06-IP Multicast Configuration Guide
HomeSupportSwitchesS9820 SeriesConfigure & DeployConfiguration GuidesH3C S9820-64H Switch Configuration Guides-Release 6715-6W10006-IP Multicast Configuration Guide
09-Multicast VPN configuration
09-Multicast VPN configuration 1.07 MB
Multicast VPN overview·· 1
Typical network diagram·· 1
MVPN scheme· 1
Basic concepts in MDT-based MVPN· 1
How MDT-based MVPN works· 2
Default MDT establishment 2
Default MDT-based delivery· 6
MDT switchover 8
Inter-AS MDT-based MVPN· 9
MDT-based MVPN inter-AS option A· 9
MDT-based MVPN inter-AS option B· 10
MDT-based MVPN inter-AS option C· 11
MVPN extranet 12
Protocols and standards· 14
Configuring multicast VPN·· 15
Restrictions and guidelines: Multicast VPN configuration· 15
MDT-based MVPN tasks at a glance· 15
Configuring MDT-based MVPN· 15
Prerequisites for configuring MDT-based MVPN· 15
Enabling IP multicast routing for a VPN instance· 15
Creating an MDT-based MVPN instance· 16
Creating an MVPN address family· 17
Specifying the default group· 17
Specifying the MVPN source interface· 17
Configuring MDT switchover parameters· 18
Configuring the RPF vector feature· 19
Enabling data group reuse logging· 19
Setting the DSCP value for outgoing data group switchover packets· 20
Configuring BGP MDT· 20
Configuring BGP MDT peers or peer groups· 20
Configuring a BGP MDT route reflector 21
Configuring BGP MDT optimal route selection delay· 22
Configuring an MVPN extranet RPF selection policy· 22
Multicast VPN configuration examples· 23
Example: Configuring intra-AS MDT-based MVPN· 23
Example: Configuring intra-AS M6VPE· 37
Example: Configuring MDT-based MVPN inter-AS option B· 53
Example: Configuring MDT-based MVPN inter-AS option C· 66
Example: Configuring receiver-PE-based MVPN extranet 80
Troubleshooting MDT-based MVPN· 89
A default MDT cannot be established· 89
An MVRF cannot be created· 89
Multicast VPN implements multicast delivery in VPNs.
As shown in Figure 1, VPN A contains Site 1 and Site 3, and VPN B contains Site 2 and Site 4.
Figure 1 Typical network diagram for multicast VPN
VPN multicast traffic between the PEs and the CEs is transmitted on a per-VPN-instance basis. The public network multicast traffic between the PEs and the P device is transmitted through the public network. Multicast VPN provides independent multicast services for the public network, VPN A, and VPN B.
For more information about CEs, PEs and Ps, see MPLS Configuration Guide.
MVPN scheme
MVPN is used to implement multicast VPN. MVPN only requires the PEs to support multiple VPN instances and the public network provided by the service provider to support multicast. There is no need to upgrade CEs and Ps or change their PIM configurations. The MVPN solution is transparent to CEs and Ps.
This section introduces the following basic concepts in MDT-based MVPN:
·     MVPN—An MVPN logically defines the transmission boundary of the multicast traffic of a VPN over the public network. It also physically identifies all the PEs that support that VPN instance on the public network. Different VPN instances correspond to different MVPNs.
·     Multicast distribution tree (MDT)—An MDT is a multicast distribution tree constructed by all PEs in the same VPN. MDT includes default MDT and data MDT.
·     Multicast tunnel (MT)—An MT is a tunnel that interconnects all PEs in an MVPN. The local PE encapsulates a VPN multicast packet into a public network multicast packet and forwards it through the MT over the public network. The remote PE decapsulates the public network multicast packet to get the original VPN multicast packet.
·     Multicast tunnel interface (MTI)—An MTI is the entrance or exit of an MT, equivalent to an entrance or exit of an MVPN. MTIs are automatically created when the MVPN for the VPN instance is created. PEs use the MTI to access the MT. The local PE sends VPN data out of the MTI. The remote PEs receive the private data from their MTIs. An MTI runs the same PIM mode as the VPN instance to which the MTI belongs. PIM is enabled on MTIs when a minimum of one interface in the VPN instance is enabled with PIM. When PIM is disabled on all interfaces in the VPN instance, PIM is also disabled on MTIs.
·     Default-group—A default group is a unique multicast address assigned to each MVPN on the public network. It is the unique identifier of an MVPN on the public network and helps build the default MDT for an MVPN on the public network. A PE encapsulates a VPN multicast packet (a multicast protocol packet or a multicast data packet) into a public network multicast packet. The default group address is used as the public network multicast group.
·     Default MDT—A default MDT uses a default group address as its group address. In a VPN, the default MDT is uniquely identified by the default group. A default MDT is automatically created after the default group is specified and will always exist on the public network, regardless of the presence of any multicast services on the public network or the VPN.
·     Data group—An MVPN is assigned a unique data group for MDT switchover. The ingress PE selects a least used address from the data group range to encapsulate the VPN multicast packets when the multicast traffic of the VPN arrives at the PE. Other PEs are notified to use the address to forward the multicast traffic for that VPN. This initiates the switchover to the data MDT.
·     Data MDT—A data MDT is an MDT that uses a data group as it group address. At MDT switchover, PEs with downstream receivers join a data group to build a data MDT. The ingress PE forwards the encapsulated VPN multicast traffic along the data MDT over the public network.
For a VPN instance, multicast data transmission on the public network is transparent. The VPN data is exchanged between the MTIs of the local PE and the remote PE. This implements the seamless transmission of the VPN data over the public network. However, the multicast data transmission process (the MDT transmission process) over the public network is very complicated.
The following types of PIM neighboring relationships exist in MVPN:
·     PE-P PIM neighboring relationship—Established between the public network interface on a PE and the peer interface on the P device over the link.
·     PE-PE PIM neighboring relationship—Established between PEs that are in the same VPN instance after they receive the PIM hello packets.
·     PE-CE PIM neighboring relationship—Established between a PE interface that is bound with the VPN instance and the peer interface on the CE over the link.
The multicast routing protocol running on the public network can be PIM-DM, PIM-SM, BIDIR-PIM, or PIM-SSM. The process of creating a Default MDT is different in these PIM modes.
Default MDT establishment in a PIM-DM network
Figure 2 Default MDT establishment in a PIM-DM network
As shown in Figure 2, PIM-DM is enabled on the network, and all the PEs support VPN instance A. The process of establishing a default MDT is as follows:
1.     To establish PIM neighboring relationships with PE 2 and PE 3 through the MTI for VPN instance A, PE 1 does the following:
a.     Encapsulates the PIM protocol packet of the private network into a public network multicast data packet. PE 1 does this by specifying the source address as the IP address of the MVPN source interface and the multicast group address as the default group address.
b.     Sends the multicast data packet to the public network.
For other PEs that support VPN instance A as default group members, PE 1 of VPN instance A initiates a flood-prune process in the entire public network. A (11.1.1.1, 239.1.1.1) state entry is created on each device along the path on the public network. This forms an SPT with PE 1 as the root, and PE 2 and PE 3 as leaves.
2.     At the same time, PE 2 and PE 3 separately initiate a similar flood-prune process.
Finally, three independent SPTs are established in the MVPN, constituting the default MDT in the PIM-DM network.
Default MDT establishment in a PIM-SM network
Figure 3 Default MDT establishment in a PIM-SM network
As shown in Figure 3, PIM-SM is enabled on the network, and all the PEs support VPN instance A. The process of establishing a default MDT is as follows:
1.     PE 1 initiates a join to the public network RP by specifying the multicast group address as the default group address in the join message. A (*, 239.1.1.1) state entry is created on each device along the path on the public network.
2.     At the same time, PE 2 and PE 3 separately initiate a similar join process.
Finally, an RPT is established in the MVPN, with the public network RP as the root and PE 1, PE 2, and PE 3 as leaves.
3.     To establish PIM neighboring relationships with PE 2 and PE 3 through the MTI for VPN instance A, PE 1 does the following:
The public network interface of PE 1 registers the multicast source with the public network RP, and the public network RP initiates a join to PE 1. A (11.1.1.1, 239.1.1.1) state entry is created on each device along the path on the public network.
4.     At the same time, PE 2 and PE 3 separately initiate a similar register process.
Finally, three SPTs between the PEs and the RP are established in the MVPN.
In the PIM-SM network, the RPT, or the (*, 239.1.1.1) tree, and the three independent SPTs constitute the default MDT.
Default MDT establishment in a BIDIR-PIM network
Figure 4 Default MDT establishment in a BIDIR-PIM network
As shown in Figure 4, BIDIR-PIM runs on the network, and all the PEs support VPN instance A. The process of establishing a default MDT is as follows:
At the same time, PE 2 and PE 3 separately initiate a similar join process. Finally, a receiver-side RPT is established in the MVPN, with the public network RP as the root and PE 1, PE 2, and PE 3 as leaves.
2.     PE 1 sends a multicast packet with the default group address as the multicast group address. The DF of each network segment on the public network forwards the multicast packet to the RP. Each device on the path creates a (*, 239.1.1.1) state entry.
At the same time, PE 2 and PE 3 separately initiate a similar process. Finally, three source-side RPTs are established in the MVPN, with PE 1, PE 2, and PE 3 as the roots and as the public network RP as the leave.
3.     The receiver-side RPT and the three source-side RPTs constitute the default MDT in the BIDIR-PIM network.
Default MDT establishment in a PIM-SSM network
Figure 5 Default MDT establishment in a PIM-SSM network
As shown in Figure 5, PIM-SSM runs on the network, and all the PEs support VPN instance A. The process of establishing a default MDT is as follows:
1.     PE 1, PE 2, and PE 3 exchange MDT route information (including BGP interface address and the default group address) through BGP.
2.     PE 1 sends a subscribe message to PE 2 and PE 3. Each device on the public network creates an (S, G) entry. An SPT is established in the MVPN with PE 1 as the root and PE 2 and PE 3 as the leaves.
At the same time, PE 2 and PE 3 separately initiate a similar process, and establish an SPT with itself as the root and the other PEs as the leaves.
3.     The three independent SPTs constitute the default MDT in the PIM-SSM network.
In PIM-SSM, the term "subscribe message" refers to a join message.
Default MDT characteristics
No matter which PIM mode is running on the public network, the default MDT has the following characteristics:
·     All PEs that support the same VPN instance join the default MDT.
·     All multicast packets that belong to this VPN are forwarded along the default MDT to every PE on the public network, even if no active downstream receivers exist.
After the default MDT is established, the multicast source forwards the VPN multicast data to the receivers in each site along the default MDT. The VPN multicast packets are encapsulated into public network multicast packets on the local PE, and transmitted along the default MDT. Then, they are decapsulated on the remote PE and transmitted in that VPN site.
VPN multicast data packets are forwarded across the public network differently in the following circumstances:
·     If PIM-DM or PIM-SSM is running in the VPN, the multicast source forwards multicast data packets to the receivers along the VPN SPT across the public network.
·     When PIM-SM is running in the VPN:
¡     Before the RPT-to-SPT switchover, if the multicast source and the VPN RP are in different sites, the VPN multicast data packets travel to the VPN RP along the VPN SPT across the public network. If the VPN RP and the receivers are in different sites, the VPN multicast data packets travel to the receivers along the VPN RPT over the public network.
¡     After the RPT-to-SPT switchover, if the multicast source and the receivers are in different sites, the VPN multicast data packets travel to the receivers along the VPN SPT across the public network.
·     When BIDIR-PIM is running in the VPN, if the multicast source and the VPN RP are in different sites, the multicast source sends multicast data to the VPN RP across the public network along the source-side RPT. If the VPN RP and the receivers are in different sites, the multicast data packets travel to the receivers across the public network along the receiver-side RPT.
For more information about RPT-to-SPT switchover, see "PIM overview."
The following example explains how multicast data packets are delivered based on the default MDT when PIM-DM is running in both the public network and the VPN network.
As shown in Figure 6:
·     PIM-DM is running in both the public network and the VPN sites.
·     Receiver of the VPN multicast group G (225.1.1.1) in Site 2 is attached to CE 2.
·     Source in Site 1 sends multicast data to multicast group (G).
·     The default group address used to forward public network multicast data is 239.1.1.1.
Figure 6 Multicast data packet delivery
A VPN multicast data packet is delivered across the public network as follows:
1.     Source sends a VPN multicast data packet (192.1.1.1, 225.1.1.1) to CE 1.
2.     CE 1 forwards the VPN multicast data packet along an SPT to PE 1, and the VPN instance on PE 1 examines the MVRF.
If the outgoing interface list of the forwarding entry contains an MTI, PE 1 processes the VPN multicast data packet as described in step 3. The VPN instance on PE 1 considers the VPN multicast data packet to have been sent out of the MTI, because step 3 is transparent to it.
3.     PE 1 encapsulates the VPN multicast data packet into a public network multicast packet (11.1.2.1, 239.1.1.1) by using the GRE method. The source IP address of the packet is the MVPN source interface 11.1.1.1, and the destination address is the default group address 239.1.1.1. PE 1 then forwards it to the public network.
4.     The default MDT forwards the multicast data packet (11.1.2.1, 239.1.1.1) to the public network instance on all the PEs. After receiving this packet, every PE decapsulates it to get the original VPN multicast data packet, and passes it to the corresponding VPN instance. If a PE has a downstream interface for an SPT, it forwards the VPN multicast packet down the SPT. Otherwise, it discards the packet.
5.     The VPN instance on PE 2 looks up the MVRF and finally delivers the VPN multicast data to Receiver.
By now, the process of transmitting a VPN multicast data packet across the public network is completed.
MDT switchover
Switching from default MDT to data MDT
When a multicast packet of a VPN is transmitted through the default MDT on the public network, the packet is forwarded to all PEs that support that VPN instance. This occurs whether or not any active receivers exist in the attached sites. When the VPN multicast traffic is high, multicast data might get flooded on the public network. This increases the bandwidth use and brings extra burden on the PEs.
To optimize multicast transmission of large VPN multicast traffic that enters the public network, the MDT-based MVPN solution introduces a dedicated data MDT. The data MDT is built between the PEs that connect VPN multicast receivers and multicast sources. When specific network criteria are met, a switchover from the default MDT to the data MDT occurs to forward VPN multicast traffic to receivers.
The device initiates a switchover of the default MDT to the data MDT as follows:
1.     The source-side PE (PE 1, for example) starts a data-delay timer when receiving the first multicast VPN packet that matches the switchover criterion.
2.     When the data-delay timer expires, PE 1 sends an MDT switchover message to all the other PE devices down the default-MDT. This message contains the multicast source address, the multicast group address, and the least-used data-group address in the data-group range.
3.     Each PE that receives this message examines whether it interfaces with a VPN that has receivers of that VPN multicast stream.
If so, it joins the data MDT rooted at PE 1. Otherwise, it caches the message and will join the data MDT when it has attached receivers.
4.     After sending the MDT switchover message, PE 1 starts the data-delay timer. When the timer expires, PE 1 uses the default group address to encapsulate the VPN multicast data. The multicast data is then forwarded down the data MDT.
5.     After the multicast traffic is switched from the default MDT to the data MDT, PE 1 continues sending MDT switchover messages periodically. Subsequent PEs with attached receivers can then join the data MDT. When a downstream PE no longer has active receivers attached to it, it leaves the data MDT.
For a given VPN instance, the default MDT and the data MDT are both forwarding tunnels in the same MVPN. A default MDT is uniquely identified by a default group address, and a data MDT is uniquely identified by a data group address. Each default group is uniquely associated with a data group range.
Backward switching from data MDT to default MDT
After the VPN multicast traffic is switched to the data-MDT, the multicast traffic conditions might change and no longer meet the switchover criterion. In this case, PE 1, as in the preceding example, initiates a backward MDT switchover process when any of the following criteria are met:
·     The associated data-group range is changed, and the data-group address for encapsulating the VPN multicast data is out of the new address range.
·     The ACL rule for controlling the switchover from the default-MDT to the data-MDT has changed, and the VPN multicast data fails to pass the new ACL rule.
In an inter-AS VPN networking scenario, VPN sites are located in multiple ASs. These sites must be interconnected. Inter-AS VPN provides the following solutions:
·     VRF-to-VRF connections between ASBRs—This solution is also called inter-AS option A.
·     EBGP redistribution of labeled VPN-IPv4 routes between ASBRs—ASBRs advertise VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option B.
·     Multihop EBGP redistribution of labeled VPN-IPv4 routes between PE devices—PEs advertise VPN-IPv4 routes to each other through MP-EBGP. This solution is also called inter-AS option C.
For more information about the three inter-AS VPN solutions, see MPLS L3VPN configuration in MPLS Configuration Guide.
Based on these solutions, there are three ways to implement inter-AS MVPN:
·     MDT-based MVPN inter-AS option A.
·     MDT-based MVPN inter-AS option B.
·     MDT-based MVPN inter-AS option C.
As shown in Figure 7:
·     Two VPN instances are in AS 1 and AS 2.
·     PE 3 and PE 4 are ASBRs for AS 1 and AS 2, respectively.
·     PE 3 and PE 4 are interconnected through their respective VPN instance and treat each other as a CE.
Figure 7 MVPN inter-AS option A
To implement MVPN inter-AS option A, a separate MVPN must be created in each AS. Multicast data is transmitted between the VPNs in different ASs through the MDs.
Multicast packets of VPN instance 1 are delivered as follows:
1.     CE 1 forwards the multicast packet of VPN instance 1 to PE 1.
2.     PE 1 encapsulates the multicast packet into a public network packet and forwards it to PE 3 through the MTI interface in MVPN 1.
3.     PE 3 considers PE 4 as a CE of VPN instance 1, so PE 3 forwards the multicast packet to PE 4.
4.     PE 4 considers PE 3 as a CE of VPN instance 2, so it forwards the multicast packet to PE 2 through the MTI interface in MVPN 2 on the public network.
