- 10-MPLS Command Reference
- 01-Basic MPLS commands
- 02-Static LSP commands
- 03-LDP commands
- 04-MPLS TE commands
- 05-Static CRLSP commands
- 06-RSVP commands
- 07-Tunnel policy commands
- 08-MPLS L3VPN commands
- 09-IPv6 MPLS L3VPN commands
- 10-MPLS L2VPN commands
- 11-VPLS commands
- 12-MPLS OAM commands
- 13-MCE commands
| 12-MPLS OAM commands | 475.13 KB |
mpls bfd backup detect-multiplier
mpls bfd backup min-receive-interval
mpls bfd backup min-transmit-interval
mpls bfd min-transmit-interval
mpls bfd trigger tunnel-down enable
mpls periodic-tracert (for LSP)
mpls te bfd enable pce-initiated-lsp
mpls te bfd min-receive-interval
mpls te bfd min-transmit-interval
mpls te tunnel-bfd detect-multiplier
mpls te tunnel-bfd min-receive-interval
mpls te tunnel-bfd min-transmit-interval
mpls tunnel-bfd (for TE tunnel)
mpls tunnel-bfd detect-multiplier
mpls tunnel-bfd min-receive-interval
mpls tunnel-bfd min-transmit-interval
mpls tunnel-sbfd (for TE tunnel)
MPLS OAM commands
The mpls bfd enable command is available only when the system operates in standard mode.
bfd discriminator
Use bfd discriminator to set local and remote discriminators for the BFD session used to verify PW connectivity.
Use undo bfd discriminator to restore the default.
bfd discriminator local local-id remote remote-id
No local or remote discriminators are set for the BFD session used to verify PW connectivity. The system automatically assigns local and remote discriminators to the BFD session.
Cross-connect PW view
VSI static PW view
VSI LDP PW view
Cross-connect backup PW view
VSI static backup PW view
VSI LDP backup PW view
local local-id: Specifies the local discriminator value for the BFD session. The value range is 1 to 32768.
remote remote-id: Specifies the remote discriminator value for the BFD session, in the range of 1 to 4294967295.
A BFD session for PW connectivity verification can be established in one of the following modes:
· Static mode—Specify the local and remote discriminator values by using the bfd discriminator command. You must specify the discriminators on both the local and remote PEs. Make sure the local discriminator and remote discriminator on the local PE are the same as the remote discriminator and local discriminator on the remote PE, respectively. Otherwise, the BFD session cannot be established for the PW.
· Dynamic mode—If you do not specify local and remote discriminators, the system automatically runs MPLS ping to negotiate the discriminator values.
# In VSI LDP PW view, set both the local and remote discriminator values to 1 for the BFD session used to verify PW connectivity.
[Sysname] vsi ttt
[Sysname-vsi-ttt] pwsignaling ldp
[Sysname-vsi-ttt-ldp] peer 22.22.2.2 pw-id 1 pw-class ttt
[Sysname-vsi-ttt-ldp-22.22.2.2-1] bfd discriminator local 1 remote 1
display l2vpn pw bfd
mpls bfd enable
vccv bfd
vccv cc
bfd ip-router-alert
Use bfd ip-router-alert to add the Router Alert option in BFD packets for LSP connectivity verification.
Use undo bfd ip-router-alert to remove the Router Alert option from BFD packets for LSP connectivity verification.
bfd ip-router-alert
The device adds the Router Alert option in BFD packets for LSP connectivity verification.
Execute the undo bfd ip-router-alert command on the local device if the peer device cannot identify the Router Alert option in BFD packets.
This command takes effect only on BFD sessions that come up after this command is executed.
# Remove the Router Alert option from BFD packets.
[Sysname] undo bfd ip-router-alert
Use display l2vpn pw bfd to display BFD information for PWs.
display l2vpn pw bfd [ peer peer-ip pw-id pw-id ]
peer peer-ip: Specifies the LSR ID of the peer PE for a PW. If you do not specify a PW, this command displays BFD information for all PWs.
pw-id pw-id: Specifies the PW ID, in the range of 1 to 4294967295.
# Display BFD information for all PWs.
<Sysname> display l2vpn pw bfd
Total number of sessions: 1, 1 up, 0 down, 0 init
FEC Type: PW FEC-128
FEC Info:
Peer IP: 22.22.2.2
PW ID: 1
VSI Index: 0 Link ID: 8
Local Discr: 514 Remote Discr: 514
Source IP: 11.11.1.1 Destination IP: 127.0.0.2
Session State: Up Session Role: Active
Template Name: -
BFD Info: Tunnel BFD |
Indicates that the PW was detected by tunnel BFD. |
FEC type |
Type of the FEC detected by BFD: PW FEC-128. |
Peer IP |
LSR ID of the peer PE. |
VSI Index |
Index of the VSI to which the PW belongs. This field is displayed when the PW is a VPLS PW. |
Connection ID |
ID of the cross-connect to which the PW belongs. This field is displayed when the PW is an MPLS L2VPN PW. |
Link ID |
Link ID of the PW. |
Local Discr |
Local discriminator of the BFD session. |
Remote Discr |
Remote discriminator of the BFD session. |
Source IP |
Source IP of the BFD session, which is the MPLS LSR ID of the local PE. |
Destination IP |
Destination IP address of the BFD session, which is on subnet 127.0.0.0/8. |
Session State |
BFD session state: · Init—BFD session is in initialization state. · Up—BFD session is up. · Down—BFD session is down. |
Session Role |
Role of the local PE in the BFD session: · Active—Sender of the BFD session. · Passive—Receiver of the BFD session. |
Template Name |
Name of the BFD session parameter template. |
bfd discriminator
vccv bfd
vccv cc
display mpls bfd
Use display mpls bfd to display BFD information for LSP tunnels or MPLS TE tunnels.
display mpls bfd [ ipv4 ipv4-address mask-length | te tunnel tunnel-number ]
ipv4 ipv4-address mask-length: Specifies an FEC by a destination IP address and mask length. The mask length is in the range of 0 to 32.
te tunnel tunnel-number: Specifies an existing MPLS TE tunnel by the tunnel interface number.
If you do not specify any parameters, this command displays BFD information for all LSP tunnels and MPLS TE tunnels.
<Sysname> display mpls bfd ipv4 22.22.2.2 32
FEC Type: LSP
FEC Info:
Destination: 22.22.2.2
Mask Length: 32
NHLFE ID: 1025
Local Discr: 513 Remote Discr: 513
Source IP: 11.11.1.1 Destination IP: 127.0.0.1
Session State: Up Session Role: Passive
Template Name: -
# Display BFD information for the LSPs to destination 22.22.2.2/32. In this example, tunnel BFD control packet mode is used.
FEC Type: LSP
FEC Info:
Mask Length: 32
NHLFE ID: 1025
Template Name: -
# Display BFD information for MPLS TE tunnel interface Tunnel 1. In this example, BFD control packet mode is used.
<Sysname> display mpls bfd te tunnel 1
FEC Type: TE Tunnel
FEC Info:
Source : 100.1.1.1
Destination: 200.1.1.1
Tunnel ID : 1
LSP ID : 100
NHLFE ID: 1025
Template Name: -
# Display BFD information for MPLS TE tunnel interface Tunnel 1. In this example, tunnel BFD control packet mode is used.
FEC Type: TE Tunnel
FEC Info:
Source : 100.1.1.1
Tunnel ID : 1
LSP ID : 100
NHLFE ID: 1025
Template Name: -
# Display BFD information for MPLS TE tunnel interface Tunnel 1. In this example, BFD echo packet mode is used.
FEC Type: TE Tunnel
FEC Info:
Source : 100.1.1.1
Tunnel ID : 1
LSP ID : 100
NHLFE ID: 1025
Local Discr: 513
Source IP: 11.11.1.1 Destination IP: 200.1.1.1
Session State: Up
Template Name: -
# Display BFD information for MPLS TE tunnel interface Tunnel 1. In this example, tunnel BFD echo packet mode is used.
FEC Type: TE Tunnel
FEC Info:
Source : 100.1.1.1
Tunnel ID : 1
LSP ID : 100
NHLFE ID: 1025
Local Discr: 513
Session State: Up
Template Name: -
Indicates that the LSP or tunnel was detected by tunnel BFD. |
FEC Type |
Type of the FEC detected by BFD: · LSP. · TE Tunnel. · Nil FEC. |
FEC Info |
If the FEC type is LSP, the FEC information includes the destination address and mask length of the FEC. If the FEC type is TE Tunnel, the FEC information includes the source and destination addresses the tunnel, tunnel ID, and LSP ID. If the FEC type is Nil FEC, the FEC information includes the destination address and mask length of the FEC. |
NHLFE ID |
ID of the NHLFE entry. |
Local Discr |
Remote Discr |
Source IP |
Destination IP |
If BFD control packet mode is used, this field displays the destination IP address of the BFD session. At the ingress node, it is an address on subnet 127.0.0.0/8. At the egress node, it is the MPLS LSR ID of the ingress node. If BFD echo packet mode is used, this field displays the destination IP address of the tunnel to be inspected. |
Session State |
Session Role |
Role of the local PE in the BFD session: · Active—Initiator of the BFD session. · Passive—Responder of the BFD session. |
Template Name |
· mpls bfd (for LSP)
· mpls bfd (for TE tunnel)
display mpls sbfd
Use display mpls sbfd to display SBFD information for LSP tunnels, MPLS TE tunnels, or Flex-Algo LSP tunnels.
display mpls sbfd [ flex-algo-lsp [ ipv4 ipv4-address mask-length [ algorithm flex-algo-id-begin [ to flex-algo-id-end ] ] ] | ipv4 ipv4-address mask-length | te tunnel tunnel-number ]
flex-algo-lsp [ ipv4 ipv4-address mask-length [ algorithm flex-algo-id-begin [ to flex-algo-id-end ] ] ]: Displays SBFD information for Flex-Algo LSPs.
· ipv4 ipv4-address mask-length: Specifies the destination IPv4 address of a Flex-Algo LSP. The mask-length argument specifies the mask length of destination IPv4 address, in the range of 0 to 32. If you do not specify this option, the command displays SBFD information for all Flex-Algo LSPs.
· algorithm flex-algo-id-begin [ to flex-algo-id-end ]: Specifies the Flex-Algos used to calculate the LSPs. The flex-algo-id-begin argument represents the start Flex-Algo ID. The flex-algo-id-end argument represents the end Flex-Algo ID. If you do not specify this option, the command displays SBFD information for all Flex-Algo LSPs with the specified destination address.
If you do not specify any parameters, this command displays SBFD information for all LSP tunnels, MPLS TE tunnels, and Flex-Algo LSP tunnels.
