- 12-Security Configuration Guide
- 01-DAE proxy configuration
- 02-Password control configuration
- 03-Keychain configuration
- 04-Public key management
- 05-PKI configuration
- 06-IPsec configuration
- 07-SSH configuration
- 08-SSL configuration
- 09-Session management
- 10-Object group configuration
- 11-Attack detection and prevention configuration
- 12-IP-based attack prevention configuration
- 13-IP source guard configuration
- 14-ARP attack protection configuration
- 15-ND attack defense configuration
- 16-uRPF configuration
- 17-SAVA configuration
- 18-Crypto engine configuration
- 19-Trust level configuration
- 20-SAVNET configuration
- 21-CSG configuration
| 07-SSH configuration | 788.25 KB |
Configuring the device as an SSH server
Specifying the SSH service port
Configuring the user lines for SSH login
Configuring a client's host public key
Configuring the SSH management parameters
Specifying a PKI domain for the SSH server
Enabling the whitelist service for SSH
Configuring the device as an Stelnet client
Stelnet client tasks at a glance
Specifying the source IP address for SSH packets
Establishing a connection to an Stelnet server
Configuring the device as an SFTP client
Specifying the source IP address for SFTP packets
Establishing a connection to an SFTP server
Terminating the connection with the SFTP server
Configuring the device as an SCP client
Establishing a connection to an SCP server
Specifying algorithms for SSH2
Specifying key exchange algorithms for SSH2
Specifying public key algorithms for SSH2
Specifying encryption algorithms for SSH2
Specifying MAC algorithms for SSH2
Display and maintenance commands for SSH
Stelnet configuration examples
Example: Configuring the device as an Stelnet server (password authentication)
Example: Configuring the device as an Stelnet server (publickey authentication)
Example: Configuring the device as an Stelnet client (password authentication)
Example: Configuring the device as an Stelnet client (publickey authentication)
Example: Configuring Stelnet based on 128-bit Suite B algorithms
Example: Configuring the device as an SFTP server (password authentication)
Example: Configuring the device as an SFTP client (publickey authentication)
Example: Configuring SFTP based on 192-bit Suite B algorithms
Example: Configuring SCP with password authentication
Example: Configuring SCP file transfer with a Linux SCP client
Example: Configuring SCP based on Suite B algorithms
NETCONF over SSH configuration examples
Example: Configuring NETCONF over SSH with password authentication
Configuring SSH
About SSH
Secure Shell (SSH) is a network security protocol. Using encryption and authentication, SSH can implement secure remote access and file transfer over an insecure network.
SSH uses the typical client-server model to establish a channel for secure data transfer based on TCP.
SSH includes two versions: SSH1.x and SSH2.0 (hereinafter referred to as SSH1 and SSH2), which are not compatible. SSH2 is better than SSH1 in performance and security.
SSH applications
The device supports the following SSH applications:
· Secure Telnet—Stelnet provides secure and reliable network terminal access services. Through Stelnet, a user can securely log in to a remote server. Stelnet can protect devices against attacks, such as IP spoofing and plain text password interception. The device can act as an Stelnet server or an Stelnet client.
· Secure File Transfer Protocol—Based on SSH2, SFTP uses SSH connections to provide secure file transfer. The device can act as an SFTP server, allowing a remote user to log in to the SFTP server for secure file management and transfer. The device can also act as an SFTP client, enabling a user to log in from the device to a remote device for secure file transfer.
· Secure Copy—Based on SSH2, SCP offers a secure method to copy files. The device can act as an SCP server, allowing a user to log in to the device for file upload and download. The device can also act as an SCP client, enabling a user to log in from the device to a remote device for secure file transfer.
· NETCONF over SSH—Based on SSH2, it enables users to securely log in to the device through SSH and perform NETCONF operations on the device through the NETCONF-over-SSH connections. The device can act only as a NETCONF-over-SSH server. For more information about NETCONF, see Network Management and Monitoring Configuration Guide.
When acting as an SSH client or server, the device supports the following SSH versions:
· When acting as an SSH client, the device supports only SSH2.
· When acting as an Stelnet server, the device supports both SSH2 and SSH1.
· When acting as an SFTP, SCP, or NETCONF-over-SSH server, the device supports only SSH2.
How SSH works
This section uses SSH2 as an example to describe the stages to establish an SSH session.
Table 1 Stages to establish an SSH session
Stages |
Connection establishment |
The SSH server listens to connection requests on port 22. After a client initiates a connection request, the server and the client establish a TCP connection. |
Version negotiation |
The two parties determine a version to use. |
Algorithm negotiation |
SSH supports multiple algorithms. Based on the local algorithms, the two parties negotiate the following algorithms: · Key exchange algorithm for generating session keys. · Encryption algorithm for encrypting data. · Public key algorithm for the digital signature and authentication. · HMAC algorithm for protecting data integrity. |
Key exchange |
The two parties use the DH exchange algorithm to dynamically generate the session keys and session ID. · The session keys are used for protecting data transfer. · The session ID is used for identifying the SSH connection. In this stage, the client also authenticates the server. |
Authentication |
The SSH server authenticates the client in response to the client's authentication request. |
Session request |
After passing the authentication, the client sends a session request to the server to request the establishment of a session (or request the Stelnet, SFTP, SCP, or NETCONF service). |
Interaction |
After the server grants the request, the client and the server start to communicate with each other in the session. In this stage, you can paste commands in text format and execute them at the CLI. The text pasted at one time must be no more than 2000 bytes. As a best practice to ensure the correct execution of commands, paste commands that are in the same view. To execute commands of more than 2000 bytes, save the commands in a configuration file, upload the file to the server through SFTP, and use it to restart the server. |
SSH authentication methods
This section describes authentication methods that are supported by the device when it acts as an SSH server.
Password authentication
The SSH server authenticates a client through the AAA mechanism. The password authentication process is as follows:
1. The client sends the server an authentication request that includes the encrypted username and password.
2. The server performs the following operations:
a. Decrypts the request to get the username and password in plain text.
b. Verifies the username and password locally or through remote AAA authentication.
c. Informs the client of the authentication result.
If the remote AAA server requires the user to enter a password for secondary authentication, it send the SSH server an authentication response carrying a prompt. The prompt is transparently transmitted to the client to notify the user to enter a specific password. When the user enters the correct password, the AAA sever examines the password validity. If the password is valid, the SSH server returns an authentication success message to the client.
SSH1 clients do not support secondary password authentication initiated by the AAA server.
For more information about AAA, see BRAS Service Configuration Guide.
Publickey authentication
The server authenticates a client by verifying the digital signature of the client. The publickey authentication process is as follows:
1. The client sends the server a publickey authentication request that includes the username, public key, and public key algorithm name.
If the digital certificate of the client is required in authentication, the client also encapsulates the digital certificate in the authentication request. The digital certificate carries the public key information of the client.
2. The server verifies the client's public key.
¡ If the public key is invalid, the server informs the client of the authentication failure.
¡ If the public key is valid, the server requests the digital signature of the client. After receiving the signature, the server uses the public key to verify the signature and informs the client of the authentication result.
When acting as an SSH server, the device supports using the public key algorithms DSA, ECDSA, and RSA to verify digital signatures.
When acting as an SSH client, the device supports using the public key algorithms DSA, ECDSA, and RSA to generate digital signatures.
For more information about public key configuration, see "Managing public keys."
Password-publickey authentication
The server requires SSH2 clients to pass both password authentication and publickey authentication. However, an SSH1 client only needs to pass either authentication.
Any authentication
The server requires clients to pass password authentication or publickey authentication.
SSH support for Suite B
Suite B contains a set of encryption and authentication algorithms that meet high security requirements. Table 2 lists all algorithms in Suite B.
The SSH server and client support using the X.509v3 certificate for identity authentication in compliance with the algorithm, negotiation, and authentication specifications defined in RFC 6239.
Security level |
Key exchange algorithm |
Encryption algorithm and HMAC algorithm |
Public key algorithm |
128-bit |
ecdh-sha2-nistp256 |
AES128-GCM |
x509v3-ecdsa-sha2-nistp256 |
192-bit |
ecdh-sha2-nistp384 |
AES256-GCM |
x509v3-ecdsa-sha2-nistp384 |
Both |
ecdh-sha2-nistp256 ecdh-sha2-nistp384 |
AES128-GCM AES256-GCM |
x509v3-ecdsa-sha2-nistp256 x509v3-ecdsa-sha2-nistp384 |
SSH server tasks at a glance
To configure an SSH server, perform the following tasks:
2. (Optional.) Specifying the SSH service port
3. Enabling the SSH server
4. Configuring the user lines for SSH login
Required only for Stelnet and NETCONF-over-SSH servers.
5. Configuring a client's host public key
Required for authentication method publickey, password-publickey, or any.
¡ Required for authentication method publickey, password-publickey, or any.
¡ Optional for the password authentication method.
7. (Optional.) Configuring the SSH management parameters
SSH management settings, such as authentication and connection control settings, help improve security of SSH connections.
