- 21-Network Management and Monitoring Command Reference
- 01-Ping and tracert commands
- 02-System debugging commands
- 03-NQA commands
- 04-iNQA commands
- 05-iFIT commands
- 06-NTP commands
- 07-SNMP commands
- 08-RMON commands
- 09-Event MIB commands
- 10-CWMP commands
- 11-Sampler commands
- 12-Mirroring commands
- 13-NetStream commands
- 14-IPv6 NetStream commands
- 15-sFlow commands
- 16-Cloud connection commands
- 17-Packet capture commands
- 18-IP traffic statistics collection commands
12-Mirroring commands | 120.03 KB |
mirroring-group mirroring-port (interface view)
mirroring-group mirroring-port (system view)
mirroring-group monitor-port (interface view)
mirroring-group monitor-port (system view)
Port mirroring commands
display mirroring-group
Use display mirroring-group to display mirroring group information.
display mirroring-group { group-id | all | local }
group-id: Specifies a mirroring group by its ID.
The following compatibility matrixes show the value ranges for the mirroring group ID:
Hardware |
Value range |
MSR1008 |
1 to 6 |
MSR1004-G |
1 |
MSR1004-G-5GCN |
1 |
MSR2630E-X1 |
1 to 6 |
MSR3610E-X1, MSR3610E-X1-DP |
1 to 6 |
MSR3610-G-X3-DP, MSR3610-G-X3, MSR3610-G-X3-DP-DC, MSR3610-G-X3-DC |
1 to 6 |
Hardware |
Value range |
MSR2660-XS |
1 to 6 |
MSR2680-XS |
1 to 6 |
Hardware |
Value range |
MSR2600-12X-WiNet |
1 to 6 |
MSR2610-13X-WiNet |
1 to 6 |
all: Specifies all mirroring groups.
local: Specifies local mirroring groups.
Mirroring group information includes the type, status, and content of a mirroring group. It is sorted by mirroring group number.
# Display information about all mirroring groups.
<Sysname> display mirroring-group all
Mirroring group 1:
Type: Local
Status: Active
Mirroring port: GigabitEthernet0/0/1 Inbound
Monitor port: GigabitEthernet0/0/2
Mirroring group 2:
Type: Local
Status: Active
Mirroring group |
Number of the mirroring group. |
Type |
Type of the mirroring group: Local. |
Status |
Status of the mirroring group: · Active—The mirroring group has taken effect. · Incomplete—The mirroring group configuration is not complete and does not take effect. |
Mirroring port |
Source port. |
Monitor port |
Destination port. |
mirroring-group
Use mirroring-group to create a mirroring group.
Use undo mirroring-group to delete mirroring groups.
mirroring-group group-id local
undo mirroring-group { group-id | all | local }
No mirroring groups exist.
group-id: Specifies a mirroring group ID.
Hardware |
Value range |
MSR1008 |
1 to 6 |
MSR1004-G |
1 |
MSR1004-G-5GCN |
1 |
MSR2630E-X1 |
1 to 6 |
1 to 6 |
1 to 6 |
Hardware |
Value range |
MSR2660-XS |
1 to 6 |
MSR2680-XS |
1 to 6 |
Hardware |
Value range |
MSR2600-12X-WiNet |
1 to 6 |
MSR2610-13X-WiNet |
1 to 6 |
# Create local mirroring group 1.
[Sysname] mirroring-group 1 local
Use mirroring-group mirroring-port to configure a port as a source port for a mirroring group.
Use undo mirroring-group mirroring-port to restore the default.
mirroring-group group-id mirroring-port { both | inbound | outbound }
undo mirroring-group group-id mirroring-port
A port does not act as a source port for any mirroring groups.
Interface view
Hardware |
Value range |
MSR1008 |
1 to 6 |
MSR1004-G |
1 |
MSR1004-G-5GCN |
1 |
MSR2630E-X1 |
1 to 6 |
1 to 6 |
1 to 6 |
Hardware |
Value range |
MSR2660-XS |
1 to 6 |
MSR2680-XS |
1 to 6 |
Hardware |
Value range |
MSR2600-12X-WiNet |
1 to 6 |
MSR2610-13X-WiNet |
1 to 6 |
both: Mirrors both received and sent packets.
inbound: Mirrors only received packets.
outbound: Mirrors only sent packets.
