03-Interface Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R6749-6W10103-Interface Command Reference
04-POS interface commands
04-POS interface commands 205.87 KB
Commands in this chapter are supported only when the device has related interfaces. For the interfaces that the device has, see the installation guide and interface module manuals.
Unless otherwise noted, the term "POS interfaces" in this document refers to standard POS interfaces.
bandwidth
Use bandwidth to configure the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
Standard POS interface view
POS subinterface view
# Set the expected bandwidth to 50 kbps for POS 2/2/1.
[Sysname] interface pos 2/2/1
[Sysname-Pos2/2/1] bandwidth 50
clock
Use clock to set the clock mode of a standard POS interface.
Use undo clock to restore the default.
clock { master | slave }
undo clock
The clock mode of a POS interface is slave.
master: Sets the clock mode to master.
slave: Sets the clock mode to slave.
Standard POS interfaces support the following clock modes:
·     Master—Uses internal clock signal.
·     Slave—Uses line clock signal.
If the standard POS interface is connected to another router, set its clock mode to be different from the mode used by the remote end. If the standard POS interface is connected to a SONET/SDH device, which provides higher clock precision, always set its clock mode to slave.
# Set the clock mode to master for POS 2/2/1.
[Sysname-Pos2/2/1] clock master
crc
Use crc to set the CRC length on an interface.
Use undo crc to restore the default.
crc { 16 | 32 }
undo crc
The CRC length on an interface is 32 bits.
16: Sets the CRC length to 16 bits.
32: Sets the CRC length to 32 bits.
The CRC length must be the same at both ends.
# Set the CRC length to 16 bits on POS 2/2/1.
[Sysname-Pos2/2/1] crc 16
dampening
Use dampening to enable the device to dampen an interface when it is flapping.
Use undo dampening to disable interface dampening.
undo dampening
Interface dampening is disabled on POS interfaces.
half-life: Specifies the amount of time (in seconds) for a penalty to decrease by half of its value. The value range is 1 to 120 seconds, and the default is 54 seconds.
reuse: Specifies the reuse threshold. The value range is 200 to 20000, and the default is 750. The reuse threshold must be lower than the suppression threshold.
suppress: Specifies the suppression threshold. The value range is 200 to 20000, and the default is 2000.
max-suppress-time: Specifies the maximum amount of time an interface can be dampened. The value range is 1 to 255 seconds, and the default is 162 seconds (three times the default half-life timer).
This command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the higher layer protocols.
For more information about the interface dampening feature, see Interface Configuration Guide.
# Configure interface dampening on POS 2/2/1.
[Sysname-Pos2/2/1] dampening 2 800 3000 5
display interface pos
default
Use default to restore the default settings for an interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. You can use the display this command in interface view to check for these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
# Restore the default settings of POS 2/2/1.
[Sysname-Pos2/2/1] default
description
The interface description uses the interface-name Interface format, for example, Pos2/2/1 Interface.
text: Specifies the description, a case-sensitive string of 1 to 255 characters.
# Configure the description of POS 2/2/1 as pos-interface.
[Sysname-Pos2/2/1] description pos-interface
Use display interface pos to display information about POS interfaces.
display interface [ pos [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
pos [ interface-number | interface-number.subnumber ]: Specifies a standard POS interface or POS subinterface. The interface-number.subnumber arguments specify a POS subinterface. The interface-number argument specifies the main interface number, and the subnumber argument specifies the subinterface number in the range of 0 to 1023. If you do not specify the pos keyword, this command displays information about all interfaces except VA interfaces on the device. If you specify the pos keyword without specifying an interface, this command displays information about all POS interfaces. For more information about VA interfaces, see PPPoE configuration in Layer 2—WAN Access Configuration Guide.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays physically down interfaces and their down causes. If you do not specify this keyword, the command displays information about interfaces in any state.
