02-IEEE8021-SPB-MIB | 223.94 KB |
IEEE8021-SPB-MIB
About this MIB
Use this MIB to configure or obtain information about basic SPB parameters.
MIB file name
ieee8021-spb.mib
Root object
iso(1).org(3).ieee(111).standards-association-numbered-series-standards(2).lan-man-stds(802).ieee802dot1(1).ieee802dot1mibs(1).ieee8021SpbMib(26)
Scalar objects
ieee8021SpbSysAreaAddress
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbSysAreaAddress (1.3.111.2.802.1.1.26.1.1.1) |
read-write |
IEEE8021SpbAreaAddress |
OCTET STRING (3) |
SPB area address. |
Supports only the read operation. |
ieee8021SpbSysId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbSysId (1.3.111.2.802.1.1.26.1.1.2) |
read-write |
MacAddress |
OCTET STRING (6) |
SPB system ID. |
ieee8021SpbSysControlAddr
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbSysControlAddr (1.3.111.2.802.1.1.26.1.1.3) |
read-write |
MacAddress |
OCTET STRING (6) |
Control address of SPB protocol packets. |
As per the MIB. |
ieee8021SpbSysName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbSysName (1.3.111.2.802.1.1.26.1.1.4) |
read-only |
OCTET STRING |
OCTET STRING (0..32) |
SPB system name. |
The return value is a zero-length string if the actual system name exceeds 32 characters. |
ieee8021SpbSysBridgePriority
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbSysBridgePriority (1.3.111.2.802.1.1.26.1.1.5) |
read-only |
IEEE8021SpbBridgePriority |
OCTET STRING (2) |
SPB bridge priority. |
As per the MIB. |
ieee8021SpbmSysSPSourceId
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbmSysSPSourceId (1.3.111.2.802.1.1.26.1.1.6) |
read-write |
IEEE8021SpbmSPsourceId |
OCTET STRING (3) |
SPBM shortest path source ID. |
As per the MIB. |
ieee8021SpbvSysMode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbvSysMode (1.3.111.2.802.1.1.26.1.1.7) |
read-write |
IEEE8021SpbMode |
INTEGER { auto(1), manual(2) } |
SPBV system mode. |
Not supported. |
ieee8021SpbmSysMode
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbmSysMode (1.3.111.2.802.1.1.26.1.1.8) |
read-write |
IEEE8021SpbMode |
SPBM shortest path source system mode. |
As per the MIB. |
ieee8021SpbSysDigestConvention
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbSysDigestConvention (1.3.111.2.802.1.1.26.1.1.9) |
read-write |
IEEE8021SpbDigestConvention |
INTEGER{ off(1), loopFreeBoth(2), loopFreeMcastOnly(3) } |
SPB digest agreement convention. |
As per the MIB. |
Tabular objects
ieee8021SpbMtidStaticTable
About this table
This table contains SPB static topology information.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ieee8021SpbMtidStaticEntryMtid and ieee8021SpbTopIx.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbMtidStaticEntryMtid (1.3.111.2.802.1.1.26.1.2.1.1) |
not-accessible |
IEEE8021SpbMTID |
Unsigned32 |
IS-IS multiple topology ID (MTID) of an SPB topology. |
Multiple topologies are not supported. The value is fixed at 0. |
ieee8021SpbMTidStaticEntryMtidOverload (1.3.111.2.802.1.1.26.1.2.1.2) |
read-create |
TruthValue |
true(1), false(2) |
Whether to set the overload bit. |
As per the MIB. |
ieee8021SpbMtidStaticEntryRowStatus (1.3.111.2.802.1.1.26.1.2.1.3) |
read-create |
RowStatus |
Active(1), CreateAndgo(4), Destroy(6) |
Row status. |
N/A |
ieee8021SpbTopIx (1.3.111.2.802.1.1.26.1.2.1.4) |
not-accessible |
IEEE8021SpbMTID |
Unsigned32 |
Index of the SPB topology. |
ieee8021SpbTopIxDynamicTable
About this table
