- 09-IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-Multicast routing and forwarding commands
- 03-IGMP commands
- 04-PIM commands
- 05-MSDP commands
- 06-Multicast VPN commands
- 07-MLD snooping commands
- 08-IPv6 multicast routing and forwarding commands
- 09-MLD commands
- 10-IPv6 PIM commands
10-IPv6 PIM commands | 418.05 KB |
bidir-pim enable (IPv6 PIM view)
bidir-rp-limit (IPv6 PIM view)
bsm-fragment enable (IPv6 PIM view)
bsm-reflection enable (IPv6 PIM view)
bsr-rp-mapping rfc2362 (IPv6 PIM view)
display ipv6 pim claimed-route
display ipv6 pim routing-table
hello-option dr-priority (IPv6 PIM view)
hello-option holdtime (IPv6 PIM view)
hello-option lan-delay (IPv6 PIM view)
hello-option neighbor-tracking (IPv6 PIM view)
hello-option override-interval (IPv6 PIM view)
holdtime join-prune (IPv6 PIM view)
ipv6 pim hello-option dr-priority
ipv6 pim hello-option holdtime
ipv6 pim hello-option lan-delay
ipv6 pim hello-option neighbor-tracking
ipv6 pim hello-option override-interval
ipv6 pim state-refresh-capable
ipv6 pim triggered-hello-delay
register-policy (IPv6 PIM view)
register-suppression-timeout (IPv6 PIM view)
register-whole-checksum (IPv6 PIM view)
source-lifetime (IPv6 PIM view)
spt-switch-threshold (IPv6 PIM view)
state-refresh-hoplimit (IPv6 PIM view)
state-refresh-interval (IPv6 PIM view)
IPv6 PIM commands
anycast-rp (IPv6 PIM view)
Use anycast-rp to add an anycast RP member to an Anycast RP set.
Use undo anycast-rp to remove an anycast RP member from an Anycast RP set.
anycast-rp ipv6-anycast-rp-address ipv6-member-address
undo anycast-rp ipv6-anycast-rp-address ipv6-member-address
No Anycast RP sets exist.
IPv6 PIM view
ipv6-anycast-rp-address: Specifies an Anycast RP address. It must be a legal IPv6 global unicast address.
ipv6-member-address: Specifies an Anycast RP member address. It must be a legal IPv6 global unicast address and must be different from the Anycast RP address.
In an Anycast RP set, RP members must have an interface (for example, loopback interface) with the same IPv6 address. The IPv6 address must be configured as both a C-RP and the Anycast RP address.
To add multiple RP member addresses to an Anycast RP set, execute this command multiple times with the same Anycast RP address but different RP member addresses.
To configure multiple Anycast RP sets, execute this command multiple times with different Anycast RP addresses.
# Add Anycast RP members 1:1::1 and 1:2::1 to Anycast RP set 1:1::0 on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] c-rp 1:1::0
[Sysname-pim6] anycast-rp 1:1::0 1:1::1
[Sysname-pim6] anycast-rp 1:1::0 1:2::1
display ipv6 pim rp-info
Use bidir-pim enable to enable IPv6 BIDIR-PIM.
Use undo bidir-pim enable to disable IPv6 BIDIR-PIM.
bidir-pim enable
IPv6 BIDIR-PIM is disabled.
IPv6 PIM view
This command takes effect only when IPv6 multicast routing is enabled on the public network or for the VPN instance to which the device belongs.
# Enable IPv6 multicast routing on the public network, and enable IPv6 BIDIR-PIM.
[Sysname] ipv6 multicast routing
[Sysname-mrib6] quit
[Sysname] ipv6 pim
[Sysname-pim6] bidir-pim enable
Use bidir-rp-limit to set the maximum number of IPv6 BIDIR-PIM RPs.
Use undo bidir-rp-limit to restore the default.
bidir-rp-limit limit
undo bidir-rp-limit
The maximum number of IPv6 BIDIR-PIM RPs is 6.
IPv6 PIM view
limit: Specifies the maximum number of IPv6 BIDIR-PIM RPs, in the range of 1 to the number allowed by the system.
In an IPv6 BIDIR-PIM domain, one DF election per RP is implemented on all IPv6 PIM-enabled interfaces. To avoid unnecessary DF elections, do not configure multiple RPs for IPv6 BIDIR-PIM.
This configuration sets a limit on the number of IPv6 BIDIR-PIM RPs. If the number of RPs exceeds the limit, extra RPs do not take effect and can be used only for DF election rather than IPv6 multicast data forwarding.
# Set the maximum number of IPv6 BIDIR RPs to 3 on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] bidir-rp-limit 3
Use bsm-fragment enable to enable bootstrap message (BSM) semantic fragmentation.
Use undo bsm-fragment enable to disable BSM semantic fragmentation.
bsm-fragment enable
BSM semantic fragmentation is enabled.
IPv6 PIM view
Disable BSM semantic fragmentation if the IPv6 PIM-SM or IPv6 BIDIR-PIM domain contains a device that does not support BSM semantic fragmentation.
# Disable BSM semantic fragmentation on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] undo bsm-fragment enable
Use bsm-reflection enable to enable the device to forward BSMs out of their incoming interfaces.
Use undo bsm-reflection enable to disable the device from forwarding BSMs out of their incoming interfaces.
The device forwards BSMs out of their incoming interfaces.
IPv6 PIM view
Disable this feature if all the routers in the IPv6 PIM-SM or IPv6 BIDIR-PIM domain have consistent routing information.
# Disable the device from forwarding BSMs out of their incoming interfaces on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] undo bsm-reflection enable
bsr-policy (IPv6 PIM view)
Use bsr-policy to configure a BSR policy.
Use undo bsr-policy to restore the default.
bsr-policy ipv6-acl-number
undo bsr-policy
No BSR policy exists, and all bootstrap messages are regarded as legal.
IPv6 PIM view
ipv6-acl-number: Specifies an IPv6 basic ACL by its number in the range of 2000 to 2999.
A BSR policy filters bootstrap messages to guard against BSR spoofing.
When you configure a rule in the IPv6 basic ACL, follow these restrictions and guidelines:
· An ACL rule containing the vpn-instance vpn-instance option does not take effect.
· The source source-address source-prefix option specifies a BSR address.
· Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
# Configure a BSR policy on the public network so that only the devices on subnet 2001::2/64 can act as the BSR.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source 2001::2 64
[Sysname] ipv6 pim
[Sysname-pim6] bsr-policy 2000
c-bsr (IPv6 PIM view)
Use bsr-rp-mapping rfc2362 to configure the device to use the BSR RP hash algorithm described in RFC 2362.
Use undo bsr-rp-mapping rfc2362 to restore the default.
The device uses the BSR RP hash algorithm described in RFC 4601.
IPv6 PIM view
To ensure consistent group-to-RP mappings on all routers in the PIM domain, configure all the routers to use the same BSR RP hash algorithm.
# Configure the router to use the BSR RP hash algorithm described in RFC 2362 on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] bsr-rp-mapping rfc2362
Use c-bsr to configure a candidate-BSR (C-BSR).
Use undo c-bsr to remove the configuration of a C-BSR.
c-bsr ipv6-address [ scope scope-id ] [ hash-length hash-length | priority priority ] *
undo c-bsr ipv6-address [ scope scope-id ]
No C-BSRs exist.
IPv6 PIM view
ipv6-address: Specifies the IPv6 address of a C-BSR. You must specify the IPv6 address of a local IPv6 PIM interface.
scope scope-id: Specifies an IPv6 admin-scoped zone by its ID in the range of 3 to 15. If you do not specify an IPv6 admin-scoped zone, this command designates the C-BSR to the global-scoped zone.
hash-length hash-length: Specifies a hash mask length in the range of 0 to 128. The default is 126.
priority priority: Specifies a C-BSR priority in the range of 0 to 255. The default is 64. The greater the value, the higher the priority.
If you execute this command for a zone multiple times, the most recent configuration takes effect.
You can configure the same C-BSR for different zones.
# Configure the interface with IPv6 address 1101::1 as a C-BSR for the global-scoped zone on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] c-bsr 1101::1
c-rp (IPv6 PIM view)
Use c-rp to configure a candidate-RP (C-RP).
Use undo c-rp to remove the configuration of a C-RP.
c-rp ipv6-address [ advertisement-interval adv-interval | { group-policy { ipv6-acl-number | name ipv6-acl-name } | scope scope-id } | holdtime hold-time | priority priority ] * [ bidir ]
undo c-rp ipv6-address
No C-RPs exist.
IPv6 PIM view
ipv6-address: Specifies the IPv6 address of a C-RP. You must specify the IPv6 address of a local IPv6 PIM interface.
advertisement-interval adv-interval: Specifies a C-RP advertisement message interval in the range of 1 to 65535 seconds. The default is 60 seconds.
group-policy ipv6-acl-number: Specifies an IPv6 basic ACL by its number in the range of 2000 to 2999. If you specify an ACL, this command designates the C-RP to IPv6 multicast groups in C-RP advertisement messages that the ACL permits. The C-RP is designated to all IPv6 multicast groups when one of the following conditions exists:
· You do not specify an ACL.
