 |
Error |
表示错误信息,如接口链路状态变化,存储卡拔出等 |
4 |
Warning |
表示警告信息,如接口连接断开,内存耗尽告警等 |
5 |
Notification |
表示正常出现但是重要的信息,如通过终端登录设备,设备重启等 |
6 |
Informational |
表示需要记录的通知信息,如通过命令行输入命令的记录信息,执行ping命令的日志信息等 |
7 |
Debug |
表示调试过程产生的信息 |
本文使用表1-3定义的方式表示日志描述字段中的可变参数域。
参数标识 |
参数类型 |
INT16 |
有符号的16位整数 |
UINT16 |
无符号的16位整数 |
INT32 |
有符号的32位整数 |
UINT32 |
无符号的32位整数 |
INT64 |
有符号的64位整数 |
UINT64 |
无符号的64位整数 |
DOUBLE |
有符号的双32位整数,格式为:[INT32].[INT32] |
HEX |
十六进制数 |
CHAR |
字节类型 |
STRING |
字符串类型 |
IPADDR |
IP地址 |
MAC |
MAC地址 |
DATE |
日期 |
TIME |
时间 |
表1-4列出了所有可能生成系统日志信息的软件模块。
模块名 |
模块全称 |
AAA |
Authentication, Authorization and Accounting |
ACL |
Access Control List |
APMGR |
Access Point Management |
ARP |
Address Resolution Protocol |
BFD |
Bidirectional Forwarding Detection |
BGP |
Border Gateway Protocol |
CFD |
Connectivity Fault Detection |
CFGMAN |
Configuration Management |
DEV |
Device Management |
DIAG |
Diagnosis |
DLDP |
Device Link Detection Protocol |
ETHOAM |
Ethernet Operation, Administration and Maintenance |
EVB |
Edge Virtual Bridging |
EVIISIS |
Ethernet Virtual Interconnect Intermediate System-to-Intermediate System |
FCOE |
Fibre Channel Over Ethernet |
FCLINK |
Fibre Channel Link |
FCZONE |
Fibre Channel Zone |
FIPS |
FIP Snooping |
FTP |
File Transfer Protocol |
HA |
High Availability |
HTTPD |
Hypertext Transfer Protocol Daemon |
IFNET |
Interface Net Management |
IKE |
Internet Key Exchange |
IPSEC |
IP Security |
IRDP |
ICMP Router Discovery Protocol |
ISIS |
L2VPN |
Layer 2 VPN |
LAGG |
Link Aggregation |
LDP |
Label Distribution Protocol |
LLDP |
Link Layer Discovery Protocol |
LOAD |
Load Management |
LOGIN |
Login |
LPDT |
Loopback Detection |
LS |
Local Server |
LSPV |
LSP Verification |
MAC |
Media Access Control |
MBFD |
MPLS BFD |
MDC |
Multitenant Device Context |
MFIB |
Multicast Forwarding Information Base |
MGROUP |
Mirroring group |
MPLS |
Multiprotocol Label Switching |
MSTP |
Multiple Spanning Tree Protocol |
MTLK |
Monitor Link |
ND |
Neighbor Discovery |
NQA |
Network Quality Analyzer |
NTP |
Network Time Protocol |
OPTMOD |
Optical Module |
OSPF |
Open INT16est Path First |
OSPFV3 |
Open INT16est Path First Version 3 |
PBB |
Provider Backbone Bridge |
PIM |
Protocol Independent Multicast |
PING |
Packet Internet Groper |
PKI |
Public Key Infrastructure |
PKT2CPU |
Packet to CPU |
PORTSEC |
Port Security |
PPP |
Point to Point Protocol |
PWDCTL |
Password Control |
QOS |
Quality of Service |
RADIUS |
Remote Authentication Dial In User Service |
RIP |
Routing Information Protocol |
RIPNG |
Routing Information Protocol Next Generation |
RM |
Routing Management |
SCM |
Service Control Manager |
SCRLSP |
Static CRLSP |
SHELL |
Shell |
SLSP |
Static LSP |
SMLK |
Smart Link |
SNMP |
Simple Network Management Protocol |
SSHS |
Secure Shell Server |
STAMGR |
Station Management |
STM |
Stack Topology Management (IRF) |
SYSLOG |
System Log |
TACACS |
Terminal Access Controller Access Control System |
TELNETD |
Telecom Munication Network Protocol Daemon |
TRILL |
Transparent Interconnect of Lots of Links |
VLAN |
Virtual Local Area Network |
VRRP |
Virtual Router Redundancy Protocol |
本文将系统日志信息按照软件模块分类,每个模块以字母顺序排序,在每个模块中,系统日志信息按照助记符的名称,以字母顺序排序。
本文以表格的形式对日志信息进行介绍。有关表中各项的含义请参考表1-5。
表项 |
举例 |
日志内容 |
显示日志信息的具体内容 |
ACL [UINT32] [STRING] [COUNTER64] packet(s). |
参数解释 |
按照参数在日志中出现的顺序对参数进行解释 参数顺序用“$数字”表示,例如“$1”表示在该日志中出现的第一个参数 |
$1:ACL编号 $2:ACL规则的ID和内容 $3:与ACL规则匹配的数据包个数 |
日志等级 |
日志严重等级 |
6 |
举例 |
一个真实的日志信息举例。由于不同的系统设置,日志信息中的“<Int_16>TIMESTAMP HOSTNAME %%vendor”部分也会不同,本文表格中的日志信息举例不包含这部分内容 |
ACL/6/ACL_STATIS_INFO: ACL 2000 rule 0 permit source 1.1.1.1 0 logging 10000 packet(s). |
日志说明 |
解释日志信息和日志生成的原因 |
匹配一条ACL规则的数据包个数。该日志会在数据包个数发生变化时输出 |
处理建议 |
建议用户应采取哪些处理措施。级别为6的“Informational”日志信息是正常运行的通知信息,用户无需处理 |
系统正常运行时产生的信息,无需处理 |
本节介绍AAA模块输出的日志信息。
日志内容 |
-AAAType=[STRING]-AAADomain=[STRING]-Service=[STRING]-UserName=[STRING]; AAA failed. |
参数解释 |
$1:AAA类型 $2:AAA方案 $3:服务 $4:用户名称 |
日志等级 |
5 |
举例 |
AAA/5/AAA_FAILURE: -AAAType=AUTHOR-AAADomain=domain1-Service=login-UserName=cwf@system; AAA is failed. |
日志说明 |
由于未收到服务器响应,用户名/密码错误,或其他原因(例如用户申请的服务类型不正确),用户的AAA请求被拒绝 |
处理建议 |
1. 检查设备与服务器的连接 2. 重新输入用户名和密码 3. 检查服务器上的设置(例如服务类型)是否正确 |
日志内容 |
-AAAType=[STRING]-AAADomain=[STRING]-Service=[STRING]-UserName=[STRING]; AAA launched. |
参数解释 |
日志等级 |
6 |
举例 |
AAA/6/AAA_LAUNCH: -AAAType=AUTHEN-AAADomain=domain1-Service=login-UserName=cwf@system; AAA launched. |
日志说明 |
用户发送AAA请求 |
处理建议 |
无 |
日志内容 |
-AAAType=[STRING]-AAADomain=[STRING]-Service=[STRING]-UserName=[STRING]; AAA is successful. |
参数解释 |
日志等级 |
6 |
举例 |
AAA/6/AAA_SUCCESS: -AAAType=AUTHOR-AAADomain=domain1-Service=login-UserName=cwf@system; AAA is successful. |
日志说明 |
接受用户的AAA请求 |
处理建议 |
无 |
本节介绍ACL模块输出的日志信息。
日志内容 |
IPv6 ACL [UINT32] [STRING] [UINT64] packet(s). |
参数解释 |
$1:ACL编号 $2:IPv6 ACL规则的ID及内容 $3:匹配上规则的报文个数 |
日志等级 |
6 |
举例 |
ACL6/6/ACL_IPV6_STATIS_INFO: IPv6 ACL 2000 rule 0 permit source 1:1::/64 logging 1000 packet(s). |
日志说明 |
匹配上IPv6 ACL规则的报文数量发生变化 |
处理建议 |
无 |
日志内容 |
Failed to configure [STRING] ACL [UINT] due to lack of memory |
参数解释 |
$1:ACL版本 $2:ACL编号 |
日志等级 |
3 |
举例 |
ACL/3/ACL_NO_MEM: Failed to configure ACL 2001 due to lack of memory. |
日志说明 |
内存不足导致配置ACL失败 |
处理建议 |
使用display memory-threshold命令检查内存使用情况 |
日志内容 |
参数解释 |
$1:ACL编号 $2:IPv4 ACL规则的ID及内容 $3:匹配上规则的报文个数 |
日志等级 |
6 |
举例 |
日志说明 |
匹配上IPv4 ACL规则的报文数量发生变化 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh the IPv4 default action to the [STRING] direction globally. The resources are insufficient. |
参数解释 |
$1:流量方向 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_GLB_IPV4_DACT_NO_RES: Failed to apply or refresh the IPv4 default action to the inbound direction globally. The resources are insufficient. |
日志说明 |
因硬件资源不足,系统无法在某个方向上全局应用或更新IPv4缺省动作 |
处理建议 |
使用display qos-acl resource命令检查硬件资源使用情况 |
日志内容 |
Failed to apply or refresh the IPv4 default action to the [STRING] direction globally. |
参数解释 |
$1:流量方向 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_GLB_IPV4_DACT_UNK_ERR: Failed to apply or refresh the IPv4 default action to the inbound direction globally. |
日志说明 |
因故障导致系统无法在某个方向上全局应用或更新IPv4缺省动作 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh the IPv6 default action to the [STRING] direction globally. The resources are insufficient. |
参数解释 |
$1:流量方向 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_GLB_IPV6_DACT_NO_RES: Failed to apply or refresh the IPv6 default action to the inbound direction globally. The resources are insufficient. |
日志说明 |
因硬件资源不足,系统无法在某个方向上全局应用或更新IPv6缺省动作 |
处理建议 |
日志内容 |
Failed to apply or refresh the IPv6 default action to the [STRING] direction globally. |
参数解释 |
$1:流量方向 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_GLB_IPV6_DACT_UNK_ERR: Failed to apply or refresh the IPv6 default action to the inbound direction globally. |
日志说明 |
因故障导致系统无法在某个方向上全局应用或更新IPv6缺省动作 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh the MAC default action to the [STRING] direction globally. The resources are insufficient. |
参数解释 |
$1:流量方向 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_GLB_MAC_DACT_NO_RES: Failed to apply or refresh the MAC default action to the inbound direction globally. The resources are insufficient. |
日志说明 |
因硬件资源不足,系统无法在某个方向上全局应用或更新MAC缺省动作 |
处理建议 |
日志内容 |
Failed to apply or refresh the MAC default action to the [STRING] direction globally. |
参数解释 |
$1:流量方向 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_GLB_MAC_DACT_UNK_ERR: Failed to apply or refresh the MAC default action to the inbound direction globally. |
日志说明 |
因故障导致系统无法在某个方向上全局应用或更新MAC缺省动作 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction globally. The resources are insufficient. |
参数解释 |
$1:ACL版本 $2:ACL编号 $3:规则的ID及内容 $4:流量方向 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_GLB_NO_RES: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction globally. The resources are insufficient. |
日志说明 |
因硬件资源不足,系统无法在某个方向上全局应用或更新ACL规则 |
处理建议 |
日志内容 |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction globally. The ACL is not supported. |
参数解释 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_GLB_NOT_SUPPORT: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction globally. The ACL is not supported. |
日志说明 |
因系统不支持ACL规则而导致无法在某个方向上全局应用或更新ACL规则 |
处理建议 |
检查ACL规则并删除不支持的配置 |
日志内容 |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction globally. |
参数解释 |
$1:ACL版本 $2:ACL编号 $3:ACL规则的ID及内容 $4:流量方向 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_GLB_UNK_ERR: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction globally. |
日志说明 |
因故障导致系统无法在某个方向上全局应用或更新ACL |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh the IPv4 default action to the [STRING] direction of interface [STRING]. The resources are insufficient. |
参数解释 |
$1:流量方向 $2:接口名称 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_IF_IPV4_DACT_NO_RES: Failed to apply or refresh the IPv4 default action to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient. |
日志说明 |
因硬件资源不足,系统无法在接口的某个方向上应用或更新IPv4缺省动作 |
处理建议 |
日志内容 |
Failed to apply or refresh the IPv4 default action to the [STRING] direction of interface [STRING]. |
参数解释 |
$1:流量方向 $2:接口名称 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_IF_IPV4_DACT_UNK_ERR: Failed to apply or refresh the IPv4 default action to the inbound direction of interface Ethernet 3/1/2. |
日志说明 |
因故障系统无法在接口的某个方向上应用或更新IPv4缺省动作 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh the IPv6 default action to the [STRING] direction of interface [STRING]. The resources are insufficient. |
参数解释 |
$1:流量方向 $2:接口名称 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_IF_IPV6_DACT_NO_RES: Failed to apply or refresh the IPv6 default action to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient. |
日志说明 |
因硬件资源不足,系统无法在接口的某个方向上应用或更新IPv6缺省动作 |
处理建议 |
日志内容 |
Failed to apply or refresh the IPv6 default action to the [STRING] direction of interface [STRING]. |
参数解释 |
$1:流量方向 $2:接口名称 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_IF_IPV6_DACT_UNK_ERR: Failed to apply or refresh the IPv6 default action to the inbound direction of interface Ethernet 3/1/2. |
日志说明 |
因故障系统无法在接口的某个方向上应用或更新IPv6缺省动作 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh the MAC default action to the [STRING] direction of interface [STRING]. The resources are insufficient. |
参数解释 |
$1:流量方向 $2:接口名称 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_IF_MAC_DACT_NO_RES: Failed to apply or refresh the MAC default action to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient. |
日志说明 |
因硬件资源不足,系统无法在接口的某个方向上应用或更新MAC缺省动作 |
处理建议 |
日志内容 |
Failed to apply or refresh the MAC default action to the [STRING] direction of interface [STRING]. |
参数解释 |
$1:流量方向 $2:接口名称 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_IF_MAC_DACT_UNK_ERR: Failed to apply or refresh the MAC default action to the inbound direction of interface Ethernet 3/1/2. |
日志说明 |
因故障系统无法在接口的某个方向上应用或更新MAC缺省动作 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of interface [STRING]. The resources are insufficient. |
参数解释 |
$1:ACL版本 $2:ACL编号 $3:ACL规则的ID及内容 $4:流量方向 $5:接口名称 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_IF_NO_RES: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient. |
日志说明 |
因硬件资源不足,系统无法在接口的某个方向上应用或更新ACL规则 |
处理建议 |
日志内容 |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of interface [STRING]. The ACL is not supported. |
参数解释 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_IF_NOT_SUPPORT: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of interface Ethernet 3/1/2. The ACL is not supported. |
日志说明 |
因系统不支持ACL规则而导致无法在接口的某个方向上应用或更新ACL规则 |
处理建议 |
检查ACL规则并删除不支持的配置 |
日志内容 |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of interface [STRING]. |
参数解释 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_IF_UNK_ERR: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of interface Ethernet 3/1/2. |
日志说明 |
因故障系统无法在接口的某个方向上应用或更新ACL规则 |
处理建议 |
无 |
日志内容 |
[STRING] ([STRING]): Packet-filter IPv6 [UINT32] [STRING] [STRING] [UINT64] packet(s). |
参数解释 |
$1:ACL应用目的地 $2:流量方向 $3:ACL编号 $4:ACL规则的ID及内容 $5:匹配上规则的报文个数 |
日志等级 |
6 |
举例 |
ACL/6/PFILTER_IPV6_STATIS_INFO: Ethernet0/4/0 (inbound): Packet-filter IPv6 2000 rule 0 permit source 1:1::/64 logging 1000 packet(s). |
日志说明 |
匹配上报文过滤中的IPv6 ACL规则的报文数量发生变化 |
处理建议 |
无 |
日志内容 |
[STRING] ([STRING]): Packet-filter [UINT32] [STRING] [UINT64] packet(s). |
参数解释 |
日志等级 |
6 |
举例 |
ACL/6/PFILTER_STATIS_INFO: Ethernet0/4/0 (inbound): Packet-filter 2000 rule 0 permit source 1.1.1.1 0 logging 10000 packet(s). |
日志说明 |
匹配上报文过滤中的IPv4 ACL规则的报文数量发生变化 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh the IPv4 default action to the [STRING] direction of VLAN [UINT16]. The resources are insufficient. |
参数解释 |
$1:流量方向 $2:VLAN ID |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_VLAN_IPV4_DACT_NO_RES: Failed to apply or refresh the IPv4 default action to the inbound direction of VLAN 1. The resources are insufficient. |
日志说明 |
因硬件资源不足,系统无法在VLAN的某个方向上应用或更新IPv4缺省动作 |
处理建议 |
日志内容 |
Failed to apply or refresh the IPv4 default action to the [STRING] direction of VLAN [UINT16]. |
参数解释 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_VLAN_IPV4_DACT_UNK_ERR: Failed to apply or refresh the IPv4 default action to the inbound direction of VLAN 1. |
日志说明 |
因故障系统无法在VLAN的某个方向上应用或更新IPv4缺省动作 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh the IPv6 default action to the [STRING] direction of VLAN [UINT16]. The resources are insufficient. |
参数解释 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_VLAN_IPV6_DACT_NO_RES: Failed to apply or refresh the IPv6 default action to the inbound direction of VLAN 1. The resources are insufficient. |
日志说明 |
因硬件资源不足,系统无法在VLAN的某个方向上应用或更新IPv6缺省动作 |
处理建议 |
日志内容 |
Failed to apply or refresh the IPv6 default action to the [STRING] direction of VLAN [UINT16]. |
参数解释 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_VLAN_IPV6_DACT_UNK_ERR: Failed to apply or refresh the IPv6 default action to the inbound direction of VLAN 1. |
日志说明 |
因故障系统无法在VLAN的某个方向上应用或更新IPv6缺省动作 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh the MAC default action to the [STRING] direction of VLAN [UINT16]. The resources are insufficient. |
参数解释 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_VLAN_MAC_DACT_NO_RES: Failed to apply or refresh the MAC default action to the inbound direction of VLAN 1. The resources are insufficient. |
日志说明 |
因硬件资源不足,系统无法在VLAN的某个方向上应用或更新MAC缺省动作 |
处理建议 |
日志内容 |
Failed to apply or refresh the MAC default action to the [STRING] direction of VLAN [UINT16]. |
参数解释 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_VLAN_MAC_DACT_UNK_ERR: Failed to apply or refresh the MAC default action to the inbound direction of VLAN 1. |
日志说明 |
因故障系统无法在VLAN的某个方向上应用或更新MAC缺省动作 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of VLAN [UINT16]. The resources are insufficient. |
参数解释 |
$1:ACL版本 $2:ACL编号 $3:ACL规则的ID及内容 $4:流量方向 $5:VLAN ID |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_VLAN_NO_RES: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of VLAN 1. The resources are insufficient. |
日志说明 |
因硬件资源不足,系统无法在VLAN的某个方向上应用或更新ACL规则 |
处理建议 |
日志内容 |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of VLAN [UINT16]. The ACL is not supported. |
参数解释 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_VLAN_NOT_SUPPORT: Failed to apply or refresh ACL 2000 rule 1 to the inbound direction of VLAN 1. The ACL is not supported. |
日志说明 |
因系统不支持ACL规则而导致无法在VLAN的某个方向上应用或更新ACL规则 |
处理建议 |
检查ACL规则并删除不支持的配置 |
日志内容 |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of VLAN [UINT16]. |
参数解释 |
日志等级 |
3 |
举例 |
PFILTER/3/PFILTER_VLAN_UNK_ERR: Failed to apply or refresh ACL 2000 rule 1 to the inbound direction of VLAN 1. |
日志说明 |
因故障系统无法在VLAN的某个方向上应用或更新ACL规则 |
处理建议 |
无 |
本节介绍AP管理模块输出的日志信息。
日志内容 |
Add BAS AC [STRING]. |
参数解释 |
$1:BAS AC的MAC地址 |
日志等级 |
6 |
举例 |
APMGR/6/APMGR_ADDBAC_INFO: Add BAS AC 3ce5-a616-28cd. |
日志说明 |
Master AC与BAS AC建立连接。 |
处理建议 |
无 |
日志内容 |
Delete BAS AC [STRING]. |
参数解释 |
$1:BAS AC的MAC地址 |
日志等级 |
6 |
举例 |
APMGR/6/APMGR_DELBAC_INFO: Delete BAS AC 3ce5-a616-28cd. |
日志说明 |
Master AC断开与BAS AC的连接 |
处理建议 |
无 |
本节介绍ARP模块输出的日志信息。
日志内容 |
Duplicate address [STRING] on interface [STRING], sourced from [STRING] |
参数解释 |
$1:IP 地址 $2:接口名称 $3:MAC 地址 |
日志等级 |
6 |
举例 |
