07-Layer 3—IP Routing Configuration Guide
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration GuidesH3C S12500R Switch Router Series Configuration Guides(R52xx)-6W10007-Layer 3—IP Routing Configuration Guide
02-Static routing configuration
02-Static routing configuration 253.77 KB
Configuring static routing
About static routes
Static routes are manually configured. If a network's topology is simple, you only need to configure static routes for the network to work correctly.
Static routes cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually.
Configuring a static route
2.     Configure a static route.
Public network:
ip route-static dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address [ nexthop-index index-string ] ] | next-hop-address [ nexthop-index index-string ] [ recursive-lookup { host-route | longest-match } ] | vpn-instance d-vpn-instance-name next-hop-address [ nexthop-index index-string ] [ recursive-lookup { host-route | longest-match } ] } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static dest-address { mask-length | mask } { sr-policy policy-name | srv6-policy { color color-value end-point ipv6 ipv6-address | name policy-name } [ sid sid ] } [ preference preference ] [ tag tag-value ] [ description text ]
By default, no static route is configured.
You can associate Track with a static route to monitor the reachability of the next hops. For more information about Track, see High Availability Configuration Guide.
You cannot specify both the recursive-lookup host-route keywords and the recursive-lookup keyword.
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address [ nexthop-index index-string ] ] | next-hop-address [ nexthop-index index-string ] [ recursive-lookup { host-route | longest-match } ] [ public ] | vpn-instance d-vpn-instance-name next-hop-address [ nexthop-index index-string ] [ recursive-lookup { host-route | longest-match } ] } [ permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { sr-policy policy-name | srv6-policy { color color-value end-point ipv6 ipv6-address | name policy-name } [ sid sid ] } [ preference preference ] [ tag tag-value ] [ description text ]
3.     (Optional.) Enable periodic sending of ARP requests to the next hops of static routes.
ip route-static arp-request interval interval
By default, the device does not send ARP requests to the next hops of static routes.
4.     (Optional.) Configure the default preference for static routes.
ip route-static default-preference default-preference
The default setting is 60.
Configuring a static route group
This task allows you to batch create static routes with different prefixes but the same output interface and next hop.
You can create a static route group, and specify the static group in the ip route-static command. All prefixes in the static route group will be assigned the next hop and output interface specified in the ip route-static command.
2.     Create a static route group and enter its view.
ip route-static-group group-name
By default, no static route group is configured.
3.     Add a static route prefix to the static route group.
prefix dest-address { mask-length | mask }
By default, no static route prefix is added to the static route group.
4.     Return to system view.
5.     Configure a static route.
Public network:
ip route-static group group-name { interface-type interface-number [ next-hop-address ] | next-hop-address [ recursive-lookup { host-route | longest-match } ] [ track track-entry-number ] | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ track track-entry-number ] } [ permanent ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name group group-name { interface-type interface-number [ next-hop-address ] | next-hop-address [ recursive-lookup { host-route | longest-match } ] [ public ] [ track track-entry-number ] | vpn-instance d-vpn-instance-name next-hop-address [ recursive-lookup { host-route | longest-match } ] [ track track-entry-number ] } [ permanent ] [ preference preference ] [ tag tag-value ] [ recursive-lookup ] [ description text ]
Configuring the DHCP-designated default router as the next hop of a static route
After an interface obtains an IP address and gateway address through DHCP, the device automatically generates a static route with the interface as the output interface. The destination address of the static route is 0.0.0.0/0 and the next hop of the static route is the default router (the gateway address designated by the DHCP server). This static route cannot form ECMP routes with manually configured static routes. The device uses this static route to guide traffic forwarding only after the manually configured static routes become invalid.
Perform this task to use both the automatically generated static route and the manually configured static routes to guide traffic forwarding. The task is applicable when the device has dual egress WAN links.
