11-MPLS
HomeSupportRoutersCR16000-M SeriesReference GuidesMIB CompanionH3C CR16000-M Routers MIB Reference-R838x-6W10011-MPLS
11-HH3C-MPLSTE-MIB
11-HH3C-MPLSTE-MIB 167.83 KB
HH3C-MPLSTE-MIB
About this MIB
Use this MIB to manage MPLS TE and RSVP TE settings.
MIB file name
hh3c-mplste.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMplsTe(143)
Scalar objects
hh3cMplsTeStatus (1.3.6.1.4.1.25506.2.143.1.1.1)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Globally enable MPLS TE (mpls te) or TE attribute (te attribute enable) for the device.
As per the MIB.
hh3cMplsTeRsvpStatus (1.3.6.1.4.1.25506.2.143.1.1.2)
Object (OID)
Access
Value range
Implementation
read-write
TruthValue
true(1),
false(2)
Enabling status of global RSVP TE.
As per the MIB.
hh3cMplsTeTunnelInfo (1.3.6.1.4.1.25506.2.143.1.1.3)
Object (OID)
Access
Value range
Implementation
accessible-for-notify
OCTET STRING
OCTET STRING (1..127)
MPLS TE tunnel information
As per the MIB.
Tabular objects
hh3cMplsTeTable
About this table
This table specifies per-interface MPLS TE settings.
Support for operations
CreateSupported only when the value for hh3cMplsTeCapability is true(1)
Edit/ModifyNot supported
DeleteSupported
ReadSupported
Columns
The table index is hh3cMplsTeIndex.
Object (OID)
Access
Value range
Implementation
hh3cMplsTeIndex
(1.3.6.1.4.1.25506.2.143.1.2.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Index of an MPLS TE interface.
As per the MIB.
(1.3.6.1.4.1.25506.2.143.1.2.1.2)
read-create
TruthValue
true(1),
false(2)
MPLS TE capability of the interface. No MPLS TE capability information can be obtained when MPLS TE is not enabled on the interface.
As per the MIB.
hh3cMplsTeRowStatus
(1.3.6.1.4.1.25506.2.143.1.2.1.3)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6).
Row status.
Supports only the following values: active(1), createAndGo(4), and destroy(6).
hh3cMplsTeRsvpTable
About this table
This table specifies per-interface RSVP TE settings.
CreateSupported only when the value for hh3cMplsTeRsvpCapability is true(1)
DeleteSupported
ReadSupported
Columns
The table index is hh3cMplsTeRsvpIndex.
Object (OID)
Access
Value range
Implementation
hh3cMplsTeRsvpIndex
(1.3.6.1.4.1.25506.2.143.1.3.1.1)
not-accessible
Unsigned32
Unsigned32
(1..4294967295)
Index of an RSVP TE interface.
As per the MIB.
hh3cMplsTeRsvpRowStatus
(1.3.6.1.4.1.25506.2.143.1.3.1.3)
read-create
RowStatus
active(1)
createAndGo(4)
destroy(6).
Row status.
Notifications
hh3cMplsTeTunnelHsbSwitch
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.143.0.1
The primary LSP fails, and traffic is switched to the hot-standby backup LSP.
Error
Major
1.3.6.1.4.1.25506.2.143.0.2 (hh3cMplsTeTunnelHsbResume)
ON
Notification triggers
This notification is generated when the primary LSP fails and the system detects a hot-standby backup LSP and switches the traffic to the backup LSP.
System impact
The TE tunnel uses the hot-standby backup LSP for forwarding, which weakens the risk resistance capability.
Status control
ON
CLI: Use the snmp-agent trap enable te-private hsb-switch command.
OFF
CLI: Use the undo snmp-agent trap enable te-private hsb-switch command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
To resolve this issue:
1.Check the current tunnel interface configuration, RSVP and IGP configuration, and the whole tunnel path and bandwidth.
  - If an explicit path is configured, check whether the interfaces on each hop of the explicit path are faulty.
If yes, proceed to step 2.
If not, proceed to step 3.
  - If no explicit path is configured, check whether a path that satisfies the tunnel requirements exists. If yes, proceed to step 3.
2.Clear link faults.
3.Collect alarm information and configuration data, and then contact Technical Support for help.
Basic information
OID
Event
Severity
Default status
The primary LSP recovers from failure and traffic is switched back from the backup LSP to the primary LSP.
Informational
Warning
N/A (N/A)
ON
This notification is generated when the primary LSP recovers from failure and traffic is switched back from the hot-standby backup LSP to the primary LSP.
System impact
No negative impact on services.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
No action is required.
hh3cMplsTeTunnelObSwitch
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.143.0.3
The primary LSP fails and traffic is switched to the ordinary backup LSP.
