03-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath F1000[F5000] Firewalls Series Configuration Guides(V7)-6W90203-Security Configuration Guide
11-MAC authentication configuration
11-MAC authentication configuration 292.30 KB
Configuring MAC authentication
About MAC authentication
MAC authentication controls network access by authenticating source MAC addresses on a port. The feature does not require client software, and users do not have to enter a username and password for network access. The device initiates a MAC authentication process when it detects an unknown source MAC address on a MAC authentication-enabled port. If the MAC address passes authentication, the user can access authorized network resources. If the authentication fails, the device marks the MAC address as a silent MAC address, drops the packet, and starts a quiet timer. The device drops all subsequent packets from the MAC address within the quiet time. The quiet mechanism avoids repeated authentication during a short time.
User account policies
MAC authentication supports the following user account policies:
·     One MAC-based user account for each user. As shown in Figure 1, the access device uses the source MAC addresses in packets as the usernames and passwords of users for MAC authentication. This policy is suitable for an insecure environment.
·     One shared user account for all users. You specify one username and password, which are not necessarily a MAC address, for all MAC authentication users on the access device. This policy is suitable for a secure environment. See Figure 2.
Figure 1 MAC-based user account policy
Figure 2 Shared user account policy
Authentication methods
You can perform MAC authentication on the access device (local authentication) or through a RADIUS server.
The device uses Password Authentication Protocol (PAP) or Challenge Handshake Authentication Protocol (CHAP) to perform MAC authentication with the authentication server.
For more information about configuring local authentication and RADIUS authentication, see "Configuring AAA."
If MAC-based accounts are used, the access device sends the source MAC address of the packet as the username and password to the RADIUS server for authentication.
If a shared account is used, the access device sends the shared account username and password to the RADIUS server for authentication.
Local authentication
If MAC-based accounts are used, the access device uses the source MAC address of the packet as the username and password to search the local account database for a match.
If a shared account is used, the access device uses the shared account username and password to search the local account database for a match.
VLAN assignment
Authorization VLAN
The authorization VLAN controls the access of a MAC authentication user to authorized network resources. The device supports authorization VLANs assigned locally or by a remote server.
IMPORTANT
IMPORTANT:
Only remote servers can assign tagged authorization VLANs.
Remote VLAN authorization
In remote VLAN authorization, you must configure an authorization VLAN for a user on the remote server. After the user authenticates to the server, the server assigns authorization VLAN information to the device. Then, the device assigns the user access port to the authorization VLAN as a tagged or untagged member.
The device supports assignment of the following authorization VLAN information by the remote server:
·     VLAN ID.
·     VLAN name, which must be the same as the VLAN description on the access device.
·     A string of VLAN IDs and VLAN names.
In the string, some VLANs are represented by their IDs, and some VLANs are represented by their names.
·     VLAN group name.
In a VLAN group, the authorization VLANs except the dynamically learned VLANs can be assigned.
For more information about VLAN groups, see VLAN configuration in Layer 2—LAN Switching Configuration Guide.
·     VLAN ID with a suffix of t or u.
The t and u suffixes require the device to assign the access port to the VLAN as a tagged or untagged member, respectively. For example, 2u indicates assigning the port to VLAN 2 as an untagged member.
If a VLAN name or VLAN group name is assigned, the device converts the information into a VLAN ID before VLAN assignment.
IMPORTANT
IMPORTANT:
For a VLAN represented by its VLAN name to be assigned successfully, you must make sure the VLAN has been created on the device.
To assign VLAN IDs with suffixes, make sure the user access port is a hybrid or trunk port.
To ensure a successful assignment, the authorization VLANs assigned by the remote server cannot be any of the following types:
·     Dynamically learned VLANs.
·     Reserved VLANs.
If the server assigns a group of VLANs, the access device selects a VLAN as described in Table 1.
Table 1 Authorization VLAN selection from a group of VLANs
VLAN information
VLANs by IDs
VLANs by names
VLAN group name
On a hybrid port with MAC-based VLAN enabled, the device selects an authorization VLAN from the VLAN group for a user according to the following rules:
·     If the port does not have online users, the device selects the VLAN with the lowest ID.