This task enables the device to automatically generate a static route destined for the specified network with the DHCP-designated default router of the output interface as the next hop. This static route takes effect only after the output interface obtains an IP address and gateway address through DHCP, and becomes invalid upon the DHCP lease expiration. The next hop of this static route changes as the gateway address of the output interface changes. In addition, this static route can form ECMP routes with manually configured static routes.
When you configure the next hop of a static route as the DHCP-designated default router, make sure the output interface of the static route is a broadcast interface.
2.     Configure a static route and specify the default router designated by the DHCP server for the output interface as the next hop of the static route.
Public network:
ip route-static { dest-address { mask-length | mask } | group group-name } interface-type interface-number dhcp [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number dhcp [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] | permanent | track track-entry-number ] [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static vpn-instance s-vpn-instance-name group group-name interface-type interface-number dhcp [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] [ permanent ] ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, no static route is configured with the DHCP-designated default router as the next hop.
Configuring floating static routes
Perform this task to configure route backup to improve network reliability.
When a static or dynamic route to a destination address already exists on the device, you configure another static route with a lower priority as the backup route to improve the network reliability. This backup static route is called a floating static route and is activated only when the primary route fails. After the primary route recovers from failure, the floating static route becomes inactive and data forwarding switches back to the primary route.
A floating static route can be configured in either of the following ways
·     Configure different priorities for multiple static routes to the same destination address. The route with the lower priority automatically becomes the floating static route.
·     When a route to a destination address already exists on the device, configure a static route with a lower priority to the same destination address.
When you configure a floating static route, the priority value of the route must be larger than then priority value of the primary route. For more information, see "Configuring a static route."
Deleting static routes
To delete a static route, use the undo ip route-static command. To delete all static routes including the default route, use the delete static-routes all command.
2.     Delete all static routes.
Public network:
VPN:
delete vpn-instance vpn-instance-name static-routes all
CAUTION
CAUTION:
This command might interrupt network communication and cause packet forwarding failure. Before executing the command, make sure you fully understand the potential impact on the network.
Configuring BFD for static routes
IMPORTANT
IMPORTANT:
Enabling BFD for a flapping route could worsen the situation.
About BFD
BFD provides a general-purpose, standard, medium-, and protocol-independent fast failure detection mechanism. It can uniformly and quickly detect the failures of the bidirectional forwarding paths between two routers for protocols, such as routing protocols and MPLS.
For more information about BFD, see High Availability Configuration Guide.
Configuring BFD control packet mode
This mode uses BFD control packets to detect the status of a link bidirectionally at a millisecond level.
BFD control packet mode can be applied to static routes with a direct next hop or with an indirect next hop.
Restrictions and guidelines for BFD control packet mode
If you use BFD control packet mode at the local end, you must use this mode also at the peer end.
You cannot use BFD to detect a static route whose output interface is a tunnel interface.
Configuring BFD control packet mode for a static route (direct next hop)
2.     Configure BFD control packet mode for a static route.
Public network:
ip route-static dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd { control-packet | static session-name } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd { control-packet | static session-name } [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD control packet mode for a static route is not configured.
3.     (Optional.) Configure BFD session parameters for the static route.
ip route-static bfd interface-type interface-number next-hop-address { detect-multiplier detect-multiplier | min-receive-interval min-receive-interval | min-transmit-interval min-transmit-interval } *
By default, no BFD session parameters are specifically configured for a static route. The static route uses the session parameters configured for the BFD module (common BFD session parameters).
Configuring BFD control packet mode for a static route (indirect next hop)
Public network:
ip route-static dest-address { mask-length | mask } { next-hop-address bfd control-packet bfd-source ip-address | vpn-instance d-vpn-instance-name next-hop-address bfd { control-packet bfd-source ip-address | static session-name } } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { next-hop-address bfd { control-packet bfd-source ip-address | static session-name } | vpn-instance d-vpn-instance-name next-hop-address bfd { control-packet bfd-source ip-address | static session-name } } [ preference preference ] [ tag tag-value ] [ description text ]
ip route-static bfd [ vpn-instance d-vpn-instance-name ] next-hop-address source-ip ip-address { detect-multiplier detect-multiplier | min-receive-interval min-receive-interval | min-transmit-interval min-transmit-interval } *
Configuring BFD echo packet mode
With BFD echo packet mode enabled for a static route, the output interface sends BFD echo packets to the destination device, which loops the packets back to test the link reachability.