8. (Optional.) Specifying a PKI domain for the SSH server
9. (Optional.) Enabling the whitelist service for SSH
Generating local key pairs
The DSA, ECDSA, or RSA key pairs on the SSH server are required for generating the session keys and session ID in the key exchange stage. They can also be used by a client to authenticate the server. When a client authenticates the server, it compares the public key received from the server with the server's public key that the client saved locally. If the keys are consistent, the client uses the locally saved server's public key to decrypt the digital signature received from the server. If the decryption succeeds, the server passes the authentication.
To support SSH clients that use different types of key pairs, generate DSA, ECDSA, and RSA key pairs on the SSH server.
· The public-key local create rsa command generates a server key pair and a host key pair for RSA. The RSA server key pair is only used in SSH1 to encrypt the session key for secure transmission of the session key. It is not used in SSH2, because no session key transmission is required in SSH2.
· The public-key local create dsa command generates only one DSA host key pair. The key modulus length must be less than 2048 bits when you generate the DSA key pair on the SSH server. SSH1 does not support the DSA algorithm.
· When you generate an ECDSA key pair, you can generate only a secp256r1 or secp384r1 ECDSA key pair.
Local DSA, ECDSA, and RSA key pairs for SSH use default names. You cannot assign names to the key pairs.
If the device does not have RSA key pairs with default names, it automatically generates one RSA server key pair and one RSA host key pair when SSH starts. Both key pairs use their default names. The SSH application starts when you execute an SSH server command on the device.
1. Enter system view.
2. Generate local key pairs.
public-key local create { dsa | ecdsa { secp256r1 | secp384r1 } | rsa } [ name key-name ]
By default, no local key pairs exist on the server.
The default port of the SSH service is 22. You can specify another port for the SSH service to improve security of SSH connections.
2. Specify the SSH service port.
ssh server port port-number
CAUTION: · If you modify the SSH port number when the SSH server is enabled, the SSH service is restarted and all SSH connections are terminated after the modification. SSH users must reconnect to the SSH server to access the server. · If you set the SSH port to a well-known port number, the service that uses the well-known port number might fail to start. Well-known port numbers are in the range of 1 to 1024. |
By default, the SSH service port is 22.
Enabling the Stelnet server
After you enable the Stelnet server on the device, a client can log in to the device through Stelnet.
2. Enable the Stelnet server.
ssh server enable
By default, the Stelnet server is disabled.
Enabling the SFTP server
After you enable the SFTP server on the device, a client can log in to the device through SFTP.
When acting as an SFTP server, the device does not support SFTP connections initiated by SSH1 clients.
2. Enable the SFTP server.
sftp server enable
By default, the SFTP server is disabled.
Enabling the SCP server
After you enable the SCP server on the device, a client can log in to the device through SCP.
When acting as an SCP server, the device does not support SCP connections initiated by SSH1 clients.
2. Enable the SCP server.
scp server enable
By default, the SCP server is disabled.
Enabling NETCONF over SSH
After you enable NETCONF over SSH on the device, a client can perform NETCONF operations on the device through a NETCONF-over-SSH connection.
When acting as a server in the NETCONF-over-SSH connection, the device does not support connection requests initiated by SSH1 clients.
2. Enable NETCONF over SSH.
netconf ssh server enable
By default, NETCONF over SSH is disabled.
For more information about NETCONF over SSH commands, see Network Management and Monitoring Command Reference.
Depending on the SSH application, an SSH client can be an Stelnet client, SFTP client, SCP client, or NETCONF-over-SSH client.
Only Stelnet and NETCONF-over-SSH clients require the user line configuration. The user line configuration takes effect on the clients at the next login.
2. Enter VTY user line view.
line vty first-number [ last-number ]
3. Set the login authentication mode to scheme.
authentication-mode scheme
By default, the authentication mode is password.
For more information about this command, see Fundamentals Command Reference.
In publickey authentication, the server compares the SSH username and the client's host public key received from the client with the locally saved SSH username and the client's host public key. If they are the same, the server checks the digital signature that the client sends. The client generates the digital signature by using the private key that is paired with the client's host public key.
For publickey authentication, password-publickey authentication, or any authentication, you must perform the following tasks:
1. Configure the client's DSA, ECDSA, or RSA host public key on the server.
2. Specify the associated host private key on the client to generate the digital signature.
If the device acts as an SSH client, specify the public key algorithm on the client. The algorithm determines the associated host private key for generating the digital signature.
Client public key configuration methods
You can configure the client host public key by using the following methods:
· Manually enter the content of a client's host public key on the server.
a. Display the host public key on the client and record the key.
b. Type the client's host public key character by character on the server, or use the copy and paste method.
The manually entered key must be in DER format without being converted. For the displayed key to meet the requirement when the client is an H3C device, use the display public-key local public command. The format of the public key displayed in any other way (for example, by using the public-key local export command) might be incorrect. If the key is not in correct format, the system discards the key.
· Import the client host public key from a public key file.
a. Save the client public key file to the server. For example, transfer the client public key file to the server in binary mode through FTP or TFTP.
b. Import the client public key from the locally saved public key file.
During the import process, the server automatically converts the host public key to a string in PKCS format.
As a best practice, configure no more than 20 SSH client's host public keys on an SSH server.
Import the client's host public key as a best practice.
Entering a client's host public key
2. Enter public key view.
public-key peer keyname
3. Configure a client's host public key.
Enter the content of the client's host public key character by character, or use the copy and paste method.
When you enter the content of a client's host public key, you can use spaces and carriage returns between characters but the system does not save them. For more information, see "Managing public keys."
4. Exit public key view and save the key.
peer-public-key end
Importing a client's host public key from the public key file
2. Import a client's public key from the public key file.
public-key peer keyname import sshkey filename
Configuring an SSH user
Configure an SSH user and a local user depending on the authentication method.
· If the authentication method is publickey, you must create an SSH user and a local user on the SSH server. The two users must have the same username, so that the SSH user can be assigned the correct working directory and user role.
· If the authentication method is password, you must perform one of the following tasks:
¡ For local authentication, configure a local user on the SSH server.
¡ For remote authentication, configure an SSH user on a remote authentication server, for example, a RADIUS server.
You do not need to create an SSH user by using the ssh user command. However, if you want to display all SSH users, including the password-only SSH users, for centralized management, you can use this command to create them. If such an SSH user has been created, make sure you have specified the correct service type and authentication method.
· If the authentication method is password-publickey or any, you must create an SSH user on the SSH server and perform one of the following tasks:
In either case, the local user or the SSH user configured on the remote authentication server must have the same username as the SSH user.
For information about configuring local users and remote authentication, see BRAS Service Configuration Guide.
If you change the authentication parameters for a logged-in SSH user, the change takes effect on the user at the next login.
For an SFTP or SCP user, the working directory depends on the authentication method.
· If the authentication method is password, the working directory is authorized by AAA.
· If the authentication method is publickey or password-publickey, the working folder is specified by the authorization-attribute command in the associated local user view.
For an SSH user, the user role also depends on the authentication method.
· If the authentication method is password, the user role is authorized by AAA.
· If the authentication method is publickey or password-publickey, the user role is specified by the authorization-attribute command in the associated local user view.
For all authentication methods except password authentication, you must specify a client's host public key or digital certificate.
· For a client that sends the user's public key information directly to the server, specify the client's host public key on the server. The specified public key must already exist. For more information about public keys, see "Configuring a client's host public key." If you specify multiple client public keys, the device verifies the user identity by using the public keys in the order they are specified. The user is valid if the user passes one public key check.
· For a client that sends the user's public key information to the server through a digital certificate, specify the PKI domain on the server. This PKI domain verifies the client's digital certificate. For successful verification, the specified PKI domain must have the correct CA certificate. To specify the PKI domain, use the ssh user or ssh server pki-domain command. For more information about configuring a PKI domain, see "Configuring PKI."
2. Create an SSH user, and specify the service type and authentication method.
ssh user username service-type { all | netconf | scp | sftp | stelnet } authentication-type { password | { any [ assign { pki-domain domain-name | publickey keyname&<1-6> } ] | { password-publickey | publickey } { assign { pki-domain domain-name | publickey keyname&<1-6> } } }
An SSH server supports up to 1024 SSH users.
Enabling the SSH server to support SSH1 clients
2. Enable the SSH server to support SSH1 clients.
ssh server compatible-ssh1x enable
By default, the SSH server does not support SSH1 clients.
Setting the minimum interval for updating the RSA server key pair
2. Set the minimum interval for updating the RSA server key pair.
ssh server rekey-interval interval
By default, the device does not update the RSA server key pair.
This configuration takes effect only on SSH1 clients.
Setting the SSH user authentication timeout timer
2. Set the SSH user authentication timeout timer.
The default setting is 60 seconds.
Perform this task to prevent malicious occupation of TCP connections. If a user does not finish the authentication when the timeout timer expires, the connection cannot be established.
Setting the maximum number of SSH authentication attempts
2. Set the maximum number of SSH authentication attempts.
ssh server authentication-retries retries
The default setting is 3.
Perform this task to prevent malicious hacking of usernames and passwords. If the authentication method is any, the total number of publickey authentication attempts and password authentication attempts cannot exceed the upper limit.
