| 02-Appendix A Device Appearance and Hardware(HW) Specifications | 385.13 KB |
Appendix A Chassis views and technical specifications
Product view
H3C SecPath AFC2000-E10-G
On the faceplate of the H3C SecPath AFC2000-E10-G there are 4 interface module slots, 8 10/100/1000BASE-T autosensing Ethernet copper ports (including 1 Ethernet management port), 4 1000BASE-X Ethernet fiber ports, 2 USB ports, 1 Console port, and 1 drive expansion slot. The specific layout is shown in the following figure.
FigureA-1 H3C SecPath AFC2000-E10-G device front view
1: LED display |
2: Console port (CONSOLE) |
3: Drive expansion slot |
4: 1000BASE-X Ethernet optical port |
5: Interface module slot |
6: 10/100/1000BASE-T Ethernet copper ports; 0 is the Ethernet management interface |
7: USB port |
8: Device indication light |
FigureA-2 H3C SecPath AFC2000-E10-G device rear view
1: drive expansion slot |
2: fan |
3: device power switch |
4: power supply |
H3C SecPath AFC2000-E40-G
On the faceplate of the H3C SecPath AFC2000-E40-G there are 8 interface module slots, 2 Ethernet management ports, 2 USB ports, and 1 Console port. The specific layout is shown in the following figure.
FigureA-3 H3C SecPath AFC2000-E40-G device front view
1: Console port (CONSOLE) |
2: LED display |
3: Interface module slot |
4: Ethernet management interface |
5: USB port |
6: Device indication lights |
FigureA-4 H3C SecPath AFC2000-E40-G device rear view
1: Drive expansion slot |
2: Fan |
3: Device power switch |
4: Power supply |
Interface modules
The interface modules do not support hot swapping. If you need to replace an interface module, first power off the device, then perform the replacement.
TableA-1 Interface module list for H3C SecPath AFC2000-EX0-G series products
Interface module model |
Specifications |
Compatible device models |
NSQM1IPCGT4GP4A3 |
4-port Ethernet Giga copper port card + 4-port Ethernet Giga fiber port card |
H3C SecPath AFC2000-E40-G |
NSQM1IPCTG4A3 |
4-port Ethernet 10G fiber port card |
Dimensions and Weight Specifications
TableA-2 Dimensions and Weight Specifications
Item |
Dimensions (H × W × D), excluding rubber feet and mounting brackets |
Weight (net) |
H3C SecPath AFC2000-E10-G |
600mmx440mmx89mm |
15.18Kg |
600mmx440mmx89mm |
15.76Kg |
Storage media
TableA-3 Storage media
Item |
Memory type and capacity |
· AFC2000-E10-G:32GB DDR4 · AFC2000-E40-G:64GB DDR5 |
drive storage |
4TB |
Power consumption
TableA-4 Chassis power consumption
Item |
Maximum power consumption |
170W |
300W |
Power supply specifications
TableA-5 Standard AC power supply specifications
Item |
Rated input voltage |
100V AC~240V AC;50/60Hz |
Max input current |
5A |
Max power |
350W |
H3C SecPath AFC2000-E10-G/AFC2000-E40-G |
TableA-6 Optional GW-CRPSD800-DC direct current (DC) power supply specifications
Item |
Model. |
GW-CRPSD800-DC |
180V DC~310V DC |
Max input current |
3A |
Max power |
800W |
Port specifications
GE copper port
TableA-7 GE copper port specifications
Attribute |
Connector type |
RJ45 |
Compliant standard |
802.3, 802.3u, and 802.3ab |
Interface type |
MDI/MDI-X autosensing |
Cable type |
Category 5 or above twisted pair cable |
Transmission distance. |
100m |
Port speed and duplex mode |
10 Mbps, autosensing |
Half/full duplex, auto-negotiation |
100 Mbps, autosensing |
1000 Mbps, autosensing |
Full duplex, auto-negotiation |
The media dependent interface (MDI) standard is typically used on the Ethernet port of network adapters. The media dependent interface crossover (MDI-X) standard is typically used on hubs or LAN switches.
GE fiber port
TableA-8 GE fiber port specifications
Attribute |
Connector type |
LC |
Transceiver module type |
SFP |
1000BASE-X |
Speed |
1000Mbps |
Operating mode |
Full duplex |
TableA-9 GE SFP transceiver modules available for the 1000BASE-X SFP ports
Cable model |
Center wavelength (nm) |
Fiber Mode |
Fiber diameter (µm) |
Mode bandwidth (MHz*km) |
Port specifications (dBm) |
Tx optical power |
Receive power |
SFP-GE-SX-MM850-A |
850 |
MMF |
50/125 |
500 |
550m |
-9.5~0 |
-17~-3 |
400 |
500m |
62.5/125 |
200 |
275m |
160 |
220m |
160 |
220m |
SFP-GE-LX-SM1310-A |
1310 |
SMF |
9/125 |
10km |
-9.5~-3 |
-20~-3 |
MMF |
50/125 |
500/400 |
550m |
62.5/125 |
500 |
550m |
10 GE fiber port
TableA-10 10 GE fiber port specifications
Attribute |
Connector type |
LC |
SFP+ |
10GBASE-R |
Speed |
LAN PHY mode: 10Gbps |
TableA-11 Specifications of 10GE SFP+ optical transceiver modules with LC connectors
Cable model |
Fiber Mode |
Transmission rate |
Tx optical power |
Receive power |
SFP-XG-SX-MM850-A |
850 |
MMF |
50/125 |
2000 |
300m |
10.31Gbps |
-7.3~-1 |
-9.9~+0.5 |
500 |
82m |
400 |
66m |
62.5/125 |
200 |
33m |
160 |
26m |
160 |
8m |
SFP-XG-LX220-MM1310 |
1310 |
MMF |
50/125 |
1500 |
220m |
10.31Gbps |
-6.5~+0.5 |
-6.5~+1.5 |
500 |
220m |
400 |
100m |
62.5/125 |
200 |
220m |
160 |
220m |
SFP-XG-LX-SM1310 |
1310 |
SMF |
9/125 |
10km |
10.31Gbps |
-8.2~+0.5 |
-14.4~+0.5 |
