| 03-SRv6 commands | 710.88 KB |
display bgp egress-engineering ipv6
display bgp egress-engineering srv6 peer-set
display isis segment-routing ipv6 capability
display isis segment-routing ipv6 locator
display ospfv3 segment-routing ipv6 capability
display ospfv3 segment-routing ipv6 locator
display segment-routing ipv6 available-static-sid
display segment-routing ipv6 forwarding
display segment-routing ipv6 local-sid
display segment-routing ipv6 local-sid statistics
display segment-routing ipv6 locator
display segment-routing ipv6 locator-statistics
display segment-routing ipv6 remote-locator
display segment-routing ipv6 remote-sid
egress-engineering metric-bandwidth advertisement enable
egress-engineering metric-bandwidth suppression
egress-engineering metric-delay advertisement enable
egress-engineering metric-delay suppression
egress-engineering metric-link-loss advertisement enable
egress-engineering metric-link-loss suppression
fast-reroute microloop-avoidance enable (IS-IS IPv6 address family)
fast-reroute microloop-avoidance enable (OSPFv3 view)
fast-reroute microloop-avoidance rib-update-delay (IS-IS IPv6 address family)
fast-reroute microloop-avoidance rib-update-delay (OSPFv3 view)
isis ipv6 fast-reroute ti-lfa disable
ospfv3 fast-reroute ti-lfa disable
peer virtual-link te link administrative group
peer virtual-link twamp-light test-session
segment-routing ipv6 (system view)
segment-routing ipv6 admin-tag
segment-routing ipv6 compatible locator-fixed-length
segment-routing ipv6 egress-engineering locator
segment-routing ipv6 end-x delete-delay
segment-routing ipv6 locator (IS-IS IPv6 address family view)
segment-routing ipv6 locator (OSPFv3 process view)
segment-routing ipv6 private-srv6-extensions compatible
segment-routing ipv6 sid delete-delay
segment-routing ipv6 sid-sub-tlv-type
segment-routing microloop-avoidance enable
segment-routing microloop-avoidance encaps
segment-routing microloop-avoidance rib-update-delay
segment-routing microloop-avoidance strict-sid-only
srv6 compress enable (IS-IS IPv6 address family view)
srv6 compress enable (OSPFv3 view)
srv6 compress enable (SRv6 view)
SRv6 commands
advertise srv6 locator
Use advertise srv6 locator to enable the device to generate routes for a locator in the BGP IPv6 unicast routing table and advertise the routes to BGP peers.
Use undo advertise srv6 locator to delete routes for a locator from the BGP IPv6 unicast routing table.
advertise srv6 locator locator-name [ route-policy route-policy-name ]
undo advertise srv6 locator locator-name
The device does not generate routes for a locator in the BGP IPv6 unicast routing table.
BGP IPv6 unicast address family view
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. Only routes that match the routing policy can be generated in the BGP IPv6 unicast routing table for the locator. All routes for the locator can be generated in the BGP IPv6 unicast routing table in the following situations:
· You do not specify a routing policy when using this command.
· The specified routing policy does not exist.
· The specified routing policy does not contain if-match clauses.
Use this command in an inter-AS BGP network. This command enables the device to use BGP to advertise routes for a locator.
Repeat this command to enable the device to use BGP to advertise routes for multiple locators.
# Enable the device to generate routes for locator abc in the BGP IPv6 unicast routing table and advertise the routes to BGP peers.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6
[Sysname-bgp-default-ipv6] advertise srv6 locator abc
locator
anycast enable
Use anycast enable to enable anycast for an SRv6 locator.
Use undo anycast enable to disable anycast for an SRv6 locator.
anycast enable
undo anycast enable
Anycast is disabled for an SRv6 locator.
SRv6 locator view
After you apply a locator to a routing protocol, the routing protocol will advertise the SRv6 SIDs in the locator. By default, the N-bit is set in the Flags field of the Locator TLV in routing protocol packets. The locator belongs to one SRv6 node. If you enable anycast for a locator, the A-bit is set in the Flags field of the Locator TLV in routing protocol packets. The locator is shared by a group of SRv6 nodes.
# Enable anycast for locator test1.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] locator test1 ipv6-prefix 100:: 64 static 32
[Sysname-segment-routing-ipv6-locator-test1] anycast enable
locator
diffserv-mode
Use diffserv-mode to configure the SRv6 DiffServ mode.
Use undo diffserv-mode to restore the default.
diffserv-mode { ingress { pipe service-class | short-pipe service-class | uniform } egress { pipe | short-pipe | uniform } | { pipe service-class | short-pipe service-class | uniform } }
undo diffserv-mode
The SRv6 DiffServ mode is pipe and the traffic class is 0.
SRv6 view
ingress: Specifies the inbound direction.
egress: Specifies the outbound direction.
pipe: Specifies the pipe mode.
short-pipe: Specifies the short-pipe mode.
uniform: Specifies the uniform mode.
service-class: Specifies a traffic class for packets that enters the SRv6 network from the IP network. The value range for the traffic class is 0 to 7, which corresponds to be, af1, af2, af3, af4, ef, cs6, and cs7, respectively.
The following SRv6 DiffServ modes are available:
· Pipe mode—When a packet enters the SRv6 network, the ingress node adds a new IPv6 header to the original packet. The ingress node ignores the IP precedence or DSCP value in the original packet and uses the value specified by using the service-class argument as the traffic class in the new IPv6 header. In the SRv6 network, SRv6 nodes perform QoS scheduling for the packet based on the specified traffic class. When the packet leaves the SRv6 network, the egress node removes the outer IPv6 header from the packet without modifying the IP precedence or DSCP value in the original packet.
· Short-pipe mode—When a packet enters and leaves the SRv6 network, all SRv6 nodes process the packet in the same way as in pipe mode except for the egress node. After the egress node removes the outer IPv6 header from the packet, it performs QoS scheduling as follows:
¡ If no priority trust mode is configured, the egress node performs QoS scheduling for the packet based on the IP precedence or DSCP value in the original packet.
¡ If a priority trust mode is configured, the egress node performs QoS scheduling for the packet based on the trusted priority.
· Uniform mode—When a packet enters the IPv6 network, the ingress node maps the IP precedence or DSCP value in the original IP header to the outer IPv6 header as the traffic class. When the packet leaves the SRv6 network, the egress node maps the traffic class value in the outer IPv6 header to the original packet as the IP precedence or DSCP value.
The accuracy changes when the DSCP value and traffic class value are mapped to each other.
To specify different DiffServ modes for the inbound and outbound directions, use the diffserv-mode command with the ingress and egress keywords. To specify the same DiffServ mode for the inbound and outbound directions, use the diffserv-mode command without the ingress or egress keyword.
If you execute the diffserv-mode command multiple times, the most recent configuration takes effect.
When you configure the SRv6 DiffServ mode on the source and destination nodes of an SRv6 tunnel, follow these restrictions and guidelines:
· The outbound DiffServ mode on the local end must be the same as the inbound DiffServ mode on the peer end.
· The inbound DiffServ mode on the local end must be the same as the outbound DiffServ mode on the peer end.
For more information about IP precedence and DSCP, see priority mapping configuration in QoS Configuration Guide.
The SRv6 DiffServ mode configuration cannot take effect on an egress node in SRv6-BE mode in the following networks:
· IP L3VPN over SRv6.
· EVPN L3VPN over SRv6.
· EVPN VPWS over SRv6.
· EVPN VPLS over SRv6.
# Configure the SRv6 DiffServ mode as uniform.
[Sysname-segment-routing-ipv6] diffserv-mode uniform
Use display bgp egress-engineering ipv6 to display BGP-EPE information for IPv6 peers.
display bgp [ instance instance-name ] egress-engineering ipv6 [ ipv6-address ] [ verbose ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays information about the default BGP instance.
ipv6-address: Specifies an IPv6 peer by its IPv6 address. The specified IPv6 peer must already exist. If you do not specify an IPv6 peer, this command displays BGP-EPE information for all IPv6 peers.
verbose: Displays detailed BGP-EPE information. If you do not specify this keyword, the command displays only brief BGP-EPE information.
# Display BGP-EPE information for all IPv6 peers.
<Sysname> display bgp egress-engineering ipv6
BGP peering segment type: Node-Adjacency
Peer NodeAdj : 2::9
Local ASNumber : 100
Remote ASNumber : 200
Local RouterID : 1.1.1.9
Remote RouterID : 2.2.2.9
Interface : XGE3/0/1
OriginalNextHop : 2::9
RelyNextHop : FE80::28B6:9EFF:FE23:206
StaticSID(PSP) : 3:4::100
StaticSID(NO-FLAVOR) : 3:4::200
StaticSID(PSP,USP,USD) : 3:4::300
StaticSID(PSP COC32) : 3:4::100:0
StaticSID(NO-FLAVOR COC32) : 3:4::102:0
StaticSID(PSP COC-NONE) : 3:4::101:0
StaticSID(NO-FLAVOR COC-NONE) : 3:4::103:0
StaticSID(PSP,USP,USD,COC-NONE) : 3:4::104:0
SID(PSP) : 3:4::100
Interface : XGE3/0/2
RelayNextHop : FE80::28B6:9EFF:FE23:208
SID(PSP) : 3:4::100
# Display detailed BGP-EPE information for all IPv6 peers.
<Sysname> display bgp egress-engineering ipv6 verbose
PeerAdj Num : 2
Nexthop : 2::9
Local Interface Address : 10::1
Remote Interface Address : 10::2
SID(PSP) : 3:4::100
Local Interface Address : 20::1
Remote Interface Address : 20::2
RelyNextHop : FE80::28B6:9EFF:FE23:208
SID(PSP) : 3:4::100
Virtual link info:
TE admin group : 0x202
TE metric : 200
TE SRLG : 50 100 300
Min/Max/Average/Variation delay : 714/5414/3554/54
BGP peering segment type : Adjacency
PeerAdj : FE80::28B6:9EFF:FE23:206
Local Interface Address : FE80::28B6:9EFF:FE23:D16
Remote Interface Address : FE80::28B6:9EFF:FE23:206
SID(PSP) : 3:4::400
SID(NO-FLAVOR) : 3:4::500
SID(PSP,USP,USD) : 3:4::600
SID(PSP COC32) : 3:4::105:0
SID(NO-FLAVOR COC32) : 3:4::106:0
SID(PSP COC-NONE) : 3:4::107:0
SID(NO-FLAVOR COC-NONE) : 3:4::108:0
SID(PSP,USP,USD,COC-NONE) : 3:4::109:0
Administrative group: 0x0
Maximum link bandwidth(kbits/sec): 100000
Maximum reservable link bandwidth(kbits/sec): 9999
Maximum Unreserved bandwidth(kbits/sec): 999 999 999 999 999 999 999 999
TE Metric: 1
TE SRLG: 100
Flag: 0, Average delay(us): 100
Flag: 0, Min delay(us): 100, Max delay(us): 200
Delay variation(us): 200
Remaining bandwidth(bytes/sec): 200
Available bandwidth(bytes/sec): 100
Utilized bandwidth(bytes/sec): 50
Link loss flag: 0, Link loss rate: 50.331624%
PeerAdj : FE80::28B6:9EFF:FE23:208
Local Interface Address : FE80::28B6:9EFF:FE23:D18
Remote Interface Address : FE80::28B6:9EFF:FE23:208
SID(PSP) : 3:4::700
SID(NO-FLAVOR) : 3:4::800
SID(PSP,USP,USD) : 3:4::900
SID(PSP COC32) : 3:4::10A:0
SID(NO-FLAVOR COC32) : 3:4::10B:0
SID(PSP COC-NONE) : 3:4::10C:0
SID(NO-FLAVOR COC-NONE) : 3:4::10D:0
SID(PSP,USP,USD,COC-NONE) : 3:4::10E:0
TE Metric: 1
TE SRLG: 100
BGP peering segment type |
BGP peering segment type of the peer: · Node—Node type. · Adjacency—Adjacency type. · Node-Adjacency—Node and adjacency type. |
Peer Node |
Address of the node-type peer. |
Peer Adj |
Address of the adjacency-type peer. |
Peer NodeAdj |
Address of the node- and adjacency-type peer. |
PeerAdj Num |
Number of adjacency-type peers. |
Information about the interface used to establish peer relationship. |
OriginalNextHop |
IP address of the original next hop. |
RelyNextHop |
IP address of the recursed next hop. |
StaticSID(NO-FLAVOR) |
Manually configured End.X SID (no-flavor type). |
StaticSID(PSP) |
Manually configured End.X SID (PSP flavor type). |
StaticSID(PSP,USP,USD) |
Manually configured End.X SID (PSP, USP, and USD flavor type). |
StaticSID(NO-FLAVOR COC32) |
Manually configured End.X (COC32) SID (no-flavor type). |
StaticSID(PSP COC32) |
Manually configured End.X (COC32) SID (PSP flavor type). |
StaticSID(NO-FLAVOR COC-NONE) |
Manually configured End.X (COC-NONE) SID (no-flavor type). |
StaticSID(PSP COC-NONE) |
Manually configured End.X (COC-NONE) SID (PSP-flavor type). |
StaticSID(PSP,USP,USD COC-NONE) |
Manually configured End.X (COC-NONE) SID (PSP, USP, and USD flavor type). |
SID(NO-FLAVOR) |
Effective End.X SID (no-flavor type). |
SID(PSP) |
Effective End.X SID (PSP flavor type). |
SID(PSP,USP,USD) |
Effective End.X SID (PSP, USP, and USP flavor type). |
Effective End.X (COC32) SID (no-flavor type). |
SID(PSP COC32) |
Effective End.X (COC32) SID (PSP flavor type). |
Effective End.X (COC-NONE) SID (no-flavor type). |
SID(PSP COC-NONE) |
Effective End.X (COC-NONE) SID (PSP-flavor type). |
Effective End.X (COC-NONE) SID (PSP, USP, and USD flavor type). |
Virtual link info |
BGP virtual link information. |
TE admin group |
Affinity attribute value for the virtual link. |
TE metric |
TE metric for the virtual link. |
TE SRLG |
SRLG to which the virtual link belongs. |
Min/Max/Average/Variation delay |
Minimum, maximum, and average delay, and delay variation, in microseconds. |
Administrative Group |
Administrative group of the link, or link attribute. |
TE Metric |
TE metric value for the link. |
TE SRLG |
SRLG to which the link belongs. |
Flag |
Flag for average delay measurement: · 0—The measured average delay value is less than or equal to 16777215 microseconds. The link is stable. · 1—The measured average delay value is greater than or equal to 16777215 microseconds. |
Average delay(us) |
Average delay in microseconds. |
Flag |
Flag for minimum/maximum delay measurement: · 0—The measured delay value is less than or equal to 16777215 microseconds. The link is stable. · 1—The measured delay value is greater than or equal to 16777215 microseconds. |
Link loss flag |
Flag for packet loss rate measurement: · 0—The measured packet loss rate of the link is smaller than 50.331642%. The link is stable. · 1—The measured packet loss rate of the link is equal to or greater than 50.331642%. The current link performance is poor. |
Link loss rate |
Packet loss rate in percentage. |
Use display bgp egress-engineering srv6 peer-set to display information about BGP-EPE SRv6 peer sets.
display bgp egress-engineering srv6 peer-set [ srv6-peer-set-name ]
peer-set-name: Specifies a BGP-EPE SRv6 peer set by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a BGP-EPE SRv6 peer set, this command displays information about all BGP-EPE SRv6 peer sets.
# Display information about all BGP-EPE SRv6 peer sets.
<Sysname> display bgp egress-engineering srv6 peer-set
BGP egress peering segment srv6 peer-set: abc
SID(PSP) : 3:4::700
Members: 1
Peer: 4:4:4::4
BGP egress peering segment srv6 peer-set |
Name of a BGP-EPE SRv6 peer set. |
StaticSID(PSP) |
SID(PSP) |
Automatically allocated End.X SID (PSP flavor type). |
SID(NO-FLAVOR) |
Automatically allocated End.X SID (no-flavor type). |
SID(PSP,USP,USD) |
Automatically allocated End.X SID (PSP, USP, and USP flavor type). |
SID(PSP COC32) |
SID(PSP COC-NONE) |
Members |
Number of peers in the BGP-EPE SRv6 peer set. |
Peer |
Peer in the BGP-EPE SRv6 peer set. |
Use display isis segment-routing ipv6 capability to display IS-IS SRv6 capability information.
display isis segment-routing ipv6 capability [ level-1 | level-2 ] [ process-id ]
level-1: Specifies IS-IS Level-1.
level-2: Specifies IS-IS Level-2.
process-id: Specifies an IS-IS process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays SRv6 capability information for all IS-IS processes.
If you do not specify a level, this command displays IS-IS SRv6 capability information for both Level-1 and Level-2.
# Display SRv6 capability information for IS-IS process 1.
<Sysname> display isis segment-routing ipv6 capability level-1 1
IPv6 segment routing capability information for IS-IS(1)
Level-1 IPv6 segment routing capability
System ID SRv6 capability
0000.1000.0001 Enabled
0000.2000.0001 Enabled
0000.2000.0002 Enabled
0000.2000.0003 Enabled
System ID |
Neighbor system ID. |
SRv6 capability |
Whether SRv6 is enabled. |
Use display isis segment-routing ipv6 locator to display IS-IS SRv6 locator information.
display isis segment-routing ipv6 locator [ ipv6-address prefix-length ] [ flex-algo flex-algo-id | [ level-1 | level-2 ] | verbose ] * [ process-id ]
ipv6-address prefix-length: Specifies a destination IPv6 address prefix and the prefix length. The value range for the prefix-length argument is 1 to 128.
flex-algo flex-algo-id: Specifies a Flex-Algo by its ID, in the range of 128 to 255. If you do not specify a Flex-Algo, this command displays locator route information calculated by all Flex-Algos.
level-1: Specifies the level-1 area.
level-2: Specifies the level-2 area.
verbose: Displays detailed IS-IS SRv6 locator information. If you do not specify this keyword, the command displays only brief IS-IS SRv6 locator information.
process-id: Specifies an IS-IS process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays IS-IS SRv6 locator information for all IS-IS processes.
# Display IS-IS SRv6 locator information.
<Sysname> display isis segment-routing ipv6 locator
Level-1 Locator Route Table
Destination : 201:: PrefixLen: 64
Flags : R/-/- Cost : 2
Next hop : FE80::38A5:3DFF:FEE9:218 Interface: XGE3/0/1
Destination : 202:: PrefixLen: 64
Flags : R/-/- Cost : 1
Next hop : FE80::38A5:3DFF:FEE9:218 Interface: XGE3/0/3
Destination |
Destination IPv6 prefix. |
PrefixLen |
Prefix length. |
Flag/Flags |
Route flags: · D—The route is a direct route. · R—The route has been flushed to the RIB. · L—The route has been advertised in LSPs. · U—Penetration flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2. |
Cost |
Route cost value. |
Next hop |
Route next hop. |
Output interface. |
# Display detailed IS-IS SRv6 locator route information.
<Sysname> display isis segment-routing ipv6 locator verbose
IPv6 dest : 5000::/64
Flag : D/L/- Cost : 0
Admin tag : - Src count : 1
Algorithm : 0
Priority : Low
Nexthop : Direct
NxthopFlag : -
Interface : NULL0 Delay Flag : N/A
Nib ID : 0x0
Level-2 Locator Route Table
Admin tag : - Src count : 4
Algorithm : 0
Priority : Low
Nexthop : Direct
NxthopFlag : -
Nib ID : 0x0
Table 5 Command output
Route information for IS-IS(1) |
Locator route information about the IS-IS process. |
Flex Algo Route Information for IS-IS(1) |
Locator route information for the specified Flex-Algo. |
Level-1 Locator Route Table |
IS-IS Level-1 locator route information. |
Level-2 Locator Route Table |
IS-IS Level-2 locator route information. |
Level-1 Flex Algo(xxx) Locator Route Table |
IS-IS Level-1 locator route information calculated by the Flex-Algo. The value xxx represents the Flex-Algo ID. |
Level-2 Flex Algo(xxx) Locator Route Table |
IS-IS Level-2 locator route information calculated by the Flex-Algo. The value xxx represents the Flex-Algo ID. |
IPv6 dest |
Destination IPv6 prefix |
Flag |
Route state flag: · D—Direct route. · R—The route has been added into the routing table. · L—The route has been advertised in an LSP. · U—Route leaking flag, indicating that the Level-1 route is from Level-2. U means that the route will not be returned to Level-2. |
Cost |
Route cost. |
Admin tag |
Administrative tag. |
Src count |
Number of advertisement sources. |
Algorithm |
Flexible algorithm ID. |
Priority |
Route convergence priority: · Critical. · High. · Medium. · Low. |
Next hop |
Next hop. If the route is a direct route, this field displays Direct. |
NxthopFlag |
Next hop flag. Value D indicates that the next hop is the direct next hop of the advertisement source. |
Output interface. |
Delay Flag |
Microloop avoidance delay flag: · D—Microloop avoidance is configured. Route convergence is delayed. · N/A—Microloop avoidance is not configured or the microloop avoidance delay timer has expired. Route convergence is in progress. |
Nib ID |
Next hop index assigned by the routing management module. |
display isis srv6 tunnel
Use display isis srv6 tunnel to display IS-IS SRv6 tunnel interface information.
display isis srv6 tunnel [ level-1 | level-2 ] [ process-id ]
process-id: Specifies an IS-IS process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays SRv6 tunnel interface information for all IS-IS processes.