5.     PE 2 forwards the multicast packet to CE 2.
Because only VPN multicast data is forwarded between ASBRs, different PIM modes can run within different ASs. However, the same PIM mode must run on all interfaces that belong to the same VPN (including interfaces with VPN bindings on ASBRs).
In MVPN inter-AS option B, RPF vector and BGP connector are introduced:
·     RPF vector—Attribute encapsulated in a PIM join message. It is the next hop of BGP MDT route from the local PE to the remote PE. Typically, it is the ASBR in the local AS.
When a device receives the join message with the RPF vector, it first checks whether the RPF vector is its own IP address. If so, the device removes the RPF vector, and sends the message to its upstream neighbor according to the route to the remote PE. Otherwise, it keeps the RPF vector, looks up the route to the RPF vector, and sends the message to the next hop of the route. In this way, the PIM message can be forwarded across the ASs and an MDT is established.
·     BGP connector—Attribute shared by BGP peers when they exchange IPv4 VPN routes. It is the IP address of the remote PE.
The local PE fills the upstream neighbor address field with the BGP connector in a join message. This ensures that the message can pass the RPF check on the remote PE after it travels along the MT.
To implement MVPN inter-AS option B, only one MVPN needs to be established for the two ASs. VPN multicast data is transmitted between different ASs on the public network within this MVPN.
As shown in Figure 8:
·     A VPN network involves AS 1 and AS 2.
·     PE 3 and PE 4 are the ASBRs for AS 1 and AS 2, respectively.
·     PE 3 and PE 4 are interconnected through MP-EBGP and treat each other as a P device.
·     PE 3 and PE 4 advertise VPN-IPv4 routes to each other through MP-EBGP.
·     An MT is established between PE 1 and PE 2 for delivering VPN multicast traffic across the ASs.
Figure 8 MVPN inter-AS option B
The establishment of the MDT on the public network is as follows:
1.     PE 1 originates a PIM join message to join the SPT rooted at PE 2. In the join message, the upstream neighbor address is the IP address of PE 2 (the BGP connector). The RPF vector attribute is the IP address of PE 3. PE 1 encapsulates the join message as a public network packet and forwards it through the MTI.
2.     P 1 determines that the RPF vector is not an IP address of its own. It looks up the routing table for a route to PE 3, and forwards the packet to PE 3.
3.     PE 3 removes the RPF vector because the RPF vector is its own IP address. It fails to find a BGP MDT route to PE 2, so it encapsulates a new RPF vector (IP address of PE 4) in the packet and forwards it to PE 4.
4.     PE 4 removes the RPF vector because the RPF vector is its own IP address. It has a local route to PE 2, so it forwards the packet to P 2, which is the next hop of the route to PE 2.
5.     P 2 sends the packet to PE 2.
6.     PE 2 receives the packet on the MTI and decapsulates the packet. The receiving interface is the RPF interface of the RPF route back to PE 1 for the join message, and the join message passes the RPF check. The SPT from PE 1 to PE 2 is established.
When PE 1 joins the SPT rooted at PE 1, PE 2 also initiates a join process to the SPT rooted at PE 1. A MDT is established when the two SPTs are finished.
As shown in Figure 9:
·     PEs in different ASs establish a multihop MP-EBGP session to advertise VPN-IPv4 routes to each other.
Figure 9 MVPN inter-AS option C
To implement MVPN inter-AS option C, only one MVPN needs to be created for the two ASs. Multicast data is transmitted between the two ASs through the MVPN.
Multicast packets are delivered as follows:
1.     CE 1 forwards the VPN instance multicast packet to PE 1.
2.     PE 1 encapsulates the multicast packet into a public network multicast packet and forwards it to PE 3 through the MTI interface on the public network.
3.     PE 3 and PE 4 are interconnected through MP-EBGP, so PE 3 forwards the public network multicast packet to PE 4 along the VPN IPv4 route.
4.     The public network multicast packet arrives at the MTI interface of PE 2 in AS 2. PE 2 decapsulates the public network multicast packet and forwards the VPN multicast packet to CE 2.
MVPN extranet
MVPN extranet implements inter-VPN multicast traffic transmission. In MVPN extranet, the multicast source and receivers are in different VPNs. In actual application, the MVPN extranet solution ensures that the service provider in a VPN provides multicast services for users in other VPNs.
The following terms are used in the MVPN extranet solution:
·     Source VPN instance—VPN instance to which the multicast source belongs.
·     Receiver VPN instance—VPN instance to which the multicast receiver belongs.
·     Source PE—PE directly connected to the multicast source.
·     Receiver PE—PE directly connected to multicast receivers.
As shown in Figure 10, multicast source Source 1 is in Site 1 of VPN A. Receiver 1 and Receiver 2 are located in Site 2 of VPN A and Site 1 of VPN B, respectively. MVPN enables Receiver 1 to receive multicast data from Source 1, and MVPN extranet enables Receiver 2 to receive multicast data from Source 1.
The MVPN extranet solution can be implemented through the source-PE-based MVPN extranet option or the receiver-PE-based MVPN extranet option.
Figure 10 MVPN extranet
Source-PE-based MVPN extranet option
To use this option, create a receiver VPN instance on the source PE and configure MVPN for this VPN instance.
This option is available only in MDT-based MVPN.
As shown in Figure 11, perform the following tasks:
1.     For multicast traffic transmission from Site 1 to Site 2, configure MVPN for VPN A on PE 1 and PE 2.
2.     For multicast traffic transmission from Site 1 to Site 3, create VPN B and configure MVPN for VPN B on PE 1.
3.     Configure an MVPN extranet RPF selection policy for VPN B on PE 1.
Figure 11 Source-PE-based MVPN extranet option
When Receiver 2 in VPN B joins the multicast group that matches the policy, multicast packets from Source 1 are transmitted as follows:
1.     PE 1 replicates and encapsulates the packets for VPN A and VPN B and forwards them.
2.     The packets travel along default MDTs of VPN A and VPN B and arrive at PE 2 and PE 3.
3.     PE 2 and PE 3 decapsulate and forward the packets to receivers.
Receiver-PE-based MVPN extranet option
To use this option, create a source VPN instance on the receiver PE and configure MVPN. This option is available in MDT-based MVPN and RSVP-TE-based MVPN. The following steps describe how to configure this option for MDT-based MVPN.
As shown in Figure 12, configure PEs as follows:
2.     For multicast traffic transmission from Site 1 to Site 3, create VPN A and configure MVPN for VPN A on PE 3.
3.     Configure an MVPN extranet RPF selection policy for VPN B on PE 3.
Figure 12 Receiver-PE-based MVPN extranet option
When Receiver 2 in VPN B joins the multicast group that matches the RPF selection policy, multicast packets from Source 1 are encapsulated on PE 1 and transmitted along the default MDT.
·     When the packets arrive at PE 2, PE 2 decapsulates the packets and forwards them to Receiver 1.
·     When the packets arrive at PE 3, PE 3 decapsulates the packets and forwards them to Receiver 2 based on the MVPN extranet RPF selection policy.
·     RFC 6037, Cisco Systems' Solution for Multicast in BGP/MPLS IP VPNs
·     RFC 6513, Multicast in MPLS/BGP IP VPNs
·     RFC 6514, BGP Encodings and Procedures for Multicast in MPLS/BGP IP VPNs
PIM FRR and IPv6 PIM FRR periodically monitor multicast traffic on the primary and backup incoming interfaces of each multicast forwarding entry to detect link failures. Use this feature only in a scenario with continued high-speed forwarding of multicast traffic. To avoid multicast traffic forwarding failures when multicast VPN is used, do not enable PIM FRR and IPv6 PIM FRR. For more information about PIM FRR and IPv6 PIM FRR, see "Configuring PIM" and "Configuring IPv6 PIM", respectively.
To configure MDT-based MVPN, perform the following tasks on PEs:
1.     Configuring MDT-based MVPN
a.     Enabling IP multicast routing for a VPN instance
b.     Creating an MDT-based MVPN instance
c.     Creating an MVPN address family
d.     Specifying the default group
e.     Specifying the MVPN source interface
f.     (Optional.) Configuring MDT switchover parameters
g.     (Optional.) Configuring the RPF vector feature
h.     (Optional.) Enabling data group reuse logging
i.     (Optional.) Setting the DSCP value for outgoing data group switchover packets
2.     Configuring BGP MDT
If PIM-SSM is running on the public network, you must configure BGP MDT.
a.     Configuring BGP MDT peers or peer groups
b.     (Optional.) Configuring a BGP MDT route reflector
c.     (Optional.) Configuring BGP MDT optimal route selection delay
Before you configure MDT-based MVPN, complete the following tasks:
·     Configure a unicast routing protocol on the public network.
·     Configure MPLS L3VPN on the public network.
·     Configure PIM-DM, PIM-SM, BIDIR-PIM, or PIM-SSM on the public network.
2.     Create a VPN instance and enter its view.
For more information about this command, see MPLS Command Reference.
3.     Configure an RD for the VPN instance.
4.     Return to system view.
5.     Enter interface view.
6.     Associate the interface with the VPN instance.
By default, an interface is associated with no VPN instance and belongs to the public network.
7.     Return to system view.
8.     Enable IP multicast routing for the VPN instance and enter MRIB view of the VPN instance.
IPv4:
multicast routing vpn-instance vpn-instance-name
By default, IPv4 multicast routing is disabled for a VPN instance.
For more information about this command, see IP Multicast Command Reference.
IPv6:
ipv6 multicast routing vpn-instance vpn-instance-name
By default, IPv6 multicast routing is disabled for a VPN instance.
To provide multicast services for a VPN instance, you must create an MDT-based MVPN instance on PEs that belong to the VPN instance. After the MVPN instance is created, the system automatically creates MTIs and binds them with the VPN instance.
You can create one or more MDT-based MVPN instances on a PE.
2.     Create an MDT-based MVPN instance and enter MVPN view.
multicast-vpn vpn-instance vpn-instance-name mode mdt
You must create an MVPN IPv4 or IPv6 address family for a VPN instance before you can perform other MVPN VPN configuration tasks for the VPN instance. For a VPN instance, configurations in MVPN IPv4 address family view apply to its IPv4 multicast packets, and configurations in IPv6 address family view apply to its IPv6 multicast packets.
2.     Enter MVPN view of a VPN instance.
3.     Create an MVPN address family and enter MVPN address family view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
You must specify the same default group on all PEs that belong to the same MVPN.
The default group for an MVPN must be different from the default group and the data group used by any other MVPN.
For an MVPN that transmits both IPv4 and IPv6 multicast packets, you must specify the same default group in MVPN IPv4 address family view and IPv6 address family view.
2.     Enter MVPN view.
3.     Enter MVPN address family view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
4.     Specify the default group.
default-group group-address
An MTI of a VPN instance uses the IP address of the MVPN source interface as the source address to encapsulate multicast packets for the VPN instance.
For the PE to obtain correct routing information, you must specify the interface used for establishing BGP peer relationship as the MVPN source interface.
For an MVPN that transmits both IPv4 and IPv6 multicast packets, you must specify the same MVPN source interface in MVPN IPv4 and IPv6 address family views.
The MTI takes effect only after the default group and MVPN source interface are specified and the MTI obtains the public IP address of the MVPN source interface. For the MTI to forward packets, you must first create a service loopback group of the multicast type. The bandwidth of the MTI depends on the maximum bandwidth of interfaces in the service loopback group. For more information about service loopback groups, see Layer 2—LAN Switching Configuration Guide.
2.     Enter MVPN view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
4.     Specify the MVPN source interface.
source interface-type interface-number
By default, no MVPN source interface is specified.
To decrease traffic interruption caused by frequent default-MDT to data-MDT switchovers, you can adjust the data-delay period. The switchover occurs a data-delay period after the multicast VPN data first arrives, regardless of whether multicast VPN data keeps arriving during the period.
On a PE, the data group range for an MVPN cannot include the default group or data groups of any other MVPN.
All VPN instances share the data group resources. As a best practice to avoid data group resource exhaustion, specify a reasonable data group range for a VPN instance.
For an MVPN that transmits both IPv4 and IPv6 multicast packets, the data group range in MVPN IPv4 and IPv6 address family views cannot overlap.
If the public network runs PIM-SSM, the data group range for an MVPN on a PE can overlap with data group ranges for other MDs on other PEs.
If BIDIR-PIM runs in a VPN instance, the switchover from the default MDT to a data MDT is not supported.
2.     Enter MVPN view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
4.     Configure the data group range and the switchover criteria.
data-group group-address { mask-length | mask } [ acl acl-number ]
By default, no data group range exists, and the default MDT to data MDT switchover never occurs.
5.     Set the data-delay period.
data-delay delay
By default, the data-delay period is 3 seconds.
This feature enables the device to insert the RPF vector (IP address of the ASBR in the local AS) in PIM join messages for other devices to perform RPF check.
Perform this task on PEs that have attached receivers.
For the device to work with other manufacturers' products on the RPF vector, you must enable RPF vector compatibility for all H3C P devices and H3C PE devices on the public network.
2.     Enter MRIB view of a VPN instance.
3.     Enable the RPF vector feature.
rpf proxy vector
By default, the RPF vector feature is disabled.
4.     Enable RPF vector compatibility.
multicast rpf-proxy-vector compatible
By default, RPF vector compatibility is disabled.
For a given VPN, the number of VPN multicast streams to be switched to data MDTs might exceed the number of addresses in the data group range. In this case, the VPN instance on the source-side PE can reuse the addresses in the address range. With data group reuse logging enabled, the address reuse information will be logged. Perform this task on PEs.
The group address reuse logging information has a severity level informational. For more information about the logging information, see Network Management and Monitoring Configuration Guide.
2.     Enter MVPN view.
IPv4:
address-family ipv4
IPv6:
address-family ipv6
4.     Enable data group reuse logging.
log data-group-reuse
By default, data group reuse logging is disabled.
The DSCP value determines the packet transmission priority. A greater DSCP value represents a higher priority.
2.     Enter MVPN view.
3.     Setting the DSCP value for outgoing data group switchover packets.
dscp dscp-value
By default, the DSCP value is 48 for outgoing data group switchover packets.
Configuring BGP MDT
Perform this task so that the PE can exchange MDT information with the BGP peer or peer group. MDT information includes the IP address of the PE and default group to which the PE belongs. On a public network running PIM-SSM, the multicast VPN establishes a default MDT rooted at the PE (multicast source) based on the MDT information.
Before you configure a BGP MDT peer or peer group, you must create a BGP peer or peer group in BGP instance view. For more information about creating a BGP peer or peer group, see BGP configuration in Layer 3—IP Routing Configuration Guide.
3.     Create a BGP IPv4 MDT address family and enter its view.
address-family ipv4 mdt
By default, no BGP IPv4 address family exists.
4.     Enable the device to exchange MDT routing information with the BGP peer or the peer group.
By default, the device cannot exchange BGP MDT routing information with a BGP peer or peer group.
For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
·     Configuring a BGP MDT route reflector—BGP MDT peers in the same AS must be fully meshed to maintain connectivity. However, when multiple BGP MDT peers exist in an AS, connection establishment among them might result in increased costs. To reduce connections between BGP MDT peers, you can configure one of them as a route reflector and specify other devices as clients.
·     Disabling routing reflection between clients—When clients establish BGP MDT connections with the route reflector, the route reflector forwards (or reflects) BGP MDT routing information between clients. The clients are not required to be fully meshed. To save bandwidth if the clients have been fully meshed, you can disable the routing reflection between clients by using the undo reflect between-clients command.
·     Configuring the cluster ID of the route reflector—The route reflector and its clients form a cluster. Typically, a cluster has only one route reflector whose router ID identifies the cluster. However, you can configure several route reflectors in a cluster to improve network reliability. To avoid routing loops, make sure the route reflectors in a cluster have the same cluster ID.
3.     Enter BGP IPv4 MDT address family view.
4.     Configure the device as a route reflector and specify its peers or peer groups as clients.
By default, neither route reflectors nor clients exist.
5.     (Optional.) Disable route reflection between clients.
By default, route reflection between clients is disabled.
6.     (Optional.) Configure the cluster ID of the route reflector.
By default, a route reflector uses its router ID as the cluster ID.
4.     Set the optimal route selection delay timer. Choose the options to configure as needed:
¡     Set the optimal route selection delay timer for all BGP routes.
¡     Set the optimal route selection delay timer for BGP routes from only neighbors that change from down state to up state.
route-select suppress on-peer-up milliseconds
By default, optimal route selection is not delayed.
MVPN extranet RPF routing policies are used for multicast transmission when multicast sources and receivers are located in different VPNs.
Restrictions and guidelines for configuring MVPN extranet RPF selection policies
The PIM modes in the source VPN instance and the receiver VPN instance must be the same. Only PIM-SM and PIM-SSM are supported.
Multicast packets can only be forwarded between two VPNs. The receiver VPN instance cannot also be the source VPN instance.
In PIM-SM mode, you can configure only one RPF selection policy for a multicast group in a VPN instance.
If an IPv4 MVPN extranet RPF selection policy with only the multicast group address specified is configured in the receiver VPN instance, the multicast traffic for the intra-VPN transmission will be interrupted.
To implement source-specific RPF selection in MVPN extranet, you must configure two MVPN extranet RPF routing policies as follows:
·     In one policy, specify the address of the RP designated to the multicast group that requires inter-VPN multicast communication as the source address.
·     In the other policy, specify the multicast source in the source VPN instance as the source address.
To implement source-and-group-specific RPF selection in MVPN extranet, you must configure two MVPN extranet RPF routing policies as follows:
·     In one policy, specify the address of the RP designated to the multicast group as the source address, and specify the multicast group.
·     In the other policy, specify the multicast source in the source VPN instance as the source address, and specify the multicast group.
·     Make sure the multicast groups in the two policies are the same to avoid inter-VPN multicast transmission failure.
Prerequisites for configuring MVPN extranet RPF selection policies
Before you configure MVPN extranet RPF selection policies, you must configure MVPN.
For the source-PE-based MVPN extranet option, see "Configuring MDT-based MVPN."