·     If the port has online users, the device selects the VLAN that has the fewest number of online users. If two VLANs have the same number of online MAC authentication users, the device selects the VLAN with the lower ID.
On an access, trunk or MAC-based VLAN disabled hybrid port, the device selects an authorization VLAN from the VLAN group for a user according to the following rules:
·     If the port has online users, the device examines whether the VLAN that has online users is in the VLAN group. If the VLAN is found in the group, the VLAN is assigned to the user as the authorization VLAN. If the VLAN is not found in the group, the VLAN authorization fails.
1.     The device selects the leftmost VLAN ID without a suffix, or the leftmost VLAN ID suffixed by u as an untagged VLAN, whichever is more leftmost.
2.     The device assigns the untagged VLAN to the port as the PVID, and it assigns the remaining as tagged VLANs. If no untagged VLAN is assigned, the PVID of the port does not change. The port permits traffic from these tagged and untagged VLANs to pass through.
For example, the authentication server sends the string 1u 2t 3 to the access device for a user. The device assigns VLAN 1 as an untagged VLAN and all remaining VLANs (including VLAN 3) as tagged VLANs. VLAN 1 becomes the PVID.
Local VLAN authorization
To perform local VLAN authorization for a user, specify the VLAN ID in the authorization attribute list of the local user account for that user. For each local user, you can specify only one authorization VLAN ID. The user access port is assigned to the VLAN as an untagged member.
IMPORTANT
IMPORTANT:
Local VLAN authorization does not support assignment of tagged VLANs.
For more information about local user configuration, see "Configuring AAA."
Authorization VLAN manipulation on a MAC authentication-enabled port
The network access device handles authorization VLANs depending on the port type and whether the authorization VLANs assigned by the server have a tagging attribute.
Only remote AAA servers can assign VLANs with the tagged attribute.
If the authorization VLAN is assigned with the untagged attribute or without any taqgging attribute, the device handles the authorization VLAN as described in Table 2.
Table 2 Manipulation of authorization VLANs assigned with the untagged attribute or without a tagging attribute
Port type
VLAN manipulation
Access
Moves the port from the current VLAN to the authorization VLAN assigned to the first authenticated user on the port.
Trunk
Permits the authorization VLAN to pass through the port.
Set the authorization VLAN as the PVID if it is assigned to the first authenticated user on the port.
Hybrid
Permits the authorization VLAN to pass through the port as an untagged VLAN.
Sets the authorization VLAN as the PVID if it is assigned to the first authenticated user on the port.
If MAC-based VLAN is enabled, the device dynamically maps the MAC addresses of users to their authorization VLANs without changing the PVID of the port.
If the authorization VLAN is assigned with the tagged attribute, the device handles the authorization VLAN as described in Table 3.
Table 3 Manipulation of authorization VLANs assigned with the tagged attribute
Port type
VLAN manipulation
Access
VLAN assignment fails.
IMPORTANT IMPORTANT:
Access ports do not support server-assigned authorization VLANs.
Trunk
Permits the authorization VLAN to pass through the port as a tagged VLAN, without changing the PVID.
Hybrid
Permits the authorization VLAN to pass through the port as a tagged VLAN without changing the PVID.
IMPORTANT
IMPORTANT:
·     If the users are attached to a port whose link type is access, make sure the authorization VLAN assigned by the server has the untagged attribute. VLAN assignment will fail if the server issues a VLAN that has the tagged attribute.
·     When you assign VLANs to users attached to a trunk port or a MAC-based VLAN disabled hybrid port, make sure there is only one untagged VLAN. If a different untagged VLAN is assigned to a subsequent user, the user cannot pass authentication.
·     For users attached to the same port, the server-assigned authorization VLANs must be different. The device maps the MAC addresses of the users to their authorization VLANs, regardless of whether MAC-based VLAN is enabled on their attached port.
For a MAC authenticated user to access the network on a hybrid port when no authorization VLAN is configured for the user, perform one of the following tasks:
·     If the port receives tagged authentication packets from the user in a VLAN, use the port hybrid vlan command to configure the port as a tagged member in the VLAN.
