21-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C MSR1000[2600][3600] Routers Command Reference(V9)-R9141-6W10021-Network Management and Monitoring Command Reference
10-CWMP commands
10-CWMP commands 181.83 KB
CWMP commands
cwmp
Use cwmp to enter CWMP view.
cwmp [ 181-model ]
181-model: Enters the CWMP view of TR181 data model. By default, the CWMP view of TR098 data model is entered.
# Enter CWMP view.
[Sysname] cwmp
cwmp enable
cwmp acs default password
Use cwmp acs default password to configure a password for authentication to the default ACS URL.
Use undo cwmp acs default password to restore the default.
cwmp acs default password { cipher | simple } string
No password is configured for authentication to the default ACS URL.
CWMP view
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 255 characters. Its encrypted form is a case-sensitive string of 33 to 373 characters.
You can configure only one password for authentication to the default ACS URL. If you execute this command multiple times, the most recent configuration takes effect.
For a successful connection, make sure the CPE has the same username and password settings as the ACS.
# Configure the password used for authentication to the default ACS URL.
[Sysname] cwmp
[Sysname-cwmp] cwmp acs default password simple newpsw
cwmp acs default url
cwmp acs default username
Use cwmp acs default url to specify a default ACS URL.
Use undo cwmp acs default url to restore the default.
cwmp acs default url url
No default ACS URL is specified.
CWMP view
url: Specifies the default ACS URL, a string of 8 to 255 characters. The URL must use the http://host[:port]/path or https://host[:port]/path format.
The CPE attempts to connect to the default ACS URL if no ACS URL has been assigned to it through the cwmp acs url command or DHCP.
You can configure only one default ACS URL. If you execute this command multiple times, the most recent configuration takes effect.
# Specify the default ACS URL.
[Sysname] cwmp
[Sysname-cwmp] cwmp acs default url https://www.example.com:9090
Use cwmp acs default username to configure the username for authentication to the default ACS URL.
Use undo cwmp acs default username to restore the default.
cwmp acs default username username
No username is configured for authentication to the default ACS URL.
CWMP view
username: Specifies a username, a case-sensitive string of 1 to 255 characters.
You can configure only one username for authentication to the default ACS URL. If you execute this command multiple times, the most recent configuration takes effect.
# Configure the username for authentication to the default ACS URL.
[Sysname] cwmp
[Sysname-cwmp] cwmp acs default username newname
cwmp acs password
Use cwmp acs password to configure the password for authentication to the preferred ACS URL.
Use undo cwmp acs password to restore the default.
cwmp acs password { cipher | simple } string
No password is configured for authentication to the preferred ACS URL.
CWMP view
You can configure only one password for authentication to the preferred ACS URL. If you execute this command multiple times, the most recent configuration takes effect.
# Configure the password used for authentication to the preferred ACS URL.
[Sysname] cwmp
[Sysname-cwmp] cwmp acs password simple newpsw
cwmp acs url
cwmp acs username
cwmp acs url
Use cwmp acs url to specify a preferred ACS URL.
Use undo cwmp acs url to restore the default.
cwmp acs url url
undo cwmp acs url
No preferred ACS URL is specified.
CWMP view
url: Specifies the preferred ACS URL, a string of 8 to 255 characters. The URL must use the http://host[:port]/path or https://host[:port]/path format.
The device supports only one preferred ACS URL. If you execute this command multiple times, the most recent configuration takes effect.
The preferred ACS URL is configurable from the CPE's CLI, the DHCP server, and the ACS. The CLI- and ACS-assigned URLs have higher priority than the DHCP-assigned URL. The CLI- and ACS-assigned URLs overwrite each other.
The CPE uses the default ACS parameters for connection establishment only when it is not assigned a preferred ACS URL from the CLI, ACS, or DHCP server.
# Specify the ACS URL.
[Sysname] cwmp
[Sysname-cwmp] cwmp acs url https://www.example.com:9090
cwmp acs username
Use cwmp acs username to configure the username for authentication to the preferred ACS URL.
Use undo cwmp acs username to restore the default.
cwmp acs username username
No username is configured for authentication to the preferred ACS URL.
CWMP view
You can configure only one username for authentication to the preferred ACS URL. If you execute this command multiple times, the most recent configuration takes effect.