If you do not specify a level, this command displays IS-IS SRv6 tunnel interface information for both level-1 and level-2 areas.
# Display SRv6 tunnel interface information for IS-IS process 1.
<Sysname> display isis srv6 tunnel
SRv6 tunnel information for IS-IS(1)
Level-1 tunnel statistics
Tunnel name Auto route Destination Metric
Tun0 Shortcut 1000::1 Relative 0
Level-2 tunnel statistics
Tun0 Shortcut 1000:: Relative 0
Table 6 Command output
Auto route |
Implementation method of automatic route advertisement on the tunnel interface: · Advertise—Forwarding adjacency. This method is not supported in the current software version. · Shortcut—IGP shortcut. |
Metric |
Metric of the tunnel interface. Supported metric types: · Relative. · Absolute. |
Use display ospfv3 segment-routing ipv6 capability to display OSPFv3 SRv6 capability information.
display ospfv3 [ process-id ] segment-routing ipv6 capability
process-id: Specifies an OSPFv3 process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays SRv6 capability information for all OSPFv3 processes.
# Display SRv6 capability information for all OSPFv3 processes.
<Sysname> display ospfv3 segment-routing ipv6 capability
OSPFv3 Process 1 with Router ID 1.1.1.1
Area 0.0.0.0
Router ID SRv6 capability
2.2.2.2 Enabled
Table 7 Command output
Router ID |
Device router ID. |
SRv6 capability |
Whether SRv6 is enabled. The value can only be Enabled. |
Use display ospfv3 segment-routing ipv6 locator to display OSPFv3 SRv6 locator information.
display ospfv3 [ process-id ] [ flex-algo flex-algo-id ] segment-routing ipv6 locator [ ipv6-address prefix-length ]
process-id: Specifies an OSPFv3 process by its ID, in the range of 1 to 65535. If you do not specify an OSPFv3 process, this command displays locator information for all OSPFv3 processes.
flex-algo flex-algo-id: Specifies a flexible algorithm by its ID. The value range for this argument is 128 to 255. If you do not specify this option, the command displays locator information for non-flexible algorithms.
ipv6-address prefix-length: Specifies an IPv6 address prefix and the prefix length. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120. If you do not specify this option, the command displays locator information for all IPv6 prefixes.
# Display locator information for all OSPFv3 processes.
<Sysname> display ospfv3 segment-routing ipv6 locator
I - Intra area route, E1 - Type 1 external route, N1 - Type 1 NSSA route
IA - Inter area route, E2 - Type 2 external route, N2 - Type 2 NSSA route
* - Selected route
*Destination: 192:168::12:0/120
Type : I Area : 0.0.0.0
AdvRouter : 2.2.2.2 Preference : 10
NibID : 0x23000002 Cost : 10
Interface : XGE3/0/1 BkInterface: N/A
Nexthop : ::
BkNexthop : N/A
Algorithm : 0
Status : Direct
Table 8 Command output
Destination |
Destination network. |
Type |
Route type. |
Area |
Area ID. |
AdvRouter |
ID of the router that advertises LSAs. |
Preference |
Route preference. |
NibID |
ID of the next hop information in the route. |
Cost |
Route cost. |
Output interface. |
BkInterface |
Backup output interface. |
Nexthop |
Next hop address. |
BkNexthop |
Backup next hop address. |
Algorithm |
Algorithm ID: · 0—SPF algorithm. · 128-255—Flexible algorithm. |
Status |
Route state: · Local—The route is a local route and has not been sent to the route management module. · Invalid—The next hop of the route is invalid. · Stale—The next hop of the route is stale. · Normal—The route is usable. · Delete—The route is deleted. · Direct—The route is a direct route. · Rely—The route is recursed by another route. |
display ospfv3 srv6 tunnel
Use display ospfv3 srv6 tunnel to display OSPFv3 SRv6 tunnel interface information.
display ospfv3 [ process-id ] srv6 tunnel [ interface-number ]
process-id: Specifies an OSPFv3 process by its ID, in the range of 1 to 65535. If you do not specify a process, this command displays SRv6 tunnel interface information for all OSPFv3 processes.
interface-number: Specifies an existing SRv6 tunnel interface by its interface number. If you do not specify an SRv6 tunnel interface, this command displays information about all SRv6 tunnel interfaces.
# Display SRv6 tunnel interface information for all OSPFv3 processes.
<Sysname> display ospfv3 srv6 tunnel
SRv6 Tunnel Information
Area: 0.0.0.0
Interface: Tunnel1
State : Active
Neighbor ID: 4.4.4.4
Cost : 1
Auto route : Shortcut
Metric : Absolute 1
Destination: 4::44
Table 9 Command output
Tunnel interface name. |
State |
Tunnel interface state: · Inactive—The next hop of the tunnel interface is not the optimal next hop. The tunnel interface is not used to forward traffic. · Active—The next hop of the tunnel interface is the optimal next hop. The tunnel interface is used to forward traffic. |
Neighbor ID |
Neighbor ID of the tunnel interface: · When the tunnel interface state is Inactive, the neighbor ID is 0.0.0.0, which indicates that the tunnel is not on the optimal path. · When the tunnel interface state is Active, the neighbor ID is the router ID of the tunnel destination end. |
Cost |
Route cost of the tunnel interface: · When the tunnel interface state is Inactive, this field displays 4294967295, which indicates that the tunnel is not on the optimal path. · When the tunnel interface state is Active, this field displays the cost of the route destined for the router ID of the tunnel destination end. |
Destination |
Tunnel destination address. |
Auto route |
Implementation method of automatic route advertisement on the tunnel interface. The value for this field is Shortcut, which represents IGP Shortcut. |
Metric |
Metric of the SRv6 tunnel interface. Supported metric types: · Absolute. · Relative. |
Use display segment-routing ipv6 available-static-sid to display available static SRv6 SIDs in a locator.
display segment-routing ipv6 available-static-sid locator locator-name [ from begin-value ]
locator locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters.
from begin-value: Specifies available static SRv6 SIDs that start from the specified value. The begin-value argument represents the start value in IPv6 address format. If you do not specify a start value, this command displays available static SRv6 SIDs starting from the smallest available one.
If you specify a static length when configuring an SRv6 locator, the device can allocate static SRv6 SIDs from the locator. Use this command to display a maximum of 10 available static SRv6 SIDs in the locator.
To specify the from begin-value option, you must first identify the static SID range of the locator. For this purpose, use the display segment-routing ipv6 locator command.
# Display available static SRv6 SIDs in locator abc.
<Sysname> display segment-routing ipv6 available-static-sid locator abc
Available static SRv6 SID table
200:1::1
200:1::2
200:1::3
200:1::4
200:1::5
200:1::6
200:1::7
200:1::8
200:1::9
200:1::A
Available static SRv6 CSID table
200:1::1:0:0
200:1::2:0:0
200:1::3:0:0
200:1::4:0:0
200:1::5:0:0
200:1::6:0:0
200:1::7:0:0
200:1::8:0:0
200:1::9:0:0
200:1::A:0:0
Table 10 Command output
Available static SRv6 SID table |
Available static non-compressible SRv6 SIDs. |
Available static SRv6 CSID table |
Available static compressible SRv6 SIDs. |
N/A |
No static SRv6 SIDs are available. |
Use display segment-routing ipv6 forwarding to display SRv6 forwarding entry information.
display segment-routing ipv6 forwarding [ entry-id [ relation ] | forwarding-type { srv6be | srv6frr | srv6pcpath | srv6pgroup | srv6policy | srv6sfc | srv6sidlist | srv6sids } ] [ slot slot-number ]
entry-id: Specifies an SRv6 forwarding entry by its ID. The value range for this argument is 0 to 4294967294. If you do not specify an SRv6 forwarding entry ID, this command displays information about all SRv6 forwarding entries.
relation: Displays information about entries associated with the specified entry.
forwarding-type: Specifies a forwarding type. If you do not specify a forwarding type, this command displays SRv6 forwarding information for all forwarding types.
srv6be: Specifies tunnels in SRv6 BE paths.
srv6frr: Specifies tunnels in SRv6 FRR.
srv6pcpath: Specifies tunnels in SRv6 TE policy candidate paths.
srv6pgroup: Specifies tunnels in SRv6 TE policy groups.
srv6policy: Specifies tunnels in SRv6 TE policies.
srv6sfc: Specifies tunnels in SRv6 SFCs.
srv6psidlist: Specifies tunnels defined by SID lists in SRv6 TE policies.
srv6sids: Specifies tunnels matching SRv6 SIDs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays SRv6 forwarding entries on the active MPU.
# Display all SRv6 forwarding entries.
<Sysname> display segment-routing ipv6 forwarding
Total SRv6 forwarding entries: 4
Flags: T – Forwarded through a tunnel
N – Forwarded through the outgoing interface to the nexthop IP address
A - Active forwarding information
B – Backup forwarding information
ID FWD-Type Flags Forwarding info
Attri-Val Attri-Val
2148532225 SRv6PSIDList NA XGE3/0/1
FE80::54CB:70FF:FE86:316
{6000::1, 7000::1, 8000::1}
2148532226 SRv6PSIDList NA XGE3/0/3
FE80::44A8:69FF:FE19:233
{22::16,
3:5:7000:1::,
[7000:5, 7000:4, 7000:3, 7000:2],
[7000:100],
3:5:8000:1::,
[8000:3, 8000:4]}
2149580801 SRv6PCPath TA 2148532225
2150629377 SRv6Policy TA 2149580801
Policy10
2153775105 SRv6SFC NA XGE3/0/1
Table 11 Command output
FWD-Type |
Tunnel forwarding type: · SRv6SIDs—Tunnel established based on SRv6 SIDs. · SRv6PSIDList—Tunnel established based on the SID list in an SRv6 TE policy. · SRv6PCPath—Tunnel established on the candidate path selected by an SRv6 TE policy. · SRv6Policy—SRv6 TE policy tunnel. · SRv6PGroup—SRv6 TE policy group tunnel. · SRv6BE—Tunnel established on the path selected in the SRv6-BE mode. · SRv6FRR—Tunnels to the primary and backup nexthops of SRv6 FRR. · SRv6SFC—Tunnels established based on SRv6 SFCs. |
Flags |
Forwarding flags: · T—Tunnel forwarding. · N—Output interface or next hop forwarding. · A—Active forwarding information. · B—Backup forwarding information. |
Forwarding info |
SRv6 forwarding information. · For the N forwarding flag, the forwarding information includes the output interface, next hop, and SID list. A SID in [xx:xx, xx:xx, xx:xx, xx:xx], [xx:xx, xx:xx, xx:xx], [xx:xx, xx:xx], or [xx:xx] format is composed of G-SIDs, where xx:xx represents a G-SID. Only the 32-bit G-SID compression mode (cos32) is supported, so such a SID can contain a maximum of four G-SIDs, listed in ascending order by SI. · For the T forwarding flag, the forwarding information is the SRv6 forwarding entry ID. |
Attri-Val |
Forwarding attribute. In the current software version, the value is an SRv6 TE policy name. This field is available only when the value for the FWD-Type field is SRv6Policy or SRv6PGroup. |
Use display segment-routing ipv6 local-sid to display information about the SRv6 local SID forwarding table.
display segment-routing ipv6 local-sid [ locator locator-name ] [ end | end-am | end-as | end-b6encaps | end-b6encapsred | end-b6insert | end-b6insertred | end-bier| end-coc-none | end-coc32 | end-dt2m | end-dt2u | end-dt2ul | end-dx2 | end-dx2l | end-m | end-op | end-r | end-rgb | end-t | end-xsid ] [ owner owner ] [ sid ]
display segment-routing ipv6 local-sid [ locator locator-name ] [ end-dt4 | end-dt46 | end-dt6 | end-dx4 | end-dx6 | src-dt4 | src-dt6 ] [ [ owner owner ] sid | vpn-instance vpn-instance-name ]
display segment-routing ipv6 local-sid [ locator locator-name ][ end-x | end-x-coc32 | end-x-coc-none ] [ sid | interface interface-type interface-number [ nexthop nexthop-ipv6-address ] ] [ owner owner ]
locator locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, this command displays information about the SRv6 local SID forwarding table for all locators.
end: Specifies End SIDs.
end-am: Specifies End.AM SIDs.
end-as: Specifies End.AS SIDs.
end-b6encaps: Specifies End.B6ENCAPS SIDs.
end-b6encapsred: Specifies End.B6ENCAPSRED SIDs.
end-b6insert: Specifies End.B6INSERT SIDs.
end-b6insertred: Specifies End.B6INSERTRED SIDs.
end-bier: Specifies End.BIER SIDs.
end-coc-none: Specifies End (COCNONE) SIDs.
end-coc32: Specifies End (COC32) SIDs.
end-dt2m: Specifies End.DT2M SIDs.
end-dt2u: Specifies End.DT2U SIDs.
end-dt2ul: Specifies End.DT2UL SIDs.
end-dt4: Specifies End.DT4 SIDs.
end-dt46: Specifies End.DT46 SIDs.
end-dt6: Specifies End.DT6 SIDs.
end-dx2: Specifies End.DX2 SIDs.
end-dx2l: Specifies End.DX2L SIDs.
end-dx4: Specifies End.DX4 SIDs.
end-dx6: Specifies End.DX6 SIDs.
end-m: Specifies End.M SIDs.
end-op: Specifies End.OP SIDs.
end-r: Specifies End.R SIDs.
end-rgb: Specifies End.RGB SIDs.
end-t: Specifies End.T SIDs.
end-xsid: Specifies End.XSID SIDs, which are the BSIDs of the reverse path in the SR-MPLS TE policy association with SBFD scenario.
end-x: Specifies End.X SIDs.
end-x-coc-none: Specifies End.X (COCNONE) SIDs.
end-x-coc32: Specifies End.X (COC32) SIDs.
src-dt4: Specifies Src.DT4 SIDs.
src-dt6: Specifies Src.DT6 SIDs.
sid: Specifies an SRv6 SID. If you do not specify an SRv6 SID, this command displays SRv6 local forwarding table information for all SRv6 SIDs of the specified type.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the SRv6 SIDs belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays SRv6 local SID forwarding table information in the public network.
interface interface-type interface-number: Specifies an output interface by its type and number. If you do not specify an output interface, the command displays SRv6 local SID forwarding table information for all End.X SIDs.
nexthop nexthop-ipv6-address: Specifies the IPv6 address of a next hop. If you do not specify a next hop, the command displays SRv6 local SID forwarding table information for all IPv6 next hops.
owner owner: Specifies a protocol. The value for the owner argument is case insensitive. The supported values include BGP, BIER, IS-IS, L2VPN, MVPN, NAT, OSPFv3, SIDMGR, and SRPolicy. If you do not specify a protocol, this command displays information about the SRv6 local SID forwarding table for all protocols.
# Display SRv6 local forwarding table information for all End SIDs.
<Sysname> display segment-routing ipv6 local-sid end
Local SID forwarding table (End)
Total SIDs: 1
SID : 100::64/96
Function type : End Flavor : PSP
Locator name : abc Allocation type: Static
Owner : SIDMGR State : Active
Create Time : May 19 17:21:15.687 2020
# Display SRv6 local forwarding table information for all End.X SIDs.
<Sysname> display segment-routing ipv6 local-sid end-x
Local SID forwarding table (End.X)
Total SIDs: 1
SID : 1000:0:0:15::/32
Function type : End.X Flavor : PSP
Interface : XGE3/0/1 Interface index: 0x102
Next hop : FE80::1 Allocation type: Static
Locator name : abc
Create Time : May 19 17:21:46.740 2020
# Display SRv6 local forwarding table information for all End.DT4 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dt4
Local SID forwarding table (End.DT4)
Total SIDs: 1
SID : 6:5::1:1/120
Function type : End.DT4 Flavor : PSP
VPN instance : vpn1 Allocation type: Static
Network type : MPLS L3VPN
Locator name : abc
Create Time : May 19 17:22:27.356 2020
# Display SRv6 local forwarding table information for all End.DT6 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dt6
Local SID forwarding table (End.DT6)
Total SIDs: 1
SID : 1:2::2:2/120
Function type : End.DT6 Flavor : PSP
Locator name : abc
# Display SRv6 local forwarding table information for all End.OP SIDs.
<Sysname> display segment-routing ipv6 local-sid end-op
Local SID forwarding table (End.OP)
Total SIDs: 1
SID : 100::190/96
Function type : End.OP
Locator name : abc
Create Time : May 19 17:23:40.248 2020
# Display SRv6 local forwarding table information for all End.DX2 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dx2
Local SID forwarding table (End.DX2)
Total SIDs: 1
SID : 100:1:2:3::6400/96
Function type : End.DX2 Flavor : PSP
Xconnect-group: abc Connection : test
VSI name : Service ID : 0
Interface :
Create Time : May 20 09:17:58.995 2020
# Display SRv6 local forwarding table information for all End.DT2U SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dt2u
Local SID forwarding table (End.DT2U)
Total SIDs: 1
SID : 100:1:2:3::C800/96
Function type : End.DT2U Flavor : PSP
VSI name : abc Allocation type: Static
Locator name : abc
Create Time : May 20 09:18:14.504 2020
# Display SRv6 local forwarding table information for all End.DX4 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dx4
Local SID forwarding table (End.DX4)
Total SIDs: 1
SID : 100::1:0:4/64
Function type : End.DX4 Flavor : PSP
Interface : GE1/0/1 Interface index: 0x11d
Nexthop : 10.1.1.1
VPN instance : vpn1 Allocation type: Dynamic
Locator name : bbb
Owner : BGP State : Active
Create Time : Jun 09 19:30:25.467 2020
# Display SRv6 local forwarding table information for all End.R SIDs.
<Sysname> display segment-routing ipv6 local-sid end-r
Local SID forwarding table (End.R)
Total SIDs: 1
SID : 100::1:0:6/64
Function type : End.R Flavor : PSP
Prefix SID1 : 1000::1:0:2 NexthopID1 : 2
Prefix SID2 : 1001::1:0:3 NexthopID2 : 3
Locator name : a Allocation type: Dynamic
Create Time : Jun 26 09:48:23.435 2023
# Display SRv6 local forwarding table information for all End.XSID SIDs.
<Sysname> display segment-routing ipv6 local-sid end-xsid
Local SID forwarding table (End.XSID)
Total SIDs: 1
SID : 7000::5/64
Function type : End.XSID Flavor : PSP
Locator name : c Allocation type: Static
Owner : SRPolicy State : Active
Create Time : Jun 15 11:52:59.621 2023
# Display SRv6 local forwarding table information for all End.DX6 SIDs.
<Sysname> display segment-routing ipv6 local-sid end-dx6
Local SID forwarding table (End.DX6)
Total SIDs: 1
SID : 100::2/64
Function type : End.DX6 Flavor : PSP
Nexthop : 100::10
Locator name : aaa
Create Time : Jun 09 19:41:36.749 2020
# Display SRv6 local forwarding table information for all End.M SIDs.
<Sysname> display segment-routing ipv6 local-sid end-m
Local SID forwarding table (End.M)
Total SIDs: 1
SID : 9:7::1:1/120
Function type : End.M Flavor : --
Locator name : ccc Allocation type: Static
Mirror locator number: 1
Mirror locator: 6:5::1:0/120
Create Time : Nov 02 09:48:23.435 2020
# Display SRv6 local forwarding table information for End.AS SIDs in Layer 2 encapsulation forwarding scenario.
<Sysname> display segment-routing ipv6 local-sid end-as
Local SID forwarding table (End.AS)
Total SIDs: 1
Function type : End.AS Allocation type: Static
Locator name : abc Forward type : L2
Inner type : IPv4 Source address : 2::60
Backup SID : 1::AA Peer SID : 300::3
Bypass : Enabled Bypass SID : 5::9
TTL mode : Uniform TTL value : -
Diffserv mode : Uniform Service class : -
Color : - Cache SL : 2
Cache list :