ARP/6/DUPIFIP: Duplicate address 1.1.1.1 on interface Ethernet1/1/1, sourced from 0015-E944-A947 |
日志说明 |
ARP检测到重复地址 接口收到ARP报文的发送端IP地址与该接口的IP地址重复 |
处理建议 |
修改IP地址配置 |
日志内容 |
IP address [STRING] conflicts with global or imported IP address, sourced from [STRING] |
参数解释 |
$1:IP 地址 $2:MAC 地址 |
日志等级 |
6 |
举例 |
ARP/6/DUPIP: IP address 30.1.1.1 conflicts with global or import IP address, sourced from 0000-0000-0001 |
日志说明 |
收到ARP报文中的发送端IP地址与全局或导入的IP地址冲突 |
处理建议 |
修改IP地址配置 |
日志内容 |
IP address [STRING] collision with VRRP virtual IP address on interface [STRING], sourced from [STRING] |
参数解释 |
日志等级 |
6 |
举例 |
ARP/6/DUPVRRPIP: IP address 1.1.1.1 conflicts with VRRP virtual IP address on interface Ethernet1/1/1, sourced from 0015-E944-A947 |
日志说明 |
收到ARP报文中的发送端IP与VRRP虚拟IP地址冲突 |
处理建议 |
修改IP地址配置 |
日志内容 |
No ARP reply from IP [STRING] was received on interface [STRING] |
参数解释 |
$1:IP 地址 $2:接口名称 |
日志等级 |
6 |
举例 |
ARP/6/ARP_ACTIVE_ACK_NO_REPLY: No ARP reply from IP 192.168.10.1 was received on interface Ethernet0/1/0. |
日志说明 |
ARP主动确认功能检测到攻击 接口向所收到ARP报文的发送端IP发送ARP请求,未收到ARP应答 |
处理建议 |
检查ARP报文发送主机的合法性 |
日志内容 |
Interface [STRING] received from IP [STRING] an ARP reply that was not requested by the device. |
参数解释 |
$1:接口名称 $2:IP地址 |
日志等级 |
6 |
举例 |
ARP/6/ARP_ACTIVE_ACK_NOREQUESTED_REPLY: Interface Ethernet0/1/0 received from IP 192.168.10.1 an ARP reply that was not requested by the device. |
日志说明 |
ARP主动确认功能检测到攻击 接口在未向ARP报文发送端IP地址发送ARP请求的情况下,收到ARP应答 |
处理建议 |
此种情况下设备会自动丢弃攻击报文,用户无需处理 |
日志内容 |
The ARP packet rate ([UINT32] pps) exceeded the rate limit ([UINT32] pps) on interface [STRING] in the last [UINT32] seconds |
参数解释 |
$1:ARP报文速率 $2:ARP报文限速速率 $3:接口名称 $4:间隔时间 |
日志等级 |
4 |
举例 |
ARP/4/ARP_RATE_EXCEEDED: The ARP packet rate (100 pps) exceeded the rate limit (80 pps) on interface Ethernet0/1/0 in the last 10 seconds. |
日志说明 |
接口接收ARP报文速率超过了接口的限速值 |
处理建议 |
检查ARP报文发送主机的合法性 |
日志内容 |
Sender IP [STRING] was not on the same network as the receiving interface [STRING] |
参数解释 |
$1:IP地址 $2:接口名称 |
日志等级 |
6 |
举例 |
ARP/6/ARP_SENDER_IP_INVALID: Sender IP 192.168.10.2 was not on the same network as the receiving interface Ethernet0/1/0. |
日志说明 |
接口收到ARP报文中发送端IP与本接口不在同一网段 |
处理建议 |
检查发送端IP对应主机的合法性 |
日志内容 |
Sender MAC [STRING] was not identical to Ethernet source MAC [STRING] on interface [STRING] |
参数解释 |
$1:MAC 地址 $2:MAC 地址 $3:接口名称 |
日志等级 |
6 |
举例 |
ARP/6/ARP_SENDER_MAC_INVALID: Sender MAC 0000-5E14-0E00 was not identical to Ethernet source MAC 0000-5C14-0E00 on interface Ethernet0/1/0. |
日志说明 |
接口收到ARP报文的以太网数据帧首部中的源MAC地址和ARP报文中的发送端MAC地址不同 |
处理建议 |
检查发送端MAC地址对应主机的合法性 |
日志内容 |
An attack from MAC [STRING] was detected on interface [STRING] |
参数解释 |
$1:MAC 地址 $2:接口名称 |
日志等级 |
6 |
举例 |
ARP/6/ARP_SRC_MAC_FOUND_ATTACK: An attack from MAC 0000-5E14-0E00 was detected on interface Ethernet0/1/0. |
日志说明 |
源MAC地址固定的ARP攻击检测功能检测到攻击 5秒内,收到同一源MAC地址(源MAC地址固定)的ARP报文超过一定的阈值 |
处理建议 |
检查该源MAC地址对应主机的合法性 |
日志内容 |
Target IP [STRING] was not the IP of the receiving interface [STRING] |
参数解释 |
$1:IP 地址 $2:接口名称 |
日志等级 |
6 |
举例 |
ARP/6/ARP_TARGET_IP_INVALID: Target IP 192.168.10.2 was not the IP of the receiving interface Ethernet0/1/0. |
日志说明 |
接口收到ARP报文中的目标IP与本接口IP不一致 |
处理建议 |
检查发送ARP报文的主机的合法性 |
本节介绍BFD模块输出的日志信息。
日志内容 |
Sess[STRING], Sta: [STRING]->[STRING], Diag: [UINT32] |
参数解释 |
$1:BFD会话的源地址、目的地址、接口和消息类型 $2:变化前状态机的名称 $3:变化后状态机的名称 $4:诊断码 |
日志等级 |
5 |
举例 |
BFD/5/BFD_CHANGE_FSM:Sess[20.0.4.2/20.0.4.1,LD/RD:533/532, Interface:Vlan204, SessType:Ctrl, LinkType:INET], Sta: INIT->UP, Diag: 0. |
日志说明 |
BFD会话的状态机发生变化。当BFD会话Up或Down时出现此信息。如果出现会话异常丢失的情况,可能由高错误率或高丢包率导致 |
处理建议 |
需要检查是否BFD配置的问题或网络出现拥塞 |
日志内容 |
The total number of BFD sessions [UINT] reached the upper limit. Please avoid creating a new session. |
参数解释 |
$1:BFD会话总数 |
日志等级 |
5 |
举例 |
BFD/5/BFD_REACHED_UPPER_LIMIT: The total number of BFD session 100 reached upper limit. Please avoid creating a new session. |
日志说明 |
BFD会话总数达到上限 |
处理建议 |
请检查BFD会话配置 |
本节介绍BGP模块输出的日志信息。
日志内容 |
The number of routes from peer [STRING] in exceeded the limit [UINT32]. |
参数解释 |
$1:BGP对等体的IP地址 $2:允许从对等体接收的最大路由前缀数量 |
日志等级 |
4 |
举例 |
BGP/4/BGP_EXCEEDED_ROUTE_LIMIT: The number of routes from peer 1.1.1.1 in exceeded the limit 100. |
日志说明 |
从对等体或对等体组学到的路由数量超过了允许的最大路由数量 |
处理建议 |
查看是否需要增大允许的最大路由数量 |
日志内容 |
Threshold value [UINT32] reached for prefixes received from peer [STRING]. |
参数解释 |
$1:接收的路由数量占允许的最大路由数量百分比的阈值 $2:BGP对等体的IP地址 |
日志等级 |
5 |
举例 |
BGP/5/BGP_RECHED_THRESHOLD: Threshold value 20 reached for prefixes received from peer 1.1.1.1. |
日志说明 |
接收的路由数量占允许的最大路由数量的百分比达到了阈值 |
处理建议 |
1. 查看是否需要增大以下数值: 2. 允许的最大路由数量 3. 接收的路由数量占允许的最大路由数量的百分比 |
日志内容 |
BGP Process receive system memory alert [STRING] event. |
参数解释 |
$1:内存告警的类型 |
日志等级 |
5 |
举例 |
BGP/5/BGP_MEM_ALERT: BGP Process receive system memory alert start event. |
日志说明 |
BGP模块收到内存告警信息 |
处理建议 |
检查系统内存 |
日志内容 |
[STRING] state is changed from [STRING] to [STRING]. BGP. [STRING]: [STRING] State is changed from [STRING]to [STRING]. |
参数解释 |
$1:VPN实例名称 $2:BGP对等体的IP地址 $3:变化前的状态名称 $4:变化后的状态名称 |
日志等级 |
5 |
举例 |
BGP/5/BGP_STATE_CHANGED: BGP.vpn1:192.99.0.2 state is changed from ESTABLISHED to IDLE. |
日志说明 |
BGP对等体的状态发生变化 此日志信息当BGP对等体从其他状态进入Established状态或者从Established状态进入其他状态时产生 |
处理建议 |
如果BGP对等体意外Down,请检查网络是否发生故障或丢包 |
本节介绍CFD模块输出的日志信息。
日志内容 |
MEP [UINT16] in SI [INT32] received a cross-connect CCM. It’s SrcMAC is [MAC], SeqNum is [INT32], RMEP is [UINT16], MD ID is [STRING], MA ID is [STRING]. |
参数解释 |
$1:服务实例的ID $2:本地MEP的ID $3:源MAC地址 $4:序列号 $5:远端MEP的ID $6:MD的ID。如果不存在,会显示“without ID” $7:MA的ID |
日志等级 |
6 |
举例 |
CFD/6/CFD_CROSS_CCM: MEP 13 in SI 10 received a cross-connect CCM. Its SrcMAC is 0011-2233-4401, SeqNum is 78, RMEP is 12, MD ID is without ID, MA ID is 0. |
日志说明 |
MEP收到交叉连接的CCM报文,该报文包含与本端不同的MA ID或MD ID |
处理建议 |
检查两端MEP的配置。让MEP所属的MD和MA的配置一致,且两端MEP级别相同、方向都相同 |
日志内容 |
MEP [UINT16] in SI [INT32] received an error CCM. It’s SrcMAC is [MAC], SeqNum is [INT32], RMEP is [UINT16], MD ID is [STRING], MA ID is [STRING]. |
参数解释 |
日志等级 |
6 |
举例 |
CFD/6/CFD_ERROR_CCM: MEP 2 in SI 7 received an error CCM. Its SrcMAC is 0011-2233-4401, SeqNum is 21, RMEP is 2, MD ID is 7, MA ID is 1. |
日志说明 |
MEP收到错误的CCM报文,该报文包含错误的MEP ID或生存时间 |
处理建议 |
检查CCM配置。让两端的CC检测周期配置一致,并配置远端MEP ID在本端允许的MEP列表中 |
日志内容 |
MEP [UINT16] in SI [INT32] failed to receive CCMs from RMEP [UINT16]. |
参数解释 |
$1:本地MEP的ID $2:服务实例ID $3:远端MEP的ID |
日志等级 |
6 |
举例 |
CFD/6/CFD_LOST_CCM: MEP 1 in SI 7 received CCMs from RMEP 2. |
日志说明 |
MEP在3.5个CCM报文发送周期内没有收到CCM报文,可能的原因是链路故障或远端MEP在此期间没有发送CCM报文 |
处理建议 |
检查链路状态和远端MEP的配置。如果链路down了或有其它的故障,例如单通故障,则恢复此链路。如果远端配置了同一服务实例的MEP,则确认两端的CC发送周期是一致的 |
日志内容 |
MEP [UINT16] in SI [INT32] received CCMs from RMEP [UINT16] |
参数解释 |
日志等级 |
6 |
举例 |
CFD/6/CFD_RECEIVE_CCM: MEP 1 in SI 7 received CCMs from RMEP 2. |
日志说明 |
MEP收到远端MEP发送的CCM报文 |
处理建议 |
无 |
本节介绍配置管理模块输出的日志信息。
日志内容 |
-EventIndex=[INT32]-CommandSource=[INT32]-ConfigSource=[INT32]-ConfigDestination=[INT32]; Configuration is changed. |
参数解释 |
$1:事件索引,取值范围为 1到2147483647 $2:源命令,取值范围为1到3 $3:源配置,取值范围为1到7 $4:目的配置,取值范围为1到7 |
日志等级 |
5 |
举例 |
CFGMAN/5/CFGMAN_CFGCHANGED: -EventIndex=[6]-CommandSource=[2]-ConfigSource=[4]-ConfigDestination=[2]; Configuration is changed. |
日志说明 |
如果配置在过去的十分钟内发生了变化,设备将记录事件索引、源命令、源配置以及目的配置 |
处理建议 |
无 |
日志内容 |
-OperateType=[INT32]-OperateTime=[INT32]-OperateState=[INT32]-OperateEndTime=[INT32]; Operation is completed. |
参数解释 |
$1:操作类型,取值范围为1到6 $2:操作时间 $3:操作状态,取值范围为1到20 $4:操作结束时间 |
日志等级 |
5 |
举例 |
CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=[1]-OperateTime=[248]-OperateState=[2]-OperateEndTime=[959983]; Operation is completed. |
日志说明 |
操作完成后记录操作的类型、状态以及时间 |
处理建议 |
无 |
本节介绍DEV(设备管理)模块输出的日志信息。
日志内容 |
Board is rebooting on Chassis [INT32] Slot [INT32]. |
参数解释 |
$1:成员编号 $2:槽位号 |
日志等级 |
5 |
举例 |
DEV/5/BOARD_REBOOT: Board is rebooting on Chassis 1 Slot 5. |
日志说明 |
用户在重启单板,或者单板因为异常而重启 |
处理建议 |
1. 检查是否有用户在重启单板 2. 如果没有用户重启,等待单板重新启动后,通过display version命令、对应单板信息中的Last reboot reason字段,查看重启原因 3. 如果重启原因为异常重启,请联系技术支持 |
日志内容 |
Board is removed from Chassis [INT32] Slot [INT32], type is [STRING]. |
参数解释 |
$1:成员编号 $2:槽位号 $3:单板类型 |
日志等级 |
3 |
举例 |
DEV/3/BOARD_REMOVED: Board is removed from Chassis 1 Slot 5, type is LSQ1FV48SA. |
日志说明 |
一块LPU或者备用MPU被拔出 |
处理建议 |
检查设备,核实情况 |
日志内容 |
Board state changes to NORMAL on Chassis [INT32] Slot [INT32], type is [STRING]. |
参数解释 |
$1:成员编号 $2:槽位号 $3:单板类型. |
日志等级 |
5 |
举例 |
DEV/5/BOARD_STATE_NORMAL: Board state changes to NORMAL on Chassis 1 Slot 5, type is LSQ1FV48SA. |
日志说明 |
一块新插入的LPU或者备用MPU完成了初始化 |
处理建议 |
无 |
日志内容 |
Board state changes to FAULT on Chassis [INT32] Slot [INT32], type is [STRING]. |
参数解释 |
日志等级 |
2 |
举例 |
DEV/2/BOARD_STATE_FAULT: Board state changes to FAULT on Chassis 1 Slot 5, type is LSQ1FV48SA. |
日志说明 |
单板在以下情况会处于Fault(故障)状态: · 单板处于启动阶段(正在初始化或者加载软件版本),单板不可用 · 单板不能正常工作 |
处理建议 |
据日志产生的情况,处理建议如下: · 对于第一种情况:单板型号不同,加载的软件版本不同,启动所需的时间不同。一般不超过10分钟,请以设备的实际情况为准 · 对于第二种情况:请联系技术支持 |
日志内容 |
Compact Flash Card is inserted in Chassis [INT32] Slot [INT32] Compact Flash Slot [INT32]. |
参数解释 |
$1:成员编号 $2:槽位号 $3:Flash槽位号 |
日志等级 |
4 |
举例 |
DEV/4/CFCARD_INSERTED: Compact Flash Card is inserted in Chassis 1 Slot 5 Compact Flash Slot 1. |
日志说明 |
一块CF卡安装到了指定槽位 |
处理建议 |
无 |
日志内容 |
Compact Flash Card is removed from Chassis [INT32] Slot [INT32] Compact Flash Slot [INT32]. |
参数解释 |
日志等级 |
3 |
举例 |
DEV/3/CFCARD_REMOVED: Compact Flash Card is removed from Chassis 1 Slot 5 Compact Flash Slot 1. |
日志说明 |
一块CF卡被拔出 |
处理建议 |
检查设备,核实情况 |
日志内容 |
Chassis [INT32] is rebooting now. |
参数解释 |
$1:成员编号 |
日志等级 |
5 |
举例 |
DEV/5/CHASSIS_REBOOT: Chassis 1 is rebooting now. |
日志说明 |
用户在重启成员设备,或者成员设备因为异常而重启 |
处理建议 |
1. 检查是否有用户在重启成员设备 2. 如果没有用户重启,等待成员设备重新启动后,通过display version命令、对应成员设备单板信息中的Last reboot reason字段,查看重启原因 3. 如果重启原因为异常重启,请联系技术支持 |
日志内容 |
-User=[STRING]-IPAddr=[IPADDR]; System clock changed from [STRING] to [STRING]. |
参数解释 |
$ 1:当前登录用户的用户名 $2:当前登录用户的IP地址 $3:老时间 $4:新时间 |
日志等级 |
5 |
举例 |
DEV/5/DEV_CLOCK_CHANGE: -User=[STRING]-IPAddr=[IPADDR]; System clock changed from 15:49:52 11/02/2011 to 15:50:00 11/02/2011. |
日志说明 |
系统时间发生了变更 |
处理建议 |
无 |
日志内容 |
Chassis [INT32] Fan [INT32] is absent. |
参数解释 |
$1:成员编号 $2:风扇ID |
日志等级 |
3 |
举例 |
DEV/3/FAN_ABSENT: Chassis 1 Fan 2 is absent. |
日志说明 |
指定位置没有风扇或者风扇被拔出 |
处理建议 |
检查设备,核实情况 |
日志内容 |
参数解释 |
$1:风扇ID |
日志等级 |
3 |
举例 |
DEV/3/FAN_ABSENT: Fan 2 is absent. |
日志说明 |
指定位置没有风扇,或风扇被拔出 |
处理建议 |
1. 如果指定位置没有风扇,则可能因散热不好,引起设备温度升高,建议安装风扇 2. 如果有风扇,检查风扇框是否插紧 3. 检查风扇框是否损坏 4. 重新安装风扇框或更换风扇框 |
日志内容 |
Fan [INT32] airflow direction is not preferred on slot [INT32], please check it. |
参数解释 |
$1:风扇ID $2:槽位号 |
日志等级 |
1 |
举例 |
DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 1 airflow direction is not preferred on slot 3, please check it. |
日志说明 |
风扇的风道方向不是用户期望的方向。风扇方向配置出错或者插错风扇 |
处理建议 |
1. 根据机房通风系统的风向,选择风向一致的型号的风扇 2. 如果风扇风向和机房通风系统风向一致,请调整风扇风向的配置 |
日志内容 |
Chassis [INT32] Fan [INT32] failed. |
参数解释 |
$1:成员编号 $2:风扇ID |
日志等级 |
2 |
举例 |
DEV/2/FAN_FAILED: Chassis 1 Fan 2 failed. |
日志说明 |
风扇出现了故障,停止了工作 |
处理建议 |
检查风扇,排除故障 |
日志内容 |
参数解释 |
$1:风扇ID |
日志等级 |
2 |
举例 |
DEV/2/FAN_FAILED: Fan 2 failed. |
日志说明 |
风扇出现了故障,停止工作 |
处理建议 |
更换风扇 |
日志内容 |
Chassis [INT32] Fan [INT32] recovered. |
参数解释 |
$1:成员编号 $2:风扇ID |
日志等级 |
5 |
举例 |
DEV/5/FAN_RECOVERED: Chassis 1 Fan 2 recovered. |
日志说明 |
插入风扇,稍后,风扇转入正常工作状态 |
处理建议 |
无 |
日志内容 |
参数解释 |
$1:风扇ID |
日志等级 |
5 |
举例 |
DEV/5/FAN_RECOVERED: Fan 2 recovered. |
日志说明 |
处理建议 |
无 |
日志内容 |
Power [INT32] is absent. |
参数解释 |
$1:电源模块ID |
日志等级 |
3 |
举例 |
DEV/3/POWER_ABSENT: Power 1 is absent. |
日志说明 |
电源模块被拔出 |
处理建议 |
1. 检查电源是否插紧 2. 检查电源是否损坏 3. 重新安装电源或更换电源 |
日志内容 |
Chassis [INT32] Power [INT32] is absent. |
参数解释 |
$1:成员编号 $2:电源模块ID |
日志等级 |
3 |
举例 |
DEV/3/POWER_ABSENT: Chassis 1 Power 1 is absent. |
日志说明 |
电源模块被拔出 |
处理建议 |
检查设备,核实情况 |
日志内容 |
Power [INT32] failed. |
参数解释 |
$1:电源模块ID |
日志等级 |
2 |
举例 |
DEV/2/POWER_FAILED: Power 1 failed. |
日志说明 |
电源模块出现故障 |
处理建议 |
更换电源 |
日志内容 |
Chassis [INT32] Power [INT32] failed. |
参数解释 |
$1:成员编号 $2:电源模块ID |
日志等级 |
2 |
举例 |
DEV/2/POWER_FAILED: Chassis 1 Power 1 failed. |
日志说明 |
电源模块出现故障 |
处理建议 |
检查电源模块,排除故障 |
日志内容 |
Power monitor unit [INT32] is absent. |
参数解释 |
$1:电源监控模块ID |
日志等级 |
3 |
举例 |
DEV/3/POWER_MONITOR_ABSENT: Power monitor unit 1 is absent. |
日志说明 |
电源监控模块被拔出 |
处理建议 |
1. 检查电源监控模块是否插紧 2. 检查电源监控模块是否损坏 3. 重新安装电源监控模块或更换电源监控模块 |
日志内容 |
Chassis [INT32] Power monitor unit [INT32] is absent. |
参数解释 |
$1:成员编号 $2:电源监视模块ID |
日志等级 |
3 |
举例 |
DEV/3/POWER_MONITOR_ABSENT: Chassis 2 Power monitor unit 1 is absent. |
日志说明 |
电源监视模块被拔出 |
处理建议 |
检查设备,核实情况。如果需要,安装电源监视模块 |
日志内容 |
Power monitor unit [INT32] failed. |
参数解释 |
$1:电源监控模块ID |
日志等级 |
2 |
举例 |
DEV/2/POWER_MONITOR_FAILED: Power monitor unit 1 failed. |
日志说明 |
电源监控模块出现故障 |
处理建议 |
更换电源监控模块 |
日志内容 |
Chassis [INT32] Power monitor unit [INT32] failed. |
参数解释 |
日志等级 |
2 |
举例 |
DEV/2/POWER_MONITOR_FAILED: Chassis 2 Power monitor unit 1 failed. |
日志说明 |
电源监视模块出现故障 |
处理建议 |
检查电源监视模块,排除故障 |
日志内容 |
Power monitor unit [INT32] recovered. |
参数解释 |
$1:电源监控模块ID |
日志等级 |
5 |
举例 |
DEV/5/POWER_MONITOR_RECOVERED: Power monitor unit 1 recovered. |
日志说明 |
电源监控模块插入后,状态从Failed或者Absent状态转换为OK |
处理建议 |
无 |
日志内容 |
Chassis [INT32] Power monitor unit [INT32] recovered. |
参数解释 |
日志等级 |
5 |
举例 |
DEV/5/POWER_MONITOR_RECOVERED: Chassis 2 Power monitor unit 1 recovered. |
日志说明 |
电源监视模块插入后,状态从Failed或者Absent状态转换为OK |
处理建议 |
无 |
日志内容 |
Power [INT32] recovered. |
参数解释 |
$1:电源模块ID |
日志等级 |
5 |
举例 |
DEV/5/POWER_RECOVERED: Power 1 recovered. |
日志说明 |
电源模块插入后,状态从Failed或者Absent状态转换为OK |
处理建议 |
无 |
日志内容 |
Chassis [INT32] Power [INT32] recovered. |
参数解释 |
$1:成员编号 $2:电源模块ID |
日志等级 |
5 |
举例 |
DEV/5/POWER_RECOVERED: Chassis 1 Power 1 recovered. |
日志说明 |
处理建议 |
无 |
日志内容 |
RPS [INT32] is absent. |
参数解释 |
$1:RPS ID |
日志等级 |
3 |
举例 |
DEV/3/RPS_ABSENT: RPS 1 is absent. |
日志说明 |
RPS被拔出 |
处理建议 |
1. 检查RPS电源是否插紧 2. 检查RPS电源是否损坏 3. 重新安装RPS电源或更换RPS电源 |
日志内容 |
Chassis [INT32] RPS [INT32] is absent. |
参数解释 |
$1:成员编号 $2:RPS ID |
日志等级 |
3 |
举例 |
DEV/3/RPS_ABSENT: Chassis 1 RPS 1 is absent. |
日志说明 |
RPS被拔出 |
处理建议 |
日志内容 |
RPS [INT32] is normal. |
参数解释 |
$1:RPS ID |
日志等级 |
5 |
举例 |
DEV/5/RPS_NORMAL: RPS 1 is normal. |
日志说明 |
RPS插入后,状态正常 |
处理建议 |
无 |
日志内容 |
Chassis [INT32] RPS [INT32] is normal. |
参数解释 |
$1:成员编号 $2:RPS ID |
日志等级 |
5 |
举例 |
DEV/5/RPS_NORMAL: Chassis 1 RPS 1 is normal. |
日志说明 |
RPS插入后,状态正常 |
处理建议 |
无 |
日志内容 |
SubCard state changes to FAULT on Chassis [INT32] slot [INT32] SubSlot [INT32], type is [STRING]. |
参数解释 |
$1:成员编号 $2:槽位号 $3:子槽位号 $4:子卡类型 |
日志等级 |
2 |
举例 |
DEV/2/SUBCARD_FAULT: SubCard state changes to FAULT on Chassis 1 slot 5 SubSlot 1, type is MIM-1ATM-OC3SML. |
日志说明 |
子卡重启,稍后,子卡状态转换为Fault |
处理建议 |
检查设备,确认原因 |
日志内容 |
SubCard is inserted in Chassis [INT32] Slot [INT32] SubSlot [INT32], type is [STRING]. |
参数解释 |
日志等级 |
4 |
举例 |
DEV/4/SUBCARD_INSERTED: SubCard is inserted in Chassis 1 Slot 5 SubSlot 1, type is MIM-1ATM-OC3SML. |
日志说明 |
一块子卡安装到了指定槽位 |
处理建议 |
无 |
日志内容 |
SubCard is rebooting on Chassis [INT32] Slot [INT32] SubSlot [INT32]. |
参数解释 |
$1:成员编号 $2:槽位号 $3:子槽位号 |
日志等级 |
5 |
举例 |
DEV/5/SUBCARD_REBOOT: SubCard is rebooting on Chassis 1 Slot 5 SubSlot 1. |
日志说明 |
用户在重启子卡或者子卡因为运行异常自动重启 |
处理建议 |
如果子卡重启后能正常运行,则无需处理。如果您想进一步了解异常重启的原因或者子卡不断自动重启,请联系技术支持 |
日志内容 |
SubCard is removed from Chassis [INT32] Slot [INT32] SubSlot [INT32], type is [STRING]. |
参数解释 |
日志等级 |
3 |
举例 |
DEV/3/SUBCARD_REMOVED: SubCard is removed from Chassis 1 Slot 5 SubSlot 1, type is MIM-1ATM-OC3SML. |
日志说明 |
一块子卡被拔出 |
处理建议 |
检查设备,核实情况 |
日志内容 |
System is rebooting now. |
参数解释 |
N/A |
日志等级 |
5 |
举例 |
DEV/5/SYSTEM_REBOOT: System is rebooting now. |
日志说明 |
用户在重启系统,或者系统因为异常而重启 |
处理建议 |
1. 检查是否有用户在重启系统 2. 如果没有用户重启,等待系统重新启动后,通过display version命令显示信息中的Last reboot reason字段,查看重启原因 3. 如果重启原因为异常重启,请联系技术支持 |
日志内容 |
Temperature is greater than alarm upper limit on Chassis [INT32] slot [INT32] sensor [STRING] [INT32]. |
参数解释 |
$1:成员编号 $2:槽位号 $3:传感器类型 $4:传感器ID |
日志等级 |
4 |
举例 |
DEV/4/TEMPERATURE_ALARM: Temperature is greater than alarm upper limit on Chassis 1 slot 5 sensor inflow 1. |
日志说明 |
传感器温度超过了严重级(Alarm)高温告警门限。环境温度太高或者风扇异常 |
处理建议 |
检查环境温度和风扇,排除故障 |
日志内容 |
Temperature is less than lower limit on Chassis [INT32] slot [INT32] sensor [STRING] [INT32]. |
参数解释 |
日志等级 |
4 |
举例 |
DEV/4/TEMPERATURE_LOW: Temperature is less than lower limit on Chassis 1 slot 5 sensor inflow 1. |
日志说明 |
传感器温度低于低温告警门限 |
处理建议 |
检查环境温度,排除故障 |
日志内容 |