# Configure the username used for authentication to the preferred ACS URL.
[Sysname] cwmp
[Sysname-cwmp] cwmp acs username newname
cwmp acs password
cwmp cpe connect interface
Use cwmp cpe connect interface to specify the CWMP connection interface.
Use undo cwmp cpe connect interface to restore the default.
cwmp cpe connect interface interface-type interface-number
No interface is specified as the CWMP connection interface. The CPE automatically selects an interface as the CWMP connection interface.
CWMP view
interface-type interface-number: Specifies the type and number of the CWMP connection interface.
A CWMP connection interface is the interface that the CPE uses to communicate with the ACS. To establish a CWMP connection, the CPE sends the IP address of this interface in the Inform message, and the ACS replies to this IP address.
Typically, the CPE selects the CWMP connection interface automatically. If the CWMP connection interface is not the interface that connects the CPE to the ACS, the CPE fails to establish a CWMP connection with the ACS. For example, an incorrect CWMP connection interface selection occurs when the following conditions exist:
·     The CPE has multiple Layer 3 interfaces.
·     The IP addresses of the CWMP connection interface and the ACS are not in the same subnet.
In this case, you need to use this command to manually specify the CWMP connection interface.
# Specify GigabitEthernet 0/0/1 as the CWMP connection interface.
[Sysname] cwmp
[Sysname-cwmp] cwmp cpe connect interface gigabitethernet 0/0/1
cwmp cpe connect retry
Use cwmp cpe connect retry to set the maximum number of attempts the CPE can make to retry a failed CWMP connection.
Use undo cwmp cpe connect retry to restore the default.
cwmp cpe connect retry retries
The CPE retries a failed connection until the connection is established with the ACS.
CWMP view
retries: Specifies the maximum number of CWMP connection retries. The value range is 0 to 100. To disable the CPE to retry a CWMP connection, set this argument to 0.
The CPE retries connecting to the ACS when its initial connection attempt fails or the CWMP session is ended before the CPE receives a session closed message from the ACS. The CPE does not stop its connection retry attempts until the connection is established or the number of connection retries reaches the upper limit.
# Set the maximum number of CWMP connection retries to 5.
[Sysname] cwmp
[Sysname-cwmp] cwmp cpe connect retry 5
cwmp cpe dhcp force-renew threshold
Use cwmp cpe dhcp force-renew threshold to configure the threshold for triggering forced ACS parameter renewal through DHCP.
Use undo cwmp dhcp force-renew threshold to restore the default.
cwmp cpe dhcp force-renew threshold threshold-value
undo cwmp cpe dhcp force-renew threshold
The threshold for triggering forced ACS parameter renewal through DHCP is 5 times.
CWMP view
threshold-value: Specifies the threshold for triggering CWMP to retrieve ACS parameters again from the DHCP server through DHCP, in the range of 1 to 20.
Application scenarios
Use this command to configure the threshold for triggering forced ACS parameter renewal through DHCP when you use the DHCP server to issue ACS parameters.
Operating mechanism
By default, a CWMP-enabled device will initiate a DHCP IP address renewal process to retrieve ACS parameters (including ACS URL, username, and password) again in either of the following conditions:
·     The device is not configured with an ACS URL.
If the device is not configured with an ACS URL, CWMP will immediately initiate a DHCP IP address renewal process to retrieve ACS parameters.
·     CWMP connection establishment fails, and the number of consecutive failures reaches the threshold set by using the cwmp cpe dhcp force-renew threshold command.
For example, if the username and password for ACS authentication are modified, the device cannot establish a CWMP connection to the ACS. Or, if the current ACS is faulty and cannot establish CWMP connections, you must replace it with a new ACS to continue incorporating the device. In this case, CWMP will wait for the device to establish a connection to the ACS. If CWMP connection establishment fails, and the number of consecutive failures reaches the threshold set by using the cwmp cpe dhcp force-renew threshold command, CWMP will perform the following tasks:
a.     Consider the current ACS to be faulty.
b.     Trigger the device to initiate a DHCP renewal process to retrieve ACS parameters from the DHCP server again.
Whether the IP address of the interface changes after renewal depends on the DHCP renewal configuration.
To use the DHCP server to assign ACS parameters, first complete the following tasks:
1.     Configure the interface on the device to obtain an IP address through DHCP.
2.     Configure the DHCP server to assign ACS parameters through DHCPv4 option 43 or DHCPv6 option 17.
¡     For IPv4, execute the option command in IPv4 address pool view to configure option 43 to assign ACS parameters.