4::3
7::8
8::9
1::16::9
Forward No-bypass : Enabled
Encapsulation count: 2
Out-interface: XGE3/0/1 In-interface : XGE3/0/1
Out-S-VLAN : 100 Out-C-VLAN : -
In-S-VLAN : 200 In-C-VLAN : -
Dest MAC : 0056-00aa-00cb
Out-interface: XGE3/0/2 In-interface : XGE3/0/1
Out-S-VLAN : 101 Out-C-VLAN : -
In-S-VLAN : 201 In-C-VLAN : -
Dest MAC : 0056-00aa-00cd
Flags : F
# Display SRv6 local forwarding table information for End.AS SIDs in Layer 3 encapsulation forwarding scenario.
Total SIDs: 1
Locator name : abc Forward type : L3
Color : - Cache-SL : 2
Cache list :
4::3
7::8
8::9
1::16::9
Next hop : 10.1.1.2 Out-interface : XGE3/0/2
In-interface : XGE3/0/2 Symmetric-index: 1
Next hop : 10.1.1.3 Out-interface : XGE3/0/1
In-interface : XGE3/0/1 Symmetric-index: 2
Flags : F
# Display SRv6 local forwarding table information for all End.RGB SIDs.
<Sysname> display segment-routing ipv6 local-sid end-rgb
Local SID forwarding table (End.RGB)
Total SIDs: 2
SID : 100:1:0:D::/48
Function type : End.RGB
Locator name : b Allocation type: Static
Owner : BIER State : Active
Create Time : Aug 14 17:13:46.380 2023
# Display SRv6 local forwarding table information for End.AM SIDs in the Layer 3 encapsulation forwarding scenario.
<Sysname> display segment-routing ipv6 local-sid end-am
Local SID forwarding table (End.AM)
Total SIDs: 1
Function type : End.AM Allocation type: Static
Next hop : 1::1 Out-interface : GE1/0/2
In-interface : GE1/0/2
Next hop : 1::2 Out-interface : GE1/0/1
In-interface : GE1/0/1
Flags : F
# Display SRv6 local forwarding table information for End.AM SIDs in the Layer 2 encapsulation forwarding scenario.
Total SIDs: 1
Out-interface: GE1/0/1 In-interface : GE1/0/1
Out-interface: GE1/0/2 In-interface : GE1/0/2
Flags : F
Table 12 Command output
SID |
SRv6 SID. |
Function type |
SRv6 SID type: · End. · End.AM. · End.AS. · End.B6.Encaps. · End.B6.Encaps.Red. · End.B6.Insert. · End.B6.Insert.Red. · End.BIER. · End (COCNONE). · End.DT2M. · End.DT2U. · End.DT2UL. · End.DT4. · End.DT46. · End.DT6. · End.DX2. · End.DX2L. · End.M. · End.OP. · End.R · End.RGB · End.X. · End.XSID · End.X (COCNONE). · End.DX4. · End.DX6. · End.T. · Src.DT4. · Src.DT6. |
Flavor |
SRv6 SID flavor type: · NO-FLAVOR—The SRv6 SID does not carry any flavors. · PSP—The penultimate SRv6 node removes the SRH. · PSP,USP,USD—The SRv6 SID carries the PSP, USP, and USD flavors. · NOPSP—The penultimate SRv6 node does not remove the SRH. · COC—The next SID is a G-SID. |
Prefix SID1 |
SRv6 SID that is associated with End.R SIDs and carried in the BGP route. After you configure the srv6-inter-as enable command, the device will request a new End.R SID for the BGP route based on this SRv6 SID. |
NexthopID1 |
Next hop ID of the SRv6 SID that is associated with End.R SIDs and carried in the BGP route. |
Prefix SID2 |
SRv6 SID that is associated with End.R SIDs and carried in the BGP route. After you configure the srv6-inter-as enable command, the device might request the same End.R SID for BGP routes that carry different SRv6 SIDs for load sharing. This field is not displayed if the srv6-inter-as enable command is not configured. |
NexthopID2 |
Next hop ID of the SRv6 SID that is associated with End.R SIDs and carried in the BGP route. This field is not displayed if the srv6-inter-as enable command is not configured. |
Peer-set name |
Output interface. |
Interface index |
Output interface index. |
Member port |
Member port of a Layer 3 aggregate group. |
Port index |
Index of the member port. |
Next hop |
Next hop address. |
VPN instance |
VPN instance name. For the public network, this field displays Public instance. |
Xconnect group |
Cross-connect group name. |
Connection |
Cross-connect name. |
VSI name |
VSI name. |
Service ID |
Ethernet service instance ID. If no Ethernet service instance ID exists, this field displays 0. |
Allocation type |
SID allocation type: · Static—Manually configured. · Dynamic—Dynamically allocated. |
Network type |
Type of the network to which the SRv6 SID is applied: · MPLS L3VPN—The SRv6 SID is applied to an MPLS L3VPN network. · EVPN L3VPN—The SRv6 SID is applied to an EVPN L3VPN network. · MPLS L3VPN, EVPN L3VPN—The SRv6 SID is applied to MPLS L3VPN and EVPN L3VPN networks. · MULTICAST VPN—The SRv6 SID is applied to a multicast VPN network. |
Mirror locator number |
Number of protected locators. |
Mirror locator |
IPv6 address prefix and prefix length of each protected locator. |
Owner |
Protocol that applies for the SID: · SIDMGR. · BGP. · BIER. · SRPolicy. · IS-IS. · OSPFv3. · L2VPN. · LSM. · MVPN. · VSRP. · NAT. |
State |
SID state: · Active. · Inactive. |
Create Time |
SID creation time. |
Forward type |
SFF-to-SF packet forwarding type: · L2—Layer 2 forwarding. · L3—Layer 3 forwarding. |
Inner type |
Protocol type of the original SFF-to-SF packet that the SFF supports. |
Source address |
Source IPv6 address re-encapsulated for the packet received by the SFF from the SF. |
Backup SID |
Backup End.AS SID. |
Peer SID |
Backup SFF SID, which is the End SID. |
Bypass |
Bypass protection status: Enabled or disabled (-). |
Bypass SID |
Backup SID of the bypass path, which is the valid End.AS SID of other protection devices in the SF group. |
TTL mode |
TTL processing mode: · Uniform—After a packet is forwarded back to the SFF from the SF, the SFF uses the TTL value in the original packet minus 1 as the TTL in the newly encapsulated IPv6 header. · Pipe—After a packet is forwarded back to the SFF from the SF, the SFF uses the specified TTL value (ttl-value) minus 1 as the TTL in the newly encapsulated IPv6 header. |
TTL value. |
TTL value: · In Uniform TTL processing mode, a hyphen (-) is displayed. · In Pipe TTL processing mode, the configured TTL value is displayed. |
Diffserv mode |
Differentiated services (Diffserv) mode: · Uniform—In the inbound direction (SF to SFF), the SFF maps the carried IP or DSCP value to the priority in the newly encapsulated IPv6 header. The packet color will not be changed. In the outbound direction (SFF to SF), the SFF removes the outer IPv6 and SRH header. Then it maps the priority in the outer IPv6 header to the IP or DSCP value in the original packet. The packet color will not be changed. · Pipe—In the inbound direction (SF to SFF), the SFF ignores the carried IP or DSCP value. It uses the configured service-class value as the priority in the newly encapsulated IPv6 header, and the configured color value as the color for the new packet. In SRv6 networks, QoS scheduling is performed for packets based on the priority and color values. In the outbound direction (SFF to SF), the SFF removes the outer IPv6 and SRH header without modifying the IP or DSCP value and color in the original packet. |
Service class |
Diffserv class of the service chain. Values include the following in ascending priority order: · be · af1 · af2 · af3 · af4 · ef · cs6 · cs7 If no Diffserv class is configured, a hyphen (-) is displayed. |
Color |
Packet color. Values include the following in ascending order of packet loss probability: · green—Indicates packet loss probability 0. · yellow—Indicates packet loss probability 1. · red—Indicates packet loss probability 2. If no Diffserv class is configured, a hyphen (-) is displayed. |
Cache-SL |
Segment left value, which indicates the number of nodes to access in the SID list before arrival at the final destination. |
Cache list |
SID list that needs to be encapsulated after the SFF receives the packet from the SF. |
Forward no-bypass |
Status of the No-Bypass feature for the SRv6 service chain in static proxy mode. · Enabled. · Disabled. |
Encapsulation count |
Number of equal-cost paths between the SFF and SF. |
Out-Interface |
Outbound interface for the SFF to forward packets to the SF. |
In-Interface |
Inbound interface for the SFF to receive packets from the SF. |
Out-S-VLAN |
Outer VLAN ID for SFF-to-SF (outbound) packets. |
Out-C-VLAN |
Inner VLAN ID for SFF-to-SF (outbound) packets. |
In-S-VLAN |
Outer VLAN ID for SF-to-SFF (inbound) packets. |
In-C-VLAN |
Inner VLAN ID for SF-to-SFF (inbound) packets. |
Dest MAC |
Destination MAC address encapsulated for packets from the SF to the remote backup SFF in Layer 2 forwarding. |
Symmetric-index |
Index that identifies a VM used for forwarding bidirectional traffic when multiple VMs exist on the SF. Both inbound and outbound traffic with the same source and destination addresses will traverse the same VM. |
Use display segment-routing ipv6 local-sid statistics to display statistics about SRv6 SIDs allocated for each protocol.
display segment-routing ipv6 local-sid statistics [ locator [ locator-name ] ]
locator: Displays statistics about SRv6 SIDs allocated for each protocol by locator. If you do not specify this keyword, the command does not display statistics about SRv6 SIDs allocated for each protocol by locator.
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, the command displays statistics about SRv6 SIDs for all locators.
# Display statistics about SRv6 SIDs allocated for each protocol (not by locator).
<Sysname> display segment-routing ipv6 local-sid statistics
Total SIDs: 0
Funtion SIDMGR IS-IS OSPFv3 BGP L2VPN VSRP NAT Total
End 0 0 0 0 0 0 0 0
End.X 0 0 0 0 0 0 0 0
End.COC32 0 0 0 0 0 0 0 0
End.XCOC32 0 0 0 0 0 0 0 0
End.COCNONE 0 0 0 0 0 0 0 0
End.XCOCNONE 0 0 0 0 0 0 0 0
End.DT4 0 0 0 0 0 0 0 0
End.DT46 0 0 0 0 0 0 0 0
End.DT6 0 0 0 0 0 0 0 0
End.DX4 0 0 0 0 0 0 0 0
End.DX6 0 0 0 0 0 0 0 0
End.DX2 0 0 0 0 0 0 0 0
End.DX2L 0 0 0 0 0 0 0 0
End.DT2M 0 0 0 0 0 0 0 0
End.DT2U 0 0 0 0 0 0 0 0
End.DT2UL 0 0 0 0 0 0 0 0
End.M 0 0 0 0 0 0 0 0
End.OP 0 0 0 0 0 0 0 0
End.T 0 0 0 0 0 0 0 0
End.AS 0 0 0 0 0 0 0 0
End.R 0 0 0 0 0 0 0 0
Funtion SRP BIER MVPN Total
End.B6Encaps 0 0 0 0
End.B6EncapsRed 0 0 0 0
End.B6Insert 0 0 0 0
End.B6InsertRed 0 0 0 0
End.BIER 0 0 0 0
Src.DT4 0 0 0 0
Src.DT6 0 0 0 0
End.RGB 0 0 0 0
End.XSID 0 0 0 0
# Display statistics about SRv6 SIDs allocated for each protocol from locator abc.
<Sysname> display segment-routing ipv6 local-sid statistics locator abc
Locator: abc
Total SIDs: 0
End 0 0 0 0 0 0 0 0
End.BIER 0 0 0 0
Src.DT4 0 0 0 0
Src.DT6 0 0 0 0
End.RGB 0 0 0 0
End.XSID 0 0 0 0
Table 13 Command output
Total SIDs |
Total number of SRv6 SIDs. If you specify a locator, this field displays the total number of SRv6 SIDs that belong to the specified locator. |
Locators |
Locator name. |
Function |
SRv6 SID type: · End. · End.X. · End.COC32 · End.XCOC32 · End.COCNONE · End.XCOCNONE · End.DT4. · End.DT46. · End.DT6. · End.DX4. · End.DX6. · End.DX2. · End.DX2L. · End.DT2M. · End.DT2U. · End.DT2UL. · End.M. · End.OP. · End.R. · End.T. · End.AS. · End.B6Encaps. · End.B6EncapsRed. · End.B6Insert. · End.B6InsertRed. · End.BIER. · Src.DT4. · Src.DT6. · End.RGB. · End.XSID. |
SIDMGR |
Static SIDs. |
IS-IS |
SRv6 SIDs allocated for IS-IS. |
OSPFv3 |
SRv6 SIDs allocated for OSPFv3. |
BGP |
SRv6 SIDs allocated for BGP. |
L2VPN |
SRv6 SIDs allocated for L2VPN. |
VSRP |
SRv6 SIDs allocated for VSRP. |
NAT |
SRv6 SIDs allocated for NAT. |
SRP |
BSIDs dynamically allocated for SRv6 TE policies. |
BIER |
SRv6 SIDs allocated for BIER. |
MVPN |
SRv6 SIDs allocated for MVPN. |
Total |
Total number for a type of SRv6 SIDs. |
Use display segment-routing ipv6 locator to display SRv6 locator information.
display segment-routing ipv6 locator [ locator-name ]
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, this command displays information about all locators.
# Display information about all locators. (The coc-both keyword is not specified when you configure locators.)
<Sysname> display segment-routing ipv6 locator
Locator configuration table
Locator name : test1 Flag(A) : 0
IPv6 prefix : 100:200:DB8:ABCD:: Prefix length : 64
Static length : 8 Args length : 16
Common prefix length: 0
Algorithm : 0
Auto SID start : 100:200:DB8:ABCD::100:0
Auto SID end : 100:200:DB8:ABCD:FFFF:FFFF:FFFF:0
Static SID start : 100:200:DB8:ABCD::1:0
Static SID end : 100:200:DB8:ABCD::FF:0
Compressed Auto SID count : 0
Compressed Static SID count : 0
Non-compressed Auto SID count : 0
Non-compressed Static SID count: 0
# Display information about all locators. (The coc-both keyword is specified when you configure locators.)
Common prefix length: 48 Non-compressed static length : 16
Algorithm : 0
Compressed auto SID start : 100:200:DB8:ABCD:100::
Compressed auto SID end : 100:200:DB8:ABCD:FFFF::
Compressed static SID start : 100:200:DB8:ABCD:1::
Compressed static SID end : 100:200:DB8:ABCD:FF::
Non-compressed auto SID start : 100:200:DB8:ABCD:0:1::
Non-compressed auto SID end : 100:200:DB8:ABCD:0:FFFF:FFFF:0
Non-compressed static SID start: 100:200:DB8:ABCD::1:0
Non-compressed static SID end : 100:200:DB8:ABCD::FFFF:0
Reserved SID start : N/A
Reserved SID count : 0
Reserved SID end : N/A
Table 14 Command output
Algorithm |
Algorithm ID: · 0—SPF algorithm. · 128 to 255—Flex-Algo algorithm. |
Flag(A) |
Anycast locator flag (A-bit). If A-bit is set, the locator is an anycast locator. |
IPv6 prefix |
IPv6 address prefix of the locator. |
Prefix length |
Prefix length of the locator. |
Static length |
Static length of the locator. |
Args length |
Argument length. |
Common prefix length |
Common prefix length of the locator. |
Non-compressed static length |
Static length of the locator for non-compressible SRv6 SIDs. |
Auto SID start |
Start dynamic SRv6 SID. If no dynamic SRv6 SIDs exist, this field displays N/A. |
Auto SID end |
End dynamic SRv6 SID. If no dynamic SRv6 SIDs exist, this field displays N/A. |
Static SID start |
Start static SRv6 SID. If no static SRv6 SIDs exist, this field displays N/A. |
Static SID end |
End static SRv6 SID. If no static SRv6 SIDs exist, this field displays N/A. |
Compressed auto SID start |
Start value for compressible dynamic SRv6 SIDs. If no compressible dynamic SRv6 SIDs exist, this field displays N/A. |
Compressed auto SID end |
End value for compressible dynamic SRv6 SIDs. If no compressible dynamic SRv6 SIDs exist, this field displays N/A. |
Compressed static SID start |
Start value for compressible static SRv6 SIDs. If no compressible static SRv6 SIDs exist, this field displays N/A. |
Compressed static SID end |
End value for compressible static SRv6 SIDs. If no compressible static SRv6 SIDs exist, this field displays N/A. |
Non-compressed auto SID start |
Start value for non-compressible dynamic SRv6 SIDs. If no non-compressible dynamic SRv6 SIDs exist, this field displays N/A. |
Non-compressed auto SID end |
End value for non-compressible dynamic SRv6 SIDs. If no non-compressible dynamic SRv6 SIDs exist, this field displays N/A. |
Non-compressed static SID start |
Start value for non-compressible static SRv6 SIDs. If no non-compressible static SRv6 SIDs exist, this field displays N/A. |
Non-compressed static SID end |
End value for non-compressible static SRv6 SIDs. If no non-compressible static SRv6 SIDs exist, this field displays N/A. |
Reserved SID start |
Start value for reserved SRv6 SIDs. If no start value is specified for SRv6 SID reservation, this field displays N/A. |
Reserved SID count |
Number of reserved SRv6 SIDs. |
Reserved SID end |
End value for reserved SRv6 SIDs. If no end value is specified for SRv6 SID reservation, this field displays N/A. |
Compressed Auto SID count |
Number of dynamic compressible SRv6 SIDs. |
Compressed Static SID count |
Number of static compressible SRv6 SIDs. |
Non-compressed Auto SID count |
Number of dynamic non-compressible SRv6 SIDs. |
Non-compressed Static SID count |
Number of static non-compressible SRv6 SIDs. |
Use display segment-routing ipv6 locator-statistics to display SRv6 locator configuration and statistics about allocated SRv6 SIDs in locators.
display segment-routing ipv6 locator-statistics [ locator-name ]
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a locator, this command displays SRv6 locator configuration and statistics about allocated SRv6 SIDs in all locators.
# Display SRv6 locator configuration and statistics about allocated SRv6 SIDs in all locators.
<Sysname> display segment-routing ipv6 locator-statistics
Total Locators: 1 Total SIDs: 1
Name IPv6 prefix/Prefix length CDyn/CStatic/Dyn/Static Flag Algo
abc 100:1::/64 0 /0 /0 /1 0 0
Table 15 Command output
Total Locators |
Total number of locators. |
Total SIDs |
Total number of SIDs that have been allocated in the locators. |
Name |
Locator name. |
IPv6 prefix/Prefix length |
Locator prefix and prefix length. |
CDyn/CStatic/Dyn/Static |
Number of dynamic compressible SRv6 SIDs, number of static compressible SRv6 SIDs, number of dynamic non-compressible SRv6 SIDs, and number of static non-compressible SRv6 SIDs. |
Flag |
Anycast locator flag (A flag). The value is 1 if this flag is set, which indicates that the locator is an anycast locator. |
Algo |
Use display segment-routing ipv6 remote-locator to display remote SRv6 locator information.
display segment-routing ipv6 remote-locator [ remote-locator-name ]
remote-locator-name: Specifies a remote locator by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a remote locator, this command displays information about all remote locators.
# Display information about all remote locators.
<Sysname> display segment-routing ipv6 remote-locator
Remote locator configuration table
Remote locator name : abc
IPv6 prefix : 100:1:: Prefix length : 64
Static length : 8 Args length : 8
Auto remote SID start : 100:1::1:0
Auto remote SID end : 100:1::FFFF:FFFF:FFFF:FF00
Static remote SID start : 100:1::100
Static remote SID end : 100:1::FF00
Table 16 Command output
IPv6 prefix |
IPv6 address prefix of the remote locator. |
Prefix length |
Prefix length of the remote locator. |
Static length |
Static length of the remote locator. |
Args length |
Argument length. |
Auto remote SID start |
Auto remote SID end |
Static remote SID start |
Static remote SID end |
Use display segment-routing ipv6 remote-sid to display remote SRv6 SID information .
display segment-routing ipv6 remote-sid { end-dx2 | end-dx2l } [ sid ]
sid: Specifies an SRv6 SID. If you do not specify an SRv6 SID, this command displays information about all remote SRv6 SIDs of the specified type.
# Display information about all remote SRv6 SIDs of the End.DX2 type.
<Sysname> display segment-routing ipv6 remote-sid end-dx2
Remote SID forwarding table (End.DX2)
Total remote SIDs: 1
SID : 100:1::100/64
Xconnect-group: abc Connection : abc
Interface :
Remote locator name: abc Allocation type: Static
Owner : L2VPN State : Active
Create Time : Jan 27 09:59:34.541 2022
# Display information about all remote SRv6 SIDs of the End.DX2L type.
<Sysname> display segment-routing ipv6 remote-sid end-dx2l
Remote SID forwarding table (End.DX2L)
SID : 200:1::100/64
Function type : End.DX2L Flavor : PSP
Xconnect-group: vpna Connection : a
Interface :
Remote locator name: bbb Allocation type: Static
Create Time : Nov 15 20:36:04.528 2021
Table 17 Command output
SID |
SRv6 SID. |
Function type |
SRv6 SID type: · End.DX2. · End.DX2L. |
Flavor |
SRv6 SID flavor type: · PSP—The penultimate SRv6 node removes the SRH. · NOPSP—The penultimate SRv6 node does not remove the SRH. |
Xconnect group |
Connection |
VSI name |
VSI name. |
Service ID |
Output interface. If no output interface exists, this field displays 0. |
Allocation type |
Owner |
Protocol that applies for the SID: · L2VPN. |
State |
Create Time |
egress-engineering link-delay
Use egress-engineering link-delay to configure the link delay information to be reported by BGP to the controller.