Temperature changes to normal on Chassis [INT32] slot [INT32] sensor [STRING] [INT32]. |
参数解释 |
日志等级 |
5 |
举例 |
DEV/5/TEMPERATURE_NORMAL: Temperature changes to normal on Chassis 1 slot 5 sensor inflow 1. |
日志说明 |
传感器温度指示正常(大于低温告警门限,小于一般级高温告警门限) |
处理建议 |
无 |
日志内容 |
Temperature is greater than shutdown upper limit on Chassis [INT32] slot [INT32] sensor [STRING] [INT32] the slot will be powered off automatically. |
参数解释 |
日志等级 |
2 |
举例 |
DEV/2/TEMPERATURE_SHUTDOWN: Temperature is greater than shutdown upper limit on Chassis 1 slot 5 sensor inflow 1 the slot will be powered off automatically. |
日志说明 |
传感器温度高过了关断级高温告警门限。环境温度太高或者风扇异常 |
处理建议 |
检查环境温度和风扇,排除故障 |
日志内容 |
Temperature is greater than warning upper limit on Chassis [INT32] slot [INT32] sensor [STRING] [INT32]. |
参数解释 |
日志等级 |
4 |
举例 |
DEV/4/TEMPERATURE_WARNING: Temperature is greater than warning upper limit on Chassis 1 slot 2 sensor inflow 1. |
日志说明 |
传感器温度高过了一般级高温告警门限。环境温度太高或者风扇异常 |
处理建议 |
检查环境温度和风扇,排除故障 |
本节介绍Diagnosis模块输出的日志信息。
日志内容 |
Memory usage has dropped below [STRING] threshold. |
参数解释 |
$1:内存告警门限级别,包括: · minor:一级 · severe:二级 · critical:三级 |
日志等级 |
1 |
举例 |
DIAG/1/MEM_BELOW_THRESHOLD: Memory usage has dropped below critical threshold. |
日志说明 |
内存告警解除。系统剩余空闲内存大于某一告警门限 |
处理建议 |
无 |
日志内容 |
Memory [STRING] threshold has been exceeded. |
参数解释 |
日志等级 |
1 |
举例 |
DIAG/1/MEM_EXCEED_THRESHOLD: Memory minor threshold has been exceeded. |
日志说明 |
内存告警 系统剩余空闲内存小于某一告警门限 |
处理建议 |
1. 当内存到达告警门限,系统会通知各业务模块进行自动修复:比如,不再申请新的内存或者释放部分内存 2. 用户可以采取以下措施: 3. 检查ARP、路由表信息,排除设备受到非法攻击可能 4. 检查和优化组网,减少路由条目或者更换更高规格的设备 |
本节介绍DLDP模块输出的日志信息。
日志内容 |
The DLDP packet failed the authentication because of unmatched [STRING] field. |
参数解释 |
$1:验证字段 · AUTHENTICATION PASSWORD:表示验证字不匹配 · AUTHENTICATION TYPE:表示验证类型不匹配 · INTERVAL:表示通告间隔不匹配 |
日志等级 |
5 |
举例 |
DLDP/5/DLDP_AUTHENTICATION_FAILED: The DLDP packet failed the authentication because of unmatched INTERVAL field. |
日志说明 |
报文验证失败。可能的原因包括:验证类型不匹配、验证字不匹配、通告间隔不匹配 |
处理建议 |
检查DLDP验证类型、验证字和通告间隔是否与对端一致 |
日志内容 |
DLDP detected a bidirectional link on interface [STRING]. |
参数解释 |
$1:接口名 |
日志等级 |
6 |
举例 |
DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ethernet1/1. |
日志说明 |
DLDP在接口上检测到双向链路 |
处理建议 |
无 |
日志内容 |
DLDP detected a unidirectional link on interface [STRING]. [STRING]. |
参数解释 |
$1:接口名 $2:接口关闭模式所指定的动作 · DLDP automatically blocked the interface:表示DLDP自动关闭了端口 · Please manually shut down the interface:表示需要用户手动关闭端口 |
日志等级 |
3 |
举例 |
DLDP/3/DLDP_LINK_UNIDIRECTIONAL: DLDP detected a unidirectional link on interface Ethernet1/1. DLDP automatically blocked the interface. |
日志说明 |
DLDP在接口上检测到单向链路 |
处理建议 |
检查线缆是否错接、脱落或者出现其他故障 |
日志内容 |
A neighbor on interface [STRING] was deleted because the neighbor was aged. The neighbor's system MAC is [MAC], and the port index is [UINT16]. |
参数解释 |
$1:接口名 $2:MAC地址 $3:接口索引 |
日志等级 |
5 |
举例 |
DLDP/5/DLDP_NEIGHBOR_AGED: A neighbor on interface Ethernet1/1 was deleted because the neighbor was aged. The neighbor's system MAC is 000f-e269-5f21, and the port index is 1. |
日志说明 |
接口删除了一个已老化的邻居 |
处理建议 |
无 |
日志内容 |
A neighbor was confirmed on interface [STRING]. The neighbor's system MAC is [MAC], and the port index is [UINT16]. |
参数解释 |
日志等级 |
6 |
举例 |
DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ethernet1/1. The neighbor's system MAC is 000f-e269-5f21, and the port index is 1. |
日志说明 |
接口检测到一个处于确定状态的邻居 |
处理建议 |
无 |
日志内容 |
A neighbor on interface [STRING] was deleted because a [STRING] packet arrived. The neighbor's system MAC is [MAC], and the port index is [UINT16]. |
参数解释 |
$1:接口名 $2:报文类型 · DISABLE:表示收到了Disable报文 · LINKDOWN:表示收到了LinkDown报文 $3:MAC地址 $4:接口索引 |
日志等级 |
5 |
举例 |
DLDP/5/DLDP_NEIGHBOR_DELETED: A neighbor on interface Ethernet1/1 was deleted because a DISABLE packet arrived. The neighbor's system MAC is 000f-e269-5f21, and the port index is 1. |
日志说明 |
由于收到了Disable报文或LinkDown报文,因此接口删除一个处于确定状态的邻居 |
处理建议 |
无 |
本节介绍以太网OAM模块输出的日志信息。
日志内容 |
The link is down on port [string] because a remote failure occurred on peer port. |
参数解释 |
$1:接口名称 |
日志等级 |
5 |
举例 |
ETHOAM/5/ETHOAM_OAM_LINK_DOWN: The link is down on port Ethernet1/0/1 because a remote failure occurred on peer port. |
日志说明 |
对端接口发生故障,链路down |
处理建议 |
检查链路状态或对端的OAM状态 |
日志内容 |
Port [string] removed the OAM connection because it received no Information OAMPDU before the timer times out. |
参数解释 |
$1:接口名称 |
日志等级 |
5 |
举例 |
ETHOAM/5/ETHOAM_CONNECTION_FAIL_TIMEOUT: Port Ethernet1/0/1 removed the OAM connection because it received no Information OAMPDU before the timer times out. |
日志说明 |
接口在超时时间内没有收到信息OAMPDU,所以删除OAM连接 |
处理建议 |
检查链路状态或对端的OAM状态 |
日志内容 |
Port [string] failed to establish an OAM connection because the peer doesn’t match the capacity of the local port. |
参数解释 |
$1:接口名称 |
日志等级 |
3 |
举例 |
ETHOAM/3/ETHOAM_CONNECTION_FAIL_UNSATISF: Port Ethernet1/0/1 failed to establish an OAM connection because the peer doesn’t match the capacity of the local port. |
日志说明 |
对端与本端接口的配置不匹配,建立OAM连接失败 |
处理建议 |
无 |
日志内容 |
An OAM connection is established on port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ETHOAM_CONNECTION_SUCCEED: An OAM connection is established on port Ethernet1/0/1. |
日志说明 |
OAM连接建立成功 |
处理建议 |
无 |
日志内容 |
Ethernet OAM is now disabled on port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ETHOAM_DISABLE: Ethernet OAM is now disabled on port Ethernet1/0/1. |
日志说明 |
以太网OAM功能已关闭 |
处理建议 |
无 |
日志内容 |
OAM port [string] quits OAM connection.. |
参数解释 |
$1:接口名称 |
日志等级 |
5 |
举例 |
ETHOAM/5/ ETHOAM_DISCOVERY_EXIT: OAM port Ethernet1/0/1 quits OAM connection. |
日志说明 |
本端接口退出OAM连接 |
处理建议 |
无 |
日志内容 |
Ethernet OAM is now enabled on port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ETHOAM_ENABLE: Ethernet OAM is now enabled on port Ethernet1/0/1. |
日志说明 |
以太网OAM功能已使能 |
处理建议 |
无 |
日志内容 |
The local OAM entity enters remote loopback as controlled DTE on OAM port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ ETHOAM_ENTER_LOOPBACK_CTRLLED: The local OAM entity enters remote loopback as controlled DTE on OAM port Ethernet1/0/1. |
日志说明 |
对端使能OAM远端环回功能后,本端OAM实体作为被控制DTE进入远端环回 |
处理建议 |
无 |
日志内容 |
The local OAM entity enters remote loopback as controlling DTE on OAM port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ ETHOAM_ENTER_LOOPBACK_CTRLLING: The local OAM entity enters remote loopback as controlling DTE on OAM port Ethernet1/0/1. |
日志说明 |
接口使能OAM远端环回功能后,本端OAM实体作为控制DTE进入远端环回 |
处理建议 |
无 |
日志内容 |
A local Dying Gasp event has occurred on [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
ETHOAM/4/ETHOAM_LOCAL_DYING_GASP: A local Dying Gasp event has occurred on Ethernet1/0/1. |
日志说明 |
重启设备或关闭接口导致本端产生致命故障(Dying Gasp)事件 |
处理建议 |
链路恢复之前不能使用 |
日志内容 |
An errored frame event occurred on local port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ETHOAM_LOCAL_ERROR_FRAME: An errored frame event occurred on local port Ethernet1/0/1. |
日志说明 |
本地接口产生错误帧事件 |
处理建议 |
检查链路 |
日志内容 |
An errored frame period event occurred on local port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ETHOAM_LOCAL_ERROR_FRAME_PERIOD: An errored frame period event occurred on local port Ethernet1/0/1. |
日志说明 |
本地接口产生错误帧周期事件 |
处理建议 |
检查链路 |
日志内容 |
An errored frame seconds event occurred on local port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ETHOAM_LOCAL_ERROR_FRAME_SECOND: An errored frame seconds event occurred on local port Ethernet1/0/1. |
日志说明 |
本地接口产生错误帧秒事件 |
处理建议 |
检查链路 |
日志内容 |
A local Link Fault event occurred on [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
ETHOAM/4/ETHOAM_LOCAL_LINK_FAULT: A local Link Fault event occurred on Ethernet1/0/1. |
日志说明 |
本地链路down,产生链路故障事件 |
处理建议 |
重新连接本地接口的光纤接收端 |
日志内容 |
OAM port [string] quits remote loopback. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
ETHOAM/4/ETHOAM_LOOPBACK_EXIT: OAM port Ethernet1/0/1 quits remote loopback. |
日志说明 |
接口关闭远端环回或OAM连接断开后,OAM接口退出远端环回 |
处理建议 |
无 |
日志内容 |
OAM port [string] quits remote loopback due to incorrect multiplexer or parser status. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ETHOAM_LOOPBACK_EXIT_ERROR_STATU: OAM port Ethernet1/0/1 quits remote loopback due to incorrect multiplexer or parser status. |
日志说明 |
复用器或解析器状态错误,OAM接口Ethernet1/0/1退出远端环回 |
处理建议 |
在OAM实体上关闭并重新使能以太网OAM |
日志内容 |
OAM port [string] can’t enter remote loopback due to insufficient resources. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
ETHOAM/4/ETHOAM_LOOPBACK_NO_RESOURCE: OAM port Ethernet1/0/1 can’t enter remote loopback due to insufficient resources. |
日志说明 |
当在本端或对端OAM实体上运行oam remote-loopback start命令时,OAM接口由于资源不足而无法进入远端环回 |
处理建议 |
释放资源并重新运行oam remote-loopback start命令 |
日志内容 |
OAM port [string] can’t enter remote loopback because the operation is not supported. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
ETHOAM/4/ETHOAM_LOOPBACK_NOT_SUPPORT: OAM port Ethernet1/0/1 can’t enter remote loopback because the operation is not supported. |
日志说明 |
由于设备不支持,OAM接口无法进入远端环回 |
处理建议 |
无 |
日志内容 |
The local OAM entity quits remote loopback as controlled DTE on OAM port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ ETHOAM_QUIT_LOOPBACK_CTRLLED: The local OAM entity quits remote loopback as controlled DTE on OAM port Ethernet1/0/1. |
日志说明 |
对端关闭远端环回功能后,本端OAM实体作为被控制DTE退出远端环回 |
处理建议 |
无 |
日志内容 |
The local OAM entity quits remote loopback as controlling DTE on OAM port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ETHOAM_QUIT_LOOPBACK_CONTROLLING: The local OAM entity quits remote loopback as controlling DTE on OAM port Ethernet1/0/1. |
日志说明 |
接口关闭远端环回功能后,本端OAM实体作为控制DTE退出远端环回 |
处理建议 |
无 |
日志内容 |
A remote Critical event occurred on [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
ETHOAM/4/ETHOAM_REMOTE_CRITICAL: A remote Critical event occurred on Ethernet1/0/1. |
日志说明 |
发生远端紧急事件 |
处理建议 |
链路恢复之前不能使用 |
日志内容 |
A remote Dying Gasp event occurred on [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
ETHOAM/4/ETHOAM_REMOTE_DYING_GASP: A remote Dying Gasp event occurred on Ethernet1/0/1. |
日志说明 |
重启远端设备或关闭接口导致远端产生致命故障(Dying Gasp)事件 |
处理建议 |
链路恢复之前不能使用 |
日志内容 |
An errored frame event occurred on the peer port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ETHOAM_REMOTE_ERROR_FRAME: An errored frame event occurred on the peer port Ethernet1/0/1. |
日志说明 |
对端产生错误帧事件 |
处理建议 |
检查链路 |
日志内容 |
An errored frame period event occurred on the peer port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ETHOAM_REMOTE_ERROR_FRAME_PERIOD: An errored frame period event occurred on the peer port Ethernet1/0/1. |
日志说明 |
对端产生错误帧周期事件 |
处理建议 |
检查链路 |
日志内容 |
An errored frame seconds event occurred on the peer port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ETHOAM_REMOTE_ERROR_FRAME_SECOND: An errored frame seconds event occurred on the peer port Ethernet1/0/1. |
日志说明 |
对端产生错误帧秒事件 |
处理建议 |
检查链路 |
日志内容 |
An errored symbol event occurred on the peer port [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
ETHOAM/6/ETHOAM_REMOTE_ERROR_SYMBOL: An errored symbol event occurred on the peer port Ethernet1/0/1. |
日志说明 |
对端产生错误信号事件 |
处理建议 |
检查链路 |
日志内容 |
OAM port [string] quits OAM connection because Ethernet OAM is disabled on the peer port. |
参数解释 |
$1:接口名称 |
日志等级 |
5 |
举例 |
ETHOAM/5/ ETHOAM_REMOTE_EXIT: OAM port Ethernet1/0/1 quits OAM connection because Ethernet OAM is disabled on the peer port. |
日志说明 |
对端接口关闭以太网OAM功能导致本端接口退出OAM连接 |
处理建议 |
无 |
日志内容 |
Peer port [string] recovered. |
参数解释 |
$1:接口名称 |
日志等级 |
5 |
举例 |
ETHOAM/5/ ETHOAM_REMOTE_FAILURE_RECOVER: Peer port Ethernet1/0/1 recovered |
日志说明 |
对端接口链路故障清除,OAM连接恢复 |
处理建议 |
无 |
日志内容 |
A remote Link Fault event occurred on [string]. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
ETHOAM/4/ETHOAM_REMOTE_LINK_FAULT: A remote Link Fault event occurred on Ethernet1/0/1. |
日志说明 |
远端链路down,产生远端链路故障事件 |
处理建议 |
重新连接远端接口的光纤接收端 |
日志内容 |
OAM port [string] the configuration failed because of insufficient hardware resources |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
ETHOAM/4/ ETHOAM_NO_ENOUGH_RESOURCE: Ethernet1/0/1 the configuration failed because of insufficient hardware resources. |
日志说明 |
硬件资源不足导致OAM接口上的配置失败 |
处理建议 |
释放资源,重新配置 |
日志内容 |
Port [string] quits Ethernet OAM because it received no Information OAMPDU before the timer times out. |
参数解释 |
$1:接口名称 |
日志等级 |
5 |
举例 |
ETHOAM/5/ ETHOAM_NOT_CONNECTION_TIMEOUT: Port Ethernet1/0/1 quits Ethernet OAM because it received no Information OAMPDU before the timer times out. |
日志说明 |
本地端口在超时时间内没有收到信息OAMPDU,所以退出以太网OAM |
处理建议 |
检查链路状态或对端的OAM使能状态 |
本节介绍连接服务器的边缘交换机上EVB协议输出的日志信息。
日志内容 |
Remove the port [STRING] from the aggregation group [STRING]. Otherwise, the EVB feature does not take effect. |
参数解释 |
$1:物理接口名称 $2:聚合接口名称 |
日志等级 |
6 |
举例 |
EVB/6/EVB_AGG_FAILED: Remove the port GigabitEthernet5/0/5 from the aggregation group Bridge-Aggregation5. Otherwise, the EVB feature does not take effect. |
日志说明 |
EVB交换机处理聚合组中物理接口失败 |
处理建议 |
将该物理接口从聚合组中删除 |
日志内容 |
VSI [STRING] went offline. |
参数解释 |
$1:VSI接口名称 |
日志等级 |
6 |
举例 |
EVB/6/EVB_VSI_OFFLINE: VSI Schannel-Aggregation1:2.0 went offline. |
日志说明 |
设备收到服务器发送的VDP报文,或者定时器已经超时,但设备还没收到服务器的VDP回复报文,VSI接口被删除 |
处理建议 |
无 |
日志内容 |
VSI [STRING] came online, status is [STRING]. |
参数解释 |
$1:VSI接口名称 $2:VSI状态 |
日志等级 |
6 |
举例 |
EVB/6/EVB_VSI_ONLINE: VSI Schannel-Aggregation1:2.0 came online, status is association. |
日志说明 |
EVB交换机收到VDP报文并成功创建VSI接口 |
处理建议 |
无 |
日志内容 |
License of the [STRING] feature will be expired in [UINT32] days. Install a permanent license. |
参数解释 |
$1:特性名称 $2:License 有效期 |
日志等级 |
6 |
举例 |
EVB/6/EVB_WARNING_NO_LICENSE: License of the EVB feature will be expired in 15 days. Install a permanent license. |
日志说明 |
主控板上的EVB License将过期 |
处理建议 |
安装永久License |
本节介绍EVI IS-IS模块输出的日志信息。
日志内容 |
The feature EVIISIS has [STRING] license. |
参数解释 |
$1:license状态 |
日志等级 |
5 |
举例 |
EVIISIS/5/EVIISIS_LICENSE: The feature EVIISIS has available license. |
日志说明 |
EVI IS-IS的license状态改变(例如安装了license或license失效)时输出本信息 |
处理建议 |
若当前EVI IS-IS的license失效,安装有效的license |
日志内容 |
No license is found for EVI IS-IS. |
参数解释 |
无 |
日志等级 |
3 |
举例 |
EVIISIS /3/ EVIISIS_LICENSE_UNAVAILABLE: No license is found for EVI IS-IS. |
日志说明 |
没有找到EVIISIS对应的License |
处理建议 |
请安装EVIISIS对应的License |
日志内容 |
EVI IS-IS is unavailable because its license has expired. |
参数解释 |
无 |
日志等级 |
3 |
举例 |
EVIISIS/3/EVIISIS_LICENSE_EXPIRED: EVI IS-IS is unavailable because its license has expired. |
日志说明 |
EVIIS对应的License已经过期 |
处理建议 |
请更换有效的License |
日志内容 |
EVI IS-IS will become unavailable in [ULONG] days. |
参数解释 |
$1:功能还可使用的天数 |
日志等级 |
5 |
举例 |
EVIISIS/5/EVIISIS_LICENSE_EXPIRED_TIME: EVI IS-IS will become unavailable in 2 days. |
日志说明 |
EVIISIS的License已经过期,EVIISIS功能将在2天后失效
EVIISIS的License过期后,EVIISIS功能还能使用30天,当前已经用了28天 |
处理建议 |
若要继续使用EVIISIS功能,请准备新的License |
日志内容 |
EVIISIS [UINT32], [STRING] adjacency [STRING] ([STRING]), state change to: [STRING]. |
参数解释 |
$1:EVI IS-IS进程ID $2:EVI IS-IS邻居等级 $3:邻居系统ID $4:接口名称 $5:当前邻接状态 |
日志等级 |
5 |
举例 |
EVIISIS/5/EVIISIS_NBR_CHG: EVIISIS 1, Level-1 adjacency 0011.2200.1501 (Evi-Link0), state change to: down. |
日志说明 |
接口EVI IS-IS邻接状态改变 |
处理建议 |
当某接口与邻居邻接状态变为down或initializing时,检查EVI IS-IS配置正确性和网络连通性 |
日志内容 |
EVIISIS process receive system memory alert [STRING] event. |
参数解释 |
$1:内存告警类型 |
日志等级 |
5 |
举例 |
EVIISIS/5/EVIISIS_MEM_ALERT: EVIISIS process receive system memory alert start event. |
日志说明 |
EVI IS-IS模块收到内存告警信息 |
处理建议 |
检查系统内存 |
本节介绍FCoE模块输出的日志信息。
日志内容 |
Because the aggregate interface [STRING] has been bound to a VFC interface, assigning the interface [STRING] that does not support FCoE to the aggregate interface will cause incorrect processing. |
参数解释 |
$1:聚合接口名称 $2:以太网接口名称 |
日志等级 |
4 |
举例 |
FCOE/4/FCOE_INTERFACE_NOTSUPPORT_FCOE: Because the aggregate interface Bridge-Aggregation 1 has been bound to a VFC interface, assigning the interface Ten-GigabitEthernet 2/0/1 that does not support FCoE to the aggregate interface will cause incorrect processing. |
日志说明 |
当不支持FCoE功能的接口加入到已绑定到VFC接口的聚合接口时,打印本信息 |
处理建议 |
将支持FCoE功能的接口加入到聚合接口,或者解除聚合接口与VFC接口的绑定 |
日志内容 |
No license is found for FCoE. |
参数解释 |
无 |
日志等级 |
3 |
举例 |
FCOE/3/FCOE_LICENSE_ERROR: No license is found for FCoE. |
日志说明 |
没有找到FCoE对应的License |
处理建议 |
请安装FCoE对应的License |
日志内容 |
FCoE is unavailable because its license has expired. |
参数解释 |
无 |
日志等级 |
3 |
举例 |
FCOE/3/FCOE_LICENSE_EXPIRED_EXIT: FCoE is unavailable because its license has expired. |
日志说明 |