· The specified ACL does not exist.
· The specified ACL does not have valid rules.
group-policy name ipv6-acl-name: Specifies an IPv6 basic ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with a letter and it cannot be all. If you specify an ACL, this command designates the C-RP to IPv6 multicast groups in C-RP advertisement messages that the ACL permits. The C-RP is designated to all IPv6 multicast groups when one of the following conditions exists:
holdtime hold-time: Specifies a C-RP lifetime in the range of 1 to 65535 seconds. The default is 150 seconds.
priority priority: Specifies a C-RP priority in the range of 0 to 255. The default is 192. The greater the value, the lower the priority.
bidir: Specifies IPv6 BIDIR-PIM to which the C-RP is designated. If you do not specify this keyword, the C-RP provides services for IPv6 PIM-SM.
To designate a C-RP to multiple IPv6 multicast group ranges, create multiple rules that specify different IPv6 multicast group ranges in the ACL.
· The source source-address source-prefix option specifies an IPv6 multicast group range.
If you execute this command by using the same IPv6 address of a C-RP multiple times, the most recent configuration takes effect.
# Configure the interface with IPv6 address 2001::1 as the C-RP for IPv6 multicast group range FF0E:0:1391::/96, and set its priority to 10 on the public network.
[Sysname-acl-ipv6-basic-2000] rule permit source ff0e:0:1391:: 96
[Sysname] ipv6 pim
[Sysname-pim6] c-rp 2001::1 group-policy 2000 priority 10
crp-policy (IPv6 PIM view)
Use crp-policy to configure a C-RP policy.
Use undo crp-policy to restore the default.
crp-policy ipv6-acl-number
undo crp-policy
No C-RP policy exists, and all C-RP messages are regarded as legal.
IPv6 PIM view
ipv6-acl-number: Specifies an IPv6 advanced ACL number in the range of 3000 to 3999.
A C-RP policy filters C-RP advertisement messages to guard against C-RP spoofing.
The device uses only the prefixes of the multicast group ranges in advertisement messages to match the destination field in ACL rules. For example, the IPv6 multicast group range in a C-RP advertisement message is FF0E:0:1::/96. If the prefix FF0E:0:1:: is in the range specified by the destination field of an ACL rule, the specified C-RPs are designated to this IPv6 multicast group range.
When you configure a rule in the IPv6 ACL, follow these restrictions and guidelines:
· The source source-address source-prefix option specifies an RP address.
· The destination dest-address dest-prefix option specifies an IPv6 multicast group address.
# Configure a C-RP policy on the public network so that only devices in the address range of 2001::2/64 can be C-RPs for the groups in the range of FF03::101/64.
[Sysname-acl-ipv6-adv-3000] rule permit ipv6 source 2001::2 64 destination ff03::101 64
[Sysname-acl-ipv6-adv-3000] quit
[Sysname] ipv6 pim
[Sysname-pim6] crp-policy 3000
display ipv6 pim bsr-info
Use display ipv6 pim bsr-info to display IPv6 PIM BSR information.
display ipv6 pim [ vpn-instance vpn-instance-name ] bsr-info
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 PIM BSR information on the public network.
# Display IPv6 PIM BSR information on the public network.
<Sysname> display ipv6 pim bsr-info
Scope: non-scoped
State: Accept Preferred
Bootstrap timer: 00:01:44
Elected BSR address: 12:12::1
Priority: 64
Hash mask length: 126
Uptime: 00:21:56
Scope: 5
State: Accept Any
Scope-zone expiry timer: 00:21:12
Scope: 6
State: Elected
Bootstrap timer: 00:00:26
Elected BSR address: 17:11::1
Priority: 64
Uptime: 02:53:37
Candidate BSR address: 17:11::1
Priority: 64
Scope: 7
State: Candidate
Bootstrap timer: 00:01:56
Elected BSR address: 61:37::1
Priority: 64
Uptime: 02:53:32
Candidate BSR address: 17:12::1
Priority: 64
Scope: 8
State: Pending
Bootstrap timer: 00:00:07
Candidate BSR address: 17:13::1
Priority: 64
Bootstrap timer |
Aging timer for the BSR. |
Scope-zone expiry timer |
Aging timer for the scoped zone. |
Elected BSR address |
Address of the elected BSR. |
Candidate BSR address |
Address of the C-BSR. |
Priority |
BSR priority. |
Uptime |
Length of time the BSR has been up. |
Use display ipv6 pim claimed-route to display information about all routes that IPv6 PIM uses.
display ipv6 pim [ vpn-instance vpn-instance-name ] claimed-route [ ipv6-source-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about all routes that IPv6 PIM uses on the public network.
ipv6-source-address: Specifies an IPv6 multicast source by its IPv6 address. If you do not specify an IPv6 multicast source, this command displays information about all routes that IPv6 PIM uses.
# Display information about all routes that IPv6 PIM uses on the public network.
<Sysname> display ipv6 pim claimed-route
RPF-route selecting rule: longest-match
Route/mask: 7:11::/64 (unicast (direct))
RPF interface: GigabitEthernet1/0/1, RPF neighbor: 8::2
Total number of (S,G) or (*,G) dependent on this route entry: 4
(7:11::10, ff1e::1)
(7:11::10, ff1e::2)
(7:11::10, ff1e::3)
(*, ff1e::4)
Route/mask: 7:12::/64 (unicast)
RPF interface: GigabitEthernet1/0/1, RPF neighbor: 8::3,
Total number of (S,G) or (*,G) dependent on this route entry: 2
(7:12::10, ff1e::1)
(7:12::10, ff1e::2)
Route/mask |
Route entry. Route types in parentheses include: · igp—IGP unicast route. · egp—EGP unicast route. · unicast (direct)—Directly connected unicast route. · unicast—Other unicast route, such as static unicast route. · mbgp—IPv6 MBGP route. |
RPF interface |
Name of the RPF interface. |
RPF neighbor |
IPv6 address of the RPF neighbor. |
Total number of (S,G) or (*,G) dependent on this route entry |
Total number (S, G) or (*, G) entries associated with the RPF route and the entry list. |
display ipv6 pim c-rp
Use display ipv6 pim c-rp to display C-RP information.
display ipv6 pim [ vpn-instance vpn-instance-name ] c-rp [ local ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays information about learned C-RPs on the public network.
local: Specifies local C-RPs. If you do not specify this keyword, the command displays information about all C-RPs.
You can display information about learned C-RPs only on the BSR. On other devices, you can display information about the locally configured C-RPs.
# Display information about learned C-RPs on the public network.
<Sysname> display ipv6 pim c-rp
Scope: non-scoped
Group/MaskLen: FF00::/8 [B]
C-RP address Priority HoldTime Uptime Expires
8:12::2 (local) 192 150 00:27:48 00:01:43
Group/MaskLen: FF23::/92 Expires: 00:02:07
# Display information about the locally configured C-RPs.
<Sysname> display ipv6 pim c-rp local
Candidate RP: 8:12::2(Loop1)
Priority: 192
HoldTime: 150
Advertisement interval: 60
Next advertisement scheduled at: 00:00:46
Group/MaskLen |
IPv6 multicast group to which the C-RP is designated. |
[B] |
The C-RP is an IPv6 BIDIR-PIM RP. This field is not displayed if the C-RP is an IPv6 PIM-SM RP. |
C-RP address |
IPv6 address of the C-RP. If the C-RP resides on the device where the command is executed, this field displays (local) after the IPv6 address. |
Priority |
C-RP priority. |
HoldTime |
C-RP lifetime. |
Uptime |
Length of time the C-RP has been up: · w—Weeks. · d—Days. · h—Hours. |
Expires |
Remaining lifetime for the C-RP and the IPv6 multicast group. |
Candidate RP |
IPv6 address of the locally configured C-RP. |
Advertisement interval |
Interval between two advertisement messages sent by the locally configured C-RP. |
Next advertisement scheduled at |
Remaining time for the locally configured C-RP to send the next advertisement message. |
display ipv6 pim df-info
Use display ipv6 pim df-info to display IPv6 BIDIR-PIM DF information.
display ipv6 pim [ vpn-instance vpn-instance-name ] df-info [ ipv6-rp-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 BIDIR-PIM DF information on the public network.
ipv6-rp-address: Specifies an IPv6 BIDIR-PIM RP by its IPv6 address.