Use undo egress-engineering link-delay to restore the default.
egress-engineering link-delay { average average-delay-value | min min-delay-value max max-delay-value | variation variation-value } * interface interface-type interface-number
undo egress-engineering link-delay { average | min | variation } * interface interface-type interface-number
No link delay information is configured.
BGP instance view
average average-delay-value: Specifies the average delay time of the interface, in the range of 1 to 16777215, in microseconds. The average delay is the average value of all delays for the IP data packets sent from the local interface to the BGP neighbor. If you do not specify this option, BGP uses the average delay advertised by the interface.
min min-delay-value max max-delay-value: Specifies the minimum and maximum delay time of the interface, in the range of 1 to 16777215, in microseconds. The minimum and maximum delays are the minimum and maximum delays among all delays for the IP data packets sent from the local interface to the BGP neighbor. If you do not specify this option, BGP uses the minimum and maximum delays advertised by the interface.
variation variation-value: Specifies the delay variation of the interface, in the range of 1 to 16777215, in microseconds. The delay variation refers to the difference between average delays. If you do not specify this option, BGP uses the delay variation advertised by the interface.
interface interface-type interface-number: Specifies the interface to be configured with the delay information. Only physical interfaces are supported.
BGP can obtain delay information of interfaces in the following methods:
· Static configuration: Use this command to configure the interface delay information for BGP.
· Dynamic obtaining: Use the test-session bind interface command to bind a TWAMP-light test session to an interface. TWAMP-light sends the collected delay information to the bound interface, which then reports the delay information to BGP.
If BGP obtains delay information in both methods, it uses the statically configured delay information.
If you execute this command multiple times for the same interface, the most recent configuration for each delay parameter takes effect.
The minimum delay value must be smaller than the maximum delay value.
# Configure the average delay, minimum delay, maximum delay, and delay variation of interface Ten-GigabitEthernet 3/0/1 as 100, 10, 1000, and 20 microseconds, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering link-delay average 100 min 10 max 1000 variation 20 interface ten-gigabitethernet 3/0/1
test-session bind interface (Network Management and Monitoring Command Reference)
egress-engineering link-loss
Use egress-engineering link-loss to configure the packet loss rate for a BGP-EPE interface.
Use undo egress-engineering link-loss to restore the default.
egress-engineering link-loss loss-value interface interface-type interface-number
undo egress-engineering link-loss interface interface-type interface-number
No packet loss rate is configured for a BGP-EPE interface.
BGP instance view
loss-value: Specifies the packet loss rate of the interface, in the range of 1 to 16777214, in a unit of 0.000003%.
interface interface-type interface-number: Specifies the interface to be configured with the packet loss rate.
BGP can obtain packet loss information of BGP-EPE interfaces in the following methods:
· Static configuration—Use this command to configure the packet loss rate for a BGP-EPE interface.
· Dynamic obtaining—Use the test-session bind interface command to bind a TWAMP-light test session to an interface. TWAMP-light sends the collected packet loss rate to the bound interface, which then reports the packet loss rate to BGP. For more information about TWAMP-light, see NQA TWAMP-light configuration in Network Management and Monitoring Configuration Guide.
If BGP obtains packet loss information in both methods, it uses the statically configured packet loss rate.
If you execute this command multiple times for the same interface, the most recent configuration takes effect.
# Configure the packet loss rate of interface Ten-GigabitEthernet 3/0/1 as 1000*0.000003%.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering link-loss 1000 interface ten-gigabitethernet 3/0/1
egress-engineering metric-bandwidth advertisement enable
Use egress-engineering metric-bandwidth advertisement enable to enable bandwidth advertisement.
Use undo egress-engineering metric-bandwidth advertisement enable to disable bandwidth advertisement.
Bandwidth advertisement is disabled.
BGP instance view
In scenarios where BGP-LS reports link states to a controller for path computation, configure this feature on BGP-EPE devices to enable BGP to collect and propagate intra-AS link bandwidth information and report the information to the controller through BGP-LS. The controller then uses the bandwidth information to compute paths to ensure that the optimal path has the most bandwidth.
# Enable bandwidth advertisement for a BGP instance.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering metric-bandwidth advertisement enable
egress-engineering metric-bandwidth suppression
Use egress-engineering metric-bandwidth suppression to enable bandwidth advertisement suppression for BGP and set the suppression parameters.
Use undo egress-engineering metric-bandwidth suppression to restore the default.
egress-engineering metric-bandwidth suppression timer time-value
Bandwidth advertisement suppression of BGP is enabled, and the bandwidth advertisement suppression timer is 120 seconds.
BGP instance view
timer time-value: Sets the bandwidth advertisement suppression timer, in the range of 0 to 600 seconds. A value of 0 means to disable bandwidth advertisement suppression.
When bandwidth changes frequently, BGP will frequently process, advertise, and report the bandwidth information, occupying too many device resources. To resolve this issue, you can enable the bandwidth advertisement suppression feature.
After this feature is enabled, interfaces report bandwidth information to BGP at intervals of the bandwidth advertisement suppression time. BGP advertises and reports bandwidth information at intervals of the bandwidth advertisement suppression time. It cannot advertise or report bandwidth information before the suppression timer expires.
This command takes effect only after the egress-engineering metric-bandwidth advertisement enable command is enabled.
# Enable bandwidth advertisement suppression and set the suppression timer to 100 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering metric-bandwidth suppression timer 100
egress-engineering metric-delay advertisement enable
Use egress-engineering metric-delay advertisement enable to enable delay advertisement for BGP.
Use undo egress-engineering metric-delay advertisement enable to disable delay advertisement for BGP.
Delay advertisement is disabled.
BGP instance view
In scenarios where BGP-LS reports link states to a controller for path computation, configure this feature on BGP-EPE devices to enable BGP to collect and propagate intra-AS link delay information and report the information to the controller through BGP-LS. The controller then uses the delay information to compute paths to ensure that the optimal path has the least delay.
# Enable delay advertisement in a BGP instance.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering metric-delay advertisement enable
egress-engineering metric-delay suppression
Use egress-engineering metric-delay suppression to enable delay advertisement suppression for BGP and set the suppression parameters.
Use undo egress-engineering metric-delay suppression to restore the default.
egress-engineering metric-delay suppression timer time-value percent-threshold percent-value absolute-threshold absolute-value
Delay advertisement suppression is enabled, and the suppression timer is 120 seconds, the delay change percentage threshold is 10%, and the delay change absolute value threshold is 1000 microseconds.
BGP instance view
timer time-value: Specifies the delay advertisement suppression timer, in the range of 0 to 600 seconds. A value of 0 means to disable delay advertisement suppression.
percent-threshold percent-value: Specifies the delay change percentage threshold, in the range of 0 to 100. A value of 0 means not to concern the delay change percentage during suppression.
absolute-threshold absolute-value: Specifies the delay change absolute value threshold, in the range of 0 to 10000. A value of 0 means not to concern the delay change absolute value during suppression.
When delay changes frequently, BGP will frequently process, advertise, and report the delay information, occupying too many device resources. To resolve this issue, you can enable the delay advertisement suppression feature.
Delay advertisement suppression operates as follows:
1. After this feature is enabled, interfaces report delay information to BGP at intervals of the delay advertisement suppression time.
2. BGP advertises and reports delay information at intervals of the delay advertisement suppression time. It cannot advertise or report delay information before the suppression timer expires except in the following cases:
¡ If the percentage of the change between two consecutive delays reported by an interface reaches or exceeds the threshold set by percent-value, BGP advertises and reports the delay information regardless of whether the suppression timer has expired or not.
¡ If the absolute value of change between two consecutive delays reported by an interface reaches or exceeds the threshold set by absolute-value, BGP advertises and reports the delay information regardless of whether the suppression timer has expired or not.
This command takes effect only after the egress-engineering metric-delay advertisement enable command is enabled.
If a suppression parameter is set to 0, the corresponding suppression function is disabled. If all the suppression parameters are set to 0, the entire delay advertisement suppression feature is disabled.
# Enable delay advertisement suppression for BGP, set the suppression timer to 100 seconds, the delay change percentage threshold to 50%, and delay change absolute value threshold to 200 microseconds.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering metric-delay suppression timer 100 percent-threshold 50 absolute-threshold 200
egress-engineering metric-link-loss advertisement enable
Use egress-engineering metric-link-loss advertisement enable to enable packet loss rate advertisement for BGP-EPE.
Use undo egress-engineering metric-link-loss advertisement enable to disable packet loss rate advertisement for BGP-EPE.
Packet loss rate advertisement is disabled for BGP-EPE.
BGP instance view
· Static configuration—Use the egress-engineering link-loss command to configure the packet loss rate for a BGP-EPE interface.
In scenarios where BGP-LS reports link states to a controller for path computation, configure the packet loss rate advertisement feature on BGP-EPE devices. Then, BGP can collect packet loss information locally and from the BGP-EPE neighbors and report the information to the controller through BGP-LS. The controller then uses the packet loss information to compute paths to ensure that the optimal path has the smallest packet loss rate.
NQA can collect packet loss rate statistics only from physical interfaces. As a best practice, use directly connected physical interfaces to establish BGP-EPE neighbor relationships to avoid packet loss rate collection failure.
# Enable packet loss rate advertisement in a BGP instance.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering metric-link-loss advertisement enable
egress-engineering link-delay advertisement enable
egress-engineering metric-link-loss suppression
Use egress-engineering metric-link-loss suppression to enable packet loss rate advertisement suppression for BGP-EPE and set the suppression parameters.
Use undo egress-engineering metric-link-loss suppression to restore the default.
egress-engineering metric-link-loss suppression timer time-value percent-threshold percent-value absolute-threshold absolute-value
Packet loss rate advertisement suppression is enabled. The suppression timer is 120 seconds. The percentage threshold of the packet loss rate change is 10%. The absolute value threshold of the packet loss rate change is 0.01%.
BGP instance view
timer time-value: Specifies the packet loss rate advertisement suppression timer, in the range of 0 to 600 seconds. A value of 0 means to disable packet loss rate advertisement suppression.
percent-threshold percent-value: Specifies the packet loss rate change percentage threshold, in the range of 0 to 100. A value of 0 means not to concern the packet loss rate change percentage during suppression. The packet loss rate change percentage = the absolute value of the difference between two consecutive packet loss rates / previous packet loss rate.
absolute-threshold absolute-value: Specifies the packet loss rate change absolute value threshold, in the range of 0 to 10000, in a unit of 0.00001%. A value of 0 means not to concern the packet loss rate change absolute value during suppression. The packet loss rate change absolute value is the absolute value of the difference between two consecutive packet loss rates.
When packet loss rate changes frequently, BGP will frequently process, advertise, and report the packet loss rate information, occupying too many device resources. To resolve this issue, you can enable the packet loss rate advertisement suppression feature.
Packet loss rate advertisement suppression operates as follows:
1. After this feature is enabled, interfaces report packet loss rate information to BGP at intervals of the packet loss rate advertisement suppression time.
2. BGP advertises and reports packet loss rate information at intervals of the packet loss rate advertisement suppression time. It cannot advertise or report packet loss rate information before the suppression timer expires except in the following cases:
¡ If the percentage of the change between two consecutive packet loss rates reported by an interface reaches or exceeds the threshold set by percent-value, BGP advertises and reports the packet loss rate information regardless of whether the suppression timer has expired or not.
¡ If the absolute value of the change between two consecutive packet loss rates reported by an interface reaches or exceeds the threshold set by absolute-value, BGP advertises and reports the packet loss rate information regardless of whether the suppression timer has expired or not.
This command takes effect only after the egress-engineering metric-link-loss advertisement enable command is enabled.
If a suppression parameter is set to 0, the corresponding suppression function is disabled. If all the suppression parameters are set to 0, the entire packet loss rate advertisement suppression feature is disabled.
If you execute both the egress-engineering metric-link-loss suppression command and the egress-engineering metric-delay suppression command, NQA uses the smaller value of the suppression timers set by the two commands as the time interval for advertising packet loss rate and delay information.
As a best practice, set the packet loss rate advertisement suppression timer greater than or equal to the NQA TWAMP-light packet loss rate test interval. For more information about TWAMP-light, see NQA TWAMP-light configuration in Network Management and Monitoring Configuration Guide.
# Enable packet loss rate advertisement suppression for BGP-EPE, set the suppression timer to 300 seconds, the percentage threshold of the packet loss rate change to 20%, and the absolute value threshold of the packet loss rate change to 0.02%.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering metric-link-loss suppression timer 300 percent-threshold 20 absolute-threshold 2000
egress-engineering srv6 peer-set
Use egress-engineering srv6 peer-set to create a BGP-EPE SRv6 peer set.
Use undo egress-engineering srv6 peer-set to delete a BGP-EPE SRv6 peer set.
egress-engineering srv6 peer-set peer-set-name [ auto-sid-coc-both { all | coc32 | coc32-all | coc32-none } | auto-sid-coc32 [ additive ] | static-sid [ coc32 | coc-both coc32 ] { no-flavor no-flavor-sid | psp psp-sid } * ]
egress-engineering srv6 peer-set peer-set-name [ auto-sid-coc-both { all | coc32 | coc32-all | coc32-none } | auto-sid-coc32 [ additive ] | static-sid [ coc-both coc32-none ] { no-flavor no-flavor-sid | psp psp-sid | psp-usp–usd psp-usp-usd-sid } * ]
undo egress-engineering srv6 peer-set peer-set-name
No BGP-EPE SRv6 peer sets exist.
BGP instance view
peer-set-name: Specifies a name for the BGP-EPE SRv6 peer set, which is a case-sensitive string of 1 to 63 characters.
auto-sid-coc-both: Dynamically allocates an SRv6 SID to the BGP-EPE SRv6 peer set from the COC-both locator applied to BGP-EPE.
· all: Dynamically allocates common, compressible, and non-compressible SRv6 SIDs to the BGP-EPE SRv6 peer set from the COC-both locator applied to BGP-EPE. During dynamic End.X SID allocation, BGP will allocate the following SIDs:
¡ Two End.X(COC32) SIDs of no-flavor and PSP types.
¡ Three End.X(COCNONE) SIDs of no-flavor, PSP, and PSP-USP-USD types.
¡ Three End.X SIDs of no-flavor, PSP, and PSP-USP-USD types.
· coc32: Dynamically allocates a compressible SRv6 SID to the BGP-EPE SRv6 peer set from the COC-both locator applied to BGP-EPE. During dynamic End.X SID allocation, BGP will allocate two End.X(COC32) SIDs of no-flavor and PSP types.
· coc32-none: Dynamically allocates a non-compressible SRv6 SID to the BGP-EPE SRv6 peer set from the COC-both locator applied to BGP-EPE. During dynamic End.X SID allocation, BGP will allocate three End.X(COCNONE) SIDs of no-flavor, PSP, and PSP-USP-USD types.
· coc32-all: Dynamically allocates compressible and non-compressible SRv6 SIDs to the BGP-EPE SRv6 peer set from the COC-both locator applied to BGP-EPE. During dynamic End.X SID allocation, BGP will allocate two End.X(COC32) SIDs of no-flavor and PSP types and three End.X(COCNONE) SIDs of no-flavor, PSP, and PSP-USP-USD types.
auto-sid-coc32: Dynamically allocates a compressible SRv6 SID to the BGP-EPE SRv6 peer set from the COC32 locator applied to BGP-EPE. During dynamic End.X SID allocation, BGP will allocate two End.X(COC32) SIDs of no-flavor and PSP types.
auto-sid-coc32 additive: Dynamically allocates a compressible SRv6 SID and an additive common SRv6 SID to the BGP-EPE SRv6 peer set from the COC32 locator applied to BGP-EPE. During dynamic End.X SID allocation, BGP will allocate two End.X(COC32) SIDs of no-flavor and PSP types and three End.X SIDs of no-flavor, PSP, and PSP-USP-USD types.
static-sid: Specifies a static SRv6 SID for the BGP-EPE SRv6 peer set. If you do not specify a static SRv6 SID, dynamic SRv6 SID allocation applies. If you specify this keyword without specifying the coc32 or coc-both keyword, the static SRv6 SID is a common SRv6 SID.
· coc32: Allocates a static compressible SRv6 SID to the BGP-EPE SRv6 peer set from the COC32 locator applied to BGP-EPE.
· coc-both coc32: Allocates a static compressible SRv6 SID to the BGP-EPE SRv6 peer set from the COC-both locator applied to BGP-EPE.
· coc-both coc32-none: Allocates a static non-compressible SRv6 SID to the BGP-EPE SRv6 peer set from the COC-both locator applied to BGP-EPE.
no-flavor no-flavor-sid: Specifies an End.X SID (without any flavors) by its ID.
psp psp-sid: Specifies an End.X SID (carrying the PSP flavor) by its ID.
psp-usp–usd psp-usp-usd-sid: Specifies an End.X SID (carrying the PSP, USP, and USD flavors) by its ID.
BGP-EPE allocates BGP peer SIDs to inter-AS segments. The device advertises the peer SIDs to a network controller through BGP LS messages. The controller orchestrates the IGP SIDs and BGP peer SIDs to realize optimal inter-AS traffic forwarding.
If the device establishes BGP peer relationship with multiple devices, use this command to add the peer devices to a peer set and allocate a PeerSet SID to the peer set. When the device forwards traffic based on the PeerSet SID, it distributes the traffic among the peers for load sharing.
Before you use this command, apply a locator to BGP-EPE by using the segment-routing ipv6 egress-engineering locator command in BGP instance view.
· If automatic SID allocation is used, the device dynamically allocates an SRv6 SID to the BGP-EPE SRv6 peer set from the specified locator.
· If you specify a static SRv6 SID for the BGP-EPE SRv6 peer set, the specified static SRv6 SID must belong to the specified locator.
If you execute the egress-engineering srv6 peer-set command to specify multiple SRv6 SIDs for one peer set, the effective configuration is as follows:
· If the static-sid keyword is not specified, the most recent configuration takes effect.
· If the static-sid keyword is specified:
¡ If all the SRv6 SIDs belong to the same type, the most recent configuration takes effect.
¡ If the SRv6 SIDs belong to different types, one of the following SRv6 SID combinations takes effect:
- Common SID, COC32 compressible SID, and COC-both non-compressible SID.
- Common SID, COC-both compressible SID, and COC-both non-compressible SID.
- If the coc32 keyword and the coc-both coc32 keyword are specified multiple times, the most recent configuration takes effect.
The static SRv6 SIDs configured by using the following commands cannot be the same:
· egress-engineering srv6 peer-set.
· peer egress-engineering srv6.
The auto-sid-coc32 and coc32 keywords take effect only when the locator applied to BGP-EPE is a COC32 locator.
The auto-sid-coc-both and coc-both keywords take effect only when the locator applied to BGP-EPE is a COC-both locator.
If dynamic allocation is used and you do not specify the auto-sid-coc32 or auto-sid-coc-both keyword, the egress-engineering srv6 peer-set command dynamically allocates a common SRv6 SID to the BGP-EPE SRv6 peer set.
You can use both the segment-routing ipv6 egress-engineering locator and egress-engineering srv6 peer-set commands to dynamically allocate SRv6 SIDs by specifying the auto-sid-coc32, auto-sid-coc-both coc32, auto-sid-coc-both coc32-none keywords. If the two commands have inconsistent keyword settings, the keywords specified in the segment-routing ipv6 egress-engineering locator command take effect.
# Create a BGP-EPE SRv6 peer set named epe and configure the peer set to use a dynamically allocated SRv6 SID.
[Sysname] bgp 100
[Sysname-bgp-default] egress-engineering srv6 peer-set epe
peer peer-set
end-x update-delay
Use end-x update-delay to configure the delay time to flush static End.X SIDs to the FIB.
Use undo end-x update-delay to restore the default.
end-x update-delay delay-time
Static End.X SIDs are not delayed to flush to the FIB.
SRv6 view
delay-time: Sets the delay time to flush static End.X SIDs to the FIB, in milliseconds. The value range is 0 to 600000.
When a neighbor fails, the interface connected to that neighbor goes down. The End.X SID associated with the interface cannot take effect. When the neighbor recovers, the interface also comes up and the static End.X SID associated with the interface takes effect. Because route convergence has not finished, the local device cannot forward packets according to the route entry of the static End.X SID. As a result, packet forwarding failure or packet loss occurs. (Dynamic End.X SIDs do not have this issue, because they are flushed to the FIB after route convergence is completed.) To avoid this issue, use this command to delay flushing the static End.X SID associated with the interface to the FIB. During the delay time, the local device does not forward traffic through the link attached to the interface. The delay configuration avoids packet loss within the delay time.
# Set the delay time to flush static End.X SIDs to the FIB to 60 milliseconds.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] end-x update-delay 60
fast-reroute microloop-avoidance enable (IS-IS IPv6 address family)
Use fast-reroute microloop-avoidance enable to enable FRR microloop avoidance.
Use undo fast-reroute microloop-avoidance enable to disable FRR microloop avoidance.
fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance enable [ level-1 | level-2 ]
FRR microloop avoidance is disabled.
IS-IS IPv6 unicast address family view
level-1: Specifies FRR microloop avoidance for IS-IS Level-1.
level-2: Specifies FRR microloop avoidance for IS-IS Level-2.
