02-SRv6 commands | 413.97 KB |
display bgp egress-engineering ipv6
display bgp egress-engineering srv6 peer-set
display ipv6 segment-routing sid-list
display isis segment-routing ipv6 capability
display isis segment-routing ipv6 locator
display ospfv3 segment-routing ipv6 capability
display ospfv3 segment-routing ipv6 locator
display segment-routing ipv6 forwarding
display segment-routing ipv6 local-sid
display segment-routing ipv6 locator
display segment-routing ipv6 pd-info
fast-reroute microloop-avoidance enable (IS-IS IPv6 address family)
fast-reroute microloop-avoidance rib-update-delay (IS-IS IPv6 address family)
isis ipv6 fast-reroute ti-lfa disable
ospfv3 fast-reroute ti-lfa disable
segment-routing ipv6 (system view)
segment-routing ipv6 compatible locator-fixed-length
segment-routing ipv6 egress-engineering locator
segment-routing ipv6 locator (BGP IPv6 unicast address family view)
segment-routing ipv6 locator (IS-IS IPv6 address family view)
segment-routing ipv6 locator (OSPFv3 process view)
segment-routing ipv6 private-srv6-extensions compatible
segment-routing microloop-avoidance enable
segment-routing microloop-avoidance rib-update-delay
srv6 compress enable (IS-IS IPv6 address family view)
srv6 compress enable (SRv6 view)
SRv6 commands
The MSR 56-60 and MSR 56-80 routers installed with the MPU-100-G modules do not support parameters or commands that are available only in IRF mode.
diffserv-mode
Use diffserv-mode to configure the SRv6 DiffServ mode.
Use undo diffserv-mode to restore the default.
diffserv-mode { ingress { pipe service-class | short-pipe service-class | uniform } egress { pipe | short-pipe | uniform } | { pipe service-class | short-pipe service-class | uniform } }
undo diffserv-mode
The SRv6 DiffServ mode is pipe. The traffic class is 0 for packets that enters the SRv6 network from the IP network.
SRv6 view
ingress: Specifies the inbound direction.
egress: Specifies the outbound direction.
pipe: Specifies the pipe mode.
short-pipe: Specifies the short-pipe mode.
uniform: Specifies the uniform mode.
service-class: Specifies a traffic class for packets that enters the SRv6 network from the IP network. The value range for the traffic class is 0 to 7.
The following SRv6 DiffServ modes are available:
· Pipe mode—When a packet enters the SRv6 network, the ingress node adds a new IPv6 header to the original packet. The ingress node ignores the IP precedence or DSCP value in the original packet and uses the value specified by using the service-class argument as the traffic class in the new IPv6 header. In the SRv6 network, SRv6 nodes perform QoS scheduling for the packet based on the specified traffic class. When the packet leaves the SRv6 network, the egress node removes the outer IPv6 header from the packet without modifying the IP precedence or DSCP value in the original packet.
· Short-pipe mode—When a packet enters and leaves the SRv6 network, all SRv6 nodes process the packet in the same way as in pipe mode except for the egress node. After the egress node removes the outer IPv6 header from the packet, it performs QoS scheduling as follows:
¡ If no priority trust mode is configured, the egress node performs QoS scheduling for the packet based on the IP precedence or DSCP value in the original packet.
¡ If a priority trust mode is configured, the egress node performs QoS scheduling for the packet based on the trusted priority.
· Uniform mode—When a packet enters the IPv6 network, the ingress node maps the IP precedence or DSCP value in the original IP header to the outer IPv6 header as the traffic class. When the packet leaves the SRv6 network, the egress node maps the traffic class value in the outer IPv6 header to the original packet as the IP precedence or DSCP value.
The priority accuracy has changes when the DSCP value and traffic class value are mapped to each other.
To specify different DiffServ modes for the inbound and outbound directions, use the diffserv-mode command with the ingress and egress keywords. To specify the same DiffServ mode for the inbound and outbound directions, use the diffserv-mode command without the ingress or egress keyword.
If you execute the diffserv-mode command multiple times, the most recent configuration takes effect.
When you configure the SRv6 DiffServ mode on the source and destination nodes of an SRv6 tunnel, follow these restrictions and guidelines:
· The outbound DiffServ mode on the local end must be the same as the inbound DiffServ mode on the peer end.
· The inbound DiffServ mode on the local end must be the same as the outbound DiffServ mode on the peer end.
For more information about IP precedence and DSCP, see priority mapping configuration in QoS Configuration Guide.
# Configure the SRv6 DiffServ mode as uniform.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] diffserv-mode uniform
Use display bgp egress-engineering ipv6 to display BGP-EPE information for IPv6 peers.
display bgp [ instance instance-name ] egress-engineering ipv6 [ ipv6-address ] [ verbose ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays information about the default BGP instance.
ipv6-address: Specifies an IPv6 peer by its IPv6 address. The specified IPv6 peer must already exist. If you do not specify an IPv6 peer, this command displays BGP-EPE information for all IPv6 peers.
verbose: Displays detailed BGP-EPE information. If you do not specify this keyword, the command displays only brief BGP-EPE information.
# Display BGP-EPE information for all IPv6 peers.
<Sysname> display bgp egress-engineering ipv6
BGP peering segment type: Node-Adjacency
Peer NodeAdj : 2::9
Local AS number : 100
Remote AS number : 200
Local router ID : 1.1.1.9
Remote router ID : 2.2.2.9
Interface : GE1/0/1
OriginalNextHop : 2::9
RelayNextHop : FE80::28B6:9EFF:FE23:206
Interface : GE1/0/2
RelayNextHop : FE80::28B6:9EFF:FE23:208
# Display detailed BGP-EPE information for all IPv6 peers.
<Sysname> display bgp egress-engineering ipv6 verbose
PeerAdj Num : 2
Nexthop : 2::9
Local interface address : 10::1
Remote interface address : 10::2
SID(no PSP, no USP) : 200::1
SID(PSP) : 200::2
Local interface address : 20::1
Remote interface address : 20::2
SID(PSP) : 200::2
BGP peering segment type : Adjacency
PeerAdj : FE80::28B6:9EFF:FE23:206
Local interface address : FE80::28B6:9EFF:FE23:D16
Remote interface address : FE80::28B6:9EFF:FE23:206
Interface : GE1/0/1
SID(no PSP, no USP) : 200::3
SID(PSP) : 200::4
PeerAdj : FE80::28B6:9EFF:FE23:208
Local interface address : FE80::28B6:9EFF:FE23:D18
Remote interface address : FE80::28B6:9EFF:FE23:208
Interface : GE1/0/2
SID(no PSP, no USP) : 200::5
SID(PSP) : 200::6
BGP peering segment type |
BGP peering segment type of the peer: · Node—Node type. · Adjacency—Adjacency type. · Node-Adjacency—Node and adjacency type. |
Peer Node |
Address of the node-type peer. |
Peer Adj |
Address of the adjacency-type peer. |
Peer NodeAdj |
Address of the node- and adjacency-type peer. |
PeerAdj Num |
Number of adjacency-type peers. |
Information about the interface used to establish peer relationship. |
OriginalNextHop |
IP address of the original next hop. |
RelayNextHop |
IP address of the recursed next hop. |
SID(PSP) |
End.X SID (PSP flavor). |
SID(no PSP, no USP) |
End.X SID (non-PSP and non-USP flavor). |
Use display bgp egress-engineering srv6 peer-set to display information about BGP-EPE SRv6 peer sets.
display bgp egress-engineering srv6 peer-set [ srv6-peer-set-name ]
peer-set-name: Specifies a BGP-EPE SRv6 peer set by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a BGP-EPE SRv6 peer set, this command displays information about all BGP-EPE SRv6 peer sets.
# Display information about all BGP-EPE SRv6 peer sets.
<Sysname> display bgp egress-engineering srv6 peer-set
BGP egress peering segment srv6 peer-set: abc
StaticSID(PSP) : 210::11
StaticSID(no PSP, no USP): 210::12
SID(PSP) : 101::1:0:0
SID(no PSP, no USP) : 101::1:0:1
Members: 1
Peer: 4:4:4::4
BGP egress peering segment srv6 peer-set |
Name of a BGP-EPE SRv6 peer set. |
StaticSID(PSP) |
Manually configured End.X SID (PSP flavor type). |
StaticSID(noPSP, noUSP) |
Manually configured End.X SID (non-PSP and non-USP flavor type). |
SID(PSP) |
Automatically allocated End.X SID (PSP flavor). |
Automatically allocated End.X SID (non-PSP and non-USP flavor). |
Members |
Number of peers in the BGP-EPE SRv6 peer set. |
Peer |
Peer in the BGP-EPE SRv6 peer set. |
Use display ipv6 segment-routing sid-list to display SID list information.
display ipv6 segment-routing sid-list [ list-name ]
list-name: Specifies an SID list by its name, a case-sensitive string of 1 to 31 characters. If you do not specify an SID list, this command displays information for all SID lists.
# Display information for SID list aa.
<Sysname> display ipv6 segment-routing sid-list aa
SID list name: aa
SID information:
SID index Address
1 10::1
2 20::1
3 30::1
SID list usage on tunnels:
Tunnel number SID list role
0 Primary
1 Backup
2 Primary
Address |
IPv6 address of the SR node. |
SID list usage on tunnels |
SID list usage on SRv6 tunnels. |
SID list role |
Role of the SID list on an SRv6 tunnel: · Primary. · Backup. |
sid
tunnel sid-list
Use display isis segment-routing ipv6 capability to display IS-IS SRv6 capability information.
display isis segment-routing ipv6 capability [ level-1 | level-2 ] [ process-id ]
level-1: Specifies IS-IS Level-1.
level-2: Specifies IS-IS Level-2.
process-id: Specifies an IS-IS process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays SRv6 capability information for all IS-IS processes.
If you do not specify a level, this command displays IS-IS SRv6 capability information for both Level-1 and Level-2.
# Display SRv6 capability information for IS-IS process 1.
<Sysname> display isis segment-routing ipv6 capability level-1 1
IPv6 segment routing capability information for IS-IS(1)
Level-1 IPv6 segment routing capability
System ID SRv6 capability
0000.1000.0001 Enabled
0000.2000.0001 Enabled
0000.2000.0002 Enabled
0000.2000.0003 Enabled
System ID |
Neighbor system ID. |
SRv6 capability |
Whether SRv6 is enabled. |
Use display isis segment-routing ipv6 locator to display IS-IS SRv6 locator information.
display isis segment-routing ipv6 locator [ ipv6-address prefix-length ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
ipv6-address prefix-length: Specifies a destination IPv6 address prefix and the prefix length. The value range for the prefix-length argument is 1 to 128.
level-1: Specifies the level-1 area.
level-2: Specifies the level-2 area.
verbose: Displays detailed IS-IS SRv6 locator information. If you do not specify this keyword, the command displays only brief IS-IS SRv6 locator information.
process-id: Specifies an IS-IS process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays IS-IS SRv6 locator information for all IS-IS processes.