·     If the port receives untagged authentication packets from the user in a VLAN, use the port hybrid vlan command to configure the port as an untagged member in the VLAN.
Guest VLAN
The MAC authentication guest VLAN on a port accommodates users that have failed MAC authentication for any reason other than server unreachable. For example, the VLAN accommodates users for which invalid passwords are entered.
You can deploy a limited set of network resources in the MAC authentication guest VLAN. For example, a software server for downloading software and system patches.
A hybrid port is always assigned to a MAC authentication guest VLAN as an untagged member. After the assignment, do not reconfigure the port as a tagged member in the VLAN.
The device reauthenticates users in the MAC authentication guest VLAN at a specific interval. Table 4 shows the way that the network access device handles guest VLANs for MAC authentication users.
Table 4 VLAN manipulation
Authentication status
VLAN manipulation
A user in the MAC authentication guest VLAN fails MAC authentication.
The user is still in the MAC authentication guest VLAN.
A user in the MAC authentication guest VLAN passes MAC authentication.
The device remaps the MAC address of the user to the authorization VLAN assigned by the authentication server.
If no authorization VLAN is configured for the user on the authentication server, the device remaps the MAC address of the user to the PVID of the port.
Critical VLAN
The MAC authentication critical VLAN on a port accommodates users that have failed MAC authentication because no RADIUS authentication servers are reachable. Users in a MAC authentication critical VLAN can access only network resources in the critical VLAN.
The critical VLAN feature takes effect when MAC authentication is performed only through RADIUS servers. If a MAC authentication user fails local authentication after RADIUS authentication, the user is not assigned to the critical VLAN. For more information about the authentication methods, see "Configuring AAA."
Table 5 shows the way that the network access device handles critical VLANs for MAC authentication users.
Table 5 VLAN manipulation
VLAN manipulation
A user fails MAC authentication because all the RADIUS servers are unreachable.
The device maps the MAC address of the user to the MAC authentication critical VLAN.
The user is still in the MAC authentication critical VLAN if the user fails MAC reauthentication because all the RADIUS servers are unreachable.
If no MAC authentication critical VLAN is configured, the device maps the MAC address of the user to the PVID of the port.
A user in the MAC authentication critical VLAN fails MAC authentication for any reason other than server unreachable.
If a guest VLAN has been configured, the device maps the MAC address of the user to the guest VLAN.
If no guest VLAN is configured, the device maps the MAC address of the user to the PVID of the port.
A user in the MAC authentication critical VLAN passes MAC authentication.
If no authorization VLAN is configured for the user on the authentication server, the device remaps the MAC address of the user to the PVID of the access port.
Restrictions and guidelines: MAC authentication configuration
Do not change the link type of a port when the MAC authentication guest VLAN or critical VLAN on the port has users.
If the MAC address that has failed authentication is a static MAC address or a MAC address that has passed any security authentication, the device does not mark the MAC address as a silent address.
MAC authentication tasks at a glance
To configure MAC authentication, perform the following tasks:
1.     Enabling MAC authentication
2.     Configure basic MAC authentication features
¡     Specifying a MAC authentication method
¡     Specifying a MAC authentication domain
¡     Configuring the user account format
¡     (Optional.) Configuring MAC authentication timers
3.     (Optional.) Configuring MAC authentication VLAN assignment
¡     Configuring a MAC authentication guest VLAN
¡     Configuring a MAC authentication critical VLAN
4.     (Optional.) Configuring other MAC authentication features
¡     Setting the maximum number of concurrent MAC authentication users on a port
¡     Enabling MAC authentication multi-VLAN mode on a port
Perform this task to not reauthenticate online users when VLAN changes occur on a port.
¡     Including user IP addresses in MAC authentication requests
¡     Configuring the keep-online feature
¡     Logging off MAC authentication users
¡     Enabling MAC authentication user logging
Prerequisites for MAC authentication
Before you configure MAC authentication, complete the following tasks:
1.     Configure an ISP domain and specify an AAA method. For more information, see "Configuring AAA."
¡     For local authentication, you must also create local user accounts (including usernames and passwords) and specify the lan-access service for local users.