# Display IPv6 BIDIR-PIM DF information on the public network.
<Sysname> display ipv6 pim df-info
RP address: 12::12
Interface: GigabitEthernet1/0/4
State : Win DF preference: 10
DF metric : 1562 DF uptime : 00:07:15
DF address: FE80::202:FF:FE00:9 (local)
Interface: Tunnel2, FE80::20:12
State : Lose DF preference: 0
DF metric : 0 DF uptime : 00:07:15
DF address: FE80::20:12
RP address |
IP address of the IPv6 BIDIR-PIM RP. |
DF interface. If the interface is an NBMA mode-enabled ADVPN tunnel interface, this field also displays the IPv6 link-local address of the remote end. |
State |
DF election state: · Win—The interface wins the DF election. · Lose—The interface loses the DF election. · Offer—The interface is in the initial state of the DF election. · Backoff—The interface is acting as the DF, but there are more appropriate devices running for the DF. If the interface does not participate in the DF election, this field displays a hyphen (-). |
DF preference |
Advertised route preference for DF election. |
DF metric |
Advertised route metric for DF election. |
DF uptime |
Length of time the DF has been up. |
DF address |
IPv6 address of the DF. If the DF resides on the device where the command is executed, this field displays (local) after the IPv6 address. |
display ipv6 pim interface
Use display ipv6 pim interface to display IPv6 PIM information for interfaces.
display ipv6 pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number ] [ verbose ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 PIM information for interfaces on the public network.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays IPv6 PIM information for all interfaces.
verbose: Displays detailed IPv6 PIM information. If you do not specify this keyword, the command displays brief IPv6 PIM information.
# Display brief IPv6 PIM information for all interfaces on the public network.
<Sysname> display ipv6 pim interface
Interface NbrCnt HelloInt DR-Pri DR-Address
GE1/0/1 1 30 1 FE80::200:5EFF:FE04:8700
Table 5 Command output
Name of the interface. |
NbrCnt |
Number of IPv6 PIM neighbors. |
HelloInt |
Interval for sending hello messages. |
DR-Pri |
DR priority. |
DR-Address |
IPv6 address (link-local address) of the DR. |
# Display detailed IPv6 PIM information on GigabitEthernet 1/0/1 on the public network.
<Sysname> display ipv6 pim interface gigabitethernet 1/0/1 verbose
Interface: GigabitEthernet1/0/1, FE80::200:5EFF:FE04:8700
PIM version: 2
PIM mode: Sparse
PIM DR: FE80::200:AFF:FE01:101
PIM DR Priority (configured): 1
PIM neighbors count: 1
PIM hello interval: 30 s
PIM LAN delay (negotiated): 500 ms
PIM LAN delay (configured): 500 ms
PIM override interval (negotiated): 2500 ms
PIM override interval (configured): 2500 ms
PIM neighbor tracking (negotiated): disabled
PIM neighbor tracking (configured): disabled
PIM generation ID: 0xF5712241
PIM require generation ID: disabled
PIM hello hold interval: 105 s
PIM assert hold interval: 180 s
PIM triggered hello delay: 5 s
PIM J/P interval: 60 s
PIM J/P hold interval: 210 s
PIM state-refresh capable (negotiated): enabled
PIM state-refresh capable (configured): enabled
PIM state-refresh interval: 60 s
PIM state-refresh rate limit: 30 s
PIM state-refresh hop limit: 255
PIM graft retry interval: 3 s
PIM BSR domain border: disabled
PIM BFD: disabled
PIM passive: disabled
Number of routers on network not using DR priority: 0
Number of routers on network not using LAN delay: 0
Number of routers on network not using neighbor tracking: 2
Table 6 Command output
Interface name and IPv6 address (link-local address). |
PIM version |
Version of the IPv6 PIM protocol |
PIM mode |
IPv6 PIM mode: dense or sparse. |
PIM DR |
PIM DR Priority (configured) |
Configured DR priority. |
PIM neighbor count |
Total number of IPv6 PIM neighbors. |
PIM hello interval |
PIM LAN delay (negotiated) |
Negotiated IPv6 message propagation delay. |
PIM LAN delay (configured) |
Configured IPv6 message propagation delay. |
PIM override interval (negotiated) |
Negotiated interval for overriding prune messages. |
PIM override interval (configured) |
Configured interval for overriding prune messages. |
PIM neighbor tracking (negotiated) |
Negotiated neighbor tracking status: enabled or disabled. |
PIM neighbor tracking (configured) |
Configured neighbor tracking status: enabled or disabled. |
PIM require generation ID |
Whether the feature of dropping hello messages without Generation_ID is enabled. |
PIM hello hold interval |
IPv6 PIM neighbor lifetime. |
PIM assert hold interval |
Assert holdtime timer. |
PIM triggered hello delay |
Maximum delay for sending hello messages. |
PIM J/P interval |
Interval for sending join or prune messages. |
PIM J/P hold interval |
Joined/pruned state holdtime timer. |
PIM state-refresh capable (negotiated) |
Negotiated state refresh status. |
PIM state-refresh capable (configured) |
Configured state refresh status. |
PIM state-refresh rate limit |
Waiting time for accepting a new state refresh message. |
PIM state-refresh hop limit |
Hop limit value in state refresh messages. |
PIM BSR domain border |
Whether an IPv6 PIM domain border is configured. |
PIM BFD |
Whether IPv6 PIM is enabled to work with BFD. |
PIM passive |
Whether IPv6 PIM passive mode is enabled on the interface. |
Number of routers on network not using DR priority |
Number of routers that do not use the DR priority field on the subnet where the interface resides. |
Number of routers on network not using LAN delay |
Number of routers that do not use the LAN delay field on the subnet where the interface resides. |
Number of routers on network not using neighbor tracking |
Number of routers that are not enabled with neighbor tracking on the subnet where the interface resides. |
display ipv6 pim nbma-link
Use display ipv6 pim nbma-link to display remote end information maintained by IPv6 PIM for ADVPN tunnel interfaces.
display ipv6 pim [ vpn-instance vpn-instance-name ] nbma-link [ interface { interface-type interface-number } ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays remote end information maintained by IPv6 PIM for ADVPN tunnel interfaces on the public network.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays remote end information maintained by IPv6 PIM for all ADVPN tunnel interfaces.
# Display remote end information maintained by IPv6 PIM for all ADVPN tunnel interfaces on the public network.
<Sysname> display ipv6 pim nbma-link
Interface: Tunnel1
Number of links: 1
Remote address: FE80::1
Private index : 0XCE000000
Private interface: Multicast-NBMA0
Interface: Tunnel2
Number of links: 1
Remote address: FE80::2
Private index : 0XCE000001
Private interface: Multicast-NBMA1
# Display remote end information maintained by IPv6 PIM for ADVPN interface tunnel1 on the public network.
<Sysname> display ipv6 pim nbma-link interface tunnel 1
Interface: Tunnel1
Number of links: 1
Table 7 Command output
Interface name of the local tunnel interface. |
Number of links |
Number of remote ends. |
Remote address |
IPv6 address of the remote end. |
Private index |
Index of the remote end. |
Private interface |
Interface name of the remote end. |
display ipv6 pim neighbor
Use display ipv6 pim neighbor to display IPv6 PIM neighbor information.
display ipv6 pim [ vpn-instance vpn-instance-name ] neighbor [ ipv6-neighbor-address | interface interface-type interface-number | verbose ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 PIM neighbor information on the public network.
ipv6-neighbor-address: Specifies an IPv6 PIM neighbor by its IPv6 address. If you do not specify an IPv6 PIM neighbor, this command displays information about all IPv6 PIM neighbors.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays information about IPv6 PIM neighbors on all interfaces.
verbose: Displays detailed IPv6 PIM neighbor information. If you do not specify this keyword, the command displays brief IPv6 PIM neighbor information.
# Display brief information about all IPv6 PIM neighbors on the public network.
<Sysname> display ipv6 pim neighbor
Total Number of Neighbors = 2
Neighbor Interface Uptime Expires DR-Priority Mode
FE80::A01:101:1 GE1/0/1 02:50:49 00:01:31 1 B
FE80::A01:102:1 GE1/0/2 02:49:39 00:01:42 1
<Sysname> display ipv6 pim neighbor fe80::a01:101:1 verbose
Neighbor: FE80::A01:101:1
Interface: GigabitEthernet1/0/3
Uptime: 00:00:10
Expiry time: 00:00:30
DR Priority: 1
Generation ID: 0x2ACEFE15
Holdtime: 105 s
LAN delay: 500 ms
Override interval: 2500 ms
State refresh interval: 60 s
Neighbor tracking: Disabled
Bidirectional PIM: Enabled
RPF proxy vector: Disabled
Secondary address(es):
1::1
Table 8 Command output
Total Number of Neighbors |
Neighbor |
Primary IPv6 address (link-local address) of the IPv6 PIM neighbor. |
Interface that connects to the IPv6 PIM neighbor. |
Uptime |
Length of time the IPv6 PIM neighbor has been up. |
Expires/Expiry time |
Remaining lifetime for the IPv6 PIM neighbor. If the IPv6 PIM neighbor is always up and reachable, this field displays never. |
DR-Priority/DR Priority |
DR priority of the IPv6 PIM neighbor. |
Mode |
IPv6 PIM mode. This field displays B if the IPv6 PIM mode is BIDIR-PIM. This field is empty if an IPv6 PIM mode other than IPv6 BIDIR-PIM is used. |
Generation ID |
Generation ID of the IPv6 PIM neighbor. (A random value represents a status change of the IPv6 PIM neighbor.) |
Holdtime |
Lifetime of the IPv6 PIM neighbor. If the IPv6 PIM neighbor is always up and reachable, this field displays forever. |
LAN delay |
IPv6 PIM message propagation delay on the shared-media LAN. |
Override interval |
Interval for overriding prune messages. |
State refresh interval |
Interval for refreshing state. This field is displayed only when the IPv6 PIM neighbor is operating in IPv6 PIM-DM mode and the state refresh feature is enabled. |
Neighbor tracking |
Neighbor tracking status: enabled or disabled. |
Bidirectional PIM |
Whether IPv6 BIDIR-PIM is enabled. |
RPF proxy vector |
Whether the RPF proxy vector feature is enabled. For more information about the RPF proxy vector feature, see multicast VPN overview in IP Multicast Configuration Guide. |
Secondary address(es) |
Secondary IPv6 address (non-link-local address) of the IPv6 PIM neighbor. |
Use display ipv6 pim routing-table to display IPv6 PIM routing entries.