# Display IS-IS SRv6 locator information.
<Sysname> display isis segment-routing ipv6 locator
Level-1 Locator Route Table
Destination : 201:: PrefixLen: 64
Flags : R/-/- Cost : 2
Next hop : FE80::38A5:3DFF:FEE9:218 Interface: GE1/0/1
Destination : 202:: PrefixLen: 64
Flags : R/-/- Cost : 1
Next hop : FE80::38A5:3DFF:FEE9:218 Interface: GE1/0/3
Table 5 Command output
Destination |
Destination IPv6 prefix. |
PrefixLen |
Prefix length. |
Flag/Flags |
Route flags: · D—The route is a direct route. · R—The route has been flushed to the RIB. · L—The route has been advertised in LSPs. · U—Penetration flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2. |
Cost |
Route cost value. |
Next hop |
Route next hop. |
Output interface. |
display isis srv6 tunnel
Use display isis srv6 tunnel to display IS-IS SRv6 tunnel interface information.
display isis srv6 tunnel [ level-1 | level-2 ] [ process-id ]
process-id: Specifies an IS-IS process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays SRv6 tunnel interface information for all IS-IS processes.
If you do not specify a level, this command displays IS-IS SRv6 tunnel interface information for both level-1 and level-2 areas.
# Display SRv6 tunnel interface information for IS-IS process 1.
<Sysname> display isis srv6 tunnel
SRv6 tunnel information for IS-IS(1)
Level-1 tunnel statistics
Tunnel name Auto route Destination Metric
Tun0 Shortcut 1000::1 Relative 0
Level-2 tunnel statistics
Tun0 Shortcut 1000:: Relative 0
Table 6 Command output
Auto route |
Implementation method of automatic route advertisement on the tunnel interface: · Advertise—Forwarding adjacency. This method is not supported in the current software version. · Shortcut—IGP shortcut. |
Metric |
Metric of the tunnel interface. Supported metric types: · Relative. · Absolute. |
Use display ospfv3 segment-routing ipv6 capability to display OSPFv3 SRv6 capability information.
display ospfv3 [ process-id ] segment-routing ipv6 capability
process-id: Specifies an OSPFv3 process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays SRv6 capability information for all OSPFv3 processes.
# Display SRv6 capability information for all OSPFv3 processes.
<Sysname> display ospfv3 segment-routing ipv6 capability
OSPFv3 Process 1 with Router ID 1.1.1.1
Area 0.0.0.0
Router ID SRv6 capability
2.2.2.2 Enabled
Table 7 Command output
Router ID |
Device router ID. |
SRv6 capability |
Whether SRv6 is enabled. The value can only be Enabled. |
Use display ospfv3 segment-routing ipv6 locator to display OSPFv3 SRv6 locator information.
display ospfv3 [ process-id ] segment-routing ipv6 locator [ ipv6-address prefix-length ]
process-id: Specifies an OSPFv3 process by its ID, in the range of 1 to 65535. If you do not specify an OSPFv3 process, this command displays locator information for all OSPFv3 processes.
ipv6-address prefix-length: Specifies an IPv6 address prefix and the prefix length. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120. If you do not specify this option, the command displays locator information for all IPv6 prefixes.
# Display locator information for all OSPFv3 processes.
<Sysname> display ospfv3 segment-routing ipv6 locator
I - Intra area route, E1 - Type 1 external route, N1 - Type 1 NSSA route
IA - Inter area route, E2 - Type 2 external route, N2 - Type 2 NSSA route
* - Selected route
*Destination: 192:168::12:0/120
Type : I Area : 0.0.0.0
AdvRouter : 2.2.2.2 Preference : 10
NibID : 0x23000002 Cost : 10
Interface : GE1/0/1 BkInterface: N/A
Nexthop : ::
BkNexthop : N/A
Status : Direct
Table 8 Command output
Destination |
Destination network. |
Type |
Route type. |
Area |
Area ID. |
AdvRouter |
ID of the router that advertises LSAs. |
Preference |
Route preference. |
NibID |
ID of the next hop information in the route. |
Cost |
Route cost. |
Output interface. |
BkInterface |
Backup output interface. |
Nexthop |
Next hop address. |
BkNexthop |
Backup next hop address. |
Status |
Route state: · Local—The route is a local route and has not been sent to the route management module. · Invalid—The next hop of the route is invalid. · Stale—The next hop of the route is stale. · Normal—The route is usable. · Delete—The route is deleted. · Direct—The route is a direct route. · Rely—The route is recursed by another route. |
display ospfv3 srv6 tunnel
Use display ospfv3 srv6 tunnel to display OSPFv3 SRv6 tunnel interface information.
display ospfv3 [ process-id ] srv6 tunnel [ interface-number ]
process-id: Specifies an OSPFv3 process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays SRv6 tunnel interface information for all OSPFv3 processes.
interface-number: Specifies an existing SRv6 tunnel interface by its interface number. If you do not specify an SRv6 tunnel interface, this command displays information about all SRv6 tunnel interfaces.
# Display SRv6 tunnel interface information for all OSPFv3 processes.
<Sysname> display ospfv3 srv6 tunnel
SRv6 Tunnel Information
Area: 0.0.0.0
Interface: Tunnel1
State : Active
Neighbor ID: 4.4.4.4
Cost : 1
Auto route : Shortcut
Metric : Absolute 1
Destination: 4::44
Table 9 Command output
Tunnel interface name. |
State |
Tunnel interface state: · Inactive—The next hop of the tunnel interface is not the optimal next hop. The tunnel interface is not used to forward traffic. · Active—The next hop of the tunnel interface is the optimal next hop. The tunnel interface is used to forward traffic. |
Neighbor ID |
Neighbor ID of the tunnel interface: · When the tunnel interface state is Inactive, the neighbor ID is 0.0.0.0, which indicates that the tunnel is not on the optimal path. · When the tunnel interface state is Active, the neighbor ID is the router ID of the tunnel destination end. |
Cost |
Route cost of the tunnel interface: · When the tunnel interface state is Inactive, this field displays 4294967295, which indicates that the tunnel is not on the optimal path. · When the tunnel interface state is Active, this field displays the cost of the route destined for the router ID of the tunnel destination end. |
Destination |
Tunnel destination address. |
Auto route |
Implementation method of automatic route advertisement on the tunnel interface. The value for this field is Shortcut, which represents IGP Shortcut. |
Metric |
Metric of the SRv6 tunnel interface. Supported metric types: · Absolute. · Relative. |
Use display segment-routing ipv6 forwarding to display SRv6 forwarding entry information.
In standalone mode:
display segment-routing ipv6 forwarding [ entry-id ] [ slot slot-number ]
In IRF mode:
display segment-routing ipv6 forwarding [ entry-id ] [ chassis chassis-number slot slot-number ]
entry-id: Specifies an SRv6 forwarding entry by its ID. The value range for this argument varies by device model. If you do not specify an SRv6 forwarding entry ID, this command displays information about all SRv6 forwarding entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays SRv6 forwarding entries on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays SRv6 forwarding entries on the global active MPU. (In IRF mode.)
# Display all SRv6 forwarding entries.
<Sysname> display segment-routing ipv6 forwarding
Total SRv6 forwarding entries: 4
Flags: T – Forwarded through a tunnel
N – Forwarded through the outgoing interface to the nexthop IP address
A - Active forwarding information
B – Backup forwarding information
ID FWD-Type Flags Forwarding info
2148532225 SRv6PSIDList NA GE1/0/1
FE80::54CB:70FF:FE86:316
{6000::1, 7000::1, 8000::1}
2149580801 SRv6PCPath TA 2148532225
2150629377 SRv6Policy TA 2149580801
2153775105 SRv6SFC NA GE1/0/1
Table 10 Command output
FWD-Type |
Tunnel forwarding type: · SRv6PSIDList—Tunnel established based on the SID list in an SRv6 TE policy. · SRv6PCPath—Tunnel established on the candidate path selected by an SRv6 TE policy. · SRv6Policy—SRv6 TE policy tunnel. · SRv6PGROUP—SRv6 TE policy group tunnel. · SRv6SFC—SRv6 service chain tunnel. |
Flags |
Forwarding flags: · T—Tunnel forwarding. · N—Output interface or next hop forwarding. · A—Active forwarding information. · B—Backup forwarding information. |
Forwarding info |
SRv6 forwarding information. · For the N forwarding flag, the forwarding information includes the output interface, next hop, and SID list. · For the T forwarding flag, the forwarding information is the SRv6 forwarding entry ID. |
Use display segment-routing ipv6 local-sid to display information about the SRv6 local SID forwarding table.
display segment-routing ipv6 local-sid { end | end-am | end-as | end-b6encaps | end-b6encapsred | end-b6insert | end-b6insertred | end-coc32 | end-dt2m | end-dt2u | end-dt2ul | end-dx2 | end-dx2l | end-m | end-op | end-t | end-x-coc32 } [ sid ]
display segment-routing ipv6 local-sid { end-dt4 | end-dt46 | end-dt6 | end-dx4 | end-dx6 } [ sid | vpn-instance vpn-instance-name ]
display segment-routing ipv6 local-sid end-x [ sid | interface interface-type interface-number [ nexthop nexthop-ipv6-address ] ]
end: Specifies End SIDs.
end-am: Specifies End.AM SIDs.
end-as: Specifies End.AS SIDs.
end-b6encaps: Specifies End.B6ENCAPS SIDs.
end-b6encapsred: Specifies End.B6ENCAPSRED SIDs.
end-b6insert: Specifies End.B6INSERT SIDs.
end-b6insertred: Specifies End.B6INSERTRED SIDs.
end-coc32: Specifies End (COC32) SIDs.
end-dt2m: Specifies End.DT2M SIDs.
end-dt2u: Specifies End.DT2U SIDs.
end-dt2ul: Specifies End.DT2UL SIDs.
end-dt4: Specifies End.DT4 SIDs.
end-dt46: Specifies End.DT46 SIDs.
end-dt6: Specifies End.DT6 SIDs.
end-dx2: Specifies End.DX2 SIDs.
end-dx2l: Specifies End.DX2L SIDs.
end-dx4: Specifies End.DX4 SIDs.
end-dx6: Specifies End.DX6 SIDs.
end-m: Specifies End.M SIDs.
end-op: Specifies End.OP SIDs.
end-t: Specifies End.T SIDs.
end-x: Specifies End.X SIDs.
end-x-coc32: Specifies End.X (COC32) SIDs.
sid: Specifies an SRv6 SID. If you do not specify an SRv6 SID, this command displays SRv6 local forwarding table information for all SRv6 SIDs of the specified type.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the SRv6 SIDs belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays SRv6 local SID forwarding table information in the public network.
interface interface-type interface-number: Specifies an output interface by its type and number. If you do not specify an output interface, the command displays SRv6 local SID forwarding table information for all End.X SIDs.
nexthop nexthop-ipv6-address: Specifies the IPv6 address of a next hop. If you do not specify a next hop, the command displays SRv6 local SID forwarding table information for all IPv6 next hops.