¡     For RADIUS authentication, make sure the device and the RADIUS server can reach each other and create user accounts on the RADIUS server. If you are using MAC-based accounts, make sure the username and password for each account are the same as the MAC address of each MAC authentication user.
For MAC authentication to take effect on a port, you must enable this feature globally and on the port.
You cannot enable MAC authentication on a port that is in a link aggregation group.
2.     Enable MAC authentication globally.
mac-authentication
By default, MAC authentication is disabled globally.
3.     Enter Layer 2 Ethernet interface view.
4.     Enable MAC authentication on the port.
mac-authentication
By default, MAC authentication is disabled on a port.
The device can use either of the following methods to perform MAC authentication with an authentication server:
·     PAP—Transports usernames and passwords in plain text. The authentication method applies to scenarios that do not require high security.
·     CHAP—Transports usernames in plain text and passwords in encrypted form over the network. CHAP is more secure than PAP.
The device must use the same authentication method as the RADIUS server.
2.     Specify an authentication method for MAC authentication.
mac-authentication authentication-method { chap | pap }
By default, the device uses PAP for MAC authentication.
By default, MAC authentication users are in the system default authentication domain. To implement different access policies for users, you can use one of the following methods to specify authentication domains for MAC authentication users:
·     Specify a global authentication domain in system view. This domain setting applies to all ports enabled with MAC authentication.
·     Specify an authentication domain for an individual port in Layer 2 Ethernet interface view.
MAC authentication chooses an authentication domain for users on a port in this order: the port-specific domain, the global domain, and the default domain. For more information about authentication domains, see "Configuring AAA."
2.     Specify an authentication domain for MAC authentication users.
¡     In system view:
¡     In Layer 2 Ethernet interface view:
By default, the system default authentication domain is used for MAC authentication users.
2.     Configure the MAC authentication user account format.
¡     Use one MAC-based user account for each user.
mac-authentication user-name-format mac-address [ { with-hyphen [ six-section | three-section ] | without-hyphen } [ lowercase | uppercase ] ]
¡     Use one shared user account for all users.
mac-authentication user-name-format fixed [ account name ] [ password { cipher | simple } string ]
By default, the device uses the MAC address of a user as the username and password for MAC authentication. The MAC address is in hexadecimal notation without hyphens, and letters are in lower case.
MAC authentication uses the following timers:
·     Offline detect timer—Sets the interval that the device waits for traffic from a user before the device determines that the user is idle. If the device has not received traffic from a user before the timer expires, the device logs off that user and requests the accounting server to stop accounting for the user.
·     Quiet timer—Sets the interval that the device must wait before the device can perform MAC authentication for a user that has failed MAC authentication. All packets from the MAC address are dropped during the quiet time. This quiet mechanism prevents repeated authentication from affecting system performance.
·     Server timeout timer—Sets the interval that the device waits for a response from a RADIUS server before the device determines that the RADIUS server is unavailable. If the timer expires during MAC authentication, the user cannot access the network.
2.     Configure MAC authentication timers.
mac-authentication timer { offline-detect offline-detect-value | quiet quiet-value | server-timeout server-timeout-value }
By default, the offline detect timer is 300 seconds, the quiet timer is 60 seconds, and the server timeout timer is 100 seconds.
When you configure the MAC authentication guest VLAN on a port, follow the guidelines in Table 6.
Table 6 Relationships of the MAC authentication guest VLAN with other security features
Feature
Relationship description
Reference
Quiet feature of MAC authentication
The MAC authentication guest VLAN feature has higher priority.
When a user fails MAC authentication, the user can access the resources in the guest VLAN. The user's MAC address is not marked as a silent MAC address.
See "Configuring MAC authentication timers."
Before you configure the MAC authentication guest VLAN on a port, complete the following tasks:
·     Create the VLAN to be specified as the MAC authentication guest VLAN.
·     Configure the port as a hybrid port, and configure the VLAN as an untagged member on the port.