# Display detailed information about POS 2/2/1.
<Sysname> display interface pos 2/2/1
Pos2/2/1
Current state: DOWN
Line protocol state: DOWN
Description: Pos2/2/1 Interface
Bandwidth: 155520kbps
Hold timer: 10 seconds, retry times: 5
Link layer protocol: PPP
LCP: initial
Physical layer is non-channelized STM-1/OC-3
Frame-format is SDH,Current baudrate is 155520000 bps
Scramble: enabled, crc: 32, clock: slave, loopback: not set
SD Threshold:6,SF Threshold:3
Optical:Absent
Output queue - Urgent queuing: Size/Length/Discards 0/1024/0
Output queue - FIFO queuing: Size/Length/Discards 0/1024/0
Last link flapping: Never
Current system time:2019-11-13 17:31:18
Last time when physical state changed to up:-
Last time when physical state changed to down:2019-11-05 15:16:24
Regenerator section:
  Alarm:  LOS  LOF  OOF  RS_TIM
  ERROR:  RS_BIP(B1) 0
  Tx: J0: ""
  Rx: J0: unknown
Multiplex section:
  Alarm:  MS_AIS
  ERROR:  MS_BIP(B2) 0, MS_REI 0
High order Path:
  Alarm:  AU_AIS  HP_RDI  HP_PLM
  ERROR:  HP_BIP(B3) 0, HP_REI 0, HP_PJE 0, HP_NJE 0
  TX: J1: ""
  RX: J1: unknown
  TX: C2: 0x16
  RX: C2: 0xff
Last 5 seconds input rate 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
Last 5 seconds output rate 0.00 bytes/sec, 0 bits/sec, 0.00 packets/sec
    Input: 0 packets, 0 bytes, 0 no buffers
           0 errors, 0 runts, 0 giants, 0 CRC,
           0 overruns, 0 aborts
    Output:0 packets, 0 bytes
           0 errors, 0 underruns, 0 aborts
# Display brief information about POS 2/2/1.
<Sysname> display interface pos 2/2/1 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Pos2/2/1             DOWN DOWN     --
# Display brief information about all standard POS interfaces, POS subinterfaces, and POS channel interfaces in a down state and the causes.
<Sysname> display interface pos brief down
Pos2/2/1             ADM  Administratively
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
Description of the interface.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
Dampening enabled:
 Penalty: 0 (not suppressed)
 Ceiling: 4525
 Reuse: 800
 Suppress: 3000
 Half-life: 2 seconds
 Max-suppress-time: 5 seconds
 Flap count: 0
Interface dampening information:
·     Dampening enabled—The dampening feature is enabled.
·     Penalty—Penalty value. The interface suppression state is displayed in parentheses.
¡     Not suppressed—The interface is not dampened. Interface state changes are reported to higher layer protocols.
¡     Suppressed—The interface is dampened. Interface state changes are not reported to higher layer protocols.
·     Ceiling—Maximum penalty value.
·     Reuse—Reuse threshold.
·     Suppress—Suppression threshold.
·     Half-life—Half-life timer.
·     Max-suppress-time—Maximum suppression time.
·     Flap count—Number of times that the interface has flapped.
These fields are not displayed if dampening is disabled on the interface.
Hold timer
Interval at which the data link layer protocol sends keepalives.
retry times
Maximum number of keepalive attempts.
The interface determines that the remote end is down if it does not receive a keepalive response after the maximum number of keepalive attempts have been made.
The interface is not assigned an IP address and cannot process IP packets.
IP address of the interface and type of the address in parentheses.
Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3IP Services Configuration Guide.
·     BOOTP-allocatedBOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3IP Services Configuration Guide.
·     PPP-negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2WAN Access Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     Cellular-allocated—IP address allocated through the modem-manufacturer's proprietary protocol. For more information, see mobile communication modem management in Layer 2WAN Access Configuration Guide.
·     MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide.
·     MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide.
Link layer protocol
Data link layer protocol of the interface.
LCP: opened, IPCP: opened
Both LCP negotiation and IPCP negotiation succeeded.
Physical layer
Physical interface.
Frame-format
Framing format of the interface.
Current baudrate
Current baud rate of the interface.
Baudrate
Baud rate of the interface.
Scramble
Payload scrambling state.
crc
CRC length.
clock
Clock mode.
loopback
Loopback state.
SD Threshold
SD alarm threshold.
SF Threshold
SF alarm threshold.
Optical
Transceiver module information.
Output queue (the number of messages, the maximum number of messages that can be accommodated, and the number of dropped messages in the urgent queue).
Output queue (the number of messages, the maximum number of messages that can be accommodated, and the number of dropped messages in the protocol queue).
Output queue (the number of messages, the maximum number of messages that can be accommodated, and the number of dropped messages in the FIFO queue).