For the receiver-PE-based MVPN extranet option, see "Configuring MDT-based MVPN."
Configuring an IPv4 MVPN extranet RPF selection policy
2.     Enter MRIB view.
3.     Configure an IPv4 MVPN extranet RPF selection policy.
multicast extranet select-rpf [ vpn-instance vpn-instance-name ] { source source-address { mask | mask-length } | group group-address { mask | mask-length } } *
By default, no IPv4 MVPN extranet RPF selection policies are configured.
Configuring an IPv6 MVPN extranet RPF selection policy
2.     Enter IPv6 MRIB view.
ipv6 multicast routing [ vpn-instance vpn-instance-name ]
3.     Configure an IPv6 MVPN extranet RPF selection policy.
ipv6 multicast extranet select-rpf { vpn-instance vpn-instance-name } { source ipv6-source-address prefix-length | group ipv6-group-address  prefix-length }*
By default, no IPv6 MVPN extranet RPF selection policies are configured.
As shown in Figure 13, configure intra-AS MDT-based MVPN to meet the following requirements:
Item
Multicast sources and receivers
·     In VPN instance a, S 1 is a multicast source, and R 1, R 2 and R 3 are receivers.
·     In VPN instance b, S 2 is a multicast source, and R 4 is a receiver.
·     For VPN instance a, the default group is 239.1.1.1, and the data group range is 225.2.2.0 to 225.2.2.15.
·     For VPN instance b, the default group is 239.2.2, and the data group range is 225.4.4.0 to 225.4.4.15.
VPN instances to which PE interfaces belong
·     PE 1: VLAN-interface 11 and VLAN-interface 20 belong to VPN instance a. VLAN-interface 12 and Loopback 1 belong to the public network instance.
·     PE 2: VLAN-interface 13 belongs to VPN instance b. VLAN-interface 14 belongs to VPN instance a. VLAN-interface 15 and Loopback 1 belong to the public network instance.
·     PE 3: VLAN-interface 17 belongs to VPN instance a. VLAN-interface 18 and Loopback 2 belong to VPN instance b. VLAN-interface 19 and Loopback 1 belong to the public network instance.
Unicast routing protocols and MPLS
·     Configure OSPF on the public network, and configure RIP between the PEs and CEs.
·     Establish BGP peer connections between PE 1, PE 2, and PE 3 on their respective Loopback 1.
·     Configure MPLS on the public network.
·     Enable IP multicast routing on the P device.
·     Enable IP multicast routing on the public network on PE 1, PE 2, and PE 3.
·     Enable IP multicast routing for VPN instance a on PE 1, PE 2, and PE 3.
·     Enable IP multicast routing for VPN instance b on PE 2 and PE 3.
·     Enable IP multicast routing on CE a1, CE a2, CE a3, CE b1, and CE b2.
IGMP
·     Enable IGMPv2 on VLAN-interface 20 of PE 1.
·     Enable IGMPv2 on VLAN-interface 40 of CE a2, VLAN-interface 50 of CE a3, and VLAN-interface 60 of CE b2.
PIM
Enable PIM-SM on the public network and for VPN instances a and b:
·     Enable PIM-SM on all interfaces of the P device.
·     Enable PIM-SM on all public and private network interfaces of PE 1, PE 2, and PE 3.
·     Enable PIM-SM on all interfaces that have no receiver hosts connected of CE a1, CE a2, CE a3, CE b1, and CE b2.
·     Configure Loopback 1 of P as a C-BSR and a C-RP for the public network to provide services for all multicast groups.
·     Configure Loopback 1 of CE a2 as a C-BSR and a C-RP for VPN instance a to provide services for all multicast groups.
·     Configure Loopback 2 of PE 3 as a C-BSR and a C-RP for VPN instance b to provide services for all multicast groups.
Figure 13 Network diagram
Device
IP address
Device
IP address
S 1
10.110.7.2/24
PE 3
Vlan-int19
192.168.8.1/24
S 2
10.110.8.2/24
PE 3
Vlan-int17
10.110.5.1/24
R 1
10.110.1.2/24
PE 3
Vlan-int18
10.110.6.1/24
R 2
10.110.9.2/24
PE 3
Loop1
1.1.1.3/32
R 3
10.110.10.2/24
PE 3
Loop2
33.33.33.33/32
R 4
10.110.11.2/24
CE a1
Vlan-int10
10.110.7.1/24
P
Vlan-int12
192.168.6.2/24
CE a1
Vlan-int11
10.110.2.2/24
P
Vlan-int15
192.168.7.2/24
CE a2
Vlan-int40
10.110.9.1/24
P
Vlan-int19
192.168.8.2/24
CE a2
Vlan-int14
10.110.4.2/24
P
Loop1
2.2.2.2/32
CE a2
Vlan-int16
10.110.12.1/24
PE 1
Vlan-int12
192.168.6.1/24
CE a2
Loop1
22.22.22.22/32
PE 1
Vlan-int20
10.110.1.1/24
CE a3
Vlan-int50
10.110.10.1/24
PE 1
Vlan-int11
10.110.2.1/24
CE a3
Vlan-int17
10.110.5.2/24
PE 1
Loop1
1.1.1.1/32
CE a3
Vlan-int16
10.110.12.2/24
PE 2
Vlan-int15
192.168.7.1/24
CE b1
Vlan-int30
10.110.8.1/24
PE 2
Vlan-int13
10.110.3.1/24
CE b1
Vlan-int13
10.110.3.2/24
PE 2
Vlan-int14
10.110.4.1/24
CE b2
Vlan-int60
10.110.11.1/24
PE 2
Loop1
1.1.1.2/32
CE b2
Vlan-int18
10.110.6.2/24
1.     Configure PE 1:
# Configure a global router ID, and enable IP multicast routing on the public network.
<PE1> system-view
[PE1] router id 1.1.1.1
[PE1] multicast routing
[PE1-mrib] quit
# Create service loopback group 1, and specify the multicast tunnel service for the group.
[PE1] service-loopback group 1 type multicast-tunnel
# Assign HundredGigE 1/0/4 to service loopback group 1. The interface does not belong to VLAN 11, VLAN 12, or VLAN 20.
[PE1] interface hundredgige 1/0/4
[PE1-HundredGigE1/0/4] port service-loopback group 1
[PE1-HundredGigE1/0/4] quit
# Configure an LSR ID, and enable LDP globally.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
# Create a VPN instance named a and configure an RD and route targets for the VPN instance.
[PE1] ip vpn-instance a
[PE1-vpn-instance-a] route-distinguisher 100:1
[PE1-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE1-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE1-vpn-instance-a] quit
# Enable IP multicast routing for VPN instance a.
[PE1] multicast routing vpn-instance a
[PE1-mrib-a] quit
# Create an MDT-based MVPN for VPN instance a.
[PE1] multicast-vpn vpn-instance a mode mdt
# Create an MVPN IPv4 family address for VPN instance a.
[PE1-mvpn-a] address-family ipv4
# Specify the default group, the MVPN source interface, and the data group range for VPN instance a.
[PE1-mvpn-a-ipv4] default-group 239.1.1.1
[PE1-mvpn-a-ipv4] source loopback 1
[PE1-mvpn-a-ipv4] data-group 225.2.2.0 28
[PE1-mvpn-a-ipv4] quit
[PE1-mvpn-a] quit
# Assign an IP address to VLAN-interface 12.
[PE1-Vlan-interface12] ip address 192.168.6.1 24
#Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 12.
[PE1-Vlan-interface12] pim sm
[PE1-Vlan-interface12] mpls enable
[PE1-Vlan-interface12] mpls ldp enable
[PE1-Vlan-interface12] quit
# Associate VLAN-interface 20 with VPN instance a.
[PE1] interface vlan-interface 20
[PE1-Vlan-interface20] ip binding vpn-instance a
# Assign an IP address to VLAN-interface 20, and enable IGMP on the interface.
[PE1-Vlan-interface20] ip address 10.110.1.1 24
[PE1-Vlan-interface20] igmp enable
[PE1-Vlan-interface20] quit
# Associate VLAN-interface 11 with VPN instance a.
[PE1] interface vlan-interface 11
[PE1-Vlan-interface11] ip binding vpn-instance a
# Assign an IP address to VLAN-interface 11, and enable PIM-SM on the interface.
[PE1-Vlan-interface11] ip address 10.110.2.1 24
[PE1-Vlan-interface11] pim sm
[PE1-Vlan-interface11] quit
# Assign an IP address to Loopback 1, and enable PIM-SM on the interface.
[PE1] interface loopback 1
[PE1-LoopBack1] ip address 1.1.1.1 32
[PE1-LoopBack1] pim sm
[PE1-LoopBack1] quit
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] group vpn-g internal
[PE1-bgp-default] peer vpn-g connect-interface loopback 1
[PE1-bgp-default] peer 1.1.1.2 group vpn-g
[PE1-bgp-default] peer 1.1.1.3 group vpn-g
[PE1–bgp-default] ip vpn-instance a
[PE1-bgp-default-a] address-family ipv4
[PE1-bgp-default-ipv4-a] import-route rip 2
[PE1-bgp-default-ipv4-a] import-route direct
[PE1-bgp-default-ipv4-a] quit
[PE1-bgp-default-a] quit
[PE1–bgp-default] address-family vpnv4
[PE1–bgp-default-vpnv4] peer vpn-g enable
[PE1–bgp-default-vpnv4] quit
[PE1-bgp-default] address-family ipv4 mdt
[PE1-bgp-default-mdt] peer vpn-g enable
[PE1-bgp-default-mdt] quit
[PE1–bgp-default] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] area 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 192.168.6.0 0.0.0.255
[PE1-ospf-1] quit
# Configure RIP.
[PE1] rip 2 vpn-instance a
[PE1-rip-2] network 10.110.1.0 0.0.0.255
[PE1-rip-2] network 10.110.2.0 0.0.0.255
[PE1-rip-2] import-route bgp
[PE1-rip-2] quit
2.     Configure PE 2:
<PE2> system-view
[PE2] router id 1.1.1.2
[PE2] multicast routing
[PE2-mrib] quit
[PE2] service-loopback group 1 type multicast-tunnel
# Assign HundredGigE 1/0/4 to service loopback group 1. The interface does not belong to VLAN 13, VLAN 14, or VLAN 15.
[PE2] interface hundredgige 1/0/4
[PE2-HundredGigE1/0/4] port service-loopback group 1
[PE2-HundredGigE1/0/4] quit
# Configure an MPLS LSR ID, and enable LDP globally.
[PE2] mpls lsr-id 1.1.1.2
[PE2] mpls ldp
[PE2-ldp] quit
# Create a VPN instance named b, and configure an RD and route targets for the VPN instance.
[PE2] ip vpn-instance b
[PE2-vpn-instance-b] route-distinguisher 200:1
[PE2-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE2-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE2-vpn-instance-b] quit
# Enable IP multicast routing for VPN instance b.
[PE2] multicast routing vpn-instance b
[PE2-mrib-b] quit
# Create an MDT-based MVPN for VPN instance b.
[PE2] multicast-vpn vpn-instance b mode mdt
# Create an MVPN IPv4 address family for VPN instance b.
[PE2-mvpn-b] address-family ipv4
# Specify the default group, the MVPN source interface, and the data group range for VPN instance b.
[PE2-mvpn-b-ipv4] default-group 239.2.2.2
[PE2-mvpn-b-ipv4] source loopback 1
[PE2-mvpn-b-ipv4] data-group 225.4.4.0 28
[PE2-mvpn-b-ipv4] quit
[PE2-mvpn-b] quit
# Create a VPN instance named a, and configure an RD and route targets for VPN instance.
[PE2] ip vpn-instance a
[PE2-vpn-instance-a] route-distinguisher 100:1
[PE2-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE2-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE2-vpn-instance-a] quit
[PE2] multicast routing vpn-instance a
[PE2-mrib-a] quit
[PE2] multicast-vpn vpn-instance a mode mdt
# Create an MVPN IPv4 address family for VPN instance a.
[PE2-mvpn-a] address-family ipv4
[PE2-mvpn-a-ipv4] default-group 239.1.1.1
[PE2-mvpn-a-ipv4] source loopback 1
[PE2-mvpn-a-ivp4] data-group 225.2.2.0 28
[PE2-mvpn-a-ipv4] quit
[PE2-mvpn-a] quit
# Assign an IP address to VLAN-interface 15.
[PE2] interface vlan-interface 15
[PE2-Vlan-interface15] ip address 192.168.7.1 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 15.
[PE2-Vlan-interface15] pim sm
[PE2-Vlan-interface15] mpls enable
[PE2-Vlan-interface15] mpls ldp enable
[PE2-Vlan-interface15] quit
# Associate VLAN-interface 13 with VPN instance b, assign an IP address to VLAN-interface 13, and enable PIM-SM on the interface.
[PE2] interface vlan-interface 13
[PE2-Vlan-interface13] ip binding vpn-instance b
[PE2-Vlan-interface13] ip address 10.110.3.1 24
[PE2-Vlan-interface13] pim sm
[PE2-Vlan-interface13] quit
# Associate VLAN-interface 14 with VPN instance a.
[PE2] interface vlan-interface 14
[PE2-Vlan-interface14] ip binding vpn-instance a
# Assign an IP address to VLAN-interface 14, and enable PIM-SM on the interface.
[PE2-Vlan-interface14] ip address 10.110.4.1 24
[PE2-Vlan-interface14] pim sm
[PE2-Vlan-interface14] quit
[PE2] interface loopback 1
[PE2-LoopBack1] ip address 1.1.1.2 32
[PE2-LoopBack1] pim sm
[PE2-LoopBack1] quit
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] group vpn-g internal
[PE2-bgp-default] peer vpn-g connect-interface loopback 1
[PE2-bgp-default] peer 1.1.1.1 group vpn-g
[PE2-bgp-default] peer 1.1.1.3 group vpn-g
[PE2–bgp-default] ip vpn-instance a
[PE2-bgp-default-a] address-family ipv4
[PE2-bgp-default-ipv4-a] import-route rip 2
[PE2-bgp-default-ipv4-a] import-route direct
[PE2-bgp-default-ipv4-a] quit
[PE2-bgp-default-a] quit
[PE2–bgp-default] ip vpn-instance b
[PE2-bgp-default-b] address-family ipv4
[PE2-bgp-default-ipv4-b] import-route rip 3
[PE2-bgp-default-ipv4-b] import-route direct
[PE2-bgp-default-ipv4-b] quit
[PE2-bgp-default-b] quit
[PE2–bgp-default] address-family vpnv4
[PE2–bgp-default-vpnv4] peer vpn-g enable
[PE2–bgp-default-vpnv4] quit
[PE2-bgp-default] address-family ipv4 mdt
[PE2-bgp-default-mdt] peer vpn-g enable
[PE2-bgp-default-mdt] quit
[PE2–bgp-default] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] area 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 1.1.1.2 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 192.168.7.0 0.0.0.255
[PE2-ospf-1] quit
# Configure RIP.
[PE2] rip 2 vpn-instance a
[PE2-rip-2] network 10.110.4.0 0.0.0.255
[PE2-rip-2] import-route bgp
[PE2-rip-2] quit
[PE2] rip 3 vpn-instance b
[PE2-rip-3] network 10.110.3.0 0.0.0.255
[PE2-rip-3] import-route bgp
[PE2-rip-3] quit
3.     Configure PE 3:
<PE3> system-view
[PE3] router id 1.1.1.3
[PE3] multicast routing
[PE3-mrib] quit
[PE3] service-loopback group 1 type multicast-tunnel
# Assign HundredGigE 1/0/4 to service loopback group 1. The interface does not belong to VLAN 17, VLAN 18, or VLAN 19.
[PE3] interface hundredgige 1/0/4
[PE3-HundredGigE1/0/4] port service-loopback group 1
[PE3-HundredGigE1/0/4] quit
[PE3] mpls lsr-id 1.1.1.3
[PE3] mpls ldp
[PE3-ldp] quit
# Create Loopback 1.
[PE3] interface loopback 1
[PE3-LoopBack1] quit
# Create Loopback 2.
[PE3] interface loopback 2
[PE3-LoopBack2] quit
# Create a VPN instance named a, and configure an RD and route targets for the VPN instance.
[PE3] ip vpn-instance a
[PE3-vpn-instance-a] route-distinguisher 100:1
[PE3-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE3-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE3-vpn-instance-a] quit
[PE3] multicast routing vpn-instance a
[PE3-mrib-a] quit
[PE3] multicast-vpn vpn-instance a mode mdt
[PE3-mvpn-a] address-family ipv4
[PE3-mvpn-a-ipv4] default-group 239.1.1.1
[PE3-mvpn-a-ipv4] source loopback 1
[PE3-mvpn-a-ipv4] data-group 225.2.2.0 28
[PE3-mvpn-a-ipv4] quit
[PE3-mvpn-a] quit
[PE3] ip vpn-instance b
[PE3-vpn-instance-b] route-distinguisher 200:1
[PE3-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE3-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE3-vpn-instance-b] quit
[PE3] multicast routing vpn-instance b
[PE3-mrib-b] quit
[PE3] multicast-vpn vpn-instance b mode mdt
[PE3-mvpn-b] address-family ipv4
[PE3-mvpn-b-ipv4] default-group 239.2.2.2
[PE3-mvpn-b-ipv4] source loopback 2
[PE3-mvpn-b-ipv4] data-group 225.4.4.0 28
[PE3-mvpn-b-ipv4] quit
[PE3-mvpn-b] quit
# Assign an IP address to VLAN-interface 19.
[PE3] interface vlan-interface 19
[PE3-Vlan-interface19] ip address 192.168.8.1 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 19.
