- 17-Network Management and Monitoring Configuration Guide
- 01-Information center configuration
- 02-Flow log configuration
- 03-Fast log output configuration
- 04-NetStream configuration
- 05-Mirroring configuration
- 06-Packet capture configuration
- 07-NQA configuration
- 08-Track configuration
- 09-BFD configuration
- 10-Monitor Link configuration
- 11-Smart Link configuration
- 12-Interface backup configuration
- 13-Interface collaboration configuration
- 14-System maintenance and debugging configuration
- 15-NTP configuration
- 16-EAA configuration
- 17-Process monitoring and maintenance configuration
- 18-NETCONF configuration
- 19-CWMP configuration
- 20-SNMP configuration
- 21-RMON configuration
- 22-Event MIB configuration
- 23-Process placement configuration
- 24-gRPC configuration
- 25-Cloud connection configuration
00-Preface | 112.03 KB |
Preface
· This configuration guide describes the fundamentals and configuration procedures for network management and monitoring features, including system maintenance and debugging (ping, tracert, and system debugging), NQA, NTP, EAA, process monitoring and maintenance, NETCONF, information center, SNMP, NetStream, RMON, flow log, event MIB, fast log output, mirroring, and CWMP.
· Security zones, security policies, object groups, object policies, APR, and session management.
· User access and authentication features (such as AAA, portal, user identification, password control, and PKI).
· Data security features (such as public key management, SSL, SSH, and crypto engine).
· Attack protection features (such as ASPF, connection limit, IP source guard, ARP attack protection, ND attack defense, uRPF, attack detection and prevention, and IP-MAC binding).
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