Error
Major
1.3.6.1.4.1.25506.2.143.0.4 (hh3cMplsTeTunnelObResume)
ON
This notification is generated when the primary LSP fails and an ordinary backup LSP becomes up and takes over traffic forwarding.
System impact
The TE tunnel uses the ordinary backup LSP for forwarding, which weakens the risk resistance capability.
Status control
ON
CLI: Use the snmp-agent trap enable te-private ob-switch command.
OFF
CLI: Use the undo snmp-agent trap enable te-private ob-switch command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
3.Collect log messages and configuration data, and then contact Technical Support for help.
Basic information
OID
Event
Severity
Default status
The primary LSP recovers from failure and traffic is switched back from the ordinary backup LSP to the primary LSP.
Recovery
Warning
N/A (N/A)
ON
This notification is generated when the primary LSP recovers from failure and traffic is switched back from the ordinary backup LSP to the primary LSP.
System impact
No negative impact on the system.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
hh3cMplsTeTunnelHsbLspDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.143.0.5
Hot-standby LSP down
Error
Major
1.3.6.1.4.1.25506.2.143.0.6 (hh3cMplsTeTunnelHsbLspUp)
ON
For all types of tunnels, this notification might be generated when the following events occur:
The interface went Down.
The configuration of the tunnel was deleted.
The link was faulty.
The hot-standby LSP had nodes through which the primary LSP passed.
The tunnel was manually shut down.
Others.
For RSVP-TE tunnels, this notification might be generated when the following events occur:
RSVP-TE LSP resources were preempted.
Transmission of an RSVP message timed out.
RSVP Hello mechanism detected a downstream node failure.
CSPF failed to calculate a path.
For Segment Routing TE tunnels, this notification might be generated when the following events occur:
IGP calculation or verification failed.
The main and standby LSP are not configured with explicit-path.
System impact
No negative impact on services that do not use the hot-standby LSP of the tunnel for forwarding.
Services that use the hot-standby LSP of the tunnel for forwarding will be switch to another available LSP of the tunnel or will be dropped if no other LSPs are available for the tunnel.
Status control
ON
CLI: Use the snmp-agent trap enable te-private hsblsp-up-down command.
OFF
CLI: Use the undo snmp-agent trap enable te-private hsblsp-up-down command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
If yes, clear link faults.
If not, proceed to step 2.
  - If no explicit path is configured, check whether a path that satisfies the tunnel requirements exists. If yes, proceed to step 2.
2.For an RSVP-TE tunnel, check whether RSVP, link bandwidth and link affinity settings are correct.
  - If the settings are correct but the issue persists, go to step 3.
  - If the settings are not correct, edit the related configuration.
  - If the tunnel is not an RSVP-TE tunnel, go to step 3.
Basic information
OID
Event
Severity
Default status
Hot-standby LSP up
Informational
Warning
N/A (N/A)
ON
This notification is generated when LSP hot standby is configured on an MPLS TE tunnel interface and the hot-standby LSP comes up.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
hh3cMplsTeTunnelObLspDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.143.0.7
Ordinary backup LSP down
Error
Major
1.3.6.1.4.1.25506.2.143.0.8 (hh3cMplsTeTunnelObLspUp)
ON
Main LSP changed UP.
Others.
System impact
No negative impact on services that do not use the ordinary LSP of the tunnel for forwarding.
Services that use the ordinary LSP of the tunnel for forwarding will be switch to another available LSP of the tunnel or will be dropped if no other LSPs are available for the tunnel.
Status control
ON
CLI: Use the snmp-agent trap enable te-private oblsp-up-down command.
OFF
CLI: Use the undo snmp-agent trap enable te-private oblsp-up-down command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
Basic information
OID
Event
Severity
Default status
Ordinary backup LSP up
Informational
Warning
N/A (N/A)
ON
This notification is generated when ordinary backup is configured on an MPLS TE tunnel interface and the backup LSP comes up.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
hh3cMplsTeTunnelMainLspDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.143.0.9
Primary LSP down
Error
Major
1.3.6.1.4.1.25506.2.143.0.10 (hh3cMplsTeTunnelMainLspUp)
ON
Others.
System impact
No negative impact on services that do not use the primary LSP of the tunnel for forwarding.
Services that use the primary LSP of the tunnel for forwarding will be switch to an available backup LSP of the tunnel or will be dropped if no backup LSPs are available for the tunnel.
Status control
ON
CLI: Use the snmp-agent trap enable te-private mainlsp-up-down command.
OFF
CLI: Use the undo snmp-agent trap enable te-private mainlsp-up-down command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
Basic information
OID
Event
Severity
Default status
Primary LSP up
Informational
Warning
N/A (N/A)
ON
This notification is generated when the primary LSP comes up from the down state.
System impact
The tunnel will come up. If traffic was switched to the backup LSP of the tunnel, the tunnel will switch the traffic back to the primary LSP.