Specifying an SSH login control ACL
2. Specify an SSH login control ACL.
IPv4:
ssh server acl { advanced-acl-number | basic-acl-number | name ipv4-acl-name | mac { mac-acl-number | name mac-acl-name } }
IPv6:
ssh server ipv6 acl { ipv6 { advanced-acl-number | basic-acl-number | name ipv6-acl-name } | mac { mac-acl-number | name mac-acl-name } }
This feature uses an ACL to filter SSH clients that initiate SSH connections to the server. By default, no ACLs are specified and all SSH users can initiate SSH connections to the server.
The ACL specified in this command filters IPv4 SSH clients' connection requests. Only the IPv4 SSH clients that the ACL permits can access the device. If the specified ACL does not exist or contains no rules, no IPv4 SSH clients can access the device.
The ACL specified in this command is also used for the static whitelist for SSH clients. To ensure successful deployment of the static whitelist entries, the specified ACL must meet the following requirements:
¡ The ACL rules must be permit statements.
¡ In the ACL rules, the protocol must be TCP, the source IPv4 or IPv6 address must be configured. If the destination address is configured in the ACL rules, the destination ports must contain 22 and 830.
¡ If the vpn-instance keyword is specified in an ACL rule, the specified VPN instance must have existed.
The ACL takes effect only on SSH connections that are initiated after the ACL configuration. Packets in the SSH connections that match the ACL rules will be processed with priority.
Enabling logging for SSH login attempts that are denied by the SSH login control ACL
2. Enable logging for SSH login attempts that are denied by the SSH login control ACL.
By default, logging is disabled for login attempts that are denied by the SSH login control ACL.
This command enables SSH to generate log messages for SSH login attempts that are denied by the SSH login control ACL and send the messages to the information center.
Setting the DSCP value in the packets that the SSH server sends to SSH clients
2. Set the DSCP value in the packets that the SSH server sends to the SSH clients.
IPv4:
ssh server dscp dscp-value
IPv6:
By default, the DSCP value of SSH packets is 48.
The DSCP value of a packet defines the priority of the packet and affects the transmission priority of the packet. A bigger DSCP value represents a higher priority.
Setting the SFTP connection idle timeout timer
2. Set the SFTP connection idle timeout timer.
By default, the SFTP connection idle timeout is 10 minutes.
When the SFTP connection idle timeout timer expires, the system automatically tears the connection down and releases the connection resources.
Setting the maximum number of online SSH users
2. Set the maximum number of online SSH users.
The default setting is 32.
When the number of online SSH users reaches the upper limit, the system denies new SSH connection requests. Changing the upper limit does not affect online SSH users.
For more information about this command, see BRAS Service Command Reference.
Setting alarm and recovery thresholds for SSH user login failures in the specified statistics period
2. Set alarm and recovery thresholds for SSH user login failures in the specified statistics period.
ssh server login-failed threshold-alarm upper-limit report-times lower-limit resume-times period period-time
By default, the statistics period is 5 minutes, and the SSH user login failure alarm threshold and alarm recovery threshold are 30 and 20, respectively.
Configure this feature to monitor the SSH user login situation. With this feature configured, the device generates alarms as follows:
¡ Generates an alarm when the number of login failures in the specified statistics period reaches or exceeds the alarm threshold.
¡ Generates a recovery alarm when the number of login failures in the specified statistics period drops below the alarm recovery threshold from the alarm threshold or a higher value.
The PKI domain specified for the SSH server has the following functions:
· The SSH server uses the PKI domain to send its certificate to the client in the key exchange stage.
· The SSH server uses the PKI domain to authenticate the client's certificate if no PKI domain is specified for the client authentication by using the ssh user command.
2. Specify a PKI domain for the SSH server.
ssh server pki-domain domain-name
By default, no PKI domain is specified for the SSH server.
In case of TCP attack protection, an interface might drop received TCP packets due to rate limit, causing failure to establish SSH connections on the interface.
To resolve this issue, enable the SSH whitelist service before you enable the SSH service. The device will add valid SSH clients that successfully log in to the SSH service whitelist. The TCP packets sourced from the SSH clients in the whitelist will not be rate limited, so that logins from valid SSH clients are not affected in TCP attack scenarios.
2. Enable the whitelist service for SSH.
ssh server whitelist enable
By default, the whitelist service for SSH is disabled.
3. Set the aging time for SSH whitelist entries.
ssh server whitelist aging-time aging-time-value
By default, the aging time for SSH whitelist entries is 30 minutes.
To configure an Stelnet client, perform the following tasks:
Only required for authentication method publickey, password-publickey, or any.
2. (Optional.) Specifying the source IP address for SSH packets
3. Establishing a connection to an Stelnet server
You must generate local key pairs on Stelnet clients when the Stelnet server uses the publickey, password-publickey, or any authentication method.
The key modulus length must be less than 2048 bits when you generate a DSA key pair.
By default, no local key pairs exist on an Stelnet client.
After you specify the source IP address for SSH packets on an Stelnet client, the client uses the specified IP address to communicate with the Stelnet server.
As a best practice, specify the IP address of a loopback interface as the source address of SSH packets for the following purposes:
· Ensuring the communication between the Stelnet client and the Stelnet server.
· Improving the manageability of Stelnet clients in authentication service.
2. Specify the source address for SSH packets.
IPv4:
By default, an IPv4 Stelnet client uses the primary IPv4 address of the output interface in the routing entry as the source address of the SSH packets.
IPv6:
By default, an IPv6 Stelnet client automatically selects a source IPv6 address for SSH packets.
Perform this task to enable the Stelnet client feature on the device and establish a connection to the Stelnet server. You can specify the public key algorithm and the preferred encryption, HMAC, and key exchange algorithms to be used during the connection.
Restrictions and guidelines for establishing a connection to an Stelnet server
An Stelnet client cannot establish connections to both IPv4 and IPv6 Stelnet servers.
To access the server, a client must use the server's host public key to authenticate the server. As a best practice, configure the server's host public key on the device in an insecure network. If the server's host public key is not configured on the client, the client will notify you to confirm whether to continue with the access.
· If you choose to continue, the client accesses the server and downloads the server's host public key. The downloaded public key will be used to authenticate the server in subsequent accesses.
· If you choose to not continue, the connection cannot be established.
Establishing a connection to an IPv4 Stelnet server
Execute the following command in user view to establish a connection with an IPv4 Stelnet server:
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } ] * [ dscp dscp-value | escape character | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
Establishing a connection to an IPv6 Stelnet server
Execute the following command to establish a connection to an IPv6 Stelnet server:
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } ] * [ dscp dscp-value | escape character | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
Establishing a connection to an IPv4 Stelnet server based on Suite B
Execute the following command in user view to establish a connection to an Stelnet server based on Suite B:
ssh2 server [ port-number ] [ vpn-instance vpn-instance-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | escape character | source { interface interface-type interface-number | ip ip-address } ] *
Establishing a connection to an IPv6 Stelnet server based on Suite B
ssh2 ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | escape character | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
SFTP client tasks at a glance
To configure an SFTP client, perform the following tasks:
2. (Optional.) Specifying the source IP address for SFTP packets
3. Establishing a connection to an SFTP server
4. (Optional.) Working with SFTP directories
5. (Optional.) Working with SFTP files
6. (Optional.) Displaying help information
7. (Optional.) Terminating the connection with the SFTP server
You must generate local key pairs on SFTP clients when the SFTP server uses the publickey, password-publickey, or any authentication method.
By default, no local key pairs exist on an SFTP client.
After you specify the source IP address for SSH packets on an SFTP client, the client uses the specified IP address to communicate with the SFTP server.
As a best practice, specify the IP address of a loopback interface as the source address of SFTP packets for the following purposes:
· Ensuring the communication between the SFTP client and the SFTP server.
· Improving the manageability of SFTP clients in authentication service.
2. Specify the source address for SFTP packets.
IPv4:
sftp client source { ip ip-address | interface interface-type interface-number }
By default, an SFTP client uses the primary IPv4 address of the output interface in the routing entry as the source address of the SFTP packets.
IPv6:
sftp client ipv6 source { ipv6 ipv6-address | interface interface-type interface-number }
By default, an IPv6 SFTP client automatically selects a source IPv6 address for the SFTP packets.
Perform this task to enable the SFTP client feature on the device and establish a connection to the SFTP server. You can specify the public key algorithm and the preferred encryption, HMAC, and key exchange algorithms to be used during the connection.
Restrictions and guidelines for establishing a connection to an SFTP server
An SFTP client cannot establish connections to both IPv4 and IPv6 SFTP servers.
Establishing a connection to an IPv4 SFTP server
Execute the following command in user view to establish a connection to an IPv4 SFTP server:
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } ] * [ dscp dscp-value | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
Establishing a connection to an IPv6 SFTP server
Execute the following command in user view to establish a connection to an IPv6 SFTP server:
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } ] * [ dscp dscp-value | { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
Establishing a connection to an IPv4 SFTP server based on Suite B
Execute the following command in user view to establish a connection to an SFTP server based on Suite B:
sftp server [ port-number ] [ vpn-instance vpn-instance-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | source { interface interface-type interface-number | ip ip-address } ] *
Establishing a connection to an IPv6 SFTP server based on Suite B
sftp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ dscp dscp-value | escape character | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
After you establish a connection to an SFTP server, you can operate directories of the SFTP server.
