| 01-MSR Routers Stateless Address Auto-Configuration Examples | 58.87 KB |
MSR Routers
Introduction
This document provides an example of configuring stateless address auto-configuration. This feature enhances network security, because it enables an interface to automatically generate an IPv6 global unicast address by using the address prefix in the received RA message and the interface ID.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
Software version used
This example is applicable to the MSR router series of the H3C Comware 7 platform. This document takes version R6749P14 of the H3C MSR3610-X1 router as an example. The specific operations might differ by product model and software version.
· Stateless address auto-configuration enables an interface to automatically generate an IPv6 global unicast address by using the address prefix in the received RA message and the interface ID. If the IPv6 prefix in the RA message is not 64 bits, stateless address auto-configuration fails to generate an IPv6 global unicast address.
· An IEEE 802 interface supports generating public IPv6 addresses and temporary IPv6 addresses. Temporary IPv6 addresses do not overwrite public IPv6 addresses, so an interface can have multiple IPv6 addresses with the same address prefix but different interface IDs. If an interface fails to generate a public IPv6 address because of a prefix conflict or other reasons, it does not generate any temporary IPv6 address.
As shown in Figure 1, the host, Router A, and Router B are connected through Ethernet interfaces. Stateless address auto-configuration is enabled on GigabitEthernet 1/0/1 of Router B.
Procedures
Configuring Router A
# Assign a global unicast address to GigabitEthernet 1/0/1 and enable RA message advertisement on the interface.
[RouterA-GigabitEthernet1/0/1] ipv6 address 3001::1/64
[RouterA-GigabitEthernet1/0/1] undo ipv6 nd ra halt
Configure Router B
# Enable stateless address auto-configuration on GigabitEthernet 1/0/1.
<RouterB> system-view
[RouterB-GigabitEthernet1/0/1] ipv6 address auto
