22-DPI Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C MSR810[830][2600][3600] Routers Configuration Guides(V7)-R0821-6W50122-DPI Configuration Guide
02-DPI engine configuration
02-DPI engine configuration 145.84 KB
Configuring DPI engine
About DPI engine
DPI engine is an inspection module shared by DPI service modules. DPI engine uses inspection rules to identify the application layer information, including the application layer protocol and behavior. DPI service modules process packets based on the inspection results.
DPI functions
DPI engine provides the following functions:
·     Protocol parsing—Identifies the application layer protocols and analyzes the application layer information. Information analysis includes recognizing, normalizing, and uncompressing application layer fields.
·     AC pattern matching—Matches packet payloads by the Aho-Corasick (AC) patterns in inspection rules. AC pattern matching is fast and it is the core function of the DPI engine.
·     Option matching—Matches packet payloads by the options in the inspection rules whose AC patterns have been matched. Option matching is slower than AC pattern matching.
DPI engine inspection rules
DPI engine uses inspection rules to match packets. Inspection rules are transformed from the rules or signatures of the DPI service modules. The match criteria in an inspection rule can contain the following types:
·     AC pattern—Criteria that identify packet signatures. An AC pattern is a character string that is three or more bytes long.
·     Option—Criteria other than AC patterns. For example, an option can be the port number or protocol type.
An inspection rule can contain both AC patterns and options. A packet must match both the AC patterns and options to match the rule.
An inspection rule can also contain only options. A packet matches the rule if it matches the options in the rule.
DPI engine mechanism
As shown in Figure 1, DPI engine works as follows:
1.     The DPI engine performs protocol parsing for the packet and searches for applicable inspection rules according to the parsing results.
2.     If an applicable inspection rule contains AC patterns, DPI engine performs AC pattern matching first. If an applicable inspection rule does not contain AC patterns, DPI engine directly performs option matching. The packet matches the rule if it matches the options.
3.     If the packet matches an AC pattern in an applicable inspection rule, the DPI engine further compares the packet against the options associated with the AC pattern. The packet matches the rule if it matches the both the AC pattern and its associated options. If the packet matches an AC pattern but does not match its associated options, the DPI engine permits the packet to pass.
4.     If the packet matches an inspection rule, the DPI engine submits the packet to the corresponding DPI service module for processing. If the packet does not match any rule, the DPI engine permits the packet to pass.
Figure 1 DPI engine mechanism
Restrictions: Hardware compatibility with the DPI engine
Hardware
DPI engine compatibility
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LM-CNDE-SJK, MSR810-CNDE-SJK
Yes
MSR810-LMS, MSR810-LUS
No
MSR810-LMS-EA, MSR810-LME
Yes
MSR2600-6-X1, MSR2600-10-X1
Yes
MSR 2630
Yes
MSR3600-28, MSR3600-51
Yes
MSR3600-28-SI, MSR3600-51-SI
No
Yes
MSR3610-I-DP, MSR3610-IE-DP, MSR3610-IE-ES, MSR3610-IE-EAD, MSR3610-I-IG, MSR3610-IE-IG
Yes
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC
Yes
MSR 3610, MSR 3620, MSR 3620-DP, MSR 3640, MSR 3660
Yes
MSR3610-G, MSR3620-G
Yes
Hardware
MSR810-W-WiNet, MSR810-LM-WiNet
Yes
MSR830-4LM-WiNet
Yes
MSR830-5BEI-WiNet, MSR830-6EI-WiNet, MSR830-10BEI-WiNet
Yes
MSR830-6BHI-WiNet, MSR830-10BHI-WiNet
Yes
MSR2600-6-WiNet, MSR2600-10-X1-WiNet
Yes
MSR2630-WiNet
Yes
MSR3600-28-WiNet
Yes
MSR3610-X1-WiNet
Yes
MSR3610-WiNet, MSR3620-10-WiNet, MSR3620-DP-WiNet, MSR3620-WiNet, MSR3660-WiNet
Yes
Hardware
MSR2630-XS
Yes
MSR3600-28-XS
Yes
MSR3610-XS
Yes
MSR3620-XS
Yes
MSR3610-I-XS
Yes
MSR3610-IE-XS
Yes
Hardware
MSR810-LM-GL
Yes
MSR810-W-LM-GL
Yes
MSR830-6EI-GL
Yes
MSR830-10EI-GL
Yes
MSR830-6HI-GL
Yes
MSR830-10HI-GL
Yes
MSR2600-6-X1-GL
Yes
MSR3600-28-SI-GL
No
DPI engine tasks at a glance
To configure the DPI engine, perform the following tasks:
1.     Configure a DPI application profile
2.     Activating policy and rule settings for DPI service modules
3.     Configuring action parameter profiles
4.     (Optional.) Optimizing the DPI engine
5.     (Optional.) Enabling inspection suspension upon excessive CPU usage
6.     (Optional.) Configuring stream fixed length inspection
7.     (Optional.) Configuring advanced features of the DPI engine
¡     Enabling source port-based application identification
¡     Specifying a proxy server for online DPI service signature update
¡     Specifying the cloud query server for DPI services
8.     (Optional.) Disabling the DPI engine
A DPI application profile includes a set of DPI service policies, such as a URL filtering policy. It can be applied to an object policy rule to specify the DPI service policy for packets that match the rule.