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
hh3cMplsTeTunnelChangeBw
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.143.0.11
MPLS TE tunnel bandwidth changes.
Informational
Major
N/A (N/A)
ON
This notification is generated when the bandwidth of the MPLS TE tunnel changes in the following situation:
The bandwidth was set or edited manually.
The bandwidth was adjusted automatically by the automatic bandwidth adjustment feature.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable te-private tunnelbw-change command.
OFF
CLI: Use the undo snmp-agent trap enable te-private tunnelbw-change command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
hh3cMplsTeAutoTunnelUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.143.0.12
Automatic TE tunnel up
Informational
Major
None (None)
ON
This notification is generated when an automatic TE tunnel comes up.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable te-private auto-tunnel-up command.
OFF
CLI: Use the undo snmp-agent trap enable te-private auto-tunnel-up command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
hh3cMplsTeLspBfdDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.143.0.13
BFD detected TE LSP Down.
Recovery
Major
1.3.6.1.4.1.25506.2.143.0.14 (hh3cMplsTeLspBfdDownClear)
ON
This notification is generated when TE LSP down is detected by BFD.
System impact
If the tunnel protection is not configured, the tunnel's traffic will be lost. If tunnel protection is configured, the tunnel's traffic will be switched to the backup LSP for forwarding.
Status control
ON
CLI: Use the snmp-agent trap enable te-private lspbfd-up-down command.
OFF
CLI: Use the undo snmp-agent trap enable te-private lspbfd-up-down command.
Object
OID (object name)
Index
Value range
MPLS TE tunnel information.
N/A
OCTET STRING
As per the MIB.
Recommended action
1.Verify that no packet loss occurs on the links of the LSP.
2.If the issue persists, contact Technical Support for help.
Basic information
OID
Event
Severity
Default status
The alarm that BFD detected TE LSP Down was cleared.
Informational
Warning
N/A (N/A)
ON
This notification might be generated when the following events occur:
BFD detected that a down TE LSP goes up.
The down TE LSP was deleted.
The BFD session for the down TE LSP was deleted.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
hh3cMplsTeTunnelDelete
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.143.0.15
The MPLS TE tunnel was deleted.
Informational
Major
N/A (N/A)
ON
This notification is generated when an MPLS TE tunnel is deleted.
System impact
Traffic forwarding on the tunnel is interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable te-private tunnel-delete command.
OFF
CLI: Use the undo snmp-agent trap enable te-private tunnel-delete command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
hh3cMplsTeAutoTunnelMainLspUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.143.0.16
The main LSP of the automatic tunnel went up.
Informational
Major
ON
This notification is generated when the main LSP of the automatic tunnel goes up.
System impact
Status control
ON
CLI: Use the snmp-agent trap enable te-private auto-tunnel-mainlsp-up command.
OFF
CLI: Use the undo snmp-agent trap enable te-private auto-tunnel-mainlsp-up command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
hh3cMplsTeP2mpTunnelSubLspDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.143.0.17
P2MP TE tunnel sub-LSP DOWN
Error
Major
N/A (N/A)
ON
The out interface of the RSVP LSP ingress is down.
Others
System impact
If FRR is configured for the sub-LSP, traffic will be switched to the bypass tunnel. If FRR is not configured, the multicast traffic forwarded on the sub-LSP will be lost.
Status control
ON
CLI: Use the snmp-agent trap enable te-private p2mp-sublsp-down command.
OFF
CLI: Use the undo snmp-agent trap enable te-private p2mp-sublsp-down command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
1.Identify the destination address of the down sub-LSP by using the display mpls te p2mp tunnel-interface command and then check if the link to the destination address is faulty.
  - If yes, repair the link.
  - If not, proceed to step 2.
2.Check whether the tunnel related configuration and protocol configuration are correct.
  - If yes, proceed to step 3.
  - If not, correct the configurations.
hh3cMplsTeP2mpTunnelDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.143.0.18
P2MP TE tunnel DOWN
Error
Major
1.3.6.1.4.1.25506.2.143.0.19 (hh3cMplsTeP2mpTunnelUp)
ON
Multicast service changed.
P2MP Tunnel All Sub Lsp Down.
Others.
System impact
Multicast services forwarded by this tunnel are interrupted.
Status control
ON
CLI: Use the snmp-agent trap enable te-private p2mp-tunnel-up-down command.
OFF
CLI: Use the undo snmp-agent trap enable te-private p2mp-tunnel-up-down command.
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
Basic information
OID
Event
Severity
Default status
P2MP TE tunnel UP
Recovery
Warning
ON
This notification is generated when a P2MP TE tunnel becomes up.
System impact
Status control
ON
OFF
Object
OID (object name)
Index
Value range
N/A
OCTET STRING
As per the MIB.
Recommended action