You do not need to configure BFD echo packet mode at the peer end.
Do not use BFD for a static route with the output interface in spoofing state.
2.     (Optional.) Configure the source address of echo packets.
bfd echo-source-ip ip-address
By default, the source address of echo packets is not configured.
As a best practice to avoid network congestion caused by excessive ICMP redirect packets from the peer, use this command. Make sure the source IPv4 address is not on the subnet of any interfaces on the device.
For more information about this command, see BFD in High Availability Command Reference.
3.     Configure BFD echo packet mode for a static route.
Public network:
ip route-static dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd { echo-packet | static session-name } [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number next-hop-address bfd { echo-packet | static session-name } [ preference preference ] [ tag tag-value ] [ description text ]
By default, BFD echo packet mode for a static route is not configured.
4.     (Optional.) Configure BFD session parameters for the static route.
ip route-static bfd interface-type interface-number next-hop-address { detect-multiplier detect-multiplier | min-echo-receive-interval min-echo-receive-interval } *
Configuring static route FRR
About static route FRR
A link or router failure on a path can cause packet loss. Static route fast reroute (FRR) enables fast rerouting to minimize the impact of link or node failures.
Figure 1 Network diagram
As shown in Figure 1, upon a link failure, packets are directed to the backup next hop to avoid traffic interruption. You can either specify a backup next hop for FRR or enable FRR to automatically select a backup next hop (which must be configured in advance).
Restrictions and guidelines for static route FRR
·     Do not use static route FRR and BFD (for a static route) at the same time.
·     Equal-cost routes do not support static route FRR.
·     Besides the configured static route for FRR, the device must have another route to reach the destination.
When the state of the primary link (with Layer 3 interfaces staying up) changes from bidirectional to unidirectional or down, static route FRR quickly redirects traffic to the backup next hop. When the Layer 3 interfaces of the primary link are down, static route FRR temporarily redirects traffic to the backup next hop. In addition, the device searches for another route to reach the destination and redirects traffic to the new path if a route is found. If no route is found, traffic interruption occurs.
Configuring static route FRR by specifying a backup next hop
A static route does not take effect when the backup output interface is unavailable.
To change the backup output interface or next hop, you must first remove the current setting. The backup output interface and next hop must be different from the primary output interface and next hop.
2.     Configure static route FRR.
Public network:
ip route-static dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] ] ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
VPN:
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } interface-type interface-number [ next-hop-address [ backup-interface interface-type interface-number [ backup-nexthop backup-nexthop-address ] ] ] [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
By default, static route FRR is disabled.
Configuring static route FRR to automatically select a backup next hop
2.     Configure static route FRR to automatically select a backup next hop.
ip route-static fast-reroute auto
By default, static route FRR is disabled from automatically selecting a backup next hop.
Enabling BFD echo packet mode for static route FRR
By default, static route FRR uses ARP to detect primary link failures. Perform this task to enable static route FRR to use BFD echo packet mode for fast failure detection on the primary link.
2.     (Optional.) Configure the source IP address of BFD echo packets.
By default, the source IP address of BFD echo packets is not configured.
3.     Enable BFD echo packet mode for static route FRR.
ip route-static primary-path-detect bfd echo
By default, BFD echo packet mode for static route FRR is disabled.
Allowing static routes to recurse to LSP tunnels
Devices in the service provider network will learn a large number of routes if they perform IP forwarding for all customer network packets. To conserve resources on the devices, use this feature on the device through which customer network users access the service provider network. This feature allows static routes to recurse to LSP tunnels. As a result, devices in the provider network will forward customer network IP packets based on labels, without the need to learn customer network routes.