Use this command only on the source node.
On an network configured with TI-LFA FRR, if a node or link fails, traffic will be switched to the backup path calculated by TI-LFA. However, if a device along the backup path has not finished route convergence, traffic will be looped between the device and the source node until the device finishes route convergence. The source node is the node prior to the node or link that failed.
To resolve this issue, configure this feature on a node enabled with TI-LFA FRR. FRR microloop avoidance first switches traffic to the backup path calculated by TI-LFA to avoid packet loss after a node or link failure on the optimal path. Then, that node starts an FRR microloop avoidance RIB-update-delay timer configured by the fast-reroute microloop-avoidance rib-update-delay command after it finishes route convergence. The node performs the following operations only after all nodes on the backup path finish route convergence and the timer times out:
· Issues the forwarding path after route convergence to the FIB.
· Switches traffic from the backup path calculated by TI-LFA to the forwarding path after route convergence.
If you configure both the segment-routing microloop-avoidance enable and fast-reroute microloop-avoidance enable commands, FRR microloop avoidance takes precedence over SR microloop avoidance. The FRR microloop avoidance RIB-update-delay timer and SR microloop avoidance RIB-update-delay timer are started for the two features, respectively. The following situations exist depending on the configuration of the two timers:
· If the FRR microloop avoidance RIB-update-delay timer is equal to or greater than the SR microloop avoidance RIB-update-delay timer, traffic is switched to the post-convergence path immediately when the former timer times out.
· If the FRR microloop avoidance RIB-update-delay timer is larger than the SR microloop avoidance RIB-update-delay timer, traffic is switched to the post-convergence path until after the latter timer times out.
If you do not specify the level-1 or level-2 keyword, the command enables or disables FRR microloop avoidance on all IS-IS levels.
# Enable FRR microloop avoidance for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] fast-reroute microloop-avoidance enable
fast-reroute microloop-avoidance rib-update-delay (IS-IS IPv6 address family)
fast-reroute microloop-avoidance enable (OSPFv3 view)
Use fast-reroute microloop-avoidance enable to enable FRR microloop avoidance for OSPFv3.
Use undo fast-reroute microloop-avoidance enable to disable FRR microloop avoidance for OSPFv3.
FRR microloop avoidance is disabled for OSPFv3.
OSPFv3 view
# Enable FRR microloop avoidance for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute microloop-avoidance enable
fast-reroute microloop-avoidance rib-update-delay (OSPFv3 view)
Use fast-reroute microloop-avoidance rib-update-delay to set the FRR microloop avoidance RIB-update-delay time.
Use undo fast-reroute microloop-avoidance rib-update-delay to restore the default.
fast-reroute microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo fast-reroute microloop-avoidance rib-update-delay [ level-1 | level-2 ]
The FRR microloop avoidance RIB-update-delay time is 5000 ms.
delay-time: Specifies the FRR microloop avoidance RIB-update-delay time in milliseconds. The value range is 1 to 60000.
level-1: Specifies the FRR microloop avoidance RIB-update-delay time for IS-IS Level-1.
level-2: Specifies the FRR microloop avoidance RIB-update-delay time for IS-IS Level-2.
If you do not specify the level-1 or level-2 keyword, the command sets the FRR microloop avoidance RIB-update-delay time for all IS-IS levels.
# Set the FRR microloop avoidance RIB-update-delay time to 6000 ms for Level-1 of IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] fast-reroute microloop-avoidance rib-update-delay 6000 level-1
fast-reroute microloop-avoidance (IS-IS IPv6 address family)
OSPFv3 view
# Set the FRR microloop avoidance RIB-update-delay time to 6000 ms for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute microloop-avoidance rib-update-delay 6000
fast-reroute microloop-avoidance (OSPFv3 view)
fast-reroute ti-lfa
Use fast-reroute ti-lfa to enable Topology-Independent Loop-free Alternate Fast Re-Route (TI-LFA FRR).
Use undo fast-refroute ti-lfa to disable TI-LFA FRR.
In IS-IS IPv6 unicast address family view:
fast-reroute ti-lfa [ per-prefix ] [ route-policy route-policy-name | host ] [ level-1 | level-2 ]
undo fast-reroute ti-lfa [ level-1 | level-2 ]
In OSPFv3 process view:
TI-LFA FRR is disabled.
OSPFv3 process view
per-prefix: Calculates backup information for each advertising source of a route. Specify this keyword only if routes are advertised by multiple sources. If you do not specify this keyword, the device calculates backup information for each route.
route-policy route-policy-name: Enables TI-LFA FRR for prefixes identified by the routing policy. The route-policy-name argument specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
host: Enables TI-LFA for host routes.
level-1: Specifies TI-LFA FRR for IS-IS Level-1.
level-2: Specifies TI-LFA FRR for IS-IS Level-2.
TI-LFA FRR provides link and node protection for SR tunnels. When a link or node fails, TI-LFA FRR switches the traffic to the backup path to ensure continuous data forwarding.
Before configuring TI-LFA FRR on a level, you must execute the fast-reroute lfa command in IS-IS IPv6 unicast address family view or OSPFv3 process view to enable LFA FRR on that level. TI-LFA FRR takes effect only after you enable LFA FRR.
If you do not specify the route-policy route-policy-name option or the host keyword, the device calculates backup information for all routes.
If you do not specify the level-1 or level-2 keyword, the command applies to both IS-IS levels.
# Enable TI-LFA FRR for IS-IS process 1 and calculate backup information for all routes.
[Sysname] isis 1
[Sysname-isis-1-ipv6] fast-reroute ti-lfa
# Enable TI-LFA FRR for OSPFv3 process 1 and calculate backup information for all routes.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] fast-reroute ti-lfa
fast-reroute (IS-IS in Layer 3—IP Routing Command Reference)
fast-reroute (OSPFv3 in Layer 3—IP Routing Command Reference)
route-policy (Layer 3—IP Routing Command Reference)
fast-reroute ti-lfa encaps
Use fast-reroute ti-lfa encaps to specify the encap encapsulation mode for TI-LFA FRR.
Use undo fast-reroute ti-lfa encaps to restore the default.
TI-LFA FRR uses the insert encapsulation mode.
TI-LFA FRR supports the following repair list encapsulation modes:
· Insert mode—In this mode, the device handles packets as follows when TI-LFA FRR is enabled:
¡ For an SRv6 packet, the device inserts a new SRH between the outer IPv6 header and the original SRH. The new SRH includes all SIDs in the repair list.
¡ For a non-SRv6 IPv6 packet, the device replaces the destination address in the original IPv6 header with the first SID in the repair list and adds an SRH to the packet. The SRH includes all SIDs in the repair list.
· Encap mode—In this mode, the device adds a new outer IPv6 header and SRH to each packet.
¡ The destination address in the new outer IPv6 header is the first SID in the repair list, and the source IPv6 address is manually configured.
¡ The SRH includes all SIDs in the repair list.
# Specify the encap encapsulation mode for TI-LFA FRR in IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] fast-reroute ti-lfa encaps
fast-reroute ti-lfa
isis ipv6 fast-reroute ti-lfa disable
Use isis ipv6 fast-reroute ti-lfa disable to prevent an IS-IS interface from participating in TI-LFA calculation.
Use undo isis ipv6 fast-reroute ti-lfa disable to allow an IS-IS interface to participate in TI-LFA calculation.
isis ipv6 fast-reroute ti-lfa disable [ level-1 | level-2 ]
undo isis ipv6 fast-reroute ti-lfa disable [ level-1 | level-2 ]
An IS-IS interface participates in TI-LFA calculation.
Interface view
level-1: Specifies TI-LFA calculation on IS-IS Level-1.
level-2: Specifies TI-LFA calculation on IS-IS Level-2.
Disable the output interface to the primary next hop from participating in TI-LFA calculation.
If you do not specify the level-1 or level-2 keyword, this command applies to both IS-IS levels.
# Prevent Ten-GigabitEthernet3/0/1 from participating in TI-LFA calculation.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] isis ipv6 fast-reroute ti-lfa disable
fast-reroute ti-lfa
locator
Use locator to create an SRv6 locator and enter its view, or enter the view of an existing SRv6 locator.
Use undo locator to delete an SRv6 locator.
locator locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
locator locator-name [ ipv6-prefix ipv6-address prefix-length common-prefix common-prefix-length coc32 [ args args-length | static static-length ] * ]
locator locator-name [ ipv6-prefix ipv6-address prefix-length common-prefix common-prefix-length coc-both [ non-compress-static non-compress-static-length ] [ args args-length | static static-length ] * ]
undo locator locator-name
No SRv6 locators exist.
SRv6 view
locator-name: Specifies a locator name, a case-sensitive string of 1 to 31 characters.
ipv6-prefix ipv6-address prefix-length: Specifies an IPv6 address prefix and the prefix length, which represent the value and length for the locator in SRv6 SIDs, respectively. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120. The IPv6 address prefix cannot be an IPv4-compatible IPv6 address.
args args-length: Specifies an argument length. The value range for the args-length argument depends on the value of the prefix-length argument and varies by device model. If you do not specify an argument length, the argument length is 0.
static static-length: Specifies the static length. The value range for the static-length argument varies by the value of the prefix-length argument and varies by device model. If you do not specify a static length, the static length is 0.
common-prefix common-prefix-length: Specifies the G-SID common prefix length. The value range for the common-prefix-length argument varies by the value of the prefix-length argument and varies by device model. If you do not specify a G-SID common prefix length, the common prefix length is 0.
coc32: Enables 32-bit G-SID compression.
coc-both: Enables the locator to allocate both compressible and non-compressible SRv6 SIDs.
non-compress-static non-compress-static-length: Specifies a static length for non-compressible SRv6 SIDs. If you do not specify a static length, the static length for non-compressible SRv6 SIDs is 0.
Locators are divided into the following types according to the configuration method:
· COC32 locator—To create a COC32 locator, specify the coc32 keyword in this command.
· COC-both locator—To create a COC-both locator, specify the coc-both keyword in this command.
· Common locator—To create a common locator, do not specify the coc32 or coc-both keyword in this command.
The locator command is used not only for configuring the value and length for the locator in SRv6 SIDs but also for planning the length of the Function, Arguments, and MBZ fields. All SRv6 SIDs are allocated by the locator command. According to whether compression is supported, configure the parameters differently for SRv6 SIDs. For more information, see SRv6 in Segment Routing Configuration Guide.
If SRv6 compression is enabled, use the locator command to configure the G-SID common prefix length and specify the G-SID compression mode. Only the 32-bit G-SID compression mode is supported in the current software version. In this mode, a standard 128-bit SRv6 SID is compressed to a 32-bit G-SID.
If a static opcode has been configured, a routing protocol preferentially uses the static opcode to construct SRv6 SIDs. If no static opcode exists, the routing protocol dynamically allocates SRv6 SIDs.
By applying a locator to IGP and BGP, you can use IGP and BGP to advertise the SRv6 SIDs on the locator.
When you create a locator, you must specify an IPv6 address prefix, prefix length, and static length for the locator. When you enter the view of an existing SRv6 locator, you do not need to specify the IPv6 address prefix, prefix length, or static length of the locator.
Each locator must have a unique name.
Do not specify the same IPv6 address prefix and prefix length for different locators. In addition, the IPv6 address prefixes of different locators cannot overlap.
You cannot delete a locator if that locator has dynamic SRv6 SIDs that are being used.
You can change a COC-both locator to a common locator or vice versa without deleting the configured locator but directly editing the command parameters, as follows:
· Change a common locator to a COC-both locator by adding the common-prefix and non-compress-static parameters. Other parameters cannot be edited.
For example, assume you configure a common locator as locator test ipv6-prefix 100:1:: 80 static 8 args 8. You can change the locator to a COC-both locator by executing locator test ipv6-prefix 100:1:: 80 common-prefix 64 coc-both non-compress-static 8 static 8 args 8.
· Change a COC-both locator to a common locator by deleting the common-prefix and non-compress-static parameters. Other parameters cannot be edited.
For example, assume you configure a COC-both locator as locator test ipv6-prefix 100:1:: 80 common-prefix 64 coc-both non-compress-static 8 static 8 args 8. You can change the locator to a common locator by executing locator test ipv6-prefix 100:1:: 80 static 8 args 8.
# Configure locator test1, setting the IPv6 address prefix to 100::, prefix length to 64, and static length to 32, and enter the SRv6 locator view of this locator.
[Sysname-segment-routing-ipv6] locator test1 ipv6-prefix 100:: 64 static 32
[Sysname-segment-routing-ipv6-locator-test1]
opcode
srv6 compress enable
opcode
Use opcode to configure the opcode of SRv6 SIDs for a locator.
Use undo opcode to delete the opcode of SRv6 SIDs for a locator.
opcode { opcode | hex hex-opcode } end { no-flavor | psp | psp-usp-usd }
opcode { opcode | hex hex-opcode } end-x interface interface-type interface-number [ member-port interface-type interface-number ] nexthop nexthop-ipv6-address { no-flavor | psp | psp-usp-usd }
opcode { opcode | hex hex-opcode } end-coc32 { no-flavor | psp }
opcode { opcode | hex hex-opcode } end-x-coc32 interface interface-type interface-number [ member-port interface-type interface-number ] nexthop nexthop-ipv6-address { no-flavor | psp }
opcode { opcode | hex hex-opcode } end-coc-none { no-flavor | psp | psp-usp-usd }
opcode { opcode | hex hex-opcode } end-x-coc-none interface interface-type interface-number [ member-port interface-type interface-number ] nexthop nexthop-ipv6-address { no-flavor | psp | psp-usp-usd }
opcode { opcode | hex hex-opcode } end-dt4 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
opcode { opcode | hex hex-opcode } end-dt46 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
opcode { opcode | hex hex-opcode } end-dt6 [ vpn-instance vpn-instance-name [ evpn | l3vpn-evpn ] ]
opcode { opcode | hex hex-opcode } end-dx4 interface interface-type interface-number nexthop nexthop-ipv4-address [ vpn-instance vpn-instance-name [ evpn ] ]
opcode { opcode | hex hex-opcode } end-dx6 interface interface-type interface-number nexthop np-ipv6-address [ vpn-instance vpn-instance-name [ evpn ] ]
opcode { opcode | hex hex-opcode } end-dx2 xconnect-group group-name connection connection-name
opcode { opcode | hex hex-opcode } end-dx2 vsi vsi-name interface interface-type interface-number service-instance instance-id
opcode { opcode | hex hex-opcode } end-dx2l xconnect-group group-name connection connection-name
opcode { opcode | hex hex-opcode } end-dx2l vsi vsi-name interface interface-type interface-number service-instance instance-id
opcode { opcode | hex hex-opcode } end-dt2m vsi vsi-name
opcode { opcode | hex hex-opcode } end-dt2u vsi vsi-name
opcode { opcode | hex hex-opcode } end-dt2ul vsi vsi-name
opcode { opcode | hex hex-opcode } end-op
opcode { opcode | hex hex-opcode } end-m mirror-locator ipv6-address prefix-length
undo opcode { opcode | hex hex-opcode } { end | end-coc32 | end-coc-none | end-dt2m | end-dt2u | end-dt2ul | end-dt4 | end-dt46 | end-dt6 | end-dx2 | end-dx2l | end-dx4 | end-dx6 | end-m mirror-locator ipv6-address prefix-length | end-op | end-x | end-x-coc32 | end-x-coc-none }
No opcode exists.
SRv6 locator view
opcode: Specifies an opcode. The value range varies by the settings of the locator command.
hex hex-opcode: Specifies an SRv6 SID in hexadecimal notation. The hex-opcode argument represents the SRv6 SID in hexadecimal notation.
end: Specifies the End type.
end-x: Specifies the End.X type.
end-coc32: Specifies the End (COC32) type.
end-x-coc32: Specifies the End.X (COC32) type.
end-coc-none: Specifies the End (COCNONE) type.
end-x-coc-none: Specifies the End.X (COCNONE) type.
end-dt4: Specifies the End.DT4 type.
end-dt46: Specifies the End.DT46 type.
end-dt6: Specifies the End.DT6 type.
end-dx4: Specifies the End.DX4 type.
end-dx6: Specifies the End.DX6 type.
end-dx2: Specifies the End.DX2 type.
end-dx2l: Specifies the End.DX2L type.
end-dt2m: Specifies the End.DT2M type.
end-dt2u: Specifies the End.DT2U type.
end-dt2ul: Specifies the End.DT2UL type.
end-op: Specifies the End.OP type.
end-m: Specifies the End.M type.
no-flavor: Specifies an SRv6 SID that does not carry any flavors.
psp: Enables the penultimate SRv6 node to remove the SRH.
psp-usp-usd: Specifies an SRv6 SID that carries the PSP, USP, and USD flavors.
interface interface-type interface-number: Specifies an output interface.
member-port interface-type interface-number: Specifies a member port of the specified Layer 3 aggregate interface. The interface-type interface-number argument represents the interface type and interface number of the member port. If the specified interface is not a member port of the Layer 3 aggregate interface, the configure SRv6 SID does not take effect.
nexthop nexthop-ipv4-address: Specifies a next hop IPv4 address.
nexthop nexthop-ipv6-address: Specifies a next hop IPv6 address.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the SRv6 SIDs belong. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. The specified VPN instance must exist. If the SRv6 SIDs belong to the public network, do not specify this option.
evpn: Specifies EVPN routes. If you do not specify this keyword, the command specifies the SRv6 SIDs of VPNv4 or VPNv6 routes.
l3vpn-evpn: Specifies EVPN routes, VPNv4 routes, and VPNv6 routes.
xconnect-group group-name: Specifies the cross-connect group to which the SRv6 SIDs belong. The group-name argument represents the cross-connect group name, a case-sensitive string of 1 to 31 characters. The name cannot contain a hyphen (-). The specified cross-connect group must exist.
connection connection-name: Specifies the cross-connect to which the SRv6 SIDs belong. The connection-name argument represents the cross-connect name, a case-sensitive string of 1 to 20 characters. The name cannot contain a hyphen (-). The specified cross-connect must exist.
vsi vsi-name: Specifies the VSI to which the SRv6 SIDs belong. The vsi-name argument represents the VSI name, a case-sensitive string of 1 to 31 characters. The specified VSI must exist.
service-instance instance-id: Specifies an Ethernet service instance by its ID, in the range of 1 to 4096.
mirror-locator ipv6-address prefix-length: Specifies a protected locator by its IPv6 address prefix and prefix length. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120. Make sure the specified locator is the same as the locator on a protected node.
An SRv6 locator and its opcode and argument generate unique SRv6 SIDs. SRv6 SIDs form local SID forwarding table entries.
Use this command to configure the opcode of static SRv6 SIDs on a locator. The number of static SRv6 SIDs is determined by the static static-length option in the locator command.
If you specify the hex keyword in this command, and the length of the static portion in the locator to which the SID belongs is 32, you can use the IPv4 address format to specify the value of the SID, for example, opcode hex ::1.2.3.4 end no-flavor. The configured opcode value is displayed in hexadecimal format.
You can execute the opcode command multiple times with the end-m keyword to specify multiple protected locators for the same opcode. Each protected locator represents one or multiple remote SRv6 SIDs that require protection. A protected locator can be specified only for one opcode. Different opcodes cannot have protected locators belonging to the same subnet.
To modify the opcode of static SRv6 SIDs on a locator, you must first delete the original opcode by using the undo opcode command.
To configure End (COC32) SRv6 SIDs or End.X (COC32) SRv6 SIDs, you must also perform the following tasks:
· Enable SRv6 compression by using the srv6 compress enable command.
· Configure the G-SID common prefix length by using the locator command.
To configure End (COCNONE) SRv6 SIDs or End.X (COCNONE) SRv6 SIDs, you must also perform the following tasks:
· Configure the locator to allocate both compressible and non-compressible SRv6 SIDs.
End (COCNONE) and End.X (COCNONE) SIDs are allocated from the compressible SRv6 SID space. End (COCNONE) SIDs and End.X (COCNONE) SIDs have the same function as End SIDs and End.X SIDs, respectively.
For a COC-both locator, you can set the same opcode for the following SIDs:
· End SID and End (COC32) SID.
· End SID and End (COCNONE) SID.
· End.X SID and End.X (COC32) SID.
· End.X SID and End.X (COCNONE) SID.
You can specify a GRE tunnel interface for the interface keyword to implement SRv6 over GRE. A GRE header is encapsulated to the SRv6 packets. In the SRv6 TE policy over GRE scenario, if the interface keyword specified for first SID in the SRv6 TE policy is a GRE tunnel interface, you must configure one of the following commands:
· encapsulation-mode encaps include local-end.x
· srv6-policy encapsulation-mode encaps include local-end.x
# Configure End SRv6 SIDs, and set the opcode to 64. Configure End.X SRv6 SIDs, set the opcode to 128, and configure Ten-GigabitEthernet 3/0/1 as the output interface and 2001::1 as the next hop IPv6 address.
