02-WLAN Command References
HomeSupportConfigure & DeployConfiguration GuidesH3C Unified Wired and Wireless Access Controller User Manual (R5456Pxx)-6W10002-WLAN Command References
13-WLAN high availability commands
13-WLAN high availability commands 37.28 KB
WLAN uplink detection commands
wlan uplink track
Use wlan uplink track to associate a track entry with WLAN uplink detection.
Use undo wlan uplink track to restore the default.
wlan uplink track track-entry-number
WLAN uplink detection is not associated with any track entry.
track-entry-number: Specifies a track entry ID in the range of 1 to 1024.
This command enables the AC to adjust radio state based on the uplink state associated with a track entry. When the track entry is in Negative state, the AC disables radios of all connected APs. When the track entry is in Positive state, the AC enables radios of all connected APs.
# Associate track entry 1 with WLAN uplink detection.
[Sysname] wlan uplink track 1
