H3C SecPath W2000-EX0-G Series Web Application Firewall Installation Guide-5W100
HomeSupportSecurityH3C SecPath W2000H3C SecPath W2000Technical DocumentsInstall & UpgradeInstallation GuidesH3C SecPath W2000-EX0-G Series Web Application Firewall Installation Guide-5W100
03-Appendix B Introduction to Indicator Lights
03-Appendix B Introduction to Indicator Lights 82.06 KB
附录B  Indicator light introduction
B.1  Front panel indicators
1-1 Front panel indicator instructions
Light
Panel silk screen
state
illustrate
Power indicator
PWR
Green is solid
The power supply is normal
The lights went out
The power supply is not powered on or malfunctions
Hard drive status indicator
HDD
Orange-yellow flashing
Data is being transferred
The lights went out
The system is not running/there is no hard disk read and write operation/the hard disk is abnormal
B.2  Interface indicator
2-1 Ethernet port indicator lights explained
Light
state
illustrate
ACT/LINK indicator (left side of the interface)
Orange is solid
It means that the interface connection is normal, but there is no data transmission
Orange flashes
This indicates that the interface is connected normally and data transmission is underway
Speed indicator (right side of the interface)
Orange is solid
It means that the working rate of the interface is 1000M
Green is solid
It means that the interface working rate is 100M/10M
The lights went out
The interface connection is not normal
Note that both the ACT/LINK indicator and the Speed indicator are off, indicating that the link is not connected
