07-Layer 3 - IP Services
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10107-Layer 3 - IP Services
02-HH3C-IP-ADDRESS-MIB
02-HH3C-IP-ADDRESS-MIB 52.60 KB
HH3C-IP-ADDRESS-MIB
About this MIB
Use this MIB to obtain and configure IPv4 addresses.
MIB file name
hh3c-ip-address.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cIpAddrMIB(67)
Scalar objects
hh3cIpAddrNotifyIfIndex
Object (OID)
Access
Value range
Implementation
hh3cIpAddrNotifyIfIndex (1.3.6.1.4.1.25506.2.67.2.1.1)
accessible-for-notify
Integer32
Integer32 (1..2147483647)
Interface index.
As per the MIB.
hh3cIpAddrOldIpAddress
Object (OID)
Access
Value range
Implementation
hh3cIpAddrOldIpAddress (1.3.6.1.4.1.25506.2.67.2.1.2)
InetAddress
OCTET STRING (0..255)
Old IP address.
As per the MIB.
hh3cIpAddrNewIpAddress
Object (OID)
Access
Value range
Implementation
hh3cIpAddrNewIpAddress (1.3.6.1.4.1.25506.2.67.2.1.3)
InetAddress
New IP address.
As per the MIB.
Tabular objects
hh3cIpAddrSetTable
About this table
Use this table to configure IPv4 addresses.
Support for operations
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table indexes are hh3cIpAddrSetIfIndex, hh3cIpAddrSetAddrType, and hh3cIpAddrSetAddr.
Object (OID)
Access
Value range
Implementation
hh3cIpAddrSetIfIndex (1.3.6.1.4.1.25506.2.67.1.1.1.1.1)
not-accessible
Integer32
Interface index.
As per the MIB.
hh3cIpAddrSetAddrType (1.3.6.1.4.1.25506.2.67.1.1.1.1.2)
not-accessible
InetAddressType
ipv4(1)
IP address version.
Only support ipv4(1)
hh3cIpAddrSetAddr (1.3.6.1.4.1.25506.2.67.1.1.1.1.3)
not-accessible
InetAddress
IP address.
As per the MIB.
hh3cIpAddrSetMask (1.3.6.1.4.1.25506.2.67.1.1.1.1.4)
read-create
IpAddress
OCTET STRING (4)
Address mask.
As per the MIB.
hh3cIpAddrSetSourceType (1.3.6.1.4.1.25506.2.67.1.1.1.1.5)
read-create
INTEGER
assignedIp(1)
Source type of the IPv4 address.
As per the MIB.
hh3cIpAddrSetCatalog (1.3.6.1.4.1.25506.2.67.1.1.1.1.6)
read-create
INTEGER
primary(1),
sub(2)
Type of the IPv4 address.
As per the MIB.
hh3cIpAddrSetRowStatus (1.3.6.1.4.1.25506.2.67.1.1.1.1.7)
read-create
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status of the IPv4 address.
Support active(1), createAndGo(4), and destroy(6) The value active(1) is read only.
hh3cIpAddrReadTable
About this table
Use this table to obtain IPv4 addresses.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cIpAddrReadIfIndex, hh3cIpAddrReadAddrType, hh3cIpAddrReadAddr.
Object (OID)
Access
Value range
Implementation
hh3cIpAddrReadIfIndex (1.3.6.1.4.1.25506.2.67.1.1.2.1.1)
not-accessible
Integer32
Interface index.
As per the MIB.
hh3cIpAddrReadAddrType (1.3.6.1.4.1.25506.2.67.1.1.2.1.2)
not-accessible
InetAddressType
ipv4(1)
IP address version.
Only support ipv4(1).
hh3cIpAddrReadAddr (1.3.6.1.4.1.25506.2.67.1.1.2.1.3)
not-accessible
InetAddress
IP address.
As per the MIB.
hh3cIpAddrReadMask (1.3.6.1.4.1.25506.2.67.1.1.2.1.4)
read-only
IpAddress
OCTET STRING (4)
Address mask.
As per the MIB.
hh3cIpAddrReadSourceType (1.3.6.1.4.1.25506.2.67.1.1.2.1.5)
read-only
INTEGER
assignedIp(1), cluster(2), dhcp(3), bootp(4), negotiate(5), unnumbered(6), vrrp(7)
As per the MIB.
hh3cIpAddrReadCatalog (1.3.6.1.4.1.25506.2.67.1.1.2.1.6)
read-only
INTEGER
primary(1), sub(2), cluster(3), vrrp(4)
As per the MIB.
hh3cIpv4AddrTable
About this table
Use this table to configure the primary IPv4 address of an interface.
Create
Edit/Modify
Delete
Read
Supported
Not supported
Supported
Supported
Columns
The table index is ifIndex.
Object (OID)
Access
Value range
Implementation
hh3cIpv4AddrAddr
(1.3.6.1.4.1.25506.2.67.1.1.3.1.1)
read-create
IpAddress
OCTET STRING (4)
IP address.
If the interface has no primary or secondary IP address, the value is 0.0.0.0.
hh3cIpv4AddrMask
(1.3.6.1.4.1.25506.2.67.1.1.3.1.2)
read-create
IpAddress
OCTET STRING (4)
Address mask.
As per the MIB.
hh3cIpv4AddrRowStatus
(1.3.6.1.4.1.25506.2.67.1.1.3.1.3)
read-create
RowStatus
active(1) ,
notInService(2) ,
createAndGo(4) ,
destroy(6)
Row status of the address configuration.
Support active(1), notInService(2), createAndGo(4), and destroy(6).
If the interface has primary or secondary IP address, the value is active(1).
If the interface has no primary or secondary IP address, the value is notInService(2).
