- 14-Layer 3—IP Services Command Reference
- 01-IP forwarding basics commands
- 02-IPv6 fast forwarding commands
- 03-DHCPv6 commands
- 04-Multi-CPU packet distribution commands
- 05-Adjacency table commands
- 06-Web caching commands
- 07-DNS commands
- 08-Fast forwarding commands
- 09-ARP commands
- 10-DHCP commands
- 11-IPv6 basics commands
- 12-IP addressing commands
- 13-IP performance optimization commands
| 08-Fast forwarding commands | 169.72 KB |
display hardware fast-forwarding packet statistics
display hardware fast-forwarding session statistics
display ip fast-forwarding aging-time
display ip fast-forwarding cache
display ip fast-forwarding fragcache
hardware fast-forwarding checksum encap incremental
hardware fast-forwarding checksum inspect action
hardware fast-forwarding checksum inspect enable
hardware fast-forwarding enable
hardware fast-forwarding link-aggregation hash-mode crc
hardware fast-forwarding link-aggregation hash-mode crc ip-offset
hardware fast-forwarding malpkt-filter enable
hardware fast-forwarding standalone
hardware fast-forwarding statistics enable
ip fast-forwarding load-sharing
reset ip fast-forwarding cache
Non-default vSystems do not support some of the fast forwarding commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
Use display hardware fast-forwarding packet statistics to display packet rate statistics for fast-forwarding engines.
display hardware fast-forwarding packet statistics [ slot slot-number cpu cpu-number ]
The following compatibility matrix shows the support of hardware platforms for this command:
Series |
Models |
Command compatibility |
F5000 series |
F5000-AI160, F5000-CN160, F5000-AI-160-G, F5000-AI-130-G, F5000-AI-110-G, F5000-CN160-G, F5000-E-G |
Yes |
F5080, F5030, F5000-CN-G55, F5000-AI-55-G, F5000-AI-15-G, F5000-AI-120-G |
No |
F1000 series |
F1000-AK9130, F1000-AI-90, F1000-AI-25, F1000-AI-90-G, F1000-AI-80-G, F1000-AI-75-G, F1000-AI-65-G, F1000-AI-55-G |
No |
context-admin
slot slot-number: Specifies a card by its slot number. If you specify a card, this command displays packet rate statistics for fast-forwarding engines on the specified card. If you do not specify a card, this command displays packet rate statistics for fast-forwarding engines on each card.
cpu cpu-number: Specifies a CPU by its number. This option is available only if multiple CPUs are available on the specified slot.
This command is supported only by Blade IV security modules installed with fast-forwarding engines. It displays the following information for a fast-forwarding engine:
· Packet transmission rate and packet reception rate of the fast-forwarding engine.
· Rate of transmitting packets to the other fast-forwarding engine on the same card.
· Rate of receiving packets from the other fast-forwarding engine on the same card.
· Rate of transmitting packets to the CPU.
· Rate of receiving packets from the CPU.
# Display packet rate statistics for fast-forwarding engines on each card.
<Sysname> display hardware fast-forwarding packet statistics
The unit of measure for the following rates is packets per second (pps).
Slot Ch. Input Output From ch. To ch. From CPU To CPU
2/0/1 0 14881000 14881000 14881000 14881000 4881000 14881000
3/0/1 0 14881000 14881000 14881000 14881000 4881000 14881000
Slot |
Number of the slot on which the fast-forwarding engine resides. Supported format include: · Slot number/CPU number |
Ch. |
ID of the fast-forwarding engine. Supported values include 0 and 1. |
Input |
Packet reception rate of the fast-forwarding engine, in pps. |
Output |
Packet transmission rate of the fast-forwarding engine, in pps. |
From ch. |
Rate of receiving packets from the other fast-forwarding engine on the same card, in pps. |
To ch. |
Rate of transmitting packets to the other fast-forwarding engine on the same card, in pps. |
From CPU |
Rate of receiving packets from the CPU, in pps. |
To CPU |
Rate of transmitting packets to the CPU, in pps. |
Use display hardware fast-forwarding session statistics to display session statistics for fast-forwarding engines.
NOTE: Support for this command varies by device model. |
display hardware fast-forwarding session statistics [ slot slot-number cpu cpu-number ]
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
No |
context-admin
slot slot-number: Specifies a card by its slot number. If you specify a card, this command displays session statistics for fast-forwarding engines on the specified card. If you do not specify a card, this command displays session statistics for fast-forwarding engines on each card.
· Number of sessions on the fast-forwarding engine.
· Session creation rate of the fast-forwarding engine.
· Session aging rate of the fast-forwarding engine.