For more information about DHCPv4, see DHCP configuration in Layer 3—IP Services Configuration Guide.
¡     For IPv6, execute the vendor-specific and suboption commands in IPv6 address pool view to configure a vendor-specific option to assign ACS parameters.
For more information about DHCPv6, see DHCPv6 configuration in Layer 3—IP Services Configuration Guide.
# Configure the threshold for triggering forced ACS parameter renewal through DHCP as 10 times.
[Sysname] cwmp
[Sysname-cwmp] cwmp cpe dhcp force-renew threshold 10
option (Layer 3—IP Services Command Reference)
suboption (Layer 3—IP Services Command Reference)
vendor-specific (Layer 3—IP Services Command Reference)
cwmp cpe dhcp parse-mode
Use cwmp cpe dhcp parse-mode telecom to configure CWMP to use the Telecom mode to parse DHCP sub-options.
Use undo cwmp cpe dhcp parse-mode to restore the default.
CWMP uses the default mode to parse DHCP sub-options.
System viww
CWMP supports automatic configuration retrieval through sub-options of DHCPv4 option 43 and DHCPv6 option 17. Different users have varying requirements for the sub-options that can be carried in the DHCP option fields based on their service needs. The device supports both the default mode and Telecom mode for parsing the sub-options of the DHCP option to best meet user service requirements.
Operating mechanism
By default, CWMP uses the default mode to parse DHCP option fields. Table 1 shows the differences between the default mode and Telecom mode.
Table 1 DHCP sub-option parsing modes
DHCP-suboption parsing mode
Requirements
Default mode
You can deploy only the ACS configuration and must deploy the following simultaneously:
·     URL of the ACS
·     Username used by the device to access ACS
·     Password used by the device to access ACS
To use this method for automatic network deployment, make sure the CPE and the ACS are located in the same subnet.
Telecom mode
You can deploy not only the ACS configuration but also other settings such as VLAN, gateway addresses, and static routes. For more information, see Table 2.
To use this method for automatic network deployment, the CPE and ACS can be on different subnets, and the CPE can communicate with the ACS through the default route or static routes provided.
Table 2 DHCP sub-options that can be parsed by CWMP in Telecom mode
DHCP sub-option code
DHCP suboption name
1
SN
Device unique identifier
This field is required in Telecom networking standards.
2
OUI
Vendor Organizationally Unique Identifier (OUI).
4
·     OM IP address subnet mask (DHCPv4)
·     OM IP address Prefix Length (DHCPv6)
IP address mask or IPv6 address prefix length of the CPE.
·     In a DHCPv4 environment, this field is the IPv4 address mask of the CPE.
·     In a DHCPv6 environment, this field is the IPv6 address prefix length of the CPE.
5
OM Gateway address
IPv4/IPv6 gateway address of the CPE.
6
OM VlanID
Created VLAN ID on the CPE.
7
Management Server URL
ACS URL to which the CPE will connect.
8
Username
Username used by the CPE to access the ACS.
9
Password
Password used by the CPE to access the ACS.
10
Routing Target IP address
IPv4/IPv6 destination address of the static route deployed to the CPE.
11
OM Next hop IP address
Next hop IPv4/IPv6 address of the static route deployed to the CPE.
12
·     Routing net mask (DHCPv4)
·     Routing Prefix Length (DHCPv6)
·     In a DHCPv4 environment, this field is the address mask of the base station.
·     In a DHCPv6 environment, this field is the prefix length of the base station.
# Configure CWMP to use the Telecom mode to parse DHCP sub-options.
[Sysname] cwmp cpe dhcp parse-mode telecom
cwmp cpe inform interval
Use cwmp cpe inform interval to set the periodic Inform interval.
Use undo cwmp cpe inform interval to restore the default.
cwmp cpe inform interval interval
The periodic Inform interval is 600 seconds.
CWMP view
interval: Sets the periodic Inform interval in the range of 1 to 4294967295 seconds.
This command sets the interval for the CPE to send Inform messages automatically to the ACS. For the command to take effect, you must configure the cwmp cpe inform interval enable command.
# Set the periodic Inform interval to 3600 seconds.
[Sysname] cwmp
[Sysname-cwmp] cwmp cpe inform interval 3600
[Sysname-cwmp] cwmp cpe inform interval enable
Use cwmp cpe inform interval enable to enable the periodic Inform feature.
