12-Security Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R6749-6W10112-Security Command Reference
17-ASPF commands
17-ASPF commands 129.35 KB
ASPF commands
The MSR 56-60 and MSR 56-80 routers installed with the MPU-100-G modules do not support parameters or commands that are available only in IRF mode.
aspf apply policy (interface view)
Use aspf apply policy to apply an ASPF policy to an interface.
Use undo aspf apply policy to remove an ASPF policy application from an interface.
aspf apply policy aspf-policy-number { inbound | outbound }
undo aspf apply policy aspf-policy-number { inbound | outbound }
No ASPF policy is applied to an interface.
Interface view
aspf-policy-number: Specifies an ASPF policy number. The value range for this argument is 1 to 256.
inbound: Applies the ASPF policy to incoming packets.
outbound: Applies the ASPF policy to outgoing packets.
To inspect the traffic through an interface, you must apply a configured ASPF policy to that interface.
Make sure a connection initiation packet and the response packet pass through the same interface, because an ASPF stores and maintains the application layer protocol status based on interfaces.
You can apply an ASPF policy to both the inbound and outbound directions of an interface.
# Apply ASPF policy 1 to the outbound direction of GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] aspf apply policy 1 outbound
aspf policy
display aspf all
display aspf interface
aspf apply policy (zone pair view)
Use aspf apply policy to apply an ASPF policy to a zone pair.
Use undo aspf apply policy to remove an ASPF policy application from a zone pair.
The system applies the predefined ASPF policy to a zone pair when the zone pair is created.
Zone pair view
With the predefined policy, ASPF inspects FTP packets and packets of all transport layer protocols, but it does not perform ICMP error message check or the TCP SYN packet check.
The predefined ASPF policy cannot be modified. To change the ASPF policy application, define an ASPF policy and apply it to the zone pair.
# Apply an ASPF policy to a zone pair.
[Sysname] security-zone name trust
[Sysname-security-zone-Trust] import interface gigabitethernet 1/0/1
[Sysname-security-zone-Trust] quit
[Sysname] security-zone name untrust
[Sysname-security-zone-Untrust] import interface gigabitethernet 1/0/2
[Sysname-security-zone-Untrust] quit
[Sysname] zone-pair security source trust destination untrust
[Sysname-zone-pair-security-Trust-Untrust] aspf apply policy 1
aspf policy
display aspf all
zone-pair security
aspf icmp-error reply
Use aspf icmp-error reply to enable the device to send ICMP error messages upon packet dropping by interzone policies applied to zone pairs.
Use undo aspf icmp-error reply to restore the default.
The device does not send ICMP error messages when the device drops packets that do not match interzone policies applied to zone pairs.
Typically, to reduce useless packets transmitted over the network and save bandwidth, do not use this command.
However, you must use this command when you use traceroute because ICMP error messages in this situation are required.
# Enable ICMP error message sending upon packet dropping by interzone policies applied to zone pairs.
[Sysname] aspf icmp-error reply
aspf log sending-realtime enable
Use aspf log sending-realtime enable to enable real-time log sending mode.
Use undo aspf log sending-realtime enable to disable real-time log sending mode.
Real-time log sending mode is disabled. Logs are cached before they are sent.
Real-time log sending mode takes effect only on logs sent by the object policy and packet filtering features.
The device supports the following log sending modes:
·     Cache log sending mode—When the first packet of a flow matches a policy, the device generates a log and caches it and starts a five-minute timer at the same time. If the log matches traffic within five minutes, the device sends the log when the timer expires. If the log does not match any traffic within five minutes, the device deletes the log. The device stops generating logs if the number of cached logs reaches the upper limit.
·     Real-time log sending mode—When the first packet of a flow matches a policy, the device sends a log immediately. For a policy that permits specific packets, the device sends only one log for a flow that matches the policy. For a policy that denies specific packets, the device sends a log for each packet of a flow that matches the policy. The number of logs is not limited.