display ipv6 pim [ vpn-instance vpn-instance-name ] routing-table [ ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] | flags flag-value | fsm | incoming-interface interface-type interface-number | mode mode-type | outgoing-interface { exclude | include | match } interface-type interface-number | extranet { source-vpn-instance source-vpn-instance-name | source-public-instance | receive-vpn-instance receive-vpn-instance-name | receive-public-instance } ] *
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays IPv6 PIM routing entries on the public network.
ipv6-group-address: Specifies an IPv6 multicast group address. The value range for this argument is FFxy::/16, where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays IPv6 PIM routing entries for all IPv6 multicast groups.
prefix-length: Specifies a prefix length of the IPv6 multicast group or IPv6 multicast source address. The default is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
flags flag-value: Specifies a flag. If you do not specify a flag, this command displays IPv6 PIM routing entries that contain all flags.
The following lists the values for the flag-value argument and their meanings:
· act: Specifies IPv6 PIM routing entries that have been used for routing data.
· del: Specifies IPv6 PIM routing entries to be deleted.
· exprune: Specifies IPv6 PIM routing entries that contain outgoing interfaces pruned by other IPv6 multicast routing protocols.
· ext: Specifies IPv6 PIM routing entries that contain outgoing interfaces provided by other multicast routing protocols.
· loc: Specifies IPv6 PIM routing entries on the devices that reside on the same subnet as the IPv6 multicast source.
· niif: Specifies IPv6 PIM routing entries that contain unknown incoming interfaces.
· nonbr: Specifies IPv6 PIM routing entries with IPv6 PIM neighbor lookup failure.
· rpt: Specifies IPv6 PIM routing entries on the RPT branches where (S, G) prunes have been sent to the RP.
· rq: Specifies IPv6 PIM routing entries on the receiving side of the RPT-to-SPT switchover.
· spt: Specifies IPv6 PIM routing entries on the SPT.
· sq: Specifies IPv6 PIM routing entries on the originating side of the RPT-to-SPT switchover.
· swt: Specifies IPv6 PIM routing entries in the process of RPT-to-SPT switchover.
· wc: Specifies IPv6 PIM routing entries with wildcards.
fsm: Displays detailed information about the finite state machine.
incoming-interface interface-type interface-number: Specifies an incoming interface. If you do not specify an incoming interface, this command displays IPv6 PIM routing entries that contain all incoming interfaces.
mode mode-type: Specifies an IPv6 PIM mode. If you do not specify an IPv6 PIM mode, this command displays IPv6 PIM routing entries in all modes. The available IPv6 PIM modes include:
· bidir: Specifies IPv6 BIDIR-PIM.
· dm: Specifies IPv6 PIM-DM.
· sm: Specifies IPv6 PIM-SM.
· ssm: Specifies IPv6 PIM-SSM.
outgoing-interface { exclude | include | match } interface-type interface-number: Specifies an outgoing interface. If you do not specify an outgoing interface, this command displays IPv6 PIM routing entries that contain all outgoing interfaces. Whether the specified outgoing interface is contained in the IPv6 PIM routing table depends on the following conditions:
· If you specify an excluded interface, this command displays IPv6 PIM routing entries that do not contain the specified outgoing interface.
· If you specify an included interface, this command displays IPv6 PIM routing entries that contain the specified outgoing interface.
· If you specify a matching interface, this command displays IPv6 PIM routing entries that contain only the specified outgoing interface.
extranet: Displays information about the IPv6 PIM routing entries for MVPN extranet.
· source-vpn-instance source-vpn-instance-name: Specifies the MPLS L3VPN instance to which the multicast source belongs. The source-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters.
· source-public-instance: Specifies the public network where the multicast source resides.
· receive-vpn-instance receive-vpn-instance-name: Specifies the MPLS L3VPN instance to which the multicast receiver belongs. The receive-vpn-instance-name argument is a case-sensitive string of 1 to 31 characters.
· receive-public-instance: Specifies the public network where the multicast receiver resides.
# Display IPv6 PIM routing entries on an ADVPN network.
<Sysname> display ipv6 pim routing-table
Total 0 (*, G) entries; 1 (S, G) entries
(2001::2, FFE3::101)
RP: FE80::A01:100:1
Protocol: pim-sm, Flag: SPT LOC ACT
UpTime: 02:54:43
Upstream interface: Tunnel2, FE80::20:11
Upstream neighbor: FE80::1
RPF prime neighbor: FE80::1
Downstream interface information:
1: Tunnel2, FE80::20:12
Protocol: pim-sm, UpTime: 02:54:43, Expires: 00:02:47
# Display state machine information for the IPv6 PIM routing table on an ADVPN network.
<Sysname> display ipv6 pim routing-table fsm
Abbreviations for FSM states:
NI - no info, J - joined, NJ - not joined, P - pruned,
NP - not pruned, PP - prune pending, W - winner, L - loser,
F - forwarding, AP - ack pending, DR - designated router,
NDR - non-designated router, RCV - downstream receivers
RP: FE80::A01:100:1
UpTime: 02:54:43
Join/Prune FSM: [SPT: J] [RPT: NP]
DR state: [DR]
Join/Prune FSM: [NI]
Assert FSM: [NI]
FSM information for non-downstream interfaces: None
# Display IPv6 PIM routing entries on the public network.
RP: FE80::A01:100:1
UpTime: 02:54:43
Upstream interface: GigabitEthernet1/0/1
Upstream neighbor: NULL
RPF prime neighbor: NULL
1: GigabitEthernet1/0/2
# Display state machine information for the IPv6 PIM routing table on the public network.
RP: FE80::A01:100:1
UpTime: 02:54:43
DR state: [DR]
Assert FSM: [NI]
# Display IPv6 PIM routing entries for MVPN extranet.
<Sysname> display ipv6 pim vpn-instance vpn1 routing-table extranet receive-vpn-instance vpn2
Total 1 (*, G) entries; 1 (S, G) entries
(*, FFE3::101)
RP: FE80::A01:100:1
Protocol: pim-sm, Flag: WC
UpTime: 07:06:11
Upstream interface: Register-Tunnel0
Total number of downstream interfaces: 2
1: GigabitEthernet1/0/1
Protocol: pim-sm, UpTime: 07:06:11, Expires: -
2: Extranet (VPN: vpn2)
Protocol: MD, UpTime: 01:12:52, Expires: -
RP: FE80::A01:100:1
UpTime: 07:06:10
Upstream interface: MTunnel0
Protocol: MD, UpTime: 01:29:07, Expires: -
Total 0 (*, G) entries; 1 (S, G) entries |
Total number of (*, G) entries, and the total number of (S, G) entries. |
(2001::2, FFE3::101) |
(S, G) entry. |
RP |
IPv6 address of the RP. |
Protocol |
IPv6 PIM mode: IPv6 PIM-SM or IPv6 PIM-DM. |
Flag |
Flag of the (S, G) entry or (*, G) entry: · ACT—The entry has been used for routing data. · DEL—The entry will be removed. · EXPRUNE—Some outgoing interfaces are pruned by other IPv6 multicast routing protocols. · EXT—The entry contains outgoing interfaces provided by other multicast routing protocols. · LOC—The entry is on a router directly connected to the same subnet with the IPv6 multicast source. · NIIF—The entry contains unknown incoming interfaces. · NONBR—The entry has an IPv6 PIM neighbor lookup failure. · RPT—The entry is on an RPT branch where (S, G) prunes have been sent to the RP. · RQ—The entry is on the receiving side of the RPT-to-SPT switchover. · SPT—The entry is on the SPT. · SQ—The entry is on the originating side of the RPT-to-SPT switchover. · SWT—The entry is in the process of RPT-to-SPT switchover. · WC—The entry contains a wildcard. |
Uptime |
Length of time since the (S, G) entry or (*, G) entry was installed. |
Upstream interface |
Upstream (incoming) interface of the (S, G) entry or (*, G) entry. If the upstream interface is an NBMA mode-enabled ADVPN tunnel interface, this field also displays the IPv6 link-local address of the remote end. |
Upstream neighbor |
Upstream neighbor of the (S, G) entry or (*, G) entry. |
RPF prime neighbor |
RPF neighbor of the (S, G) or (*, G) entry: · For a (*, G) entry, if the RPF neighbor is the RP, the field displays NULL. · For an (S, G) entry, if the RPF neighbor is a router that directly connects to the IPv6 multicast source, this field displays NULL. |
Downstream interface information |
Information about the downstream interfaces: · Total number of downstream interfaces. · Names of the downstream interfaces. · Protocol type on the downstream interfaces. · Uptime of the downstream interfaces. · Expiration time of the downstream interfaces. · IPv6 link-local addresses of the remote ends associated with the downstream ADVPN tunnel interfaces. |
Extranet |
IPv6 PIM routing entry for MVPN extranet. · In the upstream interface list, the source VPN is displayed after Extranet. · In the downstream interface list, the receiver VPN is displayed after Extranet. |
Use display ipv6 pim rp-info to display RP information.