This table contains SPB dynamic topology information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table index is ieee8021SpbTopIxDynamicEntryTopIx.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbTopIxDynamicEntryTopIx (1.3.111.2.802.1.1.26.1.3.1.1) |
not-accessible |
IEEE8021SpbMTID |
Unsigned32 |
Index of an SPB topology |
ieee8021SpbTopIxDynamicEntryAgreeDigest (1.3.111.2.802.1.1.26.1.3.1.2) |
read-only |
IEEE8021SpbDigest |
OCTET STRING (32) |
Topology agreement digest value. |
As per the MIB. |
ieee8021SpbTopIxDynamicEntryMCID (1.3.111.2.802.1.1.26.1.3.1.3) |
read-only |
IEEE8021SpbMCID |
OCTET STRING (51) |
MST Identifier MCID. |
As per the MIB. |
ieee8021SpbTopIxDynamicEntryAuxMCID (1.3.111.2.802.1.1.26.1.3.1.4) |
read-only |
IEEE8021SpbMCID |
OCTET STRING (51) |
Auxiliary MCID for migration. |
As per the MIB. |
ieee8021SpbEctStaticTable
About this table
This table contains B-VLAN to ECT algorithm static mapping entries on a bridge.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ieee8021SpbEctStaticEntryTopIx and ieee8021SpbEctStaticEntryBaseVid.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbEctStaticEntryTopIx (1.3.111.2.802.1.1.26.1.4.1.1) |
not-accessible |
IEEE8021SpbMTID |
Unsigned32 |
Index of an SPB topology. |
ieee8021SpbEctStaticEntryBaseVid (1.3.111.2.802.1.1.26.1.4.1.2) |
not-accessible |
VlanIdOrAny |
Integer32(1..4094) |
B-VLAN in a mapping entry. |
The wildcard value of 4095 is not supported. |
ieee8021SpbEctStaticEntryEctAlgorithm (1.3.111.2.802.1.1.26.1.4.1.3) |
read-create |
IEEE8021SpbEctAlgorithm |
OCTET STRING (4) |
ECT algorithm in the mapping entry. |
Default: 00-80-c2-01. |
ieee8021SpbvEctStaticEntrySpvid (1.3.111.2.802.1.1.26.1.4.1.4) |
read-create |
VlanIdOrNone |
Integer32 (0 | 1..4094) |
VID originating from this bridge if the mode is SPBV. |
Not supported. The value is fixed at 0. |
ieee8021SpbEctStaticEntryRowStatus (1.3.111.2.802.1.1.26.1.4.1.5) |
read-create |
RowStatus |
active (1), createAndGo(4), destroy(6) |
Row status. |
Supports active(1), createAndGo(4), and destroy(6). |
ieee8021SpbEctDynamicTable
About this table
This table contains information about the ECT behaviors on a bridge.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021SpbEctDynamicEntryTopIx and ieee8021SpbEctDynamicEntryBaseVid.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbEctDynamicEntryTopIx (1.3.111.2.802.1.1.26.1.5.1.1) |
not-accessible |
IEEE8021SpbMTID |
Unsigned32 |
ieee8021SpbEctDynamicEntryBaseVid (1.3.111.2.802.1.1.26.1.5.1.2) |
not-accessible |
VlanId |
B-VLAN ID. |
As per the MIB. |
ieee8021SpbEctDynamicEntryMode (1.3.111.2.802.1.1.26.1.5.1.3) |
read-only |
IEEE8021SpbEctMode |
INTEGER{ disabled(1), spbm(2), spbv(3) } |
Operating mode of the B-VLAN ID. |
As per the MIB. |
ieee8021SpbEctDynamicEntryLocalUse (1.3.111.2.802.1.1.26.1.5.1.4) |
read-only |
TruthValue |
true(1), false(2) |
Whether the ECT is in use locally for this B-VLAN ID. |
As per the MIB. |
ieee8021SpbEctDynamicEntryRemoteUse (1.3.111.2.802.1.1.26.1.5.1.5) |
read-only |
TruthValue |
true(1), false(2) |
Whether the remote ECT is in use for this B-VLAN ID. |
As per the MIB. |
ieee8021SpbEctDynamicEntryIngressCheckDiscards (1.3.111.2.802.1.1.26.1.5.1.6) |
read-only |
Unsigned32 |
Standard MIB values. |
Number of SA check failures for this mapping. |
ieee8021SpbAdjStaticTable
About this table
Use this table to configure neighbor interface parameters or obtain neighbor interface information.