[Sysname-segment-routing-ipv6] locator test ipv6-prefix 100:: 64 static 32
[Sysname-segment-routing-ipv6-locator-test] opcode 64 end psp
[Sysname-segment-routing-ipv6-locator-test] opcode 128 end-x interface ten-gigabitethernet 3/0/1 nexthop 2001::1 psp
locator
ospfv3 fast-reroute ti-lfa disable
Use ospfv3 fast-reroute ti-lfa disable to prevent an OSPFv3 interface from participating in TI-LFA calculation.
Use undo ospfv3 fast-reroute ti-lfa disable to allow an OSPFv3 interface to participate in TI-LFA calculation.
ospfv3 fast-reroute ti-lfa disable [ instance instance-id ]
undo ospfv3 fast-reroute ti-lfa disable [ instance instance-id ]
An OSPFv3 interface participates in TI-LFA calculation.
Interface view
instance instance-id: Specifies an instance by its ID, in the range of 0 to 255. The default value is 0.
[Sysname-Ten-GigabitEthernet3/0/1] ospfv3 fast-reroute ti-lfa disable
path-mtu
Use path-mtu to set the SRv6 path MTU.
Use undo path-mtu to restore the default.
path-mtu mtu-value
undo path-mtu
The SRv6 path MTU is 9600 bytes.
SRv6 view
mtu-value: Sets the path MTU, in bytes. The value range for this argument is 1280 to 9600.
This command specifies the maximum bytes that can be contained in an SRv6 tunneled packets.
The transit nodes do not fragment SRv6 tunneled packets. If a packet is larger than the MTU of the output interface, the packet will be discarded. If the MTU is too small, the bandwidth is not sufficiently used. To address these issues, use this command to set an appropriate SRv6 path MTU.
# Set the SRv6 path MTU to 2000 bytes.
[Sysname-segment-routing-ipv6] path-mtu 2000
path-mtu reserved
Use path-mtu reserved to specify a reserved MTU for SRv6 path MTU.
Use undo path-mtu reserved to restore the default.
path-mtu reserved [ reserved-value ]
No reserved MTU is specified for SRv6 path MTU.
SRv6 view
reserved-value: Specifies an MTU value, in bytes. The value range for this argument is 0 to 8320. The default value is 72 bytes.
Use this command in the TI-LFA scenario. When packets are switched to the backup path after the primary path fails, the device reconstructs an IPv6 header and SRH for the packets. As a result, packet drop might occur because the packet size has exceeded the MTU. To resolve this issue, configure a reserved MTU on the source node to reserve bytes for adding a new SRH to SRv6 packets in case of primary path failure.
The size of SRv6 packets sent from the source node is controlled by the SRv6 path MTU, reserved MTU, and the IPv6 MTU of the physical output interface. The source node first finds the smaller value between the SRv6 path MTU and the IPv6 MTU of the physical output interface. Then, it uses the smaller value minus the reserved MTU as the effective MTU of the SRv6 packets.
For example, the SRv6 path MTU is 1600 and the reserved MTU is 100.
· If the IPv6 MTU of the physical output interface is equal to or greater then 1600, the effective MTU is the SRv6 path MTU minus the reserved MTU. In this example, the effective MTU is 1500.
· If the IPv6 MTU of the physical output interface is smaller than 1600, the effective MTU is the IPv6 MTU of the physical output interface minus the reserved MTU. For example, if the IPv6 MTU of the physical output interface is 1500, the effective MTU is 1400.
# Reserve 200 bytes for SRv6 path MTU.
[Sysname-segment-routing-ipv6] path-mtu reserved 200
Use peer egress-engineering srv6 to enable SRv6 BGP-EPE.
Use undo peer egress-engineering srv6 to disable SRv6 BGP-EPE.
peer group-name egress-engineering srv6
undo peer group-name egress-engineering srv6
peer ipv6-address egress-engineering srv6 [ locator locator-name [ auto-sid-coc32 [ additive ] | auto-sid-coc-both { all | coc32 | coc32-all | coc32-none } ] | static-sid { coc32 | coc-both coc32 } { no-flavor no-flavor-sid | psp psp-sid } * ]
peer ipv6-address egress-engineering srv6 [ locator locator-name [ auto-sid-coc32 [ additive ] | auto-sid-coc-both { all | coc32 | coc32-all coc32-none } ] | static-sid coc-both coc32-none { no-flavor no-flavor-sid | psp psp-sid | psp-usp–usd psp-usp-usd-sid } * ]
undo peer ipv6-address egress-engineering srv6 [ locator | static-sid { no-flavor | psp | psp-usp–usd } * ]
peer ipv6-address prefix-length egress-engineering srv6 [ locator locator-name ]
undo peer ipv6-address prefix-length egress-engineering srv6 [ locator ]
SRv6 BGP-EPE is disabled.
BGP instance view
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The specified peer group must already exist.
ipv6-address: Specifies a peer by its IPv6 address. The specified peer must already exist.
prefix-length: Specifies the prefix length, in the range of 0 to 128. To specify dynamic peers within a subnet, you must specify both the ipv6-address and prefix-length arguments.
locator locator-name: Specifies a locator by its name. If you specify a locator, the device can dynamically allocate an End.X SID in the locator to the peer. If you specify this option without specifying the auto-sid-coc32 or auto-sid-coc-both keyword, the device dynamically allocates a common SRv6 SID in the locator to the peer.
· auto-sid-coc32: Dynamically allocates a compressible SRv6 SID to the peer from the specified COC32 locator. During dynamic SID allocation, BGP will allocate two End.X (COC32) SIDs of the no-flavor and psp flavor types.
· auto-sid-coc32 additive: Dynamically allocates a common SRv6 SID to the peer from the specified COC32 locator in addition to the compressible SRv6 SID. During dynamic End.X SID allocation, BGP will allocate two End.X (COC32) SIDs of no-flavor and psp flavor types and three End.X SIDs of no-flavor, PSP, and psp-usp-usd flavor types. If you do not specify the additive keyword, the device only dynamically allocates a compressible End.X (COC32) SRv6 SID.
· auto-sid-coc-both coc32: Dynamically allocates a compressible SRv6 SID to the peer from the specified COC-both locator. During dynamic SID allocation, BGP will allocate two End.X (COC32) SIDs of the no-flavor and psp flavor types.
· auto-sid-coc-both coc32-none: Dynamically allocates a non-compressible SRv6 SID to the peer from the specified COC-both locator. For dynamic SID allocation, BGP will allocate three End.X (COCNONE) SIDs of the no-flavor, psp, and psp-usp-usd flavor types.
· auto-sid-coc-both coc32-all: Dynamically allocates compressible and non-compressible SRv6 SIDs to the peer from the specified COC-both locator. During dynamic End.X SID allocation, BGP will allocate two End.X (COC32) SIDs of no-flavor and psp flavor types and three End.X (COCNONE) SIDs of no-flavor, psp, and psp-usp-usd flavor types.
· auto-sid-coc-both all: Dynamically allocates common, compressible, and non-compressible SRv6 SIDs to the peer from the specified COC-both locator. During dynamic End.X SID allocation, BGP will allocate two End.X (COC32) SIDs of no-flavor and psp flavor types, three End.X (COCNONE) SIDs of no-flavor, psp, and psp-usp-usd flavor types, and three End.X SIDs of no-flavor, psp, and psp-usp-usd flavor types.
static-sid: Specifies a static SRv6 SID for the peer. If you specify this keyword without specifying the coc32 or coc-both keyword, the device allocates a static common SRv6 SID to the peer.
· coc32: Specifies a static compressible SRv6 SID for the peer from the COC32 locator applied to BGP-EPE.
· coc-both coc32: Specifies a static compressible SRv6 SID for the peer from the COC-both locator applied to BGP-EPE.
· coc-both coc32-none: Specifies a static non-compressible SRv6 SID for the peer from the COC-both locator applied to BGP-EPE.
This command enables the device to allocate PeerNode SIDs and PeerAdj SIDs to peers.
If you do not specify any parameters, the device will dynamically allocate SRv6 SIDs to peers. The SRv6 SIDs belong to the locator specified by using the segment-routing ipv6 egress-engineering locator command in BGP instance view.
When you use the peer egress-engineering srv6 command for a peer, follow these restrictions and guidelines:
· If you use this command to specify multiple locators for that peer, only the most recent configuration takes effect.
· If you use this command to specify multiple static SRv6 SIDs:
If you specify a static SRv6 SID for a peer, the specified static SRv6 SID must belong to the locator specified by using the segment-routing ipv6 egress-engineering locator command in BGP instance view. To identify whether the static SRv6 SID takes effect, use the display bgp egress-engineering ipv6 command. If the static SRv6 SID does not take effect, the static SRv6 SID has been used by other protocols. Before the static SRv6 SID is released, BGP-EPE does not dynamically allocate an SRv6 SID. After the static SRv6 SID is released, first use the undo peer egress-engineering srv6 command to remove the original static SRv6 SID configuration. Then, use the peer egress-engineering srv6 command to reconfigure the static SRv6 SID.
The static SRv6 SIDs specified by using the following commands cannot be the same:
If you do not specify any parameters, the device will dynamically allocate SRv6 SIDs to peers from the locator applied to BGP-EPE by using the segment-routing ipv6 egress-engineering locator command.
· If the applied locator is a common locator, BGP will allocate three End.X SIDs of no-flavor, psp, and psp-usp-usd types.
· If the applied locator is a COS32 locator, BGP will allocate three End.X SIDs of no-flavor, psp, and psp-usp-usd types.
· If the applied locator is a COC-both locator, BGP might allocate one of the following SID combinations:
¡ Three End.X SIDs of no-flavor, psp, and psp-usp-usd types.
¡ Two End.X (COC32) SIDs of no-flavor and psp types and two End.X (COCNONE) SIDs of no-flavor and psp-usp-usd types.
# Enable SRv6 BGP-EPE.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1::1 egress-engineering srv6
peer peer-set
Use peer peer-set to add a peer to a BGP-EPE SRv6 peer set.
Use undo peer peer-set to remove a peer from a BGP-EPE SRv6 peer set.
peer { ipv6-address [ prefix-length ] } peer-set srv6-peer-set-name
undo peer { ipv6-address [ prefix-length ] } peer-set
No peers are added to a BGP-EPE SRv6 peer set.
BGP instance view
ipv6-address: Specifies a peer by its IPv6 address. The peer must exist.
prefix-length: Specifies a prefix length in the range of 0 to 128. To specify a subnet, you must specify both the ipv6-address and prefix-length arguments.
peer-set-name: Specifies a BGP-EPE SRv6 peer set by its name, a case-sensitive string of 1 to 63 characters.
A PeerSet SID can be allocated to a BGP-EPE SRv6 peer set. When the device forwards traffic based on the PeerSet SID, it distributes the traffic among the peers in the peer set for load sharing.
Before adding a peer to a BGP-EPE SRv6 peer set, you must enable SRv6 BGP-EPE for that peer.
To change the BGP-EPE SRv6 peer set for a peer, you must first use undo peer peer-set command to remove that peer from the original BGP-EPE SRv6 peer set.
# Add peer 10::1 to the BGP-EPE SRv6 peer set named abc.
[Sysname] bgp 100
[Sysname-bgp-default] peer 10::1 peer-set abc
peer virtual-link
Use peer virtual-link enable the BGP virtual link feature.
Use undo peer virtual-link to disable the BGP virtual link feature.
peer ipv6-address virtual-link
undo peer ipv6-address virtual-link
The BGP virtual link feature is enabled.
BGP instance view
Application scenarios
BGP EPE uses loopback interfaces to establish an EBGP session to an indirectly connected peer over multiple hops, which might correspond to multiple physical links. In this case, the local address in the link information reported to the controller via BGP-LS by the two indirectly connected BGP EPE peers is the loopback interface address, and the remote address is the next hop address of the direct link. The remote addresses of the two indirectly connected BGP EPE peers do not belong to the same network segment, which means the remote addresses in the BGP EPE peer link information do not match. Therefore, the controller cannot obtain complete inter-AS link topology information based on the link information reported by BGP-LS. It cannot calculate the optimal inter-AS SRv6 TE Policy primary and backup paths based on inter-AS link attributes. Enabling the BGP virtual link feature on indirectly connected BGP EPE peers can resolve such an issue.
Operating mechanism
You enable this feature on two indirectly connected BGP EPE peers. BGP-LS will use the IPv6 address of the BGP EPE peer specified by the peer egress-engineering srv6 command as the remote BGP neighbor address in the link information reported to the controller. It will the IPv6 address of the local source interface specified by the peer connect-interface command as the local address. Because the local and remote BGP peer addresses in the link information reported by the two non-directly connected BGP EPE peers match, the controller can create a reachable virtual link that does not exist in the actual topology.
You can configure TE metric, affinity attribute, SRLG, and link delay information for a BGP virtual link. For more information, see "Configuring MPSL TE" in MPLS Configuration Guide.
You can bind a BGP virtual link to a TWAMP Light test session. The TWAMP Light test session monitors the network quality of the BGP virtual link and obtains the link delay and jitter. The source IP address in the TWAMP Light test session bound to the BGP virtual link must be consistent with the local IP address of the BGP virtual link. The destination IP address in the TWAMP Light test session must be consistent with the remote IP address of the BGP virtual link. For more information about TWAMP Light test sessions, see "Configuring NQA" in Network Management and Monitoring Configuration Guide.
Directly connected BGP EPE peers do not support the BGP virtual link feature or the link attributes configured for the virtual link.
# Disable the BGP virtual link feature for the BGP peer at 1::1.
[Sysname] bgp 100
[Sysname-bgp-default] undo peer 1::1 virtual-link
peer virtual-link link-delay
peer virtual-link te link administrative group
peer virtual-link te metric
peer virtual-link te srlg
peer virtual-link twamp-light test-session
Use peer virtual-link link-delay to configure link delay parameters for a BGP virtual link.
Use undo peer virtual-link link-delay to restore the default.
peer ipv6-address virtual-link link-delay { average average-delay-value | min min-delay-value max max-delay-value | variation variation-value } *
undo peer ipv6-address virtual-link link-delay { average | min | variation } *
No link delay parameters are configured for a BGP virtual link.
BGP instance view
average average-delay-value: Specifies the average link delay for the BGP virtual link, in the range of 1 to 16777215 microseconds. The link delay is the average link delay for all IP data packets sent from the local device to the BGP peer. If you do not specify this option, BGP uses the average delay detected by the TWAMP Light test session bound to the BGP virtual link. If no TWAMP Light test session exists or the test session has not detected link delay information, the link attributes for BGP-LS do not contain link delay parameters.
min min-delay-value max max-delay-value: Specifies the minimum and maximum BGP virtual link delays, in the range of 1 to 16777215 microseconds. The minimum and maximum link delays are the minimum and maximum link delays for all IP data packets sent from the local device to the BGP peer, respectively. If you do not specify this option, BGP uses the minimum and maximum link delays detected by the TWAMP Light test session bound to the BGP virtual link. If no TWAMP Light test session exists or the test session has not detected link delay information, the link attributes for BGP-LS do not contain link delay parameters.
variation variation-value: Specifies the delay variation for the BGP virtual link, in the range of 1 to 16777215 microseconds. Delay variation is the difference in the average delay between packets. If you do not specify this option, BGP uses the delay variation detected by the TWAMP Light test session bound to the BGP virtual link. If no TWAMP Light test session exists or the test session has not detected link delay information, the link attributes for BGP-LS do not contain link delay parameters.
In scenarios where BGP-LS reports link attribute information for a BGP virtual link to the controller for inter-AS path calculation, you can use this command to specify link delay parameters for a BGP virtual link. BGP-LS will report the link delay parameters for the virtual link to the controller, and the controller will calculate the optimal path based on the link delay parameters.
Operating mechanism
You can obtain the link delay information for a BGP virtual link by using the following methods:
· Manual configuration—You use this command to configure link delay parameters.
· Dynamic acquisition—You use the peer virtual-link twamp-light test-session to bind the BGP virtual link to a TWAMP Light test session, which collects the link delay statistics for the BGP virtual link.
If you have obtained a link delay parameter by using both manual configuration and dynamic acquisition, the manual configuration takes effect.
If you execute this command multiple times for the same BGP virtual link, the most recent configuration takes effect.
The link delay parameters take effect only when the BGP virtual link feature is enabled.
# Set the average delay, minimum delay, maximum delay, and delay variation for the BGP virtual link to the BGP peer at 1::1 to 100, 10, 1000, and 20 microseconds, respectively.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1::1 virtual-link link-delay average 100 min 10 max 1000 variation 20
peer virtual-link
Use peer virtual-link te link administrative group to specify an affinity attribute for a BGP virtual link.
Use undo peer virtual-link te link administrative group to restore the default.
peer ipv6-address virtual-link te link administrative group attribute-value
undo peer ipv6-address virtual-link te link administrative group
The affinity attribute for a BGP virtual link is 0x00000000.
BGP instance view
attribute-value: Specifies an affinity attribute in the range of 0 to ffffffff in hexadecimal format. This hexadecimal value is equal to a 32-bit binary number. Each bit of the binary number represents an attribute, with an attribute value of 0 or 1.
Affinity attributes are one of the constraints for the controller to calculate paths. In scenarios where BGP-LS reports link attribute information for a BGP virtual link to the controller for inter-AS path calculation, you can use this command to add an affinity attribute to that BGP virtual link. BGP-LS will report the affinity attribute to the controller, and the controller will calculate the inter-AS path that meets the affinity attribute constraints. For more information about affinity attributes, see "Configuring MPLS TE" in MPLS Configuration Guide.
An affinity attribute takes effect only when the BGP virtual link feature is enabled.
# Specify the affinity attribute for the BGP virtual link to the BGP peer at 1::1 as 0x10.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1::1 virtual-link te link administrative group 10
peer virtual-link
Use peer virtual-link te metric to specify a TE metric for a BGP virtual link.
Use undo peer virtual-link te metric to restore the default.
peer ipv6-address virtual-link te metric value
undo peer ipv6-address virtual-link te metric
A BGP virtual link does not have a TE metric.
BGP instance view
value: Specifies a TE metric, in the range of 1 to 16777215.
In scenarios where BGP-LS reports link attribute information for a BGP virtual link to the controller for inter-AS path calculation, you can use this command to add a TE metric to that BGP virtual link. BGP-LS will report the TE metric to the controller, and the controller will calculate the path based on the TE metric for path selection. For more information about TE metrics, see "Configuring MPLS TE" in MPLS Configuration Guide.
A TE metric takes effect only when the BGP virtual link feature is enabled.
# Specify the TE metric for the BGP virtual link between the local device and the BGP peer at 1::1 as 10.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1::1 virtual-link te metric 10
peer virtual-link
Use peer virtual-link te srlg to add a BGP virtual link to Shared Risk Link Groups (SRLGs).
Use undo peer virtual-link te srlg to remove a BGP virtual link from SRLGs.
peer ipv6-address virtual-link te srlg srlg-list
undo peer ipv6-address virtual-link te srlg [ srlg-list ]
A BGP virtual link does not belong to an SRLG.
BGP instance view
srlg-list: Specifies a space-separated list of up to 64 SRLGs. The value of srlg-list is { srlg-number } &<1-64>, where srlg-number represents the SRLG number, in the range of 0 and 4294967295. If you do not specify this argument in the undo peer virtual-link te srlg command, the command removes the BGP virtual link from all SRLGs.
An SRLG is a set of links that share a resource. If one link in the group fails, all other links also fail. For example, if the primary and backup SRLSPs are established on links that belong to the same SRLG, the backup path cannot protect the primary path. For more information about SRLGs, see "Configuring MPLS TE" in MPLS Configuration Guide.
SRLGs are one of the constraints for the controller to calculate paths. In scenarios where BGP-LS reports link attribute information for a BGP virtual link to the controller for inter-AS path calculation, you can use this command to add a BGP virtual link to SRLGs. BGP-LS will report the SRLG information for the virtual link to the controller. The controller will calculate the primary and back paths based on the SRLG information to ensure that the primary and backup paths of a tunnel do not use links in the same SRLG.
One BGP virtual link can belong to multiple SRLGs.
An SRLG takes effect only when the BGP virtual link feature is enabled.
# Add BGP virtual link to the BGP peer at 1::1 to SRLGs 10 and 11.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1::1 virtual-link te srlg 10 11
peer virtual-link
Use peer virtual-link twamp-light test-session to bind a BGP virtual link to a TWAMP Light test session.
Use undo peer virtual-link twamp-light test-session to restore the default.
peer ipv6-address virtual-link twamp-light test-session session-id
undo peer ipv6-address virtual-link twamp-light test-session
A BGP virtual link is not bound to any TWAMP Light test session.
BGP instance view
session-id: Specifies a TWAMP Light test session by its ID. The value range is 1 to 512.
In scenarios where BGP-LS reports link attribute information for a BGP virtual link to the controller for inter-AS path calculation, you can use this command to bind a BGP virtual link to a TWAMP Light test session. The TWAMP Light test session monitors the network quality of the BGP virtual link and obtains the link delay and jitter. BGP-LS will report the network quality parameters to the controller, and the controller will calculate the inter-AS path with the highest network quality. For more information about TWAMP Light test sessions, see "Configuring NQA" in Network Management and Monitoring Configuration Guide.