This feature allows a device to preferentially recurse static routes to LSP tunnels. If a static route cannot recurse to an LSP tunnel, the device recurses the static route to an output interface and next hop.
2.     Enable the device to recurse static routes to LSP tunnels.
ip route-static recursive-lookup tunnel [ prefix-list ipv4-prefix-list-name ] [ tunnel-policy tunnel-policy-name | tunnel-selector tunnel-selector-name ]
By default, static routes cannot recurse to LSP tunnels.
Verifying and maintaining static routing
·     Display static route information.
display ip routing-table protocol static [ inactive | verbose ]
For more information about this command, see basic IP routing commands in Layer 3—IP Routing Command Reference.
·     Display static route next hop information.
display route-static nib [ nib-id ] [ verbose ]
·     Display static routing table information.
display route-static routing-table [ vpn-instance vpn-instance-name ] [ ip-address { mask-length | mask } ]
Static route configuration examples
Example: Configuring basic static routes
As shown in Figure 2, configure static routes on the routers for interconnections between any two hosts.
Figure 2 Network diagram
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
Configure IP addresses for the interfaces as shown in Figure 2.
1.     Configure static routes:
# Configure a default route on Router A.
[RouterA] ip route-static 0.0.0.0 0.0.0.0 1.1.4.2
# Configure two static routes on Router B.
<RouterB> system-view
[RouterB] ip route-static 1.1.2.0 255.255.255.0 1.1.4.1
[RouterB] ip route-static 1.1.3.0 255.255.255.0 1.1.5.6
# Configure a default route on Router C.
<RouterC> system-view
[RouterC] ip route-static 0.0.0.0 0.0.0.0 1.1.5.5
2.     Configure the default gateways of Host A, Host B, and Host C as 1.1.2.3, 1.1.6.1, and 1.1.3.1. (Details not shown.)
# Display the static route information on Router A.
[RouterA] display ip routing-table protocol static
Summary count : 1
Static Routing table status : <Active>
Summary count : 1
0.0.0.0/0           Static 60   0            1.1.4.2         HGE1/0/2
Static Routing table status : <Inactive>
Summary count : 0
# Display the static route information on Router B.
[RouterB] display ip routing-table protocol static
Summary count : 2
Summary count : 2
1.1.2.0/24          Static 60   0            1.1.4.1         HGE1/0/1
1.1.3.0/24          Static 60   0            1.1.5.6         HGE1/0/2
Summary count : 0
# Use the ping command on Host B to test the reachability of Host A (Windows XP runs on the two hosts).
C:\Documents and Settings\Administrator>ping 1.1.2.2
Pinging 1.1.2.2 with 32 bytes of data:
Reply from 1.1.2.2: bytes=32 time=1ms TTL=126
Ping statistics for 1.1.2.2:
# Use the tracert command on Host B to test the reachability of Host A.
C:\Documents and Settings\Administrator>tracert 1.1.2.2
Tracing route to 1.1.2.2 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  1.1.6.1
  2    <1 ms    <1 ms    <1 ms  1.1.4.1
  3     1 ms    <1 ms    <1 ms  1.1.2.2
Trace complete.
Example: Configuring BFD for static routes (direct next hop)
Configure the following, as shown in Figure 3:
·     Configure a static route to subnet 120.1.1.0/24 on Router A.
·     Configure a static route to subnet 121.1.1.0/24 on Router B.
·     Enable BFD for both routes.
·     Configure a static route to subnet 120.1.1.0/24 and a static route to subnet 121.1.1.0/24 on Router C.
When the link between Router A and Router B through the Layer 2 switch fails, BFD can detect the failure immediately. Router A then communicates with Router B through Router C.