# Display SRv6 local forwarding table information for all End SIDs.
<Sysname> display segment-routing ipv6 local-sid end
Local SID forwarding table (End)
Total SIDs: 1
SID : 100::64/96
Function type : End Flavor : PSP
Locator name : abc Allocation type: Static
Owner : SIDMGR State : Active
Create Time : May 19 17:21:15.687 2020
# Display SRv6 local forwarding table information for all End.X SIDs.
<Sysname> display segment-routing ipv6 local-sid end-x
Local SID forwarding table (End.X)
Total SIDs: 1
SID : 1000:0:0:15::/32
Function type : End.X Flavor : PSP
Interface : GE1/0/1 Interface index : 0x102
Next hop : FE80::1 Allocation type : Static
Locator name : abc
Create Time : May 19 17:21:46.740 2020
# Display SRv6 local forwarding table information for all End.DT4 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dt4
Local SID forwarding table (End.DT4)
Total SIDs: 1
SID : 6:5::1:1/120
Function type : End.DT4 Flavor : PSP
VPN instance : vpn1 Allocation type: Static
Network type : MPLS L3VPN
Locator name : abc
Create Time : May 19 17:22:27.356 2020
# Display SRv6 local forwarding table information for all End.DT6 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dt6
Local SID forwarding table (End.DT6)
Total SIDs: 1
SID : 1:2::2:2/120
Function type : End.DT6 Flavor : PSP
Locator name : abc
# Display SRv6 local forwarding table information for all End.OP SIDs.
<Sysname> display segment-routing ipv6 local-sid end-op
Local SID forwarding table (End.OP)
Total SIDs: 1
SID : 100::190/96
Function type : End.OP
Locator name : abc
Create Time : May 19 17:23:40.248 2020
# Display SRv6 local forwarding table information for all End.DX4 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dx4
Local SID forwarding table (End.DX4)
Total SIDs: 1
SID : 100::1:0:4/64
Function type : End.DX4 Flavor : PSP
Interface : GE1/0/1 Interface index : 0x11d
Nexthop : 10.1.1.1
VPN instance : vpn1 Allocation type: Dynamic
Locator name : bbb
Owner : BGP State : Active
Create Time : Jun 09 19:30:25.467 2020
# Display SRv6 local forwarding table information for all End.DX6 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dx6
Local SID forwarding table (End.DX6)
Total SIDs: 1
SID : 100::2/64
Function type : End.DX6 Flavor : PSP
Nexthop : 100::10
Locator name : aaa
Create Time : Jun 09 19:41:36.749 2020
# Display SRv6 local forwarding table information for all End.DX2 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dx2
Local SID forwarding table (End.DX2)
Total SIDs: 1
SID : 100:1:2:3::6400/96
Function type : End.DX2 Flavor : PSP
Xconnect-group: abc Connection : test
VSI name : Service ID : 0
Interface :
Create Time : May 20 09:17:58.995 2020
# Display SRv6 local forwarding table information for all End.DT2U SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dt2u
Local SID forwarding table (End.DT2U)
Total SIDs: 1
SID : 100:1:2:3::C800/96
Function type : End.DT2U Flavor : PSP
VSI name : abc Allocation type: Static
Locator name : abc
Create Time : May 20 09:18:14.504 2020
# In Layer 2 encapsulation forwarding scenario, display SRv6 local forwarding table information for End.AS SIDs.
<Sysname> display segment-routing ipv6 local-sid end-as
Local SID forwarding table (End.AS)
Total SIDs: 1
Function type : End.AS Allocation type: Static
Locator name : abc Forward type : L2
Inner type : IPv4 Source address : 2::60
Backup SID : 1::AA Peer SID : 300::3
Bypass : Enabled Bypass SID : 5::9
TTL mode : Uniform TTL value : -
Diffserv mode : Uniform Service class : -
Color : - Cache SL : 2
Cache list :
4::3
7::8
8::9
1::16::9
Encapsulation count: 2
Out-interface: GE1/0/1 In-interface : GE1/0/1
Out-S-VLAN : 100 Out-C-VLAN : -
In-S-VLAN : 200 In-C-VLAN : -
Dest MAC : 0056-00aa-00cb
Out-interface: GE1/0/2 In-interface : GE1/0/1
Out-S-VLAN : 101 Out-C-VLAN : -
In-S-VLAN : 201 In-C-VLAN : -
Dest MAC : 0056-00aa-00cd
Flags : F
# In Layer 3 encapsulation forwarding scenario, display SRv6 local forwarding table information for End.AS SIDs.
Total SIDs: 1
Locator name : abc Forward type : L3
Color : - Cache-SL : 2
Cache list :
4::3
7::8
8::9
1::16::9
Next hop : 10.1.1.2 Out-interface : GE1/0/2
In-interface : GE1/0/2 Symmetric-index: 1
Next hop : 10.1.1.3 Out-interface : GE1/0/1
In-interface : GE1/0/1 Symmetric-index: 2
Flags : F
# In Layer 3 encapsulation forwarding scenario, display SRv6 local forwarding table information for End.AM SIDs.
<Sysname> display segment-routing ipv6 local-sid end-am
Local SID forwarding table (End.AM)
Total SIDs: 1
Function type : End.AM Allocation type: Static
Next hop : 1::1 Out-interface : GE1/0/2
Next hop : 1::2 Out-interface : GE1/0/1
Flags : F
# In Layer 2 encapsulation forwarding scenario, display SRv6 local forwarding table information for End.AM SIDs.
Total SIDs: 1
Out-interface: GE1/0/2 In-interface : GE1/0/2
Flags : F
Table 11 Command output
SID |
SRv6 SID. |
Function type |
SRv6 SID type: · End. · End.AM. · End.AS. · End.B6.Encaps. · End.B6.Encaps.Red · End.B6.Insert · End.B6.Insert.Red · End(COC32). · End.DT2M. · End.DT2U. · End.DT2UL. · End.DT4. · End.DT46. · End.DT6. · End.DX2. · End.DX2L. · End.M. · End.OP. · End.X. · End.X(COC32). · End.DX4. · End.DX6. · End.T. |
Flavor |
SRv6 SID flavor type: · PSP—The penultimate SRv6 node removes the SRH. · NOPSP—The penultimate SRv6 node does not remove the SRH. |
Output interface. |
Interface index |
Output interface index. |
Next hop |
Next hop address. |
VPN instance |
VPN instance name. For the public network, this field displays Public instance. |
Xconnect group |
Cross-connect group name. |
Connection |
Cross-connect name. |
VSI name |
VSI name. |
Service ID |
Ethernet service instance ID. If no Ethernet service instance ID exists, this field displays 0. |
Allocation type |
SID allocation type: · Static—Manually configured. · Dynamic—Dynamically allocated. |
Network type |
Type of the network to which the SRv6 SID is applied: · MPLS L3VPN—The SRv6 SID is applied to an MPLS L3VPN network. · EVPN L3VPN—The SRv6 SID is applied to an EVPN L3VPN network. · MPLS L3VPN, EVPN L3VPN—The SRv6 SID is applied to MPLS L3VPN and EVPN L3VPN networks. |
Mirror locator number |
Number of protected locators. |
Mirror locator |
IPv6 address prefix and prefix length of each protected locator. |
Owner |
Protocol that applies for the SID: · SIDMGR. · BGP. · SRPolicy. · IS-IS. · OSPFv3 · L2VPN. · LSM. |
State |
SID state: · Active. · Inactive. |
Create Time |
SID creation time. |
Forward type |
SFF-to-SF packet forwarding type: · L2—Layer 2 forwarding. · L3—Layer 3 forwarding. |
Inner type |
Protocol type of the original SFF-to-SF packet. |
Source address |
Source IPv6 address re-encapsulated for the packet received by the SFF from the SF. |
Backup SID |
Backup End.AS SID. |
Peer SID |
Backup SFF SID, which is the an End SID. |
Bypass |
Bypass protection status: Enabled or disabled (-). |
Bypass SID |
Backup SID of the bypass path, which is the valid End.AS SID of other protection devices in the SF group. |
TTL mode |
TTL processing mode: · Uniform—After a packet is forwarded back to the SFF from the SF, the SFF uses the TTL value in the original packet minus 1 as the TTL in the newly encapsulated IPv6 header. · Pipe—After a packet is forwarded back to the SFF from the SF, the SFF uses the specified TTL value (ttl-value) minus 1 as the TTL in the newly encapsulated IPv6 header. |
TTL value |
TTL value: · In the Uniform TTL processing mode, a hyphen (-) is displayed. · In the Pipe TTL processing mode, the configured TTL value is displayed. |
Diffserv mode |
Differentiated services (Diffserv) mode: · Uniform—In the inbound direction (SF to SFF), the SFF maps the carried IP or DSCP value to the priority in the newly encapsulated IPv6 header. The packet color will not be changed. In the outbound direction (SFF to SF), the SFF removes the outer IPv6 and SRH header. Then it maps the priority in the outer IPv6 header to the IP or DSCP value in the original packet. The packet color will not be changed. · Pipe—In the inbound direction (SF to SFF), the SFF ignores the carried IP or DSCP value. It uses the configured service-class value as the priority in the newly encapsulated IPv6 header, and the configured color value as the color for the new packet. In SRv6 networks, QoS scheduling is performed for packets based on the priority and color values. In the outbound direction (SFF to SF), the SFF removes the outer IPv6 and SRH header without modifying the IP or DSCP value and color in the original packet. |
Service class |
Diffserv class of the service chain. Values include the following in ascending priority order: · be · af1 · af2 · af3 · af4 · ef · cs6 · cs7 If no Diffserv class is configured, a hyphen (-) is displayed. |
Color |
Packet color. Values include the following in ascending order of packet loss probability: · green—Indicates packet loss probability 0. · yellow—Indicates packet loss probability 1. · red—Indicates packet loss probability 2. If no Diffserv class is configured, a hyphen (-) is displayed. |
Cache-SL |
Segment left value, which indicates the number of nodes to access in the SID list before arrival at the final destination. |
Cache list |
SID list that needs to be encapsulated after the SFF receives the packet from the SF. |
Encapsulation count |
Number of equal-cost paths between the SFF and SF. |
Out-Interface |
Outbound interface for the SFF to forward packets to the SF. |
In-Interface |
Inbound interface for the SFF to receive packets from the SF. |
Out-S-VLAN |
Outer VLAN ID for SFF-to-SF (outbound) packets. |
Out-C-VLAN |
Inner VLAN ID for SFF-to-SF (outbound) packets. |
In-S-VLAN |
Outer VLAN ID for SF-to-SFF (inbound) packets. |
In-C-VLAN |
Inner VLAN ID for SF-to-SFF (inbound) packets. |
Dest MAC |
Destination MAC address encapsulated for packets from the SF to the remote backup SFF in Layer 2 forwarding. |
Symmetric-index |
Index that identifies a VM used for forwarding bidirectional traffic when multiple VMs exist on the SF. Both inbound and outbound traffic with the same source and destination addresses will traverse the same VM. |
Use display segment-routing ipv6 locator to display SRv6 locator information.
display segment-routing ipv6 locator [ locator-name ]
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, this command displays information about all locators.