# Display SBFD information for the LSPs to destination 22.22.2.2/32.
<Sysname> display mpls sbfd ipv4 22.22.2.2 32
FEC Type: LSP
FEC Info:
Mask Length: 32
NHLFE ID: 1025
Session State: Up
Template Name: -
# Display SBFD information for MPLS TE tunnel interface Tunnel 1.
<Sysname> display mpls sbfd te tunnel 1
FEC Type: TE Tunnel
FEC Info:
Source : 100.1.1.1
Tunnel ID : 1
LSP ID : 100
NHLFE ID: 1025
Session State: Up
Template Name: -
# Display tunnel SBFD information for MPLS TE tunnel interface Tunnel 1.
BFD Info: Tunnel SBFD
FEC Type: TE Tunnel
FEC Info:
Source : 100.1.1.1
Tunnel ID : 1
LSP ID : 100
NHLFE ID: 1025
Session State: Up
Template Name: -
# Display SBFD information for the LSP destination for 1.1.1.9 and calculated by Flex-Algo 130.
<Sysname> display mpls sbfd flex-algo ipv4 1.1.1.9 32 130
FEC Type: Flex-Algo LSP
FEC Info:
Destination: 1.1.1.9
Mask Length: 32
Flex-Algo ID: 130
NHLFE ID: 3
Local Discr: 32769 Remote Discr: 16843017
Source IP: 2.2.2.9 Destination IP: 127.0.0.1
Session State: Up
Template Name: -
BFD Info |
BFD information. This field can only be Tunnel SBFD in the current software version. |
FEC Type |
FEC type detected by SBFD: · LSP. · TE Tunnel. · Flex-Algo LSP. |
FEC Info |
When the FEC type is LSP, the FEC information includes the FEC destination address and the mask length. When the FEC type is TE tunnel, the FEC information includes the tunnel's source address, destination address, and tunnel ID. For a Flex-Algo LSP, the FEC information includes the destination address and mask length, and the Flex-Algo ID used to calculate the LSP. |
Local Discr |
Local discriminator of the SBFD session. |
Remote Discr |
Remote discriminator of the SBFD session. |
Source IP |
Source IP address of the SBFD session, which is the MPLS LSR ID of the local PE. |
Destination IP |
Destination IP address of the SBFD session, which is an address on the 127.0.0.0/8 subnet. |
Session State |
SBFD session state: · Init—SBFD session is in initialization state. · Up—SBFD session is up. · Down—SBFD session is down. |
Template Name |
Name of the SBFD session parameter template. |
Aux Path |
Information of the backup path. |
Aux Path Type |
Type of the backup path, which can be MPLS label stack. If no backup path exists, this field displays a hyphen (-). |
Aux Path Length |
Data length of the backup path. |
· mpls sbfd (for LSP)
· mpls sbfd (for TE tunnel)
mpls bfd (for LSP)
Use mpls bfd to enable BFD for LSPs associated with an FEC.
Use undo mpls bfd to disable BFD for LSPs associated with an FEC.
mpls bfd dest-addr mask-length nexthop nexthop-address discriminator local local-id remote remote-id [ bgp-lsp | ldp-lsp | static-lsp ] [ template template-name ]
undo mpls bfd dest-addr mask-length nexthop nexthop-address
mpls bfd dest-addr mask-length nexthop nexthop-address [ echo | nil-fec ] [ template template-name ] [ source-ip ipv4-address ]
mpls bfd dest-addr mask-length [ echo ] [ template template-name ] [ source-ip ipv4-address ]
BFD is not used to verify LSP connectivity for an FEC.
dest-addr mask-length: Specifies an FEC by a destination IP address and mask length. The mask length is in the range of 0 to 32.
nexthop nexthop-address: Specifies the next hop address of the FEC. If you specify the FEC next hop, BFD verifies the specified LSP. If you do not specify a next hop, BFD verifies all LSPs for the FEC.
discriminator: Specifies discriminator values for the BFD session.
local local-id: Specifies the local discriminator value for the BFD session. The value range for the local-id argument is 1 to 32768.
bgp-lsp: Specifies BGP LSP.
ldp-lsp: Specifies LDP LSP.
static-lsp: Specifies static LSP.
echo: Specifies the BFD echo packet mode. If you do not specify this keyword, the BFD control packet mode is used to verify LSP connectivity.
nil-fec: Encapsulates the Nil FEC in MPLS echo request packets when BFD control packet mode is used to detect LSPs.
template template-name: Specifies a BFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a template, BFD uses the multihop BFD session parameters configured in system view.
source-ip ipv4-address: Specifies the source IP address of the BFD session. If you do not specify this option, the device uses the MPLS LSR ID as the source address of the BFD session.
After you enable BFD for MPLS and execute the mpls bfd command, the device creates a BFD session for each LSP associated with the specified FEC. When an LSP fails, BFD can quickly detect the failure and notify the device to take an action, such as switching traffic to the backup LSP.
A BFD session for LSP connectivity verification can be established in one of the following modes:
· Static mode—Specify the local and remote discriminator values by using the discriminator keyword in the mpls bfd command. You must enable BFD for MPLS and configure the mpls bfd command on both the local and remote devices. Make sure the discriminators configured on the local device match those configured on the remote device. A static BFD session verifies connectivity of a pair of LSPs in opposite directions between two devices.
· Dynamic mode—If you do not specify local and remote discriminators, the system automatically runs MPLS ping to negotiate the discriminator values. You must enable BFD for MPLS on both the local and remote devices, but the mpls bfd command is not needed on the remote PE. A dynamic BFD session verifies the connectivity of a unidirectional LSP from the local device to the remote device.
The source address of the BFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring BFD for an LSP tunnel, make sure a route is available on the remote device to reach the source address of the BFD session.
To enable the BFD echo packet mode, you must first execute the bfd echo-source-ip command on the local device to specify a source IP address for BFD echo packets.
You must specify the same BFD mode (BFD control or echo packet mode) for the LSPs (specified by next hop addresses) of the same FEC.
If you do not specify the bgp-lsp, ldp-lsp, or static-lsp keyword when executing the mpls bfd command, BFD detects the LSPs in the static LSP, LDP LSP and BGP LSP order. The BFD session is up as long as one LSP is operating correctly. The BFD session goes down when all LSPs fail.
# Use BFD to verify the connectivity of the LSPs to destination 22.22.2.2/32.
[Sysname] mpls bfd enable
[Sysname] mpls bfd 22.22.2.2 32
# Use BFD to verify the connectivity of the LSP with destination 22.22.2.2/32 and next hop 12.0.0.2.
[Sysname] mpls bfd 22.22.2.2 32 nexthop 12.0.0.2
# Use BFD to verify the connectivity of the LSP with destination 22.22.2.2/32 and next hop 12.0.0.2. Set both the local and remote discriminators to 1, and use BFD session parameter template test.
[Sysname] mpls bfd 22.22.2.2 32 nexthop 12.0.0.2 discriminator local 1 remote 1 template test
bfd echo-source-ip (High Availability Command Reference)
display mpls bfd
mpls bfd enable
Use mpls bfd to enable BFD on an MPLS TE tunnel interface.
Use undo mpls bfd to restore the default.
mpls bfd discriminator local local-id remote remote-id [ template template-name ]
mpls bfd [ echo ] [ template template-name ] [ backup-path template template-name ] [ source-ip ipv4-address ]
undo mpls bfd
BFD is not enabled on an MPLS TE tunnel interface to verify the tunnel connectivity.
Tunnel interface view
local local-id: Specifies the local discriminator value for the BFD session, in the range of 1 to 32768.
echo: Enables the BFD echo packet mode.
template template-name: Specifies a BFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a template, BFD control packet mode uses the multihop BFD session parameters configured in system view, and BFD echo packet mode uses the system default BFD session parameters.
backup-path template template-name: Creates a BFD session for the MPLS TE backup tunnel, and specifies a BFD session parameter template for the MPLS TE backup tunnel. The template-name argument indicates the template name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the device does not create a BFD session for the backup tunnel, and it creates a BFD session only for the primary tunnel.
After you enable BFD for MPLS and execute the mpls bfd command with the backup-path template option, the device creates a BFD session for the tunnel's primary and backup CRLSPs, respectively. When the primary CRLSP fails, BFD can quickly detect the failure and notify the device to take an action, such as switching traffic to the backup CRLSP. If the two CRLSPs fail at the same time, the device puts the MPLS TE tunnel to down state so the tunnel does not receive traffic.
If you specify templates for both the primary and backup CRLSPs, specify greater interval settings for the template of the backup CRLSP than the primary CRLSP. This rule ensures that the BFD session for the new working CRLSP is up after a primary/backup CRLSP switchover.
The source address of the BFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring BFD for an MPLS TE tunnel, make sure a route is available on the remote device to reach the source address of the BFD session.
When BFD control packet mode is used, a BFD session can be established in one of the following modes:
· Static mode—Specify the local and remote discriminators by using the discriminator keyword in the mpls bfd command. You must execute the mpls bfd enable and mpls bfd commands on both the local and remote devices. Make sure the local discriminator and remote discriminator on the local device are the same as the remote discriminator and local discriminator on the remote device, respectively. A static BFD session verifies the connectivity of a pair of MPLS TE tunnels in opposite directions between two devices.
· Dynamic mode—If you do not specify local and remote discriminators, the system automatically runs MPLS ping to negotiate the discriminator values. You must execute the mpls bfd enable command on both the local and remote devices, but the mpls bfd command is not needed on the remote device. A dynamic BFD session verifies the connectivity of a unidirectional MPLS TE tunnel from the local device to the remote device.
If you do not specify the echo keyword, this command enables the BFD control packet mode to verify the MPLS TE tunnel connectivity.
# Enable the BFD control packet mode for MPLS TE tunnel interface Tunnel 1, and use the BFD session parameter template test.
[Sysname] interface tunnel 1 mode mpls-te
[Sysname-Tunnel1] mpls bfd template test
# Enable the BFD control packet mode for MPLS TE tunnel interface Tunnel 1, and set the local and remote discriminators both to 1.
[Sysname-Tunnel1] mpls bfd discriminator local 1 remote 1
# Enable the BFD echo packet mode for MPLS TE tunnel interface Tunnel 1.
[Sysname-Tunnel1] mpls bfd echo
display mpls bfd
mpls bfd enable
Use mpls bfd backup detect-multiplier to set the BFD detection time multiplier for an MPLS TE backup tunnel.
Use undo mpls bfd backup detect-multiplier to restore the default.
mpls bfd backup detect-multiplier value
undo mpls backup bfd detect-multiplier
The BFD detection time multiplier is not set for an MPLS TE backup tunnel.
value: Specifies a detection time multiplier, which is the maximum number of consecutive BFD packets that can be discarded. The value range for this argument is 3 to 50.
In control packet mode of BFD for an MPLS TE tunnel:
· If the mpls bfd backup detect-multiplier and mpls bfd backup-path template commands are both executed in the tunnel interface view, the mpls bfd backup-path template command's configuration takes effect.
· If that two commands are both not executed in the tunnel interface view, the bfd multi-hop detect-multiplier command's configuration is used.
In echo packet mode of BFD for an MPLS TE tunnel:
· If that two commands are both not executed in the tunnel interface view, the bfd detect-multiplier command's configuration is used.
