05-Network Connectivity Configuration Guide
HomeSupportWirelessWX3800X Series Access ControllersConfigure & DeployConfiguration GuidesH3C WX3800X Series Access Controllers Configuration Guides(R1411P02)-6W10205-Network Connectivity Configuration Guide
05-VLAN configuration
05-VLAN configuration 135.63 KB
Configuring VLANs
About VLANs
The Virtual Local Area Network (VLAN) technology divides a physical LAN into multiple logical LANs. It has the following benefits:
·     Security—Hosts in the same VLAN can communicate with one another at Layer 2, but they are isolated from hosts in other VLANs at Layer 2.
·     Broadcast traffic isolation—Each VLAN is a broadcast domain that limits the transmission of broadcast packets.
·     Flexibility—A VLAN can be logically divided on a workgroup basis. Hosts in the same workgroup can be assigned to the same VLAN, regardless of their physical locations.
VLAN frame encapsulation
To identify Ethernet frames from different VLANs, IEEE 802.1Q inserts a four-byte VLAN tag between the destination and source MAC address (DA&SA) field and the Type field.
Figure 1 VLAN tag placement and format
A VLAN tag includes the following fields:
·     TPID—16-bit tag protocol identifier that indicates whether a frame is VLAN-tagged. By default, the hexadecimal TPID value 8100 identifies a VLAN-tagged frame. A device vendor can set the TPID to a different value. For compatibility with a neighbor device, set the TPID value on the device to be the same as the neighbor device.
·     Priority—3-bit long, identifies the 802.1p priority of the frame. For more information, see QoS Configuration Guide.
·     CFI—1-bit long canonical format indicator that indicates whether the MAC addresses are encapsulated in the standard format when packets are transmitted across different media. Available values include:
¡     0 (default)—The MAC addresses are encapsulated in the standard format.
¡     1—The MAC addresses are encapsulated in a non-standard format.
This field is always set to 0 for Ethernet.
·     VLAN ID—12-bit long, identifies the VLAN to which the frame belongs. The VLAN ID range is 0 to 4095. VLAN IDs 0 and 4095 are reserved, and VLAN IDs 1 to 4094 are user configurable.
The way a network device handles an incoming frame depends on whether the frame has a VLAN tag and the value of the VLAN tag (if any).
Ethernet supports encapsulation formats Ethernet II, 802.3/802.2 LLC, 802.3/802.2 SNAP, and 802.3 raw. The Ethernet II encapsulation format is used here. For information about the VLAN tag fields in other frame encapsulation formats, see related protocols and standards.
For a frame that has multiple VLAN tags, the device handles it according to its outermost VLAN tag and transmits its inner VLAN tags as the payload.
Port-based VLANs
Port-based VLANs group VLAN members by port. A port forwards packets from a VLAN only after it is assigned to the VLAN.
Port link type
You can set the link type of a port to access, trunk, or hybrid. The port link type determines whether the port can be assigned to multiple VLANs. The link types use the following VLAN tag handling methods:
·     Access—An access port can forward packets only from one VLAN and send these packets untagged. An access port is typically used in the following conditions:
¡     Connecting to a terminal device that does not support VLAN packets.
¡     In scenarios that do not distinguish VLANs.
·     Trunk—A trunk port can forward packets from multiple VLANs. Except packets from the port VLAN ID (PVID), packets sent out of a trunk port are VLAN-tagged. Ports connecting network devices are typically configured as trunk ports.
·     Hybrid—A hybrid port can forward packets from multiple VLANs. The tagging status of the packets forwarded by a hybrid port depends on the port configuration.
PVID
The PVID identifies the default VLAN of a port. Untagged packets received on a port are considered as the packets from the port PVID.
An access port can join only one VLAN. The VLAN to which the access port belongs is the PVID of the port. A trunk or hybrid port supports multiple VLANs and the PVID configuration.
How ports of different link types handle frames
Actions
Access
Trunk
Hybrid
In the inbound direction for an untagged frame
Tags the frame with the PVID tag.
·     If the PVID is permitted on the port, tags the frame with the PVID tag.