The source IP address in the TWAMP Light test session bound to a BGP virtual link must be consistent with the local IP address of the BGP virtual link. The destination IP address in the TWAMP Light test session must be consistent with the remote IP address of the BGP virtual link.
The TWAMP Light test session configuration takes effect only when the BGP virtual link feature is enabled.
# Bind the BGP virtual link to the BGP peer at 1::1 to TWAMP Light test session 1.
[Sysname] bgp 100
[Sysname-bgp-default] peer 1::1 virtual-link twamp-light test-session 1
peer virtual-link
remote-locator
Use remote-locator to create a remote SRv6 locator and enter its view, or enter the view of an existing remote SRv6 locator.
Use undo remote-locator to delete a remote SRv6 locator.
remote-locator remote-locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
undo remote-locator remote-locator-name
No remote SRv6 locators exist.
SRv6 view
remote-locator-name: Specifies a remote locator name, a case-sensitive string of 1 to 31 characters.
ipv6-prefix ipv6-address prefix-length: Specifies an IPv6 address prefix and the prefix length. The ipv6-address argument represents the IPv6 address prefix. The prefix-length argument represents the prefix length, in the range of 32 to 120. The IPv6 address prefix cannot be an IPv4-compatible IPv6 address.
In the EVPN VPWS over SRv6 scenario, if the PEs cannot use BGP routes to establish SRv6 PWs, you need to establish a static SRv6 PW between the PEs to ensure correct packet forwarding. Because the PEs cannot transmit SRv6 SID information through BGP routes, you need to configure the SRv6 SIDs assigned by the local and remote ends to the cross-connect. To configure the SRv6 SID assigned by the local end, configure the opcode command for the associated locator. To configure the SRv6 SID assigned by the remote end, create the remote locator, and then use the peer command to specify the remote locator in static SRv6 configuration view of the cross-connect.
The remote locator setting on the local PE must be the same as the locator setting on the remote PE. The local and remote PEs must use consistent locator, remote locator, and SRv6 SID settings. For example:
· Configuration on the local PE (PE 1):
locator pe1 ipv6-prefix 100:: 64 static 32
opcode 1 end.dx2 xconnect-group pe1 connection pe1
remote-locator pe2 ipv6-prefix 200:: 64 static 32
xconnect-group pe1
connection pe1
static-srv6 local-service-id 1 remote-service-id 2
peer 2::2 end-dx2-sid remote-locator pe2 opcode 1
· Configuration on the remote PE (PE 2):
opcode 1 end.dx2 xconnect-group pe2 connection pe2
remote-locator pe1 ipv6-prefix 100:: 64 static 32
xconnect-group pe2
connection pe2
peer 1::1 end-dx2-sid remote-locator pe1 opcode 1
The locator for the local PE is 100::/64, and the remote locator is 200::/6. The locator for the remote PE is 200::/64, and the remote locator is 100::/6. The SRv6 SID assigned by the local PE to the cross-connect is End.DX2 SID 100::1. The SRv6 SID assigned by the remote PE to the cross-connect is End.DX2 SID 200::1.
When deploying an SRv6 PW in the EVPN VPWS over SRv6 scenario for packet forwarding, make sure the destination IPv6 address for packets is the SRv6 SID of the remote locator. Upon receiving the packets, the remote PE searches the local locator SID forwarding table, and perform one of the following operations:
· If a matching SRv6 SID is found in the local locator, the remote PE forwards the packets based on the SRv6 SID.
· If no matching SRv6 SID is found in the local locator, the remote PE discards the packets.
When you create a remote locator, you must specify an IPv6 address prefix, prefix length, and static length for the remote locator. When you enter the view of an existing remote SRv6 locator, you only need to specify the remote locator name.
Each remote locator must have a unique name.
Do not specify the same IPv6 address prefix for different remote locators. In addition, the IPv6 address prefixes of different remote locators cannot overlap.
Do not specify the same IPv6 address prefix for the remote locator and local locator. In addition, the IPv6 address prefixes of the remote locator and local locator cannot overlap.
# Configure remote locator test1, setting the IPv6 address prefix to 100::, prefix length to 64, and static length to 32, and enter the remote SRv6 locator view of this locator.
[Sysname-segment-routing-ipv6] remote-locator test1 ipv6-prefix 200:: 64 static 32
[Sysname-segment-routing-ipv6-rmtlocator-test1]
locator
opcode
peer
reserved-sid-start
Use reserved-sid-start to reserve SRv6 SIDs.
Use undo reserved-sid-start to restore the default.
reserved-sid-start sid-value count reserved-sid-count
No SRv6 SIDs are reserved.
SRv6 locator view
sid-value: Specifies the start SRv6 SID for reservation.
count reserved-sid-count: Specifies the number of reserved SRv6 SIDs, in the range of 1 to 4294967295.
When the device generates an SRv6 TE policy based on received SRv6 TE policy routes, it must assign a BSID to the SRv6 TE policy. Use this command to reserve SRv6 SIDs in COC-both locators. The reserve SRv6 SIDs can only be assigned to SRv6 TE policies as BSIDs.
To use this command on a locator, you must enable the locator to allocate both compressible and non-compressible SRv6 SIDs. In addition, make sure all reserved SRv6 SIDs belong to the non-compressible dynamic SRv6 SID range for the locator. To obtain the range, use the display segment-routing ipv6 locator command.
When you allocate reserved SRv6 SIDs in the non-compressible dynamic SRv6 SID range, make sure the length of the reserved SRv6 SIDs does not exceed 32 bits (all 32 bits are set to 1). If the length exceeds 32 bits, the reserved SIDs might not be allocated correctly or might not be as expected. Assume that the start value for non-compressible dynamic SRv6 SIDs is 100:0:0:1::100 and the end value is 100::1:0:FFFF:FFFF:FFFF, the dynamic portion length is 40 bits, and the static portion length is 8 bits, without the Args portion. If the start SRv6 SID for reservation is 100::1:0:FF:FFFF:FFFE , the start SRv6 SID for reservation occupies 32 bits (all 32 bits are set to 1) in the nonocmpressible dynamic SRv6 SID range. If you set the number of reserved SRv6 SIDs is 20, no reserved SRv6 SIDs can be allocated.
# Configure the device to reserve 1000 SRv6 SIDs starting from 100:200:DB8:ABCD::1:0 for locator abc.
[Sysname-segment-routing-ipv6] locator abc
[Sysname-segment-routing-ipv6-locator-abc] reserved-sid-start 100:200:DB8:ABCD::1:0 count 1000
router-id
Use router-id to configure the router ID for an IPv6 IS-IS process and enable IPv6 TE.
Use undo router-id to remove the router ID from an IPv6 IS-IS process and disable IPv6 TE.
router-id ipv6-address
undo router-id
No router ID is configured for an IPv6 IS-IS process and IPv6 TE is disabled.
IS-IS IPv6 address family view
ipv6-address: Specifies an IPv6 router ID.
The IPv6 router ID must be unique in the IPv6 network.
The IPv6 router ID determines the source and destination addresses of the SRv6 tunnel distributed to the IGP. The destination address of the SRv6 tunnel must be the same as the IPv6 router ID of the destination node.
To avoid route calculation errors when multiple IS-IS P2P neighbors exist between two devices, use the advertise link-attributes or router-id command to enable IS-IS to advertise the IP address of the local interface connected to the peer to the neighbors.
Configuring an IPv6 route ID on a router also enables the IPv6 TE feature on that router. After the SRv6 tunnel participates in IGP route calculation, traffic can be directed to the SRv6 tunnel.
# Configure the router ID for an IPv6 IS-IS process and enable IPv6 TE.
[Sysname] isis 1
[Sysname-isis-1] cost-style wide
[Sysname-isis-1-ipv6] router-id 1000::1
segment-routing ipv6 (system view)
Use segment-routing ipv6 to enable SRv6 and enter SRv6 view.
Use undo segment-routing ipv6 to disable SRv6.
SRv6 is disabled.
After you execute this command, you can configure locators in SRv6 view. Then, you can configure the opcode portion in SRv6 locator view to generate local SID forwarding table entries.
You cannot disable SRv6 when a locator in SRv6 view has dynamic SRv6 SIDs that are being used.
# Enable SRv6 and enter SRv6 view.
segment-routing ipv6 admin-tag
Use segment-routing ipv6 admin-tag to configure the administrative tag value for SRv6 locators.
Use undo segment-routing ipv6 admin-tag to restore the default.
segment-routing ipv6 admin-tag tag-value
SRv6 locators do not carry an administrative tag value when they are advertised by IS-IS.
tag-value: Specifies an administrative tag value, in the range of 1 to 4294967295.
To import only specific SRv6 locators when the device imports IS-IS routes from different levels and areas or learns IS-IS routes from IS-IS neighbors, use this command to configure the administrative tag value for SRv6 locators. Then use the if-match tag command to filter SRv6 locators with different administrative tags.
Operating mechanism
With this feature configured, IS-IS will carry a 32-bit administrative tag sub-TLV with type 1 and value tag-value in the SRv6 locator TLV with type 27 when it advertises an SRv6 locator. This SRv6 locator is then marked through the administrative tag Sub-TLV.
You can use this command to configure the same administrative tag value for all SRv6 locators advertised by IS-IS. Alternatively, you can use the segment-routing ipv6 locator command with the tag keyword specified in IS-IS IPv6 address family view to configure different administrative tag values for different SR6 locators.
For the same SRv6 locator, the administrative tag value specified using the segment-routing ipv6 locator command in IS-IS IPv6 address family view takes precedence. If no administrative tag value is specified using this command, the administrative tag value specified using the segment-routing ipv6 admin-tag command is applied.
This command is available only if the link cost style is wide, wide-compatible, or compatible.
# Configure administrative tag value 100 for SRv6 locators on IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] segment-routing ipv6 admin-tag 100
· if-match tag (Layer 3—IP Routing Command Reference)
· segment-routing ipv6 locator (IS-IS IPv6 address family view)
segment-routing ipv6 compatible locator-fixed-length
Use segment-routing ipv6 compatible locator-fixed-length to enable compatibility of the Locator field in SRv6 Locator TLVs with earlier drafts.
Use undo segment-routing ipv6 compatible locator-fixed-length to restore the default.
The Locator field in SRv6 locator LSAs is of variable length, with a maximum of 128 bytes.
OSPFv3 view
To avoid interoperability issues caused by differences in the Locator field length in the SRv6 Locator TLV when a third-party device or an H3C device with an older software version interoperates with an H3C device with a newer software version, you can this command to have the new devices compatible with older draft standards.
Operating mechanism
In the OSPFv3 protocol, the SRv6 Locator TLV is carried in the SRv6 Locator LSA, used to announce the network segment and mask of the locator to which the SRv6 SID belongs, as well as the End SID related to that locator.
The length of the Locator field in SRv6 Locator TLVs is defined as variable in draft-ietf-lsr-ospfv3-srv6-extensions-12 and later drafts and can be up to 128 bits. The length of the Locator field can vary based on the configured locator segment length. However, the length is fixed at 128 bits in draft-ietf-lsr-ospfv3-srv6-extensions-11 and earlier drafts. For example, if you specify the prefix-length argument as 96 in the locator command, the default Locator field length is 96 bits and the remaining 32 bits are not required in the TLV when you apply the locator to OSPFv3 and advertise it. After this command is configured, the Locator field must be 128-bit long and the remaining 32 bits are all set to zero.
For compatibility with draft-ietf-lsr-ospfv3-srv6-extensions-08 and earlier drafts, you must both this command and the segment-routing ipv6 private-srv6-extensions compatible command.
# Enable compatibility of the Locator field in SRv6 Locator TLVs with earlier drafts.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing ipv6 compatible locator-fixed-length
Use segment-routing ipv6 egress-engineering locator to apply a locator to BGP-EPE.
Use undo segment-routing ipv6 egress-engineering locator to restore the default.
segment-routing ipv6 egress-engineering locator locator-name [ auto-sid-coc-both { all | coc32 | coc32-all | coc32-none } | auto-sid-coc32 [ additive ] | auto-sid-disable ]
No locator is applied to BGP-EPE.
BGP instance view
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters.
auto-sid-coc-both: Dynamically allocates SRv6 SIDs to BGP-EPE from the specified COC-both locator.
· all: Specifies the common, compressible, and non-compressible SRv6 SIDs. During dynamic End.X SID allocation, BGP will allocate two End.X (COC32) SIDs of no-flavor and psp types, three End.X (COCNONE) SIDs of no-flavor, psp, and psp-usp-usd types, and three End.X SIDs of no-flavor, psp, and psp-usp-usd types.
· coc32: Specifies the compressible End.X (COC32) SRv6 SIDs. BGP will allocate two End.X (COC32) SIDs of no-flavor and psp types.
· coc32-all: Specifies the compressible and non-compressible SRv6 SIDs. During dynamic End.X SID allocation, BGP will allocate two End.X (COC32) SIDs of no-flavor and psp types and three End.X (COCNONE) SIDs of no-flavor, psp, and psp-usp-usd types.
· coc32-none: Specifies the non-compressible End.X (COCNONE) SRv6 SIDs. BGP will allocate three End.X (COCNONE) SIDs of no-flavor, psp, and psp-usp-usd types.
auto-sid-coc32: Dynamically allocates compressible End.X (COC32) SRv6 SIDs to BGP-EPE from the specified COC32 locator. BGP will allocate two End.X (COC32) SIDs of no-flavor and psp types.
auto-sid-coc32 additive: Dynamically allocates a common SRv6 SID to BGP-EPE from the specified COC32 locator in addition to the allocated compressible SRv6 SID. During dynamic End.X SID allocation, BGP will allocate two End.X (COC32) SIDs of no-flavor and psp flavor types and three End.X SIDs of no-flavor, PSP, and psp-usp-usd flavor types.
auto-sid-disable: Disables dynamic SRv6 SID allocation and releases all allocated SRv6 SIDs. End.X SIDs will be released with a delay of 1800 seconds. If you do not specify this keyword, the device allows dynamic SRv6 SID allocation. If you do not specify this keyword and static SRv6 SIDs are configured, the device prefers to use the static SRv6 SIDs. If no static SRv6 SIDs are configured, the device dynamically allocates SRv6 SIDs.
Use this command to restrict the range of End.X SIDs that can be allocated to BGP-EPE SRv6 peer sets and BGP-EPE-enabled peers in a BGP instance. All static SRv6 SIDs configured for the BGP-EPE SRv6 peer sets and peers must belong to the locator specified by using this command.
To dynamically allocate End.X SIDs from the specified locator:
· Do not configure a static SRv6 SID when you create a BGP-EPE SRv6 peer set by using the egress-engineering srv6 peer-set command.
· Do not specify a locator or configure a static SRv6 SID when you enable SRv6 BGP-EPE for a peer by using the peer egress-engineering srv6 command.
The auto-sid-coc32 keyword takes effect only when the specified locator is a COC32 locator.
The auto-sid-coc-both { all | coc32 | coc32-all | coc32-none } keyword takes effect only when the specified locator is a COC-both locator.
Without any parameters specified in the command, the system takes the following actions:
· If static SRv6 SIDs are configured, the system preferentially uses static SRv6 SIDs.
· If no static SRv6 SIDs are configured, the system dynamically allocates SRv6 SIDs.
Without any parameters specified in the command, BGP allocates SRv6 SIDs according to the type of the applied locator:
# Apply locator test to BGP-EPE.
[Sysname] bgp 100
[Sysname-bgp-default] segment-routing ipv6 egress-engineering locator test
segment-routing ipv6 end-x delete-delay
Use segment-routing ipv6 end-x delete-delay to enable dynamic End.X SID deletion delay and set the delay time.
Use undo segment-routing ipv6 end-x delete-delay to restore the default.
segment-routing ipv6 end-x delete-delay [ time-value ]
Dynamic End.X SID deletion delay is enabled. The delay time is 1800 seconds.
OSPFv3 process view
time-value: Sets the dynamic End.X SID deletion delay time in seconds, in the range of 0 to 2592000. The default value is 1800. If the value is 0, dynamic End.X SID deletion delay is disabled.
Packet loss occurs between OSPFv3 or IS-IS neighbors if the neighbors frequently delete and request dynamically allocated End.X SIDs for the links between them because of neighbor flapping. To resolve this issue, set a delay timer for deleting dynamically allocated End.X SIDs when the neighbors are disconnected. If the neighbors are still disconnected when the delay timer expires, the device deletes the dynamically allocated End.X SIDs.
The device always immediately deletes automatically allocated End.X SIDs without any delay in the following situations:
· The reset ospfv3 process command is executed.
· The reset isis all command is executed.
· Interfaces are deleted or removed. For example, an interface module is removed, or a subinterface or VLAN interface is deleted.
# Enable dynamic End.X SID deletion delay for IPv6 IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv6
[Sysname-isis-1-ipv6] segment-routing ipv6 end-x delete-delay
# Enable dynamic End.X SID deletion delay for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing ipv6 end-x delete-delay
reset isis all (Layer 3—IP Routing Command Reference)
reset ospfv3 process (Layer 3—IP Routing Command Reference)
Use segment-routing ipv6 locator to apply an SRv6 locator to an IPv6 IS-IS process.
Use undo segment-routing ipv6 locator to remove the specified SRv6 locator from an IPv6 IS-IS process.
segment-routing ipv6 locator locator-name [ level-1 | level-2 ] [ auto-sid-coc32 [ additive ] | auto-sid-coc-both { all | coc32 | coc32-all | coc32-none } | auto-sid-disable ] [ member-port-enable ] [ cost cost-value ] [ tag tag-value ]
undo segment-routing ipv6 locator locator-name
No SRv6 locators are applied to an IPv6 IS-IS process.
level-1: Specifies the level-1 area.
level-2: Specifies the level-2 area.
auto-sid-coc32: Dynamically allocates a compressible End (COC32) or End.X (COC32) SRv6 SID from the specified COC32 locator.
· For dynamic End SID allocation, IS-IS will allocate two End (COC32) SIDs of the no-flavor and psp flavor types.
· For dynamic End.X SID allocation, IS-IS will allocate two End.X (COC32) SIDs of the no-flavor and psp flavor types.
additive: Dynamically allocates a common SRv6 SID from the specified COC32 locator in addition to the compressible SRv6 SID.
· For dynamic End SID allocation, IS-IS will allocate the following SIDs:
¡ Two End (COC32) SIDs of the no-flavor and psp flavor types.
¡ Three End SIDs of the no-flavor, psp, and psp-usp-usd flavor types.
· For dynamic End.X SID allocation, IS-IS will allocate the following SIDs:
¡ Two End.X (COC32) SIDs of the no-flavor and psp flavor types.
¡ Three End.X SIDs of the no-flavor, psp, and psp-usp-usd flavor types.
If you do not specify the additive keyword, the device only dynamically allocates a compressible End (COC32) or End.X (COC32) SRv6 SID.
auto-sid-coc-both: Dynamically allocates the specified type of SRv6 SIDs from the specified COC-both locator.
· coc32: Specifies the compressible SRv6 SID type.
¡ For dynamic End SID allocation, IS-IS will allocate two End (COC32) SIDs of the no-flavor and psp flavor types.
¡ For dynamic End.X SID allocation, IS-IS will allocate two End.X (COC32) SIDs of the no-flavor and psp flavor types.
· coc32-none: Specifies the non-compressible End (COCNONE) and End.X (COCNONE) SRv6 SID types.
¡ For dynamic End SID allocation, IS-IS will allocate three End (COCNONE) SIDs of the no-flavor, psp, and psp-usp-usd flavor types.
¡ For dynamic End.X SID allocation, IS-IS will allocate three End.X (COCNONE) SIDs of the no-flavor, psp, and psp-usp-usd flavor types.
· coc32-all: Specifies both the compressible and non-compressible SRv6 SID types.
¡ For dynamic End SID allocation, IS-IS will allocate the following SIDs:
- Two End (COC32) SIDs of the no-flavor and psp flavor types.
- Three End (COCNONE) SIDs of the no-flavor, psp, and psp-usp-usd flavor types.
¡ For dynamic End.X SID allocation, IS-IS will allocate the following SIDs:
- Two End.X (COC32) SIDs of the no-flavor and psp flavor types.
- Three End.X (COCNONE) SIDs of the no-flavor, psp, and psp-usp-usd flavor types.
· all: Specifies the common, compressible, and non-compressible SRv6 SID types.
- Three End SIDs of the no-flavor, psp, and psp-usp-usd flavor types.
- Three End.X SIDs of the no-flavor, psp, and psp-usp-usd flavor types.
auto-sid-disable: Disables automatic SRv6 SID allocation, immediately releases allocated End SIDs, and releases allocated End.X SIDs in 1800 seconds. If you do not specify this keyword, the device allows dynamically allocated SRv6 SIDs. If static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the static SRv6 SIDs take precedence. If no static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the system dynamically allocates SRv6 SIDs.
member-port-enable: Enables SRv6 SID allocation to the Layer 3 aggregate interface and its member ports when the neighboring interface is a Layer 3 aggregate interface. If you do not specify this keyword, the system cannot allocate SRv6 SIDs to the member ports.
cost cost-value: Specifies a cost value for locators, in the range of 1 to 16777215.
tag tag-value: Specifies an administrative tag value, in the range of 1 to 4294967295.