For more information about logging configuration of the object policy and packet filtering features, see Security Configuration Guide, and ACL and QoS Configuration Guide.
# Enable real-time log sending mode.
[Sysname] aspf log sending-realtime enable
rule rule-id logging (object policy view)
rule rule-id logging (ACL and QoS Command Reference)
aspf policy
Use aspf policy to create an ASPF policy and enter its view, or enter the view of an existing ASPF policy.
Use undo aspf policy to remove an ASPF policy.
aspf policy aspf-policy-number
undo aspf policy aspf-policy-number
No ASPF policies exist.
aspf-policy-number: Assigns a number to the ASPF policy. The value range for this argument is 1 to 256.
# Create ASPF policy 1 and enter its view.
[Sysname] aspf policy 1
[Sysname-aspf-policy-1]
display aspf all
display aspf policy
detect
Use detect to configure ASPF inspection for an application layer protocol.
Use undo detect to restore the default.
detect { dns [ action { drop | logging } * ] | { ftp | h323 | http | sccp | sip | smtp } [ action drop ] | gtp | ils | mgcp | nbt | pptp | rsh | rtsp | sqlnet | tftp | xdmcp }
undo detect { dns | ftp | gtp | h323 | http | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sip | smtp | sqlnet | tftp | xdmcp }
ASPF inspects only transport layer protocols and application protocol FTP.
ASPF policy view
dns: Specifies DNS, an application layer protocol.
ftp: Specifies FTP, an application layer protocol.
gtp: Specifies GPRS Tunneling Protocol (GTP), an application layer protocol.
h323: Specifies H.323 protocol stack, application layer protocols.
http: Specifies HTTP, an application layer protocol.
ils: Specifies Internet Locator Service (ILS), an application layer protocol.
mgcp: Specifies Media Gateway Control Protocol (MGCP), an application layer protocol.
nbt: Specifies NetBIOS over TCP/IP (NBT), an application layer protocol.
pptp: Specifies Point-to-Point Tunneling Protocol (PPTP), an application layer protocol.
rsh: Specifies Remote Shell (RSH), an application layer protocol.
rtsp: Specifies Real Time Streaming Protocol (RTSP), an application layer protocol.
sccp: Specifies Skinny Client Control Protocol (SCCP), an application layer protocol.
sip: Specifies Session Initiation Protocol (SIP), an application layer protocol.
smtp: Specifies SMTP, an application layer protocol.
sqlnet: Specifies SQLNET, an application layer protocol.
tftp: Specifies TFTP, an application layer protocol.
xdmcp: Specifies X Display Manager Control Protocol (XDMCP), an application layer protocol.
action: Specifies an action on the packets that do not pass the protocol status validity check. If you do not specify an action, ASPF does not perform the protocol status validity check, and it only maintains connection status information.
drop: Drops the packets that do not pass the protocol status validity check.
logging: Generates log messages for packets that do not pass the protocol status validity check.
This command is required to ensure successful data connections for multichannel protocols when either of the following conditions exists:
·     The ALG feature is disabled in other service modules (such as NAT).
·     Other service modules with the ALG feature (such as DPI) are not configured.
This command is optional for multichannel protocols if ALG is enabled in other service modules (such as NAT) or if other service modules with the ALG feature are configured.
Application protocols supported by this command (except HTTP, SMTP, and TFTP) are multichannel protocols.
Repeat the detect command to configure ASPF inspection for multiple application protocols.
ASPF inspection for transport layer protocols is always enabled and is not configurable. The supported transport layer protocols include TCP, UDP, UDP-Lite, SCTP, Raw IP, ICMP, ICMPv6, and DCCP.
This command configures ASPF inspection for application protocols. ASPF inspection supports protocol status validity check for application protocols of DNS, FTP, H323, HTTP, SCCP, SIP, and SMTP. The device deals with packets with invalid protocol status according to the actions you have specified. To configure protocol status validity check for an application protocol, you must specify the action keyword.