2.     Create a DPI application profile and enter its view.
app-profile profile-name
3.     Apply DPI service policies to the DPI application profile.
¡     Specify an IPS policy.
ips apply policy policy-name mode { protect | alert }
For more information about this command, see IPS commands in DPI Command Reference.
¡     Specify a URL filtering policy.
url-filter apply policy policy-name
For more information about this command, see URL filtering commands in DPI Command Reference.
By default, no DPI service policies are applied to a DPI application profile.
After editing the policy and rule settings for DPI service modules such as URL filtering, you must manually activate the settings by using either of the following methods:
·     Reboot the device.
·     Execute the inspect activate command.
This task can cause temporary service outage. As a best practice, perform the task after all DPI service policy and rule settings are complete.
2.     Activate policy and rule settings for DPI service modules.
inspect activate
By default, the creation, modification, and deletion of DPI service policies and rules do not take effect.
Configuring a block source parameter profile
A block source parameter profile defines the block period for the block source action in DPI service modules.
The block source action takes effect only after the blacklist feature is enabled.
With the blacklist feature is enabled, the device drops the matching packet and adds the packet's source IP address to the IP blacklist. Subsequent packets from the source IP address will be dropped directly during the block period.
For more information about the blacklist feature, see attack detection and prevention configuration in the Security Configuration Guide.
2.     Create a block source parameter profile and enter its view.
inspect block-source parameter-profile parameter-name
3.     Set the block period during which a source IP address is blocked.
block-period period
The default setting is 1800 seconds.
Configuring a capture parameter profile
A capture parameter profile defines the following parameters for the capture action in DPI service modules:
·     Maximum number of bytes that can be cached.
·     Daily export time for cached packets.
·     URL to which cached packets are exported.
The device caches captured packets locally and exports the cached packets to the designated URL at the daily export time or when the number of cached bytes reaches the limit. After the export, the device clears the local cache and starts to capture new packets.
2.     Create a capture parameter profile and enter its view.
inspect capture parameter-profile parameter-name
3.     Set the maximum volume of captured packets that can be cached.
capture-limit kilobytes
By default, the device can cache a maximum of 512 Kilobytes of captured packets.
4.     Set the daily export time for cached captured packets.
export repeating-at time
By default, the cached captured packets are exported at 1:00 a.m. every day.
5.     Specify the URL to which cached captured packets are exported
export url url-string
By default, no URL is specified for exporting the cached captured packets.
Configuring a logging parameter profile
A logging parameter profile defines the log output method and log output language for the logging action in DPI service modules.
After setting the IPS log language to Chinese, only the attack name field of the IPS logs supports displaying in Chinese.
2.     Create a logging parameter profile and enter its view.
inspect logging parameter-profile parameter-name
3.     Specify the log export method.
log { email | syslog }
By default, logs are exported to the information center.
4.     Set the language for IPS log output to Chinese.
log language chinese
By default, IPS logs are output in English.
Configuring a redirect parameter profile
A redirect parameter profile defines the URL to which packets are redirected for the redirect action in DPI service modules.
2.     Create a redirect parameter profile and enter its view.
inspect redirect parameter-profile parameter-name
3.     Specify the URL to which packets are redirected.
redirect-url url-string
By default, no URL is specified for packet redirecting.
Configuring an email parameter profile
An email parameter profile defines the following parameters for the email action in DPI service modules:
·     Email server.
·     Email sender and receiver.
·     Username and password for logging in to the email server.
2.     Create an email parameter profile and enter its view.
inspect email parameter-profile parameter-name
3.     Specify the email server.
email-server addr-string
By default, no email server is specified.
4.     Specify the DNS server address.
dns-server ip-address
By default, no DNS server is specified.
5.     Specify the email sender address.
sender addr-string
By default, no email sender address is specified.
6.     Specify the email receiver address.
receiver addr-string
By default, no email receiver address is specified.
7.     (Optional.) Configure email client authentication.
a.     Enable email client authentication.
authentication enable
By default, email client authentication is enabled.
b.     Specify the username for logging in to the email server.
username name-string
By default, no username is specified for logging in to the email server.
c.     Specify the password for logging in to the email server.