·     If not, drops the frame.
In the inbound direction for a tagged frame
·     Receives the frame if its VLAN ID is the same as the PVID.
·     Drops the frame if its VLAN ID is different from the PVID.
·     Receives the frame if its VLAN is permitted on the port.
·     Drops the frame if its VLAN is not permitted on the port.
In the outbound direction
Removes the VLAN tag and sends the frame.
·     Removes the tag and sends the frame if the frame carries the PVID tag and the port belongs to the PVID.
·     Sends the frame without removing the tag if its VLAN is carried on the port but is different from the PVID.
Sends the frame if its VLAN is permitted on the port. The tagging status of the frame depends on the port hybrid vlan command configuration.
Layer 3 communication between VLANs
Hosts of different VLANs use VLAN interfaces to communicate at Layer 3. VLAN interfaces are virtual interfaces that do not exist as physical entities on devices. For each VLAN, you can create one VLAN interface and assign an IP address to it. The VLAN interface acts as the gateway of the VLAN to forward packets at Layer 3. When the IP addresses of multiple VLAN interfaces are on different subnets, you must configure IP routing protocols to enable Layer 3 communication between these IP addresses. Then, the devices can forward packets at Layer 3 across subnets between different VLANs. For more information about IP routing protocols, see Network Connectivity Configuration Guide.
Protocols and standards
IEEE 802.1Q, IEEE Standard for Local and Metropolitan Area Networks: Virtual Bridged Local Area Networks
Configuration profile support for commands
You can execute some commands of this feature in configuration profile view. For more information, see the command reference for this feature. For more information about configuration profiles, see configuration file management in Fundamentals Configuration Guide.
Configuring a VLAN
·     As the system default VLAN, VLAN 1 cannot be created or deleted.
·     Before you delete a dynamic VLAN or a VLAN locked by an application, you must first remove the configuration from the VLAN.
Creating VLANs
2.     Create one or multiple VLANs.
¡     Create a VLAN and enter its view.
vlan vlan-id
¡     Create multiple VLANs and enter VLAN view.
Create VLANs.
vlan { vlan-id-list | all }
vlan vlan-id
By default, only the system default VLAN (VLAN 1) exists.
3.     (Optional.) Set a name for the VLAN.
name text
By default, the name of a VLAN is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has fewer than four digits, leading zeros are added. For example, the name of VLAN 100 is VLAN 0100.
4.     (Optional.) Configure the description for the VLAN.
By default, the description of a VLAN is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has fewer than four digits, leading zeros are added. For example, the default description of VLAN 100 is VLAN 0100.
Configuring port-based VLANs
Restrictions and guidelines for port-based VLANs
·     When you use the undo vlan command to delete the PVID of a port, either of the following events occurs depending on the port link type:
¡     For an access port, the PVID of the port changes to VLAN 1.
¡     For a hybrid or trunk port, the PVID setting of the port does not change.
You can use a nonexistent VLAN as the PVID for a hybrid or trunk port, but not for an access port.
·     As a best practice, set the same PVID for a local port and its peer.
·     To prevent a port from dropping untagged packets or PVID-tagged packets, assign the port to its PVID.
Assigning an access port to a VLAN
You can assign an access port to a VLAN in VLAN view or interface view.
Assigning one or multiple access ports to a VLAN in VLAN view
2.     Enter VLAN view.
vlan vlan-id
3.     Assign one or multiple access ports to the VLAN.
port interface-list
By default, all ports belong to VLAN 1.
Assigning an access port to a VLAN in interface view
2.     Enter interface view.
¡     Enter Layer 2 Ethernet interface view.
¡     Enter Layer 2 aggregate interface view.
3.     Set the port link type to access.
port link-type access
By default, all ports are access ports.
4.     Assign the access port to a VLAN.
port access vlan vlan-id
By default, all access ports belong to VLAN 1.
Assigning a trunk port to a VLAN
A trunk port supports multiple VLANs. You can assign it to a VLAN in interface view.
To change the link type of a port from trunk to hybrid, set the link type to access first.
To enable a trunk port to transmit packets from its PVID, you must assign the trunk port to the PVID by using the port trunk permit vlan command.