Changing the working directory on the SFTP server
1. Enter SFTP client view.
For more information, see "Establishing a connection to an SFTP server."
2. Change the working directory on the SFTP server.
cd [ remote-path ]
3. (Optional.) Return to the upper-level directory.
cdup
Displaying the current working directory on the SFTP server
2. Display the current working directory on the SFTP server.
pwd
Displaying files under a directory
2. Display files under a directory.
¡ dir [ -a | -l ] [ remote-path ]
¡ ls [ -a | -l ] [ remote-path ]
The dir command has the same function as the ls command.
Changing the name of a directory on the SFTP server
2. Change the name of a directory on the SFTP server.
rename oldname newname
Creating a new directory on the SFTP server
2. Create a new directory on the SFTP server.
mkdir remote-path
Deleting directories on the SFTP server
2. Delete one or more directories from the SFTP server.
rmdir remote-path
After you establish a connection to an SFTP server, you can operate files on the SFTP server.
Changing the name of a file on the SFTP server
2. Change the name of a file on the SFTP server.
rename old-name new-name
Downloading a file from the SFTP server and save it locally
2. Download a file from the SFTP server and save it locally.
Uploading a local file to the SFTP server
2. Upload a local file to the SFTP server.
Deleting a file from the SFTP server
2. Delete a file from the SFTP server.
¡ delete remote-file
¡ remove remote-file
The delete command has the same function as the remove command.
After you establish a connection to the SFTP server, you can display the help information of SFTP client commands, including the command syntax and parameter configuration.
2. Display SFTP client command help information.
¡ help
The help command has the same function as the ? command.
2. Terminate the connection with the SFTP server and return to user view.
¡ bye
¡ exit
¡ quit
The three commands have the same function.
SCP client tasks at a glance
To configure an SCP client, perform the following tasks:
Only required for the publickey, password-publickey, or any authentication method.
2. Establishing a connection to an SCP server
You must generate local key pairs on SCP clients when the SCP server uses the publickey, password-publickey, or any authentication method.
By default, no local key pairs exist on an SCP client.
Perform this task to enable the SCP client feature on the device, establish a connection to the SCP server, and transfer files with the server. You can specify the public key algorithm and the preferred encryption, HMAC, and key exchange algorithms to be used during the connection.
Restrictions and guidelines for establishing a connection to an SCP server
An SCP client cannot establish connections to both IPv4 and IPv6 SCP servers.
Establishing a connection to an IPv4 SCP server
Execute the following command in user view to connect to an IPv4 SCP server, and transfer files with the server:
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { put | get } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ip ip-address } ] *
Establishing a connection to an IPv6 SCP server
Execute the following command in user view to connect to an IPv6 SCP server, and transfer files with the server.
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { put | get } source-file-name [ destination-file-name ] [ identity-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | { x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } pki-domain domain-name } | prefer-compress zlib | prefer-ctos-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-ctos-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } | prefer-kex { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } | prefer-stoc-cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } | prefer-stoc-hmac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } ] * [ { public-key keyname | server-pki-domain domain-name } | source { interface interface-type interface-number | ipv6 ipv6-address } ] *
Establishing a connection to an IPv4 SCP server based on Suite B
Execute the following command in user view to establish a connection to an SCP server based on Suite B:
scp server [ port-number ] [ vpn-instance vpn-instance-name ] { put | get } source-file-name [ destination-file-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ source { interface interface-type interface-number | ip ip-address } ] *
Establishing a connection to an IPv6 SCP server based on Suite B
scp ipv6 server [ port-number ] [ vpn-instance vpn-instance-name ] [ -i interface-type interface-number ] { put | get } source-file-name [ destination-file-name ] suite-b [ 128-bit | 192-bit ] pki-domain domain-name [ server-pki-domain domain-name ] [ prefer-compress zlib ] [ source { interface interface-type interface-number | ipv6 ipv6-address } ] *
About algorithms for SSH2
The SSH2 client and server use the following types of algorithms for algorithm negotiation during the Stelnet, SFTP, or SCP session establishment:
· Key exchange algorithms.
· Public key algorithms.
· Encryption algorithms.
· MAC algorithms.
If you specify algorithms, SSH2 uses only the specified algorithms for algorithm negotiation. The client uses the specified algorithms to initiate the negotiation, and the server uses the matching algorithms to negotiate with the client. If multiple algorithms of the same type are specified, the algorithm specified earlier has a higher priority during negotiation.
2. Specify key exchange algorithms for SSH2.
ssh2 algorithm key-exchange { dh-group-exchange-sha1 | dh-group1-sha1 | dh-group14-sha1 | ecdh-sha2-nistp256 | ecdh-sha2-nistp384 } *
By default, SSH2 uses the ecdh-sha2-nistp256, ecdh-sha2-nistp384, dh-group-exchange-sha1, dh-group14-sha1, and dh-group1-sha1 key exchange algorithms in descending order of priority for algorithm negotiation.
2. Specify public key algorithms for SSH2.
ssh2 algorithm public-key { dsa | ecdsa-sha2-nistp256 | ecdsa-sha2-nistp384 | rsa | x509v3-ecdsa-sha2-nistp256 | x509v3-ecdsa-sha2-nistp384 } *
By default, SSH2 uses the x509v3-ecdsa-sha2-nistp256, x509v3-ecdsa-sha2-nistp384, ecdsa-sha2-nistp256, ecdsa-sha2-nistp384, rsa, and dsa public key algorithms in descending order of priority for algorithm negotiation.
2. Specify encryption algorithms for SSH2.
ssh2 algorithm cipher { 3des-cbc | aes128-cbc | aes128-ctr | aes128-gcm | aes192-ctr | aes256-cbc | aes256-ctr | aes256-gcm | des-cbc } *
By default, SSH2 uses the aes128-ctr, aes192-ctr, aes256-ctr, aes128-gcm, aes256-gcm, aes128-cbc, 3des-cbc, aes256-cbc, and des-cbc encryption algorithms in descending order of priority for algorithm negotiation.
2. Specify MAC algorithms for SSH2.
ssh2 algorithm mac { md5 | md5-96 | sha1 | sha1-96 | sha2-256 | sha2-512 | sm3 } *
By default, SSH2 uses the sha2-256, sha2-512, sha1, md5, sha1-96, md5-96, and sm3 MAC algorithms in descending order of priority for algorithm negotiation.
Task |
Command |
Display the source IP address configured for the SFTP client. |
display sftp client source |
Display the source IP address configured for the Stelnet client. |
display ssh client source |
Display SSH server status or sessions. |
display ssh server { session | status } |
Display SSH user information on the SSH server. |
display ssh user-information [ username ] |
Display the public keys of the local key pairs. |
display public-key local { dsa | ecdsa | rsa } public [ name publickey-name ] |
Display information about peer public keys. |
display public-key peer [ brief | name publickey-name ] |
Display algorithms used by SSH2 in the algorithm negotiation stage. |
display ssh2 algorithm |
As shown in Figure 1:
· The router acts as the Stelnet server and uses password authentication to authenticate the Stelnet client. The username and password of the client are saved on the router.
· The host acts as the Stelnet client, using Stelnet client software (SSH2). After the user on the host logs in to the router through Stelnet, the user can configure and manage the router as a network administrator.
There are different types of Stelnet client software, such as PuTTY and OpenSSH. This example uses an Stelnet client that runs PuTTY version 0.58.
1. Configure the Stelnet server:
# Generate RSA key pairs.
<Router> system-view
[Router] public-key local create rsa
The range of public key modulus is (512 ~ 2048).
If the key modulus is greater than 512, it will take a few minutes.
Press CTRL+C to abort.
Generating Keys...
# Generate a DSA key pair.
[Router] public-key local create dsa
Generating Keys...
# Generate an ECDSA key pair.
[Router] public-key local create ecdsa secp256r1
Generating Keys...
# Enable the Stelnet server.
[Router] ssh server enable
# Assign an IP address to Ten-GigabitEthernet 3/0/1. The Stelnet client uses this IP address as the destination for SSH connection.
[Router] interface ten-gigabitethernet 3/0/1
[Router-Ten-GigabitEthernet3/0/1] ip address 192.168.1.40 255.255.255.0
[Router-Ten-GigabitEthernet3/0/1] quit
# Set the authentication mode to AAA for user lines.
[Router] line vty 0 63
[Router-line-vty0-63] authentication-mode scheme
[Router-line-vty0-63] quit
# Create a local device management user named client001.
[Router] local-user client001 class manage
# Set the password to 123456TESTplat&! in plain text for local user client001.
[Router-luser-manage-client001] password simple 123456TESTplat&!
# Authorize local user client001 to use the SSH service.
[Router-luser-manage-client001] service-type ssh
# Assign the network-admin user role to local user client001.
[Router-luser-manage-client001] authorization-attribute user-role network-admin
[Router-luser-manage-client001] quit
# Create an SSH user named client001. Specify the service type as stelnet and the authentication method as password for the user.
