- 14-Layer 3—IP Services Command Reference
- 01-IP forwarding basics commands
- 02-IPv6 fast forwarding commands
- 03-DHCPv6 commands
- 04-Multi-CPU packet distribution commands
- 05-Adjacency table commands
- 06-Web caching commands
- 07-DNS commands
- 08-Fast forwarding commands
- 09-ARP commands
- 10-DHCP commands
- 11-IPv6 basics commands
- 12-IP addressing commands
- 13-IP performance optimization commands
| 01-IP forwarding basics commands | 85.70 KB |
Basic IP forwarding commands
Non-default vSystems do not support some of the basic IP forwarding commands. For information about vSystem support for a command, see the usage guidelines on that command. For information about vSystem, see Virtual Technologies Configuration Guide.
display fib
Use display fib to display FIB entries.
display fib [ vpn-instance vpn-instance-name ] [ ip-address [ mask | mask-length ] ]
context-admin
context-operator
vsys-admin
vsys-operator
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. To display the FIB entries for the public network, do not specify any VPN instance.
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address. The value range is 0 to 32.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display all FIB entries of the public network.
<Sysname> display fib
Route destination count: 5
Directly-connected host count: 0
Flag:
U:Useable G:Gateway H:Host B:Blackhole D:Dynamic S:Static
R:Relay F:FRR
Destination/Mask Nexthop Flag OutInterface/Token Label
0.0.0.0/32 127.0.0.1 UH InLoop0 Null
192.168.100.0/24 192.168.100.96 U GE1/0/0 Null
127.0.0.0/8 127.0.0.1 U InLoop0 Null
127.0.0.0/32 127.0.0.1 UH InLoop0 Null
127.0.0.1/32 127.0.0.1 UH InLoop0 Null
# Display the FIB entries for VPN vpn1.
<Sysname> display fib vpn-instance vpn1
Route destination count: 6
Flag:
R:Relay F:FRR
20.20.20.0/24 20.20.20.25 U GE1/0/0 Null
20.20.20.0/32 20.20.20.25 UBH GE1/0/0 Null
20.20.20.25/32 127.0.0.1 UH InLoop0 Null
20.20.20.25/32 20.20.20.25 H GE1/0/0 Null
20.20.20.255/32 20.20.20.25 UBH GE1/0/0 Null
# Display the FIB entries matching the destination IP address 10.2.1.1.
<Sysname> display fib 10.2.1.1
Route destination count: 1
Directly-connected host count: 1
Flag:
R:Relay F:FRR
10.2.1.1/32 127.0.0.1 UH InLoop0 Null
Route destination count |
Total number of route destination addresses. |
Directly-connected host count |
Number of directly-connected hosts that are learned through features such as ARP. |
Destination/Mask |
Destination address and the mask length. |
Nexthop |
Next hop address. |
Flag |
Flags of routes: · U—Usable route. · G—Gateway route. · H—Host route. · B—Blackhole route. · D—Dynamic route. · S—Static route. · R—Relay route. · F—Fast reroute. |
OutInterface/Token |
Output interface/LSP index number. |
Label |
Inner label. |
inner-interface learn arp-nd
Use inner-interface learn arp-nd to enable ARP and ND entry learning on inner interfaces.
Use undo inner-interface learn arp-nd to disable ARP and ND entry learning on inner interfaces.
inner-interface learn arp-nd vlan vlan-id
ARP and ND entry learning is disabled on inner interfaces.
context-admin
vlan vlan-id: Specifies a VLAN by its ID in the range of 2 to 4094. The specified VLAN must be a VLAN terminated on an inner subinterface and cannot be the default VLAN ID of the peer inner interface.
You must enable this feature if NetStream statistics are sent out by inner interfaces[zn3]. Otherwise, inner interfaces cannot learn ARP or ND entries and fail to transmit NetStream statistics.
This command is supported only on the default context.
# Enable inner interfaces to learn ARP and ND entries in VLAN 200.
[Sysname] inner-interface learn arp-nd vlan 200
ip last-hop hold
Use ip last-hop hold to enable last hop holding.