# Display information about all locators.
<Sysname> display segment-routing ipv6 locator
Locator configuration table
Locator name : a
IPv6 prefix : 5000:: Prefix length : 64
Static length : 32 Args length : 0
Common prefix length: 0
Auto SID start: 5000::1:0:0
Auto SID end : 5000::FFFF:FFFF:FFFF:FFFF
Static SID start: 5000::1
Static SID end : 5000::FFFF:FFFF
Compressed Auto SID count : 0
Compressed Static SID count : 0
Non-compressed Auto SID count : 0
Non-compressed Static SID count: 0
Locator name : abc
IPv6 prefix : N/A Prefix length : 0
Pd : 10 State : Invalid
Pd IPv6 prefix : N/A Pd Prefix length : 0
Sub prefix : 100:1:2:3:: Sub Prefix length: 64
Static length : 16 Args length : 0
Auto SID start : N/A
Auto SID end : N/A
Static SID start : N/A
Static SID end : N/A
Table 12 Command output
IPv6 prefix |
IPv6 address prefix of the locator. |
Prefix length |
Prefix length of the locator. |
Pd |
Prefix delegation (PD) IPv6 prefix. This field is displayed only for a PD locator. |
State |
Locator state. This field is displayed only for a PD locator. Options include: · Invalid. · Valid. · Conflict. |
Pd IPv6 prefix |
PD IPv6 prefix. This field is displayed only for a PD locator. |
Pd Prefix length |
PD IPv6 prefix length. This field is displayed only for a PD locator. |
Sub prefix |
PD IPv6 sub prefix. This field is displayed only for a PD locator. |
Sub Prefix length |
PD IPv6 sub prefix length. This field is displayed only for a PD locator. |
Static length |
Static length of the locator. |
Args length |
Argument length. |
Common prefix length |
Common prefix length of the locator. |
Auto SID start |
Start dynamic SRv6 SID. If no dynamic SRv6 SID exists, this field displays N/A. |
Auto SID end |
End dynamic SRv6 SID. If no dynamic SRv6 SID exists, this field displays N/A. |
Static SID start |
Start static SRv6 SID. If no static SRv6 SID exists, this field displays N/A. |
Static SID end |
End static SRv6 SID. If no static SRv6 SID exists, this field displays N/A. |
Compressed Auto SID count |
Number of dynamic compressible SRv6 SIDs. |
Compressed Static SID count |
Number of static compressible SRv6 SIDs. |
Non-compressed Auto SID count |
Number of dynamic non-compressible SRv6 SIDs. |
Non-compressed Static SID count |
Number of static non-compressible SRv6 SIDs. |
Use display segment-routing ipv6 pd-info to display information about PD prefixes obtained by an SRv6 locator through DHCPv6.
In access networks, numerous CPE devices distributed across different locations connect to the service gateway through wireless connections or optical fibers. Manually configuring and planning SRv6 locators for each CPE device would require significant effort. Additionally, these CPE devices typically do not support IGP protocols, preventing them from advertising SRv6 locators to the service gateway through IGP. To address this issue, H3C uses DHCPv6 PD to obtain IPv6 prefixes and assigns them as the SRv6 locators for CPE devices. This approach greatly reduces the workload for planning and configuring SRv6 locators.
After an access device obtains IPv6 prefixes from a DHCPv6 server through DHCPv6 PD, you can use this command to view information such as the PD prefix ID acquired through DHCPv6 and execute the locator command to configure a PD-type locator.
# Display PD prefix information obtained by an SRv6 locator through DHCPv6.
<Sysname> display segment-routing ipv6 pd-info
Locator pd information table
Pd index : 1
Pd IPv6 prefix : 1004:130:0:102:: Pdprefix length : 48
Locator name : abc
Table 13 Command output
Pd index |
Automatically assigned IPv6 prefix number. |
Pd IPv6 prefix |
Automatically assigned IPv6 prefix. |
Pdprefix length |
Automatically assigned IPv6 prefix length. |
Locator name |
Associated locator name. |
locator
Use egress-engineering srv6 peer-set to create a BGP-EPE SRv6 peer set.
Use undo egress-engineering srv6 peer-set to delete a BGP-EPE SRv6 peer set.
egress-engineering srv6 peer-set peer-set-name [ static-sid { psp psp-sid | no-psp-usp no-psp-usp-sid } * ]
undo egress-engineering srv6 peer-set peer-set-name
No BGP-EPE SRv6 peer sets exist.
BGP instance view
peer-set-name: Specifies a name for the BGP-EPE SRv6 peer set, which is a case-sensitive string of 1 to 63 characters.
static-sid: Specifies a static SRv6 SID for the BGP-EPE SRv6 peer set. If you do not specify a static SRv6 SID, dynamic SRv6 SID allocation applies.
psp psp-sid: Specifies an End.X SID of PSP flavor (to remove the SRH on the penultimate segment).
no-psp-usp no-psp-usp-sid: Specifies an End.X SID of non-PSP and non-USP flavor (to not remove the SRH on the penultimate segment or the ultimate segment).
BGP-EPE allocates BGP peer SIDs to inter-AS segments. The device advertises the peer SIDs to a network controller through BGP LS messages. The controller orchestrates the IGP SIDs and BGP peer SIDs to realize optimal inter-AS traffic forwarding.
If the device establishes BGP peer relationship with multiple devices, use this command to add the peer devices to a peer set and allocate a PeerSet SID to the peer set. When the device forwards traffic based on the PeerSet SID, it distributes the traffic among the peers for load sharing.
Before you use this command, apply a locator to BGP-EPE by using the segment-routing ipv6 egress-engineering locator command in BGP instance view.
· If automatic SID allocation is used, the device dynamically allocates an SRv6 SID to the BGP-EPE SRv6 peer set from the specified locator.
· If you specify a static SRv6 SID for the BGP-EPE SRv6 peer set, the specified static SRv6 SID must belong to the specified locator.
If you execute the egress-engineering srv6 peer-set command to specify multiple SRv6 SIDs for one peer set, the effective configuration depends on whether the SRv6 SIDs are the same type.
· If all the SRv6 SIDs belong to the same type, only the most recent configuration takes effect.
· If the SRv6 SIDs belong to different types, the configuration for all the SRv6 SID types takes effect. For the SRv6 SIDs that belong to the same type, only the most recent configuration takes effect. Make sure each SRv6 SID is unique among all the SRv6 SID types.
The static SRv6 SIDs configured by using the following commands cannot be the same in a BGP instance:
· egress-engineering srv6 peer-set.
· peer egress-engineering srv6.
# Create a BGP-EPE SRv6 peer set named epe and configure the peer set to use a dynamically allocated SRv6 SID.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering srv6 peer-set epe
peer peer-set
Use fast-reroute microloop-avoidance enable to enable FRR microloop avoidance.
Use undo fast-reroute microloop-avoidance enable to disable FRR microloop avoidance.
fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
FRR microloop avoidance is disabled.
IS-IS IPv6 unicast address family view
level-1: Specifies FRR microloop avoidance for IS-IS Level-1.
level-2: Specifies FRR microloop avoidance for IS-IS Level-2.
Use this command only on the source node.
On an network configured with TI-LFA FRR, if a node or link fails, traffic will be switched to the backup path calculated by TI-LFA. However, if a device along the backup path has not finished route convergence, traffic will be looped between the device and the source node until the device finishes route convergence. The source node is the node prior to the node or link that failed.
To resolve this issue, configure this feature on a node enabled with TI-LFA FRR. FRR microloop avoidance first switches traffic to the backup path calculated by TI-LFA to avoid packet loss after a node or link failure on the optimal path. Then, that node starts an FRR microloop avoidance RIB-update-delay timer configured by the fast-reroute microloop-avoidance rib-update-delay command after it finishes route convergence. The node performs the following operations only after all nodes on the backup path finish route convergence and the timer times out:
· Issues the forwarding path after route convergence to the FIB.
· Switches traffic from the backup path calculated by TI-LFA to the forwarding path after route convergence.
If you configure both the segment-routing microloop-avoidance enable and fast-reroute microloop-avoidance enable commands, FRR microloop avoidance takes precedence over SR microloop avoidance. The FRR microloop avoidance RIB-update-delay timer and SR microloop avoidance RIB-update-delay timer are started for the two features, respectively. The following situations exist depending on the configuration of the two timers:
· If the FRR microloop avoidance RIB-update-delay timer is equal to or greater than the SR microloop avoidance RIB-update-delay timer, traffic is switched to the post-convergence path immediately when the former timer times out.
· If the FRR microloop avoidance RIB-update-delay timer is larger than the SR microloop avoidance RIB-update-delay timer, traffic is switched to the post-convergence path until after the latter timer times out.
If you do not specify the level-1 or level-2 keyword, the command enables or disables FRR microloop avoidance on all IS-IS levels.
# Enable FRR microloop avoidance for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] fast-reroute microloop-avoidance enable
Use fast-reroute microloop-avoidance rib-update-delay to set the FRR microloop avoidance RIB-update-delay time.
Use undo fast-reroute microloop-avoidance rib-update-delay to restore the default.
fast-reroute microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance rib-update-delay [ level-1 | level-2 ]
The FRR microloop avoidance RIB-update-delay time is 5000 ms.
delay-time: Specifies the FRR microloop avoidance RIB-update-delay time in milliseconds. The value range is 1 to 60000.
level-1: Specifies the FRR microloop avoidance RIB-update-delay time for IS-IS Level-1.
level-2: Specifies the FRR microloop avoidance RIB-update-delay time for IS-IS Level-2.