[PE3-Vlan-interface19] pim sm
[PE3-Vlan-interface19] mpls enable
[PE3-Vlan-interface19] mpls ldp enable
[PE3-Vlan-interface19] quit
# Associate VLAN-interface 17 with VPN instance a.
[PE3] interface vlan-interface 17
[PE3-Vlan-interface17] ip binding vpn-instance a
# Assign an IP address to VLAN-interface 17, and enable PIM-SM on the interface.
[PE3-Vlan-interface17] ip address 10.110.5.1 24
[PE3-Vlan-interface17] pim sm
[PE3-Vlan-interface17] quit
# Associate VLAN-interface 18 with VPN instance b.
[PE3] interface vlan-interface 18
[PE3-Vlan-interface18] ip binding vpn-instance b
# Assign an IP address to VLAN-interface 18, and enable PIM-SM on the interface.
[PE3-Vlan-interface18] ip address 10.110.6.1 24
[PE3-Vlan-interface18] pim sm
[PE3-Vlan-interface18] quit
[PE3-LoopBack1] ip address 1.1.1.3 32
[PE3-LoopBack1] pim sm
# Associate Loopback 2 with VPN instance b.
[PE3-LoopBack2] ip binding vpn-instance b
# Assign an IP address to Loopback 2, and enable PIM-SM on the interface.
[PE3-LoopBack2] ip address 33.33.33.33 32
[PE3-LoopBack2] pim sm
# Configure Loopback 2 as a C-BSR and a C-RP.
[PE3] pim vpn-instance b
[PE3-pim-b] c-bsr 33.33.33.33
[PE3-pim-b] c-rp 33.33.33.33
[PE3-pim-b] quit
# Configure BGP.
[PE3] bgp 100
[PE3-bgp-default] group vpn-g internal
[PE3-bgp-default] peer vpn-g connect-interface loopback 1
[PE3-bgp-default] peer 1.1.1.1 group vpn-g
[PE3-bgp-default] peer 1.1.1.2 group vpn-g
[PE3–bgp-default] ip vpn-instance a
[PE3-bgp-default-a] address-family ipv4
[PE3-bgp-default-ipv4-a] import-route rip 2
[PE3-bgp-default-ipv4-a] import-route direct
[PE3-bgp-default-ipv4-a] quit
[PE3-bgp-default-a] quit
[PE3–bgp-default] ip vpn-instance b
[PE3-bgp-default-b] address-family ipv4
[PE3-bgp-default-ipv4-b] import-route rip 3
[PE3-bgp-default-ipv4-b] import-route direct
[PE3-bgp-default-ipv4-b] quit
[PE3-bgp-default-b] quit
[PE3–bgp-default] address-family vpnv4
[PE3–bgp-default-vpnv4] peer vpn-g enable
[PE3–bgp-default-vpnv4] quit
[PE3-bgp-default] address-family ipv4 mdt
[PE3-bgp-default-mdt] peer vpn-g enable
[PE3-bgp-default-mdt] quit
[PE3–bgp-default] quit
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1] area 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 1.1.1.3 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 192.168.8.0 0.0.0.255
[PE3-ospf-1] quit
# Configure RIP.
[PE3] rip 2 vpn-instance a
[PE3-rip-2] network 10.110.5.0 0.0.0.255
[PE3-rip-2] import-route bgp
[PE3-rip-2] quit
[PE3] rip 3 vpn-instance b
[PE3-rip-3] network 10.110.6.0 0.0.0.255
[PE3-rip-3] network 33.33.33.33 0.0.0.0
[PE3-rip-3] import-route bgp
[PE3-rip-3] quit
4.     Configure P:
# Enable IP multicast routing on the public network.
<P> system-view
[P] multicast routing
[P-mrib] quit
[P] mpls lsr-id 2.2.2.2
[P] mpls ldp
[P-ldp] quit
[P] interface vlan-interface 12
[P-Vlan-interface12] ip address 192.168.6.2 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 12.
[P-Vlan-interface12] pim sm
[P-Vlan-interface12] mpls enable
[P-Vlan-interface12] mpls ldp enable
[P-Vlan-interface12] quit
[P] interface vlan-interface 15
[P-Vlan-interface15] ip address 192.168.7.2 24
[P-Vlan-interface15] pim sm
[P-Vlan-interface15] mpls enable
[P-Vlan-interface15] mpls ldp enable
[P-Vlan-interface15] quit
[P] interface vlan-interface 19
[P-Vlan-interface19] ip address 192.168.8.2 24
[P-Vlan-interface19] pim sm
[P-Vlan-interface19] mpls enable
[P-Vlan-interface19] mpls ldp enable
[P-Vlan-interface19] quit
[P] interface loopback 1
[P-LoopBack1] ip address 2.2.2.2 32
[P-LoopBack1] pim sm
[P-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and a C-RP.
[P] pim
[P-pim] c-bsr 2.2.2.2
[P-pim] c-rp 2.2.2.2
[P-pim] quit
# Configure OSPF.
[P] ospf 1
[P-ospf-1] area 0.0.0.0
[P-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[P-ospf-1-area-0.0.0.0] network 192.168.6.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 192.168.7.0 0.0.0.255
[P-ospf-1-area-0.0.0.0] network 192.168.8.0 0.0.0.255
5.     Configure CE a1:
# Enable IP multicast routing.
<CEa1> system-view
[CEa1] multicast routing
[CEa1-mrib] quit
# Assign an IP address to VLAN-interface 10, and enable PIM-SM on the interface.
[CEa1] interface vlan-interface 10
[CEa1-Vlan-interface10] ip address 10.110.7.1 24
[CEa1-Vlan-interface10] pim sm
[CEa1-Vlan-interface10] quit
[CEa1] interface vlan-interface 11
[CEa1-Vlan-interface11] ip address 10.110.2.2 24
[CEa1-Vlan-interface11] pim sm
[CEa1-Vlan-interface11] quit
# Configure RIP.
[CEa1] rip 2
[CEa1-rip-2] network 10.110.2.0 0.0.0.255
[CEa1-rip-2] network 10.110.7.0 0.0.0.255
6.     Configure CE b1:
<CEb1> system-view
[CEb1] multicast routing
[CEb1-mrib] quit
# Assign an IP address to VLAN-interface 30, and enable PIM-SM on the interface.
[CEb1] interface vlan-interface 30
[CEb1-Vlan-interface30] ip address 10.110.8.1 24
[CEb1-Vlan-interface30] pim sm
[CEb1-Vlan-interface30] quit
# Assign an IP address to VLAN-interface 13, and enable PIM-SM on the interface.
[CEb1] interface vlan-interface 13
[CEb1-Vlan-interface13] ip address 10.110.3.2 24
[CEb1-Vlan-interface13] pim sm
[CEb1-Vlan-interface13] quit
# Configure RIP.
[CEb1] rip 3
[CEb1-rip-3] network 10.110.3.0 0.0.0.255
[CEb1-rip-3] network 10.110.8.0 0.0.0.255
7.     Configure CE a2:
<CEa2> system-view
[CEa2] multicast routing
[CEa2-mrib] quit
# Assign an IP address to VLAN-interface 40, and enable IGMP on the interface.
[CEa2] interface vlan-interface 40
[CEa2-Vlan-interface40] ip address 10.110.9.1 24
[CEa2-Vlan-interface40] igmp enable
[CEa2-Vlan-interface40] quit
[CEa2] interface vlan-interface 14
[CEa2-Vlan-interface14] ip address 10.110.4.2 24
[CEa2-Vlan-interface14] pim sm
[CEa2-Vlan-interface14] quit
# Assign an IP address to VLAN-interface 16, and enable PIM-SM on the interface.
[CEa2] interface vlan-interface 16
[CEa2-Vlan-interface16] ip address 10.110.12.1 24
[CEa2-Vlan-interface16] pim sm
[CEa2-Vlan-interface16] quit
[CEa2] interface loopback 1
[CEa2-LoopBack1] ip address 22.22.22.22 32
[CEa2-LoopBack1] pim sm
[CEa2-LoopBack1] quit
[CEa2] pim
[CEa2-pim] c-bsr 22.22.22.22
[CEa2-pim] c-rp 22.22.22.22
[CEa2-pim] quit
# Configure RIP.
[CEa2] rip 2
[CEa2-rip-2] network 10.110.4.0 0.0.0.255
[CEa2-rip-2] network 10.110.9.0 0.0.0.255
[CEa2-rip-2] network 10.110.12.0 0.0.0.255
[CEa2-rip-2] network 22.22.22.22 0.0.0.0
8.     Configure CE a3:
<CEa3> system-view
[CEa3] multicast routing
[CEa3-mrib] quit
# Assign an IP address to VLAN-interface 50, and enable IGMP on the interface.
[CEa3] interface vlan-interface 50
[CEa3-Vlan-interface50] ip address 10.110.10.1 24
[CEa3-Vlan-interface50] igmp enable
[CEa3-Vlan-interface50] quit
[CEa3] interface vlan-interface 17
[CEa3-Vlan-interface17] ip address 10.110.5.2 24
[CEa3-Vlan-interface17] pim sm
[CEa3-Vlan-interface17] quit
[CEa3] interface vlan-interface 16
[CEa3-Vlan-interface16] ip address 10.110.12.2 24
[CEa3-Vlan-interface16] pim sm
[CEa3-Vlan-interface16] quit
# Configure RIP.
[CEa3] rip 2
[CEa3-rip-2] network 10.110.5.0 0.0.0.255
[CEa3-rip-2] network 10.110.10.0 0.0.0.255
[CEa3-rip-2] network 10.110.12.0 0.0.0.255
9.     Configure CE b2:
<CEb2> system-view
[CEb2] multicast routing
[CEb2-mrib] quit
# Assign an IP address to VLAN-interface 60, and enable IGMP on the interface.
[CEb2] interface vlan-interface 60
[CEb2-Vlan-interface60] ip address 10.110.11.1 24
[CEb2-Vlan-interface60] igmp enable
[CEb2-Vlan-interface60] quit
[CEb2] interface vlan-interface 18
[CEb2-Vlan-interface18] ip address 10.110.6.2 24
[CEb2-Vlan-interface18] pim sm
[CEb2-Vlan-interface18] quit
# Configure RIP.
[CEb2] rip 3
[CEb2-rip-3] network 10.110.6.0 0.0.0.255
[CEb2-rip-3] network 10.110.11.0 0.0.0.255
# Display information about the local default group for IPv4 multicast transmission in each VPN instance on PE 1.
[PE1] display multicast-vpn default-group local
MVPN local default-group information of VPN instance a:
 Group address    Source address   Interface
 239.1.1.1         1.1.1.1           MTunnel0
# Display information about the local default group for IPv4 multicast transmission in each VPN instance on PE 2.
[PE2] display multicast-vpn default-group local
 239.1.1.1         1.1.1.2           MTunnel0
MVPN local default-group information of VPN instance mvpnb:
 239.1.1.1         1.1.1.2           MTunnel1
# Display information about the local default group for IPv4 multicast transmission in each VPN instance on PE 3.
[PE3] display multicast-vpn default-group local
 239.1.1.1         1.1.1.3           MTunnel0
MVPN local default-group information of VPN instance b:
 239.2.2.2        1.1.1.3           MTunnel1
Example: Configuring intra-AS M6VPE
As shown in Figure 14, configure intra-AS M6VPE to meet the following requirements:
Item
·     In VPN instance a, S 1 is an IPv6 multicast source, and R 1, R 2, and R 3 are receivers.
·     In VPN instance b, S 2 is an IPv6 multicast source, and R 4 is a receiver.
·     For VPN instance b, the default group is 239.2.2.2, and the data group range is 225.4.4.0 to 225.4.4.15.
·     PE 1: VLAN-interface 11 and VLAN-interface 20 belong to VPN instance a. VLAN-interface 12 and Loopback 1 belong to the public network.
·     PE 2: VLAN-interface 13 belongs to VPN instance b. VLAN-interface 14 belongs to VPN instance a. VLAN-interface 15 and Loopback 1 belong to the public network.
·     PE 3: VLAN-interface 17 belongs to VPN instance a. VLAN-interface 18 and Loopback 2 belongs to VPN instance b. VLAN-interface 19 and Loopback 1 belong to the public network.
·     Configure OSPF on the public network, and configure OSPFv3 between the PEs and the CEs.
IP multicast routing and IPv6 multicast routing
·     Enable IP multicast routing on P.
·     Enable IP multicast routing for the public network on PE 1, PE 2, and PE 3.
·     Enable IPv6 multicast routing for VPN instance a on PE 1, PE 2, and PE 3.
·     Enable IPv6 multicast routing for VPN instance b on PE 2 and PE 3.
·     Enable IPv6 multicast routing on CE a1, CE a2, CE a3, CE b1, and CE b2.
MLDv1
·     Enable MLDv1 on VLAN-interface 20 of PE 1.
·     Enable MLDv1 on VLAN-interface 40 of CE a2.
·     Enable MLDv1 on VLAN-interface 50 of CE a3.
·     Enable MLDv1 on VLAN-interface 60 of CE b2.
PIM and IPv6 PIM
Enable PIM-SM on the public network and IPv6 PIM-SM for VPN instances a and b:
·     Enable PIM-SM on all interfaces of P.
·     Enable PIM-SM on all public network interfaces and IPv6 PIM-SM on private network interfaces of PE 1, PE 2, and PE 3.
·     Enable IPv6 PIM-SM on all interfaces that do not have attached receivers on CE a1, CE a2, CE a3, CE b1, and CE b2.
·     Configure Loopback 1 of P as a C-BSR and a C-RP for the public network to provide services for all IPv4 multicast groups.
·     Configure Loopback 1 of CE a2 as a C-BSR and a C-RP for VPN instance a to provide services for all IPv6 multicast groups.
·     Configure Loopback 2 of PE 3 as a C-BSR and a C-RP for VPN instance b to provide services for all IPv6 multicast groups.
Figure 14 Network diagram
Device
IPv4/IPv6 address
Device
IPv4/IPv6 address
S 1
10:110:7::2/64
PE 3
Vlan-int19
192.168.8.1/24
S 2
10:110:8::2/64
PE 3
Vlan-int17
10:110:5::1/64
R 1
10:110:1::2/64
PE 3
Vlan-int18
10:110:6::1/64
R 2
10:110:9::2/64
PE 3
Loop1
1.1.1.3/32
R 3
10:110:10::2/64
PE 3
Loop2
33:33:33::33/128
R 4
10:110:11::2/64
CE a1
Vlan-int10
10:110:7::1/64
P
Vlan-int12
192.168.6.2/24
CE a1
Vlan-int11
10:110:2::2/64
P
Vlan-int15
192.168.7.2/24
CE a2
Vlan-int40
10:110:9::1/64
P
Vlan-int19
192.168.8.2/24
CE a2
Vlan-int14
10:110:4::2/64
P
Loop1
2.2.2.2/32
CE a2
Vlan-int16
10:110:12::1/64
PE 1
Vlan-int12
192.168.6.1/24
CE a2
Loop1
22:22:22::22/128
PE 1
Vlan-int20
10:110:1::1/64
CE a3
Vlan-int50
10:110:10::1/64
PE 1
Vlan-int11
10:110:2::1/64
CE a3
Vlan-int17
10:110:5::2/64
PE 1
Loop1
1.1.1.1/32
CE a3
Vlan-int16
10:110:12::2/64
PE 2
Vlan-int15
192.168.7.1/24
CE b1
Vlan-int30
10:110:8::1/64
PE 2
Vlan-int13
10:110:3::1/64
CE b1
Vlan-int13
10:110:3::2/64
PE 2
Vlan-int14
10:110:4::1/64
CE b2
Vlan-int60
10:110:11::1/64
PE 2
Loop1
1.1.1.2/32
CE b2
Vlan-int18
10:110:6::2/64
1.     Configure PE 1:
<PE1> system-view
[PE1-mrib] quit
[PE1] mpls ldp
[PE1-ldp] quit
# Create a VPN instance named a, and configure the RD and route targets for the VPN instance.
# Enable IPv6 multicast routing for VPN instance a.
[PE1] ipv6 multicast routing vpn-instance a
[PE1-mrib6-a] quit
# Create an MVPN IPv6 address family for VPN instance a.
[PE1-mvpn-a] address-family ipv6
[PE1-mvpn-a-ipv6] default-group 239.1.1.1
[PE1-mvpn-a-ipv6] source loopback 1
[PE1-mvpn-a-ipv6] data-group 225.2.2.0 28
[PE1-mvpn-a-ipv6] quit
[PE1-mvpn-a] quit
# Associate VLAN-interface 20 with VPN instance a, and assign an IPv6 address to the interface.
[PE1-Vlan-interface20] ipv6 address 10:110:1::1 64
# Configure VLAN-interface 20 to run OSPFv3 process 2 in Area 0, and enable MLD on the interface.
[PE1-Vlan-interface20] ospfv3 2 area 0.0.0.0
[PE1-Vlan-interface20] mld enable
# Associate VLAN-interface 11 with VPN instance a, and assign an IPv6 address to the interface.
[PE1-Vlan-interface11] ipv6 address 10:110:2::1 64
# Configure VLAN-interface 11 to run OSPFv3 process 2 in Area 0, and enable IPv6 PIM-SM on the interface.
[PE1-Vlan-interface11] ospfv3 2 area 0.0.0.0
[PE1-Vlan-interface11] ipv6 pim sm
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default-a] address-family ipv6
[PE1-bgp-default-ipv6-a] import-route ospfv3 2
[PE1-bgp-default-ipv6-a] import-route direct
[PE1-bgp-default-ipv6-a] quit
[PE1–bgp-default] address-family vpnv6
[PE1–bgp-default-vpnv6] peer vpn-g enable
[PE1–bgp-default-vpnv6] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] quit