display ipv6 pim [ vpn-instance vpn-instance-name ] rp-info [ ipv6-group-address ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays RP information on the public network.
ipv6-group-address: Specifies an IPv6 multicast group address. The value range for this argument is FFxy::/16 (excluding FFx1::/16 and FFx2::/16), where "x" and "y" represent any hexadecimal numbers in the range of 0 to F. If you do not specify an IPv6 multicast group, this command displays RP information for all IPv6 multicast groups.
# Display information about the RP for IPv6 multicast group FF73:130:7:12::1 on the public network.
<Sysname> display ipv6 pim rp-info ff73:130:7:12::1
Embedded RP address is: 7:12::1
Configured ACL: 2000
BSR RP address is: 7:12::1
Priority: 192
HoldTime: 180
Uptime: 03:01:10
Expires: 00:02:30
Static RP address is: 7:12::1
Preferred: No
Configured ACL: 2003
RP mapping for this group is: 7:12::1 (local host)
Anycast-RP 7:12::1 members:
Member address State
1:1::1 Active
1:1::2 Local
1:2::1 Remote
# Display information about all RPs for all IPv6 multicast groups.
IPv6 PIM-SM embedded RP information:
Embedded RP ACL: 2000
Group RP address
FF73:230:8:12:: 8:12::2
BSR RP information:
Scope: non-scoped
Group/MaskLen: FF73:230:8:12::/64
8:12::2 (local) 192 180 03:01:36 00:02:29
Group/MaskLen: FF23::/92 [B]
7:12::1 (local) 192 180 00:00:39 00:02:57
Static RP information:
RP address ACL Mode Preferred
3:3::1 2000 pim-sm No
3:3::2 2001 pim-sm Yes
3:3::3 2002 pim-sm No
3:3::4 pim-sm No
3:3::5 2002 pim-sm Yes
Anycast-RP information:
RP address Member address State
3:3::1 1:1::1 Active
3:3::1 1:1::2 Local
3:3::1 1:2::1 Remote
Table 10 Command output
Embedded RP ACL |
ACL defining the IPv6 multicast groups to which the embedded RP is designated. |
Group |
IPv6 multicast group to which the embedded RP is designated. |
BSR RP address is |
BSR RP information |
Information about the RP. |
Group/MaskLen |
IPv6 multicast group to which the RP is designated. |
[B] |
The RP is an IPv6 BIDIR-PIM RP. This field is not displayed if the RP is an IPv6 PIM-SM RP. |
RP address |
IPv6 address of the RP. If the RP resides on the device where the command is executed, this field displays (local) after the IPv6 address. |
Priority |
Priority of the RP. |
HoldTime |
RP lifetime. |
Uptime |
Length of time the RP has been up. |
Expires |
Remaining time for the RP lifetime. |
Static RP address is/RP address |
IPv6 address of the static RP. |
Preferred |
Whether the static RP is preferred. |
Configured ACL/ACL |
ACL defining the IPv6 multicast groups to which the RP is designated. |
Mode |
RP service mode: IPv6 PIM-SM or IPv6 BIDIR-PIM. |
RP mapping for this group |
IPv6 address of the RP that provides services for the IPv6 multicast group. |
Anycast-RP 7:12::1 members |
Members of Anycast RP 7:12::1. |
Member address |
IPv6 address of the Anycast RP member. |
State |
State of the interface from which the member address originates: · Active—Activated local interface. · Local—Inactivated local interface. · Remote—Remote interface. |
display ipv6 pim statistics
Use display ipv6 pim statistics to display statistics for IPv6 PIM packets.
# Display statistics for IPv6 PIM packets.
<Sysname> display ipv6 pim statistics
Received PIM packets: 3295
Sent PIM packets : 5975
Valid Invalid Succeeded Failed
Hello : 3128 0 4333 0
Reg : 14 0 0 0
Reg-stop : 0 0 0 0
JP : 151 0 561 0
BSM : 0 0 1081 0
Assert : 0 0 0 0
Graft : 0 0 0 0
Graft-ACK: 0 0 0 0
C-RP : 0 0 0 0
SRM : 0 0 0 0
DF : 0 0 0 0
Table 11 Command output
Received PIM packets |
Total number of received IPv6 PIM packets. |
Sent PIM packets |
Total number of sent IPv6 PIM protocol packets. |
Valid |
Number of received legal IPv6 PIM protocol packets. |
Invalid |
Number of received illegal IPv6 PIM protocol packets. |
Succeeded |
Number of IPv6 PIM protocol packets that were sent successfully. |
Failed |
Number of IPv6 PIM protocol packets that failed to be sent. |
Hello |
Hello message statistics. |
Reg |
Register message statistics. |
Reg-stop |
Register-stop message statistics. |
JP |
Join or prune message statistics. |
BSM |
Bootstrap message statistics. |
Assert |
Assert message statistics. |
Graft |
Graft message statistics. |
Graft-ACK |
Graft-ACK message statistics. |
C-RP |
C-RP-Adv message statistics. |
SRM |
State refresh message statistics. |
DF |
Designated forwarder statistics. |
embedded-rp
Use embedded-rp to enable embedded RP.
Use undo embedded-rp to disable embedded RP.
embedded-rp [ ipv6-acl-number ]
undo embedded-rp
Embedded RP is disabled.
IPv6 PIM view
ipv6-acl-number: Specifies an IPv6 basic ACL number in the range of 2000 to 2999.
Embedded RP is used for RP discovery in IPv6 PIM-SM. This feature supports embedding the RP address in an IPv6 multicast group address and enables multicast routers to extract the RP address from the IPv6 multicast group address.
Embedded RP is supported only for IPv6 multicast group addresses in the range of FF7x::/12 or FFFx::/12 and in compliance with RFC 3956.
If you do not specify the ipv6-acl-number argument, this command takes effect on all IPv6 multicast groups in the range of FF7x::/12 or FFFx::/12. If you specify this argument, this command takes effect only on the IPv6 multicast groups that are in the range of FF7x::/12 or FFFx::/12 and permitted by the ACL.
When you reference an IPv6 ACL, follow these restrictions and guidelines:
· If the IPv6 ACL does not exist or contains no rules, embedded RP is enabled for all IPv6 multicast groups.
· An IPv6 ACL rule containing the vpn-instance vpn-instance option does not take effect.
# Enable embedded RP for IPv6 multicast group addresses in the range of FF7E:140:20::101/64.
[Sysname-acl-ipv6-basic-2000] rule permit source ff7e:140:20::101 64
[Sysname] ipv6 pim
[Sysname-pim6] embedded-rp 2000
Use hello-option dr-priority to set the DR priority globally.
Use undo hello-option dr-priority to restore the default.
The DR priority is 1.
IPv6 PIM view
priority: Specifies a DR priority in the range of 0 to 4294967295. The greater the value, the higher the priority.
You can set the DR priority globally for all interfaces in IPv6 PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global DR priority to 3 on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] hello-option dr-priority 3
Use hello-option holdtime to set the IPv6 PIM neighbor lifetime globally.
Use undo hello-option holdtime to restore the default.
hello-option holdtime time
The IPv6 PIM neighbor lifetime is 105 seconds.
IPv6 PIM view
time: Specifies an IPv6 PIM neighbor lifetime in the range of 1 to 65535 seconds. If you set the value to 65535 seconds, the IPv6 PIM neighbors are always reachable.
You can set the IPv6 PIM neighbor lifetime globally for all interfaces in IPv6 PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IPv6 PIM neighbor lifetime to 120 seconds on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] hello-option holdtime 120
Use hello-option lan-delay to set the IPv6 PIM message propagation delay on a shared-media LAN globally.
Use undo hello-option lan-delay to restore the default.
hello-option lan-delay delay
The IPv6 PIM message propagation delay on a shared-media LAN is 500 milliseconds.