# Display session statistics for fast-forwarding engines on each card.
<Sysname> display hardware fast-forwarding session statistic
Slot CPU Ch. Sessions Creating Aging
2/0 1 0 0 0/s 0/s
2/0 1 1 0 0/s 0/s
2/3 1 0 0 0/s 0/s
2/4 1 0 0 0/s 0/s
Slot |
Information about the slot on which the fast-forwarding engine resides. Supported formats include: · Slot number |
CPU |
CPU number. |
Ch |
Sessions |
Number of sessions on the fast-forwarding engine. |
Creating |
Session creation rate of the fast-forwarding engine, which equals the number of sessions created per second. |
Aging |
Session aging rate of the fast-forwarding engine, which equals the number of sessions aged per second. |
Use display ip fast-forwarding aging-time to display the aging time of fast forwarding entries.
context-admin
context-operator
vsys-admin
vsys-operator
# Display the aging time of fast forwarding entries.
<Sysname> display ip fast-forwarding aging-time
Aging time: 30s
Use display ip fast-forwarding cache to display fast forwarding entries.
display ip fast-forwarding cache [ ip-address ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays all fast forwarding entries.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fast forwarding entries for all member devices.
# Display all fast forwarding entries.
<Sysname> display ip fast-forwarding cache
Total number of fast-forwarding entries: 1
SIP SPort DIP DPort Pro Input_If Output_If Flg
7.0.0.13 68 8.0.0.1 67 17 GE1/0/3 GE1/0/1 5
SIP |
Source IP address. |
SPort |
Source port number. |
DIP |
Destination IP address. |
DPort |
Destination port number. |
Pro |
Protocol number. |
Input_If |
Input interface type and number. If no interface is involved in fast forwarding, this field displays N/A. If the input interface does not exist, this field displays a hyphen (-). |
Output_If |
Output interface type and number. If no interface is involved in fast forwarding, this field displays N/A. If the output interface does not exist, this field displays a hyphen (-). |
Flg |
Internal tag, marking internal operation information, such as fragmentation. |
Use display ip fast-forwarding fragcache to display fast forwarding entries for fragmented packets.
display ip fast-forwarding fragcache [ ip-address ] [ slot slot-number ]
context-admin
context-operator
vsys-admin
vsys-operator
ip-address: Specifies an IP address. If you do not specify an IP address, this command displays fast forwarding entries for all fragmented packets.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays fast forwarding entries for fragmented packets on all member devices.
The system creates fast forwarding entries for fragments only when virtual fragment reassembly (VFR) is enabled. If VFR is disabled, this command does not display fast forwarding entries for fragments.
# Display fast forwarding entries about all fragmented packets.
<Sysname> display ip fast-forwarding fragcache
Total number of fragment fast-forwarding entries: 1
SIP SPort DIP DPort Pro Input_If ID Relay_flag
7.0.0.13 68 8.0.0.1 67 17 GE1/0/3 2 1
SIP |
SPort |
DIP |
DPort |
Pro |
Protocol number. |
Input_If |
ID |
Fragment ID. |
Relay_flag |
Fragment pass-through flag: · 0—Not pass through. · 1—Pass through. |
Use hardware fast-forwarding checksum encap incremental to enable the incremental checksum encapsulation for outgoing packets on hardware fast forwarding chips.
Use undo hardware fast-forwarding checksum encap incremental to restore the default.
hardware fast-forwarding checksum encap incremental [ slot slot-number cpu cpu-number ]
undo hardware fast-forwarding checksum encap incremental [ slot slot-number cpu cpu-number ]
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
No |
The incremental checksum is encapsulated into the outgoing packets on hardware fast forwarding chips.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command enables incremental checksum encapsulation for outgoing packets on hardware fast forwarding chips of all cards.
This command takes effect only on service modules that support hardware fast forwarding.
This command is supported only by the default context and is not supported on non-default contexts.
# Enable the incremental checksum encapsulation for outgoing packets on the hardware fast forwarding chip for CPU 1 on the specified slot.
[Sysname] hardware fast-forwarding checksum encap incremental slot 1 cpu 1
Use hardware fast-forwarding checksum inspect action { drop-err | log } to specify an action for a packet alteration event.
Use undo hardware fast-forwarding checksum inspect action { drop-err | log } to cancel the specified action.
hardware fast-forwarding checksum inspect action { drop-err | log } [ slot slot-number cpu cpu-number ]
undo hardware fast-forwarding checksum inspect action { drop-err | log } [ slot slot-number cpu cpu-number ]
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
No |
When the device detects a packet alteration event, it forwards the altered packet and generates a log message.
drop-err: Drops the altered packets.
log: Generates a log message when the device detects a packet alteration event.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command configuration applies to all cards.
If you execute this command multiple times, the specified action in each execution takes effect.