# Configure OSPFv3.
[PE1] ospfv3 2 vpn-instance a
[PE1-ospfv3-2] router-id 1.1.1.1
[PE1-ospfv3-2] import-route bgp4+
[PE1-ospfv3-2] import-route direct
[PE1-ospfv3-2] area 0
[PE1-ospfv3-2-area-0.0.0.0] quit
2.     Configure PE 2:
# Configure a global RD, and enable IP multicast routing on the public network.
<PE2> system-view
[PE2-mrib] quit
[PE2] mpls ldp
[PE2-ldp] quit
# Create a VPN instance named b, and configure the RD and route targets for the VPN instance.
# Enable IPv6 multicast routing for VPN instance b.
[PE2] ipv6 multicast routing vpn-instance b
[PE2-mrib6-b] quit
# Create an MVPN IPv6 address family for VPN instance b.
[PE2-mvpn-b] address-family ipv6
[PE2-mvpn-b-ipv6] default-group 239.2.2.2
[PE2-mvpn-b-ipv6] source loopback 1
[PE2-mvpn-b-ipv6] data-group 225.4.4.0 28
[PE2-mvpn-b-ipv6] quit
[PE2-mvpn-b] quit
[PE2] ipv6 multicast routing vpn-instance a
[PE2-mrib6-a] quit
[PE2-mvpn-a] address-family ipv6
[PE2-mvpn-a-ipv6] default-group 239.1.1.1
[PE2-mvpn-a-ipv6] source loopback 1
[PE2-mvpn-a-ipv6] data-group 225.2.2.0 28
[PE2-mvpn-a-ipv6] quit
[PE2-mvpn-a] quit
# Associate VLAN-interface 13 with VPN instance b, and assign an IPv6 address to the interface.
[PE2-Vlan-interface13] ipv6 address 10:110:3::1 64
# Configure VLAN-interface 13 to run OSPFv3 process 3 in Area 0, and enable IPv6 PIM-SM on the interface.
[PE2-Vlan-interface13] ospfv3 3 area 0.0.0.0
[PE2-Vlan-interface13] ipv6 pim sm
# Associate VLAN-interface 14 with VPN instance a, and assign an IPv6 address to the interface.
[PE2-Vlan-interface14] ipv6 address 10:110::4::1 64
# Configure VLAN-interface 14 to run OSPFv3 process 2 in Area 0, and enable IPv6 PIM-SM on the interface.
[PE2-Vlan-interface14] ospfv3 2 area 0.0.0.0
[PE2-Vlan-interface14] ipv6 pim sm
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default-a] address-family ipv6
[PE2-bgp-default-ipv6-a] import-route ospfv3 2
[PE2-bgp-default-ipv6-a] import-route direct
[PE2-bgp-default-ipv6-a] quit
[PE2-bgp-default-b] address-family ipv6
[PE2-bgp-default-ipv6-b] import-route ospfv3 3
[PE2-bgp-default-ipv6-b] import-route direct
[PE2-bgp-default-ipv6-b] quit
[PE2–bgp-default] address-family vpnv6
[PE2–bgp-default-vpnv6] peer vpn-g enable
[PE2–bgp-default-vpnv6] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] quit
# Configure OSPFv3.
[PE2] ospfv3 2 vpn-instance a
[PE2-ospfv3-2] router-id 2.2.2.2
[PE2-ospfv3-2] import-route bgp4+
[PE2-ospfv3-2] import-route direct
[PE2-ospfv3-2] area 0
[PE2-ospfv3-2-area-0.0.0.0] quit
[PE2] ospfv3 3 vpn-instance b
[PE2-ospfv3-3] router-id 3.3.3.3
[PE2-ospfv3-3] import-route bgp4+
[PE2-ospfv3-3] import-route direct
[PE2-ospfv3-3] area 0
3.     Configure PE 3:
<PE3> system-view
[PE3-mrib] quit
[PE3] mpls ldp
[PE3-ldp] quit
[PE3] ipv6 multicast routing vpn-instance a
[PE3-mrib6-a] quit
[PE3-mvpn-a] address-family ipv6
[PE3-mvpn-a-ipv6] default-group 239.1.1.1
[PE3-mvpn-a-ipv6] source loopback 1
[PE3-mvpn-a-ipv6] data-group 225.2.2.0 28
[PE3-mvpn-a-ipv6] quit
[PE3-mvpn-a] quit
[PE3] ipv6 multicast routing vpn-instance b
[PE3-mrib6-b] quit
[PE3-mvpn-b] address-family ipv6
[PE3-mvpn-b-ipv6] default-group 239.2.2.2
[PE3-mvpn-b-ipv6] source loopback 1
[PE3-mvpn-b-ipv6] data-group 225.4.4.0 28
[PE3-mvpn-b-ipv6] quit
[PE3-mvpn-b] quit
# Associate VLAN-interface 17 with VPN instance a, and assign an IPv6 address to the interface.
[PE3-Vlan-interface17] ipv6 address 10:110:5::1 64
# Configure VLAN-interface 17 to run OSPFv3 process 2 in Area 0, and enable IPv6 PIM-SM on the interface.
[PE3-Vlan-interface17] ospfv3 2 area 0.0.0.0
[PE3-Vlan-interface17] ipv6 pim sm
# Associate VLAN-interface 18 with VPN instance b, and assign an IPv6 address to the interface.
[PE3-Vlan-interface18] ipv6 address 10:110:6::1 64
# Configure VLAN-interface 18 to run OSPFv3 process 3 in Area 0, and enable IPv6 PIM-SM on the interface.
[PE3-Vlan-interface18] ospfv3 3 area 0.0.0.0
[PE3-Vlan-interface18] ipv6 pim sm
# Associate Loopback 2 with VPN instance b, and assign an IPv6 address to the interface.
[PE3-LoopBack2] ipv6 address 33:33:33::33 128
# Configure Loopback 2 to run OSPFv3 process 3 in Area 0, and enable IPv6 PIM-SM on the interface.
[PE3-LoopBack2] ospfv3 3 area 0.0.0.0
[PE3-LoopBack2] ipv6 pim sm
[PE3] ipv6 pim vpn-instance b
[PE3-pim6-b] c-bsr 33:33:33::33
[PE3-pim6-b] c-rp 33:33:33::33
[PE3-pim6-b] quit
# Configure BGP.
[PE3] bgp 100
[PE3-bgp-default-a] address-family ipv6
[PE3-bgp-default-ipv6-a] import-route ospfv3 2
[PE3-bgp-default-ipv6-a] import-route direct
[PE3-bgp-default-ipv6-a] quit
[PE3-bgp-default-b] address-family ipv6
[PE3-bgp-default-ipv6-b] import-route ospfv3 3
[PE3-bgp-default-ipv6-b] import-route direct
[PE3-bgp-default-ipv6-b] quit
[PE3–bgp-default] address-family vpnv6
[PE3–bgp-default-vpnv6] peer vpn-g enable
[PE3–bgp-default-vpnv6] quit
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1] quit
# Configure OSPFv3.
[PE3] ospfv3 2 vpn-instance a
[PE3-ospfv3-2] router-id 4.4.4.4
[PE3-ospfv3-2] import-route bgp4+
[PE3-ospfv3-2] import-route direct
[PE3-ospfv3-2]  area 0
[PE3-ospfv3-2-area-0.0.0.0] quit
[PE3] ospfv3 3 vpn-instance b
[PE3-ospfv3-3] router-id 5.5.5.5
[PE3-ospfv3-3] import-route bgp4+
[PE3-ospfv3-3] import-route direct
[PE3-ospfv3-3] area 0
4.     Configure P:
<P> system-view
[P-mrib] quit
[P] mpls ldp
[P-ldp] quit
[P-LoopBack1] quit
[P] pim
[P-pim] quit
# Configure OSPF.
[P] ospf 1
5.     Configure CE a1:
# Enable IPv6 multicast routing.
<CEa1> system-view
[CEa1] ipv6 multicast routing
[CEa1-mrib6] quit
# Assign an IPv6 address to VLAN-interface 10.
[CEa1-Vlan-interface10] ipv6 address 10:110:7::1 64
# Configure VLAN-interface 10 to run OSPFv3 process 2 in Area 0, and enable IPv6 PIM-SM on the interface.
[CEa1-Vlan-interface10] ospfv3 2 area 0.0.0.0
[CEa1-Vlan-interface10] ipv6 pim sm
# Assign an IPv6 address to VLAN-interface 11.
[CEa1-Vlan-interface11] ipv6 address 10:110:2::2 64
[CEa1-Vlan-interface11] ospfv3 2 area 0.0.0.0
[CEa1-Vlan-interface11] ipv6 pim sm
# Configure OSPFv3.
[CEa1] ospfv3 2
[CEa1-ospfv3-2] router-id 6.6.6.6
[CEa1-ospfv3-2] area 0
[CEa1-ospfv3-2-area-0.0.0.0] quit
6.     Configure CE b1:
<CEb1> system-view
[CEb1] ipv6 multicast routing
[CEb1-mrib6] quit
# Assign an IPv6 address to VLAN-interface 30.
[[CEb1] interface vlan-interface 30
[CEb1-Vlan-interface30] ipv6 address 10:110:8::1 64
# Configure VLAN-interface 30 to run OSPFv3 process 3 in Area 0, and enable IPv6 PIM-SM on the interface.
[CEb1-Vlan-interface30] ospfv3 3 area 0.0.0.0
[CEb1-Vlan-interface30] ipv6 pim sm
# Assign an IPv6 address to VLAN-interface 13.
[CEb1-Vlan-interface13] ipv6 address 10:110:3::2 24
[CEb1-Vlan-interface13] ospfv3 3 area 0.0.0.0
[CEb1-Vlan-interface13] ipv6 pim sm
# Configure OSPFv3.
[CEb1] ospfv3 3
[CEb1-ospfv3-3] router-id 7.7.7.7
[CEb1-ospfv3-3] area 0
[CEb1-ospfv3-3-area-0.0.0.0] quit
7.     Configure CE a2:
<CEa2> system-view
[CEa2] ipv6 multicast routing
[CEa2-mrib6] quit
# Assign an IPv6 address to VLAN-interface 40.
[CEa2-Vlan-interface40] ipv6 address 10:110:9::1 64
# Configure VLAN-interface 40 to run OSPFv3 process 2 in Area 0, and enable MLD on the interface.
[CEa2-Vlan-interface40] ospfv3 2 area 0.0.0.0
[CEa2-Vlan-interface40] mld enable
# Assign an IPv6 address to VLAN-interface 14.
[CEa2-Vlan-interface14] ipv6 address 10:110:4::2 64
[CEa2-Vlan-interface14] ospfv3 2 area 0.0.0.0
[CEa2-Vlan-interface14] ipv6 pim sm
# Assign an IPv6 address to VLAN-interface 16.
[CEa2-Vlan-interface16] ipv6 address 10:110:12::1 64
# Configure VLAN-interface 16 to run OSPFv3 process 2 in Area 0, and enable IPv6 PIM-SM on the interface.
[CEa2-Vlan-interface16] ospfv3 2 area 0.0.0.0
[CEa2-Vlan-interface16] ipv6 pim sm
# Assign an IPv6 address to Loopback 1.
[CEa2-LoopBack1] ipv6 address 22:22:22::22 128
# Configure Loopback 1 to run OSPFv3 process 2 in Area 0, and enable IPv6 PIM-SM on the interface.
[CEa2-LoopBack1] ospfv3 2 area 0.0.0.0
[CEa2-LoopBack1] ipv6 pim sm
[CEa2] pim6
[CEa2-pim6] c-bsr 22:22:22::22
[CEa2-pim6] c-rp 22:22:22::22
[CEa2-pim6] quit
# Configure OSPFv3.
[CEa2] ospfv3 2
[CEa2-ospfv3-2] router-id 8.8.8.8
[CEa2-ospfv3-2] area 0
[CEa2-ospfv3-2-area-0.0.0.0] quit
8.     Configure CE a3:
<CEa3> system-view
[CEa3] ipv6 multicast routing
[CEa3-mrib6] quit
# Assign an IPv6 address to VLAN-interface 50.
[CEa3-Vlan-interface50] ipv6 address 10:110:10::1 64
# Configure VLAN-interface 50 to run OSPFv3 process 2 in Area 0, and enable MLD on the interface.
[CEa3-Vlan-interface50] ospfv3 2 area 0.0.0.0
[CEa3-Vlan-interface50] mld enable
# Assign an IPv6 address to VLAN-interface 17.
[CEa3-Vlan-interface17] ipv6 address 10:110:5::2 64
[CEa3-Vlan-interface17] ospfv3 2 area 0.0.0.0
[CEa3-Vlan-interface17] ipv6 pim sm
[CEa3-Vlan-interface16] ipv6 address 10:110:12::2 64
[CEa3-Vlan-interface16] ospfv3 2 area 0.0.0.0
[CEa3-Vlan-interface16] ipv6 pim sm
# Configure OSPFv3.
[CEa3] ospfv3 2
[CEa3-ospfv3-2] router-id 9.9.9.9
[CEa3-ospfv3-2] area 0
[CEa3-ospfv3-2-area-0.0.0.0] quit
9.     Configure CE b2:
<CEb2> system-view
[CEb2-mrib] quit
# Assign an IPv6 address to VLAN-interface 60.
[CEb2-Vlan-interface60] ipv6 address 10:110:11::1 64
# Configure VLAN-interface 60 to run OSPFv3 process 3 in Area 0, and enable MLD on the interface.
[CEb2-Vlan-interface60] ospfv3 3 area 0.0.0.0
[CEb2-Vlan-interface60] mld enable
# Assign an IPv6 address to VLAN-interface 18.
[CEb2-Vlan-interface18] ipv6 address 10:110:6::2 64
[CEb2-Vlan-interface18] ospfv3 3 area 0.0.0.0
[CEb2-Vlan-interface18] ipv6 pim sm
# Configure OSPFv3.
[CEb2] ospfv3 3
[CEb2-ospfv3-3] router-id 10.10.10.10
[CEb2-ospfv3-3] area 0
[CEb2-ospfv3-3-area-0.0.0.0] quit
# Display information about the local default group for IPv6 multicast transmission in each VPN instance on PE 1.
[PE1] display multicast-vpn default-group ipv6 local
MVPN local default-group information:
Group address    Source address   Interface     VPN instance
239.1.1.1        1.1.1.1          MTunnel0      a
# Display information about the local default group for IPv6 multicast transmission in each VPN instance on PE 2.
[PE2] display multicast-vpn default-group ipv6 local
239.1.1.1        1.1.1.2          MTunnel0      a
239.1.1.1        1.1.1.2          MTunnel1      b
# Display information about the local default group for IPv6 multicast transmission in each VPN instance on PE 3.
[PE3] display multicast-vpn default-group ipv6 local
239.1.1.1        1.1.1.3          MTunnel0      a
239.2.2.2        1.1.1.3          MTunnel1      b
Example: Configuring MDT-based MVPN inter-AS option B
As shown in Figure 15, configure MDT-based MVPN inter-AS option B to meet the following requirements:
Item
·     In VPN instance a, S 1 is a multicast source, and R 2 is a receiver.
·     In VPN instance b, S 2 is a multicast source, and R 1 is a receiver.
·     For VPN instance a, the default group is 232.1.1.1, and the data group range is 232.2.2.0 to 232.2.2.15. They are in the SSM group range.
·     For VPN instance b, the default group is 232.3.3.3, and the data group range is 232.4.4.0 to 232.4.4.15. They are in the SSM group range.
·     PE 1: VLAN-interface 11 belongs to VPN instance a. VLAN-interface 12 belongs to VPN instance b. VLAN-interface 2 and Loopback 1 belong to the public network instance.
·     PE 2: VLAN-interface 3, VLAN-interface 4, and Loopback 1 belong to the public network instance.
·     PE 3: VLAN-interface 4, VLAN-interface 5, and Loopback 1 belong to the public network instance.
·     PE 4: VLAN-interface 13 belongs to VPN instance a. VLAN-interface 14 belongs to VPN instance b. VLAN-interface 6 and Loopback 1 belong to the public network instance.
·     Configure OSPF separately in AS 100 and AS 200, and configure OSPF between the PEs and CEs.
·     Establish IBGP peer connections between PE 1, PE 2, PE 3, and PE 4 on their respective Loopback 1.
·     Configure BGP MDT peer connections between PE 1, PE 2, PE 3, and PE 4 on their respective Loopback 1 and between PE 2 and PE 3 on their respective VLAN-interface 4.
·     Establish EBGP peer connections between VLAN-interface 4 on PE 2 and PE 3.
·     Configure MPLS separately in AS 100 and AS 200.
·     Enable IP multicast routing on P 1 and P 2.
·     Enable IP multicast routing on the public network on PE 1, PE 2, PE 3, and PE 4.
·     Enable IP multicast routing for VPN instance a on PE 1 and PE 4.
·     Enable IP multicast routing for VPN instance b on PE 1 and PE 4.
·     Enable IP multicast routing on CE a1, CE a2, CE b1, and CE b2.
IGMP
·     Enable IGMPv2 on VLAN-interface 23 of CE a2.
·     Enable IGMPv2 on VLAN-interface 24 of CE b2.
PIM
Enable PIM-SSM on the public network and PIM-SM on VPN instances a and b:
·     Enable PIM-SM on all interfaces of P 1 and P 2.
·     Enable PIM-SM on all public network interfaces of PE 2 and PE 3.
·     Enable PIM-SM on all public and private network interfaces of PE 1 and PE 4.
·     Enable PIM-SM on all interfaces that do not have attached receiver hosts on CE a1, CE a2, CE b1, and CE b2.
·     Configure VLAN-interface 11 of CE a1 as a C-BSR and a C-RP for VPN instance a to provide services for all multicast groups.
·     Configure VLAN-interface 12 of CE b1 as a C-BSR and a C-RP for VPN instance b to provide services for all multicast groups.
RPF vector
Enable the RPF vector feature on PE 1 and PE 4.