If you do not specify the level-1 or level-2 keyword, the command sets the FRR microloop avoidance RIB-update-delay time for all IS-IS levels.
# Set the FRR microloop avoidance RIB-update-delay time to 6000 ms for Level-1 of IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] fast-reroute microloop-avoidance rib-update-delay 6000 level-1
fast-reroute microloop-avoidance (IS-IS IPv6 address family)
fast-reroute ti-lfa
Use fast-reroute ti-lfa to enable Topology-Independent Loop-free Alternate Fast Re-Route (TI-LFA FRR).
Use undo fast-refroute ti-lfa to disable TI-LFA FRR.
In IS-IS IPv6 unicast address family view:
fast-reroute ti-lfa [ per-prefix ] [ route-policy route-policy-name | host ] [ level-1 | level-2 ]
undo fast-reroute ti-lfa [ level-1 | level-2 ]
In OSPFv3 process view:
TI-LFA FRR is disabled.
OSPFv3 process view
per-prefix: Calculates backup information for each advertising source of a route. Specify this keyword only if routes are advertised by multiple sources. If you do not specify this keyword, the device calculates backup information for each route.
route-policy route-policy-name: Enables TI-LFA FRR for prefixes identified by the routing policy. The route-policy-name argument specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
host: Enables TI-LFA for host routes.
level-1: Specifies TI-LFA FRR for IS-IS Level-1.
level-2: Specifies TI-LFA FRR for IS-IS Level-2.
TI-LFA FRR provides link and node protection for SR tunnels. When a link or node fails, TI-LFA FRR switches the traffic to the backup path to ensure continuous data forwarding.
Before configuring TI-LFA FRR on a level, you must execute the fast-reroute lfa command in IS-IS IPv6 unicast address family view or OSPFv3 process view to enable LFA FRR on that level. TI-LFA FRR takes effect only after you enable LFA FRR.
If you do not specify the route-policy route-policy-name option or the host keyword, the device calculates backup information for all routes.
If you do not specify the level-1 or level-2 keyword, the command applies to both IS-IS levels.
# Enable TI-LFA FRR for IS-IS process 1 and calculate backup information for all routes.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4
[Sysname-isis-1-ipv4] fast-reroute ti-lfa
# Enable TI-LFA FRR for OSPFv3 process 1 and calculate backup information for all routes.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute ti-lfa
fast-reroute (IS-IS in Layer 3—IP Routing Command Reference)
fast-reroute (OSPFv3 in Layer 3—IP Routing Command Reference)
route-policy (Layer 3—IP Routing Command Reference)
Use ipv6 segment-routing sid-list to create an SID list and enter its view, or enter the view of an existing SID list.
Use undo ipv6 segment-routing sid-list to delete an SID list.
ipv6 segment-routing sid-list list-name
undo ipv6 segment-routing sid-list list-name
No SID lists exist.
list-name: Specifies the name of the SID list, a case-sensitive string of 1 to 31 characters.
# Create SID list aa and enter its view.
[Sysname] ipv6 segment-routing sid-list aa
[Sysname-srv6-sid-list-aa]
sid
tunnel sid-list
Use isis ipv6 fast-reroute ti-lfa disable to prevent an IS-IS interface from participating in TI-LFA calculation.
Use undo isis ipv6 fast-reroute ti-lfa disable to allow an IS-IS interface to participate in TI-LFA calculation.
isis ipv6 fast-reroute ti-lfa disable [ level-1 | level-2 ]
undo isis ipv6 fast-reroute ti-lfa disable [ level-1 | level-2 ]
An IS-IS interface participates in TI-LFA calculation.
Interface view
level-1: Specifies TI-LFA calculation on IS-IS Level-1.
level-2: Specifies TI-LFA calculation on IS-IS Level-2.
Disable the output interface to the primary next hop from participating in TI-LFA calculation.
If you do not specify the level-1 or level-2 keyword, this command applies to both IS-IS levels.
# Prevent GigabitEthernet 1/0/1 from participating in TI-LFA calculation.
[Sysname-GigabitEthernet1/0/1] isis ipv6 fast-reroute ti-lfa disable
fast-reroute ti-lfa
locator
Use locator to create an SRv6 locator and enter its view, or enter the view of an existing SRv6 locator.
Use undo locator to delete an SRv6 locator.
locator locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
locator locator-name [ ipv6-prefix ipv6-address prefix-length common-prefix common-prefix-length coc32 [ args args-length | static static-length ] * ]
locator locator-name [ ipv6-prefix ipv6-address prefix-length common-prefix common-prefix-length coc-both [ non-compress-static non-compress-static-length ] [ args args-length | static static-length ] * ]
locator locator-name [ pd prefix-number sub-prefix sub-prefix-length static static-length ]
undo locator locator-name
No SRv6 locators exist.
SRv6 view
locator-name: Specifies a locator name, a case-sensitive string of 1 to 31 characters.
ipv6-prefix ipv6-address prefix-length: Specifies an IPv6 address prefix and the prefix length. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120. The IPv6 address prefix cannot be an IPv4-compatible IPv6 address.
args args-length: Specifies an argument length. The value range for the args-length argument depends on the value of the prefix-length argument and varies by device model. If you do not specify an argument length, the argument length is 0.
static static-length: Specifies the static length. The value range for the static-length argument varies by the value of the prefix-length argument or the sub-prefix argument and varies by device model. If you do not specify a static length, the static length is 0.
common-prefix common-prefix-length: Specifies the G-SID common prefix length. The value range for the common-prefix-length argument varies by the value of the prefix-length argument and varies by device model. If you do not specify a G-SID common prefix length, the common prefix length is 0.
coc32: Enables 32-bit G-SID compression.
coc-both: Allocates both compressed and non compressed SRv6 SIDs.
pd prefix-number: Specifies a PD prefix, which is an IPv6 prefix obtained by a locator from a DHCPv6 server through DHCPv6 Prefix Delegation (PD). prefix-number represents the DHCPv6 IPv6 prefix number. To display IPv6 prefix number information, execute the display segment-routing ipv6 pd-info command. Each number corresponds to an IPv6 prefix, with a value range of 1 to 1024.
sub-prefix sub-prefix-length: Specifies the sub-prefix value and length for a locator. sub-prefix is a non-zero hexadecimal number, and sub-prefix-length is the length of the sub prefix, with a value range of 1 to 120.
An SRv6 locator can be one of the following types:
· COC32 type—An SRv6 locator with the coc32 keyword specified.
· COC-both type—An SRv6 locator with the coc-both keyword specified.
· Common type—An SRv6 locator without the coc32, coc-both, or pd keyword specified.
· PD type—An SRv6 locator with the pd keyword specified.
The locator command not only configures the value and length of the locator portion of an SRv6 SID, but is also used to plan the lengths of the Function, Arguments, and MBZ portions in the SRv6 SID. Each SRv6 SID is allocated by the locator command. For more information about the SRv6 SID fields, see SRv6 configuration in Segment Routing Configuration Guide.
If SRv6 compression is enabled, use the locator command to configure the G-SID common prefix length and specify the G-SID compression mode. Only the 32-bit G-SID compression mode is supported in the current software version. In this mode, a standard 128-bit SRv6 SID is compressed to a 32-bit G-SID.
If a static opcode has been configured, a routing protocol preferentially uses the static opcode to construct SRv6 SIDs. If no static opcode exists, the routing protocol dynamically allocates SRv6 SIDs.
By applying a locator to IGP and BGP, you can use IGP and BGP to advertise the SRv6 SIDs on the locator.
When you create a locator, you must specify an IPv6 address prefix, prefix length, and static length for the locator. When you enter the view of an existing SRv6 locator, you do not need to specify the IPv6 address prefix, prefix length, or static length of the locator.
Each locator must have a unique name.
Do not specify the same IPv6 address prefix and prefix length for different locators. In addition, the IPv6 address prefixes of different locators cannot overlap.
You cannot delete a locator if that locator has dynamic SRv6 SIDs that are being used.
# Configure locator test1, setting the IPv6 address prefix to 100::, prefix length to 64, and static length to 32, and enter the SRv6 locator view of this locator.
[Sysname-segment-routing-ipv6] locator test1 ipv6-prefix 100:: 64 static 32
[Sysname-segment-routing-ipv6-locator-test1]
opcode
opcode
Use opcode to configure the opcode of an SRv6 SID.
Use undo opcode to delete the opcode of an SRv6 SID.
opcode { opcode | hex hex-opcode } end [ no-psp ]
opcode { opcode | hex hex-opcode } end-x interface interface-type interface-number nexthop nexthop-ipv6-address [ no-psp ]
opcode { opcode | hex hex-opcode } end-coc32 [ no-psp ]
opcode { opcode | hex hex-opcode } end-x-coc32 interface interface-type interface-number nexthop nexthop-ipv6-address [ no-psp ]
opcode { opcode | hex hex-opcode } end-coc-none [ no-psp ]
opcode { opcode | hex hex-opcode } end-x-coc-none interface interface-type interface-number nexthop nexthop-ipv6-address [ no-psp ]
opcode { opcode | hex hex-opcode } end-dt4 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
opcode { opcode | hex hex-opcode } end-dt46 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
opcode { opcode | hex hex-opcode } end-dt6 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
opcode { opcode | hex hex-opcode } end-dx4 interface interface-type interface-number nexthop nexthop-ipv4-address [ vpn-instance vpn-instance-name [ evpn ] ]
opcode { opcode | hex hex-opcode } end-dx6 interface interface-type interface-number nexthop nexthop-ipv6-address [ vpn-instance vpn-instance-name [ evpn ] ]
opcode { opcode | hex hex-opcode } end-dx2 xconnect-group group-name connection connection-name
opcode { opcode | hex hex-opcode } end-dx2 vsi vsi-name interface interface-type interface-number
opcode { opcode | hex hex-opcode } end-dx2l xconnect-group group-name connection connection-name
opcode { opcode | hex hex-opcode } end-dx2l vsi vsi-name interface interface-type interface-number
opcode { opcode | hex hex-opcode } end-dt2m vsi vsi-name
opcode { opcode | hex hex-opcode } end-dt2u vsi vsi-name
opcode { opcode | hex hex-opcode } end-dt2ul vsi vsi-name
opcode { opcode | hex hex-opcode } end-op
opcode { opcode | hex hex-opcode } end-m mirror-locator ipv6-address prefix-length
undo opcode { opcode | hex hex-opcode } { end | end-coc-none | end-coc32 | end-dt2m | end-dt2u | end-dt2ul | end-dt4 | end-dt46 | end-dt6 | end-dx2 | end-dx2l end-dx4 | end-dx6 | end-m mirror-locator ipv6-address prefix-length | end-op | end-x | end-x-coc-none | end-x-coc32 }
No opcode exists.