Figure 3 Network diagram
Device
IP address
Router A
HundredGigE 1/0/1
12.1.1.1/24
Router A
HundredGigE 1/0/2
10.1.1.102/24
Router B
HundredGigE 1/0/1
12.1.1.2/24
Router B
HundredGigE 1/0/2
13.1.1.1/24
Router C
HundredGigE 1/0/1
10.1.1.100/24
Router C
HundredGigE 1/0/2
13.1.1.2/24
Configure IP addresses for the interfaces as shown in Figure 3.
# Configure static routes on Route A and enable BFD control packet mode for the static route that traverses the Layer 2 switch.
[RouterA] interface hundredgige 1/0/1
[RouterA-HundredGigE1/0/1] bfd min-transmit-interval 500
[RouterA-HundredGigE1/0/1] bfd min-receive-interval 500
[RouterA-HundredGigE1/0/1] bfd detect-multiplier 9
[RouterA-HundredGigE1/0/1] quit
[RouterA] ip route-static 120.1.1.0 24 hundredgige 1/0/1 12.1.1.2 bfd control-packet
[RouterA] ip route-static 120.1.1.0 24 hundredgige 1/0/2 10.1.1.100 preference 65
[RouterA] quit
# Configure static routes on Router B and enable BFD control packet mode for the static route that traverses the Layer 2 switch.
[RouterB] interface hundredgige 1/0/1
[RouterB-HundredGigE1/0/1] bfd min-transmit-interval 500
[RouterB-HundredGigE1/0/1] bfd min-receive-interval 500
[RouterB-HundredGigE1/0/1] bfd detect-multiplier 9
[RouterB-HundredGigE1/0/1] quit
[RouterB] ip route-static 121.1.1.0 24 hundredgige 1/0/1 12.1.1.1 bfd control-packet
[RouterB] ip route-static 121.1.1.0 24 hundredgige 1/0/2 13.1.1.2 preference 65
[RouterB] quit
# Configure static routes on Router C.
[RouterC] ip route-static 120.1.1.0 24 13.1.1.1
[RouterC] ip route-static 121.1.1.0 24 10.1.1.102
# Display BFD sessions on Router A.
<RouterA> display bfd session
 Total sessions: 1        Up sessions: 1        Init mode: Active
 IPv4 session working in control mode:
 LD/RD            SourceAddr      DestAddr        State Holdtime    Interface
 4/7              12.1.1.1        12.1.1.2        Up    2000ms      HGE1/0/1
The output shows that the BFD session has been created.
# Display static routes on Router A.
<RouterA> display ip routing-table protocol static
Summary count : 1
Summary count : 1
120.1.1.0/24        Static 60   0            12.1.1.2        HGE1/0/1
Summary count : 0
The output shows that Router A communicates with Router B through HundredGigE 1/0/1. Then the link over HundredGigE 1/0/1 fails.
Summary count : 1
Summary count : 1
120.1.1.0/24        Static 65   0            10.1.1.100      HGE1/0/2
Summary count : 0
The output shows that Router A communicates with Router B through HundredGigE 1/0/2.
Example: Configuring BFD for static routes (indirect next hop)
Figure 4 shows the network topology as follows:
·     Router A has a route to interface Loopback 1 (2.2.2.9/32) on Router B, with the output interface HundredGigE 1/0/1.
·     Router B has a route to interface Loopback 1 (1.1.1.9/32) on Router A, with the output interface HundredGigE 1/0/1.
·     Router D has a route to 1.1.1.9/32, with the output interface HundredGigE 1/0/1, and a route to 2.2.2.9/32, with the output interface HundredGigE 1/0/2.
Configure the following:
·     Configure a static route to subnet 120.1.1.0/24 and a static route to subnet 121.1.1.0/24 on both Router C and Router D.
When the link between Router A and Router B through Router D fails, BFD can detect the failure immediately. Router A then communicates with Router B through Router C.