Figure 15 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
12.1.1.100/24
R 1
12.4.1.100/24
S 2
12.2.1.100/24
R 2
12.3.1.100/24
PE 1
Vlan-int2
10.1.1.1/24
PE 3
Vlan-int5
10.4.1.1/24
PE 1
Vlan-int11
11.1.1.1/24
PE 3
Vlan-int4
10.3.1.2/24
PE 1
Vlan-int12
11.2.1.1/24
PE 3
Loop1
3.3.3.3/32
PE 1
Loop1
1.1.1.1/32
PE 4
Vlan-int6
10.5.1.2/24
PE 2
Vlan-int3
10.2.1.2/24
PE 4
Vlan-int13
11.3.1.1/24
PE 2
Vlan-int4
10.3.1.1/24
PE 4
Vlan-int14
11.4.1.1/24
PE 2
Loop1
2.2.2.2/32
PE 4
Loop1
4.4.4.4/24
P 1
Vlan-int2
10.1.1.2/24
P 2
Vlan-int6
10.5.1.1/24
P 1
Vlan-int3
10.2.1.1/24
P 2
Vlan-int5
10.4.1.2/24
P 1
Loop1
5.5.5.5/32
P 2
Loop1
6.6.6.6/32
CE a1
Vlan-int21
12.1.1.1/24
CE b1
Vlan-int22
12.2.1.1/24
CE a1
Vlan-int11
11.1.1.2/24
CE b1
Vlan-int12
11.2.1.2/24
CE a2
Vlan-int23
12.3.1.1/24
CE b2
Vlan-int24
12.4.1.1/24
CE a2
Vlan-int13
11.3.1.2/24
CE b2
Vlan-int14
11.4.1.2/24
1.     Configure PE 1:
<PE1> system-view
[PE1-mrib] quit
# Assign HundredGigE 1/0/4 to service loopback group 1. The interface does not belong to VLAN 2, VLAN 11, or VLAN 12.
[PE1] mpls ldp
[PE1-ldp] quit
# Enable the RPF vector feature.
[PE1-mrib-a] rpf proxy vector
[PE1-mrib-a] quit
[PE1-mvpn-a-ipv4] default-group 232.1.1.1
[PE1-mvpn-a-ipv4] data-group 232.2.2.0 28
[PE1-mvpn-a] quit
# Create a VPN instance named b, and configure the RD and route targets for VPN instance.
[PE1] ip vpn-instance b
[PE1-vpn-instance-b] route-distinguisher 200:1
[PE1-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE1-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE1-vpn-instance-b] quit
[PE1] multicast routing vpn-instance b
[PE1-mrib-b] rpf proxy vector
[PE1-mrib-b] quit
[PE1] multicast-vpn vpn-instance b mode mdt
[PE1-mvpn-b] address-family ipv4
[PE1-mvpn-b-ipv4] default-group 232.3.3.3
[PE1-mvpn-b-ivp4] source loopback 1
[PE1-mvpn-b-ivp4] data-group 232.4.4.0 28
[PE1-mvpn-b-ipv4] quit
[PE1-mvpn-b] quit
# Assign an IP address to VLAN-interface 2.
[PE1-Vlan-interface2] ip address 10.1.1.1 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 2.
[PE1-Vlan-interface2] pim sm
[PE1-Vlan-interface2] mpls enable
[PE1-Vlan-interface2] mpls ldp enable
[PE1-Vlan-interface2] quit
[PE1-Vlan-interface11] ip address 11.1.1.1 24
# Associate VLAN-interface 12 with VPN instance b.
[PE1-Vlan-interface12] ip binding vpn-instance b
# Assign an IP address to VLAN-interface 12, and enable PIM-SM on the interface.
[PE1-Vlan-interface12] ip address 11.2.1.1 24
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] peer 2.2.2.2 as-number 100
[PE1-bgp-default] peer 2.2.2.2 connect-interface loopback 1
[PE1-bgp-default-ipv4-a] import-route ospf 2
[PE1–bgp-default] ip vpn-instance b
[PE1-bgp-default-b] address-family ipv4
[PE1-bgp-default-ipv4-b] import-route ospf 3
[PE1-bgp-default-ipv4-b] import-route direct
[PE1-bgp-default-ipv4-b] quit
[PE1-bgp-default-b] quit
[PE1–bgp-default-vpnv4] peer 2.2.2.2 enable
[PE1-bgp-default-mdt] peer 2.2.2.2 enable
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[PE1-ospf-1] quit
[PE1] ospf 2 vpn-instance a
[PE1-ospf-2] area 0.0.0.0
[PE1-ospf-2-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[PE1-ospf-2-area-0.0.0.0] quit
[PE1-ospf-2] quit
[PE1] ospf 3 vpn-instance b
[PE1-ospf-3] area 0.0.0.0
[PE1-ospf-3-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[PE1-ospf-3-area-0.0.0.0] quit
[PE1-ospf-3] quit
2.     Configure PE 2:
<PE2> system-view
[PE2] router id 2.2.2.2
[PE2-mrib] quit
[PE2] mpls lsr-id 2.2.2.2
[PE2] mpls ldp
[PE2-ldp] quit
# Assign an IP address to VLAN-interface 3.
[PE2] interface vlan-interface 3
[PE2-Vlan-interface3] ip address 10.2.1.2 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 3.
[PE2-Vlan-interface3] pim sm
[PE2-Vlan-interface3] mpls enable
[PE2-Vlan-interface3] mpls ldp enable
[PE2-Vlan-interface3] quit
# Assign an IP address to VLAN-interface 4.
[PE2] interface vlan-interface 4
[PE2-Vlan-interface4] ip address 10.3.1.1 24
# Enable PIM-SM and MPLS on VLAN-interface 4.
[PE2-Vlan-interface4] pim sm
[PE2-Vlan-interface4] mpls enable
[PE2-Vlan-interface4] quit
[PE2-LoopBack1] ip address 2.2.2.2 32
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] peer 1.1.1.1 as-number 100
[PE2-bgp-default] peer 1.1.1.1 connect-interface loopback 1
[PE2-bgp-default] peer 10.3.1.2 as-number 200
[PE2-bgp-default-vpnv4] undo policy vpn-target
[PE2-bgp-default-vpnv4] peer 1.1.1.1 enable
[PE2-bgp-default-vpnv4] peer 10.3.1.2 enable
[PE2-bgp-default-vpnv4] quit
[PE2-bgp-default-mdt] peer 1.1.1.1 enable
[PE2-bgp-default-mdt] peer 10.3.1.2 enable
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
[PE2-ospf-1] quit
3.     Configure PE 3:
<PE3> system-view
[PE3] router id 3.3.3.3
[PE3-mrib] quit
[PE3] mpls lsr-id 3.3.3.3
[PE3] mpls ldp
[PE3-ldp] quit
# Assign an IP address to VLAN-interface 5.
[PE3] interface vlan-interface 5
[PE3-Vlan-interface5] ip address 10.4.1.1 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 5.
[PE3-Vlan-interface5] pim sm
[PE3-Vlan-interface5] mpls enable
[PE3-Vlan-interface5] mpls ldp enable
[PE3-Vlan-interface5] quit
[PE3] interface vlan-interface 4
[PE3-Vlan-interface4] ip address 10.3.1.2 24
[PE3-Vlan-interface4] pim sm
[PE3-Vlan-interface4] mpls enable
[PE3-Vlan-interface4] quit
[PE3-LoopBack1] ip address 3.3.3.3 32
# Configure BGP.
[PE3] bgp 200
[PE3-bgp-default] peer 4.4.4.4 as-number 200
[PE3-bgp-default] peer 4.4.4.4 connect-interface loopback 1
[PE3-bgp-default] peer 10.3.1.1 as-number 100
[PE3-bgp-default] address-family vpnv4
[PE3-bgp-default-vpnv4] undo policy vpn-target
[PE3-bgp-default-vpnv4] peer 4.4.4.4 enable
[PE3-bgp-default-vpnv4] peer 10.3.1.1 enable
[PE3-bgp-default-vpnv4] quit
[PE3-bgp-default-mdt] peer 4.4.4.4 enable
[PE3-bgp-default-mdt] peer 10.3.1.1 enable
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 10.4.1.0 0.0.0.255
[PE3-ospf-1] quit
4.     Configure PE 4:
<PE4> system-view
[PE4] router id 4.4.4.4
[PE4] multicast routing
[PE4-mrib] quit
[PE4] service-loopback group 1 type multicast-tunnel
# Assign HundredGigE 1/0/4 to service loopback group 1. The interface does not belong to VLAN 6, VLAN 13, or VLAN 14.
[PE4] interface hundredgige 1/0/4
[PE4-HundredGigE1/0/4] port service-loopback group 1
[PE4-HundredGigE1/0/4] quit
[PE4] mpls lsr-id 4.4.4.4
[PE4] mpls ldp
[PE4-ldp] quit
[PE4] ip vpn-instance a
[PE4-vpn-instance-a] route-distinguisher 100:1
[PE4-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE4-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE4-vpn-instance-a] quit
[PE4] multicast routing vpn-instance a
[PE4-mrib-a] rpf proxy vector
[PE4-mrib-a] quit
[PE4] multicast-vpn vpn-instance a mode mdt
[PE4-mvpn-a] address-family ipv4
[PE4-mvpn-a-ipv4] default-group 232.1.1.1
[PE4-mvpn-a-ipv4] source loopback 1
[PE4-mvpn-a-ipv4] data-group 232.2.2.0 28
[PE4-mvpn-a-ipv4] quit
[PE4-mvpn-a] quit
[PE4] ip vpn-instance b
[PE4-vpn-instance-b] route-distinguisher 200:1
[PE4-vpn-instance-b] vpn-target 200:1 export-extcommunity
[PE4-vpn-instance-b] vpn-target 200:1 import-extcommunity
[PE4-vpn-instance-b] quit
[PE4] multicast routing vpn-instance b
[PE4-mrib-b] rpf proxy vector
[PE4-mrib-b] quit
[PE4] multicast-vpn vpn-instance b mode mdt
[PE4-mvpn-b] address-family ipv4
[PE4-mvpn-b-ipv4] default-group 232.3.3.3
[PE4-mvpn-b-ipv4] source loopback 1
[PE4-mvpn-b-ipv4] data-group 232.4.4.0 28
[PE4-mvpn-b-ipv4] quit
[PE4-mvpn-b] quit
# Assign an IP address to VLAN-interface 6.
[PE4] interface vlan-interface 6
[PE4-Vlan-interface6] ip address 10.5.1.2 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 6.
[PE4-Vlan-interface6] pim sm
[PE4-Vlan-interface6] mpls enable
[PE4-Vlan-interface6] mpls ldp enable
[PE4-Vlan-interface6] quit
# Associate VLAN-interface 13 with VPN instance a.
[PE4] interface vlan-interface 13
[PE4-Vlan-interface13] ip binding vpn-instance a
[PE4-Vlan-interface13] ip address 11.3.1.1 24
[PE4-Vlan-interface13] pim sm
[PE4-Vlan-interface13] quit
# Associate VLAN-interface 14 with VPN instance b.
[PE4] interface vlan-interface 14
[PE4-Vlan-interface14] ip binding vpn-instance b
[PE4-Vlan-interface14] ip address 11.4.1.1 24
[PE4-Vlan-interface14] pim sm
[PE4-Vlan-interface14] quit
[PE4] interface loopback 1
[PE4-LoopBack1] ip address 4.4.4.4 32
[PE4-LoopBack1] pim sm
[PE4-LoopBack1] quit
# Configure BGP.
[PE4] bgp 200
[PE4-bgp-default] peer 3.3.3.3 as-number 200
[PE4-bgp-default] peer 3.3.3.3 connect-interface loopback 1
[PE4–bgp-default] ip vpn-instance a
[PE4-bgp-default-a] address-family ipv4
[PE4-bgp-default-ipv4-a] import-route ospf 2
[PE4-bgp-default-ipv4-a] import-route direct
[PE4-bgp-default-ipv4-a] quit
[PE4-bgp-default-a] quit
[PE4–bgp-default] ip vpn-instance b
[PE4-bgp-default-b] address-family ipv4
[PE4-bgp-default-ipv4-b] import-route ospf 3
[PE4-bgp-default-ipv4-b] import-route direct
[PE4-bgp-default-ipv4-b] quit
[PE4-bgp-default-b] quit
[PE4–bgp-default] address-family vpnv4
[PE4–bgp-default-vpnv4] peer 3.3.3.3 enable
[PE4–bgp-default-vpnv4] quit
[PE4-bgp-default] address-family ipv4 mdt
[PE4-bgp-default-mdt] peer 3.3.3.3 enable
[PE4-bgp-default-mdt] quit
[PE4–bgp-default] quit
# Configure OSPF.
[PE4] ospf 1
[PE4-ospf-1] area 0.0.0.0
[PE4-ospf-1-area-0.0.0.0] network 4.4.4.4 0.0.0.0
[PE4-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
[PE4-ospf-1-area-0.0.0.0] quit
[PE4-ospf-1] quit
[PE4] ospf 2 vpn-instance a
[PE4-ospf-2] area 0.0.0.0
[PE4-ospf-2-area-0.0.0.0] network 11.3.1.0 0.0.0.255
[PE4-ospf-2-area-0.0.0.0] quit
[PE4-ospf-2] quit
[PE4] ospf 3 vpn-instance b
[PE4-ospf-3] area 0.0.0.0
[PE4-ospf-3-area-0.0.0.0] network 11.4.1.0 0.0.0.255
[PE4-ospf-3-area-0.0.0.0] quit
[PE4-ospf-3] quit
5.     Configure P 1:
<P1> system-view
[P1] multicast routing
[P1-mrib] quit
[P1] mpls lsr-id 5.5.5.5
[P1] mpls ldp
[P1-ldp] quit
[P1] interface vlan-interface 2
[P1-Vlan-interface2] ip address 10.1.1.2 24
[P1-Vlan-interface2] pim sm
[P1-Vlan-interface2] mpls enable
[P1-Vlan-interface2] mpls ldp enable
[P1-Vlan-interface2] quit
[P1] interface vlan-interface 3
[P1-Vlan-interface3] ip address 10.2.1.1 24
[P1-Vlan-interface3] pim sm
[P1-Vlan-interface3] mpls enable
[P1-Vlan-interface3] mpls ldp enable
[P1-Vlan-interface3] quit
[P1] interface loopback 1
[P1-LoopBack1] ip address 5.5.5.5 32
[P1-LoopBack1] pim sm
[P1-LoopBack1] quit
# Configure OSPF.
[P1] ospf 1
[P1-ospf-1] area 0.0.0.0
[P1-ospf-1-area-0.0.0.0] network 5.5.5.5 0.0.0.0
[P1-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[P1-ospf-1-area-0.0.0.0] network 10.2.1.0 0.0.0.255
6.     Configure P 2:
<P2> system-view
[P2] multicast routing
[P2-mrib] quit
[P2] mpls lsr-id 6.6.6.6
[P2] mpls ldp
[P2-ldp] quit
[P2] interface vlan-interface 6
[P2-Vlan-interface6] ip address 10.5.1.1 24
[P2-Vlan-interface6] pim sm
[P2-Vlan-interface6] mpls enable
[P2-Vlan-interface6] mpls ldp enable
[P2-Vlan-interface6] quit
[P2] interface vlan-interface 5
[P2-Vlan-interface5] ip address 10.4.1.2 24
[P2-Vlan-interface5] pim sm
[P2-Vlan-interface5] mpls enable
[P2-Vlan-interface5] mpls ldp enable
[P2-Vlan-interface5] quit
[P2] interface loopback 1
[P2-LoopBack1] ip address 6.6.6.6 32
[P2-LoopBack1] pim sm
[P2-LoopBack1] quit
# Configure OSPF.
[P2] ospf 1
[P2-ospf-1] area 0.0.0.0
[P2-ospf-1-area-0.0.0.0] network 6.6.6.6 0.0.0.0
[P2-ospf-1-area-0.0.0.0] network 10.4.1.0 0.0.0.255
[P2-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
7.     Configure CE a1:
<CEa1> system-view
[CEa1-mrib] quit
# Assign an IP address to VLAN-interface 21, and enable PIM-SM on the interface.
[CEa1] interface vlan-interface 21
[CEa1-Vlan-interface21] ip address 12.1.1.1 24
[CEa1-Vlan-interface21] pim sm
[CEa1-Vlan-interface21] quit
[CEa1-Vlan-interface11] ip address 11.1.1.2 24
# Configure VLAN-interface 11 as a C-BSR and a C-RP.
[CEa1] pim
[CEa1-pim] c-bsr 11.1.1.2
[CEa1-pim] c-rp 11.1.1.2
[CEa1-pim] quit
# Configure OSPF.
[CEa1] ospf 1
[CEa1-ospf-1] area 0.0.0.0
[CEa1-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[CEa1-ospf-1-area-0.0.0.0] network 11.1.1.0 0.0.0.255