SRv6 locator view
opcode: Specifies an opcode in the range of 1 to 2static-length-1, in which the static-length argument is configured by using the locator command.
hex hex-opcode: Specifies an SRv6 SID in hexadecimal notation. The hex-opcode argument represents the SRv6 SID in hexadecimal notation.
end: Specifies the End type.
end-x: Specifies the End.X type.
end-coc32: Specifies the End (COC32) type. You can allocate an End type SRv6 SID that carries a COC flavor from the compressed Function portion in a COC32 or COC-both locator.
end-x-coc32: Specifies the End.X (COC32) type. You can allocate an End.X type SRv6 SID that carries a COC flavor from the compressed Function portion in a COC32 or COC-both locator.
end-coc-none: Specifies the End (COCNONE) type. This End SID does not carry a COC flavor. You can allocate an SRv6 SID from the compressed Function portion in a locator.
end-x-coc-none: Specifies the End.X (COCNONE) type. This End.X SID does not carry a COC flavor. You can allocate an SRv6 SID from the compressed Function portion in a locator.
end-dt4: Specifies the End.DT4 type.
end-dt46: Specifies the End.DT46 type.
end-dt6: Specifies the End.DT6 type.
end-dx4: Specifies the End.DX4 type.
end-dx6: Specifies the End.DX6 type.
end-dx2: Specifies the End.DX2 type.
end-dx2l: Specifies the End.DX2L type.
end-dt2m: Specifies the End.DT2M type.
end-dt2u: Specifies the End.DT2U type.
end-dt2ul: Specifies the End.DT2UL type.
end-op: Specifies the End.OP type.
end-m: Specifies the End.M type.
no-psp: Disables the penultimate SRv6 node from removing the SRH. If you do not specify this keyword, the penultimate SRv6 node will remove the SRH.
interface interface-type interface-number: Specifies an output interface.
nexthop nexthop-ipv4-address: Specifies a next hop IPv4 address.
nexthop nexthop-ipv6-address: Specifies a next hop IPv6 address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the SRv6 SID belongs. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The specified VPN instance must exist. If the SRv6 SID belongs to the public network, do not specify this option.
evpn: Specifies EVPN routes. If you do not specify this keyword, the command specifies the SRv6 SID of VPNv4 or VPNv6 routes.
l3vpn-evpn: Specifies EVPN routes, VPNv4 routes, and VPNv6 routes.
xconnect-group group-name: Specifies the cross-connect group to which the SRv6 SID belongs. The group-name argument represents the cross-connect group name, a case-sensitive string of 1 to 31 characters. The name cannot contain a hyphen (-). The specified cross-connect group must exist.
connection connection-name: Specifies the cross-connect to which the SRv6 SID belongs. The connection-name argument represents the cross-connect name, a case-sensitive string of 1 to 20 characters. The name cannot contain a hyphen (-). The specified cross-connect must exist.
vsi vsi-name: Specifies the VSI to which the SRv6 SID belongs. The vsi-name argument represents the VSI name, a case-sensitive string of 1 to 31 characters. The specified VSI must exist.
mirror-locator ipv6-address prefix-length: Specifies a protected locator by its IPv6 address prefix and prefix length. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120. Make sure the specified locator is the same as the locator on a protected node.
An SRv6 locator and its opcode and argument generate unique SRv6 SIDs. SRv6 SIDs form local SID forwarding table entries.
Use this command to configure the opcode of static SRv6 SIDs on a locator. The number of static SRv6 SIDs is determined by the static static-length option in the locator command.
You can execute the opcode command multiple times with the end-m keyword to specify multiple protected locators for the same opcode. Each protected locator represents one or multiple remote SRv6 SIDs that require protection. A protected locator can be specified only for one opcode. Different opcodes cannot have protected locators belonging to the same subnet.
To modify the opcode of static SRv6 SIDs on a locator, you must first delete the original opcode by using the undo opcode command.
To configure End (COC32) SRv6 SIDs or End.X (COC32) SRv6 SIDs, you must also perform the following tasks:
· Enable SRv6 compression by using the srv6 compress enable command.
· Configure the G-SID common prefix length by using the locator command.
To configure End (COCNONE) SRv6 SIDs or End.X (COCNONE) SRv6 SIDs, you must also perform the following tasks:
· Configure the locator to allocate both compressible and non-compressible SRv6 SIDs.
End (COCNONE) and End.X (COCNONE) SIDs are allocated from the compressible SRv6 SID space. End (COCNONE) SIDs and End.X (COCNONE) SIDs have the same function as End SIDs and End.X SIDs, respectively.
For a COC-both locator, you can set the same opcode for the following SIDs:
· End SID and End (COC32) SID.
· End SID and End (COCNONE) SID.
· End.X SID and End.X (COC32) SID.
· End.X SID and End.X (COCNONE) SID.
# Configure End SRv6 SIDs, and set the opcode to 64. Configure End.X SRv6 SIDs, set the opcode to 128, and configure GigabitEthernet 1/0/1 as the output interface and 2001::1 as the next hop IPv6 address.
[Sysname-segment-routing-ipv6] locator test ipv6-prefix 100:: 64 static 32
[Sysname-segment-routing-ipv6-locator-test] opcode 64 end
[Sysname-segment-routing-ipv6-locator-test] opcode 128 end-x interface gigabitethernet 1/0/1 nexthop 2001::1
locator
ospfv3 fast-reroute ti-lfa disable
Use ospfv3 fast-reroute ti-lfa disable to prevent an OSPFv3 interface from participating in TI-LFA calculation.
Use undo ospfv3 fast-reroute ti-lfa disable to allow an OSPFv3 interface to participate in TI-LFA calculation.
ospfv3 fast-reroute ti-lfa disable [ instance instance-id ]
undo ospfv3 fast-reroute ti-lfa disable [ instance instance-id ]
An OSPFv3 interface participates in TI-LFA calculation.
Interface view
instance instance-id: Specifies an instance by its ID, in the range of 0 to 255. The default value is 0.
# Prevent GigabitEthernet1/0/1 from participating in TI-LFA calculation.
[Sysname-GigabitEthernet1/0/1] ospfv3 fast-reroute ti-lfa disable
path-mtu
Use path-mtu to set the SRv6 path MTU.
Use undo path-mtu to restore the default.
path-mtu mtu-value
undo path-mtu
The SRv6 path MTU is 1500 bytes.
SRv6 view
mtu-value: Sets the path MTU, in bytes. The value range for this argument is 1280 to 9600.
This command specifies the maximum bytes that can be contained in an SRv6 tunneled packets.
The transit nodes do not fragment SRv6 tunneled packets. If a packet is larger than the MTU of the output interface, the packet will be discarded. If the MTU is too small, the bandwidth is not sufficiently used. To address these issues, use this command to set an appropriate SRv6 path MTU.
# Set the SRv6 path MTU to 2000 bytes.
[Sysname-segment-routing-ipv6] path-mtu 2000
path-mtu reserved
Use path-mtu reserved to specify a reserved MTU for SRv6 path MTU.
Use undo path-mtu reserved to restore the default.
path-mtu reserved [ reserved-value ]
No reserved MTU is specified for SRv6 path MTU.
SRv6 view
reserved-value: Specifies an MTU value, in bytes. The value range for this argument is 0 to 8320.The default value is 72 bytes.
Use this command in the TI-LFA scenario. When packets are switched to the backup path after the primary path fails, the device reconstructs an IPv6 header and SRH for the packets. As a result, packet drop might occur because the packet size has exceeded the MTU. To resolve this issue, configure a reserved MTU on the source node to reserve bytes for adding a new SRH to SRv6 packets in case of primary path failure.
The SRv6 path MTU minus the reserved MTU is the active MTU. Make sure the active MTU is equal to or greater than 1280 bytes.
The effective MTU for SRv6 packets on the source node is the smaller value from the following values:
· The active MTU.
· The IPv6 MTU of the physical output interface.
For example, if the SRv6 path MTU is 1600 bytes and the reserved MTU is 100 bytes, the active MTU is 1500 bytes.
· If the IPv6 MTU of the physical output interface is equal to or greater than 1500 bytes, the effective MTU on the source node is 1500 bytes.
· If the IPv6 MTU of the physical output interface is smaller than 1500 bytes, the effective MTU on the source node is the IPv6 MTU of the physical output interface.
# Reserve 200 bytes for SRv6 path MTU.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] path-mtu reserved 200
Use peer egress-engineering srv6 to enable SRv6 BGP-EPE.
Use undo peer egress-engineering srv6 to disable SRv6 BGP-EPE.
peer group-name egress-engineering srv6
undo peer group-name egress-engineering srv6
peer ipv6-address [ prefix-length ] egress-engineering srv6 [ locator locator-name | static-sid { psp psp-sid | no-psp-usp no-psp-usp-sid } * ]
undo peer ipv6-address [ prefix-length ] egress-engineering srv6 [ locator | static-sid { psp | no-psp-usp } * ]
SRv6 BGP-EPE is disabled.
BGP instance view
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The specified peer group must already exist.
ipv6-address: Specifies a peer by its IPv6 address. The specified peer must already exist.
prefix-length: Specifies the prefix length, in the range of 0 to 128. To specify dynamic peers within a subnet, you must specify both the ipv6-address and prefix-length arguments.
locator locator-name: Specifies a locator by its name. If you do not specify a locator, the device can dynamically allocate an End.X SID in the locator to the peer.
static-sid: Specifies a static SRv6 SID for the peer.
psp psp-sid: Specifies an End.X SID of PSP flavor (to remove the SRH on penultimate segment).
no-psp-usp no-psp-usp-sid: Specifies an End.X SID of non-PSP and non-USP flavor (to not removed the SRH on the penultimate segment or the ultimate segment).
This command enables the device to allocate PeerNode SIDs and PeerAdj SIDs to peers.
If you do not specify any parameters, the device will dynamically allocate SRv6 SIDs to peers. The SRv6 SIDs belong to the locator specified by using the segment-routing ipv6 egress-engineering locator command in BGP instance view.
When you use the peer egress-engineering srv6 command for a peer, follow these restrictions and guidelines:
· If you use this command to specify multiple locators for that peer, only the most recent configuration takes effect.
· If you use this command to specify multiple static SRv6 SIDs and the SIDs belong to different types, all types of SRv6 SIDs can take effect. For the same type of SRv6 SIDs, only the most recent configuration takes effect.