# Set the BFD detection time multiplier to 3 for the backup tunnel of MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls bfd backup detect-multiplier 3
bfd detect-multiplier (High Availability Command Reference)
bfd multi-hop detect-multiplier (High Availability Command Reference)
display mpls bfd
mpls bfd enable
Use mpls bfd backup min-receive-interval to set the minimum interval for an MPLS TE backup tunnel to receive BFD packets.
Use undo mpls bfd backup min-receive-interval to restore the default.
mpls bfd backup min-receive-interval interval
The minimum interval for receiving BFD packets is not set for an MPLS TE backup tunnel.
interval: Specifies the minimum interval for receiving BFD packets, in milliseconds. The value range varies by MPU model:
MPU model |
Value range |
MSU-100 |
10 to 10000 |
MSU-200 |
10 to 10000 |
MSU-400-G |
5 to 10000 |
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving rate of the local end. If the receiving rate is exceeded, the peer end dynamically adjusts the BFD packet sending interval to the minimum receiving interval of the local end.
· If the mpls bfd backup min-receive-interval and mpls bfd backup-path template commands are both executed in the tunnel interface view, the mpls bfd backup-path template command's configuration takes effect.
· If that two commands are both not executed in the tunnel interface view, the bfd multi-hop min-receive-interval command's configuration is used.
· If that two commands are both not executed in the tunnel interface view, the bfd min-echo-receive-interval command's configuration is used.
# Set the minimum BFD packet receiving interval to 550 milliseconds for the backup tunnel of MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls bfd backup min-receive-interval 550
bfd min-echo-receive-interval (High Availability Command Reference)
bfd multi-hop min-receive-interval (High Availability Command Reference)
display mpls bfd
mpls bfd enable
Use mpls bfd backup min-transmit-interval to set the minimum interval for an MPLS TE backup tunnel to transmit BFD packets.
Use undo mpls bfd backup min-transmit-interval to restore the default.
mpls bfd backup min-transmit-interval interval
The minimum interval for transmitting BFD packets is not set for an MPLS TE backup tunnel.
interval: Specifies the minimum interval for transmitting BFD packets, in milliseconds. The value range varies by MPU model.
MPU model |
Value range |
MSU-100 |
10 to 10000 |
MSU-200 |
10 to 10000 |
MSU-400-G |
5 to 10000 |
Use this command to prevent the BFD packet sending rate from exceeding the packet receiving rate of the peer end.
The actual BFD packet transmitting interval on the local end is the greater value between the following values:
· Minimum interval for transmitting BFD packets on the local end.
· Minimum interval for receiving BFD packets on the peer end.
· If the mpls bfd backup min-transmit-interval and mpls bfd backup-path template commands are both executed in the tunnel interface view, the mpls bfd backup-path template command's configuration takes effect.
· If that two commands are both not executed in the tunnel interface view, the bfd multi-hop min-transmit-interval command's configuration is used.
In echo packet mode of BFD for an MPLS TE tunnel, the mpls bfd backup min-transmit-interval command does not take effect.
# Set the minimum BFD packet transmitting interval to 450 milliseconds for the backup tunnel of MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls bfd backup min-transmit-interval 450
bfd multi-hop min-transmit-interval (High Availability Command Reference)
display mpls bfd
mpls bfd enable
mpls bfd detect-multiplier
Use mpls bfd detect-multiplier to set the BFD detection time multiplier for an MPLS TE primary tunnel.
Use undo mpls bfd detect-multiplier to restore the default.
mpls bfd detect-multiplier value
The BFD detection time multiplier is not set for an MPLS TE primary tunnel.
· If the mpls bfd detect-multiplier and mpls bfd template commands are both executed in the tunnel interface view, the mpls bfd backup-path template command's configuration takes effect.
· If the mpls bfd detect-multiplier and mpls bfd template commands are both executed in the tunnel interface view, the mpls bfd template command's configuration takes effect.
# Set the BFD detection time multiplier to 3 for the primary tunnel of MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls bfd detect-multiplier 3
display mpls bfd
mpls bfd enable
mpls bfd enable
Use mpls bfd enable to enable BFD for MPLS.
Use undo mpls bfd enable to disable BFD for MPLS.
mpls bfd enable
BFD for MPLS is disabled.
To use BFD to verify LSP, PW, or TE tunnel connectivity, you must use the mpls bfd enable command to enable BFD for MPLS. Otherwise, the BFD session cannot be established after you execute the following commands:
· mpls bfd (for LSP).
· mpls bfd (for TE tunnel).
· mpls sbfd (for LSP).
· mpls sbfd (for TE tunnel).
# Enable BFD for MPLS.
mpls bfd min-receive-interval
Use mpls bfd min-receive-interval to set the minimum interval for an MPLS TE primary tunnel to receive BFD packets.
Use undo mpls bfd min-receive-interval to restore the default.
mpls bfd min-receive-interval interval
The minimum interval for receiving BFD packets is not set for an MPLS TE primary tunnel.
MPU model |
Value range |
MSU-100 |
10 to 10000 |
MSU-200 |
10 to 10000 |
MSU-400-G |
5 to 10000 |
· If the mpls bfd min-receive-interval and mpls bfd template commands are both executed in the tunnel interface view, the mpls bfd template command's configuration takes effect.
# Set the minimum BFD packet receiving interval to 550 milliseconds for the primary tunnel of MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls bfd min-receive-interval 550
display mpls bfd
mpls bfd enable
Use mpls bfd min-transmit-interval to set the minimum interval for an MPLS TE primary tunnel to transmit BFD packets.
Use undo mpls bfd min-transmit-interval to restore the default.
mpls bfd min-transmit-interval interval
The minimum interval for transmitting BFD packets is not set for an MPLS TE primary tunnel.
MPU model |
Value range |
MSU-100 |
10 to 10000 |
MSU-200 |
10 to 10000 |
MSU-400-G |
5 to 10000 |
· If the mpls bfd min-transmit-interval and mpls bfd template commands are both executed in the tunnel interface view, the mpls bfd template command's configuration takes effect.
In echo packet mode of BFD for an MPLS TE tunnel, the mpls bfd min-transmit-interval command does not take effect.
# Set the minimum BFD packet transmitting interval to 450 milliseconds for the primary tunnel of MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls bfd min-transmit-interval 450
display mpls bfd
mpls bfd enable
mpls bfd passive delete-delay
Use mpls bfd passive delete-delay to configure the deletion delay time for a dynamic passive-mode BFD session after the BFD session goes down.
Use undo mpls bfd passive delete-delay to restore the default.
mpls bfd passive delete-delay delay-time
A dynamic passive-mode BFD session will be deleted immediately when it goes down.
delay-time: Specifies the deletion delay time, in the range of 0 to 3600 seconds. Setting the delay to 0 seconds means to delete the BFD session immediately when the session goes down.
To avoid frequent re-establishment of BFD sessions in case of BFD session state flapping, you can use this command to delay the deletion of dynamic passive-mode BFD sessions in down state.
When the active end establishes a dynamic MPLS BFD session on the primary path to the passive end, the source address of MPLS echo request packets is the outgoing interface address of the primary path. When the primary path fails, the active end establishes the BFD session by using the backup path. The source address of MPLS echo request packets is the outgoing interface address of the backup path.
When the primary path recovers, the active end re-establishes the BFD session to the passive end through the outgoing interface of the primary path. On the active end, only one BFD session exists because the destination addresses of the old and new BFD sessions are the same. On the passive end, two BFD sessions exist because it receives MPLS echo request packets with different source addresses. Because the passive end currently receives MPLS echo request packets from the primary path, so the corresponding BFD session is up, and the other BFD session is down. The passive end uses the two BFD sessions to negotiate with the only BFD session of the active end, causing BFD session flapping on the active end.
To resolve this issue, you can use this command to set the BFD session deletion delay on the passive end to 0 seconds. A dynamically created BFD session will be deleted immediately when it goes down. Thereby, only the BFD session in up state exists on the passive end, preventing BFD session flapping on the active end.
# Configure the device to delete a dynamic passive-mode BFD session 10 seconds after the session goes down.
[Sysname] mpls bfd passive delete-delay 10
mpls bfd enable
mpls bfd up-delay
Use mpls bfd up-delay to set the delay time for advertising MPLS BFD/SBFD session up events.
Use undo mpls bfd up-delay to restore the default.
mpls bfd up-delay delay-time
The delay time for advertising MPLS BFD/SBFD session up events is five seconds.
delay-time: Specifies the delay time for advertising MPLS BFD/SBFD session up events. The value range for this argument is 0 to 1200 seconds. If you set the value to 0, MPLS BFD/SBFD session up events will be advertised without delay.
Application scenarios
When an MPLS BFD/SBFD session state changes, the device advertises the change event to applications. If the session state flaps frequently, the applications will receive change events frequently, consuming system resources. To resolve this issue, you can execute this command to set a delay time for advertising MPLS BFD/SBFD session up events.
Operating mechanism
After an MPLS BFD/SBFD session comes up, the device advertises the up event to applications only when the following conditions are met:
· The MPLS BFD/SBFD session state does not change within the delay time.
· The delay timer expires.
This command takes effect on all MPLS BFD and MPLS SBFD sessions.
Set an appropriate delay time based on the network condition. If the delay time is too long, the applications cannot detect link recovery or establishment in time. If the delay time is too short, the applications will receive BFD/SBFD session state change events frequently.
# Set the delay time for advertising MPLS BFD/SBFD session up events to one second.
[Sysname] mpls bfd up-delay 1
Use mpls bfd trigger tunnel-down to configure the capability of MPLS BFD to trigger tunnel-down.
Use undo mpls bfd trigger tunnel-down to restore the default.
mpls bfd trigger tunnel-down { disable | enable }
undo mpls bfd trigger tunnel-down { disable | enable }
The configuration in MPLS TE view is used.
disable: Disables MPLS BFD from triggering tunnel-down.
enable: Enables MPLS BFD to trigger tunnel-down.
If you configure static MPLS BFD in a primary/backup scenario, the device creates a BFD session for only the primary path. During a primary/backup switchover, the BFD session of the primary path might go down if a large number of MPLS TE tunnel interfaces exist, which results in traffic interruption. To resolve this issue, execute the mpls bfd trigger tunnel-down disable command to disable MPLS BFD from triggering tunnel-down. Then, the tunnel interface state remains unchanged when the BFD session of the MPLS TE tunnel interface goes down.
As a best practice, execute the mpls tunnel-bfd command to enable tunnel BFD on an MPLS TE tunnel interface after you disable MPLS BFD from triggering tunnel-down on the interface.
You can execute the mpls bfd trigger tunnel-down command in both MPLS TE view and MPLS TE tunnel interface view. The configuration in MPLS TE view takes effect on all MPLS TE tunnel interfaces. The configuration in MPLS TE tunnel interface view takes effect on only the current MPLS TE tunnel interface. For an MPLS TE tunnel interface, the configuration in MPLS TE tunnel interface view takes precedence over the configuration in MPLS TE view.
# Enable MPLS BFD to trigger tunnel-down on interface Tunnel 1.
[Sysname-Tunnel1] mpls bfd trigger tunnel-down enable
Use mpls bfd trigger tunnel-down enable to enable MPLS BFD to trigger tunnel-down.