SONET alarm
SONET alarms.
SONET error
SONET errors.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
The most recent time that the reset counters interface pos command was executed. This field displays Never if the command has not been executed on the interface since device startup.
Current system time
Current system time in the YYYY-MM-DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY-MM-DD HH:MM:SS UTC±HH:MM:SS format.
Tx: J0
Transmitted overhead byte.
Rx: J0
Received overhead byte.
Last 300 seconds input rate
Average input rates (in Bps, bps, and pps) for the last 300 seconds.
Last 300 seconds output rate
Average output rates (in Bps, bps, and pps) for the last 300 seconds.
Input:
  0 packets, 0 bytes
  0 overruns, 0 aborts, 0 no buffers
Inbound traffic statistics for the POS interface:
·     errors—Number of inbound packets with errors detected at the physical layer.
·     runts—Number of inbound packets shorter than the minimum frame length.
·     giants—Number of inbound packets larger than the maximum frame length.
·     CRC—Total number of inbound normal-size packets with CRC errors.
·     overruns—Number of packet drops because the input rate of the interface exceeded the forwarding capability.
·     aborts—Number of invalid inbound frames.
·     no buffers—Number of packet drops because the receive buffer is full.
Output:
  0 packets, 0 bytes
Outbound traffic statistics for the POS interface:
·     errors—Number of outbound packets with errors detected at the physical layer.
·     underruns—Number of packets dropped because the output rate of the interface exceeded the memory reading rate.
·     aborts—Total number of invalid outbound packets.
Brief information about Layer 3 interfaces.
Abbreviated interface name.
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN:
·     Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
flag c2
Use flag c2 to set the C2 path signal label byte.
Use undo flag c2 to restore the default.
flag c2 flag-value
undo flag c2
The C2 value is 16 in hexadecimal notation.
flag-value: Specifies a C2 byte value, a hexadecimal number in the range of 0 to ff.
The C2 byte is a higher-order path overhead byte. It indicates the multiplex structure of virtual container (VC) frames and the property of payload.
When the C2 byte of one end is set to 1, the C2 byte of the other end can be set to any character in hexadecimal notation. If the C2 byte of either ends of a link is not set to 1, the C2 byte must be the same at both ends.
# Set the C2 byte to 01 in hexadecimal notation on POS 2/2/1.
[Sysname-Pos2/2/1] flag c2 01
flag j0
Use flag j0 to set the J0 regenerator section trace byte for SONET or SDH frames.
Use undo flag j0 to restore the default.
flag j0 { sdh | sonet } flag-value
undo flag j0 { sdh | sonet }
The device uses the SDH framing format. In SDH frames, the J0 byte value is null.
flag-value: Specifies the J0 byte. It must be a string of 1 to 15 characters for SDH, and a hexadecimal number in the range of 0 to ff for SONET.
sdh: Specifies the SDH framing format.
sonet: Specifies the SONET framing format.
J0 byte is a section overhead byte. SDH and SONET use this byte to test continuity of the connection between two interfaces at the section level.
The J0 byte can be different on devices of the same service provider. On the interfaces between two service providers, the J0 byte must be the same.
When a POS interface uses the SDH framing format, you cannot set the J0 regenerator section trace byte for SONET frames on the interface.
When a POS interface uses the SONET framing format, you cannot set the J0 regenerator section trace byte for SDH frames on the interface.
# Set the J0 byte to ff in hexadecimal notation for SDH on POS 2/2/1.
[Sysname-Pos2/2/1] flag j0 sdh ff
frame-format
flag j1
Use flag j1 to set the J1 path trace byte for SONET or SDH frames.
Use undo flag j1 to restore the default.
flag j1 { sdh | sonet } flag-value
undo flag j1 { sdh | sonet }
The device uses the SDH framing format. In SDH frames, the J1 byte value is null.
flag-value: Specifies a J1 byte value. It must be a string of 1 to 15 characters for SDH and a string of 1 to 62 characters for SONET.
J1 byte is a higher-order path overhead byte. SDH and SONET use this byte to test continuity of the connection between two interfaces at the path level.
The J1 byte must be the same at both ends of a link.
When a POS interface uses the SDH framing format, you cannot set the J1 path trace byte for SONET frames on the interface.
When a POS interface uses the SONET framing format, you cannot set the J1 path trace byte for SOH frames on the interface.
