整本手册
本章节下载 (110.11 KB)
Table of Contents
1 Compliance and Safety Manual
European Directives compliance
EN55022 / CISPR22 / AS-NZS 55022 Compliance
This equipment has been tested and found to comply with the limits for a Class A digital device, pursuant to Part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference when the equipment is operated in a commercial environment. This equipment generates, uses, and can radiate radio frequency energy and, if not installed and used in accordance with the instruction manual, may cause harmful interference to radio communications. Operation of this equipment in a residential area is likely to cause harmful interference in which case the user will be required to correct the interference at his own expense.
This Class A digital apparatus complies with Canadian ICES-003.
Cet appareil numérique de la classe A est conforme à la norme NMB-003 du Canada.
These products comply with the European Low Voltage Directive 2006/95/EC and EMC Directive 2004/108/EC.
A copy of the signed Declaration of Conformity can be downloaded from:
http://www.h3c.com/portal/Technical_Documents
The products this manual refers to are covered by the Waste Electrical and Electronic Equipment Directive (WEEE) and must be disposed of in a responsible manner.
These products comply with the requirements of EN55022 / CISPR 22 / AS/NZS CISPR 22 for Class A Information Technology Equipment (ITE).
Warning: If this equipment is used in a domestic environment, radio disturbance may arise. When such trouble occurs, the user may be required to take corrective actions.
These products comply with the requirements of VCCI for Class A Information Technology Equipment (ITE).
You must read the following safety information before you carry out any installation or removal of the H3C Blade Switch 5500 Series, or any maintenance procedures.
在安装或维护H3C Blade5500系列刀片交换机前,请务必仔细阅读以下安全信息。
The blade switch is a built-in device. Installation to the end-product shall comply with EN 60950-1.
刀片交换机属于插入式装置,安装交换机的终端系统设备要满足EN60950-1的标准。
Fire enclosure according to EN 60950-1 shall be provided by the end-product.
安装刀片交换机的终端系统产品的外壳要满足EN60950-1要求的防火外壳。
Class 1 Laser Product.
这是1类激光产品。
Thermal condition: the blade switch ambient temperature shall not exceed 55 deg C, An external forced cooling with minimum air flow rate 1.5m/s shall be provided.
散热条件:刀片交换机工作时环温不能超过55度,在设备工作时系统风扇应提供1.5m/s的风速。