A source port cannot be used as a monitor port.
# Create local mirroring group 1 to monitor the bidirectional traffic of the port GigabitEthernet 0/0/1.
[Sysname] interface gigabitethernet 0/0/1
[Sysname-GigabitEthernet0/0/1] mirroring-group 1 mirroring-port both
mirroring-group
Use mirroring-group mirroring-port to configure source ports for a mirroring group.
Use undo mirroring-group mirroring-port to remove source ports from a mirroring group.
mirroring-group group-id mirroring-port interface-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port interface-list
No source port is configured for a mirroring group.
Hardware |
Value range |
MSR1008 |
1 to 6 |
MSR1004-G |
1 |
MSR1004-G-5GCN |
1 |
MSR2630E-X1 |
1 to 6 |
1 to 6 |
1 to 6 |
Hardware |
Value range |
MSR2660-XS |
1 to 6 |
MSR2680-XS |
1 to 6 |
Hardware |
Value range |
MSR2600-12X-WiNet |
1 to 6 |
MSR2610-13X-WiNet |
1 to 6 |
interface-list: Specifies a space-separated list of up to eight interface items. Each item specifies an interface by its type and number or specifies a range of interfaces in the form of interface-type interface-number1 to interface-type interface-number2. When you specify a range of interfaces, the interfaces must be of the same type and on the same slot. The start interface number must be identical to or lower than the end interface number.
# Create local mirroring group 1 to monitor the bidirectional traffic of GigabitEthernet 0/0/1.
[Sysname] mirroring-group 1 mirroring-port gigabitethernet 0/0/1 both
mirroring-group
Use mirroring-group monitor-port to configure a port as the monitor port for a mirroring group.
Use undo mirroring-group monitor-port to restore the default.
mirroring-group group-id monitor-port
undo mirroring-group group-id monitor-port
A port does not act as the monitor port for any mirroring groups.
Interface view
Hardware |
Value range |
MSR1008 |
1 to 6 |
MSR1004-G |
1 |
MSR1004-G-5GCN |
1 |
MSR2630E-X1 |
1 to 6 |
1 to 6 |
1 to 6 |
Hardware |
Value range |
MSR2660-XS |
1 to 6 |
MSR2680-XS |
1 to 6 |
Hardware |
Value range |
MSR2600-12X-WiNet |
1 to 6 |
MSR2610-13X-WiNet |
1 to 6 |
Do not enable the spanning tree feature on the monitor port of a mirroring group.
An aggregation member port cannot be configured as the monitor port.
Use a monitor port only for port mirroring, so the data monitoring device receives and analyzes only the mirrored traffic.
The member port of an existing mirroring group cannot be configured as a monitor port.
The member port of an aggregate interface cannot be configured as a monitor port.
# Create local mirroring group 1 and configure GigabitEthernet 0/0/1 as its monitor port.
[Sysname-GigabitEthernet0/0/1] mirroring-group 1 monitor-port
mirroring-group
Use mirroring-group monitor-port to configure the monitor ports for a mirroring group.
Use undo mirroring-group monitor-port to remove the monitor ports from a mirroring group.
mirroring-group group-id monitor-port interface-type interface-number
undo mirroring-group group-id monitor-port interface-type interface-number
No monitor port is configured for a mirroring group.
Hardware |
Value range |
MSR1008 |
1 to 6 |
MSR1004-G |
1 |
MSR1004-G-5GCN |
1 |
MSR2630E-X1 |
1 to 6 |
1 to 6 |
1 to 6 |
Hardware |
Value range |
MSR2660-XS |
1 to 6 |
MSR2680-XS |
1 to 6 |
Hardware |
Value range |
MSR2600-12X-WiNet |
1 to 6 |
MSR2610-13X-WiNet |
1 to 6 |
Use a monitor port only for port mirroring, so the data monitoring device receives only the mirrored traffic.
