17-Network Management and Monitoring Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath F1000[F5000][VFW] Firewalls Series Configuration Guides(V7)-6W60017-Network Management and Monitoring Configuration Guide
14-System maintenance and debugging configuration
Using ping, tracert, and system debugging
This chapter covers ping, tracert, and information about debugging the system.
Ping
About ping
Use the ping utility to determine if an address is reachable.
Ping sends ICMP echo requests (ECHO-REQUEST) to the destination device. Upon receiving the requests, the destination device responds with ICMP echo replies (ECHO-REPLY) to the source device. The source device outputs statistics about the ping operation, including the number of packets sent, number of echo replies received, and the round-trip time. You can measure the network performance by analyzing these statistics.
You can use the ping –r command to display the routers through which ICMP echo requests have passed. The test procedure of ping –r is as shown in Figure 1:
1.     The source device (Device A) sends an ICMP echo request to the destination device (Device C) with the RR option empty.
2.     The intermediate device (Device B) adds the IP address of its outbound interface (1.1.2.1) to the RR option of the ICMP echo request, and forwards the packet.
3.     Upon receiving the request, the destination device copies the RR option in the request and adds the IP address of its outbound interface (1.1.2.2) to the RR option. Then the destination device sends an ICMP echo reply.
4.     The intermediate device adds the IP address of its outbound interface (1.1.1.2) to the RR option in the ICMP echo reply, and then forwards the reply.
5.     Upon receiving the reply, the source device adds the IP address of its inbound interface (1.1.1.1) to the RR option. The detailed information of routes from Device A to Device C is formatted as: 1.1.1.1 <-> {1.1.1.2; 1.1.2.1} <-> 1.1.2.2.
Figure 1 Ping operation
Using a ping command to test network connectivity
Perform the following tasks in any view:
·     Determine if an IPv4 address is reachable.
ping [ ip ] [ -a source-ip | -c count | -f | -h ttl | -i interface-type interface-number | -m interval | -n | -p pad | -q | -r | -s packet-size | -t timeout | -tos tos | -v | -vpn-instance vpn-instance-name ] * host
Increase the timeout time (indicated by the -t keyword) on a low-speed network.
·     Determine if an IPv6 address is reachable.
ping ipv6 [ -a source-ipv6 | -c count | -i interface-type interface-number | -m interval | -q | -s packet-size | -t timeout | -tc traffic-class | -v | -vpn-instance vpn-instance-name ] * host
Tracert
About tracert
Tracert (also called Traceroute) enables retrieval of the IP addresses of Layer 3 devices in the path to a destination. In the event of network failure, use tracert to test network connectivity and identify failed nodes.
Figure 2 Tracert operation
Tracert uses received ICMP error messages to get the IP addresses of devices. Tracert works as shown in Figure 2:
6.     The source device sends a UDP packet with a TTL value of 1 to the destination device. The destination UDP port is not used by any application on the destination device.
7.     The first hop (Device B, the first Layer 3 device that receives the packet) responds by sending a TTL-expired ICMP error message to the source, with its IP address (1.1.1.2) encapsulated. This way, the source device can get the address of the first Layer 3 device (1.1.1.2).
8.     The source device sends a packet with a TTL value of 2 to the destination device.
9.     The second hop (Device C) responds with a TTL-expired ICMP error message, which gives the source device the address of the second Layer 3 device (1.1.2.2).
10.     This process continues until a packet sent by the source device reaches the ultimate destination device. Because no application uses the destination port specified in the packet, the destination device responds with a port-unreachable ICMP message to the source device, with its IP address encapsulated. This way, the source device gets the IP address of the destination device (1.1.3.2).
11.     The source device determines that:
¡     The packet has reached the destination device after receiving the port-unreachable ICMP message.
¡     The path to the destination device is 1.1.1.2 to 1.1.2.2 to 1.1.3.2.
Before you use a tracert command, perform the tasks in this section.
For an IPv4 network:
·     Enable sending of ICMP timeout packets on the intermediate devices (devices between the source and destination devices). If the intermediate devices are H3C devices, execute the ip ttl-expires enable command on the devices. For more information about this command, see IP performance optimazition commands in Layer 3—IP Services Command Reference.
·     Enable sending of ICMP destination unreachable packets on the destination device. If the destination device is an H3C device, execute the ip unreachables enable command. For more information about this command, see IP performance optimization commands in Layer 3—IP Services Command Reference.
For an IPv6 network:
·     Enable sending of ICMPv6 timeout packets on the intermediate devices (devices between the source and destination devices). If the intermediate devices are H3C devices, execute the ipv6 hoplimit-expires enable command on the devices. For more information about this command, see IPv6 basics commands in Layer 3—IP Services Command Reference.
·     Enable sending of ICMPv6 destination unreachable packets on the destination device. If the destination device is an H3C device, execute the ipv6 unreachables enable command. For more information about this command, see IPv6 basics commands in Layer 3—IP Services Command Reference.
Using a tracert command to identify failed or all nodes in a path
·     Trace the route to an IPv4 destination.
tracert [ -a source-ip | -f first-ttl | -i interface-type interface-number | -m max-ttl | -p port | -q packet-number | -t tos | -vpn-instance vpn-instance-name [ -resolve-as { global | none | vpn } ] | -w timeout ] * host
·     Trace the route to an IPv6 destination.
tracert ipv6 [ -f first-hop | -i interface-type interface-number | -m max-hops | -p port | -q packet-number | -t traffic-class | -vpn-instance vpn-instance-name [ -resolve-as { global | none | vpn } ]  | -w timeout ] * host
System debugging
About system debugging
The device supports debugging for the majority of protocols and features, and provides debugging information to help users diagnose errors.
The following switches control the display of debugging information:
·     Module debugging switch—Controls whether to generate the module-specific debugging information.
·     Screen output switch—Controls whether to display the debugging information on a certain screen. Use the terminal monitor and terminal logging level commands to turn on the screen output switch. For more information about the commands, see information center commands in Network Management and Monitoring Command Reference.
As shown in Figure 3, the device can provide debugging for the three modules 1, 2, and 3. The debugging information can be output on a terminal only when both the module debugging switch and the screen output switch are turned on.
Debugging information is typically displayed on a console. You can also send debugging information to other destinations. For more information, see "Configuring the information center."
Figure 3 Relationship between the module and screen output switch
Configuring debugging
CAUTION
CAUTION:
Output of excessive debugging messages increases the CPU usage and downgrades the system performance. To guarantee system performance, enable debugging only for modules that are in an exceptional condition.
Enable debugging for modules for troubleshooting purposes. When debugging is complete, use the undo debugging all command to disable all the debugging functions.
Perform the following tasks in user view:
1.     Enable debugging for a module.
debugging module-name [ option ]
By default, debugging is disabled for all modules.
Display and maintenance commands for debugging
Display the enabled debugging features.
display debugging [ module-name ]