Figure 4 Network diagram
Device
IP address
Router A
HundredGigE 1/0/1
12.1.1.1/24
Router A
HundredGigE 1/0/2
10.1.1.102/24
Router A
Loopback 1
1.1.1.9/32
Router B
HundredGigE 1/0/1
11.1.1.2/24
Router B
HundredGigE 1/0/2
13.1.1.1/24
Router B
Loopback 1
2.2.2.9/32
Router C
HundredGigE 1/0/1
10.1.1.100/24
Router C
HundredGigE 1/0/2
13.1.1.2/24
Router D
HundredGigE 1/0/1
12.1.1.2/24
Router D
HundredGigE 1/0/2
11.1.1.2/24
Configure IP addresses for the interfaces as shown in Figure 4.
# Configure static routes on Router A and enable BFD control packet mode for the static route that traverses Router D.
[RouterA] bfd multi-hop min-transmit-interval 500
[RouterA] bfd multi-hop min-receive-interval 500
[RouterA] bfd multi-hop detect-multiplier 9
[RouterA] ip route-static 120.1.1.0 24 2.2.2.9 bfd control-packet bfd-source 1.1.1.9
[RouterA] quit
# Configure static routes on Router B and enable BFD control packet mode for the static route that traverses Router D.
[RouterB] bfd multi-hop min-transmit-interval 500
[RouterB] bfd multi-hop min-receive-interval 500
[RouterB] bfd multi-hop detect-multiplier 9
[RouterB] ip route-static 121.1.1.0 24 1.1.1.9 bfd control-packet bfd-source 2.2.2.9
[RouterB] quit
# Configure static routes on Router D.
<RouterD> system-view
[RouterD] ip route-static 120.1.1.0 24 11.1.1.2
[RouterD] ip route-static 121.1.1.0 24 12.1.1.1
# Display the BFD session information on Router A.
 4/7              1.1.1.9         2.2.2.9         Up    2000ms      N/A
Summary count : 1
Summary count : 1
Summary count : 0
Summary count : 1
Summary count : 1
Summary count : 0
Example: Configuring static route FRR
As shown in Figure 5, configure static routes on Router A, Router B, and Router C, and configure static route FRR. When Link A becomes unidirectional, traffic can be switched to Link B immediately.
Figure 5 Network diagram
Table 3 Interface and IP address assignment
Device
IP address
Router A
HundredGigE 1/0/1
12.12.12.1/24
Router A
HundredGigE 1/0/2
13.13.13.1/24
Router A
Loopback 0
1.1.1.1/32
Router B
HundredGigE 1/0/1
24.24.24.4/24
Router B
HundredGigE 1/0/2
13.13.13.2/24
Router B
Loopback 0
4.4.4.4/32
Router C
HundredGigE 1/0/1
12.12.12.2/24
Router C
HundredGigE 1/0/2
24.24.24.2/24
Configure IP addresses for the interfaces as shown in Figure 5.
1.     Configure static route FRR on link A by using one of the following methods:
¡     (Method 1.) Specify a backup next hop for static route FRR:
# Configure a static route on Router A, and specify HundredGigE 1/0/1 as the backup output interface and 12.12.12.2 as the backup next hop.
[RouterA] ip route-static 4.4.4.4 32 hundredgige 1/0/2 13.13.13.2 backup-interface hundredgige 1/0/1 backup-nexthop 12.12.12.2
# Configure a static route on Router B, and specify HundredGigE 1/0/1 as the backup output interface and 24.24.24.2 as the backup next hop.