IPv6 PIM view
delay: Specifies an IPv6 PIM message propagation delay on a shared-media LAN in the range of 1 to 32767 milliseconds.
You can set the IPv6 PIM message propagation delay globally for all interfaces in IPv6 PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global IPv6 PIM message propagation delay on a shared-media LAN to 200 milliseconds on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] hello-option lan-delay 200
Use hello-option neighbor-tracking to enable neighbor tracking globally.
Use undo hello-option neighbor-tracking to disable neighbor tracking globally.
Neighbor tracking is disabled.
IPv6 PIM view
You can enable neighbor tracking globally for all interfaces in IPv6 PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Enable neighbor tracking globally on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] hello-option neighbor-tracking
Use hello-option override-interval to set the override interval globally.
Use undo hello-option override-interval to restore the default.
The override interval is 2500 milliseconds.
IPv6 PIM view
interval: Specifies an override interval in the range of 1 to 65535 milliseconds.
You can set the override interval globally for all interfaces in IPv6 PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global override interval to 2000 milliseconds on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] hello-option override-interval 2000
Use holdtime join-prune to set the joined or pruned state holdtime globally.
Use undo holdtime join-prune to restore the default.
holdtime join-prune time
The joined or pruned state holdtime is 210 seconds.
IPv6 PIM view
time: Specifies a joined or pruned state holdtime in the range of 1 to 65535 seconds.
You can set the joined or pruned state holdtime globally for all interfaces in IPv6 PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
To prevent the upstream neighbors from aging out, you must set the join or prune interval to be less than the joined or pruned state holdtime timer.
# Set the global joined or pruned state holdtime to 280 seconds on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] holdtime join-prune 280
ipv6 pim holdtime join-prune
timer join-prune (IPv6 PIM view)
ipv6 pim
Use ipv6 pim to enter IPv6 PIM view.
Use undo ipv6 pim to remove all configurations in IPv6 PIM view.
undo ipv6 pim [ vpn-instance vpn-instance-name ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, you enter public network IPv6 PIM view.
# Enable IPv6 multicast routing on the public network, and enter the IPv6 PIM view on the public network.
[Sysname] ipv6 pim
[Sysname-pim6]
# Enable IPv6 multicast routing for VPN instance mvpn, and enter the IPv6 PIM view of VPN instance mvpn.
[Sysname] ipv6 multicast routing vpn-instance mvpn
[Sysname-mrib6-mvpn] quit
[Sysname] ipv6 pim vpn-instance mvpn
[Sysname-pim6-mvpn]
ipv6 pim bfd enable
Use ipv6 pim bfd enable to enable BFD for IPv6 PIM.
Use undo ipv6 pim bfd enable to disable BFD for IPv6 PIM.
ipv6 pim bfd enable
BFD is disabled for IPv6 PIM.
Interface view
This command takes effect only when IPv6 PIM-DM or IPv6 PIM-SM is enabled on the interface.
# Enable IPv6 multicast routing on the public network. Then, enable IPv6 PIM-DM and BFD for IPv6 PIM on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim dm
[Sysname-GigabitEthernet1/0/1] ipv6 pim bfd enable
ipv6 pim dm
ipv6 pim sm
ipv6 pim bsr-boundary
Use ipv6 pim bsr-boundary to configure an IPv6 PIM-SM domain border (a bootstrap message boundary).
Use ipv6 pim bsr-boundary to restore the default.
undo ipv6 pim bsr-boundary
An interface is not an IPv6 PIM-SM domain border.
Interface view
# Configure GigabitEthernet 1/0/1 as an IPv6 PIM-SM domain border.
[Sysname-GigabitEthernet1/0/1] ipv6 pim bsr-boundary
ipv6 multicast boundary
ipv6 pim dm
Use ipv6 pim dm to enable IPv6 PIM-DM.
Use undo ipv6 pim dm to disable IPv6 PIM-DM.
ipv6 pim dm
undo ipv6 pim dm
IPv6 PIM-DM is disabled.
Interface view
This command takes effect only when IPv6 multicast routing is enabled on the public network or for the VPN instance to which the interface belongs.
# Enable IPv6 multicast routing on the public network, and enable IPv6 PIM-DM on GigabitEthernet 1/0/1.
Use ipv6 pim hello-option dr-priority to set the DR priority on an interface.
Use undo ipv6 pim hello-option dr-priority to restore the default.
ipv6 pim hello-option dr-priority priority
Interface view
You can set the DR priority for an interface in interface view or globally for all interfaces in IPv6 PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the DR priority to 3 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim hello-option dr-priority 3
Use ipv6 pim hello-option holdtime to set the IPv6 PIM neighbor lifetime on an interface.
Use undo ipv6 pim hello-option holdtime to restore the default.
ipv6 pim hello-option holdtime time
Interface view
time: Specifies an IPv6 PIM neighbor lifetime in the range of 1 to 65535 seconds. If you set the value to 65535 seconds, the IPv6 PIM neighbor is always reachable.
You can set the IPv6 PIM neighbor lifetime for an interface in interface view or globally for all interfaces in IPv6 PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IPv6 PIM neighbor lifetime to 120 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim hello-option holdtime 120
Use ipv6 pim hello-option lan-delay to set the IPv6 PIM message propagation delay on a shared-media LAN for an interface.
Use undo ipv6 pim hello-option lan-delay to restore the default.
ipv6 pim hello-option lan-delay delay
Interface view
You can set the IPv6 PIM message propagation delay for an interface in interface view or globally for all interfaces in IPv6 PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the IPv6 PIM message propagation delay on a shared-media LAN to 200 milliseconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim hello-option lan-delay 200
Use ipv6 pim hello-option neighbor-tracking to enable neighbor tracking on an interface.
Use ipv6 pim hello-option neighbor-tracking disable to disable neighbor tracking on an interface when join message suppression is disabled globally.
Use undo ipv6 pim hello-option neighbor-tracking to restore neighbor tracking setting on an interface to be consistent with the global setting.
Neighbor tracking is disabled on an interface.
Interface view
You can enable neighbor tracking for an interface in interface view or globally for all interfaces in IPv6 PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Enable neighbor tracking on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim hello-option neighbor-tracking
# Disable neighbor tracking on GigabitEthernet 1/0/1 when neighbor tracking is enabled globally on the public network.
[Sysname]ipv6 pim
[Sysname-pim6]hello-option neighbor-tracking
[Sysname-pim6]quit
[Sysname-GigabitEthernet1/0/1] ipv6 pim hello-option neighbor-tracking disable
Use ipv6 pim hello-option override-interval to set the override interval on an interface.
Use undo ipv6 pim hello-option override-interval to restore the default.
ipv6 pim hello-option override-interval interval
Interface view
You can set the override interval for an interface in interface view or globally for all interfaces in IPv6 PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the override interval to 2000 milliseconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim hello-option override-interval 2000
Use ipv6 pim holdtime join-prune to set the joined or pruned state holdtime on an interface.
Use undo ipv6 pim holdtime join-prune to restore the default.
ipv6 pim holdtime join-prune time
Interface view
You can set the joined or pruned state holdtime for an interface in interface view or globally for all interfaces in IPv6 PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
To prevent the upstream neighbors from aging out, you must configure the join or prune interval to be less than the joined or pruned state holdtime timer.
# Set the joined or pruned state holdtime to 280 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim holdtime join-prune 280
ipv6 pim timer join-prune
ipv6 pim nbma-mode
Use ipv6 pim nbma-mode to enable NBMA mode on an ADVPN tunnel interface.
Use undo ipv6 pim nbma-mode to disable NBMA mode on an ADVPN tunnel interface.
ipv6 pim nbma-mode
NBMA mode for an ADVPN tunnel interface is disabled.
Tunnel interface view
This command is not available for IPv6 PIM-DM.
This command takes effect only when IPv6 PIM-SM is enabled on the interface on the public network or for the VPN instance to which the interface belongs.
# Enable IPv6 multicast routing on the public network, and enable NBMA mode on ADVPN tunnel interface tunnel2.
[Sysname-mrib] quit
[Sysname] interface Tunnel 2 mode advpn
[Sysname-Tunnel2] ipv6 pim sm
[Sysname-Tunnel2] ipv6 pim nbma-mode
ipv6 pim neighbor-policy
Use ipv6 pim neighbor-policy to configure an IPv6 PIM hello policy.
Use undo ipv6 pim neighbor-policy to restore the default.
ipv6 pim neighbor-policy ipv6-acl-number
No IPv6 PIM hello policy exists on an interface, and all IPv6 PIM hello messages are regarded as legal.
Interface view
An IPv6 PIM hello policy filters IPv6 PIM hello messages to guard against hello message spoofing.
· For the rule to take effect, do not specify the vpn-instance vpn-instance option.
· The source source-address source-prefix option specifies a source IPv6 address.
# Configure an IPv6 PIM hello policy on GigabitEthernet 1/0/1, so that only the devices on subnet FE80:101::101/64 can become PIM neighbors of this router.