FCoE对应的License已经过期 |
处理建议 |
请更换有效的License |
日志内容 |
FCoE will become unavailable in [ULONG] days. |
参数解释 |
$1:功能还可使用的天数 |
日志等级 |
4 |
举例 |
FCOE/4/FCOE_LICENSE_EXPIRED_TIME: FCoE will become unavailable in 2 days. |
日志说明 |
FCoE的License已经过期,FCoE功能将在2天后失效
FCoE的License过期后,FCoE功能还能使用30天,当前已经用了28天 |
处理建议 |
若要继续使用FCoE功能,请准备新的License |
本节介绍FCLINK模块输出的日志信息。
日志内容 |
VSAN [UINT16], Interface [STRING]: An FDISC was rejected because the hardware resource is not enough. |
参数解释 |
$1:VSAN ID $2:接口名称 |
日志等级 |
4 |
举例 |
FCLINK/4/FCLINK_FDISC_REJECT_NORESOURCE: VSAN 1, Interface FC2/0/1: An FDISC was rejected because the hardware resource is not enough. |
日志说明 |
硬件资源不足时收到了FDISC报文 |
处理建议 |
减少节点的数量 |
日志内容 |
VSAN [UINT16], Interface [STRING]: An FLOGI was rejected because the hardware resource is not enough. |
参数解释 |
日志等级 |
4 |
举例 |
FCLINK/4/FCLINK_FLOGI_REJECT_NORESOURCE: VSAN 1, Interface FC2/0/1: An FLOGI was rejected because the hardware resource is not enough. |
日志说明 |
硬件资源不足时收到了FLOGI报文 |
处理建议 |
减少节点的数量 |
本节介绍FCZONE模块输出的日志信息。
日志内容 |
VSAN [UINT16]: No enough hardware resource for zone rule, switched to soft zoning. |
参数解释 |
$1:VSAN ID |
日志等级 |
2 |
举例 |
FCZONE/2/FCZONE_HARDZONE_DISABLED: VSAN 2: No enough hardware resource for zone rule, switched to soft zoning. |
日志说明 |
硬件资源不足 |
处理建议 |
激活一个更小的zone set |
日志内容 |
VSAN [UINT16]: Hardware resource for zone rule is restored, switched to hard zoning. |
参数解释 |
$1:VSAN ID |
日志等级 |
1 |
举例 |
FCZONE/1/FCZONE_HARDZONE_ENABLED: VSAN 2: Hardware resource for zone rule is restored, switched to hard zoning. |
日志说明 |
硬件资源恢复时,切换到hard zoning |
处理建议 |
无 |
本节介绍FIPS模块输出的日志信息。
日志内容 |
No enough hardware resource for FIP Snooping rule. |
参数解释 |
N/A |
日志等级 |
4 |
举例 |
FIPS/4/FCOE_FIPS_HARD_RESOURCE_NOENOUGH: No enough hardware resource for FIP Snooping rule. |
日志说明 |
硬件资源不足 |
处理建议 |
无 |
日志内容 |
Hardware resource for FIP Snooping rule is restored. |
参数解释 |
N/A |
日志等级 |
6 |
举例 |
FIPS/6/FCOE_FIPS_HARD_RESOURCE_RESTORE: Hardware resource for FIP Snooping is restored. |
日志说明 |
硬件资源恢复 |
处理建议 |
无 |
本节介绍FTP模块输出的日志信息。
日志内容 |
FTP client [IPADDR] failed to log in. Number of FTP sessions reached the limit. |
参数解释 |
$1:FTP客户端IP地址 |
日志等级 |
6 |
举例 |
FTPD/6/FTPD_REACH_SESSION_LIMIT: FTP client 1.1.1.1 failed to log in. Number of FTP sessions reached the limit. |
日志说明 |
FTP登录用户达到上限。该日志在FTP服务端检测到登录客户数达到上限时输出 |
处理建议 |
无 |
本节介绍HA模块输出的日志信息。
日志内容 |
Batch backup of standby board in [STRING] is finished. |
参数解释 |
$1:单板所在位置 |
日志等级 |
5 |
举例 |
HA/5/HA_BATCHBACKUP_FINISHED: Batch backup of standby board in chassis 0 slot 1 is finished. |
日志说明 |
主备板批量备份完成 |
处理建议 |
无 |
日志内容 |
Batch backup(s) of standby board(s) in [STRING] started. |
参数解释 |
$1:单板所在位置 |
日志等级 |
5 |
举例 |
HA/5/HA_BATCHBACKUP_STARTED: Batch backup(s) of standby board(s) in chassis 0 slot 1 started. |
日志说明 |
主备板批量备份开始 |
处理建议 |
无 |
日志内容 |
Standby board in [STRING] is not ready, reboot ... |
参数解释 |
$1:单板所在位置 |
日志等级 |
4 |
举例 |
HA/4/HA_STANDBY_NOT_READY: Standby board in chassis 0 slot 1 is not ready, reboot ... |
日志说明 |
主备倒换时,如果备用主控板未准备好,则不会进行主备倒换,而是重启备用主控板和主用主控板,并在备用主控板上打印该信息 |
处理建议 |
建议备用主控板批量备份完成前不要进行主备倒换 |
日志内容 |
Standby board in [STRING] changes to master. |
参数解释 |
$1:单板所在位置 |
日志等级 |
5 |
举例 |
HA/5/HA_STANDBY_TO_MASTER: Standby board in chassis 0 slot 1 changes to master. |
日志说明 |
备板成为主板 |
处理建议 |
无 |
本节介绍HTTPD(HTTP daemon)模块输出的日志信息。
日志内容 |
[STRING] client [STRING] connected to the server successfully. |
参数解释 |
$1:连接类型, HTTP 或 HTTPS $2:客户端IP 地址 |
日志等级 |
6 |
举例 |
HTTPD/6/HTTPD_CONNECT: HTTP client 192.168.30.117 connected to the server successfully. |
日志说明 |
HTTP/HTTPS服务器接受了客户端的请求,HTTP/HTTPS连接成功建立 |
处理建议 |
无 |
日志内容 |
[STRING] client [STRING] connection idle timeout. |
参数解释 |
日志等级 |
6 |
举例 |
HTTPD/6/HTTPD_CONNECT_TIMEOUT: HTTP client 192.168.30.117 connection to server idle timeout. |
日志说明 |
HTTP/HTTPS连接因空闲时间太长而断开 |
处理建议 |
无 |
日志内容 |
[STRING] client [STRING] disconnected from the server. |
参数解释 |
日志等级 |
6 |
举例 |
HTTPD/6/HTTPD_DISCONNECT: HTTP client 192.168.30.117 disconnected from the server. |
日志说明 |
HTTP/HTTPS 客户端断开了到服务器的连接 |
处理建议 |
无 |
日志内容 |
[STRING] client [STRING] failed the ACL check and could not connect to the server. |
参数解释 |
日志等级 |
6 |
举例 |
HTTPD/6/HTTPD_FAIL_FOR_ACL: HTTP client 192.168.30.117 failed the ACL check and cannot connect to the server. |
日志说明 |
HTTP/HTTPS客户端没有通过ACL检查,无法建立连接 |
处理建议 |
无 |
日志内容 |
[STRING] client [STRING] was denied by the certificate access control policy and could not connect to the server. |
参数解释 |
日志等级 |
6 |
举例 |
HTTPD/6/HTTPD_FAIL_FOR_ACP: HTTP client 192.168.30.117 was denied by the certificate attribute access control policy and could not connect to the server. |
日志说明 |
HTTP/HTTPS客户端没有通过证书接入控制策略检查,无法建立连接 |
处理建议 |
无 |
日志内容 |
[STRING] client [STRING] failed to connect to the server, because the number of connections reached the upper limit. |
参数解释 |
日志等级 |
6 |
举例 |
HTTPD/6/HTTPD_REACH_CONNECT_LIMIT: HTTP client 192.168.30.117 failed to connect to the server, because the number of connections reached the upper limit. |
日志说明 |
已达到最大连接数,无法建立新的连接 |
处理建议 |
无 |
日志内容 |
Multi-active devices detected, please fix it. |
参数解释 |
N/A |
日志等级 |
1 |
举例 |
IFNET/1/IFNET_MAD: Multi-active devices detected, please fix it. |
日志说明 |
当收到冲突消息的时候,检测到冲突,需要解决冲突问题 |
处理建议 |
当IRF分裂时,处理冲突 |
日志内容 |
Interface [STRING] is inserted. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
IFNET/6/INTERFACE_INSERTED: Interface Ethernet0/1 is inserted. |
日志说明 |
插入一个接口 |
处理建议 |
无 |
日志内容 |
Interface [STRING] is removed. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
IFNET/6/INTERFACE_REMOVED: Interface Ethernet0/1 is removed. |
日志说明 |
删除一个接口 |
处理建议 |
无 |
日志内容 |
Line protocol on the interface [STRING] is [STRING]. |
参数解释 |
$1:接口名称 $2:协议状态 |
日志等级 |
5 |
举例 |
IFNET/5/LINK_UPDOWN: Line protocol on the interface Ethernet0/0 is down. |
日志说明 |
接口的链路层协议状态发生变化 |
处理建议 |
无 |
日志内容 |
[STRING]: link status is [STRING]. |
参数解释 |
$1:接口名称 $2:链路状态 |
日志等级 |
3 |
举例 |
IFNET/3/PHY_UPDOWN: Ethernet0/0: link status is down. |
日志说明 |
接口的链路状态发生变化 |
处理建议 |
无 |
日志内容 |
Protocol [STRING] on the interface [STRING] is [STRING]. |
参数解释 |
$1:协议名称 $2:接口名称 $3:协议状态 |
日志等级 |
5 |
举例 |
IFNET/5/PROTOCOL_UPDOWN: Protocol IPX on the interface Ethernet6/4/1 is up. |
日志说明 |
接口上一个协议的状态发生变化 |
处理建议 |
无 |
本节介绍IKE模块输出的日志信息。
日志内容 |
Failed to establish phase 1 SA for the reason of [STRING]. The SA’s source address is [STRING], and its destination address is [STRING]. |
参数解释 |
$1:失败原因,显示为no matching proposal、invalid ID information、unavailable certificate、unsupported DOI、unsupported situation、invalid proposal syntax、invalid SPI、invalid protocol ID、invalid certificate、authentication failure、invalid message header、invalid transform ID、malformed payload、retransmission timeout、或incorrect configuration $2:源地址 $3:目的地址 |
日志等级 |
6 |
举例 |
IKE/6/IKE_P1_SA_ESTABLISH_FAIL: Failed to establish phase 1 SA for the reason of no matching proposal. The SA’s source address is 1.1.1.1 and its destination address is 2.2.2.2. |
日志说明 |
IKE建立第一阶段SA失败以及失败原因 |
处理建议 |
检查本端和对端设备的IKE配置 |
日志内容 |
Failed to establish phase 2 SA for the reason of [STRING]. The SA’s source address is [STRING], and its destination address is [STRING]. |
参数解释 |
$1:失败原因,显示为invalid key information、invalid ID information、unavailable proposal、unsupported DOI、unsupported situation、invalid proposal syntax、 invalid SPI、invalid protocol ID、invalid hash information、invalid message header、malformed payload、retransmission timeout、或incorrect configuration $2:源地址 $3:目的地址 |
日志等级 |
6 |
举例 |
IKE/6/IKE_P2_SA_ESTABLISH_FAIL: Failed to establish phase 2 SA for the reason of invalid key information. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2. |
日志说明 |
IKE建立第二阶段SA失败以及失败原因 |
处理建议 |
检查本端和对端设备的IKE和IPsec配置 |
日志内容 |
The IKE phase 2 SA was deleted for the reason of [STRING]. The SA’s source address is [STRING], and its destination address is [STRING]. |
参数解释 |
$1:删除SA的原因,显示为SA expiration $2:源地址 $3:目的地址 |
日志等级 |
6 |
举例 |
IKE/6/IKE_P2_SA_TERMINATE: The IKE phase 2 SA was deleted for the reason of SA expiration. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2. |
日志说明 |
第二阶段SA由于过期失效而删除 |
处理建议 |
无 |
本节介绍IPsec模块输出的日志信息。
日志内容 |
IPsec packet discarded, Src IP:[STRING], Dst IP:[STRING], SPI:[UINT32], SN:[UINT32], Cause:[STRING]. |
参数解释 |
$1:报文的源IP地址 $2:报文的目的IP地址 $3:SPI(Security Parameter Index,安全参数索引) $4:报文的序列号 $5:报文丢弃的原因: · 抗重放检测失败,显示为:Anti-replay checking failed. · AH认证失败,显示为:AH authentication failed. · ESP认证失败,显示为:ESP authentication failed. · SA无效,显示为:Invalid SA. · ESP解密失败,显示为:ESP decryption failed. · 报文的源地址匹配不上SA,显示为:Source address of packet does not match the SA. · 没有匹配的ACL规则,显示为:No ACL rule matched. |
日志等级 |
6 |
举例 |
IPSEC/6/IPSEC_PACKET_DISCARDED: IPsec packet discarded, Src IP:1.1.1.2, Dest IP:1.1.1.4, SPI:1002, SN:0, Cause:ah authentication failed |
日志说明 |
IPsec报文被丢弃 |
处理建议 |
无 |
日志内容 |
Established IPsec SA. The SA’s source address is [STRING], destination address is [STRING], protocol is [STRING], and SPI is [UINT32]. |
参数解释 |
$1:IPsec SA的源IP地址 $2:IPsec SA的目的IP地址 $3:IPsec SA使用的安全协议 $4:IPsec SA的SPI |
日志等级 |
6 |
举例 |
IPSEC/6/IPSEC_SA_ESTABLISH: Established IPsec SA. The SA’s source address is 1.1.1.1, destination address is 2.2.2.2, protocol is AH, and SPI is 2435. |
日志说明 |
IPsec SA创建成功 |
处理建议 |
无 |
日志内容 |
Failed to establish IPsec SA for the reason of [STRING]. The SA’s source address is [STRING], and its destination address is [STRING]. |
参数解释 |
$1:IPsec SA创建失败的原因: · 隧道创建失败,显示为:Tunnel establishment failure. · 配置不完整,显示为:Incomplete configuration. · 配置的安全提议无效,显示为:Unavailable transform set. $2:源IP地址 $3:目的IP地址 |
日志等级 |
6 |
举例 |
IPSEC/6/IPSEC_SA_ESTABLISH_FAIL: Failed to establish IPsec SA for the reason of creating tunnel failure. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2. |
日志说明 |
IPsec SA创建失败。触发该日志的原因可能有:隧道创建失败、配置不完整、或者配置的安全提议无效 |
处理建议 |
检查本端和对端设备上的IPsec配置 |
日志内容 |
Began to establish IPsec SA. The SA’s source address is [STRING], and its destination address is [STRING]. |
参数解释 |
$1:IPsec SA的源IP地址 $2:IPsec SA的目的IP地址 |
日志等级 |
6 |
举例 |
IPSEC/6/IPSEC_SA_INITINATION: Began to establish IPsec SA. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2. |
日志说明 |
开始创建IPsec SA |
处理建议 |
无 |
日志内容 |
The IPsec SA was deleted for the reason of [STRING]. The SA’s source address is [STRING], destination address is [STRING], protocol is [STRING], and SPI is [UINT32]. |
参数解释 |
$1:IPsec SA被删除的原因: · SA空闲超时,显示为:SA idle timeout. · 执行了reset命令,显示为:reset command executed. $2:源IP地址 $3:目的IP地址 $4:使用的安全协议 $5:SPI |
日志等级 |
6 |
举例 |
IPSEC/6/IPSEC_SA_TERMINATE: The IPsec SA was deleted for the reason of SA idle timeout. The SA’s source address is 1.1.1.1, destination address is 2.2.2.2, protocol is ESP, and SPI is 34563. |
日志说明 |
IPsec SA被删除。触发该日志的原因可能有:SA空闲超时或者执行了reset命令 |
处理建议 |
无 |
本节介绍IRDP模块输出的日志信息。
日志内容 |
The number of advertisement addresses on interface [STRING] exceeded the limit 255. |
参数解释 |
$1:接口名称 |
日志等级 |
6 |
举例 |
IRDP/6/IRDP_EXCEED_ADVADDR_LIMIT: The number of advertisement addresses on interface Ethernet1/1/0/2 exceeded the limit 255. |
日志说明 |
接口上待通告的地址数超过了上限值 |
处理建议 |
删除接口上不需要的地址 |
本节介绍IS-IS模块输出的日志信息。
日志内容 |
ISIS Process receive system memory alert [STRING] event. |
参数解释 |
$1:内存告警类型 |
日志等级 |
5 |
举例 |
ISIS/5/ISIS_MEM_ALERT: ISIS Process receive system memory alert start event. |
日志说明 |
IS-IS模块收到内存告警信息 |
处理建议 |
检查系统内存 |
日志内容 |
IS-IS [UINT32], [STRING] adjacency %s (%s), state change to: %s. |
参数解释 |
$1:IS-IS进程ID $2:IS-IS邻居等级 $3:邻居ID $4:接口名称 $5:当前邻接状态 |
日志等级 |
5 |
举例 |
ISIS/5/ISIS_NBR_CHG: IS-IS 1, Level-1 adjacency 0000.0000.8888 (Eth1/4/1/3), state change to:DOWN. |
日志说明 |
接口IS-IS邻接状态改变 |
处理建议 |
当某接口与邻居邻接状态变为down时,检查IS-IS配置正确性和网络连通性 |
本节介绍L2VPN模块输出的日志信息。
日志内容 |
No enough hardware resource for L2VPN. |
参数解释 |
无 |
日志等级 |
4 |
举例 |
L2VPN/4/L2VPN_HARD_RESOURCE_NOENOUGH: No enough hardware resource for L2VPN. |
日志说明 |
L2VPN硬件资源不足 |
处理建议 |
请检查是否生成了当前业务不需要的VSI、PW或AC,是则删除对应配置 |
日志内容 |
Hardware resource for L2VPN is restored. |
参数解释 |
无 |
日志等级 |
6 |
举例 |
L2VPN/6/L2VPN_HARD_RESOURCE_RESTORE: Hardware resource for L2VPN is restored. |
日志说明 |
L2VPN硬件资源恢复 |
处理建议 |
无 |
本节介绍LAGG模块输出的日志信息。
日志内容 |
Member port [STRING] of aggregation group [STRING] became active. |
参数解释 |
$1:端口名称 $2:聚合组类型及ID |
日志等级 |
6 |
举例 |
LAGG/6/LAGG_ACTIVE: Member port FGE1/0/50 of aggregation group BAGG1 became active. |
日志说明 |
聚合组内某成员端口成为选中端口 |
处理建议 |
无 |
日志内容 |
Member port [STRING] of aggregation group [STRING] became inactive, because the aggregation configuration of the port is different from that of the aggregation group. |
参数解释 |
日志等级 |
6 |
举例 |
LAGG/6/LAGG_INACTIVE_AICFG: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the aggregation configuration of the port is different from that of the aggregation group. |
日志说明 |
由于聚合组内某成员端口的属性类配置与聚合接口属性类配置不同,该成员端口成为非选中端口 |
处理建议 |
修改该成员端口的属性类配置,使其与聚合接口属性类配置一致 |
日志内容 |
Member port [STRING] of aggregation group [STRING] became inactive, because the aggregation configuration on the port is improper. |
参数解释 |
$1:端口名称 $2:聚合组类型及ID。. |
日志等级 |
6 |
举例 |
LAGG/6/LAGG_INACTIVE_CONFIGURATION: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the aggregation configuration on the port is improper. |
日志说明 |
由于聚合组内某成员端口配置限制,该成员端口变为非选中状态 |
处理建议 |
无 |
日志内容 |
Member port [STRING] of aggregation group [STRING] became inactive, because the duplex mode configuration on the port is improper. |
参数解释 |
日志等级 |
6 |
举例 |
LAGG/6/LAGG_INACTIVE_DUPLEX: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the duplex mode configuration on the port is improper. |
日志说明 |
由于聚合组内某成员端口的双工模式与选中端口不一致,该成员端口变为非选中状态 |
处理建议 |
修改该端口双工模式,使其与选中端口一致 |
日志内容 |
Member port [STRING] of aggregation group [STRING] became inactive, because the hardware restriction on the port is improper. |
参数解释 |
日志等级 |
6 |
举例 |
LAGG/6/LAGG_INACTIVE_HARDWAREVALUE: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the hardware restriction on the port is improper. |
日志说明 |
聚合组内某成员端口因硬件限制变为非选中状态 |
处理建议 |
无 |
日志内容 |
Member port [STRING] of aggregation group [STRING] became inactive, because the number of active ports is below the lower limit. |
参数解释 |
日志等级 |
6 |
举例 |
LAGG/6/LAGG_INACTIVE_LOWER_LIMIT: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the number of active ports is below the lower limit. |
日志说明 |
因聚合组内选中端口数量未达到配置的最小选中端口数,聚合组内某成员端口变为非选中状态 |
处理建议 |
增加选中端口数量,使其达到最小选中端口数 |
日志内容 |
Member port [STRING] of aggregation group [STRING] became inactive, because the aggregation configuration of its partner is improper. |
参数解释 |
日志等级 |
6 |
举例 |
LAGG/6/LAGG_INACTIVE_PARTNER: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the aggregation configuration of its partner is improper. |
日志说明 |
动态聚合组内,由于对端端口聚合配置不正确变为非选中状态,本端端口变为非选中状态 |
处理建议 |
无 |
日志内容 |
Member port [STRING] of aggregation group [STRING] became inactive, because the physical state of the port is down. |
参数解释 |
日志等级 |
6 |
举例 |
LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the physical state of the port is down. |
日志说明 |
聚合组内某成员端口处于down状态,该成员端口变为非选中状态 |
处理建议 |
使该端口处于UP状态 |
日志内容 |
Member port [STRING] of aggregation group [STRING] became inactive, because all aggregate resources are occupied. |
参数解释 |
日志等级 |
6 |
举例 |
LAGG/6/LAGG_INACTIVE_RESOURCE_INSUFICIE: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because all aggregate resources are occupied. |
日志说明 |
聚合资源不足导致聚合组内成员端口变为非选中端口 |
处理建议 |
无 |
日志内容 |
Member port [STRING] of aggregation group [STRING] became inactive, because the speed configuration on the port is improper. |
参数解释 |
日志等级 |
6 |
举例 |
LAGG/6/LAGG_INACTIVE_SPEED: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the speed configuration on the port is improper. |
日志说明 |
聚合组内某成员端口速率与选中端口不一致,该端口变为非选中状态 |
处理建议 |
修改该端口速率,使其与选中端口一致 |
日志内容 |
Member port [STRING] of aggregation group [STRING] became inactive, because the number of active ports has reached the upper limit. |
参数解释 |
日志等级 |
6 |
举例 |
LAGG/6/LAGG_INACTIVE_UPPER_LIMIT: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the number of active ports has reached the upper limit. |
日志说明 |
动态聚合组内选中端口数量已达到上限。后加入的成员端口成为选中端口,致使某成员端口变为非选中状态 |
处理建议 |
无 |
本节介绍LDP模块输出的日志信息。
日志内容 |
Session ([STRING], [STRING]) is [STRING]. |
参数解释 |
$1:对等体的LDP ID。如果无法获得对等体的LDP ID,显示为0.0.0.0:0 $2:VPN实例名。如果该会话属于公网,显示为public instance $3:会话状态,up或者down。如果会话状态是down,则会在括号内显示会话失败的原因 |
日志等级 |
5 |
举例 |