·     Enable MAC-based VLAN on the port.
For information about VLAN configuration, see Layer 2—LAN Switching Configuration Guide.
2.     Enter Layer 2 Ethernet interface view.
3.     Specify the MAC authentication guest VLAN on the port.
By default, no MAC authentication guest VLAN is specified on a port.
You can configure only one MAC authentication guest VLAN on a port. The MAC authentication guest VLANs on different ports can be different.
4.     Set the authentication interval for users in the MAC authentication guest VLAN.
The default setting is 30 seconds.
When you configure the MAC authentication critical VLAN on a port, follow the guidelines in Table 7.
Table 7 Relationships of the MAC authentication critical VLAN with other security features
Feature
Reference
The MAC authentication critical VLAN feature has higher priority.
When a user fails MAC authentication because no RADIUS authentication server is reachable, the user can access the resources in the critical VLAN. The user's MAC address is not marked as a silent MAC address.
Before you configure the MAC authentication critical VLAN on a port, complete the following tasks:
·     Create the VLAN to be specified as the MAC authentication critical VLAN.
3.     Specify the MAC authentication critical VLAN on the port.
By default, no MAC authentication critical VLAN is specified on a port.
You can configure only one MAC authentication critical VLAN on a port. The MAC authentication critical VLANs on different ports can be different.
Perform this task to prevent the system resources from being overused.
3.     Set the maximum number of concurrent MAC authentication users on the port.
The default setting is 4294967295.
The MAC authentication multi-VLAN mode prevents an authenticated online user from service interruption caused by VLAN changes on a port. When the port receives a packet sourced from the user in a VLAN not matching the existing MAC-VLAN mapping, the device neither logs off the user nor reauthenticates the user. The device creates a new MAC-VLAN mapping for the user, and traffic transmission is not interrupted. The original MAC-VLAN mapping for the user remains on the device until it dynamically ages out. As a best practice, configure this feature on hybrid or trunk ports.
3.     Enable MAC authentication multi-VLAN mode.
mac-authentication host-mode multi-vlan
By default, this feature is disabled on a port. When the port receives a packet sourced from an authenticated user in a VLAN not matching the existing MAC-VLAN mapping, the device logs off and reauthenticates the user.
IMPORTANT
IMPORTANT:
This feature can only operate in conjunction with an IMC server.
To avoid IP conflicts that result from changes to static IP addresses, use this feature on a port that has MAC authentication users with static IP addresses.
This feature adds user IP addresses to the MAC authentication requests sent to the authentication server. When MAC authentication is triggered for a user, the device checks the user's IP address for invalidity.
·     If the IP address is valid, the device sends a MAC authentication request with the IP address included.
·     If the IP address is not a valid host IP address or the triggering packet does not contain an IP address, the device does not initiate MAC authentication.
·     If the packet is a DHCP packet with a source IP address of all zeros, the device sends a MAC authentication request without including the IP address. In this case, the IMC server does not examine the user IP address when it performs authentication.
Upon receipt of the authentication request that includes a user's IP address, the IMC server compares the user's IP and MAC addresses with its local IP-MAC mappings.
·     If an exact match is found or if no match is found, the user passes MAC authentication. In the latter case, the server creates an IP-MAC mapping for the user.
·     If a mapping is found for the MAC address but the IP addresses do not match, the user fails the MAC authentication.
Do not use this feature in conjunction with the MAC authentication guest VLAN on a port. The device cannot perform MAC authentication for a user once that user is added to the MAC authentication guest VLAN.
2.     Enter interface view.
3.     Include user IP addresses in MAC authentication requests.
mac-authentication carry user-ip
By default, a MAC authentication request does not include the user IP address.
Periodic MAC reauthentication tracks the connection status of online users, and updates the authorization attributes assigned by the RADIUS server. The attributes include VLAN.
The device reauthenticates an online MAC authentication user periodically only after it receives the termination action Radius-request from the authentication server for this user. The Session-Timeout attribute (session timeout period) assigned by the server is the reauthentication interval. To display the server-assigned Session-Timeout and Termination-Action attributes, use the display mac-authentication connection command. Support for the server configuration and assignment of Session-Timeout and Termination-Action attributes depends on the server model.