[RouterB] ip route-static 1.1.1.1 32 hundredgige 1/0/2 13.13.13.1 backup-interface hundredgige 1/0/1 backup-nexthop 24.24.24.2
¡     (Method 2.) Configure static route FRR to automatically select a backup next hop:
# Configure static routes on Router A, and enable static route FRR.
[RouterA] ip route-static 4.4.4.4 32 hundredgige 1/0/1 12.12.12.2 preference 70
[RouterA] ip route-static fast-reroute auto
# Configure static routes on Router B, and enable static route FRR.
[RouterB] ip route-static 1.1.1.1 32 hundredgige 1/0/1 24.24.24.2 preference 70
[RouterB] ip route-static fast-reroute auto
2.     Configure static routes on Router C.
[RouterC] ip route-static 4.4.4.4 32 hundredgige 1/0/2 24.24.24.4
[RouterC] ip route-static 1.1.1.1 32 hundredgige 1/0/1 12.12.12.1
# Display route 4.4.4.4/32 on Router A to view the backup next hop information.
[RouterA] display ip routing-table 4.4.4.4 verbose
Summary count : 1
Destination: 4.4.4.4/32
   Protocol: Static
  Process ID: 0
   SubProtID: 0x0                        Age: 04h20m37s
        Cost: 0                   Preference: 60
       IpPre: N/A                 QosLocalID: N/A
         Tag: 0                        State: Active Adv
   OrigTblID: 0x0                    OrigVrf: default-vrf
     TableID: 0x2                     OrigAs: 0
       NibID: 0x26000002              LastAs: 0
      AttrID: 0xffffffff            Neighbor: 0.0.0.0
       Flags: 0x1008c            OrigNextHop: 13.13.13.2
       Label: NULL               RealNextHop: 13.13.13.2
     BkLabel: NULL                 BkNextHop: 12.12.12.2
     SRLabel: NULL                 Interface: HundredGigE1/0/2
   BkSRLabel: NULL               BkInterface: HundredGigE1/0/1
   Tunnel ID: Invalid            IPInterface: HundredGigE1/0/2
 BkTunnel ID: Invalid          BKIPInterface: HundredGigE1/0/1
     InLabel: NULL            ColorInterface: N/A
    SIDIndex: NULL          BKColorInterface: N/A
    FtnIndex: 0x0            TunnelInterface: N/A
TrafficIndex: N/A          BKTunnelInterface: N/A
   Connector: N/A                     PathID: 0x0
  SRTunnelID: Invalid
    SID Type: N/A                        NID: Invalid
    FlushNID: Invalid                  BkNID: Invalid
  BkFlushNID: Invalid              StatFlags: 0x0
         Exp: N/A
   VpnPeerId: N/A                       Dscp: N/A
         SID: N/A           OrigLinkID: 0x0
       BkSID: N/A           RealLinkID: 0x0
CommBlockLen: 0
# Display route 1.1.1.1/32 on Router B to view the backup next hop information.
[RouterB] display ip routing-table 1.1.1.1 verbose
Summary count : 1
Destination: 1.1.1.1/32
   Protocol: Static
  Process ID: 0
        Cost: 0                   Preference: 10
       Flags: 0x1008c            OrigNextHop: 13.13.13.1
       Label: NULL               RealNextHop: 13.13.13.1
     BkLabel: NULL                 BkNextHop: 24.24.24.2
  SRTunnelID: Invalid
         Exp: N/A
CommBlockLen: 0
Configuring a default route
A default route is used to forward packets that do not match any specific routing entry in the routing table. Without a default route, packets that do not match any routing entries are discarded and an ICMP destination-unreachable packet is sent to the source.
A default route can be configured in either of the following ways:
·     The network administrator can configure a default route with both destination and mask being 0.0.0.0. For more information, see "Configuring static routing."
·     Some dynamic routing protocols can generate a default route. For example, an upstream router running OSPF can generate a default route and advertise it to other routers. These routers install the default route with the next hop being the upstream router. For more information, see the respective chapters on these routing protocols in this configuration guide.
As shown in Figure 6, Device B is the next hop for packets from Device A to Device C, Device D, and Device E. You can configure a default route on Device A to replace the three static routes from Device A to Device C, Device D, and Device E, respectively. Then, packets that do not match any other routes will be forwarded based on the default route.
The next hop address, destination address, and subnet mask of the default route configured on Device A are 1.1.1.2, 0.0.0.0, and 0.0.0.0, respectively.
Figure 6 Configuring a default route