LDP/5/LDP_SESSION_CHG: Session (22.22.22.2:0, public instance) is up. LDP/5/LDP_SESSION_CHG: Session (22.22.22.2:0, VPN instance: vpn1) is down (hello hold timer expired). |
日志说明 |
会话状态改变了 |
处理建议 |
· 当会话状态是up时,无 · 当会话状态是down时,根据会话失败原因检查接口状态,链路状态和其他相关配置 会话失败原因包括: · interface not operational:接口不可用 · MPLS disabled on interface:接口已取消使能MPLS · LDP disabled on interface:接口已取消使能LDP · LDP auto-configure disabled on interface:接口已取消使能LDP自动配置功能 · VPN instance changed on interface:接口所属的VPN实例已更改 · LDP instance deleted:LDP实例已删除 · targeted peer deleted:LDP对等体已删除。其中,targeted peer 可以有4种方式产生:手动配置、L2VPN自动注册、TE隧道自动注册(LDP over TE功能)、会话保护自动注册 · L2VPN disabled targeted peer:L2VPN注销targeted peer · TE tunnel disabled targeted peer:TE隧道注销targeted peer · session protection disabled targeted peer:会话保护注销targeted peer · process deactivated:LDP进程降级 · failed to receive the initialization message:未收到初始化信息 · graceful restart reconnect timer expired:平滑重启重连时间超时 · failed to recover adjacency by NSR:NSR恢复邻接关系失败 · failed to upgrade session by NSR:NSR升级会话失败 · closed the GR session:GR会话关闭 · keepalive hold timer expired:keepalive保持时间超时 · adjacency hold timer expired:邻接关系保持时间超时 · session reset manually:手动重启会话 · TCP connection down:TCP连接断开 · received a fatal notification message :收到致命的通知信息 · internal error:内部错误 · memory in critical state:内存达到critical状态 · transport address changed on interface:接口上的传输地址更改 |
日志内容 |
Session ([STRING], [STRING]): ([STRING]). |
参数解释 |
$1:对等体的LDP ID。如果无法获得对等体的LDP ID,显示为0.0.0.0:0 $2:VPN实例名。如果该会话属于公网,显示为public instance $3:会话平滑重启的状态,取值包括: · Start reconnection:启动会话重连 · Reconnection failed:会话重连失败 · Start recovery:会话重连成功,进入标签通告恢复过程 · Recovery completed:会话恢复全过程完成 |
日志等级 |
5 |
举例 |
LDP/5/LDP_SESSION_GR: Session (22.22.22.2:0, VPN instance: vpn1): Start reconnection. |
日志说明 |
当已协商支持对端设备LDP平滑重启的LDP会话down时,触发该日志。日志显示会话平滑重启过程的状态变化 |
处理建议 |
1. 从LDP_SESSION_CHG 日志消息可以查看会话平滑重启的原因 2. 当会话平滑重启状态显示为Reconnection failed时,根据会话失败原因检查接口状态,链路状态和其他相关配置,其他情况无需处理 |
日志内容 |
参数解释 |
$1:对等体的LDP ID。如果无法获得对等体的LDP ID,显示为0.0.0.0:0 $2:VPN实例名。如果该会话属于公网,显示为public instance $3:会话保护状态,取值包括: · Hold up the session:保持会话,等待Link hello邻接关系恢复 · Session recovered successfully:Link hello邻接关系恢复成功 · Session recovery failed:Link hello邻接关系恢复失败 |
日志等级 |
5 |
举例 |
LDP/5/LDP_SESSION_SP: Session (22.22.22.2:0, VPN instance: vpn1): Hold up the session. |
日志说明 |
当会话的最后一个Link hello邻接关系丢失时,触发该日志。日志显示会话保护过程的状态变化 |
处理建议 |
检查接口状态和链路状态 |
本节介绍LLDP模块输出的日志信息。
日志内容 |
[STRING] agent new neighbor created on Port [STRING] (IfIndex [UINT32]), Chassis ID is [STRING], Port ID is [STRING]. |
参数解释 |
$1:代理类型 $2:接口名称 $3:接口索引 $4:邻居的设备号 $5:邻居的端口号 |
日志等级 |
6 |
举例 |
LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent new neighbor created on Port Ten-GigabitEthernet10/0/15 (IfIndex 599), Chassis ID is 3822-d666-ba00, Port ID is GigabitEthernet6/0/5. |
日志说明 |
端口收到新邻居发来的LLDP报文 |
处理建议 |
无 |
日志内容 |
[STRING] agent neighbor deleted on Port [STRING] (IfIndex [UINT32]), Chassis ID is [STRING], Port ID is [STRING]. |
参数解释 |
$1:代理类型 $2:接口名称 $3:接口索引 $4:邻居的设备号 $5:邻居的接口号 |
日志等级 |
6 |
举例 |
LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on Port Ten-GigabitEthernet10/0/15 (IfIndex 599), Chassis ID is 3822-d666-ba00, Port ID is GigabitEthernet6/0/5. |
日志说明 |
当邻居被删除时,接口收到删除消息 |
处理建议 |
无 |
日志内容 |
The number of [STRING] agent neighbors maintained by port [STRING] (IfIndex [UINT32]) is less than [UINT32], and new neighbors can be added. |
参数解释 |
$1:代理类型 $2:接口名称 $3:接口索引 $4:接口可以维护的最大邻居数 |
日志等级 |
6 |
举例 |
LLDP/6/LLDP_LESS_THAN_NEIGHBOR_LIMIT: The number of nearest bridge agent neighbors maintained by port 1 (IfIndex 587599) is less than 16, and new neighbors can be added. |
日志说明 |
接口邻居数未达到最大值,还可以为接口增加新邻居 |
处理建议 |
无 |
日志内容 |
[STRING] agent neighbor aged out on Port [STRING] (IfIndex [UINT32]), Chassis ID is [STRING], Port ID is [STRING]. |
参数解释 |
日志等级 |
5 |
举例 |
LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Nearest bridge agent neighbor aged out on Port Ten-GigabitEthernet10/0/15 (IfIndex599), Chassis ID is 3822-d666-ba00, Port ID is GigabitEthernet6/0/5. |
日志说明 |
当接口在一段时间内没有收到邻居发来的LLDP报文时,打印本信息 |
处理建议 |
检查链路状态,或者检查对端LLDP的接收和发送状态 |
日志内容 |
The number of [STRING] agent neighbors maintained by the port [STRING] (IfIndex [UINT32]) has reached [UINT32], and no more neighbors can be added. |
参数解释 |
日志等级 |
5 |
举例 |
LLDP/5/LLDP_REACH_NEIGHBOR_LIMIT: The number of nearest bridge agent neighbors maintained by the port Ten-GigabitEthernet1/0/15 (IfIndex 15) has reached 5, and no more neighbors can be added. |
日志说明 |
当邻居数达到最大值的接口收到LLDP报文时,打印本信息 |
处理建议 |
无 |
本节介绍LOAD模块输出的日志信息。
日志内容 |
Board is loading file on Chassis [INT32] Slot [INT32]. |
参数解释 |
$1:设备ID $2:槽位ID |
日志等级 |
4 |
举例 |
LOAD/4/BOARD_LOADING: Board is loading file on Chassis 1 Slot 5. |
日志说明 |
单板正在加载文件。触发该日志的原因可能是单板重启 |
处理建议 |
无 |
日志内容 |
Board failed to load file on Chassis [INT32] Slot [INT32]. |
参数解释 |
$1:设备ID $2:槽位ID |
日志等级 |
3 |
举例 |
LOAD/3/LOAD_FAILED: Board failed to load file on Chassis 1 Slot 5. |
日志说明 |
单板加载文件失败 |
处理建议 |
检查并清除故障 |
日志内容 |
Board has finished loading file on Chassis [INT32] Slot [INT32]. |
参数解释 |
$1:设备ID $2:槽位ID |
日志等级 |
5 |
举例 |
LOAD/5/LOAD_FINISHED: Board has finished loading file on Chassis 1 Slot 5. |
日志说明 |
单板完成文件加载 |
处理建议 |
无 |
本节介绍LOGIN(登录管理)模块输出的日志信息。
日志内容 |
[STRING] failed to login form [STRING]. |
参数解释 |
$1:用户名 $2:用户线名和IP 地址 |
日志等级 |
5 |
举例 |
LOGIN/5/LOGIN_FAILED: TTY failed to log in from console0. LOGIN/5/LOGIN_FAILED: usera failed to log in from 192.168.11.22. |
日志说明 |
用户登录失败 |
处理建议 |
无 |
本节介绍环路检测(LPDT)模块输出的日志信息。
日志内容 |
Loopback exists on [STRING]. |
参数解释 |
$1:接口名 |
日志等级 |
4 |
举例 |
LPDT/4/LPDT_LOOPED: Loopback exists on Ethernet 6/4/2. |
日志说明 |
接口上检测到环路时,环路检测模块会生成该信息 |
处理建议 |
检查网络环路 |
日志内容 |
Loopback on [STRING] recovered. |
参数解释 |
$1:接口名 |
日志等级 |
5 |
举例 |
LPDT/5/LPDT_RECOVERED: Loopback on Ethernet 6/4/1 recovered. |
日志说明 |
当接口环路消除时,环路检测模块会生成该信息 |
处理建议 |
无 |
日志内容 |
Admin [STRING] added user [STRING] to group [STRING]. |
参数解释 |
$1:管理员名 $2:用户名 $3:用户组名 |
日志等级 |
4 |
举例 |
LS/4/LS_ADD_USER_TO_GROUP: Admin admin added user user1 to group group1. |
日志说明 |
管理员添加一个用户到一个用户组。. |
处理建议 |
无 |
日志内容 |
User [STRING] from [STRING] failed authentication. [STRING] |
参数解释 |
$1:用户名 $2:IP地址 $3:失败原因: · “用户没有找到.” · “密码认证失败.” · “用户未上线.” · “接入类型不匹配.” · “绑定属性失败.” · "用户在黑名单." |
日志等级 |
5 |
举例 |
LS/5/LS_AUTHEN_FAILURE: User cwf@system from 192.168.0.22 failed authentication. “User not found.” |
日志说明 |
本地服务器拒绝了一个用户的认证请求 |
处理建议 |
无 |
日志内容 |
User [STRING] from [STRING] was authenticated successfully. |
参数解释 |
$1:用户名 $2:IP地址 |
日志等级 |
6 |
举例 |
LS/6/LS_AUTHEN_SUCCESS: User cwf@system from 192.168.0.22 was authenticated successfully. |
日志说明 |
本地服务器接受了一个用户的认证请求。. |
处理建议 |
无 |
日志内容 |
Admin [STRING] delete user [STRING] from group [STRING]. |
参数解释 |
日志等级 |
4 |
举例 |
LS/4/LS_DEL_USER_FROM_GROUP: Admin admin delete user user1 from group group1. |
日志说明 |
管理员将用户从用户组里删除 |
处理建议 |
无 |
日志内容 |
Failed to delete the password for user [STRING]. |
参数解释 |
$1:用户名 |
日志等级 |
4 |
举例 |
LS/4/LS_DELETE_PASSWORD_FAIL: Failed to delete the password for user abcd. |
日志说明 |
删除用户密码失败 |
处理建议 |
检查文件系统 |
日志内容 |
User [STRING] was added to the blacklist due to multiple login failures, [STRING]. |
参数解释 |
$1:用户名 $2:但是可以做其他的尝试 | 被永久阻塞| 被临时阻塞[UINT32]分钟 |
日志等级 |
4 |
举例 |
LS/4/LS_PWD_ADDBLACKLIST: user1 was added to the blacklist due to multiple login failures, but could make other attempts. |
日志说明 |
用户多次登录失败 |
处理建议 |
检查用户的密码 |
日志内容 |
User [STRING] changed the password because it was expired. |
参数解释 |
$1:User name. |
日志等级 |
4 |
举例 |
LS/4/LS_PWD_CHGPWD_FOR_AGEDOUT: aaa changed the password because it was expired. |
日志说明 |
密码过期 |
处理建议 |
无 |
日志内容 |
User [STRING] changed the password because it was about to expire. |
参数解释 |
$1:用户名 $2:老化时间 |
日志等级 |
4 |
举例 |
LS/4/LS_PWD_CHGPWD_FOR_AGEOUT: aaa changed the password because it was about to expire. |
日志说明 |
密码即将过期 |
处理建议 |
无 |
日志内容 |
User [STRING] changed the password because it had an invalid composition. |
参数解释 |
$1:用户名 |
日志等级 |
4 |
举例 |
LS/4/LS_PWD_CHGPWD_FOR_COMPOSITION: aaa changed the password because it had an invalid composition. |
日志说明 |
密码组合错误 |
处理建议 |
无 |
日志内容 |
User [STRING] changed the password at the first login. |
参数解释 |
$1:用户名 |
日志等级 |
4 |
举例 |
LS/4/LS_PWD_CHGPWD_FOR_FIRSTLOGIN: aaa changed the password at the first login. |
日志说明 |
用户首次登陆修改了密码 |
处理建议 |
无 |
日志内容 |
User [STRING] changed the password because it was too short. |
参数解释 |
$1:用户名 |
日志等级 |
4 |
举例 |
LS/4/LS_PWD_CHGPWD_FOR_LENGTH: aaa changed the password because it was too short. |
日志说明 |
用户因为密码太短而修改了密码 |
处理建议 |
无 |
日志内容 |
Failed to write the password records to file. |
参数解释 |
N/A |
日志等级 |
4 |
举例 |
LS/4/LS_PWD_FAILED2WRITEPASS2FILE: Failed to write the password records to file. |
日志说明 |
把密码记录写到文件失败。 |
处理建议 |
无 |
日志内容 |
Admin [STRING] from [STRING] could not modify the password for user [STRING], because [STRING]. |
参数解释 |
$1:管理员名 $2:IP地址 $3:用户名 $4:密码不匹配|不能写密码历史|密码无法验证 |
日志等级 |
4 |
举例 |
LS/4/LS_PWD_MODIFY_FAIL: Admin admin from 1.1.1.1 could not modify the password for user user1, because passwords do not match. |
日志说明 |
修改用户密码失败。 |
处理建议 |
无 |
日志内容 |
Admin [STRING] from [STRING] modify the password for user [STRING] successfully. |
参数解释 |
$1:管理员名 $2:IP地址 $3:用户名 |
日志等级 |
6 |
举例 |
LS/6/LS_PWD_MODIFY_SUCCESS: Admin admin from 1.1.1.1 modify the password for user abc successfully. |
日志说明 |
成功修改用户密码。 |
处理建议 |
无 |
日志内容 |
User [STRING] from [STRING] failed reauthentication. |
参数解释 |
$1:用户名 $2:IP地址 |
日志等级 |
5 |
举例 |
LS/5/LS_REAUTHEN_FAILURE: User abcd from 1.1.1.1 failed reauthentication. |
日志说明 |
为再次认证输入的旧密码无效 |
处理建议 |
检查旧密码 |
日志内容 |
Failed to update the password for user [STRING]. |
参数解释 |
$1:用户名 |
日志等级 |
4 |
举例 |
LS/4/LS_UPDATE_PASSWORD_FAIL: Failed to update the password for user abc. |
日志说明 |
为用户更新密码失败 |
处理建议 |
检查文件系统 |
日志内容 |
User [STRING] from [STRING] cancelled inputting the password. |
参数解释 |
$1:用户名 $2:IP地址 |
日志等级 |
5 |
举例 |
LS/5/LS_USER_CANCEL: User 1 from 1.1.1.1 cancelled inputting the password. |
日志说明 |
用户取消输入密码或者没有在90秒内输入密码。. |
处理建议 |
无 |
日志内容 |
User [STRING]'s login idle timer timed out. |
参数解释 |
$1:用户名 |
日志等级 |
5 |
举例 |
LS/5/LS_USER_PASSWORD_EXPIRE: User 1's login idle timer timed out. |
日志说明 |
登录空闲时间超时 |
处理建议 |
无 |
日志内容 |
Admin [STRING] [STRING] the user role [STRING] for [STRING]. |
参数解释 |
$1:管理员名 $2:添加/删除 $3:用户角色 $4:用户名 |
日志等级 |
4 |
举例 |
LS/4/LS_USER_ROLE_CHANGE: Admin admin add user role network-admin for user abcd. |
日志说明 |
管理员修改了用户角色 |
处理建议 |
无 |
本节介绍LSP验证模块输出的日志信息。
日志内容 |
Ping statistics for [STRING]: [UINT32] packet(s) transmitted, [UINT32] packet(s) received, [DOUBLE]% packet loss, round-trip min/avg/max = [UINT32]/[ UINT32]/[ UINT32] ms. |
参数解释 |
$1:FEC $2:发出的请求数 $3:收到的应答数 $4:未收到应答的次数占发送请求总数的比例 $5:最小往返延迟时间 $6:平均往返延迟时间 $7:最大往返延迟时间 |
日志等级 |
6 |
举例 |
LSPV/6/LSPV_PING_STATIS_INFO: Ping statistics for FEC 192.168.1.1/32: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max = 1/2/5 ms. |
日志说明 |
执行ping mpls命令,触发该日志。日志显示ping的统计信息 |
处理建议 |
如果没有收到应答报文,检测到LSP隧道或者PW的连通性 |
本节介绍MAC模块输出的日志信息。
日志内容 |
MAC address table exceeded maximum number [UINT32]. |
参数解释 |
$1:最大MAC地址数量 |
日志等级 |
4 |
举例 |
MAC/4/MAC_TABLE_FULL_GLOBAL: MAC address table exceeded maximum number 2. |
日志说明 |
全局MAC地址表中的表项数量超过了允许的最大数量 |
处理建议 |
无 |
日志内容 |
MAC address table exceeded maximum number [UINT32] on interface [STRING]. |
参数解释 |
$1:最大MAC地址数量 $2:接口名称 |
日志等级 |
4 |
举例 |
MAC/4/MAC_TABLE_FULL_PORT: MAC address table exceeded maximum number 2 on interface GigabitEthernet2/0/32. |
日志说明 |
接口对应的MAC地址表中的表项数量超过了允许的最大数量 |
处理建议 |
无 |
日志内容 |
MAC address table exceeded maximum number [UINT32] on Vlan [UINT32]. |
参数解释 |
$1:最大MAC地址数量 $2:VLAN ID |
日志等级 |
4 |
举例 |
MAC/4/MAC_TABLE_FULL_VLAN: MAC address table exceeded maximum number 2 on Vlan 2. |
日志说明 |
VLAN对应的MAC地址表中的表项数量超过了允许的最大数量 |
处理建议 |
无 |
本节介绍MPLS BFD模块输出的日志信息。
日志内容 |
[STRING] in failure. ([STRING].) |
参数解释 |
$1:LSP信息 $2:LSP失败原因 |
日志等级 |
5 |
举例 |
MBFD/5/MBFD_TRACEROUTE_FAILURE: LSP (LDP IPv4: 22.22.2.2/32, nexthop: 20.20.20.2) in failure. (Replying router has no mapping for the FEC.) MBFD/5/MBFD_TRACEROUTE_FAILURE: TE tunnel (RSVP IPv4: Tunnel1) in failure. (No label entry.) |
日志说明 |
通过周期性Traceroute功能检测LSP或MPLS TE隧道时,如果收到带有不合法返回代码的应答,则打印本日志信息,说明LSP或者MPLS TE隧道出现了故障 |
处理建议 |
检查LSP或者MPLS TE隧道的配置情况 |
本节介绍MDC(Multitenant Device Context,多租户设备环境)模块输出的日志信息。
日志内容 |
Failed to create MDC [UINT16] for not enough resources. |
参数解释 |
$1:MDC ID |
日志等级 |
5 |
举例 |
MDC/5/MDC_CREATE_ERR: Failed to create MDC 2 for not enough resources. |
日志说明 |
备用主控板启动时会从主用主控板获取所有已创建的MDC的信息,并在备用主控板创建同样的MDC。如果备用主控板因为资源限制无法创建该MDC,则输出此日志信息。MDC进驻备用主控板失败,无法在该备用主控板上提供服务 |
处理建议 |
1. 使用display mdc resource命令查询新插入的备用主控板的CPU、内存空间和磁盘空间 2. 使用undo mdc命令删除该MDC,或者移除新插入的备用主控板,保证系统中所有主控板已创建的MDC一致 3. 增加备用主控板的内存或减少磁盘使用,以保证新MDC可创建 |
日志内容 |
MDC [UINT16] is created. |
参数解释 |
$1:MDC ID |
日志等级 |
5 |
举例 |
MDC/5/MDC_CREATE: MDC 2 is created. |
日志说明 |
MDC成功创建 |
处理建议 |
无 |
日志内容 |
MDC [UINT16] is deleted. |
参数解释 |
$1:MDC ID |
日志等级 |
5 |
举例 |
MDC/5/MDC_DELETE: MDC 2 is deleted. |
日志说明 |
MDC成功删除 |
处理建议 |
无 |
日志内容 |
The MDC feature's license will expire in [UINT32] days. |
参数解释 |
$1:天数,取值范围为1到30天 |
日志等级 |
5 |
举例 |
MDC/5/MDC_NO_LICENSE_EXIT: The MDC feature’s license will expire in 5 days. |
日志说明 |
MDC License将在指定天数后失效 |
处理建议 |
安装新的License |
日志内容 |
The feature MDC has no available formal license. |
参数解释 |
N/A |
日志等级 |
5 |
举例 |
MDC/5/MDC_NO_FORMAL_LICENSE: The feature MDC has no available formal license. |
日志说明 |
备用主控板变为主用主控板了,但是新主用主控板没有安装MDC License。系统会给新主用主控板一个MDC试用期。试用期过期,如果用户还没有给新主用主控板安装License,则不能继续使用MDC特性 |
处理建议 |
日志内容 |
The MDC feature is being disabled, because it has no license. |
参数解释 |
N/A |
日志等级 |
5 |
举例 |
MDC/5/MDC_NO_LICENSE_EXIT: The MDC feature is being disabled, because it has no license. |
日志说明 |
MDC特性被禁用,因为MDC License过期或者被卸载了 |
处理建议 |
安装MDC License |
日志内容 |
MDC [UINT16] is offline now. |
参数解释 |
$1:MDC的编号 |
日志等级 |
5 |
举例 |
MDC/5/MDC_OFFLINE: MDC 2 is offline now. |
日志说明 |
MDC停用了 |
处理建议 |
无 |
日志内容 |
MDC [UINT16] is online now. |
参数解释 |
$1:MDC ID |
日志等级 |
5 |
举例 |
MDC/5/MDC_ONLINE: MDC 2 is online now. |
日志说明 |
MDC 启用了 |
处理建议 |
无 |
日志内容 |
MDC [UINT16] state changed to [STRING]. |
参数解释 |
$1:MDC ID $2:Current status |
日志等级 |
5 |
举例 |
MDC/5/MDC_STATE_CHANGE: MDC 2 state changed to active. |
日志说明 |
MDC 状态发生了变化 |
处理建议 |
无 |
本节介绍组播转发模块输出的日志信息。
日志内容 |
MFIB Process receive system memory alert [STRING] event. |
参数解释 |
$1:内存告警事件类型 |
日志等级 |
5 |
举例 |
MFIB/5/MFIB_MEM_ALERT: MFIB Process receive system memory alert start event. |
日志说明 |
MFIB模块收到了系统发出的内存告警事件 触发该日志的原因为:内存的状态发生了改变 |
处理建议 |
检查系统内存 |
日志内容 |
Failed to apply the sampler for mirroring group [UINT16], because the sampler resources are insufficient. |
参数解释 |
$1:镜像组编号 |
日志等级 |
3 |
举例 |
MGROUP/3/MGROUP_APPLY_SAMPLER_FAIL: Failed to apply the sampler for mirroring group 1, because the sampler resources are insufficient. |
日志说明 |
采样器资源不足时,新镜像组引用采样器失败 |
处理建议 |
无 |
日志内容 |
Failed to restore configuration for mirroring CPU of [STRING] in mirroring group [UINT16], because [STRING] |
参数解释 |
$1:单板所在的槽位号 $2:镜像组编号 $3:恢复源CPU配置失败的原因 |
日志等级 |
3 |
举例 |
MGROUP/3/MGROUP_RESTORE_CPUCFG_FAIL: Failed to restore configuration for mirroring CPU of chassis 1 slot 2 in mirroring group 1, because the type of the monitor port in the mirroring group is not supported. |
日志说明 |
当单板上的CPU用作镜像组的源CPU时,在单板拔出阶段,配置发生变化,单板再插入时,可能会引起镜像组源CPU的配置恢复失败 |
处理建议 |
排查配置恢复失败的原因,如果是由于系统不支持变化的配置,删除不支持的配置,重新配置镜像组的源CPU |
Failed to restore configuration for interface [STRING] in mirroring group [UINT16], because [STRING] |
参数解释 |
$1:接口名称 $2:镜像组编号 $3:恢复源端口配置失败的原因 |
日志等级 |
3 |
举例 |
MGROUP/3/MGROUP_RESTORE_IFCFG_FAIL: Failed to restore configuration for interface Ethernet3/1/2 in mirroring group 1, because the type of the monitor port in the mirroring group is not supported. |
日志说明 |
当单板上的接口用作镜像组的源端口时,在单板拔出阶段,配置发生变化,单板再插入时,可能会引起镜像组源端口的配置恢复失败 |
处理建议 |
排查配置恢复失败的原因,如果是由于系统不支持变化的配置,删除不支持的配置,重新配置镜像组的源端口 |
日志内容 |
Failed to restore configuration for mirroring group [UINT16] in [STRING], because [STRING] |
参数解释 |
$1:镜像组编号 $2:单板所在的槽位号 $3:恢复镜像组配置失败的原因 |
日志等级 |
3 |
举例 |
MGROUP/3/MGROUP_SYNC_CFG_FAIL: Failed to restore configuration for mirroring group 1 in chassis 1 slot 2, because monitor resources are insufficient. |
日志说明 |
当向单板同步完整的镜像组配置时,由于单板资源不足,引起配置恢复失败 |
处理建议 |
删除配置恢复失败的镜像组 |
本节介绍MPLS模块输出的日志信息。
日志内容 |
No enough hardware resource for MPLS. |
参数解释 |
无 |
日志等级 |
4 |
举例 |
MPLS/4/MPLS_HARD_RESOURCE_NOENOUGH: No enough hardware resource for MPLS. |
