13-High Availability Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R8530Pxx-6W10213-High Availability Command Reference
11-Failover group commands
11-Failover group commands 66.69 KB
bind-vrrp
Use bind vrrp to bind a failover group to a VRRP group.
Use undo bind vrrp to unbind a failover group from a VRRP group.
bind-vrrp virtual-router-id interface interface-type interface-number
undo bind-vrrp
A failover group is not bound to any VRRP group.
Failover group view
virtual-router-id: Specifies a VRRP group by its virtual router ID in the range of 1 to 255.
interface interface-type interface-number: Specifies an interface by its type and number. The VRRP group is created on the interface.
To back up services for nodes on two independent systems, configure inter-system service backup by binding the failover group to a VRRP group. VRRP determines the status of the nodes in the failover group and backs up services from the node on the master to the node on the backup.
You cannot bind a failover group to a VRRP group if the following conditions exist:
·     The failover group is associated with a service instance group.
·     The service instance group is used by a NAT instance configured with load sharing or bound to a static address pool.
# Bind failover group group1 to VRRP group 1 created on Ten-GigabitEthernet 3/0/1.
[Sysname] failover group Group1
[Sysname-failover-group-Group1] bind-vrrp 1 interface ten-gigabitethernet 3/0/1
display failover
Use display failover to display failover group information.
display failover { group [ group-name ] | group-name group-name }
group-name: Specifies a failover group by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a failover group, this command displays brief information about all failover groups. If you specify a failover group used for inter-system service backup, this command displays detailed information about the specified failover group.
You can use either the display failover group [ group-name ] or display failover group-name group-name command to display failover group information. The commands have the same output. To display information about a failover group named >, >>, or |, use the display failover group-name group-name command.
# Display information about all failover groups. (Devices that support inter-system service backup.)
<Sysname> display failover group
Stateful failover remote group information:
ID Name                             Local    Peer      Active status
1  group1                           NA       1.1.1.2   Local
# Display detailed information about failover group group3. (Devices that support inter-system service backup.)
<Sysname> display failover group group3
 Active status     : Local
 Local node        : NA
 Local IP address  : NA
 Peer IP address   : NA
 Port number       : NA
 Bound VRRP ID     : NA
 VRRP interface    : NA
 VRRP status       : Inactive
Information about the failover group used for inter-system service backup.
ID
ID of the failover group.
Name
Name of the failover group.
Local
The node on the local system.
Peer
IP address of the peer interface on the backup link.
Active status
The state of the failover group:
·     Primary—The primary node is processing services.
·     Secondary—The secondary node is processing services.
·     Initial—No node in the failover group is processing services.
·     Local—The local node is processing services.
·     Peer—The peer node is processing services.
Local node
Local IP address
IP address of the local interface on the backup link.
Peer IP address
Port number
Port number of the failover group.
Bound VRRP ID
Number of the VRRP group that is bound to the failover group.
VRRP interface
Interface where the VRRP group is created.
VRRP status
Role of the device in the VRRP group.
failover group
Use failover group to create a failover group and enter its view, or enter the view of an existing failover group.
Use undo failover group to delete a failover group.
failover group group-name [ id group-id ]
undo failover group group-name
No failover groups exist.
id group-id: Specifies a failover group by its ID, in the range of 1 to 64. This option is required when you create a failover group. It is optional when you enter failover group view. The group ID and the group name can both identify a failover group. The group name is mainly used to identify a failover group on the local device. The group ID is mainly used to exchange messages between devices in a failover group.
A failover group backs up services (such as NAT) between two CPUs to ensure high availability.
You can execute this command multiple times to create more failover groups.
# Create failover group Group1 with group ID 1 and enter its view. (Devices that support inter-system service backup.)
[Sysname] failover group Group1 id 1
[Sysname-failover-group-group1]
remote-backup
Use remote-backup to specify a backup channel for inter-system service backup.
Use undo remote-backup to remove the backup channel configuration.
remote-backup local ip-address peer peer-ip-address port port-number
undo remote-backup
No backup channel is specified for inter-system service backup.
local ip-address: Specifies a local IP address.
peer peer-ip-address: Specifies a peer IP address.
port port-number: Specifies a port number in the range of 1024 to 55535. The port number cannot be a known port number or port number in use.
Set up the backup link by using two IP addresses that can reach each other.
This command applies to inter-system service backup. You must execute this command on both of the systems and configure the same port number for them.
As a best practice, use a direct link for backup packets. If the physical interface on the link transmits multiple types of traffic, create a dedicated subinterface for each kind of traffic.
# Specify a backup channel for inter-system service backup. The local IP address is 192.168.2.125, the peer IP address is 192.168.3.142, and the port number is 3000.
[Sysname] failover group group1 id 1
[Sysname-failover-group-group1] remote-backup local 192.168.2.125 peer 192.168.3.142 port 3000
