- 14-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-SNMP commands
- 05-RMON commands
- 06-Event MIB commands
- 07-NETCONF commands
- 08-CWMP commands
- 09-EAA commands
- 10-Process monitoring and maintenance commands
- 11-Sampler commands
- 12-Mirroring commands
- 13-NetStream commands
- 14-IPv6 NetStream commands
- 15-Fast log output commands
- 16-Performance management commands
- 17-Information center commands
00-Preface | 100.03 KB |
Preface
This command reference describes the commands for configuring basic and extended network management and monitoring features.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