日志说明 |
MPLS硬件资源不足 |
处理建议 |
请检查是否生成了当前业务不需要的大量LSP,是则配置获调整标签分发协议的LSP触发策略、标签通告策略、标签接受策略,以过滤掉不需要的LSP |
日志内容 |
Hardware resource for MPLS is restored. |
参数解释 |
无 |
日志等级 |
6 |
举例 |
MPLS/6/MPLS_HARD_RESOURCE_RESTORE: Hardware resource for MPLS is restored. |
日志说明 |
MPLS硬件资源恢复 |
处理建议 |
无 |
本节介绍生成树模块输出的日志信息。
日志内容 |
BPDU-Protection port [STRING] received BPDUs. |
参数解释 |
$1:接口名 |
日志等级 |
4 |
举例 |
MSTP/4/MSTP_BPDU_PROTECTION: BPDU-Protection port Ethernet 1/0/4 received BPDUs. |
日志说明 |
当使能了BPDU保护功能的接口收到BPDU报文时,生成树模块会生成此信息 |
处理建议 |
检查下行设备是否是用户终端,是否存在恶意攻击 |
日志内容 |
Instance [UINT32]'s port [STRING] received no BPDU within the rcvdInfoWhile interval. Information of the port aged out. |
参数解释 |
$1:生成树实例编号 $2:接口名 |
日志等级 |
5 |
举例 |
MSTP/5/MSTP_BPDU_RECEIVE_EXPIRY: Instance 0's port GigabitEthernet 0/4/1 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out. |
日志说明 |
如果非指定端口在BPDU超时之前没有收到任何BPDU报文,端口状态会改变 |
处理建议 |
检查上行设备的STP状态及是否存在恶意攻击 |
日志内容 |
Instance [UINT32]'s port [STRING] detected a topology change. |
参数解释 |
$1:生成树实例编号 $2:接口名 |
日志等级 |
6 |
举例 |
MSTP/6/MSTP_DETECTED_TC: Instance 0's port GigabitEthernet 0/1/1 detected a topology change. |
日志说明 |
接口所在生成树实例拓扑发生变化,本端设备检测到拓扑变化 |
处理建议 |
检查拓扑变化是否存在异常 |
日志内容 |
STP is now disabled on the device. |
参数解释 |
N/A |
日志等级 |
6 |
举例 |
MSTP/6/MSTP_DISABLE: STP is now disabled on the device. |
日志说明 |
设备全局去使能了生成树特性 |
处理建议 |
无 |
日志内容 |
Instance [UINT32]'s port [STRING] has been set to discarding state. |
参数解释 |
$1:生成树实例编号 $2:接口名 |
日志等级 |
6 |
举例 |
MSTP/6/MSTP_DISCARDING: Instance 0's port Ethernet 1/0/2 has been set to discarding state. |
日志说明 |
MSTP在计算实例内端口状态,该接口被置为discarding状态 |
处理建议 |
无 |
日志内容 |
STP is now enabled on the device. |
参数解释 |
N/A |
日志等级 |
6 |
举例 |
MSTP/6/MSTP_ENABLE: STP is now enabled on the device. |
日志说明 |
设备全局使能了生成树特性 |
处理建议 |
无 |
日志内容 |
Instance [UINT32]'s port [STRING] has been set to forwarding state. |
参数解释 |
$1:生成树实例编号 $2:接口名 |
日志等级 |
6 |
举例 |
MSTP/6/MSTP_FORWARDING: Instance 0's port Ethernet 1/0/2 has been set to forwarding state. |
日志说明 |
MSTP在计算实例内端口状态,该接口被置为forwarding状态 |
处理建议 |
无 |
日志内容 |
Instance [UINT32]'s LOOP-Protection port [STRING] failed to receive configuration BPDUs. |
参数解释 |
$1:生成树实例编号 $2:接口名 |
日志等级 |
4 |
举例 |
MSTP/4/MSTP_LOOP_PROTECTION: Instance 0's LOOP-Protection port Ethernet 1/0/2 failed to receive configuration BPDUs. |
日志说明 |
使能了环路保护功能的接口不能接受BPDU配置报文 |
处理建议 |
日志内容 |
The current switch is no longer the root of instance [UINT32]. |
参数解释 |
$1:生成树实例编号 |
日志等级 |
5 |
举例 |
MSTP/5/MSTP_NOT_ROOT: The current switch is no longer the root of instance 0. |
日志说明 |
本设备不再是某生成树实例的根桥,因为在用stp root primary命令将它配置为根桥之后,它收到了比自身BPDU报文更优的BPDU报文 |
处理建议 |
检查桥优先级配置及是否存在恶意攻击 |
日志内容 |
Instance [UINT32]'s port [STRING] was notified of a topology change. |
参数解释 |
$1:生成树实例编号 $2:接口名 |
日志等级 |
6 |
举例 |
MSTP/6/MSTP_NOTIFIED_TC: Instance 0's port GigabitEthernet 0/1/1 was notified of a topology change. |
日志说明 |
远端相连设备通知本设备某接口所在生成树实例的拓扑发生变化 |
处理建议 |
检查拓扑变化是否异常 |
日志内容 |
Instance [UINT32]'s ROOT-Protection port [STRING] received superior BPDUs. |
参数解释 |
$1:生成树实例编号 $2:接口名 |
日志等级 |
4 |
举例 |
MSTP/4/MSTP_ROOT_PROTECTION: Instance 0's ROOT-Protection port Ethernet 1/0/2 received superior BPDUs. |
日志说明 |
使能了根保护功能的接口收到了比自身BPDU报文更优的BPDU报文 |
处理建议 |
检查桥优先级配置及是否存在恶意攻击 |
本节介绍Monitor Link模块输出的日志信息。
日志内容 |
The uplink of monitor link group [UINT32] is [STRING]. |
参数解释 |
$1:Monitor Link组ID $2:Monitor Link组状态 · down:故障 · up:正常 |
日志等级 |
6 |
举例 |
MTLK/6/MTLK_UPLINK_STATUS_CHANGE: The uplink of monitor link group 1 is up. |
日志说明 |
Monitor Link组上行链路up或down |
处理建议 |
检查故障链路 |
本节介绍ND模块输出的日志信息。
日志内容 |
[STRING] is inconsistent |
参数解释 |
$1:配置类型 · M_FLAG, 被管理地址配置标志位 · O_FLAG, 其他信息配置标志位 · CUR_HOP_LIMIT,跳数限制 · REACHABLE TIME, 保持邻居可达状态的时间 · NS INTERVAL, 邻居请求消息间隔 · MTU, 发布链路的MTU · PREFIX VALID TIME, 前缀的有效存活时间 · PREFIX PREFERRED TIME, 前缀用于无状态地址配置的优选项的存活时间 |
日志等级 |
6 |
举例 |
ND/6/ND_CONFLICT: PREFIX VALID TIME is inconsistent |
日志说明 |
设备收到一个路由通告消息,导致与邻居路由器上的配置不一致 |
处理建议 |
检查并保证设备与邻居路由器上的配置一致 |
日志内容 |
Duplicate address: [STRING] on the interface [STRING] |
参数解释 |
$1:将要分配的IPv6地址 $2:接口名称 |
日志等级 |
6 |
举例 |
ND/6/ND_DUPADDR: Duplicate address: 33::8 on interface Vlan-interface9. |
日志说明 |
分配给该接口的地址已经被其他设备使用 |
处理建议 |
分配一个新的IPv6地址 |
本节介绍NQA模块输出的日志信息。
日志内容 |
Server [STRING] unreachable. |
参数解释 |
$1:NQA服务器的IP地址 |
日志等级 |
6 |
举例 |
NQA/6/NQA_LOG_UNREACHABLE: Server 192.168.30.117 unreachable. |
日志说明 |
NQA客户端检测到NQA服务器不可达 |
处理建议 |
检查网络环境 |
本节介绍NTP模块输出的日志信息。
日志内容 |
System Leap Indicator changed from [UINT32] to [UINT32] after clock update. |
参数解释 |
$1:起始闰秒标识 $2:当前闰秒标识 |
日志等级 |
5 |
举例 |
NTP/5/NTP_CHANGE_LEAP: System Leap Indicator changed from 00 to 01 after clock update. |
日志说明 |
NTP闰秒标识是一个二位码,预报当天最近的分钟里要被插入的闰秒秒数 比特值在闰秒秒数插入当天23:59前或次日00:00后设置。因此秒数会比插入当天的时间提前或推后1秒 系统的闰秒标识会发生变化。例如,NTP状态会从未同步状态变为已同步状态 |
处理建议 |
无 |
日志内容 |
System stratum changed from [UINT32] to [UINT32] after clock update. |
参数解释 |
$1:起始层 $2:当前层 |
日志等级 |
5 |
举例 |
NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 6 to 5 after clock update. |
日志说明 |
系统的层数已发生变化 |
处理建议 |
无 |
日志内容 |
System clock changed from [STRING] to [STRING], the server is [STRING]. |
参数解释 |
$1:起始时间 $2:同步后时间 $3:IP地址 |
日志等级 |
5 |
举例 |
NTP/5/NTP_CLOCK_CHANGE: System clock changed from 02:12:58 12/28/2012 to 02:29:12 12/28/2012, the server is 192.168.30.116. |
日志说明 |
NTP客户端的时间已经和NTP服务器同步 NTP服务器触发NTP客户端向其同步时间 |
处理建议 |
无 |
日志内容 |
NTP server changed from [STRING] to [STRING]. |
参数解释 |
$1:起始时钟源的IP地址 $2:新时钟源的IP地址 |
日志等级 |
5 |
举例 |
NTP/5/NTP_SOURCE_CHANGE: NTP server changed from 1.1.1.1 to 1.1.1.2. |
日志说明 |
系统改变了时钟源 |
处理建议 |
分配另一个NTP服务器作为时钟源 |
日志内容 |
Lost synchronization with NTP server [STRING]. |
参数解释 |
$1:IP 地址 |
日志等级 |
5 |
举例 |
NTP/5/NTP_SOURCE_LOST: Lost synchronization with NTP server 1.1.1.1. |
日志说明 |
NTP交互中的时钟源处于未同步状态或不可达 |
处理建议 |
检查NTP服务器及网络连接 |
本节介绍OPTMOD模块输出的日志信息。
日志内容 |
[STRING]: Bias current is high! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
2 |
举例 |
OPTMOD/2/BIAS_HIGH: GigabitEthernet1/0/13: Bias current is high! |
日志说明 |
光模块的偏置电流超过上限 |
处理建议 |
确认并清除故障或更换更模块 |
日志内容 |
[STRING]: Bias current is low! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/BIAS_LOW: GigabitEthernet1/0/13: Bias current is low! |
日志说明 |
光模块的偏置电流低于下限 |
处理建议 |
确认并清除故障或更换更模块 |
日志内容 |
[STRING]: Bias current is normal! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/BIAS_NORMAL: GigabitEthernet1/0/13: Bias current is normal! |
日志说明 |
光模块的偏置电流恢复至正常范围 |
处理建议 |
无 |
日志内容 |
[STRING]: The transceiver type does not match port configuration! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
3 |
举例 |
OPTMOD/3/CFG_ERR: GigabitEthernet1/0/13: The transceiver type does not match port configuration! |
日志说明 |
光模块类型与端口配置不匹配 |
处理建议 |
确认不匹配原因或更换光模块 |
日志内容 |
[STRING]: The checksum of transceiver information is bad! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/CHKSUM_ERR: GigabitEthernet1/0/13: The checksum of transceiver information is bad! |
日志说明 |
光模块寄存器信息校验失败 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: The transceiver information I/O failed! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/IO_ERR: GigabitEthernet1/0/13: The transceiver information I/O failed! |
日志说明 |
设备读取光模块寄存器信息失败 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: [STRING] is gone. |
参数解释 |
$1:端口类型和编号 $2:故障类型 |
日志等级 |
5 |
举例 |
OPTMOD/5/MOD_ALM_OFF: GigabitEthernet1/0/13: Module_not_ready is gone. |
日志说明 |
一个光模块故障被清除 |
处理建议 |
无 |
日志内容 |
[STRING]: [STRING] is detected! |
参数解释 |
日志等级 |
5 |
举例 |
OPTMOD/5/MOD_ALM_ON: GigabitEthernet1/0/13: Module_not_ready is detected! |
日志说明 |
检测到一个光模块故障 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: The transceiver is [STRING]. |
参数解释 |
$1:端口类型和编号 $2:光模块类型 |
日志等级 |
4 |
举例 |
OPTMOD/4/MODULE_IN: GigabitEthernet1/0/13: The transceiver is 1000_BASE_T_AN_SFP. |
日志说明 |
光模块类型。当一光模块插入某端口时,设备生成此日志信息 |
处理建议 |
无 |
日志内容 |
[STRING]: The transceiver is absent. |
参数解释 |
$1:端口类型和编号 |
日志等级 |
4 |
举例 |
OPTMOD/4/MODULE_OUT: GigabitEthernet1/0/13: The transceiver is absent. |
日志说明 |
光模块被拔出 |
处理建议 |
无 |
日志内容 |
[STRING]: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
4 |
举例 |
OPTMOD/4/PHONY_MODULE: GigabitEthernet1/0/13: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! |
日志说明 |
光模块非H3C生产 |
处理建议 |
确认光模块兼容性或更换光模块 |
日志内容 |
参数解释 |
$1:端口类型和编号 $2:RX故障类型 |
日志等级 |
5 |
举例 |
OPTMOD/5/RX_ALM_OFF: GigabitEthernet1/0/13: RX_not_ready is gone. |
日志说明 |
一个光模块RX故障被清除 |
处理建议 |
无 |
日志内容 |
参数解释 |
日志等级 |
5 |
举例 |
OPTMOD/5/RX_ALM_ON: GigabitEthernet1/0/13: RX_not_ready is detected! |
日志说明 |
检测到一个光模块RX故障 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: RX power is high! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/RX_POW_HIGH: GigabitEthernet1/0/13: RX power is high! |
日志说明 |
光模块RX功率超过上限 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: RX power is low! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/RX_POW_LOW: GigabitEthernet1/0/13: RX power is low! |
日志说明 |
光模块RX功率低于下限 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: RX power is normal! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/RX_POW_NORMAL: GigabitEthernet1/0/13: RX power is normal! |
日志说明 |
光模块RX功率恢复至正常范围 |
处理建议 |
无 |
日志内容 |
[STRING]: Temperature is high! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/TEMP_HIGH: GigabitEthernet1/0/13: Temperature is high! |
日志说明 |
光模块温度超过上限 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: Temperature is low! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/TEMP_LOW: GigabitEthernet1/0/13: Temperature is low! |
日志说明 |
光模块温度低于下限 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: Temperature is normal! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/TEMP_NORMAL: GigabitEthernet1/0/13: Temperature is normal! |
日志说明 |
光模块温度恢复至正常范围 |
处理建议 |
无 |
日志内容 |
参数解释 |
$1:端口类型和编号 $2:TX故障类型 |
日志等级 |
5 |
举例 |
OPTMOD/5/TX_ALM_OFF: GigabitEthernet1/0/13: TX_fault is gone. |
日志说明 |
一个光模块TX故障被清除 |
处理建议 |
无 |
日志内容 |
参数解释 |
日志等级 |
5 |
举例 |
OPTMOD/5/TX_ALM_ON: GigabitEthernet1/0/13: TX_fault is detected! |
日志说明 |
检测到一个光模块TX故障 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: TX power is high! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
2 |
举例 |
OPTMOD/2/TX_POW_HIGH: GigabitEthernet1/0/13: TX power is high! |
日志说明 |
光模块TX功率超过上限 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: TX power is low! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/TX_POW_LOW: GigabitEthernet1/0/13: TX power is low! |
日志说明 |
光模块TX功率低于下限 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: TX power is normal! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/TX_POW_NORMAL: GigabitEthernet1/0/13: TX power is normal! |
日志说明 |
光模块TX功率恢复至正常范围 |
处理建议 |
无 |
日志内容 |
[STRING]: The transceiver type is not supported by port hardware! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
3 |
举例 |
OPTMOD/3/TYPE_ERR: GigabitEthernet1/0/13: The transceiver type is not supported by port hardware! |
日志说明 |
端口硬件不支持光模块类型 |
处理建议 |
确认原因或更换光模块 |
日志内容 |
[STRING]: Voltage is high! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/VOLT_HIGH: GigabitEthernet1/0/13: Voltage is high! |
日志说明 |
光模块电压超过上限 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: Voltage is low! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/VOLT_LOW: GigabitEthernet1/0/13: Voltage is low! |
日志说明 |
光模块电压低于下限 |
处理建议 |
确认并清除故障或更换光模块 |
日志内容 |
[STRING]: Voltage is normal! |
参数解释 |
$1:端口类型和编号 |
日志等级 |
5 |
举例 |
OPTMOD/5/VOLT_NORMAL: GigabitEthernet1/0/13: Voltage is normal! |
日志说明 |
光模块电压恢复至正常范围 |
处理建议 |
无 |
本节介绍OSPF模块输出的日志信息。
日志内容 |
OSPF [UINT32] Last neighbor down event: Router ID: [STRING] Local address: [STRING] Remote address: [STRING] Reason: [STRING] |
参数解释 |
$1:OSPF进程ID $2:路由器ID $3:本地IP地址 $4:邻居IP地址 $5:原因 |
日志等级 |
6 |
举例 |
OSPF/6/OSPF_LAST_NBR_DOWN: OSPF 1 Last neighbor down event: Router ID: 2.2.2.2 Local address: 10.1.1.1 Remote address: 10.1.1.2 Reason: Dead Interval timer expired. |
日志说明 |
最近一次OSPF邻居down事件 |
处理建议 |
1. 检查OSPF邻居down事件的原因,根据具体原因进行处理 2. 如果是配置相关命令导致邻居down,如接口参数变化等,请检查配置是否正确 3. 如果是超时邻居down,检查网络状况或者配置的超时时间是否合理 4. 如果是BFD检测导致的邻居down ,检查网络状况或者BFD检测时间配置是否合理 5. 如果是接口状态变化导致的邻居down,检查网络连接情况 |
日志内容 |
OSPF Process receive system memory alert [STRING] event. |
参数解释 |
$1:内存告警类型 |
日志等级 |
5 |
举例 |
OSPF/5/OSPF_MEM_ALERT: OSPF Process receive system memory alert start event. |
日志说明 |
OSPF模块收到内存告警信息 |
处理建议 |
检查系统内存 |
日志内容 |
OSPF [UINT32] Neighbor [STRING] ([STRING]) from [STRING] to [STRING] |
参数解释 |
$1:OSPF进程ID $2:邻居IP地址 $3:接口名称 $4:旧邻接状态 $5:新邻接状态 |
日志等级 |
5 |
举例 |
OSPF/5/OSPF_NBR_CHG: OSPF 1 Neighbor 2.2.2.2 (Vlan-interface100) from Full to Down. |
日志说明 |
接口OSPF邻接状态改变 |
处理建议 |
当某接口与邻居邻接状态从full变为其他状态时,检查OSPF配置正确性和网络连通性 |
日志内容 |
OSPF [UINT32] route limit reached. |
参数解释 |
$1:OSPF进程ID |
日志等级 |
4 |
举例 |
OSPF/4/OSPF_RT_LMT: OSPF 1 route limit reached. |
日志说明 |
OSPF进程的路由数达到了上限值 |
处理建议 |
检查是否受到攻击或者减少网络路由数 |
日志内容 |
OSPF [UINT32] New router ID elected, please restart OSPF if you want to make the new router ID take effect. |
参数解释 |
$1:OSPF进程ID |
日志等级 |
5 |
举例 |
OSPF/5/OSPF_RTRID_CHG: OSPF 1 New router ID elected, please restart OSPF if you want to make the new router ID take effect. |
日志说明 |
用户更改了router ID或者是使用的接口IP发生变化而改变了OSPF路由器ID。需要手动重启OSPF使新的路由器ID生效 |
处理建议 |
使用reset ospf process命令使新的路由器ID生效 |
日志内容 |
OSPF [UINT32] Router ID changed, re-configure Vlink on peer |
参数解释 |
$1:OSPF进程ID |
日志等级 |
5 |
举例 |
OSPF/5/OSPF_VLINKID_CHG:OSPF 1 Router ID changed, re-configure Vlink on peer |
日志说明 |
新的OSPF路由器ID生效。需要根据新的路由器ID检查并修改对端路由器的虚连接配置 |
处理建议 |
本节介绍OSPFv3模块输出的日志信息。
日志内容 |
OSPFv3 [UINT32] Last neighbor down event: Router ID: [STRING] local Interface Id: [UINT32] Remote Interface Id: [UINT32] Reason: [STRING]. |
参数解释 |
$1:OSPFv3进程ID $2:路由器ID $3:本地接口ID $4:对端接口ID $5:原因 |
日志等级 |
6 |
举例 |
OSPFV3/6/OSPFV3_LAST_NBR_DOWN: OSPF 1 Last neighbor down event: Router ID: 2.2.2.2 ocal Interface Id: 1111 Remote Interface Id: 2222 Reason: Dead Interval timer expired. |
日志说明 |
最近一次OSPFv3邻居down事件 |
处理建议 |
检查OSPFv3邻居down事件的原因 |
日志内容 |
OSPFV3 Process receive system memory alert [STRING] event. |
参数解释 |
$1:内存告警类型 |
日志等级 |
5 |
举例 |
OSPFV3/5/OSPFV3_MEM_ALERT: OSPFV3 Process receive system memory alert start event. |
日志说明 |
OSPFv3模块收到内存告警信息 |
处理建议 |
检查系统内存 |
日志内容 |
OSPFv3 [UINT32] Neighbor [STRING] ([STRING]) received [STRING] and its state from [STRING] to [STRING]. |
参数解释 |
$1:OSPFv3进程ID $2:邻居路由器ID $3:接口名称 $4:邻居事件 $5:旧邻接状态 $6:新邻接状态 |
日志等级 |
5 |
举例 |
OSPFV3/5/OSPFV3_NBR_CHG: OSPFv3 1 Neighbor 2.2.2.2 (Vlan100) received 1-Way from Full to Init. |
日志说明 |
接口OSPFv3邻接状态改变 |
处理建议 |
当某接口与邻居邻接状态变为down时,检查OSPFv3配置正确性和网络连通性 |
日志内容 |
OSPFv3 [UINT32] Route limit reached. |
参数解释 |
$1:OSPFv3进程ID |
日志等级 |
5 |
举例 |
OSPFV3/5/OSPFV3_RT_LMT:OSPFv3 1 Route limit reached. |
日志说明 |
OSPFv3进程的路由数达到了上限值 |
处理建议 |
修改路由数上限值 |
本节介绍PBB模块输出的日志信息。
日志内容 |
Because the aggregate interface [STRING] has been configured with PBB, assigning the interface [STRING] that does not support PBB to the aggregate group will cause incorrect processing. |
参数解释 |
$1:聚合组名称 $2:接口名称 |
日志等级 |
4 |
举例 |
PBB/4/PBB_JOINAGG_WARNING: Because the aggregate interface Bridge-Aggregation1 has been configured with PBB, assigning the interface Ten-GigabitEthernet9/0/30 that does not support PBB to the aggregate group will cause incorrect processing. |
日志说明 |
将不支持PBB的接口加入已经配置了PBB的聚合组会引发处理错误。配置为PBB实例上行口的聚合组的成员端口都需支持PBB |
处理建议 |
将该接口从聚合组中删除 |
本节介绍PIM模块输出的日志信息。
日志内容 |
PIM Process receive system memory alert [STRING] event. |
参数解释 |
$1:内存告警事件类型 |
日志等级 |
5 |
举例 |
PIM/5/PIM_MEM_ALERT: PIM Process receive system memory alert start event. |
日志说明 |
当内存发生变化时,PIM模块收到内存告警事件 |
处理建议 |
检查系统内存 |
日志内容 |
[STRING]PIM-NBR change: Neighbor [STRING]([STRING]) is down. ([STRING][STRING]) [STRING]: Neighbor [STRING] ([STRING]) is down. |
参数解释 |
$1:公网或VPN实例 $2:PIM邻居的IP地址 $3:接口名称 |
日志等级 |
5 |
举例 |
PIM/5/PIM_NBR_DOWN: (public net): Neighbor 10.1.1.1(Vlan-interface10) is down. |
日志说明 |
PIM邻居的状态变为down |
处理建议 |
检查PIM配置是否错误,检查网络是否发生拥塞 |
日志内容 |
[STRING]PIM-NBR change: Neighbor [STRING]([STRING]) is up. ([STRING][STRING]) [STRING]: Neighbor [STRING] ([STRING]) is up. |
参数解释 |
日志等级 |
5 |
举例 |
PIM/5/PIM_NBR_UP: (public net): Neighbor 10.1.1.1(Vlan-interface10) is up. |
日志说明 |
PIM邻居的状态变为up |
处理建议 |
无 |
本节介绍ping模块输出的日志信息。
日志内容 |
[STRING] [STRING] statistics: [UINT32] packet(s) transmitted, [UINT32] packet(s) received, [DOUBLE]% packet loss, round-trip min/avg/max/std-dev = [DOUBLE]/[DOUBLE]/[DOUBLE]/[DOUBLE] ms. |