[Sysname-acl-ipv6-basic-2000] rule permit source fe80:101::101 64
[Sysname-GigabitEthernet1/0/1] ipv6 pim neighbor-policy 2000
ipv6 pim non-stop-routing
Use ipv6 pim non-stop-routing to enable IPv6 PIM NSR.
Use undo ipv6 pim non-stop-routing to disable IPv6 PIM NSR.
IPv6 PIM NSR is disabled.
# Enable IPv6 PIM NSR.
[Sysname] ipv6 pim non-stop-routing
ipv6 pim passive
Use ipv6 pim passive to enable IPv6 PIM passive mode on an interface.
Use undo ipv6 pim passive to disable IPv6 PIM passive mode on an interface.
ipv6 pim passive
IPv6 PIM passive mode is disabled on an interface.
Interface view
# Enable IPv6 multicast routing on the public network. Then, enable IPv6 PIM-DM and IPv6 PIM passive mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim passive
ipv6 pim require-genid
Use ipv6 pim require-genid to drop hello messages without the generation ID options.
Use undo ipv6 pim require-genid to restore the default.
Hello messages without the generation ID options are accepted.
Interface view
# Enable GigabitEthernet 1/0/1 to drop hello messages without the generation ID options.
[Sysname-GigabitEthernet1/0/1] ipv6 pim require-genid
ipv6 pim sm
Use ipv6 pim sm to enable IPv6 PIM-SM.
Use undo ipv6 pim sm to disable IPv6 PIM-SM.
ipv6 pim sm
undo ipv6 pim sm
IPv6 PIM-SM is disabled.
Interface view
# Enable IPv6 multicast routing on the public network, and enable IPv6 PIM-SM on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim sm
ipv6 pim state-refresh-capable
Use ipv6 pim state-refresh-capable to enable the state refresh feature on an interface.
Use undo ipv6 pim state-refresh-capable to disable the state refresh feature.
The state refresh feature is enabled.
Interface view
# Disable the state refresh feature on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo ipv6 pim state-refresh-capable
state-refresh-hoplimit (IPv6 PIM view)
state-refresh-interval (IPv6 PIM view)
state-refresh-rate-limit (IPv6 PIM view)
ipv6 pim timer graft-retry
Use ipv6 pim timer graft-retry to set the graft retry timer.
Use undo ipv6 pim timer graft-retry to restore the default.
ipv6 pim timer graft-retry interval
The graft retry timer is 3 seconds.
Interface view
interval: Specifies a graft retry timer in the range of 1 to 65535 seconds.
# Set the graft retry timer to 80 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim timer graft-retry 80
ipv6 pim timer hello
Use ipv6 pim timer hello to set the hello interval on an interface.
Use undo ipv6 pim timer hello to restore the default.
ipv6 pim timer hello interval
The hello interval is 30 seconds.
Interface view
interval: Specifies a hello interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the interface does not send hello messages.
You can set the hello interval for an interface in interface view or globally for all interfaces in IPv6 PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the hello interval to 40 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim timer hello 40
timer hello (IPv6 PIM view)
Use ipv6 pim timer join-prune to set the join or prune interval on an interface.
Use undo ipv6 pim timer join-prune to restore the default.
ipv6 pim timer join-prune interval
The join or prune interval is 60 seconds.
Interface view
interval: Specifies a join or prune interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the interface does not send join or prune messages.
You can set the join or prune interval for an interface in interface view or globally for all interfaces in IPv6 PIM view. For an interface, the interface-specific configuration takes priority over the global configuration.
The configuration takes effect after the current interval ends.
To prevent the upstream neighbors from aging out, you must set the interval for sending join or prune messages to be less than the joined or pruned state holdtime timer.
# Set the join or prune interval to 80 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim timer join-prune 80
ipv6 pim triggered-hello-delay
Use ipv6 pim triggered-hello-delay to set the triggered hello delay (maximum delay for sending a hello message).
Use undo ipv6 pim triggered-hello-delay to restore the default.
ipv6 pim triggered-hello-delay delay
The triggered hello delay is 5 seconds.
Interface view
delay: Specifies a triggered hello delay in the range of 1 to 60 seconds.
# Set the triggered hello delay to 3 seconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 pim triggered-hello-delay 3
jp-pkt-size (IPv6 PIM view)
Use jp-pkt-size to set the maximum size of a join or prune message.
Use undo jp-pkt-size to restore the default.
jp-pkt-size size
undo jp-pkt-size
The maximum size of a join or prune message is 1200 bytes.
IPv6 PIM view
size: Specifies the maximum size of a join or prune message, in the range of 100 to 64000 bytes.
# Set the maximum size of a join or prune message to 1500 bytes on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] jp-pkt-size 1500
register-policy (IPv6 PIM view)
Use register-policy to configure an IPv6 PIM register policy.
Use undo register-policy to restore the default.
register-policy { ipv6-acl-number | name ipv6-acl-name }
No IPv6 PIM register policy exists, and all IPv6 PIM register messages are regarded as legal.
IPv6 PIM view
ipv6-acl-number: Specifies an IPv6 advanced ACL by its number in the range of 3000 to 3999. If the ACL with the specified number does not exist or does not have valid rules, all PIM register messages are filtered out.
name ipv6-acl-name: Specifies an IPv6 advanced ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with a letter and it cannot be all. If the ACL with the specified name does not exist or does not have valid rules, all PIM register messages are filtered out.
An IPv6 PIM register policy enables an RP to filter IPv6 PIM register messages so that the RP is designated only to IPv6 multicast groups permitted by the ACL.
When you configure a rule in the IPv6 advanced ACL, follow these restrictions and guidelines:
· An ACL rule containing the vpn-instance vpn-instance option does not take effect.
· The source source-address source-prefix option specifies an IPv6 multicast source address.
· The destination dest-address dest-prefix option specifies an IPv6 multicast group range.
· Among the other optional parameters, only the fragment keyword and the time-range time-range-name option take effect.
# Configure an IPv6 PIM register policy on the public network to accept register messages from sources on subnet 3:1::/64 to groups on the subnet FF0E:13::/64.
[Sysname-acl-ipv6-adv-3000] rule permit ipv6 source 3:1:: 64 destination ff0e:13:: 64
[Sysname] ipv6 pim
[Sysname-pim6] register-policy 3000
register-suppression-timeout (IPv6 PIM view)
Use register-suppression-timeout to set the register suppression time.
Use undo register-suppression-timeout to restore the default.
The register suppression time is 60 seconds.
IPv6 PIM view
interval: Specifies the register suppression time in the range of 1 to 65536 seconds.
# Set the register suppression time to 70 seconds on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] register-suppression-timeout 70
register-whole-checksum (IPv6 PIM view)
Use register-whole-checksum to configure the device to calculate the checksum based on an entire register message.
Use undo register-whole-checksum to restore the default.
The device calculates the checksum based on the register message header.
IPv6 PIM view
# Configure the device to calculate the checksum based on an entire register message on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] register-whole-checksum
snmp-agent trap enable pim6
Use snmp-agent trap enable pim6 to enable SNMP notifications for IPv6 PIM.
Use undo snmp-agent trap enable pim6 to disable SNMP notifications for IPv6 PIM.
snmp-agent trap enable pim6 [ candidate-bsr-win-election | elected-bsr-lost-election | neighbor-loss ] *
undo snmp-agent trap enable pim6 [ candidate-bsr-win-election | elected-bsr-lost-election | neighbor-loss ] *
SNMP notifications for IPv6 PIM are enabled.
candidate-bsr-win-election: Specifies notifications about winning the BSR election.
elected-bsr-lost-election: Specifies notifications about losing the BSR election.
neighbor-loss: Specifies notifications about losing neighbors.
If you do not specify an optional keyword, this command enables or disables IPv6 PIM to generate SNMP notifications.
To report critical IPv6 PIM events to an NMS, enable SNMP notifications for IPv6 PIM. For IPv6 PIM event notifications to be sent correctly, you must also configure SNMP as described in Network Management and Monitoring Configuration Guide.
# Disable SNMP notifications for IPv6 PIM.
[Sysname] undo snmp-agent trap enable pim6
source-lifetime (IPv6 PIM view)
Use source-lifetime to set the IPv6 multicast source lifetime.
Use undo source-lifetime to restore the default.
source-lifetime time
The IPv6 multicast source lifetime is 210 seconds.
IPv6 PIM view
time: Specifies an IPv6 multicast source lifetime in the range of 0 to 31536000 seconds.
· If you set the lifetime to 0 seconds, IPv6 multicast sources never age out.
· If you set the lifetime to a value in the range of 1 to 30, the value that takes effect is 30 seconds.
· If you set the lifetime to a value in the range of 31 to 31536000, the value that takes effect is the set value.
# Set the IPv6 multicast source lifetime to 200 seconds on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] source-lifetime 200
source-policy (IPv6 PIM view)
Use source-policy to configure an IPv6 multicast source policy.
Use undo source-policy to restore the default.
source-policy { ipv6-acl-number | name ipv6-acl-name }
undo source-policy
No IPv6 multicast source policy exists, The device does not filter IPv6 multicast data packets.