Use undo mpls bfd trigger tunnel-down enable to disable MPLS BFD from triggering tunnel-down.
MPLS BFD is able to trigger tunnel-down. An MPLS TE tunnel interface goes down when its BFD session goes down.
MPLS TE view
If you configure static MPLS BFD in a primary/backup scenario, the device creates a BFD session for only the primary path. During a primary/backup switchover, the BFD session of the primary path might go down if a large number of MPLS TE tunnel interfaces exist, which results in traffic interruption. To resolve this issue, execute the undo mpls bfd trigger tunnel-down enable command to disable MPLS BFD from triggering tunnel-down. Then, the tunnel interface state remains unchanged when the BFD session of the MPLS TE tunnel interface goes down.
You can execute the mpls bfd trigger tunnel-down enable command in both MPLS TE view and MPLS TE tunnel interface view. The configuration in MPLS TE view takes effect on all MPLS TE tunnel interfaces. The configuration in MPLS TE tunnel interface view takes effect on only the current MPLS TE tunnel interface. For an MPLS TE tunnel interface, the configuration in MPLS TE tunnel interface view takes precedence over the configuration in MPLS TE view.
# Enable MPLS BFD to trigger tunnel-down.
[Sysname] mpls te
[Sysname-te] mpls bfd trigger tunnel-down enable
Use mpls periodic-tracert to enable periodic tracert of LSPs for an FEC.
Use undo mpls periodic-tracert to disable periodic tracert of LSPs for an FEC.
mpls periodic-tracert dest-addr mask-length [ -a source-ip | -exp exp-value | -h ttl-value | -m wait-time | -rtos tos-value | -t time-out | -u retry-attempt | fec-check ] *
undo mpls periodic-tracert dest-addr mask-length
Periodic tracert of LSPs for an FEC is disabled.
-a source-ip: Specifies the source address for MPLS echo request packets. If you do not specify this option, the device uses the MPLS LSR ID as the source address for MPLS echo requests.
-exp exp-value: Specifies the EXP value for MPLS echo request packets, in the range of 0 to 7. The default is 0.
-h ttl-value: Specifies the maximum TTL value for MPLS echo request packets (the maximum number of hops to be inspected). The value range for the ttl-value argument is 1 to 255, and the default is 30.
-m wait-time: Specifies the interval at which tracert is performed. The value range is 15 to 120 minutes. The default is 60 minutes.
-rtos tos-value: Specifies the ToS value in the IP header of an MPLS echo reply packet. The value range is 0 to 7, and the default value is 6.
-t time-out: Specifies the timeout interval for the reply to an MPLS echo request. The value range is 0 to 65535 milliseconds, and the default is 2000 milliseconds.
-u retry-attempt: Specifies the maximum number of retransmissions of an MPLS echo request if no reply is received. The value range is 1 to 9, and the default value is 3.
fec-check: Checks the FEC stack at transit nodes.
The periodic MPLS tracert feature automatically traces an LSP tunnel at intervals. It locates errors on the LSP tunnel, verifies the consistency of the data plane and control plane, and records the detected errors into system logs. You can check the logs to monitor LSP connectivity.
If both BFD and periodic MPLS tracert are configured for an LSP, both feature take effect. When periodic MPLS tracert detects a data plane failure or an inconsistency between data plane and control plane, the device performs the following operations:
1. Deletes the BFD session for the LSP.
2. Re-establishes the BFD session based on the control plane.
Before you execute this command, execute the mpls bfd enable command.
# Enable periodic tracert for LSPs to destination 11.11.1.1/32.
[Sysname] mpls periodic-tracert 11.11.1.1 32
mpls bfd enable
mpls bfd (for LSP)
mpls sbfd (for LSP)
Use mpls sbfd to enable SBFD for LSPs associated with an FEC.
Use undo mpls sbfd to disable SBFD for LSPs associated with an FEC.
mpls sbfd dest-addr mask-length [ nexthop nexthop-address ] [ remote remote-id ] [ template template-name ] [ source-ip ipv4-address ]
undo mpls sbfd dest-addr mask-length [ nexthop nexthop-address ]
SBFD is not used to verify LSP connectivity for an FEC.
nexthop nexthop-address: Specifies the next hop address of the FEC. If you specify the FEC next hop, SBFD verifies the specified LSP. If you do not specify a next hop, BFD verifies all LSPs for the FEC.
remote remote-id: Specifies the remote discriminator value for the SBFD session, in the range of 1 to 4294967295. If you do not specify this option, the SBFD session uses the FEC destination address as the remote discriminator.
template template-name: Specifies an SBFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a template, SBFD uses the multihop SBFD session parameters configured in system view.
source-ip ipv4-address: Specifies the source IP address of the SBFD session. If you do not specify this option, the device uses the MPLS LSR ID as the source address of the SBFD session.
Execute this command on the SBFD session initiator. After you enable BFD for MPLS and execute this command, the initiator creates an SBFD session for each LSP associated with the specified FEC. When an LSP fails, SBFD can quickly detect the failure and notify the initiator to take an action, such as switching traffic to the backup LSP.
An SBFD session can be established in static mode.
· If you specify a remote discriminator in the mpls sbfd command, the device uses the specified remote discriminator to establish a static SBFD session.
· If you do not specify a remote discriminator in the mpls sbfd command, the device uses the FEC destination address as the remote discriminator to establish a static SBFD session.
The remote discriminator specified by the mpls sbfd command on the initiator must be the same as the local discriminator specified by the sbfd local-discriminator command on the reflector. Otherwise, the reflector does not send responses to the initiator.
The source address of the SBFD session can be specified manually, or if not specified, is the MPLS LSR ID of the initiator. Before configuring SBFD for an LSP tunnel, make sure a route is available on the reflector to reach the source address of the SBFD session.
# Use SBFD to verify the connectivity of the LSPs to destination 22.22.2.2/32.
[Sysname] mpls sbfd 22.22.2.2 32 remote 1
# Use SBFD to verify the connectivity of the LSP with destination 22.22.2.2/32 and next hop 12.0.0.2. Set the remote discriminator to 1 and use SBFD session parameter template test.
[Sysname] mpls sbfd 22.22.2.2 32 nexthop 12.0.0.2 remote 1 template test
display mpls sbfd
mpls bfd enable
sbfd local-discriminator (High Availability Command Reference)
Use mpls sbfd to enable SBFD on an MPLS TE tunnel interface.
Use undo mpls sbfd to restore the default.
mpls sbfd [ echo | remote remote-id ] [ template template-name ] [ backup-path template template-name ] [ source-ip ipv4-address ]
undo mpls sbfd
SBFD is not used to verify tunnel connectivity on an MPLS TE tunnel interface.
echo: Enables the SBFD echo packet mode to verify the connectivity of a bidirectional MPLS TE tunnel.
remote remote-id: Specifies the remote discriminator of the SBFD session, in the range of 1 to 4294967295. If you do not specify this option, the SBFD session uses the tunnel's remote IP address as the remote discriminator.
template template-name: Specifies an SBFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a template:
· For SBFD sessions in control packet mode, the device uses the multihop BFD session parameters configured in system view.
· For SBFD sessions in echo packet mode, the device uses the default SBFD session parameters.
backup-path template template-name: Creates an SBFD session for the MPLS TE backup tunnel, and specifies the SBFD session parameter template. The template-name argument indicates the template name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the device does not establish an SBFD session for the backup tunnel.
Execute this command on the initiator of an SBFD session.
After you enable BFD for MPLS and execute the mpls sbfd command, the device creates an SBFD session for the MPLS TE tunnel. When the MPLS TE tunnel fails, SBFD can quickly detect the failure and notify the device to take an action, such as switching traffic to the backup tunnel.
When SBFD control packet mode is used, an SBFD session can be established in static mode.
· If you do not specify a remote discriminator in the mpls sbfd command, the device uses the tunnel's remote IP address as the remote discriminator to establish a static SBFD session.
The remote discriminator specified by the mpls sbfd command on the initiator must be the same as the local discriminator specified by the sbfd local-discriminator command on the reflector. Otherwise, the reflector will not respond to the initiator.
The source address of the SBFD session can be specified manually, or if not specified, is the MPLS LSR ID of the initiator. Before configuring SBFD for an MPLS TE tunnel, make sure a route is available on the reflector to reach the source address of the SBFD session.
If you do not specify the echo keyword, the system uses SBFD control packets to verify the connectivity of MPLS TE tunnels.
# Enable SBFD to verify tunnel connectivity on MPLS TE tunnel interface Tunnel 1, set the remote discriminator to 1, and use SBFD session parameter template test.
[Sysname-Tunnel1] mpls sbfd remote 1 template test
display mpls bfd
mpls bfd enable
mpls sbfd flex-algo-lsp
Use mpls sbfd flex-algo-lsp to enable SBFD for Flex-Algo LSPs.
Use undo mpls sbfd flex-alg-lsp to disable SBFD for SBFD for Flex-Algo LSPs.
mpls sbfd flex-algo-lsp dest-address mask-length algorithm flex-algo-id-begin [ to flex-algo-id-end ] [ template template-name ]
undo mpls sbfd flex-algo-lsp dest-address mask-length algorithm flex-algo-id-begin [ to flex-algo-id-end ]
SBFD is not used to verify the Flex-Algo LSP connectivity.
dest-addr: Destination address of an Flex-Algo LSP.
mask-length: Mask length of the destination address, which is 32.
algorithm flex-algo-id-begin [ to flex-algo-id-end ]: Specifies the Flex-Algos used to calculate LSPs. The flex-algo-id-begin argument represents the start Flex-Algo ID. The flex-algo-id-end argument represents the end Flex-Algo ID.
template template-name: Specifies an SBFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a template, SBFD uses the multihop SBFD session settings configured in system view.
After you execute the mpls bfd enable command and then the mpls sbfd flex-algo-lsp command, the device creates an SBFD session for the LSP destined for the specified address and calculated by the specified Flex-Algos. When the LSP fails, SBFD can quickly detect the failure and notify the device to take an action, such as switching traffic to the backup LSP.
An SBFD session can be established in static mode. The device uses the Flex-Algo LSP's destination address as the remote discriminator to establish a static SBFD session.
The destination address specified by the mpls sbfd flex-algo-lsp command on the initiator must be the same as the local discriminator specified by the sbfd local-discriminator command on the reflector. Otherwise, the reflector will not respond to the initiator.
The source address of the SBFD session is the MPLS LSR ID of the local device. Before configuring SBFD for LSPs, perform the following tasks:
· Configure an MPLS LSR ID for the local device.
· Make sure a route is available on the remote device to reach the MPLS LSR ID.
# Use SBFD to verify the connectivity of the LSP destined for 22.22.2.2/32 and calculated by Flex-Algo 128.
[Sysname] mpls sbfd flex-algo-lsp 22.22.2.2 32 algorithm 128
display mpls sbfd
mpls bfd enable
mpls te bfd detect-multiplier
Use mpls te bfd detect-multiplier to set the BFD detection time multiplier for PCE-initiated tunnels.