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ieee8021SpbAdjStaticEntryTopIx and ieee8021SpbAdjStaticEntryIfIndex.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbAdjStaticEntryTopIx(1.3.111.2.802.1.1.26.1.6.1.1) |
not-accessible |
IEEE8021SpbMTID |
Unsigned32 |
ieee8021SpbAdjStaticEntryIfIndex(1.3.111.2.802.1.1.26.1.6.1.2) |
not-accessible |
InterfaceIndexOrZero |
Integer32(0..2147483647) |
Interface index. |
The wildcard value of 0 is not supported. |
ieee8021SpbAdjStaticEntryMetric(1.3.111.2.802.1.1.26.1.6.1.3) |
read-create |
IEEE8021SpbLinkMetric |
Integer32(1..16777215) |
Link metric value. |
As per the MIB. |
ieee8021SpbAdjStaticEntryIfAdminState(1.3.111.2.802.1.1.26.1.6.1.4) |
read-create |
IEEE8021SpbAdjState |
INTEGER{ up(1), down(2), testing(3) } |
Administration state of the interface. |
Not supported. |
ieee8021SpbAdjStaticEntryRowStatus(1.3.111.2.802.1.1.26.1.6.1.5) |
read-create |
RowStatus |
active(1), createAndGo(4), destroy(6) |
Row status. |
ieee8021SpbAdjDynamicTable
About this table
This table contains SPB neighbor dynamic information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021SpbAdjDynamicEntryTopIx, ieee8021SpbAdjDynamicEntryIfIndex, and ieee8021SpbAdjDynamicEntryPeerSysId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbAdjDynamicEntryTopIx (1.3.111.2.802.1.1.26.1.7.1.1) |
not-accessible |
IEEE8021SpbMTID |
Unsigned32 |
ieee8021SpbAdjDynamicEntryIfIndex (1.3.111.2.802.1.1.26.1.7.1.2) |
not-accessible |
Interface index. |
ieee8021SpbAdjDynamicEntryPeerSysId (1.3.111.2.802.1.1.26.1.7.1.3) |
not-accessible |
MacAddress |
OCTET STRING (6) |
SPB neighbor system ID. |
As per the MIB. |
ieee8021SpbAdjDynamicEntryPort (1.3.111.2.802.1.1.26.1.7.1.4) |
read-only |
IEEE8021BridgePortNumber |
Unsigned32 (1..65535) |
Port number to reach this adjacency. |
As per the MIB. |
ieee8021SpbAdjDynamicEntryIfOperState (1.3.111.2.802.1.1.26.1.7.1.5) |
read-only |
up(1), down(2), testing(3) |
Operational state of this port.. |
Not supported. The value is always up(1). |
ieee8021SpbAdjDynamicEntryPeerSysName (1.3.111.2.802.1.1.26.1.7.1.6) |
read-only |
SnmpAdminString |
OCTET STRING (0..255) |
Neighbor system name. |
ieee8021SpbAdjDynamicEntryPeerAgreeDigest (1.3.111.2.802.1.1.26.1.7.1.7) |
read-only |
IEEE8021SpbDigest |
OCTET STRING (32) |
Neighbor topology agreement digest value. |
As per the MIB. |
ieee8021SpbAdjDynamicEntryPeerMCID (1.3.111.2.802.1.1.26.1.7.1.8) |
read-only |
IEEE8021SpbMCID |
OCTET STRING (51) |
Neighbor MST Identifier MCID. |
As per the MIB. |
ieee8021SpbAdjDynamicEntryPeerAuxMCID (1.3.111.2.802.1.1.26.1.7.1.9) |
read-only |
IEEE8021SpbMCID |
OCTET STRING (51) |
Neighbor auxiliary MST Identifier. |
As per the MIB. |
ieee8021SpbAdjDynamicEntryLocalCircuitID (1.3.111.2.802.1.1.26.1.7.1.10) |
read-only |
Unsigned32 |
Local circuit ID. |
As per the MIB. |
ieee8021SpbAdjDynamicEntryPeerLocalCircuitID (1.3.111.2.802.1.1.26.1.7.1.11) |
read-only |
Unsigned32 |
Neighbor circuit ID. |
As per the MIB. |
ieee8021SpbAdjDynamicEntryPortIdentifier (1.3.111.2.802.1.1.26.1.7.1.12) |