For IS-IS neighbors in an IS-IS network to access each other through SRv6 SIDs, configure this feature.
Operating mechanism
With this command configured, IS-IS can advertise the specified locator and the SRv6 SIDs in the locator. After learning the locator and the SRv6 SIDs in the locator, the IS-IS neighbors generate route entries.
When multiple nodes use IS-IS to reference and advertise the same SRv6 locator, you can specify different cost values for the same SRv6 locator on different nodes for optimal route selection.
In an SRv6 network, some SRv6 nodes are connected by a Layer 3 aggregate link. To process data traffic on a specific member port instead of load balancing in the aggregate group, specify the member-port-enable keyword to enable SRv6 SID allocation to the aggregate interface and its member ports. In an SID list of an SRv6 TE policy, you can specify the SRv6 SID of a member port instead of the SRv6 SID of the aggregate interface. Then, traffic steered into the SRv6 TE policy is forwarded through the specified member port.
If you do not specify a level, this command applies the specified locator to both level-1 and level-2 areas.
Use this command only when the cost style of IS-IS is wide, compatible, or wide-compatible.
Execute this command multiple times to apply multiple locators to an IPv6 IS-IS process so that the process can advertise multiple SRv6 SIDs.
You can use this command with the tag keyword specified to configure different administrative tag values for different SR6 locators. Alternatively, you can use the segment-routing ipv6 admin-tag command to configure the same administrative tag value for all SRv6 locators advertised by IS-IS.
# Apply locator abc to an IPv6 IS-IS process.
[Sysname] isis 1
[Sysname-isis-1-ipv6] segment-routing ipv6 locator abc
locator
segment-routing ipv6 locator (OSPFv3 process view)
Use segment-routing ipv6 locator to apply an SRv6 locator to an OSPFv3 process.
Use undo segment-routing ipv6 locator to remove the specified SRv6 locator from an OSPFv3 process.
segment-routing ipv6 locator locator-name[ auto-sid-coc32 [ additive ] | auto-sid-coc-both { all | coc32 | coc32-all | coc32-none } | auto-sid-disable ]
No SRv6 locators are applied to an OSPFv3 process.
OSPFv3 process view
· For dynamic End SID allocation, OSPFv3 will allocate two End (COC32) SIDs of the no-flavor and psp flavor types.
· For dynamic End.X SID allocation, OSPFv3 will allocate two End.X (COC32) SIDs of the no-flavor and psp flavor types.
· For dynamic End SID allocation, OSPFv3 will allocate the following SIDs:
· For dynamic End.X SID allocation, OSPFv3 will allocate the following SIDs:
· If you do not specify the additive keyword, the device only dynamically allocates a compressible End (COC32) or End.X (COC32) SRv6 SID.
¡ For dynamic End SID allocation, OSPFv3 will allocate two End (COC32) SIDs of the no-flavor and psp flavor types.
¡ For dynamic End.X SID allocation, OSPFv3 will allocate two End.X (COC32) SIDs of the no-flavor and psp flavor types.
¡ For dynamic End SID allocation, OSPFv3 will allocate three End (COCNONE) SIDs of the no-flavor, psp, and psp-usp-usd flavor types.
¡ For dynamic End.X SID allocation, OSPFv3 will allocate three End.X (COCNONE) SIDs of the no-flavor, psp, and psp-usp-usd flavor types.
¡ For dynamic End SID allocation, OSPFv3 will allocate the following SIDs:
¡ For dynamic End.X SID allocation, OSPFv3 will allocate the following SIDs:
auto-sid-disable: Disables automatic SRv6 SID allocation. If you do not specify this keyword, the device allows dynamically allocated SRv6 SIDs. If static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the static SRv6 SIDs take precedence. If no static SRv6 SIDs are configured when automatic SRv6 SID allocation is enabled, the system dynamically allocates SRv6 SIDs.
Use this command to enable OSPFv3 to advertise SRv6 SIDs.
If you do not specify the auto-sid-coc32, auto-sid-coc-both, or auto-sid-disable keyword, OSPFv3 will allocate the following SIDs from the specified common and COC32 locators:
· Three End SIDs of the no-flavor, psp, and psp-usp-usd types.
· Three End.X SIDs of the no-flavor, psp, and psp-usp-usd types.
As a best practice, execute the display system internal ospfv3 segment-routing ipv6 local command to view detailed information about allocated End SIDs and End.X SIDs for the COC-both type locator.
Execute this command multiple times to apply multiple locators to an OSPFv3 process so that the process can advertise multiple SRv6 SIDs.
# Apply locator abc to an OSPFv3 process.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing ipv6 locator abc
locator
Use segment-routing ipv6 private-srv6-extensions compatible to configure the TLVs and flag bits in the OSPFv3 extensions for SRv6 to be compatible with the private protocol.
Use undo segment-routing ipv6 private-srv6-extensions compatible to restore the default.
The SRv6 Capabilities TLV type values, Sub TLV type values, and flag bits in OSPFv3 packets follow the definitions in draft-ietf-lsr-ospfv3-srv6-extensions-09.
OSPFv3 view
Operating mechanism
· By default, OSPFv3 protocol packets comply with the most recent OSPFv3 draft standard, and the TLVs and flag bits in the OSPFv3 extensions for SRv6 follow the definitions in draft-ietf-lsr-ospfv3-srv6-extensions-09. The values for SRv6 Capabilities TLV Type, End.X SID Sub-TLV Type, and LAN End.X SID Sub-TLV Type are 20, 31, and 32, respectively. The N flag of the PrefixOptions field in the SRv6 Locator TLV is in the third bit, and the AC flag is in the first bit. In this case, the TLV information in the OSPFv3 extensions for SRv6 is similar to that of other vendors, allowing interoperability.
· With this command configured, the TLVs and flag bits in the OSPFv3 extensions for SRv6 follow the definition in the private protocol. The values for SRv6 Capabilities TLV Type, End.X SID Sub-TLV Type, and LAN End.X SID Sub-TLV Type are 17, 11, and 12, respectively. The N flag of the PrefixOptions field in the SRv6 Locator TLV is in the first bit, and the AC flag is in the second bit. In this case, the TLV information in the OSPFv3 extensions for SRv6 is the same as that on devices that do not use the most recent software version, allowing interoperability.
· For a successful advertisement of SRv6 locators and SRv6 SIDs, make sure OSPFv3 neighbors follow the same standard.
· If you configure both the segment-routing ipv6 sid-sub-tlv-type and segment-routing ipv6 private-srv6-extensions compatible commands, the End.X SID Sub-TLV Type and LAN End.X SID Sub-TLV Type values specified in the segment-routing ipv6 sid-sub-tlv-type command take precedence.
· After the segment-routing ipv6 private-srv6-extensions compatible command is configured, the End.X SID Sub-TLV type value is set to 11, which conflicts with the default value of OSPFv3 ASLA Sub-TLVs (11) defined in RFC 9492. This conflict causes the OSPFv3 Flex-Algo algorithm unusable. To avoid conflicts with existing standards, execute the segment-routing ipv6 sid-sub-tlv-type command to set an appropriate type value for End.X SID Sub-TLVs if multiple devices need to use the Flex-Algo algorithm in OSPFv3.
# Configure the TLVs and flag bits in the OSPFv3 extensions for SRv6 to be compatible with the private protocol.
[Sysname] opsfv3 1
[Sysname-ospfv3-1] segment-routing ipv6 private-srv6-extensions compatible
· segment-routing ipv6 locator (OSPFv3 view)
· segment-routing ipv6 sid-sub-tlv-type
· srv6 compress enable
segment-routing ipv6 sid delete-delay
Use segment-routing ipv6 sid delete-delay to configure a deletion delay for dynamic SIDs.
Use undo segment-routing ipv6 sid delete-delay to restore the default.
segment-routing ipv6 sid delete-delay [ time-value ]
The dynamic SID deletion delay time is 1800 seconds.
BGP instance view
time-value: Specifies the deletion delay time, in the range of 0 to 3600 seconds. A value of 0 means no delay and the device deletes the SRv6 SIDs allocated by BGP immediately after the BGP session is down.
To make sure BGP allocates the same SRv6 SID before and after a BGP session down-up event, use this command to set a proper dynamic SID deletion delay.
Operating mechanism
With this feature configured, the device does not delete the BGP-allocated SRv6 SID when the BGP session is down before the delay timer expires.
· If the BGP session becomes up before the delay timer expires, the original SRv6 SID is used.
· If the BGP session is down after the delay timer expires, the BGP-allocated SRv6 SID is deleted.
If an active/standby MPU switchover occurs before the delay timer expires, the device does not delete the dynamically allocated SRv6 SIDs when the neighbors are disconnected and deletes them until after the timer expires.
If you delete the BGP configuration actively, the device immediately deletes the SRv6 SIDs dynamically allocated by BGP without a delay.
# Configure the dynamic SID deletion delay time as 30 seconds.
[Sysname] bgp 100
[Sysname-bgp-default] segment-routing ipv6 sid delete-delay 30
Use segment-routing ipv6 sid-sub-tlv-type to specify a type value for an SRv6 SID sub-TLV included in OSPFv3 routes.
Use undo segment-routing ipv6 sid-sub-tlv-type to restore the default.
segment-routing ipv6 sid-sub-tlv-type { end-x end-x-value | lan-end-x lan-end-x-value }
The type value is 31 for the P2P End.X SID sub-TLV included in OSPFv3 routes and 32 for the LAN End.X SID sub-TLV included in OSPFv3 routes.
OSPFv3 process view
end-x end-x-value: Specifies a type value for the P2P End.X SID sub-TLV, in the range of 1 to 1000. The default value is 31.
lan-end-x lan-end-x-value: Specifies a type value for the LAN End.X SID sub-TLV, in the range of 1 to 1000. The default value is 32.
Operating mechanism
The type values for the End.X SID sub-TLVs included in OSPFv3 routes might vary by device model. For device intercommunication, use this command to ensure that all devices have the same type value for the same End.X SID sub-TLV included in OSPFv3 routes.
· For a successful advertisement of SRv6 locators and SRv6 SIDs, make sure OSPFv3 neighbors use the same TLV type values.
· If you configure both the segment-routing ipv6 sid-sub-tlv-type and segment-routing ipv6 private-srv6-extensions compatible commands, the End.X SID Sub-TLV Type and LAN End.X SID Sub-TLV Type values specified in the previous command take precedence.
· In broadcast and NBMA networks, OSPFv3 allocates SRv6 LAN End.X SID Sub TLVs for adjacent links when the interface type is DR. When the interface type is BDR or DROTHER, OSPFv3 might allocate SRv6 End.X SID Sub-TLVs instead of SRv6 LAN End.X SID Sub TLVs for adjacent links.
· In P2P and P2MP networks, OSPFv3 allocates SRv6 End.X SID Sub-TLVs for adjacent links.
# Set the type value of the P2P End.X SID sub-TLV to 20.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing ipv6 sid-sub-tlv-type end-x 20
segment-routing microloop-avoidance enable
Use segment-routing microloop-avoidance enable to enable SR microloop avoidance.
Use undo segment-routing microloop-avoidance enable to disable SR microloop avoidance.
In IS-IS IPv6 unicast address family view:
segment-routing microloop-avoidance enable [ level-1 | level-2 ]
undo segment-routing microloop-avoidance enable [ level-1 | level-2 ]
In OSPFv3 process view:
SR microloop avoidance is disabled.
OSPFv3 process view
level-1: Specifies IS-IS Level-1.
level-2: Specifies IS-IS Level-2.
After a network failure occurs or recovers, route convergence occurs on relevant network devices. Because of nonsimultaneous convergence on network devices, microloops might be formed. After you configure SR microloop avoidance, the devices will forward traffic along the specified path before route convergence is finished on all the relevant network devices. Because the forwarding path is independent of route convergence, microloops are avoided.
Microloop avoidance after a network failure and a failure recovery is as follows:
· When a network failure occurs, a node enabled with this feature issues the calculated forwarding path to the FIB after route convergence and switches the traffic to the forwarding path after the delay timer times out. Before the timer times out, traffic is forwarded along the TI-LFA FRR backup path to avoid microloops.
· When the failure recovers, a node enabled with this feature also calculates an explicit path that contains SIDs except for the primary forwarding path. Before the timer times out, traffic is forwarded along the backup path to avoid microloops.
If you configure both the segment-routing microloop-avoidance enable and fast-reroute microloop-avoidance enable commands, FRR microloop avoidance takes precedence over SR microloop avoidance. The FRR microloop avoidance RIB-update-delay timer and SR microloop avoidance RIB-update-delay timer are started for the two features, respectively. The following situations exist depending on the configuration of the two timers:
· If the FRR microloop avoidance RIB-update-delay timer is equal to or greater than the SR microloop avoidance RIB-update-delay timer, traffic is switched to the post-convergence path immediately when the former timer times out.
· If the FRR microloop avoidance RIB-update-delay timer is larger than the SR microloop avoidance RIB-update-delay timer, traffic is switched to the post-convergence path until after the latter timer times out.
If you do not specify the level-1 or level-2 keyword, this command applies to both IS-IS levels.
# Enable SR microloop avoidance for IPv6 IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] segment-routing microloop-avoidance enable
# Enable SR microloop avoidance for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing microloop-avoidance enable
fast-reroute microloop-avoidance enable (IS-IS IPv6 address family)
fast-reroute microloop-avoidance enable (OSPFv3 view)
segment-routing microloop-avoidance rib-update-delay
segment-routing microloop-avoidance encaps
Use segment-routing microloop-avoidance encaps to specify the encap encapsulation mode for SR microloop avoidance.
Use undo segment-routing microloop-avoidance encaps to restore the default.
SR microloop avoidance uses the insert mode.
SR microloop avoidance supports the following SID list encapsulation modes:
· Insert mode—In this mode, the device handles packets as follows when SR microloop avoidance is enabled:
¡ For an SRv6 packet, the device inserts a new SRH between the outer IPv6 header and the original SRH. The new SRH includes all SIDs in the SID list.
¡ For a non-SRv6 IPv6 packet, the device replaces the destination address in the original IPv6 header with the first SID in the SID list and adds an SRH to the packet. The SRH includes all SIDs in the SID list.
· Encap mode—In this mode, the device adds a new outer IPv6 header and SRH to each packet.
¡ The destination address in the new outer IPv6 header is the first SID in the SID list, and the source IPv6 address is manually configured.
¡ The SRH includes all SIDs in the SID list.
# Specify the encap encapsulation mode for SR microloop avoidance in IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] segment-routing microloop-avoidance encaps
Use segment-routing microloop-avoidance rib-update-delay to set the SR microloop avoidance RIB-update-delay time.
Use undo segment-routing microloop-avoidance rib-update-delay to restore the default.
segment-routing microloop-avoidance rib-update-delay delay-time [ level-1 | level-2 ]
undo segment-routing microloop-avoidance rib-update-delay [ level-1 | level-2 ]
The SR microloop avoidance RIB-update-delay time is 5000 milliseconds.
OSPFv3 process view
delay-time: Sets the delay time in milliseconds, in the range of 1 to 60000.
To ensure sufficient time for IGP to complete route convergence, set the SR microloop avoidance RIB-update-delay time. Before the timer expires, faulty relevant devices will forward traffic along the specified path. Upon expiration of the timer and completion of IGP route convergence, traffic will traverse along the IGP-calculated path.
# Set the SR microloop avoidance RIB-update-delay time to 6000 milliseconds for IPv6 IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] segment-routing microloop-avoidance rib-update-delay 6000
# Set the SR microloop avoidance RIB-update-delay time to 6000 milliseconds for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] segment-routing microloop-avoidance rib-update-delay 6000
segment-routing microloop-avoidance strict-sid-only
Use segment-routing microloop-avoidance strict-sid-only to configure SR microloop avoidance to encapsulate only strict SIDs in the SID list.
Use undo segment-routing microloop-avoidance strict-sid-only to restore the default.
The strict-SID-only feature is not configured for SR microloop avoidance.
By default, SR microloop avoidance first calculates the End SID to the P node, and then calculates the End.X SIDs from the P node to the destination node. Then, the SIDs are encapsulated into the SRH in the order of the End SID of the P node and the End.X SIDs from the P node to the destination node.
If multipoint failure exists and the forwarding path is frequently switched, a microloop might exist on the path to the P node identified by the End SID. To resolve this issue, use this command to strictly constrain the path to the P node.
This command strictly constrains the path to the P node by calculating an End.X SID to reach the P node. The SIDs are encapsulated into the SID list of the SRH in the order of the End.X SID to the P node and the End.X SIDs from the P node to the destination node.
# Configure SR microloop avoidance to encapsulate only strict SIDs in the SID list for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] segment-routing microloop-avoidance strict-sid-only
snmp-agent trap enable srv6
Use snmp-agent trap enable srv6 to enable SNMP notifications for SRv6.
Use undo snmp-agent trap enable srv6 to disable SNMP notifications for SRv6.
SNMP notifications are disabled for SRv6.
To report critical SRv6 events to an NMS, enable SNMP notifications for SRv6. For SRv6 event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see Network Management and Monitoring Configuration Guide.
# Enable SNMP notifications for SRv6.
[Sysname] snmp-agent trap enable srv6
srv6 compress enable (IS-IS IPv6 address family view)
Use srv6 compress enable to enable SRv6 compression for IPv6 IS-IS.
Use undo srv6 compress enable to disable SRv6 compression for IPv6 IS-IS.
srv6 compress enable [ level-1 | level-2 ]
undo srv6 compress enable [ level-1 | level-2 ]
SRv6 compression is disabled for IPv6 IS-IS.
If you do not specify a level, this command enables or disables SRv6 compression for both level-1 and level-2 areas.
If IPv6 IS-IS is used to advertise G-SIDs to neighbors, you must use this command to enable SRv6 compression for IPv6 IS-IS.
For this command to take effect, apply a locator to IS-IS IPv6 address family view by using the segment-routing ipv6 locator command.
# Enable SRv6 compression for IPv6 IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1-ipv6] srv6 compress enable
srv6 compress enable (OSPFv3 view)
Use srv6 compress enable to enable SRv6 compression for OSPFv3.
Use undo srv6 compress enable to disable SRv6 compression for OSPFv3.
SRv6 compression is disabled for OSPFv3.
OSPFv3 view
If OSPFv3 is used to advertise G-SIDs to neighbors, you must use this command to enable SRv6 compression for OSPFv3.
If you enable SRv6 compression for OSPFv3 without configuring this command, OSPFv3 can only advertise non-compressed SRv6 SIDs to neighbors. If you enable TI-LFA FRR or microloop avoidance in OSPFv3 view, the FRR backup path calculated by OSPFv3 contains only non-compressed SRv6 SIDs.
For this command to take effect, apply a locator to OSPFv3 view.
# Enable SRv6 compression for OSPFv3 process 1.
[Sysname] opsfv3 1
[Sysname-ospfv3-1] srv6 compress enable
srv6 compress enable (SRv6 view)
Use srv6 compress enable to enable SRv6 compression.
Use undo srv6 compress enable to disable SRv6 compression.
SRv6 compression is disabled.
SRv6 view
Typically, an address space is reserved for SRv6 SID allocation in an SRv6 subnet. This address space is called an SID space. In the SRv6 subnet, all SIDs are allocated from the SID space. The SIDs have the same prefix (common prefix). The SID common prefix is redundant information in the SRH.
SRv6 compression removes the common prefix from the SIDs in the SID list of the SRH. The remaining part of an SID is called a G-SID. G-SIDs reduce the cost of SRH.
When SRv6 uses the SID list in the SRH to replace the destination address of a packet, it combines the common prefix and the destination G-SID to form a new SID. This new SID is used as the destination address of the packet.
# Enable SRv6 compression.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] srv6 compress enable
summary algorithm
Use summary algorithm to configure an aggregate route for a locator.
Use undo summary algorithm to delete the aggregate route for a locator.
summary ipv6-prefix prefix-length algorithm algo-id [ explicit ]
undo summary ipv6-prefix prefix-length
Routes for a locator are not aggregated.
ipv6-prefix: Specifies the IPv6 prefix of a locator.
prefix-length: Specifies the prefix length.
algorithm algo-id: Specifies a Flex-Algo algorithm for locator route aggregation. The algo-id argument represents the algorithm ID, in the range of 128 to 255. The algorithm value for the aggregate route is the value specified by using this option.
explicit: Aggregates only the locator routes calculated by the same Flex-Algo algorithm into one aggregate route. If you do not specify this keyword, the command can aggregate locator routes calculated by different Flex-Algo algorithms into one aggregate route.
Use this command to aggregate locator routes associated with a Flex-Algo algorithm to reduce the size of the local LSDB and the LSPs generated by the local router.
To associate the routes for a locator with a Flex-Algo algorithm, use the flex-algo algorithm command.
The device can aggregate only routes in the locally generated LSPs.
# Configure aggregate route 202.0.0.0/8.
[Sysname] isis 1
[Sysname-isis-1-ipv6] summary 100:1:: 96 algorithm 128
flex-algo algorithm (Layer 3—IP Routing Command Reference)