Use undo cwmp cpe inform interval enable to disable the periodic Inform feature.
The CPE does not send Inform messages periodically.
CWMP view
If this command is configured, the CPE sends Inform messages regularly to establish a CWMP session with the ACS. To set the periodic Inform interval, use the cwmp cpe inform interval command.
# Enable the periodic Inform feature.
[Sysname] cwmp
cwmp cpe inform time
Use cwmp cpe inform time to set a base time for periodic Inform.
Use undo cwmp cpe inform time to restore the default.
cwmp cpe inform time time
No base time is set for periodic Inform.
CWMP view
time: Specifies the base time for periodic Inform. The time format is yyyy-mm-ddThh:mm:ss, and the value range is 1970-01-01T00:00:00 to 2035-12-31T23:59:59. The specified time must be greater than the current system time.
With this feature and the periodic Inform feature enabled, the device calculates time points for periodic Inform by adding intervals to the base time and then performs periodic Inform at the time points. For example, when the cwmp cpe inform interval 3600, cwmp cpe inform interval enable, and cwmp cpe inform time 2021-01-01T20:00:00 commands are configured, the device sends an Inform message every one hour since 2021-01-01 20:00:00.
You can use this command to set the date, time, and time zone in DateTTime or DateTTime±Time Zone format, where:
·     The date format is yyyy-mm-dd in the range of 1970-01-01 to 2035-12-31.
·     The time format is hh:mm:ss.ms, where:
¡     hh represents hour in the range of 0 to 23.
¡     mm represents minute in the range of 0 to 59.
¡     ss represents second in the range of 0 to 59.
¡     ms represents microsecond in the range of 0 to 999999. This field is optional.
·     The time zone format is hh:mm in the range of 00:00 to 12:59. You can use DateTTime+00:00, DateTTime-00:00, or DateTTimeZ to indicate time zone zero.
# Set the base time to 2021-01-01T20:00:00 for periodic Inform.
[Sysname] cwmp
[Sysname-cwmp] cwmp cpe inform time 2021-01-01T20:00:00
cwmp cpe password
Use cwmp cpe password to configure the password for the CPE to authenticate the ACS.
Use undo cwmp cpe password to restore the default.
cwmp cpe password { cipher | simple } string
No password is configured for authenticating the ACS.
CWMP view
You can configure only one password for the ACS to authenticate to the CPE when it initiates a connection. If you execute this command multiple times, the most recent configuration takes effect.
For a successful connection, make sure the ACS has the same username and password settings as the CPE.
If a password is configured, the ACS must provide the correct password when it initiates a connection to the CPE. If the password is incorrect, the CPE denies the connection request from the ACS.
You do not need to configure this command if you want to authenticate the ACS only based on its username.
# Configure the password used for authenticating the ACS.
[Sysname] cwmp
[Sysname-cwmp] cwmp cpe password simple newpsw
cwmp cpe username
cwmp cpe port
Use cwmp cpe port to specify a CPE service port number.
Use undo cwmp cpe port to restore the default.
cwmp cpe port port
undo cwmp cpe port
The CPE service port number is 7547.
CWMP view
port: Specifies a CPE service port number in the range of 1000 to 65535.
Perform this task to specify a CPE service port number. For the ACS to establish a CWMP connection to the CPE successfully, the ACS must provide a port number that is the same as configured on the CPE. After this feature is configured, the CPE uses the new port to provide CWMP services and the established CWMP services are not affected.
# Specify port 51703 to provide the CPE service.
<Sysname> system
[Sysname] cwmp
[Sysname-cwmp] cwmp cpe port 51703
cwmp cpe provision-code
Use cwmp cpe provision-code to configure the provision code of the CPE.
Use undo cwmp cpe provision-code to restore the default.
cwmp cpe provision-code provision-code
The provision code is PROVISIONINGCODE.
CWMP view
provision-code: Specifies a provision code, a string of 1 to 64 characters. The string can contain uppercase letters, digits, and the full stop (.).
The ACS can use the provision code to identify services assigned to each CPE. For correct configuration deployment, make sure the same provision code is configured on the CPE and the ACS. For information about the support of your ACS for provision codes, see the ACS documentation.
The CPE can have only one provision code. If you execute this command multiple times, the most recent configuration takes effect.