The keep-online feature enables the device to keep the MAC authentication users online when no server is reachable for MAC reauthentication.
In a fast-recovery network, you can use the keep-online feature to prevent MAC authentication users from coming online and going offline frequently.
Any modification to the MAC authentication domain or user account format setting does not affect the reauthentication of online MAC authentication users. The modified setting takes effect only on MAC authentication users that come online after the modification.
3.     Enable the keep-online feature for authenticated MAC authentication users on the port.
mac-authentication re-authenticate server-unreachable keep-online
By default, the keep-online feature is disabled. The device logs off online MAC authentication users if no server is reachable for MAC reauthentication.
Perform this task to log off specified MAC authentication users and clear information about these users from the device. These users must perform MAC authentication to come online again.
With an interface specified, the reset mac-authentication access-user command logs off all MAC authentication users on the specified interface.
With a MAC address specified, the reset mac-authentication access-user command logs off the MAC authentication user with the specified MAC address.
With a VLAN specified, the reset mac-authentication access-user command logs off all MAC authentication users in the specified VLAN, including:
·     Users that are performing MAC authentication in the specified VLAN.
·     Users that have passed MAC authentication and have been assigned the specified VLAN as their authorization VLAN by the server.
·     Users that stay in the specified VLAN after they have passed MAC authentication, because they have not been assigned an authorization VLAN yet.
To identify the VLAN in which a user is staying, use the display mac-address command.
With a VSI specified, the reset mac-authentication access-user command logs off all MAC authentication users in the specified VSI.
To log off MAC authentication users, execute the following command in user view:
reset mac-authentication access-user [ interface interface-type interface-number | mac mac-address | username username | vlan vlan-id | vsi vsi-name ]
This feature enables the device to generate logs about MAC authentication users and send the logs to the information center. For the logs to be output correctly, you must also configure the information center on the device. For more information about information center configuration, see Network Management and Monitoring Configuration Guide.
To prevent excessive MAC authentication user log entries, use this feature only if you need to analyze abnormal MAC authentication user logins or logouts.
2.     Enable MAC authentication user logging.
By default, MAC authentication user logging is disabled.
If you do not specify any parameters, this command enables all types of MAC authentication user logs.
Display and maintenance commands for MAC authentication
Display MAC authentication information.
Display MAC authentication connections.
display mac-authentication connection [ interface interface-type interface-number | slot slot-number | user-mac mac-address | user-name user-name ]
Clear MAC authentication statistics.
Remove users from the MAC authentication critical VLAN on a port.
reset mac-authentication critical-vlan interface interface-type interface-number [ mac-address mac-address ]
Remove users from the MAC authentication critical voice VLAN on a port.
reset mac-authentication critical-voice-vlan interface interface-type interface-number [ mac-address mac-address ]
Remove users from the MAC authentication guest VLAN on a port.
MAC authentication configuration examples
Example: Configuring local MAC authentication
As shown in Figure 3, the device performs local MAC authentication on GigabitEthernet 1/0/1 to control Internet access of users.
Configure the device to meet the following requirements:
·     Detect whether a user has gone offline every 180 seconds.
·     Deny a user for 180 seconds if the user fails MAC authentication.
·     Authenticate all users in ISP domain bbb.
·     Use the MAC address of each user as the username and password for authentication. The MAC addresses are in hexadecimal notation with hyphens, and letters are in lower case.
Figure 3 Network diagram
# Add a network access local user. In this example, configure both the username and password as Host A's MAC address 08-00-27-12-34-56.
