| 02-Appendix A Equipment Appearance and Hardware Specifications | 375.89 KB |
A Equipment appearance and hardware specifications
A.1.1 H3C SecPath W2000-E20-G/W2000-E40-G
A.3 Form factor and weight specifications
A.5 Device power consumption specifications
A.6 Power module specifications
A.7.2 Gigabit Ethernet optical port
A.7.3 Gigabit Ethernet optical port
A.1 Device appearance
The H3C SecPath W2000-E20-G/W2000-E40-G has 4 interface module slots, 8 10/100/1000BASE-T adaptive Ethernet electrical ports (including 1 Ethernet management port), 4 1000BASE-X Ethernet optical ports, 2 USB ports, and 1 Console port , 1 hard disk expansion slot. The specific structure is shown in the figure below.
A-1 H3C SecPath W2000-E20-G/W2000-E40-G Front view of the device
1: CONSOLE |
2: CONSOLE 10/100/1000BASE-T Ethernet electrical port, 0 is the Ethernet management interface |
3: Hard drive expansion slot |
4: 1000BASE-X Ethernet optical port |
5: Interface module slot |
6: 10/100/1000BASE-T Ethernet electrical port, 0 is the Ethernet management interface |
7: USB port |
8: Device indicator |
A-2 H3C SecPath W2000-E20-G/W2000-E40-G Rear View of the device
1: Hard disk expansion slot |
2: a fan |
3: Device power switch |
4: Power Module |
A.1.2 H3C SecPath W2000-E80-G
The H3C SecPath W2000-E80-G has 8 interface module slots, 2 Ethernet management ports, 2 USB ports, and 1 Console port on the front panel. The specific structure is shown in the figure below.
A-3 H3C SecPath W2000-E80-G Device Front View
1: CONSOLE |
7: USB port |
A-4 H3C SecPath W2000-E80-G Rear View of the Device
2: a fan |
4: Power Module |
A.2 Interface module
Attention
The interface module does not support hot-swapping, if you need to replace the interface module, please turn off the power supply of the device before replacing it.
A-1 H3C SecPath W2000-EX0-G Series Product Interface Module List
Interface module model |
specification |
Adapt to the equipment model |
NSQM1IPCGT4GP4A3 |
4-port Ethernet Gigabit electrical port card + 4-port Ethernet Gigabit optical port card |
H3C SecPath W2000-E80-G |
NSQM1IPCPFCGT4GP4A3 |
4-port Ethernet Gigabit adapter (including 2 pairs of bypass interfaces) + 4-port Ethernet Gigabit optical port card |
NSQM1IPCTG4A3 |
4-port Ethernet 100 Gigabit optical port card |
A-2 Dimensions and weight specifications
project |
Dimensions (W×D×H) (without foot pads and lugs) |
Weight (net) |
H3C SecPath W2000-E20-G |
600mmx440mmx89mm |
15.18Kg |
H3C SecPath W2000-E40-G |
600mmx440mmx89mm |
15.18Kg |
600mmx440mmx89mm |
15.76Kg |
A.4 Memory specifications
A-3 Memory specifications
project |
illustrate |
Memory type and capacity |
· W2000-E20-G:16GB DDR4 · W2000-E40-G:32GB DDR4 · W2000-E80-G:64GB DDR5 |
Hard disk storage |
· W2000-E20-G: Built-in 4TB, supports expansion of 3 SATA hard drives · W2000-E40-G: Built-in 4TB, supports expansion of 3 SATA hard drives · W2000-E80-G: Built-in 4TB, supports expansion of 2 SATA hard drives |
A-4 Power consumption specifications
project |
Maximum power consumption |
170W |
170W |
300W |
A-5 AC power module specifications are standard
project |
illustrate |
Rated input voltage |
100V AC~240V AC; 50/60Hz |
Maximum input current |
5A |
Maximum power supply |
350W |
H3C SecPath W2000-E20-G/W2000-E40-G/W2000-E80-G |
A-6 Optional GW-CRPSD800-DC DC power module specifications
project |
illustrate |
Model |
GW-CRPSD800-DC |
180V DC~310V DC |
3A |
800W |
A.7 Interface specifications
A.7.1 Gigabit Ethernet port
A-7 Gigabit Ethernet electrical port attributes
attribute |
description |
Connector type |
RJ45 |
interface standard |
802.3, 802.3u, and 802.3ab |
Interface type |
MDI/MDIX adaptive |
Cable type |
Class 5 or more twisted pairs |
Transmission distance |
100m |
Support rates and working methods |
10Mbps adaptive |
Half/full-duplex auto-negotiation |
100Mbps adaptive |
1000Mbps adaptive |
Full-duplex automatic negotiation |
Instructions
MDI (Media Dependent Interface) is the abbreviation of Ethernet's media-related interface, and the Ethernet interface on the general network card is mostly of this type. The other is a crossed media-related interface, abbreviated as MDIX, which is commonly used in HUB or LAN Switch.
A-8 Gigabit Ethernet optical port attributes
attribute |
description |
Connector type |
LC |
Interface Optical Transceiver Type |
SFP |
1000BASE-X |
speed |
1000Mbps |
How it works |
Full duplex mode |
A-9 Description of the 1000BASE-X SFP Optical Interface Module
External models |
Center Wavelength (nm) |
Fiber Mode |
Fiber diameter (μm). |
Mode bandwidth (MHz*km). |
Interface metrics (dBm). |
Output optical power |
Receive optical power |
SFP-GE-SX-MM850-A |
850 |
MMF |
50/125 |
500 |
550m |
-9.5~0 |
-17~-3 |
400 |
500m |
62.5/125 |
200 |
275m |
160 |
220m |
160 |
220m |
SFP-GE-LX-SM1310-A |
1310 |
SMF |
9/125 |
10km |
-9.5~-3 |
-20~-3 |
MMF |
50/125 |
500/400 |
550m |
62.5/125 |
500 |
550m |
A-10 Gigabit Ethernet interface attributes
attribute |
description |
Connector type |
LC |
SFP+ |
10GBASE-R |
speed |
LAN PHY mode: 10Gbps |
A-11 Description of SFP+ Optical Interface Module (with LC connector)
External models |
Center wavelength (nm). |
Fiber Mode |
Transfer rate |
SFP-XG-SX-MM850-A |
850 |
MMF |
50/125 |
2000 |
300m |
10.31Gbps |
-7.3~-1 |
-9.9~+0.5 |
500 |
82m |
400 |
66m |
62.5/125 |
200 |
33m |
160 |
26m |
160 |
8m |
SFP-XG-LX220-MM1310 |
1310 |
MMF |
50/125 |
1500 |
220m |
10.31Gbps |
-6.5~+0.5 |
-6.5~+1.5 |
500 |
220m |
400 |
100m |
62.5/125 |
200 |
220m |
160 |
220m |
SFP-XG-LX-SM1310 |
1310 |
SMF |
9/125 |
10km |
10.31Gbps |
-8.2~+0.5 |
-14.4~+0.5 |