参数解释 |
$1:目的IP地址,IPv6地址,或主机名 $2:ping 或 ping IPv6 $3;发送的回显请求数量 $4;接收的回显应答数量 $5:没有回复的报文占总请求报文比 $6:最小往返时间 $7:平均往返时间 $8:最大往返时间 $9:往返时间标准差 |
日志等级 |
6 |
举例 |
PING/6/PING_STATIS_INFO: 192.168.0.115 ping statistics: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms. |
日志说明 |
用户执行ping命令查看公网中对端是否可达 |
处理建议 |
如果没有收到报文,请检查接口是否down,并查找路由表,看是否存在有效路由 |
日志内容 |
[STRING] in VPN-instance [STRING] [STRING] statistics: [UINT32] packet(s) transmitted, [UINT32] packet(s) received, [DOUBLE]% packet loss, round-trip min/avg/max/std-dev = [DOUBLE]/[DOUBLE]/[DOUBLE]/[DOUBLE] ms. |
参数解释 |
$1:目的IP地址,IPv6地址,或主机名 $2:VPN实例名 $3:ping 或 ping IPv6 $3:发送的回显请求数量 $4:接收的回显应答数量 $5:没有回复的报文占总请求报文比 $6:最小往返时间 $7:平均往返时间 $8:最大往返时间 $9:往返时间标准差 |
日志等级 |
6 |
举例 |
PING/6/PING_VPN_STATIS_INFO: 192.168.0.115 in VPN-instance VPNA ping statistics: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms. |
日志说明 |
处理建议 |
本节包含PKI日志消息。
日志内容 |
Failed to request certificate of domain [STRING]. |
参数解释 |
$1:PKI域名 |
日志等级 |
5 |
举例 |
PKI/5/REQUEST_CERT_FAIL: Failed to request certificate of domain abc. |
日志说明 |
为PKI域申请证书失败 |
处理建议 |
检查设备和CA服务器的配置和其间的网络 |
日志内容 |
Request certificate of domain [STRING] successfully. |
参数解释 |
$1:PKI域名 |
日志等级 |
5 |
举例 |
PKI/5/REQUEST_CERT_SUCCESS: Request certificate of domain abc successfully. |
日志说明 |
为PKI域申请证书成功 |
处理建议 |
无 |
本节包含PKT2CPU日志消息。
日志内容 |
-Interface=[STRING]-ProtocolType=[UINT32]-MacAddr=[STRING]; The resources is insufficient. -Interface=[STRING]-ProtocolType=[UINT32]-SrcPort=[UINT32]-DstPort=[UINT32]; The resources is insufficient. |
参数解释 |
$1:接口名 $2:协议类型 $3:MAC地址或源端口 $4:目的端口 |
日志等级 |
4 |
举例 |
PKT2CPU/4/PKT2CPU_NO_RESOURCE: -Interface=Ethernet0/0/2-ProtocolType=21-MacAddr=0180-c200-0014; The resources is insufficient. |
日志说明 |
硬件资源不足 |
处理建议 |
取消配置。 |
日志内容 |
The port-security mode is configured but is not effective on interface [STRING]. |
参数解释 |
$1:接口名 |
日志等级 |
3 |
举例 |
PORTSEC/3/PORTSEC_PORTMODE_NOT_EFFECTIVE: The port-security mode is configured but is not effective on interface Ethernet3/1/2. |
日志说明 |
端口安全模式在接口上不生效,因为该接口不支持这种端口安全模式 |
处理建议 |
改变端口安全模式或关闭接口的端口安全特性 |
日志内容 |
The NeedToKnow feature is configured but is not effective on interface [STRING]. |
参数解释 |
$1:接口名 |
日志等级 |
3 |
举例 |
PORTSEC/3/PORTSEC_NTK_NOT_EFFECTIVE: The NeedToKnow feature is configured but is not effective on interface Ethernet3/1/2. |
日志说明 |
NeedToKnow模式在接口上不生效,因为该接口不支持NeedToKnow模式 |
处理建议 |
无 |
本节介绍PPP模块输出的日志信息。
日志内容 |
The address pool [STRING] is exhausted. |
参数解释 |
$1:地址池名称 |
日志等级 |
5 |
举例 |
PPP/5/IPPOOL_ADDRESS_EXHAUSTED: The address pool aaa is exhausted. |
日志说明 |
当地址池里最后一个地址分配出去时,打印本信息 |
处理建议 |
向地址池里添加地址 |
本节介绍Password control模块输出的日志信息。
日志内容 |
[STRING] was added to the blacklist for failed login attempts. |
参数解释 |
$1:用户名 |
日志等级 |
6 |
举例 |
PWDCTL/6/ADDBLACKLIST: hhh was added to the blacklist for failed login attempts. |
日志说明 |
因为用户输入密码错误,用户登录设备失败,被加入密码控制黑名单 |
处理建议 |
无 |
日志内容 |
[STRING] changed the password because [STRING]. |
参数解释 |
$1:用户名 $2:更改密码原因 |
日志等级 |
6 |
举例 |
PWDCTL/6/CNAHGEPASSWORD: hhh changed the password because first login. |
日志说明 |
由于某种原因,用户改变用户密码。例如该用户的账户第一次登录设备 |
处理建议 |
无 |
日志内容 |
参数解释 |
N/A |
日志等级 |
6 |
举例 |
PWDCTL/6/FAILEDTOWRITEPWD: failed to write the password records to file. |
日志说明 |
设备无法将用户密码写入密码记录文件 |
处理建议 |
请检查设备文件系统存储空间是否充足 |
本节介绍QoS模块输出的日志信息。
日志内容 |
CBWFQ is removed from [STRING]. |
参数解释 |
$1:接口名称 |
日志等级 |
3 |
举例 |
QOS/3/QOS_CBWFQ_REMOVED: CBWFQ is removed from GigabitEthernet4/0/1. |
日志说明 |
因接口最大带宽或接口速率更改后低于接口上原来配置的CBWFQ要求的带宽或速率,系统从接口上删除CBWFQ |
处理建议 |
增大接口最大带宽或接口速率后重新应用被删除的CBWFQ |
日志内容 |
Failed to apply classifier-behavior [STRING] in policy [STRING] to the [STRING] direction of control plane slot [UINT32]. [STRING]. |
参数解释 |
$1:CB对名称 $2:QoS策略名称 $3:流量方向 $4:槽位号 $5:失败原因 |
日志等级 |
4 |
举例 |
QOS/4/QOS_POLICY_APPLYCOPP_CBFAIL: Failed to apply classifier-behavior d in policy b to the inbound direction of control plane slot 3. No actions in behavior. |
日志说明 |
系统在控制平面的某个方向上应用或更新QoS策略中的某个CB对失败 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction of control plane slot [UINT32]. [STRING]. |
参数解释 |
$1:QoS策略名称 $2:流量方向 $3:槽位号 $4:失败原因 |
日志等级 |
4 |
举例 |
QOS/4/QOS_POLICY_APPLYCOPP_FAIL: Failed to apply or refresh QoS policy b to the inbound direction of control plane slot 3. Not supported by hardware. |
日志说明 |
系统在控制平面的某个方向上应用或更新QoS策略失败 |
处理建议 |
请根据失败原因,修改策略中的配置 |
日志内容 |
Failed to apply classifier-behavior [STRING] in policy [STRING] to the [STRING] direction globally. [STRING]. |
参数解释 |
$1:CB对名称 $2:QoS策略名称 $3:流量方向 $4:失败原因 |
日志等级 |
4 |
举例 |
QOS/4/QOS_POLICY_APPLYGLOBAL_CBFAIL: Failed to apply classifier-behavior a in policy b to the outbound direction globally. No actions in behavior. |
日志说明 |
系统在某个方向上全局应用或更新QoS策略中的某个CB对失败 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction globally. [STRING]. |
参数解释 |
$1:QoS策略名称 $2:流量方向 $3:失败原因 |
日志等级 |
4 |
举例 |
QOS/4/ QOS_POLICY_APPLYGLOBAL_FAIL: Failed to apply or refresh QoS policy b to the inbound direction globally. Not supported by hardware. |
日志说明 |
系统在某个方向上全局应用或更新QoS策略失败 |
处理建议 |
请根据失败原因,修改策略中的配置 |
日志内容 |
Failed to apply classifier-behavior [STRING] in policy [STRING] to the [STRING] direction of interface [STRING]. [STRING]. |
参数解释 |
$1:CB对名称 $2:QoS策略名称 $3:流量方向 $4:接口名称 $5:失败原因 |
日志等级 |
4 |
举例 |
QOS/4/QOS_POLICY_APPLYIF_CBFAIL: Failed to apply classifier-behavior b in policy b to the inbound direction of interface Ethernet3/1/2. No actions in behavior. |
日志说明 |
系统在接口的某个方向上应用或更新QoS策略中的某个CB对失败 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction of interface [STRING]. [STRING]. |
参数解释 |
$1:QoS策略名称 $2:流量方向 $3:接口名称 $4:失败原因 |
日志等级 |
4 |
举例 |
QOS/4/QOS_POLICY_APPLYIF_FAIL: Failed to apply or refresh QoS policy b to the inbound direction of interface Ethernet3/1/2. Not supported by hardware. |
日志说明 |
系统在接口的某个方向上应用或更新QoS策略失败 |
处理建议 |
请根据失败原因,修改策略中的配置 |
日志内容 |
Failed to apply classifier-behavior [STRING] in policy [STRING] to the [STRING] direction of VLAN [UINT32]. [STRING]. |
参数解释 |
$1:CB对名称 $2:QoS策略名称 $3:流量方向 $4:VLAN ID $5:失败原因 |
日志等级 |
4 |
举例 |
QOS/4QOS_POLICY_APPLYVLAN_CBFAIL: Failed to apply classifier-behavior b in policy b to the inbound direction of VLAN 2. No actions in behavior. |
日志说明 |
系统在VLAN的某个方向上应用或更新QoS策略中的某个CB对失败 |
处理建议 |
无 |
日志内容 |
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction of VLAN [UINT32]. [STRING]. |
参数解释 |
$1:QoS策略名称 $2:流量方向 $3:VLAN ID $4:失败原因 |
日志等级 |
4 |
举例 |
QOS/4/QOS_POLICY_APPLYVLAN_FAIL: Failed to apply or refresh QoS policy b to the inbound direction of VLAN 2. Not supported by hardware. |
日志说明 |
系统在VLAN的某个方向上应用或更新QoS策略失败 |
处理建议 |
请根据失败原因,修改策略中的配置 |
日志内容 |
Policy [STRING] requested bandwidth [UINT32](kbps). Only [UINT32](kbps) is available on [STRING]. |
参数解释 |
$1:QoS策略名称 $2:CBWFQ需要的带宽 $3:接口可用带宽 $4:接口名称 |
日志等级 |
3 |
举例 |
QOS/3/QOS_NOT_ENOUGH_BANDWIDTH: Policy d requested bandwidth 10000(kbps). Only 80(kbps) is available on GigabitEthernet4/0/1. |
日志说明 |
因CBWFQ要求的带宽大于接口最大带宽,CBWFQ配置失败 |
处理建议 |
增大接口最大带宽值或减小CBWFQ要求的带宽值 |
本节介绍RADIUS模块输出的日志信息。
日志内容 |
User [STRING] from [STRING] failed authentication. |
参数解释 |
$1:用户名称 $2:IP地址 |
日志等级 |
5 |
举例 |
RADIUS/5/RADIUS_AUTH_FAILURE: User abc@system from 192.168.0.22 failed authentication. |
日志说明 |
RADIUS服务器了拒绝用户的认证请求 |
处理建议 |
无 |
日志内容 |
参数解释 |
$1:用户名称 $2:IP地址 |
日志等级 |
6 |
举例 |
RADIUS/6/RADIUS_AUTH_SUCCESS: User abc@system from 192.168.0.22 was authenticated successfully. |
日志说明 |
RADIUS服务器接收了用户的认证请求 |
处理建议 |
无 |
日志内容 |
Failed to delete servers in scheme [STRING]. |
参数解释 |
$1:方案名称 |
日志等级 |
4 |
举例 |
RADIUS/4/RADIUS_DELETE_HOST_FAIL: Failed to delete servers in scheme abc. |
日志说明 |
删除RADIUS方案中的服务器失败 |
处理建议 |
无 |
本节介绍RIP模块输出的日志信息。
日志内容 |
RIP Process receive system memory alert [STRING] event. |
参数解释 |
$1:内存告警类型 |
日志等级 |
5 |
举例 |
RIP/5/RIP_MEM_ALERT: RIP Process receive system memory alert start event. |
日志说明 |
RIP模块收到内存告警信息 |
处理建议 |
检查系统内存 |
日志内容 |
RIP [UINT32] Route limit reached |
参数解释 |
$1:RIP进程ID |
日志等级 |
6 |
举例 |
RIP/6/RIP_RT_LMT: RIP 1 Route limit reached. |
日志说明 |
RIP进程的路由数达到了上限值 |
处理建议 |
检查是否受到攻击或者减少网络路由数 |
本节介绍RIPng模块输出的日志信息。
日志内容 |
RIPNG Process receive system memory alert [STRING] event. |
参数解释 |
$1:内存告警类型 |
日志等级 |
5 |
举例 |
RIPNG/5/RIPNG_MEM_ALERT: RIPNG Process receive system memory alert start event. |
日志说明 |
RIPng模块收到内存告警信息 |
处理建议 |
检查系统内存 |
日志内容 |
RIPng [UINT32] Route limit reached |
参数解释 |
$1:RIPng进程ID |
日志等级 |
6 |
举例 |
RIPNG/6/RIPNG_RT_LMT: RIPng 1 Route limit reached. |
日志说明 |
RIPng进程的路由数达到了上限值 |
处理建议 |
检查是否受到攻击或者减少网络路由数 |
本节介绍RM模块输出的日志信息。
日志内容 |
Max active [STRING] routes [UINT32] reached in URT of [STRING] |
参数解释 |
$1:IPv4或IPv6 $2:最大激活路由数 $3:VPN实例名 |
日志等级 |
4 |
举例 |
RM/4/RM_ROUTE_REACH_LIMIT: Max active IPv4 routes 100000 reached in URT of VPN1 |
日志说明 |
VPN实例单播路由表中的激活路由数达到了上限值 |
处理建议 |
检查所有的路由并删除不需要的路由 |
日志内容 |
Threshold value [UINT32] of max active [STRING] routes reached in URT of [STRING] |
参数解释 |
$1:最大激活路由数告警百分比 $2:IPv4或IPv6 $3:VPN实例名 |
日志等级 |
4 |
举例 |
RM/4/RM_ACRT_REACH_THRESVALUE: Threshold value 50% of max active IPv4 routes reached in URT of vpn1 |
日志说明 |
VPN实例单播路由表中的激活路由数达到了最大路由数告警百分比 |
处理建议 |
修改最大路由数告警百分比或路由数上限值 |
日志内容 |
Threshold value [UINT32] of active [STRING] routes reached in URT of [STRING] |
参数解释 |
$1:最大激活路由数 $2:IPv4或IPv6 $3:VPN实例名 |
日志等级 |
4 |
举例 |
RM/4/RM_THRESHLD_VALUE_REACH: Threshold value 10000 of active IPv4 routes reached in URT of vpn1 |
日志说明 |
处理建议 |
修改路由数上限值 |
本节介绍服务控制管理模块输出的日志信息。
日志内容 |
The service [STRING] is [STRING]... |
参数解释 |
$1:服务名 $2:服务状态 |
日志等级 |
6 |
举例 |
SCM/6/JOBINFO: The service DEV is starting... |
日志说明 |
系统正在启动,或者用户在管理服务 |
处理建议 |
无 |
日志内容 |
The service [STRING] receives a duplicate event in status [STRING], ignore it. |
参数解释 |
$1:服务名 $2:服务状态 |
日志等级 |
5 |
举例 |
SCM/5/RECV_DUPLICATEEVENT: The service DEV receives a duplicate event in status starting, ignore it. |
日志说明 |
服务收到状态相同的事件 |
处理建议 |
无 |
日志内容 |
Standby service [STRING] in [STRING] failed to become the active service and restarted because of incomplete synchronization. |
参数解释 |
$1:服务名 $2:单板位置 |
日志等级 |
4 |
举例 |
SCM/4/SERVICE_RESTART: Standby service ospf in slot 0 failed to become the active service and restarted because of incomplete synchronization. |
日志说明 |
备用服务还未完成同步时主服务意外退出 |
处理建议 |
无 |
日志内容 |
The service [STRING] receives an error event in status [STRING], drop it. |
参数解释 |
$1:服务名 $2:服务状态 |
日志等级 |
5 |
举例 |
SCM/5/SERVICE_STATEERROR: The service DEV receives an error event in status starting, drop it. |
日志说明 |
服务收到处于某种状态的错误事件 |
处理建议 |
无 |
日志内容 |
The service %s status failed : no response! |
参数解释 |
$1:服务名 |
日志等级 |
5 |
举例 |
SCM/5/SERVICE_STATUSFAILED: The service DEV status failed : no response! |
日志说明 |
服务失败 |
处理建议 |
无 |
日志内容 |
The service [STRING] set status [STRING] (Must be [STRING]), Ignore. |
参数解释 |
$1:服务名 $2:服务状态 $3:服务状态 |
日志等级 |
5 |
举例 |
SCM/5/SET_WRONGSTATUS: The service DEV set status stopping (Must be starting), Ignore. |
日志说明 |
服务收到了处于错误状态的事件 |
处理建议 |
无 |
本节介绍静态CRLSP模块输出的日志信息。
日志内容 |
Incoming label [INT32] for static CRLSP [STRING] is duplicate. |
参数解释 |
$1:入标签值 $2:静态CRLSP名称 |
日志等级 |
4 |
举例 |
SCRLSP/4/SCRLSP_LABEL_DUPLICATE: Incoming label 1024 for static CRLSP aaa is duplicate. |
日志说明 |
静态CRLSP的入标签被静态PW或者静态LSP占用。触发该日志的原因可能有: 在MPLS已使能的情况下,配置了一条入标签被静态PW或者静态LSP占用的静态CRLSP 在入标签被静态PW或静态LSP占用的静态CRLSP存在的情况下,使能MPLS |
处理建议 |
删除该CRLSP,重新配置一条静态CRLSP,并指定一个新的入标签 |
本节介绍SHELL模块输出的日志信息。
日志内容 |
-Line=[STRING]-IPAddr=[STRING]-User=[STRING]; Command is [STRING] |
参数解释 |
$1:用户线名(如果不涉及该参数,显示为**) $2:IP 地址(如果不涉及该参数,显示为**) $3:用户名(如果不涉及该参数,显示为**) $4:命令字符串 |
日志等级 |
6 |
举例 |
SHELL/6/SHELL_CMD: -Line=aux0-IPAddr=**-User=**; Command is quit |
日志说明 |
命令成功执行 |
处理建议 |
无 |
日志内容 |
Confirm option of command [STRING] is [STRING]. |
参数解释 |
$1:命令字符串 $2:确认结果,包括yes、no、timeout、cancel yes:表示用户确认结果为yes no:表示用户确认结果为no timeout:表示用户在规定时间内未输入确认结果 cancel:表示用户输入ctrl+C,中断操作 |
日志等级 |
6 |
举例 |
SHELL/6/SHELL_CMD_CONFIRM: Confirm option of command save is no. |
日志说明 |
记录需要用户确认的命令以及用户选项的操作结果 |
处理建议 |
无 |
日志内容 |
-User=[STRING]-IPAddr=[STRING]; Command [STRING] in view [STRING] failed to be executed. |
参数解释 |
$1:用户名 $2:IP地址 $3:命令字符串 $4:当前视图 |
日志等级 |
4 |
举例 |
SHELL/4/SHELL_CMD_EXECUTEFAIL: -User=**-IPAddr=192.168.62.138; Command description 10 in view system failed to be executed. |
日志说明 |
命令在当前视图下执行失败 |
处理建议 |
1. 确认命令是否与当前配置的某一功能冲突 2. 请联系技术支持 |
日志内容 |
Input string for the [STRING] command is [STRING]. |
参数解释 |
$1:命令字符串 $2:输入的字符串 |
日志等级 |
6 |
举例 |
SHELL/6/SHELL_CMD_INPUT: Input string for the save command is startup.cfg. SHELL/6/SHELL_CMD_INPUT: Input string for the save command is CTRL_C. SHELL/6/SHELL_CMD_INPUT: Input string for the save command is the Enter key. |
日志说明 |
当执行命令时,如果需要输入相关信息以便进行下一步操作,则输入的字符内容将被记录,并产生该操作的日志信息 |
处理建议 |
无 |
日志内容 |
Operation timed out: Getting input for the [STRING] command. |
参数解释 |
$1:命令字符串 |
日志等级 |
6 |
举例 |
SHELL/6/SHELL_CMD_INPUT_TIMEOUT: Operation timed out: Getting input for the fdisk command. |
日志说明 |
当执行命令时,如果需要输入额外信息才能正确执行此命令,而用户在大约30s时间内未输入信息,则会产生信息超时的日志信息 例如: 执行fdisk 命令进行手动分区时,需要输入分区大小,如果在一定时间内未输入分区大小的信息,则会产生输入信息超时的日志。 |
处理建议 |
无 |
日志内容 |
-User=[STRING]-IPAddr=[STRING]; Command [STRING] in view [STRING] failed to be matched. |
参数解释 |
日志等级 |
4 |
举例 |
SHELL/4/SHELL_CMD_MATCHFAIL: -User=**-IPAddr=192.168.62.138; Command description 10 in view system failed to be matched. |
日志说明 |
由于命令输入错误,或者当前视图不正确等,造成命令不能匹配并且不能正确执行 |
处理建议 |
1. 确认命令是否可以在当前视图下执行 2. 确认命令行是否正确 3. 请联系技术支持 |
日志内容 |
-Line=[STRING]-IPAddr=[STRING]-User=[STRING]; Command [STRING] is permission denied. |
参数解释 |
日志等级 |
5 |
举例 |
SHELL/5/SHELL_CMDDENY: -Line=vty0-IPAddr=192.168.62.138-User=**; Command vlan 10 is permission denied. |
日志说明 |
命令执行失败。用户权限不够 |
处理建议 |
无 |
日志内容 |
Command [STRING] fails to recover configuration. |
参数解释 |
$1:命令字符串 |
日志等级 |
6 |
举例 |
SHELL/6/SHELL_CMDFAIL: Command display this fails to recover configuration. |
日志说明 |
配置恢复操作失败 |
处理建议 |
无 |
日志内容 |
-User=[STRING]-IPAddr=[STRING]; Command is [STRING] . |
参数解释 |
$1:用户名 $2:IP 地址 $3:命令字符串 |
日志等级 |
6 |
举例 |
SHELL/6/SHELL_CRITICAL_CMDFAIL: -User=admin-IPAddr=169.254.0.7; Command is save. |
日志说明 |
命令被取消或者没有执行 |
处理建议 |
无 |
日志内容 |
[STRING] login form [STRING]. |
参数解释 |
$1:用户名 $2:用户线名 |
日志等级 |
5 |
举例 |
SHELL/5/SHELL_LOGIN: Console logged in from console0. |
日志说明 |
用户成功登录 |
处理建议 |
无 |
日志内容 |
[STRING] logout form [STRING]. |
参数解释 |
$1:用户名 $2:用户线名 |
日志等级 |
5 |
举例 |
SHELL/5/SHELL_LOGOUT: Console logged out from console0. |
日志说明 |
用户退出登录 |
处理建议 |
无 |
本节介绍静态LSP模块输出的日志信息。
日志内容 |
Incoming label [INT32] for static LSP [STRING] is duplicate. |
参数解释 |
$1:入标签值 $2:静态LSP名称 |
日志等级 |
4 |
举例 |
SLSP/4/SLSP_LABEL_DUPLICATE: Incoming label 1024 for static LSP aaa is duplicate. |
日志说明 |
静态LSP的入标签被静态PW或者静态CRLSP占用。触发该日志的原因可能有: 在MPLS已使能的情况下,配置了一条入标签被静态PW或静态CRLSP占用的静态LSP 在入标签被静态PW或静态CRLSP占用的静态LSP存在的情况下,使能MPLS |
处理建议 |
删除该LSP,重新配置一条静态LSP,并指定一个新的入标签 |
本节介绍Smart Link模块输出的日志信息。
日志内容 |
Status of port [STRING] in smart link group [UINT16] changes to active. |
参数解释 |
$1:端口名称 $2:Smart Link组ID |
日志等级 |
4 |
举例 |
SMLK/4/SMLK_LINK_SWITCH: Status of port GigabitEthernet0/1/4 in smart link group 1 changes to active. |
日志说明 |
从端口接替故障主端口转发流量 |
处理建议 |
清除网络故障 |
本节介绍SNMP模块输出的日志信息。
日志内容 |
SNMP [STRING] from [STRING] is rejected due to ACL restriction. |
参数解释 |
$1:SNMP 团体名/用户名/组名 $2:NMS的IP 地址 |
日志等级 |
3 |
举例 |
SNMP/3/SNMP_ACL_RESTRICTION: SNMP community public from 192.168.1.100 is rejected due to ACL restrictions. |
日志说明 |
当SNMP报文因ACL限制被拒绝通过时,打印系统日志 |
处理建议 |
检查SNMP agent上的ACL配置,及agent是否被攻击 |
日志内容 |
-seqNO=[UINT32]-srcIP=[STRING]-op=GET-node=[STRING]-value=[STRING]; The agent received a message. |
参数解释 |
$1:SNMP操作日志的序列号 $2:NMS的IP 地址 $3:Get操作的MIB节点名及对应的OID $4:请求报文的取值字段 |
日志等级 |
6 |
举例 |
SNMP/6/SNMP_GET: -seqNO=1-srcIP=192.168.28.28-op=GET-node=sysLocation(1.3.6.1.2.1.1.6.0)-value=; The agent received a message. |
日志说明 |
NMS向Agent发送Get请求报文。如果SNMP日志功能开启,SNMP模块将记录Get请求相关信息 |
处理建议 |
无 |
日志内容 |
Notification [STRING] [STRING]. |
参数解释 |
$1:告警名称 $2:告警信息绑定的变量名称及对应的OID。如果无变量绑定,OID值为null |
日志等级 |
6 |
举例 |
SNMP/6/SNMP_NOTIFY: Notification hh3cLogIn(1.3.6.1.4.1.25506.2.2.1.1.3.0.1) with hh3cTerminalUserName(1.3.6.1.4.1.25506.2.2.1.1.2.1.0)=;hh3cTerminalSource(1.3.6.1.4.1.25506.2.2.1.1.2.2.0)=Console. |
日志说明 |
Agent 发送告警给NMS。如果SNMP告警日志功能开启,Agent将记录SNMP告警信息 |
处理建议 |
无 |
日志内容 |
-seqNO=[UINT32]-srcIP=[STRING]-op=SET-errorIndex=[UINT32]-errorStatus=[STRING]-node=[STRING]-value=[STRING]; The agent received a message. |
参数解释 |