[Router] ssh user client001 service-type stelnet authentication-type password
2. Establish a connection to the Stelnet server:
a. Launch PuTTY.exe to enter the interface shown in Figure 2.
b. In the Host Name (or IP address) field, enter the IP address 192.168.1.40 of the Stelnet server.
c. Click Open.
Figure 2 Specifying the host name (or IP address)
d. Enter username client001 and password 123456TESTplat&! to log in to the Stelnet server.
As shown in Figure 3:
· The router acts as the Stelnet server, and it uses publickey authentication and the RSA public key algorithm.
In the server configuration, the client's host public key is required. Use the client software to generate RSA key pairs on the client before configuring the Stelnet server.
1. Generate RSA key pairs on the Stelnet client:
a. Run PuTTYGen.exe, select SSH-2 RSA and click Generate.
Figure 4 Generating a key pair on the client
b. Continue moving the mouse during the key generating process, but do not place the mouse over the green progress bar shown in Figure 5. Otherwise, the progress bar stops moving and the key pair generating process stops.
c. After the key pair is generated, click Save public key to save the public key.
Figure 6 Saving a key pair on the client
d. Enter a file name (key.pub in this example), and click Save.
e. On the page as shown in Figure 6, click Save private key to save the private key.
A confirmation dialog box appears.
f. Click Yes.
A file saving window appears.
g. Enter a file name (private.ppk in this example), and click Save.
h. Transmit the public key file to the server through FTP or TFTP. (Details not shown.)
2. Configure the Stelnet server:
Generating Keys...
Generating Keys...
Generating Keys...
# Assign an IP address to Ten-GigabitEthernet 3/0/1. The Stelnet client uses this address as the destination for SSH connection.
# Import the peer public key from the public key file key.pub and name it clientkey.
[Router] public-key peer clientkey import sshkey key.pub
# Create an SSH user named client002. Specify the authentication method as publickey for the user, and assign the public key clientkey to the user.
[Router] ssh user client002 service-type stelnet authentication-type publickey assign publickey clientkey
# Create a local device management user named client002.
[Router] local-user client002 class manage
# Authorize local user client002 to use the SSH service.
[Router-luser-manage-client002] service-type ssh
# Assign the network-admin user role to local user client002.
[Router-luser-manage-client002] authorization-attribute user-role network-admin
[Router-luser-manage-client002] quit
3. Specify the private key file and establish a connection to the Stelnet server:
a. Launch PuTTY.exe on the Stelnet client to enter the interface shown in Figure 7.
b. In the Host Name (or IP address) field, enter IP address 192.168.1.40 of the Stelnet server.
Figure 7 Specifying the host name (or IP address)
c. From the navigation tree, select Connection > SSH.
The window shown in Figure 8 appears.
d. Set Preferred SSH protocol version to 2.
Figure 8 Setting the preferred SSH version
e. From the navigation tree, select Connection > SSH > Auth.
The window shown in Figure 9 appears.
f. Click Browse… to open the file selection window, and then select the private key file (private.ppk in this example).
g. Click Open.
Figure 9 Specifying the private key file
h. Enter username client002 to log in to the Stelnet server.
As shown in Figure 10:
· Router B acts as the Stelnet server and uses password authentication to authenticate the Stelnet client. The username and password of the client are saved on Router B.
· Router A acts as the Stelnet client. After the user on Router A logs in to Router B through Stelnet, the user can configure and manage Router B as a network administrator.
<RouterB> system-view
[RouterB] public-key local create rsa
Generating Keys...
[RouterB] public-key local create dsa
Generating Keys...
[RouterB] public-key local create ecdsa secp256r1
Generating Keys...
[RouterB] ssh server enable
# Assign an IP address to Ten-GigabitEthernet 3/0/1. The Stelnet client uses this address as the destination address for SSH connection.
[RouterB] interface ten-gigabitethernet 3/0/1
[RouterB-Ten-GigabitEthernet3/0/1] ip address 192.168.1.40 255.255.255.0
[RouterB-Ten-GigabitEthernet3/0/1] quit
[RouterB] line vty 0 63
[RouterB-line-vty0-63] authentication-mode scheme
[RouterB-line-vty0-63] quit
[RouterB] local-user client001 class manage
[RouterB-luser-manage-client001] password simple 123456TESTplat&!
[RouterB-luser-manage-client001] service-type ssh
[RouterB-luser-manage-client001] authorization-attribute user-role network-admin
[RouterB-luser-manage-client001] quit
[RouterB] ssh user client001 service-type stelnet authentication-type password
# Specify the DSA public key algorithm for SSH2.
[RouterB] ssh2 algorithm public-key dsa
[RouterA] interface ten-gigabitethernet 3/0/1
[RouterA-Ten-GigabitEthernet3/0/1] ip address 192.168.1.56 255.255.255.0
[RouterA-Ten-GigabitEthernet3/0/1] quit
[RouterA] quit
¡ If the client does not have the server's host public key, and is connected to the server for the first time:
# Establish an SSH connection to server 192.168.1.40. Enter username client001, and then enter y to continute accessing the server without authentecting the server, and enter y to download and save the server's host public key.
<RouterA> ssh2 192.168.1.40
Username: client001
Connecting to 192.168.1.40 port 22.
The server is not authenticated. Continue? [Y/N]:y
Do you want to save the server public key? [Y/N]:y
[email protected]'s password:
Enter a character ~ and a dot to abort.
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
<RouterB>
After you enter password 123456TESTplat&!, you can access Router B successfully. At the next connection attempt, the client authenticates the server by using the server's host public key that is locally saved on the client.
¡ If you configure the server's host public key on the client before establishing a connection to the server:
# Use the display public-key local dsa public command on the server to display the server's host public key. (Details not shown.)
# Enter public key view of the client and copy the host public key of the server to the client.
[RouterA] public-key peer key1
Enter public key view. Return to system view with "peer-public-key end" command.
[RouterA-pkey-public-key-key1] 308201B73082012C06072A8648CE3804013082011F0281810
0D757262C4584C44C211F18BD96E5F0
[RouterA-pkey-public-key-key1]61C4F0A423F7FE6B6B85B34CEF72CE14A0D3A5222FE08CECE
65BE6C265854889DC1EDBD13EC8B274
[RouterA-pkey-public-key-key1]DA9F75BA26CCB987723602787E922BA84421F22C3C89CB9B0
6FD60FE01941DDD77FE6B12893DA76E
[RouterA-pkey-public-key-key1]EBC1D128D97F0678D7722B5341C8506F358214B16A2FAC4B3
68950387811C7DA33021500C773218C
[RouterA-pkey-public-key-key1]737EC8EE993B4F2DED30F48EDACE915F0281810082269009E
14EC474BAF2932E69D3B1F18517AD95
[RouterA-pkey-public-key-key1]94184CCDFCEAE96EC4D5EF93133E84B47093C52B20CD35D02
492B3959EC6499625BC4FA5082E22C5
[RouterA-pkey-public-key-key1]B374E16DD00132CE71B020217091AC717B612391C76C1FB2E
88317C1BD8171D41ECB83E210C03CC9
[RouterA-pkey-public-key-key1]B32E810561C21621C73D6DAAC028F4B1585DA7F42519718CC
9B09EEF0381840002818000AF995917
[RouterA-pkey-public-key-key1]E1E570A3F6B1C2411948B3B4FFA256699B3BF871221CC9C5D
F257523777D033BEE77FC378145F2AD
[RouterA-pkey-public-key-key1]D716D7DB9FCABB4ADBF6FB4FDB0CA25C761B308EF53009F71
01F7C62621216D5A572C379A32AC290
[RouterA-pkey-public-key-key1]E55B394A217DA38B65B77F0185C8DB8095522D1EF044B465E
8716261214A5A3B493E866991113B2D
[RouterA-pkey-public-key-key1]485348
[RouterA-pkey-public-key-key1] peer-public-key end
[RouterA] ssh2 algorithm public-key dsa
[RouterA] quit
# Establish an SSH connection to the server, and specify the host public key of the server as key1.
<RouterA> ssh2 192.168.1.40 public-key key1
Username: client001
<RouterB>
After you enter username client001 and password 123456TESTplat&!, you can log in to Router B successfully.
¡ If the client has the server's host public key:
Username: client001
<RouterB>
As shown in Figure 11:
· Router B acts as the Stelnet server, and it uses publickey authentication and the DSA public key algorithm.
In the server configuration, the client's host public key is required. Generate a DSA key pair on the client before configuring the Stelnet server.
1. Configure the Stelnet client:
[RouterA] public-key local create dsa
Generating Keys...
# Export the DSA host public key to a public key file named key.pub.
[RouterA] public-key local export dsa ssh2 key.pub
[RouterA] quit
# Transmit the public key file key.pub to the server through FTP or TFTP. (Details not shown.)
Generating Keys...
Generating Keys...
Generating Keys...
