- 06-Layer 3—IP Services Command Reference
- 01-ARP commands
- 02-DHCPv6 commands
- 03-DHCP commands
- 04-IPv6 basics commands
- 05-IPv6 fast forwarding commands
- 06-IPv6 neighbor discovery commands
- 07-IP addressing commands
- 08-IP performance optimization commands
- 09-IP forwarding basics commands
- 10-IRDP commands
- 11-WAAS commands
- 12-DNS commands
- 13-Multi-CPU packet distribution commands
- 14-Fast forwarding commands
- 15-Adjacency table commands
| 00-Preface | 110.22 KB |
Preface
This command reference covers the commands for configuring and managing IP addressing (including static and dynamic IPv4 and IPv6 address assignment), network performance optimization, ARP, and interoperation between IPv4 and IPv6.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