Use undo ip last-hop hold to disable last hop holding.
ip last-hop hold
Last hop holding is disabled.
context-admin
vsys-admin
IPv4 last hop holding implements symmetric routing.
When the interface enabled with this feature receives the first IP packet of a forward flow, this feature implements the following operations:
· Obtains the forward flow information and last hop information of the packet.
· Based on the obtained information, creates a fast forwarding entry for the reverse flow.
When packets of the reverse flow arrive at the device, the device forwards those packets according to the fast forwarding entry.
You can configure IPv4 last hop holding globally by using the ip global last-hop hold command or on a per-interface basis by using the ip last-hop hold command. This feature takes effect on an interface as long as it is enabled globally or on that interface. To disable this feature on an interface, perform the following operations:
· Disable IPv4 last hop holding globally by using the undo ip global last-hop hold command.
· Disable IPv4 last hop holding on the interface by using the undo ip last-hop hold command.
Last hop holding relies on fast forwarding entries. If the MAC address of a last hop changes on an Ethernet link, this feature can function correctly only after the fast forwarding entry is updated for the MAC address.
# Enable the last hop holding feature.
[Sysname-GigabitEthernet1/0/1] ip last-hop hold
last-hop backup enable
Use last-hop backup enable to enable last hop backup.
Use undo last-hop backup enable to disable last hop backup.
Last hop backup is enabled.
context-admin
vsys-admin
This feature enables the system to transmit the forward flow and reverse flow between the local device and a peer device over the same path.
In an IRF fabric enabled with this feature, the IRF master device performs the following operations when receiving the first IP packet of a forward flow on an interface enabled with last hop holding:
1. Saves the last hop information of the packet.
2. Synchronizes the last hop information to subordinate devices in the IRF fabric.
The last hop information can be used for guiding the reverse flow when the flow arrives at the master device or is forwarded through a subordinate device.
For this feature to takes effect, you must also enable last hop holding on the master device in the IRF fabric.
This command takes effect only when the session synchronization is enabled by using the session synchronization enable command. For more information about the session synchronization enable command, see Security Command Reference.
This feature is also applicable to multi-module devices enabled with service backup. If this feature is enabled on such a device, a device module performs the following operations when receiving the first IP packet of a forward flow on an interface enabled with last hop holding:
3. Saves the last hop information of the packet.
4. Synchronizes the last hop information to other modules in the device.
The last hop information can be used for guiding the backward flow when the flow arrives at one of these modules.
For this feature to take effect on a multi-module device, you must also enable session flow redirection by using the session flow-redirect enable command. For more information about the session flow-redirect enable command, see Security Command Reference.
# Disable last hop backup.
[Sysname] undo ip last-hop backup enable
ip last-hop hold
session synchronization enable (Security Command Reference)
session flow-redirect enable (Security Command Reference)
Load sharing commands
ip load-sharing local-first enable
Use ip load-sharing local-first enable to enable local-first load sharing.
Use undo ip load-sharing local-first enable to disable local-first load sharing.
Local-first load sharing is disabled.
context-admin
vsys-admin
Local-first load sharing takes effect only on an IRF fabric.
# Enable local-first load sharing.
[Sysname] ip load-sharing local-first enable
ip load-sharing mode
Use ip load-sharing mode to configure the load sharing mode.
Use undo ip load-sharing mode to restore the default.
ip load-sharing mode { per-flow [ [ dest-ip | dest-port | ip-pro | src-ip | src-port ] * ] | per-packet } { global | slot slot-number }
undo ip load-sharing mode { global | slot slot-number }
The device performs per-flow load sharing.
context-admin
vsys-admin
per-flow: Implements per-flow load sharing.
dest-ip: Identifies flows by destination IP address.
dest-port: Identifies flows by destination port.
ip-pro: Identifies flows by protocol number.
src-ip: Identifies flows by source IP address.
src-port: Identifies flows by source port.
global: Configures the load sharing mode globally.
per-packet: Implements per-packet load sharing.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command configures the load sharing mode for all member devices.
The per-packet load sharing mode does not take effect in fast forwarding.
# Configure per-flow load sharing for slot 1.
[Sysname] ip load-sharing mode per-flow slot 1