# Import the peer public key from the public key file key.pub, and name it clientkey.
[RouterB] public-key peer clientkey import sshkey key.pub
[RouterB] ssh user client002 service-type stelnet authentication-type publickey assign publickey clientkey
[RouterB] local-user client002 class manage
[RouterB-luser-manage-client002] service-type ssh
[RouterB-luser-manage-client002] authorization-attribute user-role network-admin
[RouterB-luser-manage-client002] quit
3. Establish an SSH connection to the Stelnet server.
<RouterA> ssh2 192.168.1.40 identity-key dsa
Username: client002
Do you want to save the server public key? [Y/N]:n
<RouterB>
The client does not have the server's host public key, so when you connect to the server for the first time, you can log in to the server successfully after you enter y to continue accessing the server.
As shown in Figure 12:
· Router B acts as the Stelnet Suite B server (SSH2), and it uses publickey authentication to authenticate the client.
· Router A acts as an Stelnet Suite B client (SSH2). After the user on Router A logs in to Router B through the Stelnet Suite B client software, the user can configure and manage Router B as an administrator.
Before you configure Stelnet, first configure the certificates of the server and the client because they are required for identity authentication.
You can modify the pkix version of the client software OpenSSH to support Suite B. This example uses an H3C router as an Stelnet client.
# Upload the server's certificate file ssh-server-ecdsa256.p12 and the client's certificate file ssh-client-ecdsa256.p12 to the Stelnet client through FTP or TFTP. (Details not shown.)
# Create a PKI domain named server256 for verifying the server's certificate and enter its view.
[RouterA] pki domain server256
# Disable CRL checking.
[RouterA-pki-domain-server256] undo crl check enable
[RouterA-pki-domain-server256] quit
# Import local certificate file ssh-server-ecdsa256.p12 to PKI domain server256.
[RouterA] pki import domain server256 p12 local filename ssh-server-ecdsa256.p12
The system is going to save the key pair. You must specify a key pair name, which is a case-insensitive string of 1 to 64 characters. Valid characters include a to z, A to Z, 0 to 9, and hyphens (-).
Please enter the key pair name[default name: server256]:
# Display information about local certificates in PKI domain server256.
[RouterA] display pki certificate domain server256 local
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 3 (0x3)
Signature Algorithm: ecdsa-with-SHA256
Issuer: C=CN, ST=Beijing, L=Beijing, O=H3C, OU=Software, CN=SuiteB CA
Validity
Not Before: Aug 21 08:39:51 2015 GMT
Not After : Aug 20 08:39:51 2016 GMT
Subject: C=CN, ST=Beijing, O=H3C, OU=Software, CN=SSH Server secp256
Subject Public Key Info:
Public Key Algorithm: id-ecPublicKey
Public-Key: (256 bit)
pub:
04:a2:b4:b4:66:1e:3b:d5:50:50:0e:55:19:8d:52:
6d:47:8c:3d:3d:96:75:88:2f:9a:ba:a2:a7:f9:ef:
0a:a9:20:b7:b6:6a:90:0e:f8:c6:de:15:a2:23:81:
3c:9e:a2:b7:83:87:b9:ad:28:c8:2a:5e:58:11:8e:
c7:61:4a:52:51
ASN1 OID: prime256v1
NIST CURVE: P-256
X509v3 extensions:
X509v3 Basic Constraints:
CA:FALSE
Netscape Comment:
OpenSSL Generated Certificate
X509v3 Subject Key Identifier:
08:C1:F1:AA:97:45:19:6A:DA:4A:F2:87:A1:1A:E8:30:BD:31:30:D7
X509v3 Authority Key Identifier:
keyid:5A:BE:85:49:16:E5:EB:33:80:25:EB:D8:91:50:B4:E6:3E:4F:B8:22
30:65:02:31:00:a9:16:e9:c1:76:f0:32:fc:4b:f9:8f:b6:7f:
31:a0:9f:de:a7:cc:33:29:27:2c:71:2e:f9:0d:74:cb:25:c9:
00:d2:52:18:7f:58:3f:cc:7e:8b:d3:42:65:00:cb:63:f8:02:
30:01:a2:f6:a1:51:04:1c:61:78:f6:6b:7e:f9:f9:42:8d:7c:
a7:bb:47:7c:2a:85:67:0d:81:12:0b:02:98:bc:06:1f:c1:3c:
9b:c2:1b:4c:44:38:5a:14:b2:48:63:02:2b
# Create a PKI domain named client256 for the client's certificate and enter its view.
[RouterA] pki domain client256
[RouterA-pki-domain-client256] undo crl check enable
[RouterA-pki-domain-client256] quit
# Import local certificate file ssh-client-ecdsa256.p12 to PKI domain client256.
[RouterA] pki import domain client256 p12 local filename ssh-client-ecdsa256.p12
Please enter the key pair name[default name: client256]:
# Display information about local certificates in PKI domain client256.
[RouterA] display pki certificate domain client256 local
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 4 (0x4)
Validity
Not Before: Aug 21 08:41:09 2015 GMT
Not After : Aug 20 08:41:09 2016 GMT
Subject: C=CN, ST=Beijing, O=H3C, OU=Software, CN=SSH Client secp256
pub:
04:da:e2:26:45:87:7a:63:20:e7:ca:7f:82:19:f5:
96:88:3e:25:46:f8:2f:9a:4c:70:61:35:db:e4:39:
b8:38:c4:60:4a:65:28:49:14:32:3c:cc:6d:cd:34:
29:83:84:74:a7:2d:0e:75:1c:c2:52:58:1e:22:16:
12:d0:b4:8a:92
NIST CURVE: P-256
X509v3 extensions:
CA:FALSE
Netscape Comment:
1A:61:60:4D:76:40:B8:BA:5D:A1:3C:60:BC:57:98:35:20:79:80:FC
30:66:02:31:00:9a:6d:fd:7d:ab:ae:54:9a:81:71:e6:bb:ad:
5a:2e:dc:1d:b3:8a:bf:ce:ee:71:4e:8f:d9:93:7f:a3:48:a1:
5c:17:cb:22:fa:8f:b3:e5:76:89:06:9f:96:47:dc:34:87:02:
31:00:e3:af:2a:8f:d6:8d:1f:3a:2b:ae:2f:97:b3:52:63:b6:
18:67:70:2c:93:2a:41:c0:e7:fa:93:20:09:4d:f4:bf:d0:11:
66:0f:48:56:01:1e:c3:be:37:4e:49:19:cf:c6
# Upload the server's certificate file ssh-server-ecdsa256.p12 and the client's certificate file ssh-client-ecdsa256.p12 to the Stelnet server through FTP or TFTP. (Details not shown.)
# Create a PKI domain named client256 for verifying the client's certificate and import the file of the client's certificate to this domain. (Details not shown.)
# Create a PKI domain named server256 for the server's certificate and import the file of the server's certificate to this domain. (Details not shown.)
# Specify Suite B algorithms for algorithm negotiation.
[RouterB] ssh2 algorithm key-exchange ecdh-sha2-nistp256
[RouterB] ssh2 algorithm cipher aes128-gcm
[RouterB] ssh2 algorithm public-key x509v3-ecdsa-sha2-nistp256 x509v3-ecdsa-sha2-nistp384
# Specify server256 as the PKI domain of the server's certificate.
[RouterB] ssh server pki-domain server256
# Create a local device management user named client001. Authorize the user to use the SSH service and assign the network-admin user role to the user.
# Create an SSH user named client001. Specify the publickey authentication method for the user and specify client256 as the PKI domain for verifying the client's certificate.
[RouterB] ssh user client001 service-type stelnet authentication-type publickey assign pki-domain client256
3. Establish an SSH connection to the Stelnet server based on the 128-bit Suite B algorithms:
# Establish an SSH connection to the server at 192.168.1.40.
<RouterA> ssh2 192.168.1.40 suite-b 128-bit pki-domain client256 server-pki-domain server256
Username: client001
<RouterB>
SFTP configuration examples
Example: Configuring the device as an SFTP server (password authentication)
As shown in Figure 13:
· The router acts as the SFTP server and uses password authentication to authenticate the SFTP client. The username and password of the client are saved on the router.
· The host acts as the SFTP client. After the user on the client logs in to the router through SFTP, the user can perform file management and transfer operations on the router as a network administrator.
The device supports different types of SFTP client software. This example uses an SFTP client that runs PSFTP of PuTTY version 0.58.
PSFTP supports only password authentication.
Generating Keys...
Generating Keys...
Generating Keys...
# Enable the SFTP server.
[Router] sftp server enable
# Assign an IP address to Ten-GigabitEthernet 3/0/1. The client uses this address as the destination for SSH connection.
[Router-Ten-GigabitEthernet3/0/1] ip address 192.168.1.45 255.255.255.0
# Set the password to 123456TESTplat&! in plain text for local user client002.
[Router-luser-manage-client002] password simple 123456TESTplat&!
# Assign the network-admin user role and working directory flash:/ to local user client002.
[Router-luser-manage-client002] authorization-attribute user-role network-admin work-directory flash:/
# Create an SSH user named client002. Specify the authentication method as password and service type as sftp for the user.
[Router] ssh user client002 service-type sftp authentication-type password
2. Establish a connection to the SFTP server:
a. Run the psftp.exe to launch the client interface shown in Figure 14, and enter the following command:
open 192.168.1.45
b. Enter username client002 and password 123456TESTplat&! to log in to the SFTP server.