# Disable logging for packet alteration for CPU 1 on the specified slot.
[Sysname] undo hardware fast-forwarding checksum inspect action log slot 1 cpu 1
Use hardware fast-forwarding checksum inspect enable to enable alteration detection for outgoing packets on hardware fast forwarding chips.
Use undo hardware fast-forwarding checksum inspect enable to disable alteration detection for outgoing packets on hardware fast forwarding chips.
hardware fast-forwarding checksum inspect [ l3 | l4 [ tcp | udp ] ] enable [ slot slot-number cpu cpu-number ]
undo hardware fast-forwarding checksum inspect [ l3 | l4 [ tcp | udp ] ] enable [ slot slot-number cpu cpu-number ]
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
No |
Alteration detection is enabled for outgoing packets on hardware fast forwarding chips.
l3: Enables the packet alteration detection on the Layer 3 information.
l4: Enables the packet alteration detection on the Layer 4 information.
tcp: Enables the TCP packet alteration detection.
udp: Enables the UDP packet alteration detection.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, the command enables alteration detection for outgoing packets on hardware fast forwarding chips of all cards.
To enable alteration detection on different types of packets, execute this command multiple times.
To enable TCP or UDP packet alteration detection, specify the l4 keyword before you specify the tcp or udp keyword.
If you do not specify any parameters, the device detects alterations for outgoing packets on both the Layer 3 and Layer 4 information.
If you specify the l4 keyword without specifying the tcp or udp keyword, the device detects alterations for outgoing packets on the Layer 4 information.
# Disable alteration detection on outgoing TCP packets for CPU 1 on slot 1.
[Sysname] undo hardware fast-forwarding checksum inspect l4 tcp enable slot 1 cpu 1
Use hardware fast-forwarding enable to enable hardware fast forwarding.
Use undo hardware fast-forwarding enable to disable hardware fast forwarding.
hardware fast-forwarding enable [ slot slot-number ]
undo hardware fast-forwarding enable [ slot slot-number ]
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
No |
Hardware fast forwarding is enabled.
Non-default vSystems do not support this command.
Hardware fast forwarding stores session information during fast forwarding to speed up subsequent traffic forwarding by comparing the traffic with session information.
Disable hardware fast forwarding when you troubleshoot problems on forwarding chips.
Non-default context does not support this command.
# Disable hardware fast forwarding on slot 1.
[Sysname] undo hardware fast-forwarding enable slot 1
Use hardware fast-forwarding link-aggregation hash-mode crc to use the CRC hash algorithm to select a link aggregation member port as the output interface for outgoing traffic.
Use undo hardware fast-forwarding link-aggregation hash-mode crc to restore the default.
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
No |
The Exclusive-OR algorithm is used for aggregation member port selection.
# Use the CRC hash algorithm to select a link aggregation member port as the output interface for outgoing traffic on slot 3.
[Sysname] hardware fast-forwarding link-aggregation hash-mode crc
Use hardware fast-forwarding link-aggregation hash-mode crc ip-offset to set the IPv6 address offset for CRC calculation to select an aggregation member port as the output interface for outgoing traffic.
Use undo hardware fast-forwarding link-aggregation hash-mode crc ip-offset to restore the default.
hardware fast-forwarding link-aggregation hash-mode crc ip-offset offset-vlaue
undo hardware fast-forwarding link-aggregation hash-mode crc ip-offset [ offset-vlaue ]
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
No |
The IPv6 address offset used in CRC calculation is 0.
offset-vlaue: Set the IPv6 address offset in bits. The value range for this argument is 0 to 31.
If you use the CRC hash algorithm for aggregation member port selection, you can use this command to set a calculation offset for IPv6 addresses to be calculated. CRC takes the bit where the offset-vlaue argument specifies and the following 32 bits for calculation.
# Set the IPv6 address offset used in CRC calculation to 10.
[Sysname] hardware fast-forwarding link-aggregation hash-mode crc ip-offset 10
Use hardware fast-forwarding malpkt-filter enable to enable malformed packet detection.
Use undo hardware fast-forwarding malpkt-filter enable to disable malformed packet detection.
hardware fast-forwarding malpkt-filter enable [ slot slot-number cpu cpu-number ]
undo hardware fast-forwarding malpkt-filter enable [ slot slot-number cpu cpu-number ]
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
No |
Malformed packet detection is enabled.
slot slot-number: Specifies a card by the slot number.
# Enable malformed packet detection on slot 1.
[Sysname] hardware fast-forwarding malpkt-filter enable slot 1
Use ip hardware fast-forwarding standalone to enable single-chip hardware forwarding for upstream packets.
Use undo hardware fast-forwarding standalone to restore the default.
hardware fast-forwarding standalone [ slot slot-number [ cpu cpu-number ] ]
undo hardware fast-forwarding standalone [ slot slot-number [ cpu cpu-number ] ]
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
No |
Dual-chip hardware forwarding is enabled for upstream packets.