Use undo mpls te bfd detect-multiplier to restore the default.
mpls te bfd detect-multiplier value
The BFD detection time multiplier is not set for PCE-initiated tunnels. The BFD detection time multiplier set by the bfd multi-hop detect-multiplier command applies.
The device sends BFD packets to a peer periodically. If the device does not receive BFD packets from the peer within the actual detection interval, it determines that the session is down. The actual detection interval of the sender is the detection time multiplier of the receiver × the actual sending interval of the receiver.
This command takes effect only on BFD sessions created by the mpls te bfd enable pce-initiated-lsp command.
# Set the BFD detection time multiplier to 3 for PCE-initiated tunnels.
[Sysname] mpls te bfd detect-multiplier 3
Use mpls te bfd enable pce-initiated-lsp to enable BFD for PCE-initiated tunnels.
Use undo mpls te bfd enable pce-initiated-lsp to disable BFD for PCE-initiated tunnels.
mpls te bfd enable pce-initiated-lsp rsvp
undo mpls te bfd enable pce-initiated-lsp rsvp
BFD for PCE-initiated tunnels is not enabled.
rsvp: Specifies the PCE-initiated RSVP-TE tunnels.
This command enables the device to create a BFD session for each PCE-initiated primary RSVP-TE or SR tunnel to detect the primary tunnel connectivity.
When a primary RSVP-TE tunnel fails, BFD can quickly detect the failure and switches traffic to the backup tunnel to reduce packet loss.
If you execute both the mpls te bfd enable pce-initiated-lsp command and the mpls bfd command for a PCE-initiated tunnel, the mpls bfd command takes effect on the tunnel.
# Enable BFD for PCE-initiated RSVP-TE tunnels.
[Sysname] mpls te bfd enable pce-initiated-lsp rsvp
mpls bfd (for TE Tunnel)
Use mpls te bfd min-receive-interval to set the minimum interval for PCE-initiated tunnels to receive BFD packets.
Use undo mpls te bfd min-receive-interval to restore the default.
mpls te bfd min-receive-interval interval
The minimum interval for receiving BFD packets is not set for PCE-initiated tunnels. The interval set by the bfd multi-hop min-receive-interval command applies.
MPU model |
Value range |
MSU-100 |
10 to 10000 |
MSU-200 |
10 to 10000 |
MSU-400-G |
5 to 10000 |
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving rate of the local end. If the receiving rate is exceeded, the peer end dynamically adjusts the BFD packet transmitting interval to the minimum receiving interval of the local end.
# Set the minimum BFD packet receiving interval of PCE-initiated tunnels to 30 milliseconds.
[Sysname] mpls te bfd min-receive-interval 30
Use mpls te bfd min-transmit-interval to set the minimum interval for PCE-initiated tunnels to transmit BFD packets.
Use undo mpls te bfd min-transmit-interval to restore the default.
mpls te bfd min-transmit-interval interval
The minimum interval for transmitting BFD packets is not set for PCE-initiated tunnels. The interval set by the bfd multi-hop min-transmit-interval command applies.
MPU model |
Value range |
MSU-100 |
10 to 10000 |
MSU-200 |
10 to 10000 |
MSU-400-G |
5 to 10000 |
# Set the minimum BFD packet transmitting interval of PCE-initiated tunnels to 30 milliseconds.
[Sysname] mpls te bfd min-transmit-interval 30
Use mpls te tunnel-bfd detect-multiplier to set the tunnel BFD detection time multiplier for PCE-initiated tunnels.
Use undo mpls te tunnel-bfd detect-multiplier to restore the default.
mpls te tunnel-bfd detect-multiplier value
The tunnel BFD detection time multiplier is not set for PCE-initiated tunnels. The multiplier set by the bfd multi-hop detect-multiplier command applies.
This command takes effect only on BFD sessions created by the mpls te tunnel-bfd enable command.
# Set the tunnel BFD detection time multiplier to 3 for PCE-initiated tunnels.
[Sysname] mpls te tunnel-bfd detect-multiplier 3
Use mpls te tunnel-bfd enable pce-initiated-lsp to enable tunnel BFD for PCE-initiated tunnels.
Use undo mpls te tunnel-bfd enable pce-initiated-lsp to disable tunnel BFD for PCE-initiated tunnels.
mpls te tunnel-bfd enable pce-initiated-lsp rsvp
undo mpls te tunnel-bfd enable pce-initiated-lsp rsvp
Tunnel BFD for PCE-initiated tunnels is not enabled.
This command enables the device to create a tunnel BFD session for each PCE-initiated RSVP-TE tunnel to detect the tunnel connectivity.
A tunnel BFD session detects the primary path and all its backup paths of a PCE-initiated RSVP-TE tunnel. The BFD session remains in up state as long as one of the paths is available. When all the primary and backup paths fail, the BFD session is placed to down state. BFD can quickly detect the failure and trigger another protection measure (such as MPLS L3VPN FRR) to switch traffic to an available forwarding path.
If you execute both the mpls te tunnel-bfd enable command and the mpls tunnel-bfd command for a PCE-initiated tunnel, the mpls tunnel-bfd command takes effect on the tunnel.
# Enable tunnel BFD for PCE-initiated RSVP-TE tunnels.
[Sysname] mpls te tunnel-bfd enable pce-initiated-lsp rsvp
mpls tunnel-bfd (for TE Tunnel)
Use mpls te tunnel-bfd min-receive-interval to set the tunnel BFD minimum receiving interval for PCE-initiated tunnels.
Use undo mpls te tunnel-bfd min-receive-interval to restore the default.
mpls te tunnel-bfd min-receive-interval interval
The tunnel BFD minimum receiving interval is not set for PCE-initiated tunnels. The interval set by the bfd multi-hop min-receive-interval command applies.
MPU model |
Value range |
MSU-100 |
10 to 10000 |
MSU-200 |
10 to 10000 |
MSU-400-G |
5 to 10000 |
# Set the tunnel BFD minimum receiving interval to 30 milliseconds for PCE-initiated tunnels.
[Sysname] mpls te tunnel-bfd min-receive-interval 30
Use mpls te tunnel-bfd min-transmit-interval to set the tunnel BFD minimum transmitting interval for PCE-initiated tunnels.
Use undo mpls te tunnel-bfd min-transmit-interval to restore the default.
mpls te tunnel-bfd min-transmit-interval interval
The tunnel BFD minimum transmitting interval is not set for PCE-initiated tunnels. The interval set by the bfd multi-hop min-transmit-interval command applies.
MPU model |
Value range |
MSU-100 |
10 to 10000 |
MSU-200 |
10 to 10000 |
MSU-400-G |
5 to 10000 |
[Sysname] mpls te tunnel-bfd min-transmit-interval 30
mpls tunnel-bfd (for LSP)
Use mpls tunnel-bfd to enable tunnel BFD for LSPs associated with an FEC.
Use undo mpls tunnel-bfd to disable tunnel BFD for LSPs associated with an FEC.
mpls tunnel-bfd dest-addr mask-length discriminator local local-id remote remote-id [ bgp-lsp | ldp-lsp | static-lsp ] [ template template-name ]
mpls tunnel-bfd dest-addr mask-length [ echo | nil-fec ] [ template template-name ] [ source-ip ipv4-address ]
undo mpls tunnel-bfd dest-addr mask-length
Tunnel BFD is not used to verify LSP connectivity for an FEC.
The mpls bfd command can detect only the primary LSP failure. When the primary LSP fails, BFD can quickly detect the failure and notify the device to switch traffic to the backup LSP. When both the primary and backup LSPs fail, the BFD detection mechanism fails. Traffic is lost until another mechanism detects the failures and triggers a traffic protection measure (such as MPLS L3VPN ECMP route based load balancing and FRR) to take effect.
To resolve this issue, you can execute the mpls tunnel-bfd command to configure tunnel BFD, which detects failures on the primary LSP and all the backup LSPs. When both the primary LSP and current backup LSP fail, tunnel BFD can quickly detect the failures and trigger a traffic protection measure to switch traffic to an available backup LSP.
The source address of the BFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring tunnel BFD for an LSP tunnel, make sure a route is available on the remote device to reach the source address of the BFD session.
When BFD control packet mode is used to verify LSP connectivity, a BFD session can be established in one of the following modes:
· Static mode—Specify the local and remote discriminator values by using the discriminator keyword in the mpls tunnel-bfd command. You must enable BFD for MPLS and execute the mpls tunnel-bfd command on both the local and remote devices. Make sure the discriminators configured on the local device match those configured on the remote device. A static BFD session verifies connectivity of a pair of LSPs in opposite directions between two devices.
· Dynamic mode—If you do not specify local and remote discriminators, the system automatically runs MPLS ping to negotiate the discriminator values. You must enable BFD for MPLS on both the local and remote devices, but the mpls tunnel-bfd command is not needed on the remote device. A dynamic BFD session verifies the connectivity of a unidirectional LSP from the local device to the remote device.
If you do not specify the bgp-lsp, ldp-lsp, or static-lsp keyword when executing the mpls tunnel-bfd command, BFD detects the LSPs in the following sequence:
1. Static LSP.
2. LDP LSP.
3. BGP LSP.
# Use tunnel BFD to verify the connectivity of the LSPs to destination 22.22.2.2/32.
[Sysname] mpls tunnel-bfd 22.22.2.2 32
display mpls bfd
mpls bfd enable
Use mpls tunnel-bfd to enable tunnel BFD on an MPLS TE tunnel interface.
Use undo mpls tunnel-bfd to restore the default.
mpls tunnel-bfd discriminator local local-id remote remote-id [ template template-name ]
mpls tunnel-bfd [ echo ] [ template template-name ] [ source-ip ipv4-address ]
Tunnel BFD is not used to verify MPLS TE tunnel connectivity on a tunnel interface.
In an MPLS TE CRLSP backup scenario, you can use the mpls bfd command to create a BFD session for the primary and backup CRLSPs, respectively. When the primary CRLSP fails, BFD can quickly detect the failure and notify the device to switch traffic to the backup CRLSP. When both the primary and backup CRLSPs fail, the BFD detection mechanism fails. Traffic is lost until another mechanism detects the failure and triggers a traffic protection measure (such as MPLS L3VPN ECMP route based load balancing and FRR) to take effect.
To resolve this issue, you can execute the mpls tunnel-bfd command to configure tunnel BFD, which detects failures on the primary CRLSP and all the backup CRLSPs. When both the primary CRLSP and the current backup CRLSP fail, tunnel BFD can quickly detect the failures and trigger a traffic protection measure to switch traffic to an available backup CRLSP.
The source address of the BFD session can be specified manually, or if not specified, is the MPLS LSR ID of the local device. Before configuring tunnel BFD for an MPLS TE tunnel, make sure a route is available on the remote device to reach the source address of the BFD session.
· Static mode—Specify the local and remote discriminators by using the discriminator keyword in the mpls tunnel-bfd command. You must execute the mpls bfd enable and mpls tunnel-bfd commands on both the local and remote devices. Make sure the local discriminator and remote discriminator on the local device are the same as the remote discriminator and local discriminator on the remote device, respectively. A static BFD session verifies the connectivity of a pair of MPLS TE tunnels in opposite directions between two devices.