Figure 14 SFTP client interface
Example: Configuring the device as an SFTP client (publickey authentication)
As shown in Figure 15:
· Router B acts as the SFTP server, and it uses publickey authentication and the RSA public key algorithm.
· Router A acts as the SFTP client. After the user on Router A logs in to Router B through SFTP, the user can perform file management and transfer operations on Router B as a network administrator.
In the server configuration, the client's host public key is required. Generate RSA key pairs on the client before configuring the SFTP server.
1. Configure the SFTP client:
[RouterA-Ten-GigabitEthernet3/0/1] ip address 192.168.0.2 255.255.255.0
[RouterA] public-key local create rsa
Generating Keys...
# Export the host public key to a public key file named pubkey.
[RouterA] public-key local export rsa ssh2 pubkey
[RouterA] quit
# Transmit the public key file pubkey to the server through FTP or TFTP. (Details not shown.)
2. Configure the SFTP server:
Generating Keys...
Generating Keys...
Generating Keys...
[RouterB] sftp server enable
# Assign an IP address to Ten-GigabitEthernet 3/0/1. The client uses this address as the destination address for SSH connection.
[RouterB-Ten-GigabitEthernet3/0/1] ip address 192.168.0.1 255.255.255.0
# Import the peer public key from the public key file pubkey, and name it routerkey.
[RouterB] public-key peer routerkey import sshkey pubkey
# Create an SSH user named client001. Specify the service type as sftp and the authentication method as publickey for the user. Assign the public key routerkey to the user.
[RouterB] ssh user client001 service-type sftp authentication-type publickey assign publickey routerkey
# Assign the network-admin user role and working directory flash:/ to local user client001.
[RouterB-luser-manage-client001] authorization-attribute user-role network-admin work-directory flash:/
3. Establish a connection between the SFTP client and the SFTP server:
# Establish a connection to the SFTP server and enter SFTP client view.
<RouterA> sftp 192.168.0.1 identity-key rsa
Username: client001
Connecting to 192.168.0.1 port 22.
sftp>
# Display files under the current directory of the server, delete file z, and verify the result.
sftp> dir -l
-rwxrwxrwx 1 1 1 1759 Aug 23 06:52 config.cfg
-rwxrwxrwx 1 1 1 225 Aug 24 08:01 pubkey2
-rwxrwxrwx 1 1 1 283 Aug 24 07:39 pubkey
drwxrwxrwx 1 1 1 0 Sep 01 06:22 new
-rwxrwxrwx 1 1 1 225 Sep 01 06:55 pub
-rwxrwxrwx 1 1 1 0 Sep 01 08:00 z
sftp> delete z
Removing /z
sftp> dir -l
# Add a directory named new1 and verify the result.
sftp> mkdir new1
sftp> dir -l
drwxrwxrwx 1 1 1 0 Sep 02 06:30 new1
# Change the name of directory new1 to new2 and verify the result.
sftp> rename new1 new2
sftp> dir
drwxrwxrwx 1 1 1 0 Sep 02 06:33 new2
# Download file pubkey2 from the server and save it as a local file named public.
sftp> get pubkey2 public
Fetching / pubkey2 to public
/pubkey2 100% 225 1.4KB/s 00:00
# Upload a local file pu to the server, save it as puk, and verify the result.
sftp> put pu puk
Uploading pu to / puk
sftp> dir
-rwxrwxrwx 1 1 1 283 Sep 02 06:35 pub
-rwxrwxrwx 1 1 1 283 Sep 02 06:36 puk
sftp>
# Exit SFTP client view.
sftp> quit
<RouterA>
Example: Configuring SFTP based on 192-bit Suite B algorithms
As shown in Figure 16:
· Router B acts as the SFTP Suite B server (SSH2), and it uses publickey authentication to authenticate the SFTP client.
· Router A acts as an SFTP Suite B client (SSH2). After the user on Router A logs in to Router B based on the SFTP Suite B client software, the user can manage and transfer files on Router B as an administrator.
Before you configure SFTP, first configure the certificates of the server and the client because they are required for identity authentication.
You can modify the pkix version of the client software OpenSSH to support Suite B. This example uses an H3C router as an SFTP client.
# Upload the server's certificate file ssh-server-ecdsa384.p12 and the client's certificate file ssh-client-ecdsa384.p12 to the SFTP client through FTP or TFTP. (Details not shown.)
# Create a PKI domain named server384 for verifying the server's certificate and enter its view.
[RouterA] pki domain server384
[RouterA-pki-domain-server384] undo crl check enable
[RouterA-pki-domain-server384] quit
# Import local certificate file ssh-server-ecdsa384.p12 to PKI domain server384.
[RouterA] pki import domain server384 p12 local filename ssh-server-ecdsa384.p12
Please enter the key pair name[default name: server384]:
# Display information about local certificates in PKI domain server384.
[RouterA] display pki certificate domain server384 local
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 1 (0x1)
Signature Algorithm: ecdsa-with-SHA384
Validity
Not Before: Aug 20 10:08:41 2015 GMT
Not After : Aug 19 10:08:41 2016 GMT
Subject: C=CN, ST=Beijing, O=H3C, OU=Software, CN=ssh server
Public-Key: (384 bit)
pub:
04:4a:33:e5:99:8d:49:45:a7:a3:24:7b:32:6a:ed:
b6:36:e1:4d:cc:8c:05:22:f4:3a:7c:5d:b7:be:d1:
e6:9e:f0:ce:95:39:ca:fd:a0:86:cd:54:ab:49:60:
10:be:67:9f:90:3a:18:e2:7d:d9:5f:72:27:09:e7:
bf:7e:64:0a:59:bb:b3:7d:ae:88:14:94:45:b9:34:
d2:f3:93:e1:ba:b4:50:15:eb:e5:45:24:31:10:c7:
07:01:f9:dc:a5:6f:81
ASN1 OID: secp384r1
NIST CURVE: P-384
X509v3 extensions:
CA:FALSE
Netscape Comment:
10:16:64:2C:DA:C1:D1:29:CD:C0:74:40:A9:70:BD:62:8A:BB:F4:D5
30:65:02:31:00:80:50:7a:4f:c5:cd:6a:c3:57:13:7f:e9:da:
c1:72:7f:45:30:17:c2:a7:d3:ec:73:3d:5f:4d:e3:96:f6:a3:
33:fb:e4:b9:ff:47:f1:af:9d:e3:03:d2:24:53:40:09:5b:02:
30:45:d1:bf:51:fd:da:22:11:90:03:f9:d4:05:ec:d6:7c:41:
fc:9d:a1:fd:5b:8c:73:f8:b6:4c:c3:41:f7:c6:7f:2f:05:2d:
37:f8:52:52:26:99:28:97:ac:6e:f9:c7:01
# Create a PKI domain named client384 for the client's certificate and enter its view.
[RouterA] pki domain client384
[RouterA-pki-domain-client384] undo crl check enable
[RouterA-pki-domain-client384] quit
# Import local certificate file ssh-client-ecdsa384.p12 to PKI domain client384.
[RouterA] pki import domain client384 p12 local filename ssh-client-ecdsa384.p12
Please enter the key pair name[default name: client384]:
# Display information about local certificates in PKI domain client384.
[RouterA]display pki certificate domain client384 local
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 2 (0x2)
Validity
Not Before: Aug 20 10:10:59 2015 GMT
Not After : Aug 19 10:10:59 2016 GMT
Subject: C=CN, ST=Beijing, O=H3C, OU=Software, CN=ssh client
pub:
04:85:7c:8b:f4:7a:36:bf:74:f6:7c:72:f9:08:69:
d0:b9:ac:89:98:17:c9:fc:89:94:43:da:9a:a6:89:
41:d3:72:24:9b:9a:29:a8:d1:ba:b4:e5:77:ba:fc:
df:ae:c6:dd:46:72:ab:bc:d1:7f:18:7d:54:88:f6:
b4:06:54:7e:e7:4d:49:b4:07:dc:30:54:4b:b6:5b:
01:10:51:6b:0c:6d:a3:b1:4b:c9:d9:6c:d6:be:13:
91:70:31:2a:92:00:76
ASN1 OID: secp384r1
NIST CURVE: P-384
X509v3 extensions:
CA:FALSE
Netscape Comment:
BD:5F:8E:4F:7B:FE:74:03:5A:D1:94:DB:CA:A7:82:D6:F7:78:A1:B0
30:66:02:31:00:d2:06:fa:2c:0b:0d:f0:81:90:01:c3:3d:bf:
97:b3:79:d8:25:a0:e2:0e:ed:00:c9:48:3e:c9:71:43:c9:b4:
2a:a6:0a:27:80:9e:d4:0f:f2:db:db:5b:40:b1:a9:0a:e4:02:
31:00:ee:00:e1:07:c0:2f:12:3f:88:ea:fe:19:05:ef:56:ca:
33:71:75:5e:11:c9:a6:51:4b:3e:7c:eb:2a:4d:87:2b:71:7c:
30:64:fe:14:ce:06:d5:0a:e2:cf:9a:69:19:ff
# Upload the server's certificate file ssh-server-ecdsa384.p12 and the client's certificate file ssh-client-ecdsa384.p12 to the SFTP server through FTP or TFTP. (Details not shown.)
