| 04-IP-FORWARD-MIB | 53.32 KB |
IP-FORWARD-MIB
About this MIB
Use this MIB to configure IP routes for Classless Inter-Domain Routing (CIDR).
MIB file name
rfc4292-ip-forward.mib
Root object
iso(1).org(3).dod(6).internet(1).mgmt(2).mib-2(1).ip(4).ipForward(24)
Scalar objects
ipCidrRouteNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipCidrRouteNumber(1.3.6.1.2.1.4.24.3) |
read-only |
Gauge32 |
Standard MIB values. |
Number of current valid ipCidrRouteTable entries. |
As per the MIB. |
inetCidrRouteNumber
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
inetCidrRouteNumber (1.3.6.1.2.1.4.24.6) |
read-only |
Gauge32 |
Number of current valid inetCidrRouteTable entries. |
As per the MIB. |
inetCidrRouteDiscards
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
inetCidrRouteDiscards (1.3.6.1.2.1.4.24.8) |
read-only |
Counter32 |
Number of invalid entries dropped by inetCidrRouteTable. |
As per the MIB. |
Tabular objects
ipCidrRouteTable
About this table
Use this table to implement routing table function on an entity.
Support for operations
Create |
Edit/Modify |
Delete |
Read |
Supported |
Supported |
Supported |
Supported |
Columns
The table indexes are ipCidrRouteDest, ipCidrRouteMask, ipCidrRouteTos, and ipCidrRouteNextHop.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
ipCidrRouteDest(1.3.6.1.2.1.4.24.4.1.1) |
read-only |
IpAddress |
(0..255) |
Destination IP address of the route. |
As per the MIB. |
ipCidrRouteMask(1.3.6.1.2.1.4.24.4.1.2) |
read-only |
IpAddress |
(0..255) |
Address mask. |
As per the MIB. |
ipCidrRouteTos(1.3.6.1.2.1.4.24.4.1.3) |
read-only |
Integer32 |
ToS field value. |
The value is always 0. |
ipCidrRouteNextHop(1.3.6.1.2.1.4.24.4.1.4) |
read-only |
IpAddress |
(0..255) |
Address of the next hop. |
As per the MIB. |
ipCidrRouteIfIndex(1.3.6.1.2.1.4.24.4.1.5) |
read-create |
Integer32 |
Interface index. |
Read only. |
ipCidrRouteType(1.3.6.1.2.1.4.24.4.1.6) |
read-create |
INTEGER |
Type of the route. |
Read only. |
ipCidrRouteProto(1.3.6.1.2.1.4.24.4.1.7) |
read-only |
INTEGER |
Protocol type. |
As per the MIB. |
ipCidrRouteAge(1.3.6.1.2.1.4.24.4.1.8) |
read-only |
Integer32 |
Time since the route was last updated. |
As per the MIB. |
ipCidrRouteInfo(1.3.6.1.2.1.4.24.4.1.9) |
read-create |
OBJECT IDENTIFIER |
Route information. |
The value is always 0. Read only. |
ipCidrRouteNextHopAS(1.3.6.1.2.1.4.24.4.1.10) |
read-create |
Integer32 |
AS number of the next hop. |
ipCidrRouteMetric1(1.3.6.1.2.1.4.24.4.1.11) |
read-create |
Integer32 |
Primary routing metric of the route. |
Read only. |
ipCidrRouteMetric2(1.3.6.1.2.1.4.24.4.1.12) |
read-create |
Integer32 |
Alternate routing metric of the route. |
The value is always -1. Read only. |
ipCidrRouteMetric3(1.3.6.1.2.1.4.24.4.1.13) |
read-create |
Integer32 |
ipCidrRouteMetric4(1.3.6.1.2.1.4.24.4.1.14) |
read-create |
Integer32 |
ipCidrRouteMetric5(1.3.6.1.2.1.4.24.4.1.15) |
read-create |
Integer32 |
ipCidrRouteStatus(1.3.6.1.2.1.4.24.4.1.16) |
read-create |
INTEGER |
Row status variable, used according to row installation and deletion conventions. |
Read only. |
inetCidrRouteTable
About this table
Use this table to obtain IP version-independent multipath CIDR routes.
Create |
Edit/Modify |
Delete |
Read |
Not supported |
Not supported |
Not supported |
Supported |
Columns
The table indexes are inetCidrRouteDestType, inetCidrRouteDest, inetCidrRoutePfxLen, inetCidrRoutePolicy, and inetCidrRouteNextHop.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
inetCidrRouteDestType (1.3.6.1.2.1.4.24.7.1.1) |
not-accessible |
Integer32 |
Destination address family. |
As per the MIB. |
inetCidrRouteDest (1.3.6.1.2.1.4.24.7.1.2) |
not-accessible |
Octets |
(0..255) |
Destination address. |
As per the MIB. |
inetCidrRoutePfxLen (1.3.6.1.2.1.4.24.7.1.3) |
not-accessible |
Gauge32 |
Prefix length of the destination address. |
As per the MIB. |
inetCidrRoutePolicy (1.3.6.1.2.1.4.24.7.1.4) |
not-accessible |
Object Identifier |
General set of route information. |
As per the MIB. |
inetCidrRouteNextHopType (1.3.6.1.2.1.4.24.7.1.5) |
not-accessible |
Integer32 |
Next hop address family. |
As per the MIB. |
inetCidrRouteNextHop (1.3.6.1.2.1.4.24.7.1.6) |
not-accessible |
Octets |
(0..255) |
As per the MIB. |
inetCidrRouteIfIndex (1.3.6.1.2.1.4.24.7.1.7) |
read-create |
Integer32 |
Output interface. |
Read only. |
inetCidrRouteType (1.3.6.1.2.1.4.24.7.1.8) |
read-create |
Integer32 |
Only supports remote, local, and blackhole. Read only. |
inetCidrRouteProto (1.3.6.1.2.1.4.24.7.1.9) |
read-only |
Integer32 |
Routing protocol type. |
Supports local, netmgmt, rip, ospf, is-is, bgp, and other (unspecified). |
inetCidrRouteAge (1.3.6.1.2.1.4.24.7.1.10) |
read-only |
Gauge32 |
Lifetime of the route. |
As per the MIB. |
inetCidrRouteNextHopAS (1.3.6.1.2.1.4.24.7.1.11) |
read-create |
Gauge32 |
inetCidrRouteMetric1 (1.3.6.1.2.1.4.24.7.1.12) |
read-create |
Integer32 |
Routing metric in the protocol. |
Read only. |
inetCidrRouteMetric2 (1.3.6.1.2.1.4.24.7.1.13) |
read-create |
Integer32 |
inetCidrRouteMetric3 (1.3.6.1.2.1.4.24.7.1.14) |
read-create |
Integer32 |
inetCidrRouteMetric4 (1.3.6.1.2.1.4.24.7.1.15) |
read-create |
Integer32 |
inetCidrRouteMetric5 (1.3.6.1.2.1.4.24.7.1.16) |
read-create |
Integer32 |
inetCidrRouteStatus (1.3.6.1.2.1.4.24.7.1.17) |
read-create |
Integer32 |
Row status. |
Read only. |