· Dynamic mode—If you do not specify local and remote discriminators, the system automatically runs MPLS ping to negotiate the discriminator values. You must execute the mpls bfd enable command on both the local and remote devices, but the mpls tunnel-bfd command is not needed on the remote device. A dynamic BFD session verifies the connectivity of a unidirectional MPLS TE tunnel from the local device to the remote device.
If you do not specify the echo keyword, the system uses BFD control packets to verify the connectivity of MPLS TE tunnels.
As a best practice to avoid tunnel flappings, disable MPLS BFD from triggering tunnel-down if you configure tunnel BFD for MPLS TE tunnels. To disable MPLS BFD from triggering tunnel-down, execute mpls bfd trigger tunnel-down disable in tunnel interface view or undo mpls bfd trigger tunnel-down enable in MPLS TE view.
# Enable tunnel BFD to verify tunnel connectivity on MPLS TE tunnel interface Tunnel 1, and use the BFD session parameter template test.
[Sysname-Tunnel1] mpls tunnel-bfd template test
display mpls bfd
mpls bfd enable
mpls tunnel-bfd detect-multiplier
Use mpls tunnel-bfd detect-multiplier to set the tunnel BFD and tunnel SBFD detection time multiplier for an MPLS TE tunnel.
Use undo mpls tunnel-bfd detect-multiplier to restore the default.
mpls tunnel-bfd detect-multiplier value
The tunnel BFD and tunnel SBFD detection time multiplier is not set for an MPLS TE tunnel.
For tunnel BFD on an MPLS TE tunnel:
· If the mpls tunnel-bfd detect-multiplier command and the mpls tunnel-bfd command with the template keyword are both executed in the tunnel interface view, the mpls tunnel-bfd command takes effect.
For tunnel SBFD on an MPLS TE tunnel:
· If the mpls bfd detect-multiplier command and the mpls tunnel-sbfd command with the template keyword are both executed in the tunnel interface view, the mpls tunnel-sbfd command takes effect.
# Set the tunnel BFD and tunnel SBFD detection time multiplier to 3 for MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls tunnel-bfd detect-multiplier 3
display mpls bfd
display mpls sbfd
mpls bfd enable
mpls tunnel-bfd (for TE tunnel)
mpls tunnel-sbfd (for TE tunnel)
mpls tunnel-bfd min-receive-interval
Use mpls tunnel-bfd min-receive-interval to set the minimum receiving interval for tunnel BFD and tunnel SBFD on an MPLS TE tunnel.
Use undo mpls tunnel-bfd min-receive-interval to restore the default.
mpls tunnel-bfd min-receive-interval interval
The minimum receiving interval is not set for tunnel BFD and tunnel SBFD on an MPLS TE tunnel.
MPU model |
Value range |
MSU-100 |
10 to 10000 |
MSU-200 |
10 to 10000 |
MSU-400-G |
5 to 10000 |
· If the mpls tunnel-bfd min-receive-interval command and the mpls tunnel-bfd command with the template keyword are both executed in the tunnel interface view, the mpls tunnel-bfd command takes effect.
· If the mpls tunnel-bfd min-receive-interval command and the mpls tunnel-sbfd command with the template keyword are both executed in the tunnel interface view, the mpls tunnel-sbfd command takes effect.
# Set the minimum BFD packet receiving interval to 550 milliseconds for tunnel BFD and tunnel SBFD on MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls tunnel-bfd min-receive-interval 550
display mpls bfd
display mpls sbfd
mpls bfd enable
mpls tunnel-bfd min-transmit-interval
Use mpls tunnel-bfd min-transmit-interval to set the minimum transmit interval for tunnel BFD and tunnel SBFD on an MPLS TE tunnel.
Use undo mpls tunnel-bfd min-transmit-interval to restore the default.
mpls tunnel-bfd min-transmit-interval interval
The minimum transmit interval is not set for tunnel BFD and tunnel SBFD on an MPLS TE tunnel.
MPU model |
Value range |
MSU-100 |
10 to 10000 |
MSU-200 |
10 to 10000 |
MSU-400-G |
5 to 10000 |
· If the mpls tunnel-bfd min-transmit-interval command and the mpls tunnel-bfd command with the template keyword are both executed in the tunnel interface view, the mpls tunnel-bfd command takes effect.
· If the mpls tunnel-bfd min-transmit-interval command and the mpls tunnel-sbfd command with the template keyword are both executed in the tunnel interface view, the mpls tunnel-sbfd command takes effect.
# Set the minimum BFD packet transmitting interval to 450 milliseconds for tunnel BFD and tunnel SBFD on MPLS TE tunnel 1.
[Sysname-Tunnel1] mpls tunnel-bfd min-transmit-interval 450
display mpls bfd
display mpls sbfd
mpls bfd enable
Use mpls tunnel-sbfd to enable tunnel SBFD on an MPLS TE tunnel.
Use undo mpls tunnel-sbfd to restore the default.
mpls tunnel-sbfd [ echo | remote remote-id ] [ template template-name ] [ source-ip ipv4-address ]
Tunnel SBFD is not used to verify MPLS TE tunnel connectivity.
remote remote-id: Specifies the remote discriminator value for the SBFD session, in the range of 1 to 4294967295. If you do not specify this option, the SBFD session uses the tunnel's remote IP address as the remote discriminator.
template template-name: Specifies an SBFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a template, the SBFD session uses the BFD session settings configured in tunnel interface view.
In an MPLS TE network, you can use the mpls sbfd command to create an SBFD session for the primary and backup paths of the MPLS TE tunnel, respectively. When the primary path fails, BFD can quickly detect the failure and notify the device to switch traffic to the backup path. When both the primary and backup paths fail, the SBFD detection mechanism fails. Traffic is lost until another mechanism detects the failure and triggers a traffic protection measure (such as MPLS L3VPN ECMP route based load balancing and FRR) to take effect.
To resolve this issue, you can execute the mpls tunnel-sbfd command to configure tunnel SBFD, which detects failures on the primary path and all the backup paths. When both the primary path and the current backup path fail, tunnel BFD can quickly detect the failures and trigger a traffic protection measure to switch traffic to an available backup path.
Execute the mpls tunnel-sbfd command on the initiator of the SBFD session. Before executing the mpls tunnel-sbfd command, you must first enable BFD for MPLS on the initiator by using the mpls bfd enable command.
When BFD control packet mode is used, an SBFD session can be established in static mode.
· If you specify a remote discriminator in the mpls tunnel-sbfd command, the device uses the specified remote discriminator to establish a static SBFD session.
· If you do not specify a remote discriminator in the mpls tunnel-sbfd command, the device uses the tunnel's remote IP address as the remote discriminator to establish a static SBFD session.
The remote discriminator specified by the mpls tunnel-sbfd command on the initiator must be the same as the local discriminator specified by the sbfd local-discriminator command on the reflector. Otherwise, the reflector will not respond to the initiator.
The source address of the SBFD session can be specified manually, or if not specified, is the MPLS LSR ID of the initiator. Before configuring tunnel SBFD for an MPLS TE tunnel, make sure a route is available on the reflector to reach the source address of the SBFD session.
As a best practice to avoid tunnel flappings, disable MPLS BFD from triggering tunnel-down if you configure tunnel SBFD for MPLS TE tunnels. To disable MPLS BFD from triggering tunnel-down, execute mpls bfd trigger tunnel-down disable in tunnel interface view or undo mpls bfd trigger tunnel-down enable in MPLS TE view.
# Enable tunnel SBFD to verify tunnel connectivity on MPLS TE tunnel interface Tunnel 1, and use the BFD session parameter template test.
[Sysname-Tunnel1] mpls tunnel-sbfd remote 1 template test
display mpls sbfd
mpls bfd enable
ping mpls ipv4
Use ping mpls ipv4 to verify MPLS LSP connectivity for an IPv4 prefix.
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * ipv4 ipv4-address mask-length [ destination start-address [ end-address [ address-increment ] ] ] [ fec-type { generic | ldp } ]
-a source-ip: Specifies the source address for MPLS echo request packets. If you do not specify this option, the device uses the primary IP address of the outgoing interface as the source address for MPLS echo requests.
-c count: Specifies the number of MPLS echo request packets to be sent with the same destination address in the IP header. The value range is 1 to 4294967295. The default is 5.
-h ttl-value: Specifies the TTL value for MPLS echo request packets, in the range of 1 to 255. The default is 255.
-m wait-time: Specifies the interval for sending MPLS echo request packets, in the range of 1 to 10000 milliseconds. The default is 200 milliseconds.
-r reply-mode: Specifies the reply mode of the receiver in response to MPLS echo request packets. The reply-mode argument can be 1, 2, 3, or 4. 1 means "Do not reply." 2 means "Reply by using a UDP packet." 3 means "Reply by using a UDP packet that carries the Router Alert option." 4 means "Reply by using a VCCV packet." The default is 2. The reply mode 4 is not available for MPLS LSP connectivity verification. If the reply mode 4 is specified, the remote end does not reply.
-s packet-size: Specifies the length (excluding the IP header and UDP header) of an MPLS echo request packet. The value for the packet-size argument is 65 to 8100 bytes, and the default is 100 bytes.
-v: Displays detailed reply information. If you do not specify this keyword, the command displays brief reply information.
ipv4-address mask-length: Specifies an FEC by a destination IP address and mask length. The mask length is in the range of 0 to 32.
destination: Specifies the destination address in the IP header of MPLS echo requests. The default is 127.0.0.1.
start-address: Specifies the destination address or the start destination address. This address must be an address on subnet 127.0.0.0/8—a local loopback address. If you specify the start-address argument without the end-address argument, the start-address is the destination address in the IP header. The number of MPLS echo requests to be sent is determined by the -c count keyword. If you specify both start-address and end-address, you specify a range of destination addresses. The destination address increments by the value specified for the address-increment argument, starting from the start-address to the end-address. The number of MPLS echo requests to be sent with each of the destination addresses is determined by the -c count keyword.
end-address: Specifies the end destination address. This address must be an address on subnet 127.0.0.0/8—a local loopback address.
address-increment: Specifies the increment value by which the destination address in the IP header increases in turn. The value range is 1 to 16777215 and the default value is 1.
fec-type: Specifies the FEC type of the MPLS LSPs to be verified. If you do not specify this keyword, the FEC type is the protocol type of the specified FEC in the routing table.
generic: Represents LSPs of any FEC type.
ldp: Represents LDP signaled LSPs.
# Verify the connectivity of LSPs to destination 3.3.3.9/32.
<Sysname> ping mpls ipv4 3.3.3.9 32
MPLS ping FEC 3.3.3.9/32 with 100 bytes of data:
100 bytes from 100.1.2.1: Sequence=1 time=49 ms
100 bytes from 100.1.2.1: Sequence=2 time=44 ms
100 bytes from 100.1.2.1: Sequence=3 time=60 ms
100 bytes from 100.1.2.1: Sequence=4 time=60 ms
100 bytes from 100.1.2.1: Sequence=5 time=76 ms
--- Ping statistics for FEC 3.3.3.9/32 ---
Round-trip min/avg/max = 44/57/76 ms
# Verify the connectivity of LSPs to destination 3.3.3.9/32, and specify the following parameters:
· Set the number of MPLS echo requests to be sent with the same destination address to 3.