# Set the J1 byte to aabbcc for SDH on POS 2/2/1.
[Sysname-Pos2/2/1] flag j1 sdh aabbcc
·     flag j1 ignore
frame-format
flow-interval
Use flow-interval to set the statistics polling interval for an interface.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is 300 seconds.
interval: Specifies the statistics polling interval in the range of 5 to 300 and in steps of 5, in seconds.
In system view, the command takes effect on all interfaces.
# Set the statistics polling interval to 180 seconds for interfaces.
[Sysname] flow-interval 180
frame-format
Use frame-format to set the framing format on a standard POS interface.
Use undo frame-format to restore the default.
frame-format { sdh | sonet }
undo frame-format
The framing format is SDH on a standard POS interface.
When you use the flag j0 and flag j1 commands to set the overhead bytes, the settings must match the framing format.
When a POS interface uses the SDH framing format, you cannot set the J0 regenerator section trace byte or J1 path trace byte for SONET frames on the interface.
When a POS interface uses the SONET framing format, you cannot set the J0 regenerator section trace byte or J1 path trace byte for SDH frames on the interface.
# Set the framing format to SONET on POS 2/2/1.
[Sysname-Pos2/2/1] frame-format sonet
flag j0
flag j1
interface pos
Use interface pos to create a POS subinterface and enter its view, or enter the view of an existing standard POS interface or POS subinterface.
Use undo interface pos to delete a POS subinterface.
interface pos { interface-number | interface-number.subnumber [ p2mp | p2p ] }
undo interface pos interface-number.subnumber
No POS subinterfaces exist.
interface-number: Specifies a standard POS interface or POS channel interface by its number.
interface-number.subnumber: Specifies a POS subinterface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number in the range of 0 to 1023.
p2mp: Sets the subinterface type to point-to-multipoint. By default, a POS subinterface is P2MP type.
p2p: Sets the subinterface type to point-to-point.
You can create POS subinterfaces only on Frame Relay-enabled standard POS interfaces.
# Enter the view of POS 2/2/1.
[Sysname-Pos2/2/1]
# Create POS subinterface POS 2/2/1.1.
[Sysname] interface pos 2/2/1.1
[Sysname-Pos2/2/1.1]
link-protocol
link-protocol
Use link-protocol to set the data link layer protocol of an interface.
link-protocol { fr | hdlc | ppp }
PPP is used.
fr: Specifies Frame Relay as the data link layer protocol of the interface.
hdlc: Specifies HDLC as the data link layer protocol of the interface.
ppp: Specifies PPP as the data link layer protocol of the interface.
# Specify HDLC as the data link protocol of POS 2/2/1.
[Sysname-Pos2/2/1] link-protocol hdlc
loopback
Use loopback to enable loopback for a standard POS interface.
Use undo loopback to disable loopback for a standard POS interface.
loopback { local | remote }
undo loopback
Loopback is disabled on a standard POS interface.
local: Enables internal loopback.
remote: Enables external loopback.
Loopback is intended for testing only. Disable the feature when the interface is operating correctly.
Before you use this command on a standard POS interface, make sure its clock mode is master.
If you enable internal loopback on an unconnected standard POS interface, the status of the data link layer protocol changes to up.
# Enable internal loopback on POS 2/2/1.
[Sysname-Pos2/2/1] loopback local
clock
mtu
Use mtu to set the MTU size for an interface.
mtu size
undo mtu
The MTU size for an interface is 1500 bytes.
size: Sets the maximum transmission unit (MTU) in bytes. The value range for this argument is 128 to 1650.
The MTU setting affects the assembly and fragmentation of IP packets.
After configuring the MTU for an interface, you must use the shutdown command and then the undo shutdown command on the interface for the modification to take effect.
# Set the MTU to 1430 bytes for POS 2/2/1.
[Sysname-Pos2/2/1] mtu 1430
Use reset counters interface pos to clear interface statistics.
reset counters interface [ pos [ interface-number | interface-number.subnumber ] ]
pos [ interface-number | interface-number.subnumber ]: Clears statistics for a standard POS interface, POS channel interface,. The interface-number.subnumber arguments specify a POS subinterface. The interface-number argument specifies the main interface number, and the subnumber argument specifies the subinterface number in the range of 0 to 1023. If you do not specify the pos keyword, this command clears statistics for all interfaces except VA interfaces. If you specify the pos keyword without specifying an interface, this command clears statistics for all standard POS interfaces, POS subinterfaces,. For more information about VA interfaces, see PPPoE configuration in Layer 2—WAN Access Configuration Guide.