$1:SNMP操作日志的序列号 $2:NMS的IP地址 $3:Set操作的差错索引 $4:Set操作的差错状态 $5:Set操作的MIB节点名及对应的OID $6:Set操作设置的MIB节点的值 |
日志等级 |
6 |
举例 |
SNMP/6/SNMP_SET: -seqNO=3-srcIP=192.168.28.28-op=SET-errorIndex=0-errorStatus=noError-node=sysLocation(1.3.6.1.2.1.1.6.0)-value=Hangzhou China; The agent received a message. |
日志说明 |
NMS向Agent发送Set请求。如果SNMP日志功能开启,SNMP模块将记录Set操作 |
处理建议 |
无 |
日志内容 |
-User=[STRING]-IPAddr=[STRING]; SNMPv3 message is not in time window. |
参数解释 |
$1:用户名 $2:IP 地址 |
日志等级 |
4 |
举例 |
SNMP/4/SNMP_USM_NOTINTIMEWINDOW: -User=admin-IPAddr=169.254.0.7; SNMPv3 message is not in time window. |
日志说明 |
SNMPv3 消息不在时间窗 |
处理建议 |
无 |
日志内容 |
Failed to authenticate SNMP message. |
参数解释 |
无 |
日志等级 |
4 |
举例 |
SNMP/4/SNMP_AUTHENTICATION_FAILURE: Failed to authenticate SNMP message. |
日志说明 |
当Agent收到来自NMS的请求时,因Agent和NMS上配置的团体名/用户名等参数不一致,导致请求认证失败 |
处理建议 |
对于SNMPv1/v2,请检查并确保Agent和NMS上配置相同的团体名/用户名;对于SNMPv3还需确保Agent和NMS上配置相同的认证和加密方式及密钥 |
本节介绍SSHS(SSH server,SSH 服务器)模块输出的日志信息。
日志内容 |
SSH client [STRING] failed to log in because of [STRING] algorithm mismatch. |
参数解释 |
$1:SSH客户端IP地址 $2:算法类型,encryption(加密)、key exchange(密钥交换)、MAC(Message Authentication code)或者public key(公钥) |
日志等级 |
6 |
举例 |
SSHS/6/SSHS_ALGORITHM_MISMATCH: SSH client 192.168.30.117 failed to log in because of encryption algorithm mismatch. |
日志说明 |
算法不匹配,SSH客户端登录失败 |
处理建议 |
修改算法,使SSH客户端和服务器使用相同算法 |
日志内容 |
SSH user [STRING] (IP: [STRING]) failed to log in, because the number of authentication attempts exceeded the upper limit. |
参数解释 |
$1:用户名 $2:SSH客户端IP地址 |
日志等级 |
6 |
举例 |
SSHS/6/SSHS_AUTH_EXCEED_RETRY_TIMES: SSH user David (IP: 192.168.30.117) failed to log in, because the number of authentication attempts exceeded the upper limit. |
日志说明 |
SSH用户登录失败,认证尝试次数达到了最大值 |
处理建议 |
请SSH用户确认登录信息,并尝试重新登录 |
日志内容 |
SSH user [STRING] (IP: [STRING]) didn't pass public key authentication for [STRING]. |
参数解释 |
$1:用户名 $2:SSH客户端IP地址 $3:失败原因: · wrong public key algorithm (公钥算法错误) · wrong public key(公钥错误) · wrong digital signature(数字签名错误) |
日志等级 |
5 |
举例 |
SSHS/5/SSHS_AUTH_FAIL: SSH user David (IP: 192.168.30.117) didn't pass public key authentication for wrong public key algorithm. |
日志说明 |
SSH用户没有通过公钥认证 |
处理建议 |
请SSH用户重新登录 |
日志内容 |
Authentication timed out for [IPADDR]. |
参数解释 |
$1:用户IP地址 |
日志等级 |
6 |
举例 |
SSHS/6/SSHS_AUTH_TIMEOUT: Authentication timed out for 1.1.1.1. |
日志说明 |
SSH用户认证超时。该日志在SSH服务端检测到用户认证超时时输出 |
处理建议 |
建议用户检查是否没有及时输入认证信息 |
日志内容 |
SSH user [STRING] (IP: [STRING]) connected to the server successfully. |
参数解释 |
日志等级 |
6 |
举例 |
SSHS/6/SSHS_CONNECT: SSH user David (IP: 192.168.30.117) connected to the server successfully. |
日志说明 |
SSH用户成功登录服务器 |
处理建议 |
无 |
日志内容 |
The packet from [STRING] failed to be decrypted with [STRING]. |
参数解释 |
$1:SSH客户端IP地址 $2:加密算法(比如aes256-cbc) |
日志等级 |
5 |
举例 |
SSHS/5/SSHS_DECRYPT_FAIL: The packet from 192.168.30.117 failed to be decrypted with aes256-cbc. |
日志说明 |
来自SSH客户端的报文解密失败 |
处理建议 |
无 |
日志内容 |
SSH user [STRING] (IP: [STRING]) disconnected from the server. |
参数解释 |
日志等级 |
6 |
举例 |
SSHS/6/SSHS_DISCONNECT: SSH user David (IP: 192.168.30.117) disconnected from the server. |
日志说明 |
SSH用户退出登录 |
处理建议 |
无 |
日志内容 |
The packet to [STRING] failed to be encrypted with [STRING]. |
参数解释 |
日志等级 |
5 |
举例 |
SSHS/5/SSHS_ENCRYPT_FAIL: The packet to 192.168.30.117 failed to be encrypted with aes256-cbc. |
日志说明 |
发往SSH客户端的报文加密失败 |
处理建议 |
无 |
日志内容 |
Authentication failed for [STRING] from [STRING] port [INT32] ssh2. |
参数解释 |
$1:SSH客户端IP地址 $2:用户名 $3:端口号 |
日志等级 |
6 |
举例 |
SSHS/6/SSHS_LOG: Authentication failed for David from 140.1.1.46 port 16266 ssh2. |
日志说明 |
SSH用户密码认证失败,用户名或者密码错误 |
处理建议 |
无 |
日志内容 |
SSH server received a packet with wrong message authentication code (MAC) from [STRING]. |
参数解释 |
$1:SSH客户端IP地址 |
日志等级 |
6 |
举例 |
SSHS/6/SSHS_MAC_ERROR: SSH server received a packet with wrong message authentication code (MAC) from 192.168.30.117. |
日志说明 |
SSH服务器从客户端收到一个MAC错误的报文 |
处理建议 |
无 |
日志内容 |
SSH client [STRING] failed to log in, because the number of SSH sessions reached the upper limit. |
参数解释 |
$1:SSH客户端IP地址 |
日志等级 |
6 |
举例 |
SSHS/6/SSHS_REACH_SESSION_LIMIT: SSH client 192.168.30.117 failed to log in, because the number of SSH sessions reached the upper limit. |
日志说明 |
SSH客户端登录失败,SSH会话数达到了最大值 |
处理建议 |
无 |
日志内容 |
SSH client [STRING] failed to log in, because the number of users reached the upper limit. |
参数解释 |
$1:SSH客户端IP地址 |
日志等级 |
6 |
举例 |
SSHS/6/SSHS_REACH_USER_LIMIT: SSH client 192.168.30.117 failed to log in, because the number of users reached the upper limit. |
日志说明 |
SSH客户端登录失败,SSH用户数达到了最大值 |
处理建议 |
无 |
日志内容 |
User [STRING] at [IPADDR] requested operation: [STRING]. |
参数解释 |
$1:用户名称. $2:用户IP地址. $3:用户请求内容,包括文件操作等信息 · get file "name":下载名为name的文件 · put file "name":上传名为name的文件 |
日志等级 |
6 |
举例 |
SSHS/6/SSHS_SCP_OPER: User user1 at 1.1.1.1 requested operation: put file " flash:/aa". |
日志说明 |
SCP用户请求下载或者上传文件信息。该日志在SCP服务端收到用户请求执行相关命令时输出 |
处理建议 |
无 |
日志内容 |
参数解释 |
$1:用户名称. $2:用户IP地址. $3:用户请求内容,包括文件操作和目录操作等信息 · open dir "path":打开目录path · open "file" (attribute code code) in MODE mode:在MODE模式下,打开文件file,该文件的属性代码为code · remove file "file":删除文件file · mkdir "path" (attribute code code):创建新目录path,该目录的属性代码为code · rmdir "path":删除目录path · rename old "old-name" to new "new-name":改变旧文件或文件夹的名称old-name为new-name |
日志等级 |
6 |
举例 |
SSHS/6/SSHS_SFTP_OPER: User user1 at 1.1.1.1 requested operation: open dir "flash:/". |
日志说明 |
SFTP用户请求相关操作信息。该日志在SFTP服务端收到用户请求执行相关命令时输出 |
处理建议 |
无 |
日志内容 |
SSH client [STRING] failed to log in because of version mismatch. |
参数解释 |
$1:SSH客户端IP地址 |
日志等级 |
6 |
举例 |
SSHS/6/SSHS_VERSION_MISMATCH: SSH client 192.168.30.117 failed to log in because of version mismatch. |
日志说明 |
SSH客户端和服务器的SSH版本号不匹配 |
处理建议 |
修改版本,使SSH客户端和服务器使用相同SSH版本 |
日志内容 |
Add BAS AC [STRING]. |
参数解释 |
$1:BAS AC的MAC地址 |
日志等级 |
6 |
举例 |
STAMGR/6/STAMGR_ADDBAC_INFO: Add BAS AC 3ce5-a616-28cd. |
日志说明 |
Master AC与BAS AC建立连接 |
处理建议 |
无 |
日志内容 |
Add client [STRING]. |
参数解释 |
$1:客户端的MAC地址 |
日志等级 |
6 |
举例 |
STAMGR/6/STAMGR_ADDSTA_INFO: Add client 3ce5-a616-28cd. |
日志说明 |
客户端成功连接到BAS AC |
处理建议 |
无 |
日志内容 |
Delete BAS AC [STRING]. |
参数解释 |
$1:BAS AC的MAC地址 |
日志等级 |
6 |
举例 |
STAMGR/6/STAMGR_DELBAC_INFO: Delete BAS AC 3ce5-a616-28cd. |
日志说明 |
Master AC断开与BAS AC的连接 |
处理建议 |
无 |
日志内容 |
Delete client [STRING]. |
参数解释 |
$1:客户端的MAC地址 |
日志等级 |
6 |
举例 |
STAMGR/6/STAMGR_DELSTA_INFO: Delete client 3ce5-a616-28cd. |
日志说明 |
客户端断开与BAS AC的连接 |
处理建议 |
无 |
日志内容 |
IP address of client [STRING] changed to [STRING]. |
参数解释 |
$1:客户端的MAC地址 $1:客户端更新的IP地址 |
日志等级 |
6 |
举例 |
STAMGR/6/STAMGR_STAIPCHANGE_INFO: IP address of client 3ce5-a616-28cd changed to 4.4.4.4. |
日志说明 |
客户端更新IP地址 |
处理建议 |
无 |
本节介绍STM(IRF)模块输出的日志信息。
日志内容 |
Slot [UINT32] auto-update failed because [STRING]. |
参数解释 |
$1:槽位号 $2:失败原因 |
日志等级 |
4 |
举例 |
STM/4/STM_AUTO_UPDATE: Slot 5 auto-update failed because incompatible software version. |
日志说明 |
在加入IRF时,设备或主控板从主设备加载启动文件失败 |
处理建议 |
手动升级即将加入IRF的设备的软件 |
日志内容 |
Self member-id is changed from [UINT32] to [UINT32]. |
参数解释 |
$1:旧成员编号 $2:新成员编号 |
日志等级 |
4 |
举例 |
STM/4/STM_MEMBERID_CONFLICT: Self member-id changed from 1 to 4 |
日志说明 |
设备成员编号改变 |
处理建议 |
无 |
日志内容 |
Merge occurs. This IRF need NOT be rebooted. |
参数解释 |
N/A |
日志等级 |
5 |
举例 |
STM/5/STM_MERGE: Merge occurs. This IRF need NOT be rebooted. |
日志说明 |
由于本IRF系统在主设备选举中取胜,无须重启本IRF系统完成IRF合并 |
处理建议 |
无 |
日志内容 |
Merge occurs. This IRF need be rebooted. |
参数解释 |
N/A |
日志等级 |
4 |
举例 |
STM/4/STM_MERGE_NEED_REBOOT: Merge occurs. This IRF need be rebooted. |
日志说明 |
由于本IRF系统在主设备选举中失败,请重启本IRF系统来完成IRF合并 |
处理建议 |
无 |
日志内容 |
Merge occurs. |
参数解释 |
N/A |
日志等级 |
4 |
举例 |
STM/4/STM_LINK_RECOVERY: Merge occurs. |
日志说明 |
IRF合并事件发生 |
处理建议 |
无 |
日志内容 |
IRF port [UINT32] is down. |
参数解释 |
$1:IRF端口名 |
日志等级 |
3 |
举例 |
STM/3/STM_LINK_STATUS_DOWN: IRF port 2 is down. |
日志说明 |
IRF端口关闭。当绑定的所有物理端口都关闭时,IRF端口关闭 |
处理建议 |
检查绑定到IRF端口的物理端口,确保至少有一个物理端口可以正常工作 |
日志内容 |
IRF port [UINT32] is down because heartbeat timed out. |
参数解释 |
$1:IRF端口名 |
日志等级 |
2 |
举例 |
STM/2/STM_LINK_STATUS_TIMEOUT: IRF port 1 is down because heartbeat timed out. |
日志说明 |
由于心跳检测超时,IRF端口关闭 |
处理建议 |
检查IRF链路故障 |
日志内容 |
IRF port [UINT32] is up. |
参数解释 |
$1:IRF端口名 |
日志等级 |
6 |
举例 |
STM/6/STM_LINK_STATUS_UP: IRF port 1 is up. |
日志说明 |
IRF链路可以正常工作 |
处理建议 |
无 |
日志内容 |
Neighbor of IRF port [UINT32] can't be stacked. |
参数解释 |
$1:IRF端口名 |
日志等级 |
3 |
举例 |
STM/3/STM_SOMER_CHECK: Neighbor of IRF port 1 can’t be stacked. |
日志说明 |
IRF口连接的设备无法与本设备堆叠 |
处理建议 |
1. 检查以下事项: 2. 设备型号是否允许堆叠 3. IRF配置是否正确 4. 要获取更多信息,请参见该型号设备的IRF配置指导 |
本节包含syslog日志消息。
日志内容 |
Log file space is full. |
参数解释 |
N/A |
日志等级 |
4 |
举例 |
SYSLOG/4/SYSLOG_LOGFILE_FULL: Log file space is full. |
日志说明 |
日志空间已满 |
处理建议 |
备份日志文件后将其删除,然后根据需要使能端口 |
日志内容 |
System restarted -- [STRING] [STRING] Software. |
参数解释 |
$1:公司名,包含H3C, HP。 $2:软件名,Comware 或者Router. |
日志等级 |
6 |
举例 |
SYSLOG/6/SYSLOG_RESTART: System restarted -- H3C Comware Software |
日志说明 |
系统重启日志 |
处理建议 |
无 |
本节介绍TACACS模块输出的日志信息。
日志内容 |
参数解释 |
$1:用户名称 $2:IP地址 |
日志等级 |
5 |
举例 |
TACACS/5/TACACS_AUTH_FAILURE: User cwf@system from 192.168.0.22 failed authentication. |
日志说明 |
TACACS 服务器了拒绝用户的认证请求 |
处理建议 |
无 |
日志内容 |
参数解释 |
$1:用户名称 $2:IP地址 |
日志等级 |
6 |
举例 |
TACACS/6/TACACS_AUTH_SUCCESS: User cwf@system from 192.168.0.22 was authenticated successfully. |
日志说明 |
TACACS 服务器接收了用户的认证请求 |
处理建议 |
无 |
日志内容 |
参数解释 |
$1:方案名称 |
日志等级 |
4 |
举例 |
TACACS/4/TACACS_DELETE_HOST_FAIL: Failed to delete servers in scheme abc. |
日志说明 |
删除TACACS方案中的服务器失败 |
处理建议 |
无 |
本节介绍Telnet模块输出的日志信息。
日志内容 |
Telnet client [IPADDR] failed to log in. Number of Telnet sessions reached the limit. |
参数解释 |
$1:Telnet客户端IP地址 |
日志等级 |
6 |
举例 |
TELNETD/6/TELNETD_REACH_SESSION_LIMIT:Telent client 1.1.1.1 failed to log in. Number of Telnet sessions reached the limit. |
日志说明 |
Telnet登录用户达到上限。该日志在Telnet服务端检测到登录客户数达到上限时输出 |
处理建议 |
无 |
本节介绍TRILL模块输出的日志信息。
日志内容 |
Duplicate System ID [STRING] in [STRING] PDU sourced from RBridge 0x[HEX]. |
参数解释 |
$1:System ID $2:PDU类型 $3:源RBridge的Nickname |
日志等级 |
5 |
举例 |
TRILL/5/TRILL_DUP_SYSTEMID: Duplicate System ID 0011.2200.1501 in LSP PDU sourced from RBridge 0xc758. |
日志说明 |
本地RBridge收到的LSP或者IIH PDU中的System ID和本地RBridge的System ID相同。可能的原因包括: 为本地RBridge和远端RBridge分配了相同的System ID 本地RBridge收到了一个自己产生、携带了旧的Nickname的LSP PDU |
处理建议 |
检查TRILL网络中上RBridge的System ID |
日志内容 |
The interface [STRING] does not support TRILL. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
TRILL/4/TRILL_INTF_CAPABILITY: The interface GigabitEthernet0/1/3 does not support TRILL. |
日志说明 |
不支持TRILL的端口被加入到了聚合组中 |
处理建议 |
将不支持TRILL的端口从聚合组中删除 |
日志内容 |
Interface [STRING] entered the suspended state. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
TRILL/4/TRILL_INTF_ENTERED_SUSPENDED: Interface Ten-GigabitEthernet1/0/1 entered the suspended state. |
日志说明 |
RB的一个TRILL端口检测到自己和本RB上拥有更高优先级的TRILL端口连在一起或者该端口检测到本地网络存在环路从而进入suspended状态 |
处理建议 |
避免将同一RB上的多个TRILL端口通过传统二层网络连接起来或者消除TRILL端口连接的本地网络环路 |
日志内容 |
Interface [STRING] exited the suspended state. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
TRILL/4/TRILL_INTF_EXITED_SUSPENDED: Interface Ten-GigabitEthernet1/0/1 exited the suspended state. |
日志说明 |
消除同一RB上多个TRILL端口之间通过传统二层网络的连接从而使端口退出suspended状态;或者TRILL端口检测到本地网络环路消除从而退出suspended状态 |
处理建议 |
无 |
日志内容 |
The TRILL feature is being disabled, because it has no license. |
参数解释 |
无 |
日志等级 |
5 |
举例 |
TRILL/5/TRILL_LICENSE_UNAVAILABLE: The TRILL feature is being disabled, because it has no license. |
日志说明 |
TRILL的License已经过期 |
处理建议 |
检查TRILL的License |
日志内容 |
The feature TRILL has no available license. |
参数解释 |
无 |
日志等级 |
5 |
举例 |
TRILL/5/TRILL_LICENSE_UNAVAILABLE: The feature TRILL has no available license. |
日志说明 |
TRILL没有License |
处理建议 |
检查TRILL的License |
日志内容 |
No license is found for TRILL. |
参数解释 |
无 |
日志等级 |
3 |
举例 |
TRILL/3/TRILL_LICENSE_UNAVAILABLE: No license is found for TRILL. |
日志说明 |
没有找到TRILL对应的License |
处理建议 |
请安装TRILL对应的License |
日志内容 |
TRILL is unavailable because its license has expired. |
参数解释 |
无 |
日志等级 |
3 |
举例 |
TRILL/3/TRILL_LICENSE_EXPIRED: TRILL is unavailable because its license has expired. |
日志说明 |
TRILL对应的License已经过期 |
处理建议 |
请更换有效的License |
日志内容 |
TRILL will become unavailable in [ULONG] days. |
参数解释 |
$1:功能还可使用的天数 |
日志等级 |
5 |
举例 |
TRILL/5/TRILL_LICENSE_EXPIRED_TIME: TRILL will become unavailable in 2 days. |
日志说明 |
EVIISIS的License已经过期,EVIISIS功能将在2天后失效
EVIISIS的License过期后,EVIISIS功能还能使用30天,当前已经用了28天 |
处理建议 |
若要继续使用EVIISIS功能,请准备新的License |
日志内容 |
TRILL process receive system memory alert [STRING] event. |
参数解释 |
$1:内存告警事件的类型 |
日志等级 |
5 |
举例 |
TRILL/5/TRILL_MEM_ALERT: TRILL process receive system memory alert start event. |
日志说明 |
TRILL从系统收到一个内存告警事件 |
处理建议 |
检查系统内存 |
日志内容 |
TRILL [UINT32], [STRING] adjacency [STRING] ([STRING]), state change to: [STRING]. |
参数解释 |
$1:TRILL进程ID $2:邻居级别 $3:邻居的System ID $4:接口名 $5:当前邻居状态 |
日志等级 |
5 |
举例 |
TRILL/5/TRILL_NBR_CHG: TRILL 1, Level-1 adjacency 0011.2200.1501 (GigabitEthernet0/1/3), state change to: down. |
日志说明 |
一个TRILL邻居的状态发生改变 |
处理建议 |
当邻居状态变为down或者initializing时,请根据状态变化的原因检查TRILL配置和网络状态 |
本节介绍接口VLAN模块输出的日志信息。
日志内容 |
Failed to add interface [STRING] to the default VLAN. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
VLAN/4/VLAN_FAILED: Failed to add interface S-Channel 4/2/0/19:100 to the default VLAN. |
日志说明 |
在硬件资源不足的时候创建一个S-Channel接口。此S-Channel接口不能加入到缺省VLAN |
处理建议 |
无 |
日志内容 |
The configuration failed because of resource insufficiency or conflicts on [STRING]. |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
VLAN/4/VLAN_VLANMAPPING_FAILED: The configuration failed because of resource insufficiency or conflicts on Ethernet0/0. |
日志说明 |
因本接口硬件资源不足或者接口加入或离开二层聚合组,所以部分或全部VLAN映射配置丢失 |
处理建议 |
无 |
日志内容 |
参数解释 |
$1:接口名称 |
日志等级 |
4 |
举例 |
VLAN/4/VLAN_VLANTRANSPARENT_FAILED: The configuration failed because of resource insufficiency or conflicts on Ethernet0/0. |
日志说明 |
因本接口硬件资源不足或者接口加入或离开二层聚合组,所以部分或全部VLAN透传配置丢失 |
处理建议 |
无 |
本节介绍VRRP模块输出的日志信息。
日志内容 |
Authentication failed in [STRING] virtual router [UINT32] (configured on [STRING]): [STRING]. |
参数解释 |
$1:VRRP协议版本 $2:VRRP备份组号 $3:VRRP备份组所在接口的名称 $4:错误信息详细内容 |
日志等级 |
6 |
举例 |
VRRP/6/VRRP_AUTH_FAILED: Authentication failed in IPv4 virtual router 10 (configured on Ethernet0/0): authentication type mismatch. |
日志说明 |
收到了VRRP报文,但没有通过认证 |
处理建议 |
检查指定接口上的VRRP备份组配置。确保备份组中所有成员使用相同的验证模式和验证字 |
日志内容 |
The [STRING] virtual router [UINT32] (configured on [STRING]) detected a VRRP configuration error: [STRING]. |
参数解释 |
日志等级 |
6 |
举例 |
VRRP/6/VRRP_CONFIG_ERROR: The IPv4 virtual router 10 (configured on Ethernet0/0) detected a VRRP configuration error: VIRTUAL IP ADDRESS COUNT ERROR. |
日志说明 |
VRRP备份组配置错误。例如:成员上的备份组虚拟IP地址的数量不一致 |
处理建议 |
检查指定接口上的VRRP备份组配置。确保备份组中所有成员使用相同的配置 |
日志内容 |
The [STRING] virtual router [UINT32] (configured on [STRING]) received an error packet: [STRING]. |
参数解释 |
日志等级 |
6 |
举例 |
VRRP/6/VRRP_PACKET_ERROR: The IPv4 virtual router 10 (configured on Ethernet0/0) received an error packet: CKSUM ERROR. |
日志说明 |
VRRP备份组收到无效VRRP报文。例如,校验和错误 |
处理建议 |
检查指定接口上的VRRP备份组配置 |
日志内容 |
The status of [STRING] virtual router [UINT32] (configured on [STRING]) changed from [STRING] to [STRING]: [STRING]. |
参数解释 |
$1:VRRP协议版本 $2:VRRP备份组号 $3:VRRP备份组所在接口的名称 $4:先前状态 $5:当前状态 $6:状态变化原因 |
日志等级 |
6 |
举例 |
VRRP/6/VRRP_STATUS_CHANGE: The status of IPv4 virtual router 10 (configured on Ethernet0/0) changed (from Backup to Master): Timer expired. |
日志说明 |
定时器超时,VRRP备份组中的Master或Backup路由器状态发生变化 |
处理建议 |
检查VRRP备份组中的Master或Backup路由器状态,确保备份组工作正常 |
日志内容 |
The [STRING] virtual router [UINT32] (configured on [STRING]) virtual forwarder [UINT32] detected status change (from [STRING] to [STRING]): [STRING]. |
参数解释 |
$1:VRRP协议版本 $2:VRRP备份组号 $3:VRRP备份组所在接口的名称 $4:VF ID $5:VF先前状态 $6:VF当前状态 $7:状态变化原因 |
日志等级 |
6 |
举例 |
VRRP/6/VRRP_VF_STATUS_CHANGE: The IPv4 virtual router 10 (configured on GigabitEthernet5/1) virtual forwarder 2 detected status change (from Active to Initialize): Weight changed. |
日志说明 |
虚拟转发器状态发生改变。可能的原因包括权重变化、定时器超时、VRRP备份组Down |
处理建议 |
检查Track项的状态 |
日志内容 |
The [STRING] virtual router [UINT32] (configured on [STRING]) failed to add virtual MAC: [STRING]. |
参数解释 |
$1:VRRP协议版本 $2:VRRP备份组号 $3:VRRP备份组所在接口的名称 $4:出现错误的原因 |
日志等级 |
3 |
举例 |
VRRP/3/VRRP_VMAC_INEFFECTIVE: The IPv4 virtual router 10 (configured on Ethernet0/0) failed to add virtual MAC: Hardware resources insufficient. |
日志说明 |
添加虚拟MAC地址失败 |
处理建议 |
确定操作失败的根因并解决 |