If you specify a static SRv6 SID for a peer, the specified static SRv6 SID must belong to the locator specified by using the segment-routing ipv6 egress-engineering locator command in BGP instance view. To identify whether the static SRv6 SID takes effect, use the display bgp egress-engineering ipv6 command. If the static SRv6 SID does not take effect, the static SRv6 SID has been used by other protocols. After the static SRv6 SID is released, first use the undo peer egress-engineering srv6 command to remove the original static SRv6 SID configuration. Then, use the peer egress-engineering srv6 command to reconfigure the static SRv6 SID.
The static SRv6 SIDs specified by using the following commands cannot be the same:
# Enable SRv6 BGP-EPE.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1::1 egress-engineering srv6
peer peer-set
Use peer peer-set to add a peer to a BGP-EPE SRv6 peer set.
Use undo peer peer-set to remove a peer from a BGP-EPE SRv6 peer set.
peer { ipv6-address [ prefix-length ] } peer-set srv6-peer-set-name
undo peer { ipv6-address [ prefix-length ] } peer-set
No peers are added to a BGP-EPE SRv6 peer set.
BGP instance view
ipv6-address: Specifies a peer by its IPv6 address. The peer must exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. To specify a subnet, you must specify both the ipv6-address and prefix-length arguments.
peer-set-name: Specifies a BGP-EPE SRv6 peer set by its name, a case-sensitive string of 1 to 63 characters.
A PeerSet SID can be allocated to a BGP-EPE SRv6 peer set. When the device forwards traffic based on the PeerSet SID, it distributes the traffic among the peers in the peer set for load sharing.
Before adding a peer to a BGP-EPE SRv6 peer set, you must enable SRv6 BGP-EPE for that peer.
To change the BGP-EPE SRv6 peer set for a peer, you must first use undo peer peer-set command to remove that peer from the original BGP-EPE SRv6 peer set.
# Add peer 10::1 to the BGP-EPE SRv6 peer set named abc.
[Sysname] bgp 100
[Sysname-bgp-default] peer 10::1 peer-set abc
router-id
Use router-id to configure the router ID for an IPv6 IS-IS process and enable IPv6 TE.
Use undo router-id to remove the router ID from an IPv6 IS-IS process and disable IPv6 TE.
router-id ipv6-address
undo router-id
No router ID is configured for an IPv6 IS-IS process and IPv6 TE is disabled.
IS-IS IPv6 address family view
ipv6-address: Specifies an IPv6 router ID.
The IPv6 router ID must be unique in the IPv6 network.
The IPv6 router ID determines the source and destination addresses of the SRv6 tunnel distributed to the IGP. The destination address of the SRv6 tunnel must be the same as the IPv6 router ID of the destination node.
To avoid route calculation errors when multiple IS-IS P2P neighbors exist between two devices, configure the advertise link-attributes or router-id command to enable IS-IS to advertise the IP address of the local interface connected to the peer to the neighbors.
Configuring an IPv6 route ID on a router also enables the IPv6 TE feature on that router. After the SRv6 tunnel participates in IGP route calculation, traffic can be directed to the SRv6 tunnel.
# Configure the router ID for an IPv6 IS-IS process and enable IPv6 TE.
[Sysname] isis 1
[Sysname-isis-1] cost-style wide
[Sysname-isis-1-ipv6] router-id 1000::1
segment-routing ipv6 (system view)
Use segment-routing ipv6 to enable SRv6 and enter SRv6 view.
Use undo segment-routing ipv6 to disable SRv6.
SRv6 is disabled.
After you execute this command, you can configure locators in SRv6 view. Then, you can configure the opcode portion in SRv6 locator view to generate local SID forwarding table entries.
You cannot disable SRv6 when a locator in SRv6 view has dynamic SRv6 SIDs that are being used.
# Enable SRv6 and enter SRv6 view.
segment-routing ipv6 compatible locator-fixed-length
Use segment-routing ipv6 compatible locator-fixed-length to enable compatibility of the Locator field in SRv6 Locator TLVs with earlier drafts.
Use undo segment-routing ipv6 compatible locator-fixed-length to restore the default.
The Locator field in SRv6 locator LSAs is of variable length, with a maximum of 128 bytes.
OSPFv3 view
Application scenarios
To avoid interoperability issues caused by differences in the Locator field length in the SRv6 Locator TLV when a third-party device or an H3C device with an older software version interoperates with an H3C device with a newer software version, you can this command to have the new devices compatible with older draft standards.
Operating mechanism
In the OSPFv3 protocol, the SRv6 Locator TLV is carried in the SRv6 Locator LSA, used to announce the network segment and mask of the locator to which the SRv6 SID belongs, as well as the End SID related to that locator.
The length of the Locator field in SRv6 Locator TLVs is defined as variable in draft-ietf-lsr-ospfv3-srv6-extensions-12 and later drafts and can be up to 128 bits. The length of the Locator field can vary based on the configured locator segment length. However, the length is fixed at 128 bits in draft-ietf-lsr-ospfv3-srv6-extensions-11 and earlier drafts. For example, if you specify the prefix-length argument as 96 in the locator command, the default Locator field length is 96 bits and the remaining 32 bits are not required in the TLV when you apply the locator to OSPFv3 and advertise it. After this command is configured, the Locator field must be 128-bit long and the remaining 32 bits are all set to zero.
For compatibility with draft-ietf-lsr-ospfv3-srv6-extensions-08 and earlier drafts, you must both this command and the segment-routing ipv6 private-srv6-extensions compatible command.
# Enable compatibility of the Locator field in SRv6 Locator TLVs with earlier drafts.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing ipv6 compatible locator-fixed-length
Use segment-routing ipv6 egress-engineering locator to apply a locator to BGP-EPE.
Use undo segment-routing ipv6 egress-engineering locator to restore the default.
segment-routing ipv6 egress-engineering locator locator-name
No locator is applied to BGP-EPE.
BGP instance view
Use this command to restrict the range of End.X SIDs that can be allocated to BGP-EPE SRv6 peer sets and BGP-EPE-enabled peers in a BGP instance. All static SRv6 SIDs configured for the BGP-EPE SRv6 peer sets and peers must belong to the locator specified by using this command.
To dynamically allocate End.X SIDs from the specified locator:
· Do not configure a static SRv6 SID when you create a BGP-EPE SRv6 peer set by using the egress-engineering srv6 peer-set command.
· Do not specify a locator or configure a static SRv6 SID when you enable SRv6 BGP-EPE for a peer by using the peer egress-engineering srv6 command.
# Apply locator test to BGP-EPE.
[Sysname] bgp 100
[Sysname-bgp-default] segment-routing ipv6 egress-engineering locator test
segment-routing ipv6 locator (BGP IPv6 unicast address family view)
Use segment-routing ipv6 locator to apply a locator to BGP.
Use undo segment-routing ipv6 locator to restore the default.
segment-routing ipv6 locator locator-name [ auto-sid-disable ]
No locators are applied to BGP.
auto-sid-disable: Disables automatic SRv6 SID allocation. If you do not specify this keyword, the device allows dynamically allocated SRv6 SIDs. If static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the static SRv6 SIDs take precedence. If no static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the system dynamically allocates SRv6 SIDs.
This command uses BGP IPv4 or IPv6 unicast routes to advertise SRv6 SIDs in the specified locator.
# In BGP IPv6 unicast address family view, specify locator abc.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6
[Sysname-bgp-default-ipv6] segment-routing ipv6 locator abc
locator
segment-routing ipv6 locator (IS-IS IPv6 address family view)
Use segment-routing ipv6 locator to apply an SRv6 locator to an IPv6 IS-IS process.
Use undo segment-routing ipv6 locator to remove the specified SRv6 locator from an IPv6 IS-IS process.
segment-routing ipv6 locator locator-name [ level-1 | level-2 ] [ auto-sid-disable ]
undo segment-routing ipv6 locator locator-name
No SRv6 locators are applied to an IPv6 IS-IS process.
level-1: Specifies the level-1 area.
level-2: Specifies the level-2 area.
Use this command to enable IPv6 IS-IS to advertise SRv6 SIDs.
If you do not specify a level, this command applies the specified locator to both level-1 and level-2 areas.
Use this command only when the cost style of IS-IS is wide, compatible, or wide-compatible.
Execute this command multiple times to apply multiple locators to an IPv6 IS-IS process so that the process can advertise multiple SRv6 SIDs.
# Apply locator abc to an IPv6 IS-IS process.
[Sysname] isis 1
[Sysname-isis-1-ipv6] segment-routing ipv6 locator abc
locator
segment-routing ipv6 locator (OSPFv3 process view)
Use segment-routing ipv6 locator to apply an SRv6 locator to an OSPFv3 process.
Use undo segment-routing ipv6 locator to remove the specified SRv6 locator from an OSPFv3 process.
No SRv6 locators are applied to an OSPFv3 process.
OSPFv3 process view
Use this command to enable OSPFv3 to advertise SRv6 SIDs.
Execute this command multiple times to apply multiple locators to an OSPFv3 process so that the process can advertise multiple SRv6 SIDs.
# Apply locator abc to an OSPFv3 process.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing ipv6 locator abc
locator
Use segment-routing ipv6 private-srv6-extensions compatible to configure the TLVs and flag bits in the OSPFv3 extensions for SRv6 to be compatible with the private protocol.
Use undo segment-routing ipv6 private-srv6-extensions compatible to restore the default.
The SRv6 Capabilities TLV type values, Sub TLV type values, and flag bits in OSPFv3 packets follow the definitions in draft-ietf-lsr-ospfv3-srv6-extensions-09.
OSPFv3 view
Operating mechanism
· By default, OSPFv3 protocol packets comply with the most recent OSPFv3 draft standard, and the TLVs and flag bits in the OSPFv3 extensions for SRv6 follow the definitions in draft-ietf-lsr-ospfv3-srv6-extensions-09. The values for SRv6 Capabilities TLV Type, End.X SID Sub-TLV Type, and LAN End.X SID Sub-TLV Type are 20, 31, and 32, respectively. The N flag of the PrefixOptions field in the SRv6 Locator TLV is in the third bit, and the AC flag is in the first bit. In this case, the TLV information in the OSPFv3 extensions for SRv6 is similar to that of other vendors, allowing interoperability.
· With this command configured, the TLVs and flag bits in the OSPFv3 extensions for SRv6 follow the definition in the private protocol. The values for SRv6 Capabilities TLV Type, End.X SID Sub-TLV Type, and LAN End.X SID Sub-TLV Type are 17, 11, and 12, respectively. The N flag of the PrefixOptions field in the SRv6 Locator TLV is in the first bit, and the AC flag is in the second bit. In this case, the TLV information in the OSPFv3 extensions for SRv6 is the same as that on devices that do not use the most recent software version, allowing interoperability.