Use this command to clear history statistics before you collect statistics for a time period.
# Clear statistics for POS 2/2/1.
<Sysname> reset counters interface pos 2/2/1
scramble
Use scramble to enable payload scrambling on an interface.
Use undo scramble to disable payload scrambling on an interface.
scramble
undo scramble
Payload scrambling is enabled on standard POS interfaces and POS channel interfaces.
Payload scrambling enables an interface to scramble outgoing data and descramble incoming data. By preventing the presence of long strings of all 1s or all 0s, payload scrambling enables the receiving end to extract the line clock signal correctly.
If payload scrambling is disabled, the interface does not scramble outgoing data or descramble incoming data.
The payload scrambling setting must be the same at both ends of a link to ensure correct communication.
After payload scrambling is enabled or disabled on an interface, the C2 byte on the interface does not change automatically. Use the flag c2 command to set the same C2 byte on the interface as its peer.
# Enable payload scrambling on POS 2/2/1.
[Sysname-Pos2/2/1]scramble
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to bring up an interface.
shutdown
An interface is up.
# Shut down POS 2/2/1.
[Sysname-Pos2/2/1] shutdown
snmp-agent trap enable { b1-tca | b2-tca | b3-tca }
Use snmp-agent trap enable { b1-tca | b2-tca | b3-tca } to enable SNMP notifications about signal transmission performance for a standard POS interface.
Use undo snmp-agent trap enable { b1-tca | b2-tca | b3-tca } to disable SNMP notifications about signal transmission performance for a standard POS interface.
Signal transmission performance notifications are enabled for the standard POS interface.
To generate SNMP notifications when a B1, B2, or B3 alarm occurs on a standard POS interface, use this command.
B1, B2, and B3 bytes indicate the signal transmission performance of a line at different levels.
·     B1 alarm occurs if the bit error rate of a complete STM-N frame exceeds the B1 alarm threshold.
·     B2 alarm occurs if the bit error rate of an STM-1 frame exceeds the B2 alarm threshold.
·     B3 alarm occurs if the bit error rate of a multiplexed signal (VC3 or VC4 frame) in the STM-1 frame exceeds the B3 alarm threshold.
For B1, B2, or B3 alarm SNMP notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Disable B1 alarm notifications on POS 2/2/1.
[Sysname-Pos2/2/1] undo snmp-agent trap enable b1-tca
speed
Use speed to set the rate of a standard POS interface.
Use undo speed to restore the default.
speed speed-value
undo speed
The rate of a standard POS interface is 155 Mbps.
speed-value: Specifies the rate in Mbps. The value range for this argument varies by POS interface module model.
# Set the rate to 622 Mbps for POS 2/2/1.
[Sysname-Pos2/2/1] speed 622
timer-hold
Use timer-hold to set the keepalive interval.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds.
seconds: Specifies the interval at which the interface sends keepalive packets. The value range for this argument is 0 to 32767 seconds.
On an interface encapsulated with PPP, FR, or HDLC, the data link layer sends keepalive packets at keepalive intervals to detect the availability of the remote end. The data link layer determines that the peer end is down if it does not receive a response after the maximum number of keepalive attempts have been made. The data link layer then reports the link down event to the upper-layer protocols.
To set the maximum number of keepalive attempts, use the timer-hold retry command.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive interval to 15 seconds for POS 2/2/1.
[Sysname-Pos2/2/1] timer-hold 15
timer-hold retry
timer-hold retry
Use timer-hold retry to set the maximum number of keepalive attempts.
Use undo timer-hold retry to restore the default.
timer-hold retry retries
The maximum number of keepalive attempts is 5.
retries: Specifies the maximum number of keepalive attempts, in the range of 1 to 255.
This command applies to interfaces encapsulated with PPP, FR, or HDLC. To set the keepalive interval, use the timer-hold command.
On a slow link, increase the maximum number of keepalive attempts to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the maximum number of keepalive attempts to 10 for POS 2/2/1.
[Sysname-Pos2/2/1] timer-hold retry 10
timer-hold