read-only |
Unsigned32 |
Port ID of the circuit selected by the local bridge when multiple candidate circuits are available. |
As per the MIB. |
ieee8021SpbAdjDynamicEntryPeerPortIdentifier (1.3.111.2.802.1.1.26.1.7.1.13) |
read-only |
Unsigned32 |
Port ID of the circuit selected by the neighbor bridge when multiple candidate circuits are available. |
As per the MIB. |
ieee8021SpbAdjDynamicEntryIsisCircIndex (1.3.111.2.802.1.1.26.1.7.1.14) |
read-only |
Unsigned32 |
The isisCircTable reference. This allows cross referencing to an IS-IS MIB. |
ieee8021SpbTopNodeTable
About this table
Use this table to obtain bridge information in an SPB network.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021SpbTopNodeEntryTopIx and ieee8021SpbTopNodeEntrySysId.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbTopNodeEntryTopIx (1.3.111.2.802.1.1.26.1.8.1.1) |
not-accessible |
IEEE8021SpbMTID |
Unsigned32 |
ieee8021SpbTopNodeEntrySysId (1.3.111.2.802.1.1.26.1.8.1.2) |
not-accessible |
MacAddress |
OCTET STRING (6) |
System ID of a bridge. |
ieee8021SpbTopNodeEntryBridgePriority (1.3.111.2.802.1.1.26.1.8.1.3) |
read-only |
OCTET STRING (2) |
Bridge priority. |
As per the MIB. |
ieee8021SpbmTopNodeEntrySPsourceID (1.3.111.2.802.1.1.26.1.8.1.4) |
read-only |
OCTET STRING (3) |
Shortest path source ID. |
As per the MIB. |
ieee8021SpbTopNodeEntrySysName (1.3.111.2.802.1.1.26.1.8.1.5) |
read-only |
SnmpAdminString |
System name. |
ieee8021SpbTopEctTable
About this table
Use this table to obtain ECT and B-VLAN information in an SPB network.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021SpbTopEctEntryTopIx, ieee8021SpbTopEctEntrySysId, and ieee8021SpbTopEctEntryBaseVid.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbTopEctEntryTopIx (1.3.111.2.802.1.1.26.1.9.1.1) |
not-accessible |
IEEE8021SpbMTID |
Unsigned32 |
ieee8021SpbTopEctEntrySysId (1.3.111.2.802.1.1.26.1.9.1.2) |
not-accessible |
MacAddress |
OCTET STRING (6) |
System ID in a mapping entry. |
ieee8021SpbTopEctEntryBaseVid (1.3.111.2.802.1.1.26.1.9.1.3) |
not-accessible |
VlanIdOrAny |
B-VLAN ID in a mapping entry. |
ieee8021SpbTopEctEntryEctAlgorithm (1.3.111.2.802.1.1.26.1.9.1.4) |
read-only |
OCTET STRING (4) |
ECT algorithm in a mapping entry. |
As per the MIB. |
ieee8021SpbTopEctEntryMode (1.3.111.2.802.1.1.26.1.9.1.5) |
read-only |
Interface operating mode. |
As per the MIB. |
ieee8021SpbvTopEctSysMode (1.3.111.2.802.1.1.26.1.9.1.6 ) |
read-only |
IEEE8021SpbMode |
INTEGER{ auto(1), manual(2) } |
SPBV system mode. |
Not supported. |
ieee8021SpbvTopEctEntrySpvid (1.3.111.2.802.1.1.26.1.9.1.7) |
read-only |
VlanIdOrNone |
VID used to load traffic in SPBV mode. |
Not supported. |
ieee8021SpbTopEctEntryLocalUse (1.3.111.2.802.1.1.26.1.9.1.8) |
read-only |
TruthValue |
true(1), false(2) |
Whether the local bridge uses this B-VLAN to load traffic. |
As per the MIB. |
Ieee8021SpbTopEdgeTable
About this table
