欢迎user
整本手册
本章节下载 (83.64 KB)
前面板左上角标有丝印LSQ1SRP1CB3,用来标识该单板。
属性 |
LSQ1SRP1CB3 |
接口连接器类型 |
RJ-45 |
对外接口 |
l 1个Console口,支持交换机的本地或远程拨号配置管理 l 1个管理用10/100BASE-TX接口 l 1个支持热插拔的CF卡接口 |
接口传输速率 |
l Console口:≤115200bit/s,缺省为9600bit/s l 10Base-T/100Base-TX接口:10/100Mbit/s半/全双工;MDIX |
可选用线缆及最大传输距离 |
l Console口:普通异步串行口电缆,传输距离≤15m l 10Base-T/100Base-TX接口:5类双绞线,传输距离100m |
单板适用的机型 |
S7603/S7606/S7606-V/S7610以太网交换机 |
单板适用的主机软件版本 |
Release 6000系列版本中的Release 6600及以上版本 |
如主机软件版本不匹配,可以联系该设备的销售商或集成商获取相应的主机软件版本。
单板安装说明及主机软件版本的升级方法请参见《H3C S7600系列以太网交换机 安装手册》相关章节。
Copyright © 2009 杭州华三通信技术有限公司
BOM: 3123A161
The silkscreen LSQ1SRP1CB3 is printed at the upper left corner of the front panel, and is used to identify the card.
Table1 LSQ1SRP1CB3 specifications
Item |
LSQ1SRP1CB3 |
Connector |
RJ-45 |
External interface |
l One Console port : Support local/remote dialup configuration management of the switch l One 10/100BASE-TX interface for management l One hot-swappable interface for CF card |
Interface transmission speed |
l Console port: £ 115,200 bps (default: 9,600 bps) l 10Base-T/100Base-TX interface: 10/100 Mbps (half/full duplex), MDIX. |
Cable and maximum transmission distance |
l Console port: Ordinary asynchronous serial port cable; maximum transmission distance: 15 m (49 ft). l 10Base-T/100Base-TX interface: Category-5 twisted pair; maximum transmission distance: 100 m (328 ft). |
Applied to |
S7603/S7606/S7606-V/S7610 Ethernet switches |
Host software version |
Release 6600 and later of the Release 6000 series |
If the host software version does not match the one applicable to the card, contact the vendor or the integrator for the right version.
For the introduction of card installation and host software upgrade, see the related part in H3C S7600 Series Ethernet Switches Installation Manual.
Copyright © 2009 Hangzhou H3C Technologies Co., Ltd.
