H3C SecPath AFC2000-EX0-G Series Abnormal Traffic Cleaning System Installation Guide-5W100
HomeSupportSecurityH3C SecPath AFC2000H3C SecPath AFC2000Technical DocumentsInstall & UpgradeInstallation GuidesH3C SecPath AFC2000-EX0-G Series Abnormal Traffic Cleaning System Installation Guide-5W100
00-Preface
00-Preface 132.72 KB
Preface
This configuration guide describes the installation steps.
·     Audience
·     Conventions
·     Documentation feedback
Audience
·     Network planners.
·     Network operators, administrators, and maintainers.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Text in square brackets [ ] denotes window names, menu names, and data tables, e.g., "open the [New User] window".
Use "/" to separate levels in multi-level menus. For example, the multi-level menu [File/New/Folder] denotes the [Folder] menu item under the [New] submenu of the [File] menu.
Symbols
This documentation uses the following symbols to highlight information that requires different levels of attention:
Network topology icons
The icons used in this book and their meanings are as follows:
This icon and its related description represent a router in the general sense, as well as other devices running routing protocols.
Represents an access point.
Configuration examples provided in this documentation are for illustration only. They might differ depending on the hardware model, software version, and configuration. Examples in this document might use devices that differ from your device in hardware model, configuration, or software version.
The port numbers shown in this manual are for illustration only and do not imply that the device actually has ports with those numbers. In actual use, refer to the port numbers on the device.
You can e-mail your comments about product documentation to
E-mail: [email protected]
We appreciate your comments.