# Configure ASPF inspection for FTP packets.
[Sysname-aspf-policy-1] detect ftp
# Configure ASPF inspection for DNS packets, drop packets that fail protocol status validity check and generate log messages for these packets.
[Sysname-aspf-policy-1] detect dns action drop logging
display aspf policy
display aspf all
Use display aspf all to display the configuration of all ASPF policies and their applications.
display aspf all
# Display the configuration of all ASPF policies and their applications.
<Sysname> display aspf all
ASPF policy configuration:
  Policy default:
    ICMP error message check: Disabled
    Inspected protocol    Action
      FTP                  None
  Policy number: 1
    TCP SYN packet check: Disabled
      FTP                  None
Interface configuration:
    Inbound policy : 1
    Outbound policy: none
Zone-pair security application:
  Source Trust destination Untrust
    Apply ASPF policy: default
Policy default
Predefined ASPF policy.
Whether ICMP error message check is enabled.
Whether TCP SYN check is enabled.
Inspected protocol
Protocols to be inspected by ASPF.
Action
Actions on the detected illegal packets:
·     Drop—Drops illegal packets.
·     Log—Generates log messages for illegal packets.
·     None—Allows illegal packets to pass.
If the protocol does not support the action configuration, this field displays a hyphen (-).
Interfaces where ASPF policy is applied.
Inbound policy
Inbound ASPF policy number.
Outbound policy
Outbound ASPF policy number.
Information about zone-pair security application.
Source XXX destination XXX
Source zone and destination zone.
Apply ASPF policy
Number of ASPF policy applied to the zone pair.
aspf apply policy
aspf policy
display aspf policy
Use display aspf interface to display ASPF policy application on interfaces.
# Display ASPF policy application on interfaces.
<Sysname> display aspf interface
    Inbound policy : 1
Inbound policy
Outbound policy
aspf apply policy
aspf policy
display aspf policy
Use display aspf policy to display the configuration of an ASPF policy.
display aspf policy { aspf-policy-number | default }
aspf-policy-number: Specifies the number of an ASPF policy. The value range for this argument is 1 to 256.
default: Specifies the predefined ASPF policy.
# Display the configuration of ASPF policy 1.
<Sysname> display aspf policy 1
  Policy number: 1
    TCP SYN packet check: Enabled
     FTP                  Drop
     HTTP                 None
     RSH                  -
Inspected protocol
Action
aspf policy
display aspf session
Use display aspf session to display ASPF sessions.
In standalone mode:
display aspf session [ ipv4 | ipv6 ] [ slot slot-number ] [ verbose ]
In IRF mode:
display aspf session [ ipv4 | ipv6 ] [ chassis chassis-number slot slot-number ] [ verbose ]
ipv4: Displays IPv4 ASPF sessions.
ipv6: Displays IPv6 ASPF sessions.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ASPF sessions on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ASPF sessions for all cards. (In IRF mode.)
verbose: Displays detailed information about ASPF sessions. If you do not specify this keyword, the command displays the brief information about ASPF sessions.
If you do not specify the ipv4 keyword or the ipv6 keyword, this command displays all ASPF sessions on the device.
# (In standalone mode.) Display brief information about IPv4 ASPF sessions.
<Sysname> display aspf session ipv4
Slot 1:
Initiator:
  Source      IP/port: 192.168.1.18/1877
  Destination IP/port: 192.168.1.55/22
  DS-Lite tunnel peer: -
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet1/0/1
  Source security zone: SrcZone
Initiator:
  Source      IP/port: 192.168.1.18/1792
  Destination IP/port: 192.168.1.55/2048
  Protocol: ICMP(1)
