05-Network Connectivity Configuration Guide
HomeSupportWirelessWX3800X Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX3800X Series Access Controllers Configuration Guides(R1411P02)-6W10205-Network Connectivity Configuration Guide
20-IP forwarding basics configuration
20-IP forwarding basics configuration 50.38 KB
Configuring IP forwarding basic settings························································ 1
About FIB table······························································································································· 1
Enabling SNMP notifications for FIB events······················································································ 1
Display and maintenance commands for IP forwarding basics··························································· 2
Display and maintenance commands for FIB table····································································· 2
The term "router" in this document refers to a routing-capable device.
About FIB table
A device uses the FIB table to make packet forwarding decisions.
A device selects optimal routes from the routing table, and puts them into the FIB table. Each FIB entry specifies the next hop IP address and output interface for packets destined for a specific subnet or host.
For more information about the routing table, see Network Connectivity Configuration Guide.
Use the display fib command to display the FIB table. The following example displays the entire FIB table.
<Sysname> display fib
Route destination count: 4
Directly-connected host count: 0
Flag:
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
10.2.0.0/16        10.2.1.1        U        GE1/0/1                  Null
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
A FIB entry includes the following items:
·     Destination—Destination IP address.
·     Mask—Network mask. The mask and the destination address identify the destination network. A logical AND operation between the destination address and the network mask yields the address of the destination network. For example, if the destination address is 192.168.1.40 and the mask 255.255.255.0, the address of the destination network is 192.168.1.0. A network mask includes a certain number of consecutive 1s. It can be expressed in dotted decimal format or by the number of the 1s.
·     Nexthop—IP address of the next hop.
·     Flag—Route flag.
·     OutInterface—Output interface.
·     Token—MPLS Label Switched Path index number.
·     Label—Inner label.
This feature enables the FIB module to generate SNMP notifications for critical FIB events, such as the exceeding of the message queue length threshold. The SNMP notifications are sent to the SNMP module. For the SNMP notifications to be sent correctly, you must also configure SNMP. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
2.     Enable SNMP notifications for FIB events.
snmp-agent trap enable fib
By default, SNMP notifications for FIB events are enabled.
·     To display FIB entries, execute the following command in any view:
display fib  [ ip-address [ mask | mask-length ] ] [ slot slot-number  ]
·     To display HPF trace information, use the following command in user view:
display hpf trace filter