· Display detailed reply information.
· Specify the range of destination addresses in IP headers as 127.0.0.1 to 127.0.0.3, and set the destination address increment value to 2. With these settings, the destination addresses are 127.0.0.1 and 127.0.0.3.
<Sysname> ping mpls –c 3 –v ipv4 3.3.3.9 32 destination 127.0.0.1 127.0.0.3 2
Destination address 127.0.0.1
100 bytes from 100.1.2.1: Sequence=1 time=49 ms Return Code=3(1)
Destination address 127.0.0.3
100 bytes from 100.1.2.1: Sequence=2 time=44 ms Return Code=3(1)
100 bytes from 100.1.2.1: Sequence=3 time=60 ms Return Code=3(1)
100 bytes from 100.1.2.1: Sequence=4 time=60 ms Return Code=3(1)
100 bytes from 100.1.2.1: Sequence=5 time=76 ms Return Code=3(1)
100 bytes from 100.1.2.1: Sequence=6 time=57 ms Return Code=3(1)
6 packets transmitted, 6 packets received, 0.0% packet loss
MPLS Ping FEC: 3.3.3.9/32 with 100 bytes of data |
Verify LSP connectivity for FEC 3.3.3.9/32 by sending 100-byte MPLS echo requests. |
Destination address |
Destination IP address in the IP header. |
100 bytes from 100.1.2.1 |
Received a 100-byte reply from 100.1.2.1. |
Sequence |
Sequence number of the reply, for determination of packet loss, disorder, or duplicate. |
time |
Packet round-trip delay. |
Return Code |
Return code. The number in parentheses represents a return subcode. · 1—The received MPLS echo request packet has content errors. · 2—The packet contains an unsupported TLV. · 3—Reply from the egress node. · 5—Unmatching downstream mapping. · 6—The upstream did not provide the outgoing interface. · 8—Reply from the label switching node. · 10—The outgoing label for the FEC is inconsistent with that in the packet label stack. · 11—The label in the packet label stack does not have a matching forwarding entry. · 12—The protocol type of the FEC is inconsistent with that in the label forwarding table for the packet. |
Ping statistics for FEC 3.3.3.9/32 |
LSP verification statistics. |
packets transmitted |
Number of MPLS echo requests sent. |
packets received |
Number of MPLS echo replies received. |
packet loss |
Percentage of unreplied packets to total request packets. |
Round-trip min/avg/max |
Minimum, average, and maximum round-trip delay. |
ping mpls out-labels
Use ping mpls out-labels to verify the MPLS LSP of the specified outgoing labels.
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * out-labels out-label-value&<1-n> interface interface-type interface-number [ nexthop nexthop-address ]
-a source-ip: Specifies the source address of MPLS echo request packets. If you do not specify this option, the device uses the primary IP address of the outgoing interface as the source address of MPLS echo requests.
-exp exp-value: Specifies the EXP value of MPLS echo request packets, in the range of 0 to 7. The default is 0.
-h ttl-value: Specifies the TTL value of MPLS echo request packets, in the range of 1 to 255. The default is 255.
-r reply-mode: Specifies the reply mode of the receiver in response to MPLS echo request packets. The reply-mode argument can be 1, 2, 3, or 4. The default is 2.
· 1—Do not reply.
· 2—Reply by using a UDP packet.
· 3—Reply by using a UDP packet that carries the Router Alert option.
· 4—Reply by using a VCCV packet. The reply mode 4 is not available for MPLS LSP connectivity verification. If the reply mode 4 is specified, the remote end does not reply.
out-labels out-label-value&<1-n>: Specifies a space-separated list of up to n outgoing labels, corresponding to the labels from top to bottom in the label stack. The value range for the out-label-value argument is 0, 3, and 16 to 1048575. The value for n is 13.
interface interface-type interface-number: Specifies the outgoing interface by the interface type and number.
nexthop nexthop-address: Specifies the next hop IP address.
To verify connectivity of a specific LSP, first execute the display mpls lsp command to identify the outgoing interface and next hop for the outgoing labels to be specified.
# In an LDP network, verify the connectivity of the LSP with outgoing label 2173, outgoing interface GigabitEthernet 1/0/1, and next hop IP address 10.1.1.2/32.
<Sysname> ping mpls out-labels 2173 interface gigabitethernet 1/0/1 nexthop 10.1.1.2
MPLS ping out-labels 2173 with 100 bytes of data:
100 bytes from 20.1.1.2: Sequence=1 time=1 ms
100 bytes from 20.1.1.2: Sequence=3 time=1 ms
100 bytes from 20.1.1.2: Sequence=4 time=1 ms
--- Ping statistics for out-labels ---
Round-trip min/avg/max = 1/1/1 ms
<Sysname>%Oct 11 09:26:52:882 2018 Sysname LSPV/6/LSPV_PING_STATIS_INFO: Ping statistics for out-labels 2173: 5 packets transmitted, 5 packets received, 0.0% packets loss, round-trip min/avg/max = 1/1/1 ms.
Table 5 Command output
MPLS ping out-labels out-label-value with 100 bytes of data |
Verify LSP connectivity for the specified outgoing labels (out-label-value) by sending 100-byte MPLS echo requests. |
100 bytes from 20.1.1.2 |
Received a 100-byte reply from 20.1.1.2. |
Sequence |
time |
Return Code |
Return code. The number in parentheses represents a return subcode. · The received MPLS echo request packet has content errors. · 2—The packet contains an unsupported TLV. · 3—Reply from the egress node. · 5—Unmatching downstream mapping. · 6—The upstream did not provide the outgoing interface. · 8—Reply from the label switching node. · 10—The outgoing label for the FEC is inconsistent with that in the packet label stack. · 11—The label in the packet label stack does not have a matching forwarding entry. · 12—The protocol type of the FEC is inconsistent with that in the label forwarding table for the packet. |
Ping statistics for out-labels |
packets received |
packet loss |
ping mpls pw
Use ping mpls pw to verify LDP PW or static PW connectivity.
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v ] * pw ip-address pw-id pw-id [ remote remote-ip-address remote-pw-id ]
-a source-ip: Specifies the source address of MPLS echo request packets. If you do not specify this option, the device uses its MPLS LSR ID as the source address of MPLS echo requests.
-c count: Specifies the number of MPLS echo request packets to be sent. The value range is 1 to 4294967295. The default is 5.
· 1—Do not reply.
ip-address: Specifies the IP address of the peer PE.
pw-id pw-id: Specifies the ID of the PW to the peer PE, in the range of 1 to 4294967295.
remote remote-ip-address remote-pw-id: Specifies a multisegment PW. The remote-ip-address argument represents the IP address of the egress node of the multisegment PW. The remote-pw-id argument represents the ID of the last segment PW, in the range of 1 to 4294967295. This option is required only when the egress node of a multisegment PW supports verifying the Target FEC Stack TLV in an MPLS echo request. Comware devices do not support the verification in the current software version.
To use this command to verify the connectivity of an LDP PW or a static PW, the PW must be created by using a PW class that specifies the VCCV CC type.
If you execute this command for a down PW, the ping operation might fail because of negotiation issues at the two ends of the PW. In this case, the device prompts not support for PW ping.
# Verify the connectivity of PW 301 to peer PE 3.3.3.9.
<Sysname> ping mpls pw 3.3.3.9 pw-id 301
MPLS ping PW 3.3.3.9 301 with 100 bytes of data:
--- Ping statistics for PW 3.3.3.9 301 ---
For the command output, see Table 4.
ping mpls te
Use ping mpls te to verify MPLS TE tunnel connectivity.
ping mpls [ -a source-ip | -c count | -exp exp-value | -h ttl-value | -m wait-time | -r reply-mode | -rtos tos-value | -s packet-size | -t time-out | -v | fec-check ] * te tunnel interface-number [ nil ] [ hot-standby ]
Parameter
-c count: Specifies the number of MPLS echo request packets to be sent, in the range of 1 to 4294967295. The default is 5.
· 1—Do not reply.
· 4—Reply by using a VCCV packet. The reply mode 4 is not available for MPLS TE tunnel connectivity verification. If the mode is specified, the remote end does not reply.
-rtos tos-value: Specifies the ToS value in the IP header of an MPLS echo reply packet. The value range is 0 to 7, and the default is 6.
-s packet-size: Specifies the length (excluding the IP header and UDP header) of an MPLS echo request packet. The value range for the packet-size argument is 65 to 8100 bytes, and the default is 100 bytes.
fec-check: Checks the FEC type at transit nodes. If you do not specify this keyword, transit nodes do not check the FEC type.
tunnel interface-number: Specifies an MPLS TE tunnel interface by the interface number. The specified MPLS TE tunnel interface must have already been created.
nil: Specifies the Nil FEC, so that the egress node will not check the FEC type. If you do not specify this keyword, the egress node will check the FEC type.
hot-standby: Verifies the connectivity of the hot-standby backup LSP created for the specified MPLS TE tunnel. To verify the specified MPLS TE tunnel, do not specify this keyword.
nil-fec: Specifies the Nil FEC, so that the egress node will not check the FEC type. If you do not specify this keyword, the egress node will check the FEC type.
# Verify the connectivity of the MPLS TE tunnel for Tunnel 1.
<Sysname> ping mpls te tunnel 1
MPLS ping TE tunnel Tunnel1 with 100 bytes of data:
--- Ping statistics for TE tunnel Tunnel1 ---
tracert mpls ipv4
Use tracert mpls ipv4 to trace MPLS LSPs from the ingress node to the egress node for an IPv4 prefix. You can locate the error node according to the reply information.
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | ddmap | fec-check ] * ipv4 ipv4-address mask-length [ destination start-address [ end-address [ address-increment ] ] ] [ fec-type {generic | ldp } ]
-a source-ip: Specifies the source address for MPLS echo request packets. If you do not specify this option, the command uses the primary IP address of the outgoing interface as the source address for MPLS echo requests.
-r reply-mode: Specifies the reply mode of the receiver in response to MPLS echo request packets. The reply-mode argument can be 2, 3, or 4. The default is 2.
ddmap: Encapsulates the Downstream Detailed Mapping (DDMAP) TLV in MPLS echo reply and MPLS echo request packets. If you do not specify this keyword, Downstream Mapping TLV (DSMAP) will be encapsulated in these packets. DDMAP TLV and DSMAP TLV carry the downstream information of the current node, including the next hop address and outgoing label. When you perform MPLS tracert operations, the device will verify the next hop address and outgoing label in the DDMAP TLV and DSMAP TLV. If both the address and label are correct, the device sends a normal MPLS echo reply to the ingress node. If the address or label is incorrect, the device sends an MPLS echo reply with an error code to the ingress node.
ipv4-address mask-length: Specifies an FEC by an IPv4 destination address and a mask length. The value range for the mask-length argument is 0 to 32.
start-address: Specifies the destination address or the start destination address. This address must be an address on subnet 127.0.0.0/8—a local loopback address. If you specify the start-address argument without the end-address argument, the start-address is the destination address in the IP header. If you specify both start-address and end-address, you specify a range of destination addresses. The destination address increments by the value specified for the address-increment argument, starting from the start-address to the end-address. The command performs a tracert for each of the destination addresses.
fec-type: Specifies the FEC type to be carried in an MPLS echo request packet. If you do not specify this keyword, the FEC type is the protocol type of the specified FEC in the routing table.