# Set the provision code to ABC30010714.
<Sysname> system
[Sysname] cwmp
[Sysname-cwmp] cwmp cpe provision-code ABC30010714
cwmp cpe stun enable
Use cwmp cpe stun enable to enable NAT traversal for the connection requests from the ACS to reach the CPE through a NAT gateway.
Use undo cwmp cpe stun enable to disable NAT traversal for the connection requests from the ACS to reach the CPE through a NAT gateway.
NAT traversal is disabled for CWMP.
CWMP view
Connection requests initiated from the CPE can reach the ACS through a NAT gateway without NAT traversal. However, for the connection request initiated from the ACS to reach the CPE, you must enable NAT traversal on the CPE when a NAT gateway resides between the CPE and the ACS.
The NAT traversal feature complies with Simple Traversal of UDP Through NATs (STUN), RFC 3489. The feature enables the CPE to do the following:
·     Discovers the NAT gateway.
·     Obtains an open NAT binding (a public IP address and port binding) through which the ACS can send unsolicited packets.
The CPE sends the binding to the ACS when it initiates a connection to the ACS. For the connection requests sent by the ACS at any time to reach the CPE, the CPE maintains the open NAT binding.
For more information about NAT, see Layer 3—IP Services Configuration Guide.
# Enable NAT traversal for the CPE.
[Sysname] cwmp
[Sysname-cwmp] cwmp cpe stun enable
cwmp cpe username
Use cwmp cpe username to configure the username for the CPE to authenticate the ACS.
Use undo cwmp cpe username to restore the default.
cwmp cpe username username
No username is configured for authenticating the ACS.
CWMP view
You can configure only one username for the ACS to authenticate to the CPE when it initiates a connection. If you execute this command multiple times, the most recent configuration takes effect.
For a successful connection, make sure the ACS has the same username setting as the CPE. If a password is required, you must also make sure the ACS has the same password setting as the CPE.
The ACS must provide the correct username when it initiates a connection to the CPE. If the username is incorrect, the CPE denies the connection request from the ACS.
# Configure the username used for authenticating the ACS.
[Sysname] cwmp
[Sysname-cwmp] cwmp cpe username newname
cwmp cpe password
cwmp cpe wait timeout
Use cwmp cpe wait timeout to set the close-wait timer for the CPE to close an idle connection.
Use undo cwmp cpe wait timeout to restore the default.
cwmp cpe wait timeout seconds
The close-wait timer is 30 seconds.
CWMP view
seconds: Sets the close-wait timer, in the range of 30 to 1800 seconds.
The close-wait timer has the following functions:
·     It specifies the amount of time the connection to the ACS can be idle before it is terminated. The CPE terminates the connection to the ACS if no traffic is transmitted before the timer expires.
·     It also specifies the amount of time the CPE waits for the response to a session request. The CPE determines that its session attempt has failed when the timer expires. By default, the CPE retries a failed session until the session is established with the ACS. To limit the number of retries, use the cwmp cpe connect retry command.
# Set the close-wait time to 60 seconds.
[Sysname] cwmp
[Sysname-cwmp] cwmp cpe wait timeout 60
cwmp enable
Use cwmp enable to enable CWMP.
Use undo cwmp enable to disable CWMP.
cwmp enable
undo cwmp enable
CWMP is disabled.
CWMP view
CWMP configuration takes effect only after CWMP is enabled.
# Enable CWMP.
[Sysname] cwmp
[Sysname-cwmp] cwmp enable
cwmp
display cwmp configuration
Use display cwmp configuration to display the CWMP configuration.
display cwmp [ 181-model | all-model ] configuration
181-model: Displays the configuration for CWMP of TR181 data model.
all-model: Displays the configuration for CWMP of all models.
If you do not specify the 181-model or all-model keyword, the system displays the configuration for CWMP of TR098 data model.
# Display the CWMP configuration after CWMP is enabled.
<Sysname> display cwmp configuration
TR-098 data model configuration:
CWMP state                           : Enabled
ACS URL                               : https://www.example.com:9090
ACS username                         : newname
ACS default URL                     : Null
ACS default username               : defname
Periodic inform                     : Disabled
Inform interval                     : 600s
Inform time                          : Not configured
Wait timeout                         : 30s
Connection retries                  : Unlimited
Source IP interface                 : None
STUN state                            : Disabled
SSL policy name                      : Null
DHCP force-renew threshold         : 5
TR-098 data model status
Configuration for CWMP of TR-098 data model.