IPv6 PIM view
ipv6-acl-number: Specifies an IPv6 basic or advanced ACL by its number in the range of 2000 to 3999. If the ACL with the specified number does not exist or does not have valid rules, all IPv6 multicast data packets are filtered out.
name ipv6-acl-name: Specifies an IPv6 basic or advanced ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with a letter and it cannot be all. If the ACL with the specified name does not exist or does not have valid rules, all IPv6 multicast data packets are filtered out.
An IPv6 multicast source policy filters IPv6 multicast data packets to control information available to downstream receivers.
· In a basic ACL, the source source-address source-prefix option specifies a source IPv6 address.
· In an advanced ACL, the source source-address source-prefix option specifies a source IPv6 address. The destination dest-address dest-prefix option specifies an IPv6 multicast group address.
# Configure an IPv6 multicast source policy on the public network to accept IPv6 multicast data from source 3121::1 and to deny the data from source 3121::2.
[Sysname] acl ipv6 basic 2000
[Sysname-acl-ipv6-basic-2000] rule permit source 3121::1 128
[Sysname-acl-ipv6-basic-2000] rule deny source 3121::2 128
[Sysname] ipv6 pim
[Sysname-pim6] source-policy 2000
[Sysname-pim6] quit
spt-switch-threshold (IPv6 PIM view)
Use spt-switch-threshold to configure a criterion for an RPT-to-SPT switchover.
Use undo spt-switch-threshold to remove criteria for RPT-to-SPT switchovers.
spt-switch-threshold { traffic-rate | immediacy | infinity } [ group-policy ipv6-acl-number ]
undo spt-switch-threshold [ traffic-rate | immediacy | infinity ] [ group-policy ipv6-acl-number ]
The first IPv6 multicast data packet triggers an RPT-to-SPT switchover.
IPv6 PIM view
traffic-rate: Specifies a traffic rate threshold for triggering an RPT-to-SPT switchover, in the range of 1 to 4194304 kbps.
immediacy: Triggers an RPT-to-SPT switchover immediately.
infinity: Disables RPT-to-SPT switchover.
group-policy ipv6-acl-number: Specifies an IPv6 basic ACL by its number in the range of 2000 to 2999. If you specify an ACL, the configuration applies to the IPv6 multicast groups that the ACL permits. The configuration applies to all IPv6 multicast groups when one of the following conditions exists:
· You do not specify an ACL.
· The specified ACL does not exist.
· The specified ACL does not have valid rules.
When you configure a rule in the IPv6 basic ACL, follow these restrictions and guidelines:
· The source source-address source-prefix option specifies an IPv6 multicast group address.
You can configure multiple traffic rate thresholds by executing this command multiple times. However, if you specify the same ACL in the command, the most recent configuration takes effect. If the configured traffic rate thresholds are applied to the same multicast group, the first configuration takes effect.
The source-side DR cannot encapsulate multicast packets in register packets sent to the RP. To avoid multicast traffic forwarding failure, do not disable RPT-to-STP switchover on the devices that might become an RP.
# Set the traffic rate threshold to 4 kbps for triggering an RPT-to-SPT switchover on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] spt-switch-threshold 4
# Disable RPT-to-SPT switchover on receiver-side DR on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] spt-switch-threshold infinity
ssm-policy (IPv6 PIM view)
Use ssm-policy to configure the IPv6 SSM group range.
Use undo ssm-policy to restore the default.
ssm-policy { ipv6-acl-number | name ipv6-acl-name }
undo ssm-policy
The IPv6 SSM group range is FF3x::/32, where x can be any valid scope.
IPv6 PIM view
ipv6-acl-number: Specifies an IPv6 basic ACL by its number in the range of 2000 to 2999. If the ACL with the specified number does not exist or does not have valid rules, the device does not use the IPv6 PIM-SSM node.
name ipv6-acl-name: Specifies an IPv6 basic ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with a letter and it cannot be all. If the ACL with the specified name does not exist or does not have valid rules, the device does not use the IPv6 PIM-SSM node.
This command defines an IPv6 multicast group range that is used by IPv6 PIM-SSM. The IPv6 PIM-SSM mode applies to IPv6 multicast packets that are permitted by the ACL. The IPv6 PIM-SM mode applies to IPv6 multicast packets that are not permitted by the ACL.
· The source source-address source-prefix option specifies an IPv6 multicast group range.
# Configure the IPv6 SSM group range as FF3E:0:8192::/96.
[Sysname-acl-ipv6-basic-2000] rule permit source ff3e:0:8192:: 96
[Sysname] ipv6 pim
[Sysname-pim6] ssm-policy 2000
Use state-refresh-hoplimit to set the hop limit for state refresh messages.
Use undo state-refresh-hoplimit to restore the default.
state-refresh-hoplimit hoplimit-value
The hop limit for state refresh messages is 255.
IPv6 PIM view
hoplimit-value: Specifies the hop limit for state refresh messages, in the range of 1 to 255.
# Set the hop limit for state refresh messages to 45 on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-hoplimit 45
Use state-refresh-interval to set the state refresh interval.
Use undo state-refresh-interval to restore the default.
The state refresh interval is 60 seconds.
IPv6 PIM view
interval: Specifies a state refresh interval in the range of 1 to 255 seconds.
# Set the state refresh interval to 70 seconds on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-interval 70
Use state-refresh-rate-limit to set the waiting time to accept a new state refresh message.
Use undo state-refresh-rate-limit to restore the default.
state-refresh-rate-limit time
The device waits 30 seconds before it accepts a new state refresh message.
IPv6 PIM view
time: Specifies the waiting time to accept a new refresh message, in the range of 1 to 65535 seconds.
# Set the waiting time to 45 seconds to accept a new state refresh message on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] state-refresh-rate-limit 45
static-rp (IPv6 PIM view)
Use static-rp to configure a static RP.
Use undo static-rp to delete a static RP.
static-rp ipv6-rp-address [ { ipv6-acl-number| name ipv6-acl-name } | bidir | preferred ] *
undo static-rp ipv6-rp-address
No static RPs exist.
IPv6 PIM view
ipv6-rp-address: Specifies the IPv6 address of the static RP. This address must be a valid IPv6 global unicast address.
ipv6-acl-number: Specifies an IPv6 basic ACL by its number in the range of 2000 to 2999. If you specify an ACL, the static RP is designated only to IPv6 multicast groups that the ACL permits. The static RP is designated to all IPv6 multicast groups when one of the following conditions exists:
name ipv6-acl-name: Specifies an IPv6 basic ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must begin with a letter and it cannot be all. If you specify an ACL, the static RP is designated only to multicast groups that the ACL permits. The static RP is designated to all IPv6 multicast groups when one of the following conditions exists:
bidir: Specifies IPv6 BIDIR-PIM to which the static RP is designated. If you do not specify this keyword, the PIM mode is IPv6 PIM-SM.
preferred: Gives priority to the static RP if the static RP and the dynamic RP exist at the same time on the network. The dynamic RP takes effect only when no static RP exists on the network. If you do not specify this keyword, the dynamic RP has priority. The static RP takes effect only when the dynamic RP fails.
You do not need to enable IPv6 PIM on an interface that acts as a static RP.
When rules in the ACL used by a static RP change, new RPs are dynamically elected for all IPv6 multicast groups.
You can configure multiple static RPs by using this command multiple times. However, if you specify the same static RP address or use the same ACL in the commands, the most recent configuration takes effect. If you configure multiple static RPs for the same IPv6 multicast group, the static RP with the highest IPv6 address is used.
# Configure the interface with IPv6 address 2001::2 as a static RP for IPv6 multicast group range FF03::101/64 and give priority to this static RP on the public network.
[Sysname] acl ipv6 basic 2001
[Sysname-acl-ipv6-basic-2001] rule permit source ff03::101 64
[Sysname] ipv6 pim
[Sysname-pim6] static-rp 2001::2 2001 preferred
Use timer hello to set the hello interval globally.
Use undo timer hello to restore the default.
undo timer hello
IPv6 PIM view
interval: Specifies a hello interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the device does not send hello messages.
You can set the hello interval globally for all interfaces in IPv6 PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
# Set the global hello interval to 40 seconds on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] timer hello 40
Use timer join-prune to set the join or prune interval globally.
Use undo timer join-prune to restore the default.
IPv6 PIM view
interval: Specifies a join or prune interval in the range of 0 to 18000 seconds. If you set the value to 0 seconds, the device does not send join or prune messages.
You can set the join or prune interval globally for all interfaces in IPv6 PIM view or for an interface in interface view. For an interface, the interface-specific configuration takes priority over the global configuration.
To prevent the upstream neighbors from aging out, you must set the join or prune interval to be less than the joined or pruned state holdtime.
# Set the global join or prune interval to 80 seconds on the public network.
[Sysname] ipv6 pim
[Sysname-pim6] timer join-prune 80
holdtime join-prune (IPv6 PIM view)
