04-Layer 2—LAN Switching Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R6749-6W10104-Layer 2—LAN Switching Command Reference
05-QinQ commands
05-QinQ commands 68.93 KB
QinQ commands
This document uses the following terms:
·     CVLAN—Customer network VLANs, also called inner VLANs, refer to VLANs that a customer uses on the private network.
·     SVLAN—Service provider network VLANs, also called outer VLANs, refer to VLANs that a service provider uses to transmit VLAN tagged traffic for customers.
display qinq
Use display qinq to display QinQ-enabled interfaces.
display qinq [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays all QinQ-enabled interfaces.
If QinQ is not enabled on any interfaces, this command does not provide any output.
# Enable QinQ on GigabitEthernet 1/0/1. Then, verify that QinQ is enabled on the interface.
[Sysname-GigabitEthernet1/0/1] qinq enable
[Sysname-GigabitEthernet1/0/1] display qinq interface gigabitethernet 1/0/1
# Enable QinQ on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/3. Then, verify that QinQ is enabled on the interfaces.
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] qinq enable
[Sysname-GigabitEthernet1/0/3] display qinq
qinq enable
qinq enable
Use qinq enable to enable QinQ on an interface.
Use undo qinq enable to disable QinQ on an interface.
qinq enable
undo qinq enable
QinQ is disabled on interfaces.
VEB interface view
display qinq
qinq ethernet-type (interface view)
Use qinq ethernet-type to set the TPID value in SVLAN tags on an interface.
Use undo qinq ethernet-type to restore the default TPID value in SVLAN tags on an interface.
qinq ethernet-type service-tag { hex-value | dot1ad | dot1q }
undo qinq ethernet-type service-tag
If the device supports global TPID configuration, the interface-level TPID value in SVLAN tags equals the global TPID value.
If the device does not support global TPID configuration, the TPID value in SVLAN tags is 8100 in hexadecimal notation.
VEB interface view
service-tag: Sets the TPID value in the SVLAN tag.
hex-value: Sets a hexadecimal TPID value in the range of 600 to ffff, excluding the reserved EtherType values listed in Table 1.
Table 1 Reserved EtherType values
Protocol type
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86dd
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
LLDP
0x88cc
802.1X
0x888e
802.1ag
0x8902
Cluster
0x88a7
Reserved
0xfffd/0xfffe/0xffff
dot1ad: Sets the hexadecimal TPID value to 88a8.
dot1q: Sets the hexadecimal TPID value to 8100.
For a port, the TPID value set in interface view applies preferentially over the TPID value set in system view.
# Set the TPID value in SVLAN tags to 9100 (hexadecimal) on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qinq ethernet-type service-tag 9100
qinq ethernet-type (system view)
Use qinq ethernet-type to set the TPID value in CVLAN tags globally.
Use undo qinq ethernet-type to restore the default TPID value in CVLAN tags globally.
qinq ethernet-type customer-tag { hex-value | dot1ad | dot1q }
undo qinq ethernet-type customer-tag
The global TPID value in CVLAN tags is 8100 in hexadecimal notation.
customer-tag: Sets the TPID value in the CVLAN tag.
hex-value: Sets a hexadecimal TPID value in the range of 600 to ffff, excluding the reserved EtherType values listed in Table 2.
Table 2 Reserved EtherType values
Protocol type
Value
ARP
0x0806
PUP
0x0200
RARP
0x8035
IP
0x0800
IPv6
0x86dd
PPPoE
0x8863/0x8864
MPLS
0x8847/0x8848
IPX/SPX
0x8137
IS-IS
0x8000
LACP
0x8809
LLDP
0x88cc
802.1X
0x888e
802.1ag
0x8902
Cluster
0x88a7
Reserved
# Set the global TPID value in CVLAN tags to 88a8 (hexadecimal).
[Sysname] qinq ethernet-type customer-tag dot1ad