TR-181 data model status
Configuration for CWMP of TR-181 data model.
CWMP state
Status of CWMP: Enabled or Disabled.
ACS URL
Preferred ACS URL.
This field displays Null if no preferred ACS URL has been specified.
ACS username
Username for the CPE to authenticate to the ACS. This field displays Null if no username has been configured for authentication to the preferred ACS URL.
ACS default URL
Default ACS URL.
This field displays Null if no default ACS URL has been configured.
Username for the CPE to authenticate to the default ACS URL.
This field displays Null if no username has been configured for authentication to the default ACS URL.
Periodic inform
Status of the periodic Inform feature: Enabled or Disabled.
Inform interval
Periodic Inform interval. The default interval is 600 seconds.
Inform time
Base time for periodic Inform. If you do not specify a base time, this field displays Not configured.
Wait timeout
Close-wait timer. This timer is configurable with the cwmp cpe wait timeout command.
Connection retries
Number of attempts the CPE can make to retry a failed CWMP connection.
This field displays Unlimited if the default setting is used. The CPE retries a failed session until the session is established with the ACS.
Source IP interface
IP address of the specified CWMP connection interface. This field displays None if you have not specified a CWMP connection interface.
STUN state
Status of NAT traversal for CWMP: Enabled or Disabled.
SSL policy name
SSL client policy specified for the CPE to authenticate the ACS for establishing an HTTPS connection. You must specify an SSL client policy when HTTPS is used.
This field displays Null if you have not specified an SSL client policy.
Threshold for triggering forced DHCP renewal.
display cwmp status
display cwmp status
Use display cwmp status to display CWMP state information.
display cwmp [ 181-model | all-model ] status
181-model: Displays the state information about CWMP of TR181 data model.
all-model: Displays the state information about CWMP of all models.
If you do not specify the 181-model or all-model keyword, the system displays the state information about CWMP of TR098 data model.
# Display CWMP state information.
<Sysname> display cwmp status
TR-098 data model status:
ACS URL of most recent connection              : https://www.example.com:9090
ACS information source                            : User
ACS username of most recent connection         : newname
Connection status                                  : Disconnected
Data transfer status                               : None
Most recent successful connection attempt      : None
Length of time before next connection attempt : 1096832s
Status of CWMP using TR-098 data model.
Status of CWMP using TR-181 data model.
CWMP state
ACS URL used for the most recent connection attempt.
This field displays Null if no ACS URL was available.
Source from which the CPE obtained the ACS URL:
·     User—ACS URL assigned by using the cwmp acs url command or by ACS.
·     DHCP—ACS URL assigned by the DHCP server.
·     DHCPv6—ACS URL assigned by the DHCPv6 server.
·     Default—ACS URL assigned by using the cwmp acs default url command.
This field displays None if no ACS URL was available.
Username used for the most recent connection to the ACS.
This field displays Null if no ACS username was available.
Connection status
Current CWMP session status:
·     Connected—A CWMP session has been established to the ACS.
·     Disconnected—No CWMP session has been established to the ACS.
·     Waiting response—The CPE is waiting for the connection response from the ACS.
Data transfer status of the CPE:
·     Uploading—The CPE is uploading data.
·     Downloading—The CPE is downloading data.
·     None—No data is transferred.
Time of the most recent successful CWMP connection. This field displays None if no CWMP session was established.
Amount of time (in seconds) that the CPE must wait before it initiates the next connection. This field displays None if the CPE does not detect an event that will trigger a connection attempt.
ssl client-policy
Use ssl client-policy to specify an SSL client policy for CWMP.
Use undo ssl client-policy to restore the default.
ssl client-policy policy-name
No SSL client policy is specified for CWMP.
CWMP view
policy-name: Specifies the name of an SSL client policy, a string of 1 to 31 characters.
CWMP uses HTTP or HTTPS for data transmission. If the ACS uses HTTPS for secure access, its URL begins with https://. You must configure an SSL client policy for the CPE to authenticate the ACS for establishing an HTTPS connection. For more information about configuring SSL client policies, see Security Configuration Guide.
# Specify the SSL client policy test for CWMP.
<Sysname> system
[Sysname] cwmp
[Sysname-cwmp] ssl client-policy test