Use this table to obtain link information for a pair of devices.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021SpbTopEdgeEntryTopIx, ieee8021SpbTopEdgeEntrySysIdNear, and ieee8021SpbTopEdgeEntrySysIdFar.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbTopEdgeEntryTopIx (1.3.111.2.802.1.1.26.1.10.1.1) |
not-accessible |
IEEE8021SpbMTID |
Unsigned32 |
ieee8021SpbTopEdgeEntrySysIdNear (1.3.111.2.802.1.1.26.1.10.1.2) |
not-accessible |
MacAddress |
OCTET STRING (6) |
System ID of the local bridge. |
ieee8021SpbTopEdgeEntrySysIdFar (1.3.111.2.802.1.1.26.1.10.1.3) |
not-accessible |
MacAddress |
OCTET STRING (6) |
System ID of the remote bridge. |
ieee8021SpbTopEdgeEntryMetricNear2Far (1.3.111.2.802.1.1.26.1.10.1.4) |
read-only |
Link metric for the local bridge to reach the remote bridge. |
As per the MIB. |
ieee8021SpbTopEdgeEntryMetricFar2Near (1.3.111.2.802.1.1.26.1.10.1.5) |
read-only |
Link metric for the remote bridge to reach the local bridge. |
As per the MIB. |
ieee8021SpbmTopSrvTable
About this table
Use this table to obtain information about SPBM PBB services.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021SpbmTopSrvEntryTopIx, ieee8021SpbmTopSrvEntrySysId, ieee8021SpbmTopSrvEntryIsid, ieee8021SpbmTopSrvEntryBaseVid, and ieee8021SpbmTopSrvEntryMac.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbmTopSrvEntryTopIx(1.3.111.2.802.1.1.26.1.11.1.1) |
not-accessible |
IEEE8021SpbMTID |
Unsigned32 |
ieee8021SpbmTopSrvEntrySysId(1.3.111.2.802.1.1.26.1.11.1.2) |
not-accessible |
MacAddress |
OCTET STRING (6) |
System ID. |
ieee8021SpbmTopSrvEntryIsid(1.3.111.2.802.1.1.26.1.11.1.3) |
not-accessible |
IEEE8021SpbServiceIdentifierOrAny |
Unsigned32(255..16777215) |
I-SID. |
ieee8021SpbmTopSrvEntryBaseVid(1.3.111.2.802.1.1.26.1.11.1.4) |
not-accessible |
VlanIdOrAny |
B-VLAN ID. |
ieee8021SpbmTopSrvEntryMac(1.3.111.2.802.1.1.26.1.11.1.5) |
not-accessible |
MacAddress |
OCTET STRING (6) |
B-MAC address. |
ieee8021SpbmTopSrvEntryIsidFlags(1.3.111.2.802.1.1.26.1.11.1.6) |
read-only |
IEEE8021PbbIngressEgress |
BITS{ ingress(0), egress(1) } |
I-SID transmit flags. |
As per the MIB. |
ieee8021SpbvTopSrvTable
About this table
This table is obsolete. It contains SPBV PBB service information.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are ieee8021SpbvTopSrvEntryTopIx, ieee8021SpbvTopSrvEntrySysId, and ieee8021SpbvTopSrvEntryMMac.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ieee8021SpbvTopSrvEntryTopIx (1.3.111.2.802.1.1.26.1.12.1.1) |
not-accessible |
IEEE8021SpbMTID |
Unsigned32 |
As per the MIB. |
ieee8021SpbvTopSrvEntrySysId(1.3.111.2.802.1.1.26.1.12.1.2) |
not-accessible |
MacAddress |
OCTET STRING (6) |
System ID. |
As per the MIB. |
ieee8021SpbvTopSrvEntryMMac(1.3.111.2.802.1.1.26.1.12.1.3) |
not-accessible |
MacAddress |
OCTET STRING (6) |
Multicast MAC address. |
As per the MIB. |
ieee8021SpbvTopSrvEntryBaseVid(1.3.111.2.802.1.1.26.1.12.1.4) |
read-only |
VlanId |
B-VLAN ID. |
As per the MIB. |
ieee8021SpbvTopSrvEntryMMacFlags(1.3.111.2.802.1.1.26.1.12.1.5) |
read-only |
Transmit flags of the multicast MAC address. |
As per the MIB. |