[CEa1-ospf-1-area-0.0.0.0] quit
[CEa1-ospf-1] quit
8.     Configure CE b1:
<CEb1> system-view
[CEb1-mrib] quit
# Assign an IP address to VLAN-interface 22, and enable PIM-SM on the interface.
[CEb1] interface vlan-interface 22
[CEb1-Vlan-interface22] ip address 12.2.1.1 24
[CEb1-Vlan-interface22] pim sm
[CEb1-Vlan-interface22] quit
[CEb1] interface vlan-interface 12
[CEb1-Vlan-interface12] ip address 11.2.1.2 24
[CEb1-Vlan-interface12] pim sm
[CEb1-Vlan-interface12] quit
# Configure VLAN-interface 12 as a C-BSR and a C-RP.
[CEb1] pim
[CEb1-pim] c-bsr 11.2.1.2 24
[CEb1-pim] c-rp 11.2.1.2 24
[CEb1-pim] quit
# Configure OSPF.
[CEb1] ospf 1
[CEb1-ospf-1] area 0.0.0.0
[CEb1-ospf-1-area-0.0.0.0] network 12.2.1.0 0.0.0.255
[CEb1-ospf-1-area-0.0.0.0] network 11.2.1.0 0.0.0.255
[CEb1-ospf-1-area-0.0.0.0] quit
[CEb1-ospf-1] quit
9.     Configure CE a2:
<CEa2> system-view
[CEa2-mrib] quit
# Assign an IP address to VLAN-interface 23, and enable IGMP on the interface.
[CEa2] interface vlan-interface 23
[CEa2-Vlan-interface23] ip address 12.3.1.1 24
[CEa2-Vlan-interface23] igmp enable
[CEa2-Vlan-interface23] quit
[CEa2] interface vlan-interface 13
[CEa2-Vlan-interface13] ip address 11.3.1.2 24
[CEa2-Vlan-interface13] pim sm
[CEa2-Vlan-interface13] quit
# Configure OSPF.
[CEa2] ospf 1
[CEa2-ospf-1] area 0.0.0.0
[CEa2-ospf-1-area-0.0.0.0] network 12.3.1.0 0.0.0.255
[CEa2-ospf-1-area-0.0.0.0] network 11.3.1.0 0.0.0.255
[CEa2-ospf-1-area-0.0.0.0] quit
[CEa2-ospf-1] quit
10.     Configure CE b2:
<CEb2> system-view
[CEb2-mrib] quit
# Assign an IP address to VLAN-interface 24, and enable IGMP on the interface.
[CEb2] interface vlan-interface 24
[CEb2-Vlan-interface24] ip address 12.4.1.1 24
[CEb2-Vlan-interface24] igmp enable
[CEb2-Vlan-interface24] quit
[CEb2] interface vlan-interface 14
[CEb2-Vlan-interface14] ip address 11.4.1.2 24
[CEb2-Vlan-interface14] pim sm
[CEb2-Vlan-interface14] quit
# Configure OSPF.
[CEb2] ospf 1
[CEb2-ospf-1] area 0.0.0.0
[CEb2-ospf-1-area-0.0.0.0] network 12.4.1.0 0.0.0.255
[CEb2-ospf-1-area-0.0.0.0] network 11.4.1.0 0.0.0.255
[CEb2-ospf-1-area-0.0.0.0] quit
[CEb2-ospf-1] quit
 232.1.1.1         1.1.1.1           MTunnel0
 232.3.3.3         1.1.1.1           MTunnel1
# Display information about the remote default group for IPv4 multicast transmission in each VPN instance on PE 1.
[PE1] display multicast-vpn default-group remote
MVPN remote default-group information:
 Group address   Source address  Next hop         VPN instance
 232.1.1.1       4.4.4.4         2.2.2.2          a
 232.3.3.3       4.4.4.4         2.2.2.2          b
# Display information about the local default group for IPv4 multicast transmission in each VPN instance on PE 4.
[PE4] display multicast-vpn default-group local
 232.1.1.1         4.4.4.4           MTunnel0
 233.3.3.3         4.4.4.4           MTunnel1
# Display information about the remote default group for IPv4 multicast transmission in each VPN instance on PE 4.
[PE4] display multicast-vpn default-group remote
 232.1.1.1       1.1.1.1         3.3.3.3          a
 232.3.3.3       1.1.1.1         3.3.3.3          b
Example: Configuring MDT-based MVPN inter-AS option C
As shown in Figure 16, configure MDT-based MVPN inter-AS option C to meet the following requirements:
Item
·     For VPN instance a, the default group is 239.1.1.1, and the data group range is 225.1.1.0 to 225.1.1.15.
·     For VPN instance b, the default group is 239.4.4.4, and the data group range is 225.4.4.0 to 225.4.4.15.
VPN instances to which PEs belong
·     PE 1: VLAN-interface 11 belongs to VPN instance b. VLAN-interface 12 belongs to VPN instance a. VLAN-interface 2 and Loopback 1 belong to the public network instance.
·     PE 2: VLAN-interface 2, VLAN-interface 3, Loopback 1, and Loopback 2 belong to the public network instance.
·     PE 3: VLAN-interface 3, VLAN-interface 4, Loopback 1, and Loopback 2 belong to the public network instance.
·     PE 4: VLAN-interface 13 belongs to VPN instance a. VLAN-interface 14 belongs to VPN instance b. VLAN-interface 4 and Loopback 1 belong to the public network instance.
·     Establish BGP peer connections between PE 1, PE 2, PE 3, and PE 4 on their respective Loopback 1.
IGMPv2
·     Enable IGMPv2 on VLAN-interface 30 of CE a2.
·     Enable IGMPv2 on VLAN-interface 40 of CE b2.
PIM-SM
·     Enable PIM-SM on all interfaces that do not have attached receiver hosts of CE a1, CE a2, CE b1, and CE b2.
·     Configure Loopback 2 of PE 2 and PE 3 as a C-BSR and a C-RP for their own AS to provide services for all multicast groups.
·     Configure Loopback 0 of CE a1 as a C-BSR and a C-RP for VPN instance a to provide services for all multicast groups.
·     Configure Loopback 0 of CE b1 as a C-BSR and a C-RP for VPN instance b to provide services for all multicast groups.
MSDP
Establish an MSDP peering relationship between PE 2 and PE 3 on their Loopback 1.
Figure 16 Network diagram
Table 4 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
10.11.5.2/24
R 1
10.11.8.2/24
S 2
10.11.6.2/24
R 2
10.11.7.2/24
PE 1
Vlan-int2
10.10.1.1/24
PE 3
Vlan-int4
10.10.2.1/24
PE 1
Vlan-int11
10.11.1.1/24
PE 3
Vlan-int3
192.168.1.2/24
PE 1
Vlan-int12
10.11.2.1/24
PE 3
Loop1
1.1.1.3/32
PE 1
Loop1
1.1.1.1/32
PE 3
Loop2
22.22.22.22/32
PE 2
Vlan-int2
10.10.1.2/24
PE 4
Vlan-int4
10.10.2.2/24
PE 2
Vlan-int3
192.168.1.1/24
PE 4
Vlan-int13
10.11.3.1/24
PE 2
Loop1
1.1.1.2/32
PE 4
Vlan-int14
10.11.4.1/32
PE 2
Loop2
11.11.11.11/32
PE 4
Loop1
1.1.1.4/32
CE a1
Vlan-int10
10.11.5.1/24
CE b1
Vlan-int20
10.11.6.1/24
CE a1
Vlan-int11
10.11.1.2/24
CE b1
Vlan-int12
10.11.2.2/24
CE a1
Loop0
2.2.2.2/32
CE b2
Vlan-int40
10.11.8.1/24
CE a2
Vlan-int30
10.11.7.1/24
CE b2
Vlan-int14
10.11.4.2/24
CE a2
Vlan-int13
10.11.3.2/24
CE b2
Loop0
3.3.3.3/32
1.     Configure PE 1:
<PE1> system-view
[PE1-mrib] quit
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-mrib-a] quit
[PE1-mvpn-a-ipv4] data-group 225.1.1.0 28
[PE1-mvpn-a] quit
[PE1-mrib-b] quit
[PE1-mvpn-b-ipv4] default-group 239.4.4.4
[PE1-mvpn-b-ipv4] source loopback 1
[PE1-mvpn-b-ivp4] data-group 225.4.4.0 28
[PE1-mvpn-b] quit
[PE1-Vlan-interface2] ip address 10.10.1.1 24
[PE1-Vlan-interface11] ip address 10.11.1.1 24
[PE1-Vlan-interface12] ip address 10.11.2.1 24
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] group pe1-pe2 internal
[PE1-bgp-default] peer pe1-pe2 connect-interface loopback 1
[PE1-bgp-default] peer 1.1.1.2 group pe1-pe2
[PE1-bgp-default] group pe1-pe4 external
[PE1-bgp-default] peer pe1-pe4 as-number 200
[PE1-bgp-default] peer pe1-pe4 ebgp-max-hop 255
[PE1-bgp-default] peer pe1-pe4 connect-interface loopback 1
[PE1-bgp-default] peer 1.1.1.4 group pe1-pe4
[PE1–bgp-default] address-family ipv4
[PE1-bgp-default-ipv4] peer pe1-pe2 enable
[PE1-bgp-default-ipv4] peer pe1-pe2 label-route-capability
[PE1-bgp-default-ipv4] quit
[PE1–bgp-default-vpnv4] peer pe1-pe4 enable
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1-area-0.0.0.0] network 10.10.1.0 0.0.0.255
[PE1-ospf-1] quit
[PE1-ospf-2] import-route bgp
[PE1-ospf-2-area-0.0.0.0] network 10.11.1.0 0.0.0.255
[PE1-ospf-2] quit
[PE1-ospf-3] import-route bgp
[PE1-ospf-3-area-0.0.0.0] network 10.11.2.0 0.0.0.255
[PE1-ospf-3] quit
2.     Configure PE 2:
<PE2> system-view
[PE2-mrib] quit
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] interface vlan-interface 2
[PE2-Vlan-interface2] ip address 10.10.1.2 24
[PE2-Vlan-interface2] pim sm
[PE2-Vlan-interface2] mpls enable
[PE2-Vlan-interface2] mpls ldp enable
[PE2-Vlan-interface2] quit
[PE2-Vlan-interface3] ip address 192.168.1.1 24
# Enable PIM-SM and MPLS on VLAN-interface 3.
[PE2] interface loopback 2
[PE2-LoopBack2] ip address 11.11.11.11 32
[PE2-LoopBack2] pim sm
[PE2-LoopBack2] quit
[PE2] pim
[PE2-pim] c-bsr 11.11.11.11
[PE2-pim] c-rp 11.11.11.11
[PE2-pim] quit
# Configure VLAN-interface 3 as a PIM-SM domain border.
[PE2-Vlan-interface3] pim bsr-boundary
# Establish an MSDP peering relationship.
[PE2] msdp
[PE2-msdp] encap-data-enable
[PE2-msdp] peer 1.1.1.3 connect-interface loopback 1
# Configure a static route.
[PE2] ip route-static 1.1.1.3 32 vlan-interface 3 192.168.1.2
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] group pe2-pe1 internal
[PE2-bgp-default] peer pe2-pe1 connect-interface loopback 1
[PE2-bgp-default] peer 1.1.1.1 group pe2-pe1
[PE2-bgp-default] group pe2-pe3 external
[PE2-bgp-default] peer pe2-pe3 as-number 200
[PE2-bgp-default] peer 192.168.1.2 group pe2-pe3
[PE2-bgp-default-ipv4] peer pe2-pe1 enable
[PE2-bgp-default-ipv4] peer pe2-pe1 route-policy map2 export
[PE2-bgp-default-ipv4] peer pe2-pe1 label-route-capability
[PE2-bgp-default-ipv4] peer pe2-pe3 enable
[PE2-bgp-default-ipv4] peer pe2-pe3 route-policy map1 export
[PE2-bgp-default-ipv4] peer pe2-pe3 label-route-capability
[PE2-bgp-default-ipv4] import-route ospf 1
[PE2-bgp-default-ipv4] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1-area-0.0.0.0] network 11.11.11.11 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 10.10.1.0 0.0.0.255
[PE2-ospf-1] quit
3.     Configure PE 3:
<PE3> system-view
[PE3-mrib] quit
[PE3] mpls ldp
[PE3-ldp] quit
[PE3-Vlan-interface4] ip address 10.10.2.1 24
# Enable PIM-SM, MPLS, and IPv4 LDP on VLAN-interface 4.
[PE3-Vlan-interface4] mpls ldp enable
[PE3] interface vlan-interface 3
[PE3-Vlan-interface3] ip address 192.168.1.2 24
[PE3-Vlan-interface3] pim sm
[PE3-Vlan-interface3] mpls enable
[PE3-Vlan-interface3] quit
[PE3-LoopBack2] ip address 22.22.22.22 32
[PE3] pim
[PE3-pim] c-bsr 22.22.22.22
[PE3-pim] c-rp 22.22.22.22
[PE3-pim] quit
[PE3-Vlan-interface3] pim bsr-boundary
[PE3] msdp
[PE3-msdp] encap-data-enable
[PE3-msdp] peer 1.1.1.2 connect-interface loopback 1
[PE3] ip route-static 1.1.1.2 32 vlan-interface 3 192.168.1.1
# Configure BGP.
[PE3] bgp 200
[PE3-bgp-default] group pe3-pe4 internal
[PE3-bgp-default] peer pe3-pe4 connect-interface loopback 1
[PE3-bgp-default] peer 1.1.1.4 group pe3-pe4
[PE3-bgp-default] group pe3-pe2 external
[PE3-bgp-default] peer pe3-pe2 as-number 100
[PE3-bgp-default] peer 192.168.1.1 group pe3-pe2
[PE3-bgp-default-ipv4] peer pe3-pe4 enable
[PE3-bgp-default-ipv4] peer pe3-pe4 route-policy map2 export
[PE3-bgp-default-ipv4] peer pe3-pe4 label-route-capability
[PE3-bgp-default-ipv4] peer pe3-pe2 enable
[PE3-bgp-default-ipv4] peer pe3-pe2 route-policy map1 export
[PE3-bgp-default-ipv4] peer pe3-pe2 label-route-capability
[PE3-bgp-default-ipv4] import-route ospf 1
[PE3-bgp-default-ipv4] quit
# Configure OSPF.
[PE3] ospf 1
[PE3-ospf-1-area-0.0.0.0] network 22.22.22.22 0.0.0.0
[PE3-ospf-1-area-0.0.0.0] network 10.10.2.0 0.0.0.255
[PE3-ospf-1] quit
4.     Configure PE 4:
<PE4> system-view
[PE4] router id 1.1.1.4
[PE4-mrib] quit
# Assign HundredGigE 1/0/4 to service loopback group 1. The interface does not belong to VLAN 4, VLAN 13, or VLAN 14.
[PE4] mpls lsr-id 1.1.1.4
[PE4] mpls ldp
[PE4-ldp] quit
[PE4-mrib-a] quit
[PE4-mvpn-a-ipv4] default-group 239.1.1.1
[PE4-mvpn-a-ivp4] source loopback 1
[PE4-mvpn-a-ivp4] data-group 225.1.1.0 28
[PE4-mvpn-a] quit
[PE4-mrib-b] quit
[PE4-mvpn-b-ipv4] default-group 239.4.4.4
[PE4-mvpn-b-ivp4] data-group 225.4.4.0 28
[PE4-mvpn-b] quit
[PE4] interface vlan-interface 4
[PE4-Vlan-interface4] ip address 10.10.2.2 24
[PE4-Vlan-interface4] pim sm
[PE4-Vlan-interface4] mpls enable
[PE4-Vlan-interface4] mpls ldp enable
[PE4-Vlan-interface4] quit
[PE4-Vlan-interface13] ip address 10.11.3.1 24
[PE4-Vlan-interface14] ip address 10.11.4.1 24
[PE4-LoopBack1] ip address 1.1.1.4 32
# Configure BGP.
[PE4] bgp 200
[PE4-bgp-default] group pe4-pe3 internal
[PE4-bgp-default] peer pe4-pe3 connect-interface loopback 1
[PE4-bgp-default] peer 1.1.1.3 group pe4-pe3
[PE4-bgp-default] group pe4-pe1 external
[PE4-bgp-default] peer pe4-pe1 as-number 100
[PE4-bgp-default] peer pe4-pe1 ebgp-max-hop 255
[PE4-bgp-default] peer pe4-pe1 connect-interface loopback 1
[PE4-bgp-default] peer 1.1.1.1 group pe4-pe1
[PE4–bgp-default] address-family ipv4
[PE4-bgp-default-ipv4] peer pe4-pe3 enable
[PE4-bgp-default-ipv4] peer pe4-pe3 label-route-capability
[PE4-bgp-default-ipv4] quit
[PE4–bgp-default-vpnv4] peer pe4-pe1 enable
# Configure OSPF.
[PE4] ospf 1
[PE4-ospf-1-area-0.0.0.0] network 1.1.1.4 0.0.0.0
[PE4-ospf-1-area-0.0.0.0] network 10.10.2.0 0.0.0.255
[PE4-ospf-1] quit
[PE4-ospf-2] import-route bgp
[PE4-ospf-2-area-0.0.0.0] network 10.11.3.0 0.0.0.255
[PE4-ospf-2] quit
[PE4-ospf-3] import-route bgp
[PE4-ospf-3-area-0.0.0.0] network 10.11.4.0 0.0.0.255
[PE4-ospf-3] quit
5.     Configure CE a1:
<CEa1> system-view
[CEa1-mrib] quit
[CEa1-Vlan-interface10] ip address 10.11.5.1 24
[CEa1-Vlan-interface11] ip address 10.11.1.2 24
[CEa1] interface loopback 1
[CEa1-LoopBack1] ip address 2.2.2.2 32
[CEa1-LoopBack1] pim sm
[CEa1-LoopBack1] quit
[CEa1] pim
[CEa1-pim] c-bsr 2.2.2.2
[CEa1-pim] c-rp 2.2.2.2
[CEa1-pim] quit
# Configure OSPF.
[CEa1] ospf 1
[CEa1-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[CEa1-ospf-1-area-0.0.0.0] network 10.11.1.0 0.0.0.255
[CEa1-ospf-1-area-0.0.0.0] network 10.11.5.0 0.0.0.255
[CEa1-ospf-1] quit
6.     Configure CE b1:
<CEb1> system-view
[CEb1-mrib] quit
# Assign an IP address to VLAN-interface 20, and enable PIM-SM on the interface.
[CEb1] interface vlan-interface 20
[CEb1-Vlan-interface20] ip address 10.11.6.1 24
[CEb1-Vlan-interface20] pim sm
[CEb1-Vlan-interface20] quit
[CEb1-Vlan-interface12] ip address 10.11.2.2 24
# Configure OSPF.
[CEb1] ospf 1
[CEb1-ospf-1-area-0.0.0.0] network 10.11.2.0 0.0.0.255
[CEb1-ospf-1-area-0.0.0.0] network 10.11.6.0 0.0.0.255
[CEb1-ospf-1] quit
7.     Configure CE a2:
<CEa2> system-view
[CEa2-mrib] quit
# Assign an IP address to VLAN-interface 30, and enable IGMP on the interface.
[CEa2] interface vlan-interface 30
[CEa2-Vlan-interface30] ip address 10.11.7.1 24
[CEa2-Vlan-interface30] igmp enable
[CEa2-Vlan-interface30] quit
[CEa2-Vlan-interface13] ip address 10.11.3.2 24
# Configure OSPF.
[CEa2] ospf 1
[CEa2-ospf-1-area-0.0.0.0] network 10.11.3.0 0.0.0.255
[CEa2-ospf-1-area-0.0.0.0] network 10.11.7.0 0.0.0.255
[CEa2-ospf-1] quit
8.     Configure CE b2:
<CEb2> system-view
[CEb2-mrib] quit
[CEb2] interface vlan-interface 40
[CEb2-Vlan-interface40] ip address 10.11.8.1 24
[CEb2-Vlan-interface40] igmp enable
[CEb2-Vlan-interface40] quit
[CEb2-Vlan-interface14] ip address 10.11.4.2 24
[CEb2] interface loopback 1
[CEb2-LoopBack1] ip address 3.3.3.3 32
[CEb2-LoopBack1] pim sm
[CEb2-LoopBack1] quit
[CEb2] pim
[CEb2-pim] c-bsr 3.3.3.3
[CEb2-pim] c-rp 3.3.3.3
[CEb2-pim] quit
# Configure OSPF.
[CEb2] ospf 1
[CEb2-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[CEb2-ospf-1-area-0.0.0.0] network 10.11.4.0 0.0.0.255
[CEb2-ospf-1-area-0.0.0.0] network 10.11.8.0 0.0.0.255
[CEb2-ospf-1] quit
 239.4.4.4         1.1.1.1           MTunnel1
 239.1.1.1         1.1.1.4           MTunnel0
 239.4.4.4         1.1.1.4           MTunnel1
Example: Configuring receiver-PE-based MVPN extranet
As shown in Figure 17, configure MVPN extranet to meet the following requirements:
Item
Multicast sources and receivers
·     In VPN instance a, S 1 is a multicast source.