[Device] local-user 08-00-27-12-34-56 class network
[Device-luser-network-08-00-27-12-34-56] password simple 08-00-27-12-34-56
# Specify the LAN access service for the user.
[Device-luser-network-08-00-27-12-34-56] service-type lan-access
[Device-luser-network-08-00-27-12-34-56] quit
# Configure ISP domain bbb to perform local authentication for LAN users.
[Device] domain bbb
[Device-isp-bbb] authentication lan-access local
[Device-isp-bbb] quit
# Enable MAC authentication on GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] mac-authentication
# Specify ISP domain bbb as the MAC authentication domain.
[Device] mac-authentication domain bbb
# Configure MAC authentication timers.
[Device] mac-authentication timer offline-detect 180
[Device] mac-authentication timer quiet 180
# Configure MAC authentication to use MAC-based accounts. Each MAC address is in hexadecimal notation with hyphens, and letters are in lower case.
[Device] mac-authentication user-name-format mac-address with-hyphen lowercase
# Enable MAC authentication globally.
# Display MAC authentication settings and statistics to verify your configuration.
<Device> display mac-authentication
   MAC authentication     : Enabled
   Authentication method  : PAP
   User name format       : MAC address in lowercase(xx-xx-xx-xx-xx-xx)
           Username       : mac
           Password       : Not configured
   Offline detect period  : 180 s
   Quiet period           : 180 s
   Server timeout         : 100 s
   Authentication domain  : bbb
 Online MAC-auth wired users    : 1
 Silent MAC users:
          MAC address       VLAN ID  From port               Port index
          0800-2711-1111    8        Gigabitethernet1/0/1    1
 Gigabitethernet1/0/1 is link-up
   Carry User-IP              : Disabled
   Authentication domain      : Not configured
   Auth-delay timer           : Disabled
   Guest VLAN                 : Not configured
   Guest VLAN auth-period     : 30 s
   Critical VLAN              : Not configured
   Critical voice VLAN        : Disabled
   Host mode                  : Single VLAN
   Max online users           : 4294967295
   Authentication attempts    : successful 1, failed 0
   Current online users       : 1
          MAC address       Auth state
          0800-2712-3456    Authenticated
The output shows that Host A has passed MAC authentication and has come online. Host B failed MAC authentication and its MAC address is marked as a silent MAC address.
Example: Configuring RADIUS-based MAC authentication
As shown in Figure 4, the device uses RADIUS servers to perform authentication, authorization, and accounting for users.
To control user access to the Internet by MAC authentication, perform the following tasks:
·     Enable MAC authentication globally and on GigabitEthernet 1/0/1.
·     Configure the device to detect whether a user has gone offline every 180 seconds.
·     Configure the device to deny a user for 180 seconds if the user fails MAC authentication.
·     Configure all users to belong to ISP domain bbb.
·     Use a shared user account for all users, with username aaa and password 123456TESTplat&!TESTplat&!.
Figure 4 Network diagram
Make sure the RADIUS server and the access device can reach each other.
1.     Configure the RADIUS servers to provide authentication, authorization, and accounting services. Create a shared account with username aaa and password 123456TESTplat&!TESTplat&! for MAC authentication users. (Details not shown.)
2.     Configure RADIUS-based MAC authentication on the device:
# Configure a RADIUS scheme.
[Device] radius scheme 2000
[Device-radius-2000] primary authentication 10.1.1.1 1812
[Device-radius-2000] primary accounting 10.1.1.2 1813
[Device-radius-2000] key authentication simple abc
[Device-radius-2000] key accounting simple abc
[Device-radius-2000] user-name-format without-domain
[Device-radius-2000] quit
# Apply the RADIUS scheme to ISP domain bbb for authentication, authorization, and accounting.
[Device] domain bbb
[Device-isp-bbb] authentication default radius-scheme 2000
[Device-isp-bbb] authorization default radius-scheme 2000
[Device-isp-bbb] accounting default radius-scheme 2000
# Specify the MAC authentication domain as ISP domain bbb.
# Set MAC authentication timers.
# Specify username aaa and password 123456TESTplat&!TESTplat&! in plain text for the account shared by MAC authentication users.
[Device] mac-authentication user-name-format fixed account aaa password simple 123456TESTplat&!TESTplat&!
# Verify the MAC authentication configuration.
   Username format        : Fixed account
           Username       : aaa
           Password       : ******
 Silent MAC users:
 GigabitEthernet1/0/1  is link-up
