06-Internet Access Behavior Management
HomeSupportConfigure & DeployConfiguration ExamplesH3C Routers Easy and Effortless Routing Feature Configuration Examples-6W10106-Internet Access Behavior Management
04-MSR Routers Bandwidth Guarantee Configuration Examples (CLI)
MSR Routers
Introduction
The following information provides an example for configuring bandwidth guarantee.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of ACL and QoS.
Example: Configuring bandwidth guarantee
As shown in Figure 1, the services accessed by the device include voice services, administrative department services, and common services. Configure bandwidth guarantee to meet the following requirements when network congestion occurs:
·     Expedited forwarding (EF) is performed on the voice service traffic.
·     Assured-forwarding (AF) is performed on the administrative department service traffic.
·     The remaining or idle bandwidth is used for forwarding the common service traffic.
Figure 1 Network diagram
Analysis
To achieve bandwidth guarantee for different data flows, you must define class rules that match the data of each service. This example uses ACLs for matching IP packets from different sources, and associates the class rules with different bandwidth guarantee actions.
Procedures
# Assign IP addresses to interfaces.
[Device-GigabitEthernet1/0/1] ip address 1.1.1.1 24
[Device-GigabitEthernet1/0/2] ip address 192.168.20.1 24
[Device] interface gigabitethernet 1/0/3
[Device-GigabitEthernet1/0/3] ip address 192.168.10.1 24
[Device-GigabitEthernet1/0/3] quit
[Device] interface gigabitethernet 1/0/4
[Device-GigabitEthernet1/0/4] ip address 192.168.30.1 24
[Device-GigabitEthernet1/0/4] quit
# Create basic ACLs, and configure rules to match packets sourced from 192.168.20.0/24 and 192.168.30.0/24.
[Device] acl basic 2000
[Device-acl-ipv4-basic-2000] rule 5 permit source 192.168.20.0 0.0.0.255
[Device] acl basic 2001
[Device-acl-ipv4-basic-2001] rule 0 permit source 192.168.30.0 0.0.0.255
[Device-acl-ipv4-basic-2001] quit
# Create traffic classes af-1 and use ACL 2000 as the match criterion. Create traffic class ef-1 and use ACL 2001 as the match criterion.
[Device] traffic classifier af-1
[Device-classifier-af-1] if-match acl 2000
[Device-classifier-af-1] quit
[Device] traffic classifier ef-1
[Device-classifier-ef-1] if-match acl 2001
[Device-classifier-ef-1] quit
# Create traffic behavior af-1. Enable AF and set a minimum guaranteed bandwidth percentage of 20%.
[Device] traffic behavior af-1
[Device-behavior-af-1] queue af bandwidth pct 20
[Device-behavior-af-1] quit
# Create traffic behavior ef-1. Enable EF and set a maximum bandwidth percentage of 40%.
[Device] traffic behavior ef-1
[Device-behavior-ef-1] queue ef bandwidth pct 40
[Device-behavior-ef-1] quit
# Define a QoS policy and associate the configured traffic behaviors with classes in the QoS policy.
[Device] qos policy cbq
[Device-qospolicy-cbq] classifier ef-1 behavior ef-1
[Device-qospolicy-cbq] classifier af-1 behavior af-1
[Device-qospolicy-cbq] quit
# Apply the QoS policy to the outgoing traffic of GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] qos apply policy cbq outbound
# Display the QoS policy configuration on GigabitEthernet 1/0/1.
[Device] display qos policy interface gigabitethernet 1/0/1
  Direction: Outbound
  Policy: cbq
   Classifier: default-class
     Matched : 0 (Packets) 0 (Bytes)
     5-minute statistics:
      Forwarded: 0/0 (pps/bps)
      Dropped  : 0/0 (pps/bps)
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: be
     Default Queue:
      Flow based Weighted Fair Queue:
        Max number of hashed queues: 256
        Enqueued : 0 (Packets) 0 (Bytes)
        Discarded: 0 (Packets) 0 (Bytes)
        Discard Method: Tail
   Classifier: af-1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: af-1
      Assured Forwarding:
        Bandwidth 160000 (kbps)
Classifier: ef-1
     Operator: AND
     Rule(s) :
      If-match acl 2001
     Behavior: ef-1
      Expedited Forwarding:
        Bandwidth 320000 (kbps) CBS 8000000 (Bytes)
Configuration files
 port link-mode route
 combo enable copper
 ip address 1.1.1.1 255.255.255.0
 combo enable copper
 ip address 192.168.20.1 255.255.255.0
 combo enable copper
 ip address 192.168.10.1 255.255.255.0
interface GigabitEthernet1/0/4
 combo enable copper
 ip address 192.168.30.1 255.255.255.0
acl basic 2000
acl basic 2001
 if-match acl 2000
 if-match acl 2001
qos policy cbq
Related documentation
·     ACL and QoS Configuration Guide in H3C MSR Router Series Comware 7 Configuration Guides
·     ACL and QoS Command Reference in H3C MSR Router Series Comware 7 Command References
