06-Internet Access Behavior Management
HomeSupportConfigure & DeployConfiguration ExamplesH3C Routers Easy and Effortless Routing Feature Configuration Examples-6W10106-Internet Access Behavior Management
02-ER G3 Routers MAC Filter Configuration Examples
ERG3 Routers
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Introduction
The following information provides MAC filter configuration examples.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of ACL and QoS.
Example: Configuring MAC filter
As shown in Figure 1, the router serves as the egress router on the enterprise network and is configured with VLANs VLAN2 and VLAN3. VLAN2's interface resides on subnet 192.168.2.0/24 and VLAN3's interface resides on subnet 192.168.3.0/24.
Configure MAC filter to control Internet access:
·     Permit users on VLAN2 to access the Internet.
·     Forbid the user with MAC address 509A-4CDA-1ECB on VLAN3 from accessing the Internet and permit other users on VLAN3 to access the Internet.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on Release 0136 of the ER3200G3 router.
For internal users to access the external network, make sure the subnet on which the WAN interface resides is different from the internal subnets.
Procedures
Connecting interface WAN1 to the Internet
1.     On the Web interface of the device, select Network Settings > External Networks.
2.     Click the WAN Settings tab.
3.     Click the edit icon in the Actions column for WAN1.
4.     In the Connection Mode field, select Fixed IP.
5.     In the IP Address field, enter 192.168.200.21.
6.     In the Subnet Mask field, enter 255.255.255.0.
7.     In the Gateway Address field, enter 192.168.200.1.
8.     Use the default settings for the other parameters. Click Apply.
Figure 2 Editing WAN settings
Configuring VLAN2 and the interface IP address
# On the router, configure VLAN2 and configure its interface IP address as 192.168.2.1/24.
1.     On the Web interface of the device, select Network Settings > LANs from the navigation pane. Click the VLAN Settings tab.
2.     Click Add.
3.     In the VLAN ID field, enter 2.
4.     In the IP Address field, enter 192.168.2.1.
5.     In the Subnet Mask field, enter 255.255.255.0.
6.     Select Enable DHCP.
7.     Use the default settings for the other parameters. Click Apply.
Figure 3 Configuring VLAN2
Configuring VLAN3 and the interface IP address
# On the router, configure VLAN3 and configure its interface IP address as 192.168.3.1/24.
2.     Click Add.
3.     In the VLAN ID field, enter 3.
4.     In the IP Address field, enter 192.168.3.1.
Figure 4 Configuring VLAN3
Assigning interface LAN1 to VLAN2 and VLAN3
2.     On the VLAN Division tab, click the edit icon in the Actions column for LAN1.
3.     Select VLAN2 and VLAN3 from the left box.
4.     Click the > icon.
5.     Click Apply.
Figure 5 Detailed port settings page
# Add MAC address 509A-4CDA-1ECB to the denylist.
1.     On the Web interface of the device, select Security > MAC Filter from the navigation pane.
2.     Select MAC Denylist and Allowlist > Denylist.
3.     Click Add.
4.     In the MAC Address field, enter 50-9A-4C-DA-1E-CB.
5.     Click Apply.
Figure 6 Adding a source MAC address to the denylist
# Enable MAC filter for port VLAN3.
6.     On the Web interface of the device, select Security > MAC Filter from the navigation pane.
7.     On the MAC Filter Settings tab, select Enable MAC Filter.
8.     Select the Denylist filtering method and Enable for port VLAN3.
9.     Click Apply.
Figure 7 MAC filter settings page
1.     Verify that the users on VLAN2 can access the Internet.
C:\Users\VLAN 2a>ping –S 192.168.2.2 114.114.114.114
Reply from 114.114.114.114: bytes=32 time=73ms TTL=85
Reply from 114.114.114.114: bytes=32 time=91ms TTL=79
Reply from 114.114.114.114: bytes=32 time=82ms TTL=65
Reply from 114.114.114.114: bytes=32 time=103ms TTL=77
Ping statistics for 114.114.114.114:
Approximate round trip time in milli-seconds:
    Minimum = 73ms, Maximum = 103ms, Average = 87ms
2.     Verify that the user with MAC address 50-9A-4C-DA-1E-CB on VLAN3 cannot access the Internet.
C:\Users\VLAN 3a>ping –S 192.168.3.2 114.114.114.114
Request timed out.
Request timed out.
Request timed out.
Request timed out.
3.     Verify that other users on VLAN3 can access the Internet.
C:\Users\VLAN 3b>ping –S 192.168.3.3 114.114.114.114