# Trace the path that the LSP (for FEC 5.5.5.9/32) traverses from the ingress node to the egress node. Specify the IP header destination address range as 127.1.1.1 to 127.1.1.2 and set the address increment value to 1. With these settings, the device performs a tracert for 127.1.1.1 and 127.1.1.2.
<Sysname> tracert mpls ipv4 5.5.5.9 32 destination 127.1.1.1 127.1.1.2 1
MPLS trace route FEC 5.5.5.9/32
Destination address 127.1.1.1
TTL Replier Time Type Downstream
0 Ingress 100.1.2.1/[1025]
1 100.1.2.1 1 ms Transit 100.2.4.1/[1024]
2 100.2.4.1 63 ms Transit 100.4.5.1/[3]
3 100.4.5.1 129 ms Egress
Destination address 127.1.1.2
0 Ingress 100.1.3.1/[1030]
1 100.1.3.1 1 ms Transit 100.3.4.1/[1024]
2 100.3.4.1 51 ms Transit 100.4.5.1/[3]
3 100.4.5.1 80 ms Egress
# Trace the path that the LSP (for FEC 5.5.5.9/32) traverses from the ingress node to the egress node. Display detailed reply information, specify the IP header destination address range as 127.1.1.1 to 127.1.1.2, and set the address increment value to 1. With these settings, the device performs a tracert for 127.1.1.1 and 127.1.1.2.
<Sysname> tracert mpls –v ipv4 5.5.5.9 32 destination 127.1.1.1 127.1.1.2 1
1 100.1.2.1 1 ms Transit 100.2.4.1/[1024] ReturnCode 8(1)
2 100.2.4.1 63 ms Transit 100.4.5.1/[3] ReturnCode 8(1)
3 100.4.5.1 129 ms Egress ReturnCode 3(1)
1 100.1.3.1 1 ms Transit 100.3.4.1/[1024] ReturnCode 8(1)
2 100.3.4.1 51 ms Transit 100.4.5.1/[3] ReturnCode 8(1)
3 100.4.5.1 80 ms Egress ReturnCode 3(1)
MPLS trace route FEC |
Trace the LSPs for the specified FEC. |
TTL |
Number of hops. |
Replier |
Address of the LSR that replied the request. |
Time |
Time used to receive the reply, in milliseconds. |
Type |
LSR type: Ingress, Transit, or Egress. |
Downstream |
Address of the downstream LSR and the label assigned by the downstream LSR. |
ReturnCode |
tracert mpls out-labels
Use tracert mpls out-labels to trace MPLS LSPs of the specified outgoing labels from the ingress node to the egress node of the LSPs. You can locate the error node according to the reply information.
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | fec-check ]* out-labels out-label-value&<1-n> interface interface-type interface-number [ nexthop nexthop-address ]
-h ttl-value: Specifies the maximum TTL value of MPLS echo request packets (the maximum number of hops to be inspected). The value range for the ttl-value argument is 1 to 255, and the default is 30.
To trace a specific LSP, first execute the display mpls lsp command to identify the outgoing interface and next hop for the outgoing labels to be specified.
# In an LDP network, trace the path of the LSP with outgoing label 2173, outgoing interface GigabitEthernet 1/0/1, and next hop IP address 10.1.1.2/32.
<Sysname> tracert mpls out-labels 2173 interface gigabitethernet 1/0/1 nexthop 10.1.1.2
MPLS trace route out-labels 2173
0 Ingress 10.1.1.2/[2173]
1 10.1.1.2 1 ms Transit 20.1.1.2/[1040127]
2 20.1.1.2 1 ms Egress
Table 7 Command output
MPLS trace route out-labels out-label-value |
Trace the LSPs for the specified outgoing labels. |
TTL |
Number of hops. |
Replier |
IP address of the LSR that replied the request. |
Time |
Packet round-trip delay, in milliseconds. |
Type |
Downstream |
Address of the downstream LSR and the outgoing label (label assigned by the downstream LSR). |
Return Code |
tracert mpls pw
Use tracert mpls pw to trace the path of a PW and locate the error node according to the reply information.
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v ] * pw { { peer peer-address pw-id pw-id | vsi vsi-name peer peer-address } [ remote remote-ip-address remote-pw-id ] | vsi vsi-name local-site-id remote-site-id [ control-word ] | vsi vsi-name mac mac-address } [ ddmap | full-lsp-path ] *
-h ttl-value: Specifies the maximum TTL value of MPLS echo request packets (the maximum number of hops to be inspected). The value range for the ttl-value argument is 1 to 255, and the default is 255.
peer ip-address: Specifies the IP address of the peer PE.
vsi vsi-name: Specifies the VSI associated with the PW by the VSI name, which is a case-sensitive string of 1 to 31 characters.
local-site-id remote-site-id: Specifies a BGP PW by its local site ID and remote site ID. The value for the site ID depends on the device model.
control-word: Includes the control word field in the PW label encapsulation for MPLS echo requests. If you do not specify this keyword, the command does not include the control word field in the PW label encapsulation for MPLS echo requests.
mac mac-address: Specifies the PW destined for the specified MAC address. The MAC address is in format of H-H-H, and cannot be an all-zero, broadcast, or multicast MAC address.
full-lsp-path: Displays the full LSP path between the local PE and the remote PE. If you do not specify this keyword, the command displays only the path information returned by the egress node.
To use this command to trace the path of a PW, the PW must be created by using a PW class that specifies the VCCV CC type.
In the MPLS trace route result, no downstream information is displayed for some nodes if the MPLS LSP contains ECMP paths on a transit node that uses per-packet load sharing. This is because different MPLS echo requests will select different paths on the transit node, resulting in downstream mapping verification failure on some nodes of the MPLS LSP.
# Display the path of the PW with remote IP address 3.3.3.9 and PW ID 301.
<Sysname> tracert mpls pw peer 3.3.3.9 pw-id 301 full-lsp-path
MPLS tracert PW 3.3.3.9 301
0 Ingress 10.4.5.1/[1025]
1 10.4.5.1 1 ms Transit 100.3.4.1/[1024]
2 100.3.4.1 63 ms Transit 100.1.2.1/[3]
3 100.1.2.1 129 ms Egress
# Display the path of the PW destined for IP address 3.3.3.9 in VSI vpna.
<Sysname> tracert mpls pw vsi vpna peer 3.3.3.9
MPLS Tracert PW in VSI vpna with IP 3.3.3.9
# Display the path of the PW destined for MAC address 0002-0002-0002 in VSI vpna.
<Sysname> tracert mpls pw vsi vpna mac 0002-0002-0002
MPLS Tracert PW in VSI vpna with MAC 0002-0002-0002
Table 8 Command output
MPLS tracert PW 3.3.3.9 301 |
Tracert the PW with remote IP address 3.3.3.9 and PW ID 301. |
MPLS Tracert PW in VSI vpna with IP 3.3.3.9 |
Tracert the PW with remote IP address 3.3.3.9 in VSI vpna. |
MPLS Tracert PW in VSI vpna with MAC 0002-0002-0002 |
Tracert the PW destined for remote MAC address 0002-0002-0002 in VSI vpna. |
TTL |
Number of hops. |
Replier |
Time |
Type |
Downstream |
ReturnCode |
tracert mpls te
Use tracert mpls te to trace an MPLS TE tunnel from the ingress node to the egress node. You can locate the error node according to the reply information.
tracert mpls [ -a source-ip | -exp exp-value | -h ttl-value | -r reply-mode | -rtos tos-value | -t time-out | -v | ddmap | fec-check ] * te tunnel interface-number [ nil ] [ hot-standby ]
-a source-ip: Specifies the source address of MPLS echo request packets. If you do not specify this option, the command uses the primary IP address of the outgoing interface as the source address of MPLS echo requests.
tunnel interface-number: Specifies an existing MPLS TE tunnel interface by the interface number.
hot-standby: Tracerts the hot-standby backup LSP created for the specified MPLS TE tunnel. To tracert the specified MPLS TE tunnel, do not specify this keyword.
# Trace the path that MPLS TE tunnel 1 traverses from the ingress node to the egress node.
<Sysname> tracert mpls te tunnel 1
MPLS trace route TE tunnel Tunnel1
For the command output, see Table 6.
vccv bfd
Use vccv bfd to configure BFD to verify PW connectivity.
Use undo vccv bfd to restore the default.
vccv bfd [ raw-bfd ] [ template template-name ]
undo vccv bfd
BFD is not used to verify PW connectivity.
PW class view
raw-bfd: Specifies the BFD packets to use PW-ACH encapsulation (without IP/UDP headers). This keyword takes effect only when the CC type is control word. If you do not specify this keyword, the BFD packets use IP/UDP encapsulation (with IP/UDP headers).
template template-name: Specifies a BFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a template, BFD uses the multihop BFD session settings configured in system view.
After you execute this command and specify the PW class for a PW, the PEs use the specified encapsulation type to verify PW connectivity when the following conditions are met:
· Both PEs of the PW have configured BFD for the PW.
· The PEs use the same encapsulation type for BFD packets.
If any of the previous conditions are not met, the PEs do not use BFD to verify PW connectivity.
To use BFD for PW connectivity verification, you must execute the vccv bfd and mpls bfd enable commands on both ends of the PW.
# Configure BFD to verify PW connectivity and specify the BFD session parameter template as aaa.
[Sysname] pw-class test
[Sysname-pw-test] vccv bfd template aaa
display l2vpn pw bfd
mpls bfd enable
vccv cc
vccv cc
Use vccv cc to specify the VCCV control channel (CC) type.
Use undo vccv cc to restore the default.
vccv cc { control-word | router-alert }
undo vccv cc
No VCCV CC type is specified.
PW class view
control-word: Specifies the VCCV CC type as control word.
router-alert: Specifies the VCCV CC type as MPLS router alert label.
The packets used to verify PW connectivity are collectively referred to as VCCV packets. A PE transfers VCCV packets through a CC.
CCs include the following types:
· Control word—Identifies VCCV packets through the control word (PW-ACH, PW Associated Channel Header). You can use this CC type only when the PW supports control word. For more information about control word, see MPLS Configuration Guide.
· MPLS router alert label—Identifies a VCCV packet by adding an MPLS router alert label before the PW label.
After you execute this command and specify the PW class for a PW, the specified CC is used if both PEs have specified the same VCCV CC type. Otherwise, the PEs do not use any CC and they cannot establish a BFD session for the PW.
# Specify the VCCV CC type as MPLS router alert label.
[Sysname-pw-test] vccv cc router-alert
mpls bfd enable
vccv bfd