3.     Set the port link type to trunk.
port link-type trunk
4.     Assign the trunk port to the specified VLANs.
By default, a trunk port permits only VLAN 1.
5.     (Optional.) Set the PVID for the trunk port.
port trunk pvid vlan vlan-id
The default setting is VLAN 1.
Assigning a hybrid port to a VLAN
A hybrid port supports multiple VLANs. You can assign it to the specified VLANs in interface view. Make sure the VLANs have been created.
To enable a hybrid port to transmit packets from its PVID, you must assign the hybrid port to the PVID by using the port hybrid vlan command.
3.     Set the port link type to hybrid.
port link-type hybrid
4.     Assign the hybrid port to the specified VLANs.
By default, the hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
5.     (Optional.) Set the PVID for the hybrid port.
port hybrid pvid vlan vlan-id
By default, the PVID of a hybrid port is the ID of the VLAN to which the port belongs when its link type is access.
Configuring a VLAN group
A VLAN group includes a set of VLANs.
2.     Create a VLAN group and enter its view.
vlan-group group-name
3.     Add VLANs to the VLAN group.
vlan-list vlan-id-list
By default, no VLANs exist in a VLAN group.
You can add multiple VLAN lists to a VLAN group.
Configuring VLAN interfaces
For information about the bandwidth, description, and shutdown commands, see Interface Command Reference.
When a VLAN interface is not manually shut down, the following guidelines apply to the interface state:
·     The VLAN interface is down if all ports in the VLAN are down.
·     The VLAN interface is up if one or more ports in the VLAN are up.
When you use this command to shut down a VLAN interface, the VLAN interface remains in DOWN (Administratively) state. In this case, the VLAN interface state is not affected by the state of the ports in the VLAN.
Before you configure parameters for a VLAN interface, use this command to shut it down to prevent the configuration from affecting the network. After you complete the VLAN interface configuration, use the undo shutdown command to make the settings take effect.
To troubleshoot a failed VLAN interface, you can use the shutdown command and then the undo shutdown command on the interface to see whether it recovers.
In a VLAN, the state of each Ethernet interface is independent of the state of the VLAN interface.
VLAN interfaces configuration tasks at a glance
To configure VLAN interfaces, perform the following tasks:
1.     Creating a VLAN interface
2.     (Optional.) Restoring the default settings for the VLAN interface
Before you create a VLAN interface for a VLAN, create the VLAN first.
2.     Create a VLAN interface and enter its view.
3.     Assign an IP address to the VLAN interface.
By default, no IP address is assigned to a VLAN interface.
4.     (Optional.) Configure the description for the VLAN interface.
The default setting is the VLAN interface name. For example, Vlan-interface1 Interface.
5.     (Optional.) Set the MTU for the VLAN interface.
mtu size
By default, the MTU for a VLAN interface is 1500 bytes.
6.     (Optional.) Set the expected bandwidth for the interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is the interface baud rate divided by 1000.
7.     Bring up the VLAN interface.
By default, a VLAN interface is down.
This feature might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
For information about the default command, see Interface Command Reference.
2.     Enter a VLAN interface view.
3.     Restore the default settings for the VLAN interface.
CAUTION
CAUTION:
This feature might interrupt ongoing network services. Make sure you are fully aware of the impact of this feature when you use it on a live network.
Verifying and maintaining VLANs
Verifying VLAN configuration
Perform all display tasks in any view.
·     Display brief VLAN information.
display vlan brief
·     Display VLAN information.
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | reserved | static ]
·     Display hybrid ports or trunk ports on the device.
Verifying VLAN group configuration and running status
Display VLAN group information in any view.
display vlan-group [ group-name ]
Verifying VLAN interface configuration and running status
·     Display VLAN interface information.
display interface [ vlan-interface [ interface-number ] ] [ brief [ description | down ] ]
Clearing VLAN interface statistics
Clear statistics on a VLAN interface in user view.
reset counters interface [ vlan-interface [ interface-number ] ]
For information about the reset counters interface command, see Interface Command Reference.