This feature applies only to modules that have more than one hardware forwarding chip.
It enables a dual-chip module to forward upstream packets by using only one of the chips. This feature does not apply to downstream packets. The module uses both chips to forward downstream packets.
After you change the hardware forwarding mode for upstream packets, you must restart the module for the change to take effect.
To change the hardware forwarding mode for upstream packets in a security engine group with multiple security engines (multiple modules), perform the following tasks:
1. Execute the hardware fast-forwarding standalone or undo hardware fast-forwarding standalone command on all modules one by one to change their hardware forwarding mode for upstream packets.
2. Restart all modules.
For more information about security engine groups, see context configuration in Virtual Technologies Configuration Guide.
# Enable single-chip hardware forwarding for upstream packets on slot 1.
[Sysname] hardware fast-forwarding standalone slot 1
Use hardware fast-forwarding statistics enable to enable the traffic statistics on hardware fast forwarding.
hardware fast-forwarding statistics enable [ slot slot-number [ cpu cpu-number ]]
undo hardware fast-forwarding statistics enable [ slot slot-number [ cpu cpu-number ]]
Series |
Models |
F5000 series |
Yes |
No |
F1000 series |
No |
The traffic statistics on hardware fast forwarding is disabled.
slot slot-number: Specifies a card by the slot number. If you do not specify a card, this command enables traffic statistics on hardware fast forwarding for all cards.
This feature is applicable only to security service modules with hardware fast forwarding chips.
With this feature enabled, you can use the display interface blade or display interface blade-aggregation command to view the statistics of all traffic forwarded by software or hardware fast forwarding on the corresponding Blade interface. With this feature disabled, you can use the commands to view only statistics of traffic forwarded by software fast forwarding.
This command is supported only by the default context and not supported by non-default contexts.
# Enable traffic statistics on hardware fast forwarding on the specified CPU and the specified slot.
[Sysname] hardware fast-forwarding statistics enable slot 3 cpu 1
display interface (Layer 2—LAN Switching Command References)
display interface blade (Interface Command References)
Use ip fast-forwarding aging-time to configure the aging time for fast forwarding entries.
Use undo ip fast-forwarding aging-time to restore the default.
ip fast-forwarding aging-time aging-time
The aging time is 30 seconds.
context-admin
vsys-admin
aging-time: Specifies the aging time in the range of 10 to 300 seconds.
# Set the aging time to 20 seconds for fast forwarding entries.
[Sysname] ip fast-forwarding aging-time 20
ip fast-forwarding dscp
Use ip fast-forwarding dscp to enable DSCP-based fast forwarding for GRE and VXLAN packets.
Use undo ip fast-forwarding dscp to restore the default.
DSCP-based fast forwarding for GRE and VXLAN packets is disabled.
context-admin
vsys-admin
This command is applicable to GRE packets (with IP as the passenger protocol) and VXLAN packets that are processed by software.
This feature uses the DSCP value in the outer header instead of the source port number among the identification criteria to identify GRE and VXLAN traffic flows.
This command is mutually exclusive with NAT and load balancing.
# Enable DSCP-based GRE and VXLAN packet fast forwarding.
[Sysname] ip fast-forwarding dscp
Use ip fast-forwarding load-sharing to enable fast forwarding load sharing.
Use undo ip fast-forwarding load-sharing to disable fast forwarding load sharing.
Fast forwarding load sharing is enabled.
context-admin
vsys-admin
Fast forwarding load sharing enables the device to load share packets of the same flow. This feature identifies a data flow by using the packet information.
If fast forwarding load sharing is disabled, the device identifies a data flow by the packet information and the input interface. No load sharing is implemented.
# Enable fast forwarding load sharing.
<Sysname> system-Views
[Sysname] ip fast-forwarding load-sharing
ip fast-forwarding vxlan-port
Use ip fast-forwarding vxlan-port to specify the destination UDP port number for identifying VXLAN packets.
Use undo ip fast-forwarding vxlan-port to restore the default.
ip fast-forwarding vxlan-port port-number
The destination UDP port number is 4789.
Predefined use roles
context-admin
vsys-admin
port-number: Specifies a UDP port number in the range of 1 to 65535.
This feature is applicable to only the UDP packets that are processed by software.
In a VXLAN network, configure this command on intermediate devices to identify VXLAN packets.
# Specify the destination UDP port number to 4900 for identifying VXLAN packets.
[Sysname] ip fast-forwarding vxlan-port 4900
Use reset ip fast-forwarding cache to clear the fast forwarding table.
reset ip fast-forwarding cache [ slot slot-number ]
context-admin
vsys-admin
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command clears the fast forwarding table for all member devices.
# Clear the fast forwarding table.
<Sysname> reset ip fast-forwarding cache
