13-High Availability Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SR6600 SR6600-X Routers Command Reference(V7)-R7821-6W50113-High Availability Command Reference
07-Layer 3 connection keepalive commands
07-Layer 3 connection keepalive commands 48.21 KB
display l3-keepalive
Use display l3-keepalive to display Layer 3 connection keepalive information.
# Display Layer 3 connection keepalive information.
<Sysname> display l3-keepalive
Interface            Track ID       State
GE2/0/1              1              NotReady
GE2/0/2              2              Positive
Track ID
Track entry associated with the Layer 3 connection keepalive feature.
State of the track entry:
·     Positive—The tracked object operates correctly (the peer is reachable).
·     Negative—The tracked object is abnormal (the peer is unreachable).
·     NotReady—The detection result is invalid.
l3-keepalive
l3-keepalive
Use l3-keepalive to enable the Layer 3 connection keepalive feature and associate a track entry with the feature.
Use undo l3-keepalive to disable the Layer 3 connection keepalive feature.
l3-keepalive track track-entry-number
undo l3-keepalive
The Layer 3 connection keepalive feature is disabled.
VLAN interface view
track track-entry-number: Specifies the track entry by its ID in the range of 1 to 1024. For more information about Track, see High Availability Configuration Guide.
If a device becomes faulty but its interfaces are functional, the device can receive IP packets from other devices but is unable to process them. The Layer 3 connection keepalive feature can address this issue by detecting peer device faults. With this feature enabled, an interface stops sending Layer 3 packets to a peer device when it detects that the peer device is faulty. Upon discovering this Layer 3 connection failure, the administrator can troubleshoot the faulty device immediately in order to resume Layer 3 communication between devices.
Only one track entry can be associated with the Layer 3 connection keepalive feature on an interface. If you execute this command multiple times, the most recent configuration takes effect.
This feature can work with only ARP NQA operations.
# Enable the Layer 3 connection keepalive feature and associate track entry 2 with the feature on GigabitEthernet 2/0/1.
[Sysname-GigabitEthernet2/0/1] l3-keepalive track 2
# Enable the Layer 3 connection keepalive feature and associate track entry 2 with the feature on VLAN-interface 10.
[Sysname-Vlan-interface10] l3-keepalive track 2
nqa entry (Network Management and Monitoring Command Reference)
track nqa