# Create a PKI domain named client384 for verifying the client's certificate and import the file of the client's certificate to this domain. (Details not shown.)
# Create a PKI domain named server384 for the server's certificate and import the file of the server's certificate to this domain. (Details not shown.)
[RouterB] ssh2 algorithm key-exchange ecdh-sha2-nistp384
[RouterB] ssh2 algorithm cipher aes256-gcm
[RouterB] ssh2 algorithm public-key x509v3-ecdsa-sha2-nistp384
# Specify server384 as the PKI domain of the server's certificate.
[RouterB] ssh server pki-domain server384
# Create an SSH user named client001. Specify the publickey authentication method for the user and specify client384 as the PKI domain for verifying the client's certificate.
[RouterB] ssh user client001 service-type sftp authentication-type publickey assign pki-domain client384
3. Establish an SFTP connection to the SFTP server based on the 192-bit Suite B algorithms:
# Establish an SFTP connection to the server at 192.168.0.1.
<RouterA> sftp 192.168.0.1 suite-b 192-bit pki-domain client384 server-pki-domain server384
Username: client001
sftp>
SCP configuration examples
Example: Configuring SCP with password authentication
As shown in Figure 17:
· Router B acts as the SCP server and uses password authentication to authenticate the SCP client. The client's username and password are saved on Router B.
· Router A acts as the SCP client. After the user on Router A logs in to Router B through SCP, the user can transfer files between routers as a network administrator.
1. Configure the SCP server:
Generating Keys...
Generating Keys...
Generating Keys...
# Enable the SCP server.
[RouterB] scp server enable
# Configure an IP address for Ten-GigabitEthernet 3/0/1. The client uses this address as the destination for SCP connection.
# Create an SSH user named client001. Specify the service type as scp and the authentication method as password for the user.
[RouterB] ssh user client001 service-type scp authentication-type password
2. Configure an IP address for Ten-GigabitEthernet 3/0/1 on the SCP client.
[RouterA] quit
3. Connect to the SCP server, download file remote.bin from the server, and save it as a local file named local.bin.
<RouterA> scp 192.168.0.1 get remote.bin local.bin
Username: client001
[email protected]’s password:
remote.bin 100% 2875 2.8KB/s 00:00
Example: Configuring SCP file transfer with a Linux SCP client
As shown in Figure 18, the router acts as the SCP server and uses password authentication to authenticate the SCP client. The client's username and password are saved on the router.
The device acts as the SCP client. After the user on the device logs in to the router through SCP, the user can transfer files with the router as a network administrator.
# Generate an RSA key pair.
The range of public key modulus is (512 ~ 4096).
Generating Keys...
Generating Keys...
Generating Keys...
[Router] scp server enable
# Configure an IP address for Ten-GigabitEthernet 3/0/1. The SCP client uses this IP address as the destination address of the SCP connection.
[Router-Ten-GigabitEthernet3/0/1] ip address 192.168.0.1 255.255.255.0
# Create a local device management user named client001. Set a password for the user, authorize the user to use the SSH service, assign the network-admin user role to the user, and specify the working directory as flash:/.
[Router-luser-manage-client001] authorization-attribute user-role network-admin work-directory flash:/
# Configure an SSH user named client001, specify the SCP service for the SSH user, and set the authentication method as password. (This step is optional.)
[Router] ssh user client001 service-type scp authentication-type password
2. Configure the SCP client:
The following uses the SCP client running on a Linux system as an example:
# Connect to the SCP server, download the remote.bin file from the server, and save it as a local file named local.bin.
admin@device:~# scp [email protected]:remote.bin local.bin
remote.bin 100% 15
0.0KB/s 00:00
Example: Configuring SCP based on Suite B algorithms
As shown in Figure 19:
· Router B acts as the SCP Suite B server (SSH2), and it uses publickey authentication to authenticate the SCP client.
· Router A acts as an SCP Suite B client (SSH2). After the user on Router A logs in to Router B through SCP based on the SCP Suite B client software, the user can transfer files between routers as a network administrator.
Before you configure SCP, first configure the certificates of the server and the client because they are required for identity authentication.
You can modify the pkix version of the client software OpenSSH to support Suite B. This example uses an H3C router as an SCP client.
1. Configure the SCP client:
# Upload the server's certificate files (ssh-server-ecdsa256.p12 and ssh-server-ecdsa384.p12) and the client's certificate files (ssh-client-ecdsa256.p12 and ssh-client-ecdsa384.p12) to the SCP client through FTP or TFTP. (Details not shown.)
# Create a PKI domain named server256 for verifying the server's certificate ecdsa256 and enter its view.
Certificate:
Data:
Version: 3 (0x2)
Validity
pub:
c7:61:4a:52:51
NIST CURVE: P-256
X509v3 extensions:
CA:FALSE
Netscape Comment:
# Create a PKI domain named client256 for the client's certificate ecdsa256 and enter its view.
Certificate:
Data:
Version: 3 (0x2)
Validity
pub:
12:d0:b4:8a:92
NIST CURVE: P-256
X509v3 extensions:
CA:FALSE
Netscape Comment:
# Create a PKI domain named server384 for verifying the server's certificate ecdsa384 and enter its view.
Certificate:
Data:
Version: 3 (0x2)
Validity
pub:
ASN1 OID: secp384r1
NIST CURVE: P-384
X509v3 extensions:
CA:FALSE
Netscape Comment:
# Create a PKI domain named client384 for the client's certificate ecdsa384 and enter its view.
[RouterA] display pki certificate domain client384 local
Certificate:
Data:
Version: 3 (0x2)
Validity
pub:
ASN1 OID: secp384r1
NIST CURVE: P-384
X509v3 extensions:
CA:FALSE
Netscape Comment:
[RouterA] quit
2. Configure the SCP server:
# Upload the server's certificate files (ssh-server-ecdsa256.p12 and ssh-server-ecdsa384.p12) and the client's certificate files (ssh-client-ecdsa256.p12 and ssh-client-ecdsa384.p12) to the SCP server through FTP or TFTP. (Details not shown.)
# Create a PKI domain named client256 for verifying the client's certificate ecdsa256 and import the file of this certificate to this domain. Create a PKI domain named server256 for the server's certificate ecdsa256 and import the file of this certificate to this domain. (Details not shown.)
# Create a PKI domain named client384 for verifying the client's certificate ecdsa384 and import the file of this certificate to this domain. Create a PKI domain named server384 for the server's certificate ecdsa384 and import the file of this certificate to this domain. (Details not shown.)
[RouterB] ssh2 algorithm key-exchange ecdh-sha2-nistp256 ecdh-sha2-nistp384
[RouterB] ssh2 algorithm cipher aes128-gcm aes256-gcm
# Create a local device management user named client002. Authorize the user to use the SSH service and assign the network-admin user role to the user.
3. Establish an SCP connection to the SCP server:
¡ Based on the 128-bit Suite B algorithms:
# Create an SSH user client001. Specify the authentication method publickey for the user and specify client256 as the PKI domain for verifying the client's certificate.
[RouterB] ssh user client001 service-type scp authentication-type publickey assign pki-domain client256
# Establish an SCP connection to the SCP server at 192.168.0.1 based on the 128-bit Suite B algorithms.
<RouterA> scp 192.168.0.1 get src.cfg suite-b 128-bit pki-domain client256 server-pki-domain server256
Username: client001
src.cfg 100% 4814 4.7KB/s 00:00
<RouterA>
¡ Based on the 192-bit Suite B algorithms:
# Create an SSH user client002. Specify the publickey authentication method for the user and specify client384 as the PKI domain for verifying the client's certificate.
[RouterB] ssh user client002 service-type scp authentication-type publickey assign pki-domain client384
# Establish an SCP connection to the SCP server at 192.168.0.1 based on the 192-bit Suite B algorithms.
<RouterA> scp 192.168.0.1 get src.cfg suite-b 192-bit pki-domain client384 server-pki-domain server384
Username: client002
<RouterA>
NETCONF over SSH configuration examples
Example: Configuring NETCONF over SSH with password authentication
As shown in Figure 20:
· The router acts as the NETCONF-over-SSH server and uses password authentication to authenticate the client. The client's username and password are saved on the router.
· The host acts as the NETCONF-over-SSH client, using SSH2 client software. After the user on the host logs in to the router through NETCONF over SSH, the user can perform NETCONF operations on the router as a network administrator.
Generating Keys...
Generating Keys...
Generating Keys...
# Enable NETCONF over SSH.
[Router] netconf ssh server enable
# Configure an IP address for Ten-GigabitEthernet 3/0/1. The client uses this address as the destination for NETCONF-over-SSH connection.
# Create an SSH user named client001. Specify the service type as NETCONF and the authentication method as password for the user.
[Router] ssh user client001 service-type netconf authentication-type password
# Verify that you can perform NETCONF operations after logging in to the router. (Details not shown.)