[Sysname] mirroring-group 1 monitor-port gigabitethernet 0/0/1
mirroring-group
Flow mirroring commands
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
Syntax I
mirror-to interface interface-type interface-number [ { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ dscp dscp-value | erspan-id erspan-id-value | vlan vlan-id | vrf-instance vrf-instance-name ] * ] [ destination-mac mac-address ]
undo mirror-to interface interface-type interface-number
Syntax II
mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address } [ dscp dscp-value | erspan-id erspan-id-value | vlan vlan-id | vrf-instance vrf-name ] * [ destination-mac mac-address ]
undo mirror-to interface { destination-ip destination-ip-address source-ip source-ip-address | destination-ipv6 destination-ipv6-address source-ipv6 source-ipv6-address }
No mirroring actions exist to mirror traffic to interfaces.
Traffic behavior view
destination-ip destination-ip-address: Specifies the destination IP address for the mirrored packets.
source-ip source-ip-address: Specifies the source IP address for the mirrored packets.
destination-ipv6 destination-ipv6-address: Specifies the destination IPv6 address for the mirrored packets.
source-ipv6 source-ipv6-address: Specifies the source IPv6 address for the mirrored packets.
dscp dscp-value: Specifies the DSCP value for the mirrored packets. The dscp-value argument can be a number in the range of 0 to 63 or a keyword in Table 2.
Table 2 DSCP keywords and values
Keyword |
DSCP value in binary |
DSCP value in decimal |
af11 |
001010 |
10 |
af12 |
001100 |
12 |
af13 |
001110 |
14 |
af21 |
010010 |
18 |
af22 |
010100 |
20 |
af23 |
010110 |
22 |
af31 |
011010 |
26 |
af32 |
011100 |
28 |
af33 |
011110 |
30 |
af41 |
100010 |
34 |
af42 |
100100 |
36 |
af43 |
100110 |
38 |
cs1 |
001000 |
8 |
cs2 |
010000 |
16 |
cs3 |
011000 |
24 |
cs4 |
100000 |
32 |
cs5 |
101000 |
40 |
cs6 |
110000 |
48 |
cs7 |
111000 |
56 |
default |
000000 |
0 |
ef |
101110 |
46 |
erspan-id erspan-id-value: Specifies the ERSPAN ID for the mirrored packets in the range of 1 to 1023.
vlan vlan-id: Specifies a VLAN by its VLAN ID in the range of 1 to 4094 for the mirrored packets.
vrf-instance vrf-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. The mirrored packets will be forwarded based on the routing table of the specified VPN instance.
destination-mac mac-address: Specifies the destination MAC address for mirrored packets sent to the interface. The mac-address argument is in the format of H-H-H. If you do not specify this option, the device uses the destination IP address to dynamically get the destination MAC address for the mirrored packets.
strip-vlan vlan-id: Specifies a VLAN where mirrored packets are broadcast by its ID in the range of 1 to 4094.
You can execute this command multiple times for a traffic behavior to mirror traffic to different interfaces.
The encapsulation parameters for the mirrored packets are available only when the mirrored packets are sent out of Ethernet interfaces.
If you use syntax I, traffic is mirrored to the specified interface.
If you use syntax II, traffic is processed as follows:
1. The device encapsulates the traffic with the specified parameters.
2. The device looks up the source IP address and destination IP address of the traffic in the routing table and forwards the traffic based on the matching route. The outgoing interface of the route is the destination interface of the mirrored traffic.
Through configuring load sharing in the routing protocols, you can specify multiple destination interfaces for the mirrored traffic. When the current mirroring destination interface fails, the mirrored traffic is forwarded to the outgoing interface re-calculated by the routing protocols.
# Create traffic behavior 1 and configure the action of mirroring traffic to GigabitEthernet 0/0/1 for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to interface gigabitethernet 0/0/1
# Create traffic behavior 1, and configure the action of mirroring traffic to GigabitEthernet 0/0/1 for the traffic behavior. Specify the following parameters for the mirrored packets sent to GigabitEthernet 0/0/1:
· Specify 1.1.1.1 and 2.2.2.2 as the destination address and source address, respectively.
· Specify 20, 100, and vpn1 as the DSCP value, VLAN, and the VPN instance name, respectively.
[Sysname-behavior-1] mirror-to interface gigabitethernet 0/0/1 destination-ip 1.1.1.1 source-ip 2.2.2.2 dscp 20 vlan 100 vrf-instance vpn1