By default, no password is specified for logging in to the email server.
d.     Enable the secure password transmission feature.
secure-authentication enable
By default, the secure password transmission feature is disabled.
8.     Configure output limit for log entries sent to the email server.
email-limit interval interval max-number value
By default, the device allows sending a maximum of 10 log entries within five minutes.
The DPI engine includes a series of optimization features. For example, you can enable the DPI engine to uncompress or decode the compressed or encoded packets to identify the application information of the packets. The optimization features improve inspection and accuracy of the DPI engine, but consume more system resources.
2.     Set the maximum number of payload-carrying packets to be inspected per data flow.
inspect packet maximum max-number
By default, the DPI engine can inspect a maximum of 32 payload-carrying packets per data flow.
3.     Set the maximum number of options to be cached per TCP or UDP data flow.
inspect cache-option maximum max-number
By default, the DPI engine can cache a maximum of 32 options per TCP or UDP data flow.
4.     Configure the TCP segment reassembly feature.
¡     Enable TCP segment reassembly.
inspect tcp-reassemble enable
By default, the TCP segment reassembly feature is disabled.
¡     Set the maximum number of TCP segments that can be cached for reassembly per TCP flow.
inspect tcp-reassemble max-segment max-number
By default, a maximum of 10 TCP segments can be cached for reassembly per TCP flow.
5.     (Optional.) Disable a DPI engine optimization feature.
inspect optimization [ chunk | no-acsignature | raw | uncompress | url-normalization ] disable
By default, all DPI engine optimization features are enabled.
You can disable DPI engine optimization features to improve the device performance as needed.
Packet inspection of the DPI engine is a complex and resource-consuming process.
Inspection suspension upon excessive CPU usage works as follows:
·     When the device's CPU usage rises to or above the CPU usage threshold, the DPI engine suspends packet inspection to guarantee the device performance.
·     When the device's CPU usage drops to or below the CPU usage recovery threshold, the DPI engine resumes packet inspection.
For information about configuring the CPU usage thresholds, see device management in Fundamentals Configuration Guide.
Do not disable inspection suspension upon excessive CPU usage if the device's CPU usage is high.
When the device's CPU usage is low, you can disable this feature to improve inspection accuracy.
2.     Enable inspection suspension upon excessive CPU usage.
undo inspect cpu-threshold disable
By default, inspection suspension upon excessive CPU usage is enabled.
DPI engine inspects only the fixed-length data after the first packet for each stream. The remaining stream data is not inspected.
2.     Enable the stream fixed length inspection.
undo inspect stream-fixed-length disable
By default, the stream fixed length inspection is enabled.
3.     Set the fixed length for stream inspection.
inspect stream-fixed-length { email | ftp | http } * length
The default length is 32 Kilobytes for FTP, HTTP, and email streams.
The longer the inspection data length, the lower the device throughput, and the higher the packet inspection accuracy.
You can use this feature to identify traffic of applications that use fixed source ports when the following conditions are true:
·     The types of traffic transmitted over networks are relatively unvaried and use fixed source ports.
·     Destination port-based application identification or signature-based traffic content identification is not supported.
The application identification results produced by this feature might not be accurate. Configure this feature according to your live network as a best practice.
2.     Enable source port-based application identification.
inspect source-port-identify enable
By default, source port-based application identification is disabled.
The device must access the company's website for online signature update of DPI services (such as URL filtering). If direct connectivity is not available, the device can access the company's website through the specified proxy server. For more information about online signature update, see "Configuring URL filtering" and "Configuring anti-virus."
If you specify a proxy server by domain name instead of IP address, make sure the device can resolve the domain name into an IP address through DNS. For more information about DNS, see Layer 3—IP Services Configuration Guide.
2.     Specify a proxy server for online DPI service signature update
inspect signature auto-update proxy { domain domain-name | ip ip-address } [ port port-number ] [ user user-name password { cipher | simple } string ]
By default, the proxy server used by DPI services for online signature update is not specified.
You can specify the server used for cloud query by DPI services. The cloud query server supports only URL filtering cloud query in the current software version.
For successful cloud query, make sure the device can resolve the host name of the cloud query server into an IP address through DNS. For more information about DNS, see DNS configuration in Layer 3—IP Services Configuration Guide.
2.     Specify the cloud query server for DPI services.
inspect cloud-server host-name
By default, DPI services use the cloud query server with host name sec.h3c.com.
Packet inspection in the DPI engine is a complex and resource-consuming process. When the CPU usage is too high, you can disable the DPI engine to guarantee the device performance. After you disable the DPI engine, packets will not be processed by DPI.
2.     Disable the DPI engine.
inspect bypass
By default, the DPI engine is enabled.
Display and maintenance commands for DPI engine
Display the status of the DPI engine.
display inspect status