For a successful advertisement of SRv6 locators and SRv6 SIDs, make sure OSPFv3 neighbors follow the same standard.
# Configure the TLVs and flag bits in the OSPFv3 extensions for SRv6 to be compatible with the private protocol.
[Sysname] opsfv3 1
[Sysname-ospfv3-1] segment-routing ipv6 private-srv6-extensions compatible
· segment-routing ipv6 locator (OSPFv3 view)
Use segment-routing microloop-avoidance enable to enable SR microloop avoidance.
Use undo segment-routing microloop-avoidance enable to disable SR microloop avoidance.
segment-routing microloop-avoidance enable [ level-1 | level-2 ]
undo segment-routing microloop-avoidance enable [ level-1 | level-2 ]
SR microloop avoidance is disabled.
OSPFv3 process view
level-1: Specifies IS-IS Level-1.
level-2: Specifies IS-IS Level-2.
After a network failure occurs or recovers, route convergence occurs on relevant network devices. Because of nonsimultaneous convergence on network devices, microloops might be formed. After you configure SR microloop avoidance, the devices will forward traffic along the specified path before route convergence is finished on all the relevant network devices. Because the forwarding path is independent of route convergence, microloops are avoided.
# Enable SR microloop avoidance for IPv6 IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] segment-routing microloop-avoidance enable
# Enable SR microloop avoidance for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing microloop-avoidance enable
segment-routing microloop-avoidance rib-update-delay
Use segment-routing microloop-avoidance rib-update-delay to set the SR microloop avoidance RIB-update-delay time.
Use undo segment-routing microloop-avoidance rib-update-delay to restore the default.
segment-routing microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo segment-routing microloop-avoidance rib-update-delay [ level-1 | level-2 ]
The SR microloop avoidance RIB-update-delay time is 5000 milliseconds.
OSPFv3 process view
delay-time: Sets the delay time in milliseconds, in the range of 1 to 60000.
To ensure sufficient time for IGP to complete route convergence, set the SR microloop avoidance RIB-update-delay time. Before the timer expires, faulty relevant devices will forward traffic along the specified path. Upon expiration of the timer and completion of IGP route convergence, traffic will traverse along the IGP-calculated path.
# Set the SR microloop avoidance RIB-update-delay time to 6000 milliseconds for IPv6 IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] segment-routing microloop-avoidance rib-update-delay 6000
# Set the SR microloop avoidance RIB-update-delay time to 6000 milliseconds for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing microloop-avoidance rib-update-delay 6000
service-class
Use service-class to specify a service class value for an SRv6 tunnel interface.
Use undo service-class to restore the default.
service-class class-value
undo service-class
No service class value is specified for an SRv6 tunnel interface.
SRv6 tunnel interface view
class-value: Specifies a service class value. The lower the service class value, the lower the forwarding priority of a tunnel. If no service class value is specified for a tunnel, the tunnel has the lowest forwarding priority. The value range for this argument is 0 to7.
Class Based Tunnel Selection (CBTS) compares the service class value of the traffic with the service class values of SRv6 tunnels. CBTS uses the following rules to select a tunnel to forward the traffic:
· If the traffic matches an SRv6 tunnel, CBTS uses this tunnel.
· If the traffic matches multiple SRv6 tunnels, CBTS selects a tunnel based on the flow forwarding mode set on the tunnel interface:
¡ If flow-based forwarding is set, CBTS randomly selects a matching tunnel for packets of the same flow.
¡ If packet-based forwarding is set, CBTS uses all matching tunnels to load share the packets.
· If the traffic does not match any SRv6 tunnels, CBTS selects an SRv6 tunnel from all tunnels with a service class value smaller than the traffic. Among these tunnels, the one with the largest service class value is used. If all SRv6 tunnels have a service class value greater than the traffic, CBTS uses the tunnel with the smallest service class value.
# Set the service class value to 5 for SRv6 tunnel interface Tunnel 1.
[Sysname] interface tunnel 1 mode sr ipv6
[Sysname-Tunnel1] service-class 5
sid
Use sid to configure a node in an SID list.
Use undo sid to remove a node from an SID list.
sid [ index index-number ] ipv6-address
undo sid index index-number
No nodes exist in an SID list.
SID list view
index index-number: Specifies an index for the node, in the range of 1 to 65535. If you do not specify an index for the node, the system automatically assigns the node the largest index that has been assigned plus an increment. The default initial index value is 5 and the step is 4.
ipv6-address: Specifies the IPv6 address of the node.
Make sure the node nearest to the source node is assigned the smallest index. The nearer a node is to the source node, the smaller the index value of the node must be.
# Configure a node in SID list aa. The index is 2 and the IPv6 address is 1::1.
[Sysname-srv6-sid-list-aa] sid index 2 1::1
srv6 compress enable (IS-IS IPv6 address family view)
Use srv6 compress enable to enable SRv6 compression for IPv6 IS-IS.
Use undo srv6 compress enable to disable SRv6 compression for IPv6 IS-IS.
srv6 compress enable [ level-1 | level-2 ]
SRv6 compression is disabled for IPv6 IS-IS.
If you do not specify a level, this command enables SRv6 compression for both level-1 and level-2 areas.
If IPv6 IS-IS is used to advertise G-SIDs to neighbors, you must use this command to enable SRv6 compression for IPv6 IS-IS.
Before you use this command, apply a locator to IS-IS IPv6 address family view by using the segment-routing ipv6 locator command.
# Enable SRv6 compression for IPv6 IS-IS.
[Sysname] isis 1
[Sysname-isis-1-ipv6] srv6 compress enable
srv6 compress enable (SRv6 view)
Use srv6 compress enable to enable SRv6 compression.
Use undo srv6 compress enable to disable SRv6 compression.
SRv6 compression is disabled.
SRv6 view
Typically, an address space is reserved for SRv6 SID allocation in an SRv6 subnet. This address space is called an SID space. In the SRv6 subnet, all SIDs are allocated from the SID space. The SIDs have the same prefix (common prefix). The SID common prefix is redundant information in the SRH.
SRv6 compression removes the common prefix from the SIDs in the SID list of the SRH. The remaining part of an SID is called a G-SID. G-SIDs reduce the cost of SRH.
When SRv6 uses the SID list in the SRH to replace the destination address of a packet, it combines the common prefix and the destination G-SID to form a new SID. This new SID is used as the destination address of the packet.
# Enable SRv6 compression.
[Sysname-segment-routing-ipv6] srv6 compress enable
srv6 igp metric
Use srv6 igp metric to assign a metric to an SRv6 tunnel.
Use undo srv6 igp metric to restore the default.
srv6 igp metric { absolute value | relative value }
The metric of an SRv6 tunnel equals its IGP metric.
absolute value: Specifies an absolute metric, an integer in the range of 1 to 65535.
relative value: Specifies a relative metric, an integer in the range of –10 to +10. A relative metric is the assigned metric value plus the IGP metric.
When IGP shortcut is enabled for an SRv6 tunnel, the tunnel participates in the IGP route calculation as a link. You can use this command to configure the metric of this link used for IGP route calculation.
# Assign SRv6 tunnel interface Tunnel 0 a relative metric of –1 for route calculation in IGP shortcut mechanism.
[Sysname] interface tunnel 0 mode sr ipv6
[Sysname-Tunnel0] srv6 igp metric relative -1
srv6 igp shortcut
srv6 igp shortcut
Use srv6 igp shortcut to enable IGP shortcut for an SRv6 tunnel. The tunnel ingress node includes the tunnel in the IGP route calculation as a link.
Use undo srv6 igp shortcut to disable IGP shortcut.
srv6 igp shortcut [ isis | ospf ]
IGP shortcut is disabled for an SRv6 tunnel. The ingress node does not include the tunnel in the IGP route calculation as a link.
isis: Specifies IS-IS as the IGP.
ospf: Specifies OSPF as the IGP.
If you do not specify an IGP in this command, both OSPF and IS-IS will include the SRv6 tunnel in route calculation.
# Enable IGP shortcut for SRv6 tunnel interface Tunnel 0, so the tunnel ingress node considers the tunnel as a link in OSPF and IS-IS route calculation.
[Sysname-Tunnel0] srv6 igp shortcut
srv6 igp metric
tunnel bfd enable echo
Use tunnel bfd enable echo to enable BFD echo-mode detection on an SRv6 tunnel interface.
Use undo tunnel bfd enable echo to disable BFD echo-mode detection on an SRv6 tunnel interface.
BFD echo-mode detection is disabled on an SRv6 tunnel interface.
Execute this command on an SRv6 tunnel interface to use BFD sessions for quick link connectivity detection of the SRv6 tunnel. If a link failure is detected along the path, the device can quickly handle the issue, for example, it can direct the traffic to the backup path to ensure traffic forwarding continuity.
If the BFD session of a path is down, the path is unavailable. If the BFD session of a path is up, the path is available.
# Enable BFD echo-mode detection on SRv6 tunnel interface Tunnel 1.
[Sysname-Tunnel1] tunnel bfd enable echo
bfd echo-source-ipv6 (High Availability Command Reference)
tunnel route-static
Use tunnel route-static to configure automatic static route advertisement.
Use undo tunnel route-static to restore the default.
tunnel route-static [ preference preference-value ]
Automatic static route advertisement is not configured.
preference preference-value: Specifies a preference value for the static route to be advertised, in the range of 1 to 255. The default value is 60.
This command creates a static route whose destination address and output interface are the tunnel destination address and the tunnel interface, respectively.
# Configure automatic static route advertisement on SRv6 tunnel interface Tunnel 1 and set the preference to 3.
[Sysname-Tunnel1] tunnel route-static preference 3
tunnel sid-list
Use tunnel sid-list to specify an SID list on an SRv6 tunnel interface.
Use undo tunnel sid-list to remove an SID list from an SRv6 tunnel interface.
tunnel sid-list list-name [ backup ]
undo tunnel sid-list list-name
No SID lists are specified for an SRv6 tunnel interface.
list-name: Specifies an SID list by its name, a case-sensitive string of 1 to 31 characters.
backup: Specifies the SID list as the backup path of the SRv6 tunnel. If you do not specify this keyword, the specified SID list is used as the primary path of the SRv6 tunnel.
# Specify SID list aa on SRv6 tunnel interface Tunnel 1.
[Sysname-Tunnel1] tunnel sid-list aa
interface tunnel (Layer 3—IP Services Command Reference)
