| 00-Preface | 110.36 KB |
Preface
This command reference covers the commands for configuring Segment Routing.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Support for slots varies by device model. All slot-related descriptions in this documentation are for illustration only. It is normal that the slots in the examples differ from those on your device. On a device to which this documentation applies, the slot-number argument in a command represents the entire device and is fixed at 0. The command applies to the entire device regardless of whether the slot number is specified.
Documentation feedback
We appreciate your comments.