·     In VPN instance b, R 1 is a receiver.
·     For VPN instance a, the default group is 239.1.1.1, and the data group range is 225.2.2.0 to 225.2.2.15.
VPN instances to which PE interfaces belong
·     PE 1: VLAN-interface 11 belongs to VPN instance a. VLAN-interface 12 and Loopback 0 belong to the public network instance.
·     PE 2: VLAN-interface 12 belongs to VPN instance b. VLAN-interface 11 and Loopback 0 belong to the public network instance.
Unicast routing protocols and MPLS
·     Configure OSPF on the public network and configure RIP between PEs and CEs.
·     Establish BGP peer connections between PE 1 and PE 2 on their respective Loopback 0.
·     Configure MPLS on the public network.
·     Enable IP multicast routing on the P device.
·     Enable IP multicast routing for the public network on PE 1 and PE 2.
·     Enable IP multicast routing for VPN instance a on PE 1.
·     Enable IP multicast routing for VPN instance b on PE 2.
·     Enable IP multicast routing on CE 1 and CE 2.
IGMPv2
Enable IGMPv2 on VLAN-interface 12 of CE 2.
PIM-SM
Enable PIM-SM on the public network and for VPN instances a and b:
·     Enable PIM-SM on all interfaces of the P device.
·     Enable PIM-SM on all public and private network interfaces of PE 1 and PE 2.
·     Enable PIM-SM on all interfaces that do not have attached receiver hosts on CE 1 and CE 2.
·     Configure Loopback 0 of the P device as a C-BSR and a C-RP for the public network to provide services for all multicast groups.
·     Configure Loopback 1 of CE 1 as a C-BSR and a C-RP for VPN instance a to provide services for all multicast groups.
·     Configure Loopback 1 of PE 2 as a C-BSR and a C-RP for VPN instance b to provide services for all multicast groups.
Figure 17 Network diagram
Table 5 Interface and IP address assignment
Device
IP address
Device
IP address
S 1
10.110.7.2/24
PE 2
Vlan-int11
192.168.7.1/24
R 1
10.110.11.2/24
PE 2
Vlan-int12
10.110.3.2/24
P
Vlan-int11
192.168.6.1/24
PE 2
Loop0
1.1.1.2/32
P
Vlan-int12
192.168.7.2/24
PE 2
Loop1
20.20.20.20/32
P
Loop0
2.2.2.2/32
PE 2
Loop2
100.100.100.100/32
PE 1
Vlan-int11
10.110.2.1/24
CE 1
Vlan-int11
10.110.7.1/24
PE 1
Vlan-int12
192.168.6.2/24
CE 1
Vlan-int12
10.110.2.2/24
PE 1
Loop0
1.1.1.1/32
CE 1
Loop1
11.11.11.11/32
CE 2
Vlan-int11
10.110.3.1/24
CE 2
Vlan-int12
10.110.11.1/24
1.     Configure PE 1:
# Configure a global router ID, and enable IP multicast routing on the public network.
<PE1> system-view
[PE1] router id 1.1.1.1
[PE1-mrib] quit
# Configure an LSR ID, and enable LDP globally.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
[PE1] ip vpn-instance a
[PE1-vpn-instance-a] route-distinguisher 100:1
[PE1-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE1-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE1-vpn-instance-a] quit
# Enable IP multicast routing for VPN instance a.
[PE1] multicast routing vpn-instance a
[PE1-mrib-a] quit
# Create an MDT-based MVPN for VPN instance a.
[PE1] multicast-vpn vpn-instance a mode mdt
# Create an MVPN IPv4 address family for VPN instance a.
[PE1-mvpn-a] address-family ipv4
# Specify the default group, the MVPN source interface, and the data group range for VPN instance a.
[PE1-mvpn-a-ipv4] default-group 239.1.1.1
[PE1-mvpn-a-ipv4] source loopback 0
[PE1-mvpn-a-ipv4] data-group 225.2.2.0 28
[PE1-mvpn-a-ipv4] quit
[PE1-mvpn-a] quit
# Assign an IP address to VLAN-interface 12, and enable PIM-SM, MPLS, and IPv4 LDP on the interface.
[PE1] interface vlan-interface12
[PE1-Vlan-interface12] ip address 192.168.6.2 24
[PE1-Vlan-interface12] pim sm
[PE1-Vlan-interface12] mpls enable
[PE1-Vlan-interface12] mpls ldp enable
[PE1-Vlan-interface12] quit
# Associate VLAN-interface 11 with VPN instance a, assign an IP address to the interface and enable PIM-SM on the interface.
[PE1] interface vlan-interface11
[PE1-Vlan-interface11] ip binding vpn-instance a
[PE1-Vlan-interface11] ip address 10.110.2.1 24
[PE1-Vlan-interface11] pim sm
[PE1-Vlan-interface11] quit
# Assign an IP address to Loopback 0, and enable PIM-SM on the interface.
[PE1] interface loopback 0
[PE1-LoopBack0] pim sm
[PE1-LoopBack0] quit
# Configure BGP.
[PE1] bgp 100
[PE1-bgp-default] group vpn-g internal
[PE1-bgp-default] peer vpn-g connect-interface loopback 0
[PE1-bgp-default] peer 1.1.1.2 group vpn-g
[PE1–bgp-default] ip vpn-instance a
[PE1-bgp-default-a] address-family ipv4
[PE1-bgp-default-ipv4-a] import-route rip 2
[PE1-bgp-default-ipv4-a] import-route direct
[PE1-bgp-default-ipv4-a] quit
[PE1-bgp-default-a] quit
[PE1–bgp-default] address-family vpnv4
[PE1–bgp-default-vpnv4] peer vpn-g enable
[PE2–bgp-default-vpnv4] quit
[PE1–bgp-default] address-family ipv4 mdt
[PE1–bgp-default-mdt] peer vpn-g enable
[PE1–bgp-default-mdt] quit
[PE1–bgp-default] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] area 0.0.0.0
[PE1-ospf-1-area-0.0.0.0] network 192.168.6.0 0.0.0.255
[PE1-ospf-1] quit
# Configure RIP.
[PE1] rip 2 vpn-instance a
[PE1-rip-2] network 10.110.2.0 0.0.0.255
[PE1-rip-2] import-route bgp
[PE1-rip-2] quit
2.     Configure PE 2:
<PE2> system-view
[PE2] router id 1.1.1.2
[PE2] multicast routing
[PE2-mrib] quit
[PE2] mpls lsr-id 1.1.1.2
[PE2] mpls ldp
[PE2-ldp] quit
[PE2] ip vpn-instance a
[PE2-vpn-instance-a] route-distinguisher 100:1
[PE2-vpn-instance-a] vpn-target 100:1 export-extcommunity
[PE2-vpn-instance-a] vpn-target 100:1 import-extcommunity
[PE2-vpn-instance-a] quit
[PE2] multicast routing vpn-instance a
[PE2-mrib-a] quit
[PE2] multicast-vpn vpn-instance a mode mdt
[PE2-mvpn-a] address-family ipv4
[PE2-mvpn-a-ipv4] default-group 239.1.1.1
[PE2-mvpn-a-ipv4] source loopback 0
[PE2-mvpn-a-ipv4] data-group 225.2.2.0 28
[PE2-mvpn-a-ipv4] quit
[PE2-mvpn-a] quit
# Create a VPN instance named b.
[PE2] ip vpn-instance b
[PE2-vpn-instance-b] quit
# Enable IP multicast routing for VPN instance b.
[PE2] multicast routing vpn-instance b
# Configure IPv4 MVPN extranet RPF selection policies.
[PE2-mrib-b] multicast extranet select-rpf vpn-instance a source 10.110.7.2 32 group 226.1.1.0 24
[PE2-mrib-b] multicast extranet select-rpf vpn-instance a source 20.20.20.20 32 group 226.1.1.0 24
[PE2-mrib-b] quit
# Assign an IP address to VLAN-interface 11, and enable PIM-SM, MPLS, and IPv4 LDP on the interface.
[PE2] interface vlan-interface11
[PE2-Vlan-interface11] ip address 192.168.7.1 24
[PE2-Vlan-interface11] pim sm
[PE2-Vlan-interface11] mpls enable
[PE2-Vlan-interface11] mpls ldp enable
[PE2-Vlan-interface11] quit
# Associate VLAN-interface12 with VPN instance b, assign an IP address to the interface, and enable PIM-SM on the interface.
[PE2] interface vlan-interface12
[PE2-Vlan-interface12] ip binding vpn-instance b
[PE2-Vlan-interface12] ip address 10.110.3.2 24
[PE2-Vlan-interface12] pim sm
[PE2-Vlan-interface12] quit
[PE2] interface loopback 0
[PE2-LoopBack0] ip address 1.1.1.2 32
[PE2-LoopBack0] pim sm
[PE2-LoopBack0] quit
# Associate Loopback 1 with VPN instance b, assign an IP address to the interface, and enable PIM-SM on the interface.
[PE2] interface loopback 1
[PE2-LoopBack1] ip binding vpn-instance b
[PE2-LoopBack1] ip address 20.20.20.20 32
[PE2-LoopBack1] pim sm
[PE2-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and a C-RP for VPN instance b.
[PE2] pim vpn-instance b
[PE2-pim-b] c-bsr 20.20.20.20
[PE2-pim-b] c-rp 20.20.20.20
[PE2-pim-b] quit
# Associate Loopback 2 with VPN instance a, assign an IP address to the interface, and enable PIM-SM on the interface.
[PE2-LoopBack2] ip binding vpn-instance a
[PE2-LoopBack2] ip address 100.100.100.100 32
# Configure BGP.
[PE2] bgp 100
[PE2-bgp-default] group vpn-g internal
[PE2-bgp-default] peer vpn-g connect-interface loopback 0
[PE2-bgp-default] peer 1.1.1.1 group vpn-g
[PE2–bgp-default] ip vpn-instance a
[PE2-bgp-default-a] address-family ipv4
[PE2-bgp-default-ipv4-a] import-route direct
[PE2-bgp-default-ipv4-a] quit
[PE2-bgp-default-a] quit
[PE2–bgp-default] address-family vpnv4
[PE2–bgp-default-vpnv4] peer vpn-g enable
[PE2–bgp-default] address-family ipv4 mdt
[PE2–bgp-default-mdt] peer vpn-g enable
[PE2–bgp-default-mdt] quit
[PE2–bgp-default] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] area 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 1.1.1.2 0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 192.168.7.0 0.0.0.255
[PE2-ospf-1] quit
# Configure RIP.
[PE2] rip 3 vpn-instance b
[PE2-rip-3] network 10.110.3.0 0.0.0.255
[PE2-rip-3] network 20.20.20.20 0.0.0.0
[PE2-rip-3] import-route bgp
[PE2-rip-3] quit
3.     Configure the P device:
<P> system-view
[P-mrib] quit
[P] mpls ldp
[P-ldp] quit
[P] interface vlan-interface11
[P-Vlan-interface11] ip address 192.168.6.1 24
[P-Vlan-interface11] pim sm
[P-Vlan-interface11] mpls enable
[P-Vlan-interface11] mpls ldp enable
[P-Vlan-interface11] quit
[P] interface vlan-interface12
[P-Vlan-interface12] ip address 192.168.7.2 24
[P] interface loopback 0
[P-LoopBack0] ip address 2.2.2.2 32
[P-LoopBack0] pim sm
[P-LoopBack0] quit
# Configure Loopback 0 as a C-BSR and a C-RP for the public network.
[P] pim
[P-pim] quit
# Configure OSPF.
[P] ospf 1
4.     Configure CE 1:
<CE1> system-view
[CE1] multicast routing
[CE1-mrib] quit
# Assign an IP address to VLAN-interface 11, and enable PIM-SM on the interface.
[CE1] interface vlan-interface11
[CE1-Vlan-interface11] ip address 10.110.7.1 24
[CE1-Vlan-interface11] pim sm
[CE1-Vlan-interface11] quit
[CE1] interface vlan-interface12
[CE1-Vlan-interface12] ip address 10.110.2.2 24
[CE1-Vlan-interface12] pim sm
[CE1-Vlan-interface12] quit
# Assign an IP address to Loopback 1, and enable PIM-SM on the interface.
[CE1] interface loopback 1
[CE1-LoopBack1] ip address 11.11.11.11 32
[CE1-LoopBack1] pim sm
[CE1-LoopBack1] quit
# Configure Loopback 1 as a C-BSR and a C-RP for VPN instance a.
[CE1] pim
[CE1-pim] c-bsr 11.11.11.11
[CE1-pim] c-rp 11.11.11.11
[CE1-pim] quit
# Configure RIP.
[CE1] rip 2
[CE1-rip-2] network 10.110.2.0 0.0.0.255
[CE1-rip-2] network 10.110.7.0 0.0.0.255
[CE1-rip-2] network 11.11.11.11 0.0.0.0
5.     Configure CE 2:
<CE2> system-view
[CE2] multicast routing
[CE2-mrib] quit
# Assign an IP address to VLAN-interface 11, and enable IGMP on the interface.
[CE2] interface vlan-interface11
[CE2-Vlan-interface11] ip address 10.110.3.1 24
[CE2-Vlan-interface11] pim sm
[CE2-Vlan-interface11] quit
[CE2] interface vlan-interface12
[CE2-Vlan-interface12] ip address 10.110.11.1 24
[CE2-Vlan-interface12] igmp enable
[CE2-Vlan-interface12] quit
# Configure RIP.
[CE2] rip 3
[CE2-rip-3] network 10.110.3.0 0.0.0.255
[CE2-rip-3] network 10.110.11.0 0.0.0.255
# Display PIM routing entries for MVPN extranet of VPN instance a on PE 2.
[PE2] display pim vpn-instance a routing-table
 Total 1 (*, G) entries; 1 (S, G) entries
 (*, 226.1.1.1)
     RP: 11.11.11.11
     Protocol: pim-sm, Flag: WC
     UpTime: 07:06:11
     Upstream interface: MTunnel0
         Upstream neighbor: 1.1.1.1
         RPF prime neighbor: 1.1.1.1
     Downstream interface information:
         1: Extranet (VPN: b)
             Protocol: MD, UpTime: 01:12:52, Expires: -
(10.110.7.2, 226.1.1.1)
     RP: 11.11.11.11
     Protocol: pim-sm, Flag: SPT ACT RQ
     UpTime: 07:06:10
# Display PIM routing entries for MVPN extranet of VPN instance b on PE 2.
[PE2] display pim vpn-instance b routing-table
 (*, 226.1.1.1)
     RP: 20.20.20.20
     UpTime: 07:06:11
     Upstream interface: Extranet (VPN: a)
         Upstream neighbor: 127.0.0.1
         RPF prime neighbor: 127.0.0.1
         1: Vlan-interface12
             Protocol: igmp, UpTime: 01:12:52, Expires: -
     RP: 20.20.20.20
     Protocol: pim-sm, Flag: SPT ACT 2MVPN
     UpTime: 07:06:10
         1: Vlan-interface12
Troubleshooting MDT-based MVPN
This section describes common MDT-based MVPN problems and how to troubleshoot them.
A default MDT cannot be established
Symptom
The default MDT cannot be established. PIM neighboring relationship cannot be established between PEs' interfaces that are in the same VPN instance.
Solution
To resolve the problem:
1.     Use the display interface command to examine the MTI interface state and address encapsulation on the MTI.
2.     Use the display multicast-vpn default-group command to verify that the same default group address has been configured for the same VPN instance on different PEs.
3.     Use the display pim interface command to verify the following:
¡     PIM is enabled on a minimum of one interface of the same VPN on different PEs.
¡     The same PIM mode is running on all the interfaces of the same VPN instance on different PEs and on all the interfaces of the P device.
4.     Use the display ip routing-table command to verify that a unicast route exists from the VPN instance on the local PE to the same VPN instance on each remote PE.
5.     Use the display bgp peer command to verify that the BGP peer connections have been correctly configured.
6.     If the problem persists, contact H3C Support.
An MVRF cannot be created
Symptom
A VPN instance cannot create an MVRF correctly.
Solution
1.     Use the display pim bsr-info command to verify that the BSR information exists on the public network and VPN instance. If it does not, verify that a unicast route exists to the BSR.
2.     Use the display pim rp-info command to examine the RP information. If no RP information is available, verify that a unicast route exists to the RP. Use the display pim neighbor command to verify that the PIM adjacencies have been correctly established on the public network and the VPN.
3.     Use the ping command to examine the connectivity between the VPN DR and the VPN RP.
4.     If the problem persists, contact H3C Support.