Total sessions found: 2
# (In standalone mode.) Display detailed information about IPv4 ASPF sessions.
<Sysname> display aspf session ipv4 verbose
Slot 1:
Initiator:
  Protocol: TCP(6)
Responder:
  Source      IP/port: 192.168.1.55/22
  Destination IP/port: 192.168.1.18/1877
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet1/0/2
  Source security zone: DestZone
State: TCP_SYN_SENT
Application: SSH
Start time: 2011-07-29 19:12:36  TTL: 28s
Initiator->Responder:         1 packets         48 bytes
Responder->Initiator:         0 packets          0 bytes
Initiator:
  Protocol: ICMP(1)
Responder:
  Source      IP/port: 192.168.1.55/1792
  Destination IP/port: 192.168.1.18/0
  Protocol: ICMP(1)
State: ICMP_REQUEST
Application: OTHER
Start time: 2011-07-29 19:12:33  TTL: 55s
Initiator->Responder:         1 packets         6048 bytes
Initiator
Session information from initiator to responder.
Responder
Session information from responder to initiator.
Source IP/port
Source IP address and port number.
Destination IP/port
Destination IP address and port number.
DS-Lite tunnel peer
IP address of the DS-Lite tunnel peer.
If the session is not tunneled by DS-Lite, this field displays a hyphen (-).
VPN-instance/VLAN ID/Inline ID
·     VPN-instance—MPLS L3VPN instance where the session is initiated.
·     VLAN ID—VLAN to which the session belongs during Layer 2 forwarding.
·     Inline ID—Inline to which the session belongs during Layer 2 forwarding.
If no MPLS L3VPN instance, VLAN ID, or Inline ID is specified, a hyphen (-) is displayed for each field.
Protocol
Transport layer protocols, including DCCP, ICMP, ICMPv6, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
Number in parentheses represents the protocol number.
Security zone to which the inbound interface belongs.
If the inbound interface does not belong to any security zone, this field displays a hyphen (-).
Protocol status of the session.
Application
Application layer protocol, including FTP and DNS.
If it is an unknown protocol identified by an unknown port, this field displays OTHER.
Start time
Establishment time of the session.
TTL
Remaining lifetime of the session, in seconds.
Number of packets and bytes from initiator to responder.
Number of packets and bytes from responder to initiator.
reset aspf session
icmp-error drop
Use icmp-error drop to enable ICMP error message dropping.
Use undo icmp-error drop to disable ICMP error message dropping.
icmp-error drop
ICMP error message dropping is disabled.
ASPF policy view
An ICMP error message carries information about the corresponding connection. ICMP error message dropping verifies the information. If the information does not match the connection, ASPF drops the message.
# Enable ICMP error message dropping for ASPF policy 1.
[Sysname-aspf-policy-1] icmp-error drop
aspf policy
display aspf policy
reset aspf session
Use reset aspf session to clear ASPF session statistics.
In standalone mode:
reset aspf session [ ipv4 | ipv6 ] [ slot slot-number ]
In IRF mode:
reset aspf session [ ipv4 | ipv6 ] [ chassis chassis-number slot slot-number ]
ipv4: Clears IPv4 ASPF session statistics.
ipv6: Clears IPv6 ASPF session statistics.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears ASPF session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears ASPF session statistics for all cards. (In IRF mode.)
If you do not specify the ipv4 keyword or the ipv6 keyword, this command clears all ASPF session statistics.
# Clear all ASPF session statistics.
<Sysname> reset aspf session
tcp syn-check
Use tcp syn-check to enable TCP SYN check.
Use undo tcp syn-check to disable TCP SYN check.
tcp syn-check
undo tcp syn-check
TCP SYN check is disabled.
ASPF policy view
TCP SYN check checks the first packet to establish a TCP connection whether it is a SYN packet. If the first packet is not a SYN packet, ASPF drops the packet.
When a router attached to the network is started up, it can receive a non-SYN packet of an existing TCP connection for the first time. If you do not want to interrupt the existing TCP connection, you can disable the TCP SYN check. Then, the router allows the non-SYN packet that is the first packet to establish a TCP connection to pass. After the network topology becomes steady, you can enable TCP SYN check again.
# Enable TCP SYN check for ASPF policy 1.
[Sysname-aspf-policy-1] tcp syn-check
aspf policy
